System Pro virus removal??
Post by FH on 9th November 2009, 3:51 pm
My computer is infected with system pro virus, How can I remove it , hopefully for FREE!
Thank you
Note, system is XP not vista
FH
Joined Joined : 2009-11-09
OS OS : vista
Points Points : 25894
Re: System Pro virus removal??
Post by Belahzur on 9th November 2009, 8:36 pm
Points Points : 245121
Post by FH on 10th November 2009, 12:06 am
This will not install, I get an error message
The application cannot be executed. The file Mcupdui.exe is infected
Do you want to activate your antivirus software now?
Yes No
I have tried clicking yes and no and the super pro screen comes up,
Any other help you can offer?
Thank you
FH
OS OS : vista
Post by Belahzur on 10th November 2009, 5:31 pm
