antivirus system pro
Post by jewelcraft on Tue Nov 10, 2009 7:13 pm
Help I got it back, it seems I keep getting this thing under one name or another over and over. I cant download and run any removers or scans and I dont know what to do. Please help
jewelcraft
Posts Posts : 28
Joined Joined : 2009-07-04
Points Points : 27292
Re: antivirus system pro
Post by Belahzur on Tue Nov 10, 2009 7:55 pm
Points Points : 245049
Post by jewelcraft on Tue Nov 10, 2009 8:01 pm
It wont let me open hijackthis, it says its infected and blocks it. I cant even start my computer in safemode...
jewelcraft
Posts Posts : 28
Post by Belahzur on Tue Nov 10, 2009 8:04 pm
Post by jewelcraft on Tue Nov 10, 2009 8:18 pm
exeHelper by Raktor
Build 20091021
Run at exeHelper by Raktor
Build 20091021
Run at 15:12:03 on 11/10/09
Now searching...
Checking for bad processes...
Checking for bad files...
Resetting policies...
--Finished--
exeHelper by Raktor
exeHelper by Raktor
Build 20091021
Run at 15:12:35 on 11/10/09
Now searching...
--Finished--
exeHelper by Raktor
exeHelper by Raktor
Build 20091021
Run at 15:16:12exeHelper by Raktor
Build 20091021
Run at 15:16:16 on 11/10/09
Now searching...
--Finished--
exeHelper by Raktor
Build 20091021
Run at 15:16:29exeHelper by Raktor
Build 20091021
Build 20091021
Run at 15:16:36 on 11/10/09
Now searching...
--Finished--
jewelcraft
Posts Posts : 28
Post by Belahzur on Tue Nov 10, 2009 8:18 pm
Can you run Hijack This now?
Post by jewelcraft on Tue Nov 10, 2009 8:52 pm
Scan saved at 3:48:09 PM, on 11/10/2009
C:\Program Files\iWin Games\iWinTrusted.exe
C:\PROGRA~1\AVANQU~1\Fix-It\mxtask.exe
C:\Program Files\QuickTime\qttask.exe
C:\Program Files\Brother\Brmfcmon\BrMfcWnd.exe
C:\Documents and Settings\Wanda_2\Local Settings\Application Data\rhgwqw\twndsysguard.exe
C:\Program Files\Brother\ControlCenter3\brccMCtl.exe
C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe
C:\Program Files\Brother\Brmfcmon\BrMfcmon.exe
O1 - Hosts: ::1 localhost
O1 - Hosts: 91.212.127.227 awareremover2009.microsoft.com
O1 - Hosts: 91.212.127.227 awareremover2009.com
O1 - Hosts: 91.212.127.227 [You must be registered and logged in to see this link.]
O2 - BHO: NCO 2.0 IE BHO - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408} - (no file)
O2 - BHO: Free Game Bar Toolbar - {6f094b04-2c69-4ff3-ac74-d9716e97e296} - C:\Program Files\Free_Game_Bar\tbFree.dll
O2 - BHO: (no name) - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - (no file)
O2 - BHO: BrowserHelper Class - {8A9D74F9-560B-4FE7-ABEB-3B2E638E5CD6} - C:\Program Files\SGPSA\SearchAssistant.dll
O2 - BHO: (no name) - {AA58ED58-01DD-4d91-8333-CF10577473F7} - (no file)
O2 - BHO: (no name) - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - (no file)
O2 - BHO: BHO - {B6D223F6-C185-49a2-BA7E-A03E84744702} - C:\WINDOWS\system32\iehelper.dll
O2 - BHO: Google Dictionary Compression sdch - {C84D72FE-E17D-4195-BB24-76C02E2E7C4E} - (no file)
O2 - BHO: Search Assistant - {F0626A63-410B-45E2-99A1-3F2475B2D695} - C:\Program Files\SGPSA\BHO.dll
O2 - BHO: XBTBPos00 - {FCBCCB87-9224-4B8D-B117-F56D924BEB18} - C:\Program Files\Fast Browser Search\IE\FBStoolbar.dll
O3 - Toolbar: (no name) - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - (no file)
O3 - Toolbar: (no name) - {4E7BD74F-2B8D-469E-92BE-BF2DFE9AAE2C} - (no file)
O3 - Toolbar: (no name) - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - (no file)
O3 - Toolbar: (no name) - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - (no file)
O3 - Toolbar: Fast Browser Search Toolbar - {1BB22D38-A411-4B13-A746-C2A4F4EC7344} - C:\Program Files\Fast Browser Search\IE\FBStoolbar.dll
O3 - Toolbar: Free Game Bar Toolbar - {6f094b04-2c69-4ff3-ac74-d9716e97e296} - C:\Program Files\Free_Game_Bar\tbFree.dll
O4 - HKLM\..\Run: [VirusScannerPro] C:\PROGRA~1\AVANQU~1\Fix-It\MemCheck.exe
O4 - HKLM\..\Run: [PPort11reminder] "C:\Program Files\ScanSoft\PaperPort\Ereg\Ereg.exe" -r "C:\Documents and Settings\All Users\Application Data\ScanSoft\PaperPort\11\Config\Ereg\Ereg.ini"
O4 - HKLM\..\Run: [BrMfcWnd] C:\Program Files\Brother\Brmfcmon\BrMfcWnd.exe /AUTORUN
O4 - HKLM\..\Run: [ControlCenter3] C:\Program Files\Brother\ControlCenter3\brctrcen.exe /autorun
O4 - HKLM\..\Run: [SGPUpdater] C:\Program Files\Search Guard PlusU\sgpUpdaters.exe
O4 - HKLM\..\Run: [FBSearch] C:\Program Files\Search Guard Plus\SearchGuardPlus.exe
O4 - HKLM\..\Run: [lhwnmhkm] C:\Documents and Settings\Wanda_2\Local Settings\Application Data\rhgwqw\twndsysguard.exe
O4 - HKCU\..\Run: [lhwnmhkm] C:\Documents and Settings\Wanda_2\Local Settings\Application Data\rhgwqw\twndsysguard.exe
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\WINDOWS\system32\shdocvw.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\WINDOWS\system32\shdocvw.dll
O9 - Extra button: (no name) - {85d1f590-48f4-11d9-9669-0800200c9a66} - C:\WINDOWS\bdoscandel.exe
O9 - Extra 'Tools' menuitem: Uninstall BitDefender Online Scanner - {85d1f590-48f4-11d9-9669-0800200c9a66} - C:\WINDOWS\bdoscandel.exe
O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\system32\Shdocvw.dll
O9 - Extra button: Run IMVU - {d9288080-1baa-4bc4-9cf8-a92d743db949} - C:\WINDOWS\system32\shdocvw.dll
O16 - DPF: {149E45D8-163E-4189-86FC-45022AB2B6C9} (SpinTop DRM Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {1A1F56AA-3401-46F9-B277-D57F3421F821} (FunGamesLoader Object) - [You must be registered and logged in to see this link.]
O16 - DPF: {1D082E71-DF20-4AAF-863B-596428C49874} (TPIR Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {2C153C75-8476-434B-B3C3-57B63A3D1939} (Brickout Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {352797A0-EFD0-4FA6-B229-145120EA4B8A} (Walt Disney Internet Group Hardware Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {5D86DDB5-BDF9-441B-9E9E-D4730F4EE499} (BDSCANONLINE Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {5ED80217-570B-4DA9-BF44-BE107C0EC166} (Windows Live Safety Center Base Module) - [You must be registered and logged in to see this link.]
O16 - DPF: {8A94C905-FF9D-43B6-8708-F0F22D22B1CB} (Wwlaunch Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {A52FBD2B-7AB3-4F6B-90E3-91C772C5D00F} (WoF Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {B1E2B96C-12FE-45E2-BEF1-44A219113CDD} (SABScanProcesses Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {BB21F850-63F4-4EC9-BF9D-565BD30C9AE9} (a-squared Scanner) - [You must be registered and logged in to see this link.]
O16 - DPF: {BDBDE413-7B1C-4C68-A8FF-C5B2B4090876} (F-Secure Online Scanner 3.3) - [You must be registered and logged in to see this link.]
O16 - DPF: {CC450D71-CC90-424C-8638-1F2DBAC87A54} (ArmHelper Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {CF969D51-F764-4FBF-9E90-475248601C8A} (FamilyFeud Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {D0C0F75C-683A-4390-A791-1ACFD5599AB8} (Oberon Flash Game Host) - [You must be registered and logged in to see this link.]
O16 - DPF: {D71F9A27-723E-4B8B-B428-B725E47CBA3E} (Imikimi_activex_plugin Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {E6BB2089-163F-466B-812A-748096614DFD} (CAScanner Control) - [You must be registered and logged in to see this link.]
O18 - Filter: x-sdch - {B1759355-3EEC-4C1E-B0F1-B719FE26E377} - (no file)
O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.dll
O23 - Service: Fix-It Task Manager - Avanquest North America, Inc. - C:\PROGRA~1\AVANQU~1\Fix-It\mxtask.exe
O23 - Service: Google Update Service (gupdate1ca26895b87caa0) (gupdate1ca26895b87caa0) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: Google Software Updater (gusvc) - Unknown owner - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe (file missing)
O23 - Service: iWinTrusted - iWin Inc. - C:\Program Files\iWin Games\iWinTrusted.exe
O23 - Service: Kodak AiO Device Service (KodakSvc) - Eastman Kodak Company - C:\Program Files\Kodak\printer\center\KodakSvc.exe
O23 - Service: Windows Defender (WinDefend) - Unknown owner - C:\Program Files\Windows Defender\MsMpEng.exe (file missing)
O23 - Service: Yahoo! Updater (YahooAUService) - Yahoo! Inc. - C:\Program Files\Yahoo!\SoftwareUpdate\YahooAUService.exe
End of file - 9303 bytes
jewelcraft
Posts Posts : 28
Post by Belahzur on Tue Nov 10, 2009 9:02 pm
Post by jewelcraft on Tue Nov 10, 2009 9:30 pm
jewelcraft
Posts Posts : 28
Post by jewelcraft on Tue Nov 10, 2009 9:44 pm
Scan saved at 4:44:14 PM, on 11/10/2009
End of file - 7457 bytes
jewelcraft
Posts Posts : 28
Post by jewelcraft on Tue Nov 10, 2009 10:21 pm
Thank You so much, whatever you did or had me do,,,it worked at least for now. It seems to be gone again. If you have any advise on keeping it gone please let me know and again thank you!!
jewelcraft
Posts Posts : 28
Post by Belahzur on Wed Nov 11, 2009 12:37 am
Not done yet, all we did was disable and hopefully removed some of it, but I still think there is some leftovers hanging around.
Post by jewelcraft on Wed Nov 11, 2009 9:12 pm
DDS (Ver_09-10-26.01)
Microsoft Windows XP Home Edition
Install Date: 7/20/2008 3:26:45 PM
System Uptime: 11/11/2009 9:03:36 AM (7 hours ago)
Motherboard: Dell Inc. | | 0RY206
Processor: AMD Sempron(tm) Processor LE-1300 | Socket AM2 | 2310/200mhz
C: is fȋxed (NTFS) - 149 GiB total, 120.472 GiB free.
D: is CDROM ()
E: is Removable
RP321: 9/25/2009 2:57:59 PM - System Checkpoint
RP322: 9/25/2009 2:57:59 PM - System Checkpoint
RP323: 9/25/2009 2:57:59 PM - System Checkpoint
RP324: 9/25/2009 2:57:59 PM - System Checkpoint
RP325: 9/25/2009 2:57:59 PM - System Checkpoint
RP326: 9/25/2009 2:57:59 PM - System Checkpoint
RP327: 9/25/2009 2:57:59 PM - System Checkpoint
RP328: 9/25/2009 2:57:59 PM - Installed Windows Internet Explorer 8.
RP329: 9/25/2009 2:57:59 PM - Software Distribution Service 3.0
RP330: 9/25/2009 2:57:59 PM - System Checkpoint
RP331: 9/25/2009 2:57:59 PM - System Checkpoint
RP332: 9/25/2009 2:57:59 PM - System Checkpoint
RP333: 9/25/2009 2:57:59 PM - System Checkpoint
RP334: 9/25/2009 2:57:59 PM - Installed PC SpeedScan Pro
RP335: 9/25/2009 2:57:59 PM - Removed PC SpeedScan Pro
RP336: 9/25/2009 2:57:59 PM - System Checkpoint
RP337: 9/25/2009 2:57:59 PM - System Checkpoint
RP338: 9/25/2009 2:57:59 PM - System Checkpoint
RP339: 9/25/2009 2:57:59 PM - System Checkpoint
RP340: 9/25/2009 2:57:59 PM - System Checkpoint
RP341: 9/25/2009 2:57:59 PM - System Checkpoint
RP342: 9/25/2009 2:57:59 PM - Installed ScanSoft PaperPort 11
RP343: 9/25/2009 2:57:59 PM - Installed PaperPort Image Printer
RP344: 9/25/2009 2:57:59 PM - Printer Driver Nuance Image Printer Driver Installed
RP345: 9/25/2009 2:57:59 PM - Installed Brother MFL-Pro Suite
RP346: 9/25/2009 2:57:59 PM - Unsigned printer driver Brother PC-FAX v.2 installed.
RP347: 9/25/2009 2:57:59 PM - System Checkpoint
RP348: 9/25/2009 2:57:59 PM - System Checkpoint
RP349: 9/25/2009 2:57:59 PM - System Checkpoint
RP350: 9/25/2009 2:57:59 PM - Software Distribution Service 3.0
RP351: 9/25/2009 2:57:59 PM - System Checkpoint
RP352: 9/25/2009 2:57:59 PM - System Checkpoint
RP353: 9/25/2009 2:57:59 PM - System Checkpoint
RP354: 9/25/2009 2:57:59 PM - System Checkpoint
RP355: 9/25/2009 2:57:59 PM - System Checkpoint
RP356: 9/25/2009 2:57:59 PM - System Checkpoint
RP357: 9/25/2009 2:57:59 PM - System Checkpoint
RP358: 9/25/2009 2:57:59 PM - System Checkpoint
RP359: 9/25/2009 2:57:59 PM - System Checkpoint
RP360: 9/25/2009 2:57:59 PM - System Checkpoint
RP361: 9/25/2009 2:57:59 PM - System Checkpoint
RP362: 9/25/2009 2:57:59 PM - System Checkpoint
RP363: 9/25/2009 2:57:59 PM - System Checkpoint
RP364: 9/25/2009 2:57:59 PM - System Checkpoint
RP365: 9/25/2009 2:57:59 PM - System Checkpoint
RP366: 9/25/2009 2:57:59 PM - System Checkpoint
RP367: 9/25/2009 2:57:59 PM - System Checkpoint
RP368: 9/25/2009 2:58:00 PM - System Checkpoint
RP369: 9/25/2009 2:58:00 PM - System Checkpoint
RP370: 9/25/2009 2:58:00 PM - System Checkpoint
RP371: 9/25/2009 2:58:00 PM - System Checkpoint
RP372: 9/25/2009 2:58:00 PM - System Checkpoint
RP373: 9/25/2009 2:58:00 PM - System Checkpoint
RP374: 9/25/2009 2:58:00 PM - System Checkpoint
RP375: 9/25/2009 2:58:00 PM - Software Distribution Service 3.0
RP376: 9/25/2009 2:58:00 PM - System Checkpoint
RP377: 9/25/2009 2:58:00 PM - System Checkpoint
RP378: 9/25/2009 2:58:00 PM - System Checkpoint
RP379: 9/25/2009 2:58:00 PM - System Checkpoint
RP380: 9/25/2009 2:58:00 PM - System Checkpoint
RP381: 9/25/2009 2:58:00 PM - System Checkpoint
RP382: 9/25/2009 2:58:00 PM - System Checkpoint
RP383: 9/25/2009 2:58:00 PM - System Checkpoint
RP384: 9/25/2009 2:58:00 PM - System Checkpoint
RP385: 9/25/2009 2:58:00 PM - System Checkpoint
RP386: 9/25/2009 2:58:00 PM - System Checkpoint
RP387: 9/25/2009 2:58:00 PM - System Checkpoint
RP388: 9/25/2009 2:58:00 PM - System Checkpoint
RP389: 9/25/2009 2:58:00 PM - System Checkpoint
RP390: 9/25/2009 2:58:00 PM - System Checkpoint
RP391: 9/25/2009 2:58:00 PM - System Checkpoint
RP392: 9/25/2009 2:58:00 PM - System Checkpoint
RP393: 9/25/2009 2:58:00 PM - Removed Barbie(R) idesign(TM) Ultimate Stylist(TM).
RP394: 9/25/2009 2:58:00 PM - Removed Lets Ride Silver Buckle Stables
RP395: 9/25/2009 2:58:00 PM - System Checkpoint
RP396: 9/25/2009 2:58:00 PM - Software Distribution Service 3.0
RP397: 9/25/2009 2:58:00 PM - System Checkpoint
RP398: 9/25/2009 2:58:00 PM - System Checkpoint
RP399: 9/25/2009 2:58:00 PM - Restore Operation
RP400: 9/25/2009 2:58:00 PM - System Checkpoint
RP401: 9/25/2009 2:58:00 PM - System Checkpoint
RP402: 9/25/2009 2:58:00 PM - Installed STOPzilla. Available with Windows Installer version 1.2 and later.
RP403: 9/25/2009 2:58:00 PM - Removed STOPzilla. Available with Windows Installer version 1.2 and later.
RP404: 9/25/2009 2:58:00 PM - Avira AntiVir Personal - 7/10/2009 10:02
RP405: 9/25/2009 2:58:00 PM - System Checkpoint
RP406: 9/25/2009 2:58:00 PM - System Checkpoint
RP407: 9/25/2009 2:58:00 PM - System Checkpoint
RP408: 9/25/2009 2:58:00 PM - System Checkpoint
RP409: 9/25/2009 2:58:00 PM - System Checkpoint
RP410: 9/25/2009 2:58:00 PM - Software Distribution Service 3.0
RP411: 9/25/2009 2:58:00 PM - System Checkpoint
RP412: 9/25/2009 2:58:00 PM - System Checkpoint
RP413: 9/25/2009 2:58:01 PM - System Checkpoint
RP414: 9/25/2009 2:58:01 PM - System Checkpoint
RP415: 9/25/2009 2:58:01 PM - System Checkpoint
RP416: 9/25/2009 2:58:01 PM - Installed Windows Media Format Runtime
RP417: 9/25/2009 2:58:02 PM - Installed Windows Media Format Runtime
RP418: 9/25/2009 2:58:03 PM - Software Distribution Service 3.0
RP419: 9/25/2009 2:58:03 PM - System Checkpoint
RP420: 9/25/2009 2:58:04 PM - System Checkpoint
RP421: 9/25/2009 2:58:04 PM - System Checkpoint
RP422: 9/25/2009 2:58:04 PM - Printer Driver Microsoft XPS Document Writer Installed
RP423: 9/25/2009 2:58:04 PM - System Checkpoint
RP424: 9/25/2009 2:58:04 PM - Avira AntiVir Personal - 8/13/2009 13:23
RP425: 9/25/2009 2:58:04 PM - System Checkpoint
RP426: 9/25/2009 2:58:04 PM - System Checkpoint
RP427: 9/25/2009 2:58:05 PM - Software Distribution Service 3.0
RP428: 9/25/2009 2:58:05 PM - Software Distribution Service 3.0
RP429: 9/25/2009 2:58:05 PM - System Checkpoint
RP430: 9/25/2009 2:58:05 PM - Software Distribution Service 3.0
RP431: 9/25/2009 2:58:05 PM - System Checkpoint
RP432: 9/25/2009 2:58:05 PM - System Checkpoint
RP433: 9/25/2009 2:58:05 PM - Software Distribution Service 3.0
RP434: 9/25/2009 2:58:05 PM - System Checkpoint
RP435: 9/25/2009 2:58:05 PM - System Checkpoint
RP436: 9/25/2009 2:58:05 PM - System Checkpoint
RP437: 9/25/2009 2:58:06 PM - Software Distribution Service 3.0
RP438: 9/25/2009 2:58:06 PM - System Checkpoint
RP439: 9/25/2009 2:58:06 PM - Software Distribution Service 3.0
RP440: 9/25/2009 2:58:06 PM - Software Distribution Service 3.0
RP441: 9/25/2009 2:58:06 PM - System Checkpoint
RP442: 9/25/2009 2:58:06 PM - System Checkpoint
RP443: 9/25/2009 2:58:06 PM - Windows Defender Checkpoint
RP444: 9/25/2009 2:58:07 PM - Software Distribution Service 3.0
RP445: 9/25/2009 2:58:07 PM - System Checkpoint
RP446: 9/25/2009 2:58:07 PM - Software Distribution Service 3.0
RP447: 9/25/2009 2:58:07 PM - System Checkpoint
RP448: 9/25/2009 2:58:07 PM - Software Distribution Service 3.0
RP449: 9/25/2009 2:58:08 PM - System Checkpoint
RP450: 9/25/2009 2:58:08 PM - System Checkpoint
RP451: 9/25/2009 2:58:08 PM - Software Distribution Service 3.0
RP452: 9/25/2009 2:58:08 PM - System Checkpoint
RP453: 9/25/2009 2:58:08 PM - System Checkpoint
RP454: 9/25/2009 2:58:08 PM - Software Distribution Service 3.0
RP455: 9/25/2009 2:58:08 PM - Software Distribution Service 3.0
RP456: 9/25/2009 2:58:09 PM - Installation
RP457: 9/25/2009 2:58:09 PM - eGames GameButler (tm)
RP458: 9/25/2009 2:58:09 PM - System Checkpoint
RP459: 9/25/2009 2:58:09 PM - System Checkpoint
RP460: 9/25/2009 2:58:09 PM - System Checkpoint
RP461: 9/25/2009 2:58:09 PM - Software Distribution Service 3.0
RP462: 9/25/2009 2:58:09 PM - System Checkpoint
RP463: 9/25/2009 2:58:09 PM - System Checkpoint
RP464: 9/25/2009 2:58:10 PM - Software Distribution Service 3.0
RP465: 9/25/2009 2:58:10 PM - System Checkpoint
RP466: 9/25/2009 2:58:10 PM - System Checkpoint
RP467: 9/25/2009 2:58:10 PM - System Checkpoint
RP468: 9/25/2009 2:58:10 PM - Software Distribution Service 3.0
RP469: 9/25/2009 2:58:11 PM - System Checkpoint
RP470: 9/25/2009 2:58:11 PM - System Checkpoint
RP471: 9/25/2009 2:58:11 PM - Software Distribution Service 3.0
RP472: 9/25/2009 3:29:01 PM - Windows Defender Checkpoint
RP473: 10/4/2009 12:13:01 AM - System Checkpoint
RP474: 10/4/2009 4:36:39 AM - Microsoft Antimalware Checkpoint
RP475: 10/5/2009 12:17:15 PM - Restore Operation
RP476: 10/6/2009 11:45:58 AM - Installed Microsoft Easy Assist v2
RP477: 10/7/2009 1:30:51 PM - System Checkpoint
RP478: 10/8/2009 2:05:24 PM - System Checkpoint
RP479: 10/9/2009 2:56:21 PM - System Checkpoint
RP480: 10/10/2009 5:12:33 PM - System Checkpoint
RP481: 10/11/2009 8:55:36 PM - System Checkpoint
RP482: 10/12/2009 10:25:36 PM - System Checkpoint
RP483: 10/13/2009 10:51:19 PM - System Checkpoint
RP484: 10/14/2009 11:56:11 PM - System Checkpoint
RP485: 10/16/2009 12:15:24 AM - System Checkpoint
RP486: 10/17/2009 10:12:27 AM - System Checkpoint
RP487: 10/18/2009 10:54:38 AM - System Checkpoint
RP488: 10/19/2009 10:54:58 AM - System Checkpoint
RP489: 10/20/2009 12:15:53 PM - System Checkpoint
RP490: 10/21/2009 2:15:34 PM - System Checkpoint
RP491: 10/22/2009 3:44:41 PM - System Checkpoint
RP492: 10/23/2009 4:11:01 PM - System Checkpoint
RP493: 10/24/2009 6:49:47 PM - System Checkpoint
RP494: 10/25/2009 7:06:17 PM - System Checkpoint
RP495: 10/26/2009 7:16:59 PM - System Checkpoint
RP496: 10/27/2009 8:58:01 PM - System Checkpoint
RP497: 10/28/2009 9:59:10 PM - System Checkpoint
RP498: 10/29/2009 8:20:55 PM - Cleaned registry with Windows Live OneCare safety scanner
RP499: 10/29/2009 9:24:29 PM - Removed WeatherBug
RP500: 10/31/2009 12:05:50 AM - System Checkpoint
RP501: 11/1/2009 9:17:54 AM - System Checkpoint
RP502: 11/2/2009 11:00:24 AM - System Checkpoint
RP503: 11/3/2009 2:36:42 PM - System Checkpoint
RP504: 11/4/2009 3:52:00 PM - System Checkpoint
RP505: 11/6/2009 12:22:13 PM - System Checkpoint
RP506: 11/7/2009 3:09:48 PM - System Checkpoint
RP507: 11/8/2009 4:14:17 PM - System Checkpoint
RP508: 11/9/2009 8:09:09 PM - System Checkpoint
RP509: 11/11/2009 9:41:08 AM - System Checkpoint
123 Free Solitaire 2008 v6.0
3D Falling Leaves Animated Wallpaper
3D Frog Frenzy
3D Snowy Cottage Animated Wallpaper
Adobe Flash Player 10 ActiveX
Adobe Reader 8
Adobe Shockwave Player 11
aiofw
aioocr
aioprnt
aioscnnr
Annabel (remove only)
AOL Coach Version 2.0(Build:20041026.5 en)
AOL You've Got Pictures Screensaver
Autumn Tree
AVS Video Editor 4 4.2.1.166
AVS Video Recorder 2.4 (Service Version)
AVS YouTube Uploader version 2.1
AVS4YOU Software Navigator 1.3
Barbie(TM) as Rapunzel
Big City Adventure: San Francisco
Big City Adventure: Sydney Australia
Blood Ties
Brother MFL-Pro Suite MFC-290C
Business Card Designer Plus 9.5.0.0
CA Yahoo! Anti-Spy (remove only)
CCScore
center
CleanUp!
Conexant D850 56K V.9x DFVc Modem
Coupon Printer for Windows
Cradle of Rome (remove only)
Dancing with the Stars
Dell Support Center
Diamond Drop 2 (CD version)
Discovery
Documentation & Support Launcher
Double Solitaire 2.00
DXG-518
Embarq Toolbar
ESSBrwr
ESSCDBK
ESScore
ESSgui
ESSini
ESSPCD
ESSSONIC
ESSTOOLS
essvatgt
Falling leaves Wallpaper
Family Feud Dream Home (remove only)
Fashion Apprentice
Fast Browser Search (My Web Tattoo)
Feeding Frenzy 2 Deluxe 1.0
Finders Keepers
Fix-It Utilities 8 Professional
Free_Game_Bar Toolbar
Freeze Wallpaper
FunPhotor 5.0
G.H.O.S.T. Hunters: The Haunting of Majesty Manor
GameHouse
Games, Music, & Photos Launcher
Google Chrome
Google Update Helper
Help_CTR
helptut
helpug
Heroes of Hellas (remove only)
Hide and Secret
HijackThis 2.0.2
Imikimi Plugin
Intel(R) Integrated Performance Primitives RTI 4.0
InterActual Player
Internet Service Offers Launcher
Interpol 2: Most Wanted (remove only)
iWin Games (remove only)
Jewel Quest II (remove only)
Jewel Quest Online Party (remove only)
kgcbaby
kgcbase
kgchday
kgchlwn
kgcinvt
kgckids
kgcmove
kgcvday
KODAK All-in-One Printer Software
ksdip
Leeloo's Talent Agency
Little Shop: Memories (remove only)
Marooned
Microsoft .NET Framework 1.1
Microsoft Office PowerPoint Viewer 2007 (English)
Microsoft Visual C++ 2008 ATL Update kb973924 - x86 9.0.30729.4148
Microsoft Works
Modem Diagnostic Tool
MostFun.com Games - Big City Adventure: San Francisco (remove only)
MostFun.com Games - Big City Adventure: Sydney Australia (remove only)
MostFun.com Games - Fashion Apprentice (remove only)
MostFun.com Games - Finders Keepers (remove only)
MostFun.com Games - G.H.O.S.T. Hunters: The Haunting of Majesty Manor (remove only)
MostFun.com Games - Neverland (remove only)
MostFun.com Games - Pirate Island (remove only)
MostFun.com Games - Rainbow Mystery (remove only)
MostFun.com Games - Righteous Kill (remove only)
MostFun.com Games - Slingo Quest (remove only)
MostFun.com Games - Snowy: The Bears Adventures (remove only)
MostFun.com Games - Super Granny 4 (remove only)
MostFun.com Games - The Lost Cases of Sherlock Holmes (remove only)
MSN
MSXML 4.0
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
MSXML 6.0 Parser (KB933579)
Mystery of Unicorn Castle
Mystery Solitaire: Secret Island (remove only)
netbrdg
NetWaiting
Neverland
Norton Security Scan
NVIDIA Drivers
OfotoXMI
PakMan 2008
PCDADDIN
PCDHELP
Photo Viewer
Pirate Island
Pop-Up Stopper Free Edition
PowerDVD
Presto! VideoWorks 6
Print Artist Express
QuickTime
Rainbow Mystery
RealArcade
RealPlayer Basic
Registry Mechanic 8.0
Righteous Kill
Scooby-Doo(TM), Case File #1 The Glowing Bug Man
Search Guard Plus (My Web Tattoo)
Search Guard Plus Updater (My Web Tattoo)
Security Update for Windows Internet Explorer 8 (KB969897)
Security Update for Windows Internet Explorer 8 (KB972260)
Security Update for Windows XP (KB950759)
SFR
SHASTA
skin0001
SKINXSDK
Slingo Quest
Spyware Doctor 6.1
staticcr
Super Granny 4
SUPERAntiSpyware Free Edition
Supermarket Mania
The Treasures Of Mystery Island
tooltips
Total 3D Home
Treasure Masters
TriJinx
Uninstall JL2005A Camera
Unity Web Player
Update for Windows Internet Explorer 8 (KB968220)
Viewpoint Media Player
VIVA MEDIA GAME CENTER
VPRINTOL
WebFldrs XP
Windows Defender
Windows XP Service Pack 3
WIRELESS
Yahoo! Messenger
Yahoo! Search Protection
Yahoo! Software Update
11/8/2009 3:18:27 PM, error: Service Control Manager [7011] - Timeout (30000 milliseconds) waiting for a transaction response from the Netman service.
11/6/2009 10:44:34 AM, error: Service Control Manager [7026] - The following boot-start or system-start driver(s) failed to load: Beep
11/6/2009 10:44:32 AM, error: Service Control Manager [7000] - The Windows Defender service failed to start due to the following error: The system cannot find the path specified.
11/5/2009 6:28:36 PM, error: Print [6161] - The document Full page fax print owned by Wanda_2 failed to print on printer Brother MFC-290C Printer. Data type: NT EMF 1.008. Size of the spool file in bytes: 0. Number of bytes printed: 0. Total number of pages in the document: 1. Number of pages printed: 0. Client machine: \\D1FNS3G1. Win32 error code returned by the print processor: 259 (0x103).
11/5/2009 4:18:35 PM, error: Service Control Manager [7023] - The Application Management service terminated with the following error: The specified module could not be found.
11/4/2009 9:49:28 AM, error: Service Control Manager [7011] - Timeout (30000 milliseconds) waiting for a transaction response from the WZCSVC service.
11/10/2009 3:26:49 PM, error: Service Control Manager [7034] - The Fix-It Task Manager service terminated unexpectedly. It has done this 1 time(s).
11/10/2009 2:25:33 PM, error: Service Control Manager [7009] - Timeout (30000 milliseconds) waiting for the Kodak AiO Device Service service to connect.
11/10/2009 2:25:33 PM, error: Service Control Manager [7000] - The Kodak AiO Device Service service failed to start due to the following error: The service did not respond to the start or control request in a timely fashion.
11/10/2009 2:24:57 PM, error: Ftdisk [49] - Configuring the Page file for crash dump failed. Make sure there is a page file on the boot partition and that is large enough to contain all physical memory.
11/10/2009 2:24:57 PM, error: Ftdisk [45] - The system could not sucessfully load the crash dump driver.
jewelcraft
Posts Posts : 28
Post by jewelcraft on Wed Nov 11, 2009 9:13 pm
Run by Wanda_2 at 16:09:12.03 on Wed 11/11/2009
Internet Explorer: 8.0.6001.18702
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.1982.1473 [GMT -5:00]
AV: Avanquest VirusScanner Pro *On-access scanning enabled* (Updated) {6A383D4C-7657-408f-BD0D-B379B5C7C3BE}
AV: Microsoft Security Essentials *On-access scanning disabled* (Updated) {BCF43643-A118-4432-AEDE-D861FCBCFCDF}
svchost.exe
svchost.exe
svchost.exe
svchost.exe
C:\Documents and Settings\Wanda_2\Desktop\dds.pif
TB: {2318C2B1-4965-11D4-9B18-009027A5CD4F} - No File
mRun: [VirusScannerPro] c:\progra~1\avanqu~1\fix-it\MemCheck.exe
mRun: [PPort11reminder] "c:\program files\scansoft\paperport\ereg\ereg.exe" -r "c:\documents and settings\all users\application data\scansoft\paperport\11\config\ereg\Ereg.ini"
mRun: [BrMfcWnd] c:\program files\brother\brmfcmon\BrMfcWnd.exe /AUTORUN
mRun: [ControlCenter3] c:\program files\brother\controlcenter3\brctrcen.exe /autorun
mRun: [SGPUpdater] c:\program files\search guard plusu\sgpUpdaters.exe
mRun: [FBSearch] c:\program files\search guard plus\SearchGuardPlus.exe
IE: &Search
IE: {85d1f590-48f4-11d9-9669-0800200c9a66} - %windir%\bdoscandel.exe
IE: {d9288080-1baa-4bc4-9cf8-a92d743db949}
IE: {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - {CAFEEFAC-0015-0000-0006-ABCDEFFEDCBC}
IE: {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - {FE54FA40-D68C-11d2-98FA-00C0F0318AFE} - c:\windows\system32\Shdocvw.dll
DPF: {149E45D8-163E-4189-86FC-45022AB2B6C9} - [You must be registered and logged in to see this link.]
DPF: {1A1F56AA-3401-46F9-B277-D57F3421F821} - [You must be registered and logged in to see this link.]
DPF: {1D082E71-DF20-4AAF-863B-596428C49874} - [You must be registered and logged in to see this link.]
DPF: {2C153C75-8476-434B-B3C3-57B63A3D1939} - [You must be registered and logged in to see this link.]
DPF: {352797A0-EFD0-4FA6-B229-145120EA4B8A} - [You must be registered and logged in to see this link.]
DPF: {5D86DDB5-BDF9-441B-9E9E-D4730F4EE499} - [You must be registered and logged in to see this link.]
DPF: {5ED80217-570B-4DA9-BF44-BE107C0EC166} - [You must be registered and logged in to see this link.]
DPF: {8A94C905-FF9D-43B6-8708-F0F22D22B1CB} - [You must be registered and logged in to see this link.]
DPF: {A52FBD2B-7AB3-4F6B-90E3-91C772C5D00F} - [You must be registered and logged in to see this link.]
DPF: {B1E2B96C-12FE-45E2-BEF1-44A219113CDD} - [You must be registered and logged in to see this link.]
DPF: {BB21F850-63F4-4EC9-BF9D-565BD30C9AE9} - [You must be registered and logged in to see this link.]
DPF: {BDBDE413-7B1C-4C68-A8FF-C5B2B4090876} - [You must be registered and logged in to see this link.]
DPF: {CC450D71-CC90-424C-8638-1F2DBAC87A54} - [You must be registered and logged in to see this link.]
DPF: {CF969D51-F764-4FBF-9E90-475248601C8A} - [You must be registered and logged in to see this link.]
DPF: {D0C0F75C-683A-4390-A791-1ACFD5599AB8} - [You must be registered and logged in to see this link.]
DPF: {D71F9A27-723E-4B8B-B428-B725E47CBA3E} - [You must be registered and logged in to see this link.]
DPF: {E6BB2089-163F-466B-812A-748096614DFD} - [You must be registered and logged in to see this link.]
Notify: !SASWinLogon - c:\program files\superantispyware\SASWINLO.dll
SEH: {091EB208-39DD-417D-A5DD-7E2C2D8FB9CB} - No File
SEH: SABShellExecuteHook Class: {5ae067d3-9afb-48e0-853a-ebb7f4a000da} - c:\program files\superantispyware\SASSEH.DLL
mASetup: {A509B1FF-37FF-4bFF-8CFF-4F3A747040FF} - c:\windows\system32\rundll32.exe c:\windows\system32\advpack.dll,launchinfsectionex c:\program files\internet explorer\clrtour.inf,DefaultInstall.ResetTour,,12
R0 Achernar;Achernar - SCSI Command Filters;c:\windows\system32\drivers\Achernar.sys [2008-7-20 16855]
R1 SASDIFSV;SASDIFSV;c:\program files\superantispyware\sasdifsv.sys [2009-6-23 9968]
R1 SASKUTIL;SASKUTIL;c:\program files\superantispyware\SASKUTIL.SYS [2009-6-23 74480]
R2 iWinTrusted;iWinTrusted;c:\program files\iwin games\iWinTrusted.exe [2009-9-2 78104]
R2 tmpreflt;tmpreflt;c:\progra~1\avanqu~1\fix-it\tmpreflt.sys [2007-8-31 32528]
R2 YahooAUService;Yahoo! Updater;c:\program files\yahoo!\softwareupdate\YahooAUService.exe [2008-11-9 602392]
R3 Aldebaran;Aldebaran - SCSI Command Filters;c:\windows\system32\drivers\Aldebaran.sys [2008-7-20 21808]
R3 MailScan;MailScan;c:\progra~1\avanqu~1\fix-it\MailScan.sys [2008-8-26 20496]
S2 gupdate1ca26895b87caa0;Google Update Service (gupdate1ca26895b87caa0);c:\program files\google\update\GoogleUpdate.exe [2009-8-26 133104]
S2 KodakSvc;Kodak AiO Device Service;c:\program files\kodak\printer\center\KodakSvc.exe [2008-2-28 18944]
S3 JL2005;JL2005A Camera;c:\windows\system32\drivers\toywdm.sys [2005-10-8 71512]
S3 SASENUM;SASENUM;c:\program files\superantispyware\SASENUM.SYS [2009-6-23 7408]
2009-11-10 21:51:43 0 d-s---w- C:\ComboFix
2009-11-10 19:13:59 159600 ----a-w- c:\windows\system32\drivers\pctgntdi.sys
2009-11-10 19:13:53 86888 ----a-w- c:\windows\system32\drivers\PCTAppEvent.sys
2009-11-10 19:13:53 206256 ----a-w- c:\windows\system32\drivers\PCTCore.sys
2009-11-10 19:13:48 0 d-----w- c:\program files\common files\PC Tools
2009-11-10 19:13:47 64392 ----a-w- c:\windows\system32\drivers\pctplsg.sys
2009-11-10 19:13:43 0 d-----w- c:\docume~1\wanda_2\applic~1\PC Tools
2009-11-10 19:13:43 0 d-----w- c:\docume~1\alluse~1\applic~1\PC Tools
2009-11-06 19:17:14 0 d-----w- c:\program files\Conduit
2009-11-06 19:17:13 0 d-----w- c:\program files\Free_Game_Bar
2009-11-06 13:59:26 4720 ----a-w- c:\windows\system32\PerfStringBackup.TMP
2009-11-02 01:34:41 0 d-----w- c:\program files\SGPSA
2009-11-02 01:34:21 0 d-----w- c:\program files\Fast Browser Search
2009-10-30 00:46:41 1310 ----a-w- C:\halloween_log.html
2009-10-29 21:48:33 0 d-----w- c:\windows\system32\drivers\NSS
2009-10-29 21:48:33 0 d-----w- c:\program files\Norton Security Scan
2009-10-29 21:48:33 0 d-----w- c:\docume~1\alluse~1\applic~1\Norton
2009-10-29 21:44:30 0 d-----w- c:\program files\NortonInstaller
2009-10-29 21:44:30 0 d-----w- c:\docume~1\alluse~1\applic~1\NortonInstaller
2009-10-29 21:33:54 50176 ----a-w- c:\windows\system32\proquota.exe
2009-10-29 21:33:54 50176 ----a-w- c:\windows\system32\dllcache\proquota.exe
2009-10-29 21:27:12 77312 ----a-w- c:\windows\MBR.exe
2009-10-29 21:27:12 236544 ----a-w- c:\windows\PEV.exe
2009-10-29 21:04:44 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-10-29 21:04:43 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-10-29 21:04:43 0 d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-10-03 23:26:02 11336 ----a-w- c:\windows\system32\drivers\kgpcpy.cfg
2009-10-01 14:29:14 195440 ----a-w- c:\windows\system32\MpSigStub.exe
2009-09-26 02:24:57 376 ----a-w- c:\windows\system32\drivers\kgpfr2.cfg
2009-08-31 09:49:34 819200 ----a-w- c:\windows\system32\SaqScreenSaver.scr
2009-08-26 12:12:52 147456 ----a-w- c:\windows\system32\Fishdom Screensaver.scr
2008-09-08 04:01:40 32768 --sha-w- c:\windows\system32\config\systemprofile\local settings\history\history.ie5\mshist012008090720080908\index.dat
2009-07-22 15:02:54 32768 --sha-w- c:\windows\system32\config\systemprofile\local settings\history\history.ie5\mshist012009072220090723\index.dat
============= FINISH: 16:10:19.69 ===============
jewelcraft
Posts Posts : 28
Post by Belahzur on Wed Nov 11, 2009 11:17 pm
  • Save it to your desktop.
    :files
    :reg
    "SGPUpdater"=-
    "FBSearch"=-
  • Close OTMoveIt
Please post the OTMoveIt log.
Post by jewelcraft on Thu Nov 12, 2009 12:26 am
========== FILES ==========
c:\program files\Conduit\Community Alerts folder moved successfully.
c:\program files\Conduit folder moved successfully.
c:\program files\Free_Game_Bar folder moved successfully.
c:\program files\Fast Browser Search\IE folder moved successfully.
c:\program files\Fast Browser Search folder moved successfully.
Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\\SGPUpdater deleted successfully.
Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\\FBSearch deleted successfully.
OTM by OldTimer - Version 3.1.1.0 log created on 11112009_192457
jewelcraft
Posts Posts : 28
Post by jewelcraft on Thu Nov 12, 2009 12:27 am
jewelcraft
Posts Posts : 28
Post by Belahzur on Thu Nov 12, 2009 1:22 am
Okay, last scan.
Post by jewelcraft on Thu Nov 12, 2009 1:52 am
Database version: 3141
11/11/2009 8:52:17 PM
mbam-log-2009-11-11 (20-52-17).txt
Objects scanned: 144198
Time elapsed: 6 minute(s), 10 second(s)
jewelcraft
Posts Posts : 28
Post by Belahzur on Thu Nov 12, 2009 1:54 am
We can remove OTMoveIt now.
  • Please double-click OTM.exe to run it again.
  • Press the green CleanUp! button.
  • Press Yes cleanup process prompt, do the same for the reboot prompt.
Post by jewelcraft on Thu Nov 12, 2009 2:04 pm
Everything seems to be good again, thank you so very much... How do these things get into a computer and again, can you tell me how to keep it gone??
jewelcraft
Posts Posts : 28
Post by Belahzur on Thu Nov 12, 2009 5:25 pm
Post by shanabelle on Fri Feb 05, 2010 4:48 am
Moderated Message: Hello, your comment has been removed. Please do not post in another member's topic. If you need help, please read [You must be registered and logged in to see this link.] over and [You must be registered and logged in to see this link.] to open a new topic. -Belahzur
shanabelle
Joined Joined : 2010-02-05
OS OS : mac, microsoft word
Points Points : 24958
