win32/nuqel.e and bankerfox.a problem
Post by mpdc on 9th November 2009, 9:52 pm
Hello. I am having a problem with win32/nuqel.e and bankerfox.a which have made my computer a mess. Can you please help me remove them from my system. Thank you.
mpdc
Posts Posts : 6
Joined Joined : 2009-11-09
Points Points : 25906
Re: win32/nuqel.e and bankerfox.a problem
Post by Nazzgull on 9th November 2009, 10:41 pm
Please go to this category [You must be registered and logged in to see this link.].
Remember to read [You must be registered and logged in to see this link.] post before you open topic about your problem.
Posts Posts : 2330
Points Points : 40485
Post by mpdc on 10th November 2009, 3:54 am
Hello, I went into the category you refered. There it says I should not do what has been reccomended to other users and that my problem will be handled individually, if I understood correclty.
I am no computer wizard. I can tell you that my computer is extremely slow, sites are opening by themselves without my request or consent, some contain nudity and I do not visit these sites, there is also an Antivirus System Pro which continues to insist I purchase their product. The red antivirus alert continues to pop up and it says I have bankerfox.a and win32/neqel.e
I know this has happened to other people. Every time I try opening a file it tells me it is infected.
I read laydyapril problem and mine is identical...she is under the heading new member with a virus? Help.
I tried downloading highjackthis but it is not working, it is geing saved with an extension for AutoCad LT which I use to draw.....I do not understand
Please help.
mpdc
Posts Posts : 6
Post by Belahzur on 10th November 2009, 3:04 pm
Hijack This should be saved as an exe file, not something else.
Points Points : 245101
Post by mpdc on 15th November 2009, 4:38 pm
Thank you for the response....I did as intrsucted and this is what I got:
exeHelper by Raktor
Build 20091021
Run at 11:36:39 on 11/15/09
Now searching...
Checking for bad processes...
Checking for bad files...
Resetting policies...
--Finished--
I think this does not say much...correct? is it running well?
mpdc
Posts Posts : 6
Post by Belahzur on 15th November 2009, 8:41 pm
Can you run Hijack This now?
Post by mpdc on 15th November 2009, 10:42 pm
No I cannot run it without an error message like the one I pasted below...... I just copied a little piece but it more of the same.....Can you help me? Thank you so so so much...
removed
mpdc
Posts Posts : 6
Post by Belahzur on 15th November 2009, 11:24 pm
Lets try this.
Post by mpdc on 20th November 2009, 4:38 am
Hi! Thank you for your email.
Unfortunately I continue to get the script message I sent before...same thing...that it canno run in dos...the rest is all script...
mpdc
Posts Posts : 6
Post by mpdc on 24th November 2009, 5:22 pm
Ok I run it again and this is what i got:
exeHelper by Raktor
Build 20091122
Run at 12:20:40 on 11/24/09
Now searching...
Checking for sysguard processes...
Killed sysguard process duknsysguard.exe
Killed process winupdate86.exe
Deleting file C:\WINDOWS\system32\41.exe
Deleting file C:\WINDOWS\system32\winupdate86.exe
Removing HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\Advanced Virus Remover
Removing HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\ttool
Removing HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\winupdate86.exe
--Finished--
mpdc
Posts Posts : 6
Post by Belahzur on 24th November 2009, 9:16 pm
Can you run DDS now?
