Alpha Antivirus Removal Help
Post by gailnc on 6th November 2009, 9:56 pm
I have updated flash and adobe and all critical updates. I tried using the Malwarebytes' Anti-Malware program, that is already on my computer, to remove the Alpha Antivirus. First I updated and did a quick scan and it showed 11 infections. I removed all checked and I am now able to use internet explorer without it redirecting me to another page where it says that my computer is infected and the icons are no longer showing in the system tray. The Alpha Antivirus is still showing up in the add remove programs and I believe my computer is still infected. I downloaded hijackthis and am posting the log file here:
Scan saved at 4:45:01 PM, on 11/6/2009
C:\Program Files\Windows Defender\MsMpEng.exe
C:\WINDOWS\system32\agrsmsvc.exe
C:\Program Files\Norton PC Checkup\Engine\2.0.0.146\ccSvcHst.exe
C:\Program Files\Creative\Shared Files\CTDevSrv.exe
C:\Program Files\Norton 360\Engine\3.5.2.11\ccSvcHst.exe
C:\Program Files\Norton PC Checkup\Engine\2.0.0.146\SymcPCCULaunchSvc.exe
C:\Program Files\Windows Defender\MSASCui.exe
C:\WINDOWS\system32\ps2.exe
C:\Program Files\Windows Media Player\WMPNSCFG.exe
C:\WINDOWS\system32\DllHost.exe
C:\Documents and Settings\HP_Owner\My Documents\My Received Files\winlogon.scr
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = [You must be registered and logged in to see this link.]
F2 - REG:system.ini: UserInit=C:\WINDOWS\system32\Userinit.exe
O2 - BHO: Symantec NCO BHO - {602ADB0E-4AFF-4217-8AA1-95DAC4DFA408} - C:\Program Files\Norton 360\Engine\3.5.2.11\coIEPlg.dll
O2 - BHO: Symantec Intrusion Prevention - {6D53EC84-6AAE-4787-AEEE-F4628F01010C} - C:\Program Files\Norton 360\Engine\3.5.2.11\IPSBHO.DLL
O3 - Toolbar: HP view - {B2847E28-5D7D-4DEB-8B67-05D28BCF79F5} - c:\Program Files\HP\Digital Imaging\bin\HPDTLK02.dll
O3 - Toolbar: Norton Toolbar - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - C:\Program Files\Norton 360\Engine\3.5.2.11\coIEPlg.dll
O4 - HKLM\..\Run: [Windows Defender] "C:\Program Files\Windows Defender\MSASCui.exe" -hide
O4 - HKLM\..\Run: [PS2] C:\WINDOWS\system32\ps2.exe
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\RunOnce: [Uninstall Adobe Download Manager] "C:\WINDOWS\system32\rundll32.exe" "C:\Program Files\NOS\bin\getPlus_Helper.dll",Uninstall /IE2883E8F-472F-4fb0-9522-AC9BF37916A7 /Get1noarp
O4 - HKCU\..\Run: [WMPNSCFG] C:\Program Files\Windows Media Player\WMPNSCFG.exe
O4 - HKCU\..\Run: [AAntivirus] C:\Program Files\AAntivirus\alpha.exe
O4 - HKCU\..\Run: [updateMgr] "C:\Program Files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe" AcRdB7_0_9 -reboot 1
O4 - HKCU\..\RunOnce: [Shockwave Updater] C:\WINDOWS\system32\Adobe\Shockwave 11\SwHelper_1150596.exe -Update -1150596 -"Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; MS-RTC EA 2; AskTB5.5)" -"http://www.shockwave.com/gamelanding/football3d.jsp"
O6 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O8 - Extra context menu item: &AOL Toolbar search - [You must be registered and logged in to see this link.] Files\AOL Toolbar\toolbar.dll/SEARCH.HTML
O8 - Extra context menu item: Add To HP Organize... - C:\PROGRA~1\HEWLET~1\HPORGA~1\bin\core.hp.main\SendTo.html
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MI1933~1\OFFICE11\REFIEBAR.DLL
O16 - DPF: {149E45D8-163E-4189-86FC-45022AB2B6C9} (SpinTop DRM Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {44990301-3C9D-426D-81DF-AAB636FA4345} (Symantec Script Runner Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {4A3CF76B-EC7A-405D-A67D-8DC6B52AB35B} - [You must be registered and logged in to see this link.]
O16 - DPF: {6A344D34-5231-452A-8A57-D064AC9B7862} (Symantec Download Manager) - [You must be registered and logged in to see this link.]
O16 - DPF: {8A94C905-FF9D-43B6-8708-F0F22D22B1CB} (Wwlaunch Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {A52FBD2B-7AB3-4F6B-90E3-91C772C5D00F} (WoF Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {CC450D71-CC90-424C-8638-1F2DBAC87A54} - [You must be registered and logged in to see this link.]
O16 - DPF: {CF969D51-F764-4FBF-9E90-475248601C8A} (FamilyFeud Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {DF780F87-FF2B-4DF8-92D0-73DB16A1543A} - [You must be registered and logged in to see this link.]
O16 - DPF: {E5D419D6-A846-4514-9FAD-97E826C84822} - [You must be registered and logged in to see this link.]
O18 - Protocol: symres - {AA1061FE-6C41-421F-9344-69640C9732AB} - C:\Program Files\Norton 360\Engine\3.5.2.11\coIEPlg.dll
O18 - Filter hijack: text/html - {6d2bc926-48cc-4435-973f-217e5f4bb1c2} - (no file)
O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Agere Systems - C:\WINDOWS\system32\agrsmsvc.exe
O23 - Service: Common Client Job Manager Service (ccJobMgr) - Symantec Corporation - C:\Program Files\Norton PC Checkup\Engine\2.0.0.146\ccSvcHst.exe
O23 - Service: CT Device Query service (CTDevice_Srv) - Creative Technology Ltd - C:\Program Files\Creative\Shared Files\CTDevSrv.exe
O23 - Service: Creative Centrale Media Server (CTUPnPSv) - Creative Technology Ltd - C:\Program Files\Creative\Creative Centrale\CTUPnPSv.exe
O23 - Service: Firebird Server - MAGIX Instance (FirebirdServerMAGIXInstance) - MAGIX® - C:\MAGIX\Common\Database\bin\fbserver.exe
O23 - Service: Norton 360 (N360) - Symantec Corporation - C:\Program Files\Norton 360\Engine\3.5.2.11\ccSvcHst.exe
O23 - Service: Norton PC Checkup Application Launcher - Symantec Corporation - C:\Program Files\Norton PC Checkup\Engine\2.0.0.146\SymcPCCULaunchSvc.exe
End of file - 10231 bytes
gailnc
Posts Posts : 7
Joined Joined : 2009-11-06
Points Points : 25919
Re: Alpha Antivirus Removal Help
Post by Origin on 7th November 2009, 7:52 pm
Hello gailnc,
Welcome to Geek Police, my name is Origin and I will be helping you today. Please keep the following in mind:
  • If you do not get a reply from me or another helper within 2 days, please reply to your topic with the phrase BUMP
  • If you have any cracked/pirated software in your computer delete them or we will not help you.
  • Only follow advise from Geek Police Staff and not a regular member.
  • Do NOT run any tool without Geek Police supervision as it could hinder your system useless.
  • Open HijackThis.
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31523
Post by gailnc on 7th November 2009, 9:44 pm
Database version: 3118
11/7/2009 4:43:39 PM
mbam-log-2009-11-07 (16-43-39).txt
Objects scanned: 121210
Time elapsed: 14 minute(s), 17 second(s)
Folders Infected: 1
Files Infected: 1
C:\Program Files\AAntivirus (Rogue.AlphaAV) -> Quarantined and deleted successfully.
C:\Program Files\AAntivirus\alpha.exe (Rogue.AlphaAV) -> Quarantined and deleted successfully.
gailnc
Posts Posts : 7
Post by gailnc on 7th November 2009, 9:56 pm
I've restarted the computer after running Malwarebytes' Anti-Malware 1.41. The AAntivirus is still showing in my start menu. Does this mean that I am still infected and how do I get rid of it? Just want to say thank you for helping me with this.
gailnc
Posts Posts : 7
Post by Belahzur on 8th November 2009, 8:54 pm
Points Points : 245111
Post by gailnc on 8th November 2009, 9:38 pm
Run by HP_Owner at 16:33:06.87 on Sun 11/08/2009
Internet Explorer: 8.0.6001.18702 BrowserJavaVersion: 1.6.0_17
Microsoft Windows XP Home Edition 5.1.2600.3.1252.1.1033.18.959.177 [GMT -5:00]
AV: Norton 360 *On-access scanning enabled* (Updated) {E10A9785-9598-4754-B552-92431C1C35F8}
FW: Norton 360 *enabled* {7C21A4C9-F61F-4AC4-B722-A6E19C16F220}
svchost.exe
C:\WINDOWS\system32\svchost.exe -k WudfServiceGroup
svchost.exe
svchost.exe
svchost.exe
C:\WINDOWS\System32\svchost.exe -k HTTPFilter
c:\WINDOWS\Microsoft.NET\Framework\v3.0\Windows Communication Foundation\infocard.exe
C:\Documents and Settings\HP_Owner\My Documents\My Received Files\dds.scr
mWinlogon: Userinit=c:\windows\system32\Userinit.exe
BHO: Symantec NCO BHO: {602adb0e-4aff-4217-8aa1-95dac4dfa408} - c:\program files\norton 360\engine\3.5.2.11\coIEPlg.dll
BHO: Symantec Intrusion Prevention: {6d53ec84-6aae-4787-aeee-f4628f01010c} - c:\program files\norton 360\engine\3.5.2.11\IPSBHO.DLL
TB: HP view: {b2847e28-5d7d-4deb-8b67-05d28bcf79f5} - c:\program files\hp\digital imaging\bin\HPDTLK02.dll
TB: Norton Toolbar: {7febefe3-6b19-4349-98d2-ffb09d4b49ca} - c:\program files\norton 360\engine\3.5.2.11\coIEPlg.dll
TB: {EF99BD32-C1FB-11D2-892F-0090271D4F88} - No File
TB: {46AE04C0-BCFA-4728-90E7-00EB4A8B3863} - No File
TB: {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - No File
TB: {D4027C7F-154A-4066-A1AD-4243D8127440} - No File
EB: {4528BBE0-4E08-11D5-AD55-00010333D0AD} - No File
uRun: [WMPNSCFG] c:\program files\windows media player\WMPNSCFG.exe
uRun: [updateMgr] "c:\program files\adobe\acrobat 7.0\reader\AdobeUpdateManager.exe" AcRdB7_0_9 -reboot 1
uRunOnce: [Shockwave Updater] c:\windows\system32\adobe\shockwave 11\SwHelper_1150596.exe -Update -1150596 -"Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; MS-RTC EA 2; AskTB5.5)" -"http://www.shockwave.com/gamelanding/football3d.jsp"
mRun: [Windows Defender] "c:\program files\windows defender\MSASCui.exe" -hide
mRun: [PS2] c:\windows\system32\ps2.exe
mRun: [NvCplDaemon] RUNDLL32.EXE c:\windows\system32\NvCpl.dll,NvStartup
mRun: [SunJavaUpdateSched] "c:\program files\java\jre6\bin\jusched.exe"
mRun: [Adobe Reader Speed Launcher] "c:\program files\adobe\reader 9.0\reader\Reader_sl.exe"
uPolicies-explorer: NoViewOnDrive = 0 (0x0)
IE: &AOL Toolbar search - c:\program files\aol toolbar\toolbar.dll/SEARCH.HTML
IE: Add To HP Organize... - c:\progra~1\hewlet~1\hporga~1\bin\core.hp.main\SendTo.html
IE: E&xport to Microsoft Excel - c:\progra~1\mi1933~1\office11\EXCEL.EXE/3000
IE: {92780B25-18CC-41C8-B9BE-3C9C571A8263} - {FF059E31-CC5A-4E2E-BF3B-96E929D65503} - c:\progra~1\mi1933~1\office11\REFIEBAR.DLL
Trusted Zone: rr.com\www
DPF: {149E45D8-163E-4189-86FC-45022AB2B6C9} - [You must be registered and logged in to see this link.]
DPF: {233C1507-6A77-46A4-9443-F871F945D258} - [You must be registered and logged in to see this link.]
DPF: {44990301-3C9D-426D-81DF-AAB636FA4345} - [You must be registered and logged in to see this link.]
DPF: {6A344D34-5231-452A-8A57-D064AC9B7862} - [You must be registered and logged in to see this link.]
DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} - [You must be registered and logged in to see this link.]
DPF: {8A94C905-FF9D-43B6-8708-F0F22D22B1CB} - [You must be registered and logged in to see this link.]
DPF: {A52FBD2B-7AB3-4F6B-90E3-91C772C5D00F} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CF969D51-F764-4FBF-9E90-475248601C8A} - [You must be registered and logged in to see this link.]
Handler: symres - {AA1061FE-6C41-421f-9344-69640C9732AB} - c:\program files\norton 360\engine\3.5.2.11\CoIEPlg.dll
Notify: igfxcui - igfxsrvc.dll
SEH: Microsoft AntiMalware ShellExecuteHook: {091eb208-39dd-417d-a5dd-7e2c2d8fb9cb} - c:\progra~1\wifd1f~1\MpShHook.dll
SecurityProviders: msapsspc.dll, schannel.dll, digest.dll, msnsspc.dll, zwebauth.dll
FF - ProfilePath - c:\docume~1\hp_owner\applic~1\mozilla\firefox\profiles\d81hqeht.default\
FF - prefs.js: browser.search.selectedEngine - Ask.com
FF - prefs.js: keyword.URL -
FF - component: c:\documents and settings\all users\application data\norton\{0c55c096-0f1d-4f28-aaa2-85ef591126e7}\norton\coffplgn\components\coFFPlgn.dll
FF - component: c:\documents and settings\all users\application data\norton\{0c55c096-0f1d-4f28-aaa2-85ef591126e7}\norton\ipsffplgn\components\IPSFFPl.dll
FF - plugin: c:\documents and settings\hp_owner\application data\move networks\plugins\npqmp071505000010.dll
FF - plugin: c:\program files\real\realarcade\plugins\mozilla\npracplug.dll
FF - plugin: c:\program files\viewpoint\viewpoint experience technology\npViewpoint.dll
FF - hȋdden: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - c:\windows\microsoft.net\framework\v3.5\windows presentation foundation\dotnetassistantextension\
FF - hȋdden: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0012-ABCDEFFEDCBA}
FF - hȋdden: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA}
FF - hȋdden: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0015-ABCDEFFEDCBA}
FF - hȋdden: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0017-ABCDEFFEDCBA}
---- FIREFOX POLICIES ----
c:\program files\mozilla firefox\greprefs\security-prefs.js - pref("security.ssl3.rsa_seed_sha", true);
R0 SymEFA;Symantec Extended File Attributes;c:\windows\system32\drivers\n360\0305020.00b\SymEFA.sys [2009-8-31 310320]
R1 BHDrvx86;Symantec Heuristics Driver;c:\windows\system32\drivers\n360\0305020.00b\BHDrvx86.sys [2009-8-31 259632]
R1 ccHP;Symantec Hash Provider;c:\windows\system32\drivers\n360\0305020.00b\cchpx86.sys [2009-8-31 482432]
R1 IDSxpx86;IDSxpx86;c:\documents and settings\all users\application data\norton\{0c55c096-0f1d-4f28-aaa2-85ef591126e7}\norton\definitions\ipsdefs\20091105.001\IDSXpx86.sys [2009-11-6 329592]
R2 ACEDRV06;ACEDRV06;c:\windows\system32\drivers\ACEDRV06.sys [2007-9-22 99840]
R2 BCMNTIO;BCMNTIO;c:\progra~1\checkit\diagno~1\BCMNTIO.sys [2006-7-19 3744]
R2 ccJobMgr;Common Client Job Manager Service;c:\program files\norton pc checkup\engine\2.0.0.146\ccSvcHst.exe [2009-9-6 126392]
R2 MAPMEM;MAPMEM;c:\progra~1\checkit\diagno~1\MAPMEM.sys [2006-7-19 3904]
R2 N360;Norton 360;c:\program files\norton 360\engine\3.5.2.11\ccSvcHst.exe [2009-8-31 117640]
R2 Norton PC Checkup Application Launcher;Norton PC Checkup Application Launcher;c:\program files\norton pc checkup\engine\2.0.0.146\SymcPCCULaunchSvc.exe [2009-9-6 123248]
R3 EraserUtilRebootDrv;EraserUtilRebootDrv;c:\program files\common files\symantec shared\eengine\EraserUtilRebootDrv.sys [2009-8-28 102448]
S3 CTUPnPSv;Creative Centrale Media Server;c:\program files\creative\creative centrale\CTUPnPSv.exe [2008-5-21 64000]
S3 FirebirdServerMAGIXInstance;Firebird Server - MAGIX Instance;c:\magix\common\database\bin\fbserver.exe [2007-9-22 1527900]
2009-11-06 02:37:08 0 d-----w- c:\program files\common files\AAntivirusUninstall
2009-11-01 03:09:16 0 d-----w- c:\docume~1\hp_owner\applic~1\Paltalk
2009-10-16 01:11:03 0 d-----w- c:\program files\MSECache
2009-11-03 01:42:06 195456 ------w- c:\windows\system32\MpSigStub.exe
2009-10-11 09:17:27 411368 ----a-w- c:\windows\system32\deploytk.dll
2009-09-11 14:18:39 136192 ----a-w- c:\windows\system32\msv1_0.dll
2009-09-10 19:54:06 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-09-10 19:53:50 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-09-04 21:03:36 58880 ----a-w- c:\windows\system32\msasn1.dll
2009-08-31 23:27:22 60808 ----a-w- c:\windows\system32\S32EVNT1.DLL
2009-08-31 23:26:37 107368 ----a-r- c:\windows\system32\GEARAspi.dll
2009-08-29 08:08:21 916480 ----a-w- c:\windows\system32\wininet.dll
2009-08-26 08:00:21 247326 ----a-w- c:\windows\system32\strmdll.dll
2005-05-18 22:34:55 774144 -c--a-w- c:\program files\RngInterstitial.dll
2004-11-27 05:53:22 0 -csha-w- c:\windows\sminst\HPCD.sys
2009-03-08 06:10:33 32768 --sha-w- c:\windows\system32\config\systemprofile\local settings\history\history.ie5\mshist012009030820090309\index.dat
============= FINISH: 16:34:20.50 ===============
gailnc
Posts Posts : 7
Post by gailnc on 8th November 2009, 9:39 pm
Install Date: 9/27/2004 11:22:47 PM
System Uptime: 11/7/2009 6:27:12 PM (22 hours ago)
Motherboard: ASUSTek Computer INC. | | Kelut
Processor: AMD Athlon(tm) XP 3000+ | Socket A | 2099/200mhz
C: is fȋxed (NTFS) - 143 GiB total, 82.369 GiB free.
D: is fȋxed (FAT32) - 6 GiB total, 0.749 GiB free.
E: is CDROM (UDF)
F: is Removable
G: is Removable
H: is Removable
I: is Removable
Class GUID: {4D36E972-E325-11CE-BFC1-08002BE10318}
Description: 1394 Net Adapter
Device ID: V1394\NIC1394\98426AE01800
Manufacturer: Microsoft
Name: 1394 Net Adapter
PNP Device ID: V1394\NIC1394\98426AE01800
Service: NIC1394
RP1: 9/11/2009 3:25:54 PM - System Checkpoint
RP2: 9/12/2009 3:29:19 PM - System Checkpoint
RP3: 9/13/2009 9:28:10 PM - System Checkpoint
RP4: 9/14/2009 1:50:24 PM - Software Distribution Service 3.0
RP5: 9/15/2009 1:53:17 PM - System Checkpoint
RP6: 9/16/2009 2:12:21 PM - System Checkpoint
RP7: 9/17/2009 2:24:18 PM - System Checkpoint
RP8: 9/17/2009 8:09:29 PM - Software Distribution Service 3.0
RP9: 9/19/2009 5:39:13 AM - System Checkpoint
RP10: 9/20/2009 5:50:29 AM - System Checkpoint
RP11: 9/21/2009 6:13:41 AM - System Checkpoint
RP12: 9/21/2009 11:55:38 PM - Software Distribution Service 3.0
RP13: 9/22/2009 11:58:35 PM - System Checkpoint
RP14: 9/24/2009 1:25:46 AM - System Checkpoint
RP15: 9/24/2009 9:46:46 AM - Software Distribution Service 3.0
RP16: 9/25/2009 11:06:11 AM - System Checkpoint
RP17: 9/26/2009 5:28:32 PM - System Checkpoint
RP18: 9/27/2009 6:06:30 PM - System Checkpoint
RP19: 9/28/2009 8:18:57 PM - System Checkpoint
RP20: 9/29/2009 8:58:02 AM - Software Distribution Service 3.0
RP21: 9/30/2009 9:29:53 AM - System Checkpoint
RP22: 10/1/2009 10:41:49 AM - System Checkpoint
RP23: 10/2/2009 11:01:01 AM - System Checkpoint
RP24: 10/2/2009 3:36:52 PM - Software Distribution Service 3.0
RP25: 10/3/2009 5:18:30 PM - System Checkpoint
RP26: 10/4/2009 10:31:33 PM - System Checkpoint
RP27: 10/5/2009 9:11:18 PM - Software Distribution Service 3.0
RP28: 10/6/2009 9:45:07 PM - System Checkpoint
RP29: 10/7/2009 10:16:41 PM - System Checkpoint
RP30: 10/8/2009 11:17:11 AM - Software Distribution Service 3.0
RP31: 10/9/2009 11:21:47 AM - System Checkpoint
RP32: 10/10/2009 11:51:05 AM - System Checkpoint
RP33: 10/10/2009 2:16:10 PM - Norton 360 Registry Clean
RP34: 10/11/2009 3:59:53 PM - System Checkpoint
RP35: 10/12/2009 4:32:37 PM - Software Distribution Service 3.0
RP36: 10/13/2009 4:42:50 PM - System Checkpoint
RP37: 10/14/2009 5:18:47 PM - System Checkpoint
RP38: 10/15/2009 5:25:31 PM - System Checkpoint
RP39: 10/15/2009 7:09:11 PM - Software Distribution Service 3.0
RP40: 10/15/2009 9:11:16 PM - Installed Compatibility Pack for the 2007 Office system
RP41: 10/16/2009 3:01:23 AM - Software Distribution Service 3.0
RP42: 10/17/2009 3:03:24 AM - Software Distribution Service 3.0
RP43: 10/18/2009 5:34:16 AM - System Checkpoint
RP44: 10/19/2009 6:02:01 AM - System Checkpoint
RP45: 10/19/2009 4:13:48 PM - Software Distribution Service 3.0
RP46: 10/20/2009 6:08:26 PM - System Checkpoint
RP47: 10/21/2009 9:27:15 PM - System Checkpoint
RP48: 10/22/2009 10:22:51 PM - System Checkpoint
RP49: 10/23/2009 2:24:58 AM - Software Distribution Service 3.0
RP50: 10/24/2009 3:49:10 AM - System Checkpoint
RP51: 10/25/2009 6:00:02 AM - System Checkpoint
RP52: 10/26/2009 6:39:25 AM - System Checkpoint
RP53: 10/26/2009 9:41:18 AM - Software Distribution Service 3.0
RP54: 10/27/2009 11:34:16 AM - System Checkpoint
RP55: 10/28/2009 3:00:29 AM - Software Distribution Service 3.0
RP56: 10/29/2009 3:00:38 AM - Software Distribution Service 3.0
RP57: 10/29/2009 6:08:31 PM - Software Distribution Service 3.0
RP58: 10/30/2009 6:19:30 PM - System Checkpoint
RP59: 10/31/2009 10:44:47 PM - System Checkpoint
RP60: 11/2/2009 12:43:27 AM - System Checkpoint
RP61: 11/3/2009 1:37:10 AM - Software Distribution Service 3.0
RP62: 11/3/2009 2:17:26 AM - Removed Ask Toolbar.
RP63: 11/4/2009 3:33:24 AM - System Checkpoint
RP64: 11/4/2009 3:35:21 AM - Software Distribution Service 3.0
RP65: 11/5/2009 5:27:27 AM - System Checkpoint
RP66: 11/6/2009 2:47:49 PM - System Checkpoint
RP67: 11/6/2009 3:57:18 PM - Installed Java(TM) 6 Update 17
RP68: 11/6/2009 4:07:50 PM - Removed Adobe Reader 7.0.9
RP69: 11/6/2009 4:08:45 PM - Removed Adobe Reader 7.0.5 Language Support
RP70: 11/6/2009 4:15:12 PM - Installed Adobe Reader 9.2.
RP71: 11/7/2009 6:01:36 AM - Software Distribution Service 3.0
RP72: 11/8/2009 5:18:24 AM - System Checkpoint
1310
1310_Help
1310Tour
1310Trb
Acrobat.com
Adobe AIR
Adobe Flash Player 10 ActiveX
Adobe Flash Player 10 Plugin
Adobe Photoshop Album 2.0 Starter Edition
Adobe Reader 9.2
Adobe Shockwave Player 11.5
Agere Systems PCI Soft Modem
AiO_Scan
AiOSoftware
Alpha Antivirus
AOL Uninstaller (Choose which Products to Remove)
Apple Mobile Device Support
Apple Software Update
Bonjour
BufferChm
CameraDrivers
CCScore
CheckIt Diagnostics
Copy
Creative Centrale
Creative Removable Disk Manager
Creative Software Update
Creative ZEN Mozaic User's Guide
CreativeProjects
CreativeProjectsTemplates
CueTour
Destinations
Director
DivX Web Player
DocProc
DocumentViewer
Enhanced Multimedia Keyboard Solution
ESSCDBK
ESScore
ESSgui
ESSini
ESSPCD
ESSSONIC
ESSTOOLS
essvatgt
EuroTalk Talk Now Plus!
Fax
Firebird SQL Server - MAGIX Edition (US)
GearDrvs
Help and Support Additions
HighMAT Extension to Microsoft Windows XP CD Writing Wizard
HijackThis 2.0.2
HP Deskjet Preloaded Printer Drivers
HP Diagnostic Assistant
HP Image Zone 4.2
HP Image Zone Plus 4.2
HP Organize
HP Photo & Imaging 3.5 - HP Devices
HP PSC & OfficeJet 4.0
HP Update
hpg2436
hpg3970
hpg4600
hpg5530
hpg8200
HPHDiscovery
HPIZ402
HPODiscovery
HpSdpAppCoreApp
HPSystemDiagnostics
InstantShare
IntelliMover Data Transfer Demo
InterActual Player
InterVideo WinDVD Player
iTunes
kgcbaby
kgcbase
kgchday
kgchlwn
kgcinvt
kgckids
kgcmove
kgcvday
Kodak EasyShare software
KSU
Learn2 Player (Uninstall Only)
Microsoft .NET Framework 1.1
Microsoft Easy Assist v2
Microsoft Money 2004
Microsoft Money 2004 System Pack
Microsoft Office Standard Edition 2003
Microsoft Plus! Digital Media Edition Installer
Microsoft Silverlight
Microsoft XML Parser
Move Media Player
Mozilla Firefox (3.5.5)
MSXML 4.0 SP2 (KB925672)
MSXML 4.0 SP2 (KB927978)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
MSXML 6 Service Pack 2 (KB954459)
netbrdg
Norton 360
Norton PC Checkup
Notebook Interactive Viewer
Notifier
NVIDIA Drivers
OfotoXMI
PC-Doctor for Windows
PCDADDIN
PCDHELP
PhotoGallery
Photosmart 320,370,7400,8100,8400 Series
PrintScreen
ProductContext
PS2
PSPrinters06
Python 2.2 combined Win32 extensions
Python 2.2.1
QFolder
Quicken 2004
QuickProjects
QuickTime
Readme
Realtek AC'97 Audio
S3 S3Display
S3 S3Gamma2
S3 S3Info2
S3 S3Overlay
S3GSetup
Scan
Security Update for Windows Internet Explorer 7 (KB928090)
Security Update for Windows Internet Explorer 7 (KB929969)
Security Update for Windows Internet Explorer 7 (KB931768)
Security Update for Windows Internet Explorer 8 (KB969897)
Security Update for Windows Internet Explorer 8 (KB971961)
Security Update for Windows Internet Explorer 8 (KB972260)
Security Update for Windows Internet Explorer 8 (KB974455)
SFR
SHASTA
SKIN0001
SkinsHP1
SkinsHP2
SKINXSDK
Sonic RecordNow!
staticcr
TES Construction Set
Text-To-Speech-Runtime
The Interview With God Screensaver Screensaver
The Sims 2
The Sims 2 Nightlife
The Sims 2 Open For Business
The Sims 2 Pets
The Sims 2 University
The Sims™ 2 Apartment Life
The Sims™ 2 Bon Voyage
The Sims™ 2 Seasons
tooltips
TrayApp
Unload
Update for Windows Internet Explorer 8 (KB971930)
Update for Windows Internet Explorer 8 (KB976749)
Updates from HP
VIA Rhine-Family Fast-Ethernet Adapter
VIA/S3G Display Driver
Viewpoint Manager (Remove Only)
Viewpoint Media Player
VPRINTOL
WebFldrs XP
WebReg
Windows Defender
Windows Genuine Advantage v1.3.0254.0
Windows Imaging Component
Windows Live Messenger
Windows Media Format SDK Hotfix - KB891122
Windows XP Service Pack 3
WinZip Self-Extractor
WIRELESS
11/7/2009 10:28:24 PM, error: Service Control Manager [7011] - Timeout (30000 milliseconds) waiting for a transaction response from the stisvc service.
11/6/2009 4:56:22 AM, error: Service Control Manager [7026] - The following boot-start or system-start driver(s) failed to load: AmdK7 BHDrvx86 ccHP eeCtrl Fips IDSxpx86 SRTSP SRTSPX SYMTDI
11/6/2009 4:55:16 AM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service EventSystem with arguments "" in order to run the server: {1BE1F766-5536-11D1-B726-00C04FB926AF}
11/3/2009 2:17:35 AM, error: Service Control Manager [7023] - The Application Management service terminated with the following error: The specified module could not be found.
gailnc
Posts Posts : 7
Post by Belahzur on 9th November 2009, 1:19 am
  • Save it to your desktop.
    :files
  • Close OTMoveIt
Please post the OTMoveIt log.
Post by gailnc on 9th November 2009, 5:59 am
========== FILES ==========
c:\program files\common files\AAntivirusUninstall moved successfully.
OTM by OldTimer - Version 3.0.0.6 log created on 11092009_005606
gailnc
Posts Posts : 7
Post by Belahzur on 9th November 2009, 8:32 pm
We can remove OTMoveIt now.
  • Please double-click OTM.exe to run it again.
  • Press the green CleanUp! button.
  • Press Yes cleanup process prompt, do the same for the reboot prompt.
Post by gailnc on 9th November 2009, 9:03 pm
I completed the tasks above. The AAntivirus is still showing in my start menu. My Windows defender detected the AAntivirus and I removed the issues it detected. After-wards the AAntivirus is no longer showing up in the start menu. The computer seems to be running fine so far, hopefully this solved the problem. Thank you so very much for all your help.
gailnc
Posts Posts : 7
Post by Belahzur on 10th November 2009, 5:35 pm
Just delete it from your start menu, it's just a leftover.
