Antivirus System Pro
Post by kerryr on 9th November 2009, 1:05 pm
Can't run MAMB
kerryr
Posts Posts : 13
Joined Joined : 2009-06-29
OS OS : windows xp
Points Points : 27248
Re: Antivirus System Pro
Post by kerryr on 9th November 2009, 1:49 pm
Finally got MAMB to work and all is good!
kerryr
Posts Posts : 13
OS OS : windows xp
Post by dmckeejr on 9th November 2009, 3:30 pm
I just downloaded MAMB but can't get it to run. help.
dmckeejr
Joined Joined : 2009-11-09
Points Points : 25882
Post by Belahzur on 9th November 2009, 8:36 pm
Points Points : 245111
