Alpha Antivirus Help!
Post by Tocowujo on 8th November 2009, 2:38 am
Hey, i'm helping my dad get rid of this program he contracted this morning on his Vista laptop. It doesn't allow him to open IE, so i am using my mac, and transferring all the software via USB drive. I tried the malwarebyte, superantispyware, and an online fix, but nȯne of them worked. The first time i ran malwarebyte it found 5 infections, i cleared them but after restarting, Alpha AV was still on the system as before. When i run it again it doesn't find anything. I tried spywaredoctor and it found the AlphaAV threat as well as some other minor ones, but naturally i couldn't remove them without paying for the program.
An interesting note, the process associated with Alpha AV is "alpha.exe" rather than the typical "alphaAV.exe" that i see on most help websites.
I ran combofix after reading some suggestion and copied the log to my computer, not sure what is preferable, but i will download and run hijackthis also if necessary...
Thanks!
ComboFix 09-11-07.02 - Owner 11/07/2009 18:15.1.2 - NTFSx86
MicrosoftĆ Windows Vistaô Home Premium 6.0.6002.2.1252.1.1033.18.1013.336 [GMT -6:00]
Running from: c:\users\Owner\Desktop\commy.exe
AV: ESET NOD32 antivirus system 2.70 *On-access scanning enabled* (Updated) {E5E70D32-0101-4F12-8FB0-D96ACA4F34C0}
SP: SUPERAntiSpyware *disabled* (Updated) {222A897C-5018-402e-943F-7E7AC8560DA7}
SP: Windows Defender *enabled* (Outdated) {D68DDC3A-831F-4FAE-9E44-DA132C1ACF46}
* Resident AV is active
c:\$recycle.bin\S-1-5-21-2152478756-3922319563-605102323-500
c:\$recycle.bin\S-1-5-21-2450969143-844794473-1312612106-500
c:\$recycle.bin\S-1-5-21-3569018428-901859288-1186912836-500
c:\$recycle.bin\S-1-5-21-4214898707-607555799-2004620691-500
c:\$recycle.bin\S-1-5-21-864547194-220137812-69340660-500
c:\program files\alot
c:\$recycle.bin\S-1-5-21-2152478756-3922319563-605102323-500\desktop.ini
c:\$recycle.bin\S-1-5-21-2450969143-844794473-1312612106-500\desktop.ini
c:\$recycle.bin\S-1-5-21-3569018428-901859288-1186912836-500\desktop.ini
c:\$recycle.bin\S-1-5-21-4214898707-607555799-2004620691-500\desktop.ini
c:\$recycle.bin\S-1-5-21-864547194-220137812-69340660-500\desktop.ini
c:\program files\alot\alotUninst.exe
c:\program files\alot\bin\alot.dll
c:\program files\alot\bin\ALOTSettings.exe
c:\programdata\ntuser.dat{0dd9af55-9d0b-11db-8678-0016d42a45f8}.TMContainer00000000000000000001.regtrans-ms
c:\programdata\ntuser.dat{0dd9af65-9d0b-11db-8678-0016d42a45f8}.TMContainer00000000000000000001.regtrans-ms
((((((((((((((((((((((((( Files Created from 2009-10-08 to 2009-11-08 )))))))))))))))))))))))))))))))
2009-11-08 00:25 . 2009-11-08 00:27 -------- d-----w- c:\users\Owner\AppData\Local\temp
2009-11-08 00:25 . 2009-11-08 00:25 -------- d-----w- c:\users\Default\AppData\Local\temp
2009-11-07 17:58 . 2009-11-07 17:58 117760 ----a-w- c:\users\Owner\AppData\Roaming\SUPERAntiSpyware.com\SUPERAntiSpyware\SDDLLS\UIREPAIR.DLL
2009-11-07 17:58 . 2009-11-07 17:58 -------- d-----w- c:\programdata\SUPERAntiSpyware.com
2009-11-07 17:57 . 2009-11-07 17:57 4096 d-----w- c:\program files\SUPERAntiSpyware
2009-11-07 17:57 . 2009-11-07 17:57 -------- d-----w- c:\users\Owner\AppData\Roaming\SUPERAntiSpyware.com
2009-11-07 17:56 . 2009-11-07 17:56 -------- d-----w- c:\program files\Common Files\Wise Installation Wizard
2009-11-07 17:05 . 2009-11-07 17:05 -------- d-----w- c:\program files\Common Files\AAntivirusUninstall
2009-11-07 17:05 . 2009-11-07 17:05 -------- d-----w- c:\program files\AAntivirus
2009-10-28 15:25 . 2009-09-10 14:58 310784 ----a-w- c:\windows\system32\unregmp2.exe
2009-10-28 15:25 . 2009-09-10 14:59 8147456 ----a-w- c:\windows\system32\wmploc.DLL
2009-10-14 19:37 . 2009-09-10 16:48 218624 ----a-w- c:\windows\system32\msv1_0.dll
2009-10-14 19:35 . 2009-09-04 11:41 60928 ----a-w- c:\windows\system32\msasn1.dll
2009-10-14 19:35 . 2009-09-14 09:29 144896 ----a-w- c:\windows\system32\drivers\srv2.sys
2009-10-14 19:35 . 2009-05-08 12:53 604672 ----a-w- c:\windows\system32\WMSPDMOD.DLL
2009-10-12 17:03 . 2009-10-12 17:03 -------- d-----w- c:\program files\Microsoft
2009-10-12 17:01 . 2009-10-12 17:00 411368 ----a-w- c:\windows\system32\deploytk.dll
2009-11-07 18:47 . 2009-03-05 18:38 4096 d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-11-03 02:42 . 2009-10-02 15:58 195456 ------w- c:\windows\system32\MpSigStub.exe
2009-10-15 12:51 . 2006-11-02 11:18 4096 d-----w- c:\program files\Windows Mail
2009-10-12 17:00 . 2007-01-05 23:14 -------- d-----w- c:\program files\Java
2009-09-10 20:54 . 2009-03-05 18:38 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-09-10 20:53 . 2009-03-05 18:38 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-08-29 00:27 . 2009-09-02 23:28 4240384 ----a-w- c:\windows\system32\GameUXLegacyGDFs.dll
2009-08-29 00:14 . 2009-09-02 23:28 28672 ----a-w- c:\windows\system32\Apphlpdm.dll
2009-08-27 05:22 . 2009-10-14 19:36 916480 ----a-w- c:\windows\system32\wininet.dll
2009-08-27 05:17 . 2009-10-14 19:36 109056 ----a-w- c:\windows\system32\iesysprep.dll
2009-08-27 05:17 . 2009-10-14 19:36 71680 ----a-w- c:\windows\system32\iesetup.dll
2009-08-27 03:42 . 2009-10-14 19:36 133632 ----a-w- c:\windows\system32\ieUnatt.exe
2009-08-14 16:27 . 2009-09-09 14:17 904776 ----a-w- c:\windows\system32\drivers\tcpip.sys
2009-08-14 15:53 . 2009-09-09 14:17 17920 ----a-w- c:\windows\system32\netevent.dll
2009-08-14 13:49 . 2009-09-09 14:17 9728 ----a-w- c:\windows\system32\TCPSVCS.EXE
2009-08-14 13:49 . 2009-09-09 14:17 17920 ----a-w- c:\windows\system32\ROUTE.EXE
2009-08-14 13:49 . 2009-09-09 14:17 11264 ----a-w- c:\windows\system32\MRINFO.EXE
2009-08-14 13:49 . 2009-09-09 14:17 27136 ----a-w- c:\windows\system32\NETSTAT.EXE
2009-08-14 13:49 . 2009-09-09 14:17 19968 ----a-w- c:\windows\system32\ARP.EXE
2009-08-14 13:49 . 2009-09-09 14:17 8704 ----a-w- c:\windows\system32\HOSTNAME.EXE
2009-08-14 13:49 . 2009-09-09 14:17 10240 ----a-w- c:\windows\system32\finger.exe
2009-08-14 13:48 . 2009-09-09 14:17 30720 ----a-w- c:\windows\system32\drivers\tcpipreg.sys
2009-08-14 13:48 . 2009-09-09 14:17 105984 ----a-w- c:\windows\system32\netiohlp.dll
"TOSCDSPD"="c:\program files\TOSHIBA\TOSCDSPD\TOSCDSPD.exe" [2006-11-10 417792]
"Sidebar"="c:\program files\Windows Sidebar\sidebar.exe" [2009-04-11 1233920]
"Search Protection"="c:\program files\Yahoo!\Search Protection\SearchProtection.exe" [2009-02-03 111856]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2008-12-30 39408]
"Windows Defender"="c:\program files\Windows Defender\MSASCui.exe" [2008-01-19 1008184]
"LtMoh"="c:\program files\ltmoh\Ltmoh.exe" [2005-12-16 188416]
"TPwrMain"="c:\program files\TOSHIBA\Power Saver\TPwrMain.EXE" [2006-12-20 411768]
"HSON"="c:\program files\TOSHIBA\TBS\HSON.exe" [2006-12-08 55416]
"SmoothView"="c:\program files\Toshiba\SmoothView\SmoothView.exe" [2006-12-12 448632]
"00TCrdMain"="c:\program files\TOSHIBA\FlashCards\TCrdMain.exe" [2006-12-15 530552]
"HWSetup"="c:\program files\TOSHIBA\Utilities\HWSetup.exe" [2006-11-01 413696]
"SVPWUTIL"="c:\program files\TOSHIBA\Utilities\SVPWUTIL.exe" [2006-01-19 421888]
"KeNotify"="c:\program files\TOSHIBA\Utilities\KeNotify.exe" [2006-11-07 34352]
"nod32kui"="c:\program files\Eset\nod32kui.exe" [2007-09-02 949376]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-01-12 39792]
"YSearchProtection"="c:\program files\Yahoo!\Search Protection\SearchProtection.exe" [2009-02-03 111856]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2008-02-12 141848]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2008-02-12 166424]
"Persistence"="c:\windows\system32\igfxpers.exe" [2008-02-12 133656]
"SynTPEnh"="c:\program files\Synaptics\SynTP\SynTPEnh.exe" [2009-03-20 1451304]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2009-10-12 149280]
"Microsoft Default Manager"="c:\program files\Microsoft\Search Enhancement Pack\Default Manager\DefMgr.exe" [2009-02-03 233304]
"RtHDVCpl"="RtHDVCpl.exe" - c:\windows\RtHDVCpl.exe [2006-11-09 3784704]
"{5AE067D3-9AFB-48E0-853A-EBB7F4A000DA}"= "c:\program files\SUPERAntiSpyware\SASSEH.DLL" [2008-05-13 77824]
2009-09-03 21:21 548352 ----a-w- c:\program files\SUPERAntiSpyware\SASWINLO.dll
"aux"=wdmaud.drv
"AntiVirusOverride"=""
"FirewallOverride"=""
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Svc]
"VistaSp2"=hex(b):c6,03,14,3c,c4,f6,c9,01
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Svc\S-1-5-21-2450969143-844794473-1312612106-1000]
"EnableNotificationsRef"=dword:00000001
R1 nod32drv;nod32drv;c:\windows\System32\drivers\nod32drv.sys [9/2/2007 12:44 PM 15424]
R1 SASDIFSV;SASDIFSV;c:\program files\SUPERAntiSpyware\sasdifsv.sys [10/12/2009 9:24 PM 9968]
R1 SASKUTIL;SASKUTIL;c:\program files\SUPERAntiSpyware\SASKUTIL.SYS [10/12/2009 9:24 PM 74480]
R3 NETw5v32;Intel(R) Wireless WiFi Link 5000 Series Adapter Driver for Windows Vista 32 Bit;c:\windows\System32\drivers\NETw5v32.sys [11/17/2008 2:40 PM 3668480]
S3 SASENUM;SASENUM;c:\program files\SUPERAntiSpyware\SASENUM.SYS [10/12/2009 9:24 PM 7408]
*NewlyCreated* - MBR
*NewlyCreated* - PROCEXP113
*Deregistered* - mbr
*Deregistered* - PROCEXP113
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{A509B1FF-37FF-4bFF-8CFF-4F3A747040FF}]
c:\windows\system32\rundll32.exe c:\windows\system32\advpack.dll,LaunchINFSectionEx c:\program files\Internet Explorer\clrtour.inf,DefaultInstall.ResetTour,,12
2009-11-07 c:\windows\Tasks\AAntivirus.job
- c:\program files\AAntivirus\alpha.exe [2009-11-07 17:05]
Trusted Zone: usaa.com\www
Trusted Zone: yahoo.com
Trusted Zone: yahoo.com\us.f622.mail
AddRemove-alotToolbar - c:\program files\alot\alotUninst.exe
Rootkit scan 2009-11-07 18:26
Windows 6.0.6002 Service Pack 2 NTFS
scanning hȋdden processes ...
HKCU\Software\Microsoft\Windows\CurrentVersion\Run
TOSCDSPD = c:\program files\TOSHIBA\TOSCDSPD\TOSCDSPD.exe?/i???????['C~????\?8?\?p?\???\???
scanning hȋdden files ...
hȋdden files: 0
@Denied: (A) (Users)
@Denied: (A) (Everyone)
"BlindDial"=dword:00000000
"MSCurrentCountry"=dword:000000b5
Completion time: 2009-11-08 18:30
ComboFix-quarantined-files.txt 2009-11-08 00:30
Pre-Run: 111,334,653,952 bytes free
Post-Run: 111,514,812,416 bytes free
- - End Of File - - 0E35474719107474BCEEC53583284DE5
Tocowujo
Joined Joined : 2009-11-08
OS OS : Mac OS X
Points Points : 25874
Re: Alpha Antivirus Help!
Post by Belahzur on 8th November 2009, 9:10 pm
  • Save it to your desktop.
    :files
    :reg
    "AntiVirusOverride"=-
    "FirewallOverride"=-
  • Close OTMoveIt
Please post the OTMoveIt log.
Points Points : 245091
Post by Tocowujo on 9th November 2009, 12:03 am
Ok, so NOD 32 just found and destroyed Alpha AV randomly earlier. For some reason Internet Explorer(8) continues to freeze up and not respond the instant i open it. It works fine in safe mode, so I cleared the browsing history and temp files while in safe mode, but it still doesn't work normally.
Thanks again!
Tocowujo
OS OS : Mac OS X
Post by Belahzur on 9th November 2009, 1:16 am
Internet Explorer is always buggy like that, I recommend you don't use it and switch to Firefox.
