Antivirus System Pro
Post by ranism7 on 9th November 2009, 10:42 pm
My computer has been infected by Antivirus System Pro. I can't run any program. I was reading your postings and tried to run Hijackthis but always says the program is infected. What can I do? Help please
ranism7
Posts Posts : 31
Joined Joined : 2009-11-09
Points Points : 26215
Re: Antivirus System Pro
Post by Dr Jay on 10th November 2009, 12:11 am
Posts Posts : 14309
Points Points : 302960
Post by ranism7 on 10th November 2009, 2:34 am
I finally could disable the Mcfee, but anytime I try to execute the command, the alert window shows up saying the file commy.exe is infected. What else can I do?
thanks
ranism7
Posts Posts : 31
Post by Dr Jay on 10th November 2009, 2:57 am
  • Click Scan now.
  • Read and put a Check next to Yes I accept the terms of use.
  • Click the Launching HouseCall>> button.
  • If confirmed that HouseCall can run on your system, under Using Java-based HouseCall kernel click the Starting HouseCall>> button.
  • You may receive a Security Warning about the TrendMicro Java applet, click YES.
  • Under Scan complete computer for malware, grayware, and vulnerabilities click the Next>> button.
  • Please be patient while it installs, updates, and scans your system.
  • Once the scan is complete, it will take you to the summary page.
  • Under Cleanup options, choose clean all detected infections automatically.
  • Click the Clean now>> button.
  • If anything was found you may be prompted to run the scan again, you can just close the browser window.
Posts Posts : 14309
Post by ranism7 on 10th November 2009, 3:10 am
Well, I could get the Hijackthis running and this is the log, should I tried Housecall or continue with this?
Scan saved at 9:07:30 PM, on 11/9/2009
C:\Program Files\McAfee.com\Agent\mcagent.exe
C:\WINDOWS\vsnpmi03.exe
C:\Documents and Settings\Administrator.HOUSE-F9KCUBM1Q\Local Settings\Application Data\orjnpy\qqpqsysguard.exe
C:\Program Files\The Weather Channel FW\Desktop\DesktopWeather.exe
C:\Program Files\Adobe\Acrobat 6.0\Distillr\acrotray.exe
C:\Program Files\McAfee\SiteAdvisor\McSACore.exe
C:\Program Files\Common Files\Motive\McciCMService.exe
c:\PROGRA~1\COMMON~1\mcafee\mna\mcnasvc.exe
C:\Program Files\Microsoft\Search Enhancement Pack\SeaPort\SeaPort.exe
C:\PROGRA~1\McAfee\MSM\McSmtFwk.exe
C:\PROGRA~1\McAfee\VIRUSS~1\mcods.exe
R3 - URLSearchHook: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll
O1 - Hosts: ::1 localhost
O1 - Hosts: 91.212.127.227 awareremover2009.microsoft.com
O1 - Hosts: 91.212.127.227 awareremover2009.com
O1 - Hosts: 91.212.127.227 [You must be registered and logged in to see this link.]
O2 - BHO: &Yahoo! Toolbar Helper - {02478D38-C3F9-4EFB-9B51-7695ECA05670} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll
O2 - BHO: Skype add-on (mastermind) - {22BF413B-C6D2-4d91-82A9-A0F997BA588C} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O2 - BHO: Windows Live Family Safety Browser Helper - {4f3ed5cd-0726-42a9-87f5-d13f3d2976ac} - C:\Program Files\Windows Live\Family Safety\fssbho.dll
O2 - BHO: Yahoo! IE Services Button - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O2 - BHO: Search Helper - {6EBF7485-159F-4bff-A14F-B9E3AAC4465B} - C:\Program Files\Microsoft\Search Enhancement Pack\Search Helper\SEPsearchhelperie.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - c:\PROGRA~1\mcafee\VIRUSS~1\scriptsn.dll
O2 - BHO: TwcToolbarBhoApp Class - {AA1F9DDB-E605-4ba6-81D4-E427DEE012AD} - C:\WINDOWS\SYSTEM32\TwcToolbarBho.dll
O2 - BHO: AcroIEToolbarHelper Class - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Adobe\Acrobat 6.0\Acrobat\AcroIEFavClient.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.3.4501.1418\swg.dll
O2 - BHO: McAfee SiteAdvisor BHO - {B164E929-A1B6-4A06-B104-2CD0E90A88FF} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O2 - BHO: MSN Toolbar Helper - {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - C:\Program Files\MSN\Toolbar\3.0.0311.0\msneshellx.dll
O2 - BHO: Windows Live Toolbar Helper - {E15A8DC0-8516-42A1-81EA-DC94EC1ACF10} - C:\Program Files\Windows Live\Toolbar\wltcore.dll
O3 - Toolbar: The Weather Channel Toolbar - {2E5E800E-6AC0-411E-940A-369530A35E43} - C:\WINDOWS\SYSTEM32\TwcToolbarIe7.dll
O3 - Toolbar: Yahoo! Toolbar - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn0\yt.dll
O3 - Toolbar: MSN Toolbar - {1E61ED7C-7CB8-49d6-B9E9-AB4C880C8414} - C:\Program Files\MSN\Toolbar\3.0.0311.0\msneshellx.dll
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 6.0\Acrobat\AcroIEFavClient.dll
O3 - Toolbar: McAfee SiteAdvisor Toolbar - {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O3 - Toolbar: &Windows Live Toolbar - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - C:\Program Files\Windows Live\Toolbar\wltcore.dll
O3 - Toolbar: (no name) - {0BF43445-2F28-4351-9252-17FE6E806AA0} - (no file)
O4 - HKLM\..\Run: [fssui] "C:\Program Files\Windows Live\Family Safety\fsui.exe" -autorun
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [SNPMI03] C:\WINDOWS\vsnpmi03.exe
O4 - HKLM\..\Run: [RoxWatchTray] "C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatchTray9.exe"
O4 - HKLM\..\Run: [idsqawcs] C:\Documents and Settings\Administrator.HOUSE-F9KCUBM1Q\Local Settings\Application Data\orjnpy\qqpqsysguard.exe
O4 - HKCU\..\Run: [DelayShred] "C:\Program Files\McAfee\MSHR\ShrCL.EXE" /P7 /q C:\DOCUME~1\ADMINI~1.HOU\LOCALS~1\Temp\MESSEN~1.SH! C:\DOCUME~1\ADMINI~1.HOU\LOCALS~1\TEMPOR~1\Content.IE5\WHMJGDA3\BLANK_~2.SH! C:\DOCUME~1\ADMINI~1.HOU\LOCALS~1\TEMPOR~1\Content.IE5\7NRIO8DP\NO_CON~1.SH! C:\DOCUME~1\ADMINI~1.HOU\LOCALS~1\TEMPOR~1\Content.IE5\7NRIO8DP\APP_1_~1.SH! C:\DOCUME~1\ADMINI~1.HOU\LOCALS~1\TEMPOR~1\Content.IE5\PHLN2CXJ\DW_PAS~1.SH! C:\DOCUME~1\ADMINI~1.HOU\LOCALS~1\TEMPOR~1\Content.IE5\NZKG0WD4\INDEX_~1.SH! C:\DOCUME~1\ADMINI~1.HOU\LOCALS~1\TEMPOR~1\Content.IE5\NJMG5CWE\DC_1_~1.SH! C:\DOCUME~1\ADMINI~1.HOU\LOCALS~1\TEMPOR~1\Content.IE5\7NRIO8DP\DW_PAS~3.SH! C:\DOCUME~1\ADMINI~1.HOU\LOCALS~1\TEMPOR~1\Content.IE5\NJMG5CWE\DW_PAS~2.SH! C:\DOCUME~1\ADMINI~1.HOU\LOCALS~1\TEMPOR~1\Content.IE5\7NRIO8DP\USERST~1.SH! C:\DOCUME~1\ADMINI~1.HOU\LOCALS~1\TEMPOR~1\Content.IE5\NJMG5CWE\BLANK_~1.SH! C:\DOCUME~1\ADMINI~1.HOU\LOCALS~1\TEMPOR~1\Content.IE5\PHLN2CXJ\ARTICU~1.SH! C:\DOCUME~1\ADMINI~1.HOU\LOCALS~1\TEMPOR~1\Cont
O4 - HKCU\..\Run: [DW6] "C:\Program Files\The Weather Channel FW\Desktop\DesktopWeather.exe"
O4 - HKCU\..\Run: [idsqawcs] C:\Documents and Settings\Administrator.HOUSE-F9KCUBM1Q\Local Settings\Application Data\orjnpy\qqpqsysguard.exe
O4 - HKUS\S-1-5-19\..\Run: [geziwojure] Rundll32.exe "C:\WINDOWS\system32\megejiwe.dll",s (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [geziwojure] Rundll32.exe "C:\WINDOWS\system32\megejiwe.dll",s (User 'NETWORK SERVICE')
O4 - Global Startup: Acrobat Assistant.lnk = C:\Program Files\Adobe\Acrobat 6.0\Distillr\acrotray.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE
O9 - Extra button: Blog This - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra 'Tools' menuitem: &Blog This in Windows Live Writer - {219C3416-8CB2-491a-A3C7-D9FCDDC9D600} - C:\Program Files\Windows Live\Writer\WriterBrowserExtension.dll
O9 - Extra button: The Weather Channel - {2E5E800E-6AC0-411E-940A-369530A35E43} - (no file)
O9 - Extra 'Tools' menuitem: The Weather Channel - {2E5E800E-6AC0-411E-940A-369530A35E43} - (no file)
O9 - Extra button: (no name) - {5067A26B-1337-4436-8AFE-EE169C2DA79F} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra 'Tools' menuitem: Skype add-on for Internet Explorer - {5067A26B-1337-4436-8AFE-EE169C2DA79F} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra button: Yahoo! Services - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - C:\Program Files\Yahoo!\Common\yiesrvc.dll
O9 - Extra button: Skype - {77BF5300-1474-4EC7-9980-D32B190E9B07} - C:\Program Files\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O15 - Trusted Zone: [You must be registered and logged in to see this link.] (HKLM)
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (Installation Support) - C:\Program Files\Yahoo!\Common\Yinsthelper.dll
O18 - Protocol: sacore - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O23 - Service: McAfee SiteAdvisor Service - Unknown owner - C:\Program Files\McAfee\SiteAdvisor\McSACore.exe
O23 - Service: McciCMService - Motive Communications, Inc. - C:\Program Files\Common Files\Motive\McciCMService.exe
O23 - Service: Roxio UPnP Renderer 9 - Sonic Solutions - C:\Program Files\Roxio\Digital Home 9\RoxioUPnPRenderer9.exe
O23 - Service: Roxio Upnp Server 9 - Sonic Solutions - C:\Program Files\Roxio\Digital Home 9\RoxioUpnpService9.exe
O23 - Service: LiveShare P2P Server 9 (RoxLiveShare9) - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxLiveShare9.exe
O23 - Service: RoxMediaDB9 - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxMediaDB9.exe
O23 - Service: Roxio Hard Drive Watcher 9 (RoxWatch9) - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatch9.exe
End of file - 13363 bytes
ranism7
Posts Posts : 31
Post by Dr Jay on 10th November 2009, 3:13 am
Please try HouseCall.
Posts Posts : 14309
Post by ranism7 on 10th November 2009, 3:40 am
After trying many times I downloaded the HouseCall but at the end I get this error:
The housecall says an Internal error has prevented HouseCall from opening. Do you want to visit the HouseCall website to get the latest version and try again? (E:1034112965:7).
ranism7
Posts Posts : 31
Post by Dr Jay on 10th November 2009, 5:20 am
Please download [You must be registered and logged in to see this link.] and save it to your Desktop. Do NOT perform a scan yet
  • Double-click on drweb-cureit.exe to start the program.
    An Express Scan of your PC notice will appear.
  • Under Start the Express Scan Now, Click OK to start the scan.
    This is a short scan that will scan the files currently running in memory.
    If something is found, click the Yes button when it asks you if you want to cure it.
  • Once the short scan has finished, Click Options > Change settings
  • Choose the Scan tab and UNcheck Heuristic analysis
  • Back at the main window, click Custom Scan, then Select drives (a red dot will show which drives have been chosen).
  • Then click the Start/Stop Scanning button (green arrow on the right, and the scan will start.
  • When finished, a message will be displayed at the bottom advising if any viruses were found.
  • Click Yes to all if it asks if you want to cure/move the file.
  • When the scan has finished, look if you can see the icon next to the files found.
    If so, click it, then click the next icon right below and select Move incurable.
    (This will move it to the C:\Documents and Settings\userprofile\DoctorWeb\Quarantine folder if it can't be cured)
  • Next, in the Dr.Web CureIt menu on top, click file and choose save report list.
  • Save the DrWeb.csv report to your Desktop.
  • Exit Dr.Web Cureit when you have finished.
  • Important! Reboot your computer because it could be possible that files in use will be moved/deleted during reboot.
  • After reboot, post the contents of the log from Dr.Web in your next reply. (You can use Notepad to open the DrWeb.cvs report)
Posts Posts : 14309
Post by ranism7 on 10th November 2009, 1:37 pm
Nop, I can't execute the program. It says that the file is infected. Please don't tell me I need to format the computer.
Thanks for your efforts.
ranism7
Posts Posts : 31
Post by Dr Jay on 10th November 2009, 3:30 pm
Your computer is infected with a dangerous infection:
We have hit a dead end. Please tell me when you have completed a reformat and reinstall.
I am sorry for the bad news. I do not understand why these mean people make such harsh viruses, and I wish there was a way to clean your system without everything being damaged. But, the problem is, cleaning the system, most files will be damaged. It is like trying to clean up a city that just had a tornado or hurricane run through it. Takes rebuilding, and time to set back up.
Posts Posts : 14309
Post by ranism7 on 10th November 2009, 6:44 pm
I could have the malwarebytes working and found 4 threaths and it cleaned them. I did the same yesterday but after normal rebooting the popups windows came back. I am working in safe mode right now and see i f I can do something else. Thanks anyway, keep me posted please if you find something that works. I don't want to give up.
ranism7
Posts Posts : 31
Post by ranism7 on 10th November 2009, 9:11 pm
DragonMaster, seems like I got rid of the nightmare, although I am not sure yet. It has been two hours without any weird things happening in my computer.
Let me tell you what I did
1. After many times trying, I had the malwarebytes working, I updated it, found 4 threaths and it cleaned them.
2. Reebot in safe mode (i haven't been able to do this before)
3. Updated Mcfee
4. My husband found this website [You must be registered and logged in to see this link.] I thought what the h...., I didn't have anything to lose, so I followed the instructions, and reboot normally. After that No alerts, no threatens , no porn and viagra webpages, seems like it is working normally.
I have rebooted twice in the last 2 hours and everything seems to work fine. I am still scared, I want to believe that really everything is OK but I don't trust. Please let me know what you think.
ranism7
Posts Posts : 31
Post by Dr Jay on 11th November 2009, 2:10 am
Malwarebytes is usually not blocked by Virut.
Delete your copy of ComboFix; grab a fresh copy, except before you download it, rename it to blackpudding.bat
Navigate to Start --> Run, and enter the following command exactly as shown:
"%userprofile%\desktop\blackpudding.bat" /killall
See if ComboFix will run now.
Posts Posts : 14309
