Antivirus System Pro Removal
Post by abbazabba34 on Fri Nov 06, 2009 9:17 am
Hello Geek Police! I am new to the site and the Antivirus System Pro has recently installed itself on my computer. I have read the post about "How to Remove Antivirus System PRO [Removal Guide]" and I downloaded Malwarebytes and tried to follow the instructions provided. First I ran the quick scan in normal mode and it did not find any infected files. I am assuming that this occurred because the Antivirus System PRO was still running while the scan was in progress since I couldn't find the suggested process to end on the task manager list to stop it. So then I booted the computer in safe mode and ran a quick scan again and it found one infected file and removed it. Then when I rebooted the computer in normal mode the Antivirus System Pro started up again. I guess I am just wondering if there are any additional steps that I need to take (regarding my system or internet settings) to prevent it from starting up again once I reboot the computer, or if I need to do the scan several times or do a full scan to catch all of the files. Any advice you could offer would be greatly appreciated. Thanks in advance.
abbazabba34
abbazabba34
Joined Joined : 2009-11-06
OS OS : Vista
Points Points : 25864
Re: Antivirus System Pro Removal
Post by Dr Jay on Fri Nov 06, 2009 4:01 pm
Posts Posts : 13714
Points Points : 302072
Post by abbazabba34 on Fri Nov 06, 2009 10:57 pm
Below are the two logs you asked me to include, but first I just wanted to give you some additional information that might help. When I started up my computer today in normal mode, I was able to start a scan with Malwarebytes as well as open up my Task Manager before Antivirus System Pro started. As a result, I was able to do an end task on Antivirus System Pro when it's main screen opens up and it starts its fake scan, so I was able to end the program and stop the pop-ups once my computer started up. Also, everytime I run the scan it keeps finding and removing one file that's the same everytime from the extra/heuristics part of the scan. Here is the name of that file from the scan log:
Here is the combo fix log:
ComboFix 09-11-05.05 - Abby 11/06/2009 16:23.1.2 - NTFSx86
Microsoft® Windows Vista™ Home Premium 6.0.6000.0.1252.1.1033.18.2038.913 [GMT -6:00]
Running from: c:\users\Abba Zabba\Desktop\commy.exe
SP: McAfee VirusScan *disabled* (Updated) {C78B3C70-4777-4742-BB91-9D615CC575E6}
c:\$recycle.bin\S-1-5-21-1178592387-1833165622-420749516-500
c:\$recycle.bin\S-1-5-21-1400113804-1914402855-3429530994-500
c:\$recycle.bin\S-1-5-21-2152478756-3922319563-605102323-500
c:\$recycle.bin\S-1-5-21-1178592387-1833165622-420749516-500\desktop.ini
c:\$recycle.bin\S-1-5-21-1400113804-1914402855-3429530994-500\desktop.ini
c:\$recycle.bin\S-1-5-21-2152478756-3922319563-605102323-500\desktop.ini
((((((((((((((((((((((((( Files Created from 2009-10-06 to 2009-11-06 )))))))))))))))))))))))))))))))
2009-11-06 22:33 . 2009-11-06 22:33 -------- d-----w- c:\users\Default\AppData\Local\temp
2009-11-06 08:25 . 2009-11-06 08:25 -------- d-----w- c:\users\Abba Zabba\AppData\Roaming\Malwarebytes
2009-11-06 08:25 . 2009-09-10 20:54 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-11-06 08:25 . 2009-09-10 20:53 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-11-06 08:25 . 2009-11-06 08:25 4096 d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-11-06 07:24 . 2009-11-06 07:24 -------- d-----w- c:\users\Abby\AppData\Roaming\Malwarebytes
2009-11-06 07:24 . 2009-11-06 07:24 -------- d-----w- c:\programdata\Malwarebytes
2009-11-06 03:13 . 2009-11-06 03:13 -------- d-----w- c:\users\Abba Zabba\AppData\Local\kcwovu
2009-11-03 23:42 . 2009-11-03 23:42 6725632 ----a-w- c:\programdata\Intuit\Quicken\Inet\Common\patch\Update\181625-18178.dll
2009-11-03 05:38 . 2009-11-03 05:38 746760 ----a-w- c:\programdata\Microsoft\eHome\Packages\MCESpotlight\MCESpotlight\SpotlightResources.dll
2009-11-01 17:56 . 2009-11-01 17:58 -------- d-----w- c:\users\Abba Zabba\AppData\Local\Powercinema
2009-10-29 15:05 . 2009-08-07 02:24 44768 ----a-w- c:\windows\system32\wups2.dll
2009-10-29 15:05 . 2009-08-07 02:24 53472 ----a-w- c:\windows\system32\wuauclt.exe
2009-10-29 15:05 . 2009-08-07 02:23 1929952 ----a-w- c:\windows\system32\wuaueng.dll
2009-10-29 15:05 . 2009-08-07 01:45 2421760 ----a-w- c:\windows\system32\wucltux.dll
2009-10-29 15:04 . 2009-08-07 02:24 35552 ----a-w- c:\windows\system32\wups.dll
2009-10-29 15:04 . 2009-08-07 02:23 575704 ----a-w- c:\windows\system32\wuapi.dll
2009-10-29 15:04 . 2009-08-07 01:44 87552 ----a-w- c:\windows\system32\wudriver.dll
2009-10-29 15:04 . 2009-08-07 00:23 171608 ----a-w- c:\windows\system32\wuwebv.dll
2009-10-29 15:04 . 2009-08-06 23:44 33792 ----a-w- c:\windows\system32\wuapp.exe
2009-10-28 14:11 . 2009-09-10 15:29 311296 ----a-w- c:\windows\system32\unregmp2.exe
2009-10-28 14:11 . 2009-09-10 17:39 7680 ----a-w- c:\windows\system32\spwmp.dll
2009-10-28 14:11 . 2009-09-10 17:40 4096 ----a-w- c:\windows\system32\dxmasf.dll
2009-10-28 14:11 . 2009-09-10 15:29 8147968 ----a-w- c:\windows\system32\wmploc.DLL
2009-10-14 02:20 . 2009-09-10 17:38 216576 ----a-w- c:\windows\system32\msv1_0.dll
2009-10-14 02:18 . 2009-09-14 09:50 130048 ----a-w- c:\windows\system32\drivers\srv2.sys
2009-10-14 02:16 . 2009-04-02 11:50 604672 ----a-w- c:\windows\system32\WMSPDMOD.DLL
2009-11-06 22:05 . 2007-08-27 17:25 115704 ----a-w- c:\users\Abby\AppData\Local\GDIPFONTCACHEV1.DAT
2009-11-06 21:10 . 2007-08-22 00:17 12 ----a-w- c:\windows\bthservsdp.dat
2009-11-03 23:43 . 2009-02-14 19:00 49152 d-----w- c:\program files\Quicken
2009-11-03 23:39 . 2009-03-13 07:47 245760 ----a-w- c:\programdata\Intuit\Quicken\Inet\Common\patch\Update\QWPATCH.EXE
2009-11-01 17:56 . 2009-05-23 08:32 -------- d-----w- c:\users\Abba Zabba\AppData\Roaming\CyberLink
2009-10-22 14:56 . 2007-08-22 00:35 4096 d-----w- c:\program files\McAfee
2009-10-17 15:05 . 2009-06-07 02:48 8192 d-----w- c:\users\Abba Zabba\AppData\Roaming\LimeWire
2009-10-15 05:48 . 2006-11-02 11:18 4096 d-----w- c:\program files\Windows Mail
2009-10-14 07:44 . 2007-09-06 21:54 8192 d-----w- c:\programdata\Microsoft Help
2009-10-12 02:19 . 2009-04-15 19:28 4096 d-----w- c:\users\Abba Zabba\AppData\Roaming\Skype
2009-10-11 23:14 . 2009-04-15 19:31 -------- d-----w- c:\users\Abba Zabba\AppData\Roaming\skypePM
2009-10-01 15:29 . 2009-10-03 06:13 195440 ------w- c:\windows\system32\MpSigStub.exe
2009-09-29 22:19 . 2007-09-30 07:32 115704 ----a-w- c:\users\Abba Zabba\AppData\Local\GDIPFONTCACHEV1.DAT
2009-09-29 08:06 . 2007-09-06 22:00 4096 d-----w- c:\program files\Microsoft Works
2009-09-16 15:22 . 2007-08-22 00:35 40552 ----a-w- c:\windows\system32\drivers\mfesmfk.sys
2009-09-16 15:22 . 2007-08-22 00:35 35272 ----a-w- c:\windows\system32\drivers\mfebopk.sys
2009-09-16 15:22 . 2007-08-22 00:35 79816 ----a-w- c:\windows\system32\drivers\mfeavfk.sys
2009-09-16 15:22 . 2007-08-22 00:35 214664 ----a-w- c:\windows\system32\drivers\mfehidk.sys
2009-09-16 15:22 . 2007-08-22 00:35 34248 ----a-w- c:\windows\system32\drivers\mferkdk.sys
2009-09-16 09:16 . 2009-09-16 09:16 127872 ----a-w- c:\users\Abba Zabba\AppData\Roaming\Move Networks\uninstall.exe
2009-09-16 09:16 . 2009-02-02 23:38 4096 d-----w- c:\users\Abba Zabba\AppData\Roaming\Move Networks
2009-09-16 09:16 . 2009-06-16 06:35 4183416 ----a-w- c:\users\Abba Zabba\AppData\Roaming\Move Networks\plugins\npqmp071503000010.dll
2009-09-04 12:38 . 2009-10-14 02:19 60928 ----a-w- c:\windows\system32\msasn1.dll
2009-08-31 15:21 . 2009-10-14 02:19 292352 ----a-w- c:\windows\system32\psisdecd.dll
2009-08-31 15:17 . 2009-10-14 02:19 1244672 ----a-w- c:\windows\system32\mcmde.dll
2009-08-31 15:16 . 2009-10-14 02:19 428032 ----a-w- c:\windows\system32\EncDec.dll
2009-08-29 03:41 . 2009-09-02 22:00 1686528 ----a-w- c:\windows\system32\gameux.dll
2009-08-29 03:40 . 2009-09-02 22:00 28672 ----a-w- c:\windows\system32\Apphlpdm.dll
2009-08-28 23:31 . 2009-09-02 22:00 4247552 ----a-w- c:\windows\system32\GameUXLegacyGDFs.dll
2009-08-27 05:22 . 2009-10-14 02:19 916480 ----a-w- c:\windows\system32\wininet.dll
2009-08-27 05:17 . 2009-10-14 02:19 109056 ----a-w- c:\windows\system32\iesysprep.dll
2009-08-27 05:17 . 2009-10-14 02:19 71680 ----a-w- c:\windows\system32\iesetup.dll
2009-08-27 03:42 . 2009-10-14 02:19 133632 ----a-w- c:\windows\system32\ieUnatt.exe
2009-08-18 04:33 . 2009-08-18 04:33 1193832 ----a-w- c:\windows\system32\FM20.DLL
2009-08-14 17:16 . 2009-09-08 23:21 213592 ----a-w- c:\windows\system32\drivers\netio.sys
2009-08-14 16:42 . 2009-09-08 23:21 167424 ----a-w- c:\windows\system32\tcpipcfg.dll
2009-08-14 16:40 . 2009-09-08 23:21 103936 ----a-w- c:\windows\system32\netiohlp.dll
2009-08-14 16:40 . 2009-09-08 23:21 15360 ----a-w- c:\windows\system32\netevent.dll
2009-08-14 14:25 . 2009-09-08 23:21 9728 ----a-w- c:\windows\system32\TCPSVCS.EXE
2009-08-14 14:25 . 2009-09-08 23:21 17920 ----a-w- c:\windows\system32\ROUTE.EXE
2009-08-14 14:25 . 2009-09-08 23:21 11264 ----a-w- c:\windows\system32\MRINFO.EXE
2009-08-14 14:25 . 2009-09-08 23:21 27136 ----a-w- c:\windows\system32\NETSTAT.EXE
2009-08-14 14:25 . 2009-09-08 23:21 19968 ----a-w- c:\windows\system32\ARP.EXE
2009-08-14 14:25 . 2009-09-08 23:21 8704 ----a-w- c:\windows\system32\HOSTNAME.EXE
2009-08-14 14:25 . 2009-09-08 23:21 10240 ----a-w- c:\windows\system32\finger.exe
2009-08-14 14:24 . 2009-09-08 23:21 813568 ----a-w- c:\windows\system32\drivers\tcpip.sys
2009-08-14 14:23 . 2009-09-08 23:21 22016 ----a-w- c:\windows\system32\netiougc.exe
2007-08-22 00:29 . 2007-08-22 00:29 76 --sh--r- c:\windows\CT4CET.bin
2007-08-22 08:10 . 2007-08-22 08:07 8192 --sha-w- c:\windows\Users\Default\NTUSER.DAT
"ehTray.exe"="c:\windows\ehome\ehTray.exe" [2006-11-02 125440]
"Aim6"="c:\program files\AIM6\aim6.exe" [2008-03-25 50528]
"Skype"="c:\program files\Skype\\Phone\Skype.exe" [2009-04-16 24264488]
"Windows Defender"="c:\program files\Windows Defender\MSASCui.exe" [2007-08-22 1006264]
"SynTPEnh"="c:\program files\Synaptics\SynTP\SynTPEnh.exe" [2007-04-28 857648]
"OEM02Mon.exe"="c:\windows\OEM02Mon.exe" [2007-05-09 36864]
"SigmatelSysTrayApp"="c:\program files\SigmaTel\C-Major Audio\WDM\sttray.exe" [2007-06-25 405504]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2007-05-16 138008]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2007-05-16 154392]
"Persistence"="c:\windows\system32\igfxpers.exe" [2007-05-16 133912]
"ISUSScheduler"="c:\program files\Common Files\InstallShield\UpdateService\issch.exe" [2006-10-03 81920]
"PCMService"="c:\program files\Dell\MediaDirect\PCMService.exe" [2007-04-16 184320]
"ECenter"="c:\dell\E-Center\EULALauncher.exe" [2007-03-16 17920]
"Google Desktop Search"="c:\program files\Google\Google Desktop Search\GoogleDesktop.exe" [2008-12-21 29744]
"dscactivate"="c:\program files\Dell Support Center\gs_agent\custom\dsca.exe" [2007-11-15 16384]
"mcagent_exe"="c:\program files\McAfee.com\Agent\mcagent.exe" [2009-09-17 645328]
"IntelliPoint"="c:\program files\Microsoft IntelliPoint\ipoint.exe" [2009-01-07 1468296]
"mxomssmenu"="c:\program files\Maxtor\OneTouch Status\maxmenumgr.exe" [2008-07-21 169312]
Adobe Reader Speed Launch.lnk - c:\program files\Adobe\Acrobat 7.0\Reader\reader_sl.exe [2005-9-23 29696]
Bluetooth.lnk - c:\program files\WIDCOMM\Bluetooth Software\BTTray.exe [2006-11-3 703280]
Digital Line Detect.lnk - c:\program files\Digital Line Detect\DLG.exe [2007-8-21 50688]
QuickSet.lnk - c:\windows\Installer\{7F0C4457-8E64-491B-8D7B-991504365D1E}\NewShortcut2_53A01CC614B04512A2E710D39BF83DC4.exe [2007-8-21 45056]
"LoadAppInit_DLLs"=1 (0x1)
"AppInit_DLLs"=c:\progra~1\Google\GOOGLE~2\GoogleDesktopNetwork3.dll
SetupExecute REG_MULTI_SZ \0
R2 Viewpoint Manager Service;Viewpoint Manager Service;c:\program files\Viewpoint\Common\ViewpointService.exe [4/16/2008 10:39 PM 24652]
R3 OEM02Dev;Creative Camera OEM002 Driver;c:\windows\System32\drivers\OEM02Dev.sys [7/17/2007 4:02 PM 235520]
R3 OEM02Vfx;Creative Camera OEM002 Video VFX Driver;c:\windows\System32\drivers\OEM02Vfx.sys [8/22/2007 2:10 AM 7424]
S3 GoogleDesktopManager-061008-081103;Google Desktop Manager 5.7.806.10245;c:\program files\Google\Google Desktop Search\GoogleDesktop.exe [8/21/2007 6:39 PM 29744]
*NewlyCreated* - MBR
*NewlyCreated* - PROCEXP113
*Deregistered* - mbr
*Deregistered* - PROCEXP113
bthsvcs REG_MULTI_SZ BthServ
2009-10-15 c:\windows\Tasks\McDefragTask.job
- c:\program files\mcafee\mqc\QcConsol.exe [2009-10-21 17:22]
2009-10-01 c:\windows\Tasks\McQcTask.job
uWindow Title = Internet Explorer provided by Dell
IE: Send image to &Bluetooth Device... - c:\program files\WIDCOMM\Bluetooth Software\btsendto_ie_ctx.htm
IE: Send page to &Bluetooth Device... - c:\program files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
------- File Associations -------
regedit=regedit.exe "%1"
HKLM-Run- - (no file)
Rootkit scan 2009-11-06 16:33
Windows 6.0.6000 NTFS
scanning hȋdden processes ...
scanning hȋdden files ...
hȋdden files: 0
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\msiserver]
"ImagePath"="%systemroot%\system32\msiexec /V"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\{4D36E96D-E325-11CE-BFC1-08002BE10318}\0000\AllUserSettings]
@Denied: (A) (Users)
@Denied: (A) (Everyone)
"BlindDial"=dword:00000000
Completion time: 2009-11-06 16:36
ComboFix-quarantined-files.txt 2009-11-06 22:36
Pre-Run: 48,990,724,096 bytes free
Post-Run: 50,984,370,176 bytes free
- - End Of File - - 6D5DB5BE3D348EE5B8D10034137D846B
Here is the Add/Remove Programs log:
Adobe Flash Player 10 ActiveX
Adobe Reader 7.0.9
Advanced Audio FX Engine
Advanced Video FX Engine
AIM 6
AnswerWorks 5.0 English Runtime
Banctec Service Agreement
Broadcom Management Programs
Conexant HDA D330 MDC V.92 Modem
Dell DataSafe Online
Dell Support Center
Dell System Customization Wizard
Dell Touchpad
DELL Webcam Center
DELL Webcam Manager
DellSupport
Digital Line Detect
Games, Music, & Photos Launcher
Google Desktop
Java(TM) SE Runtime Environment 6
Laptop Integrated Webcam Driver (1.03.02.0719)
LimeWire 4.18.8
Live! Cam Avatar Creator
Live! Cam Avatar v1.0
Maxtor Manager
McAfee SecurityCenter
MediaDirect
Microsoft IntelliPoint 6.3
Microsoft Office 2007 Service Pack 2 (SP2)
Microsoft Office Access MUI (English) 2007
Microsoft Office Access Setup Metadata MUI (English) 2007
Microsoft Office InfoPath MUI (English) 2007
Microsoft Office Professional Plus 2007
Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
Microsoft Office Publisher MUI (English) 2007
Modem Diagnostic Tool
MSXML 4.0 SP2 (KB927978)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB941833)
MSXML 4.0 SP2 (KB954430)
NetWaiting
OutlookAddinSetup
Product Documentation Launcher
Quicken 2009
QuickSet
Roxio Creator Audio
Roxio Creator BDAV Plugin
Roxio Creator Copy
Roxio Creator Data
Roxio Creator DE
Roxio Creator Tools
Roxio Express Labeler
Roxio MyDVD DE
Roxio Update Manager
Security Update for 2007 Microsoft Office System (KB969559)
Security Update for 2007 Microsoft Office System (KB969679)
Security Update for Microsoft Office Excel 2007 (KB969682)
Security Update for Microsoft Office Outlook 2007 (KB972363)
Security Update for Microsoft Office PowerPoint 2007 (KB957789)
Security Update for Microsoft Office Publisher 2007 (KB969693)
Security Update for Microsoft Office system 2007 (972581)
Security Update for Microsoft Office system 2007 (KB969613)
Security Update for Microsoft Office system 2007 (KB974234)
Security Update for Microsoft Office Visio Viewer 2007 (KB973709)
Security Update for Microsoft Office Word 2007 (KB969604)
Skype™ 4.0
Sonic Activation Module
Update for Microsoft Office 2007 Help for Common Features (KB963673)
Update for Microsoft Office Access 2007 Help (KB963663)
Update for Microsoft Office Excel 2007 Help (KB963678)
Update for Microsoft Office Infopath 2007 Help (KB963662)
Update for Microsoft Office Outlook 2007 Help (KB963677)
Update for Microsoft Office Powerpoint 2007 Help (KB963669)
Update for Microsoft Office Publisher 2007 Help (KB963667)
Update for Microsoft Office script Editor Help (KB963671)
Update for Microsoft Office Word 2007 Help (KB963665)
Update for Outlook 2007 Junk Email Filter (KB974810)
URL Assistant
User's Guides
Viewpoint Media Player
WIDCOMM Bluetooth Software 6.0.1.3100
WinZip 12.1
I hope these are what you wanted. Thanks again for all your help.
abbazabba34
abbazabba34
OS OS : Vista
Post by Dr Jay on Sat Nov 07, 2009 1:12 am
Please use Internet Explorer and run a [You must be registered and logged in to see this link.]
  • Please check I agree with the Terms and Conditions and click Start Here
  • You will need to allow an Active X install for the scan to run.
  • Leave the scanning options at default and click Start Scan
Please post the results in your next reply.
Posts Posts : 13714
