Antivirus System PRO (Need help)
Post by v4nity on Fri 06 Nov 2009, 4:51 pm
Okay I tried following the guide, I have downloaded Malwarebytes etc and followed the instructions to run a quick scan etc. Malware found some of the files, but A.V.S.P still remains on my computer.
Operating System : Vista
Re: Antivirus System PRO (Need help)
Post by DragonMaster Jay on Sat 07 Nov 2009, 2:54 am
Please download ComboFix from
GeekPolice Academy Manager
DragonMaster Jay
Manager | Tech Officer
