Problems with removing antivirus pro
Post by Jaynie bug on Tue 10 Nov 2009, 12:44 pm
T.T I am having great difficulty with removing antivirus system pro. This is the third time it's attacked my computer. The previous two times I was able to remove it by just starting my computer up from a previous memory, but now that I have some important things on here, I don't want to go that rout if I don't have to.
I've downloaded the Malwarebytes' Anti-malware program and I've run it several times. But pop ups keep coming, and porn sights, and ed problem sights, and the program isn't working for me.
Any suggestions?
~jaynie bug
Jaynie bug
Operating System : Windows xp
Re: Problems with removing antivirus pro
Post by Belahzur on Wed 11 Nov 2009, 4:33 am
Please download the current version of HijackThis from HERE
Manager | Tech Officer
