Antivirus System Pro
Post by jbluemink on Wed Nov 04, 2009 5:11 am
I can't get rid of Antivirus System Pro with the Malwarebytes program. The program detects 3 or 4 items and after deleting them and restarting the malware simply reappears. Below is the HijackThis logfile.
Thanks!
Scan saved at 8:58:41 PM, on 11/3/2009
MSIE: Internet Explorer v6.00 SP3 (6.00.2900.5512)
C:\Program Files\TELUS\TELUS security services\Fws.exe
C:\WINDOWS\system32\agrsmsvc.exe
C:\Program Files\Nero\Nero 7\InCD\InCDsrv.exe
C:\Program Files\O2Micro Oz128 Driver\o2flash.exe
C:\Program Files\Raxco\PerfectDisk\PDAgent.exe
C:\Program Files\TELUS\TELUS security services\rps.exe
C:\Program Files\CyberLink\Shared Files\RichVideo.exe
C:\Program Files\TELUS\TELUS security advisor\TsaComHandler.exe
C:\Program Files\Raxco\PerfectDisk\PDEngine.exe
C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe
C:\Program Files\Nero\Nero 7\InCD\NBHGui.exe
C:\Program Files\Nero\Nero 7\InCD\InCD.exe
C:\WINDOWS\system32\hkcmd.exe
C:\WINDOWS\system32\igfxsrvc.exe
C:\WINDOWS\RTHDCPL.EXE
C:\WINDOWS\system32\oopmagent.exe
C:\Program Files\QuickTime\qttask.exe
C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb05.exe
C:\Program Files\TELUS\TELUS security services\RpsSecurityAwareR.exe
C:\PROGRA~1\TELUSE~1\SMARTB~1\MotiveSB.exe
C:\Program Files\TELUS\TELUS security advisor\Tsa.exe
C:\Documents and Settings\Default\Local Settings\Application Data\jjsnac\opgxsysguard.exe
C:\Program Files\Common Files\LightScribe\LightScribeControlPanel.exe
C:\Program Files\Nikon\PictureProject\NkbMonitor.exe
C:\Program Files\TELUS eCare\bin\mpbtn.exe
C:\Documents and Settings\Default\My Documents\Downloads\winlogon.scr
O1 - Hosts: ::1 localhost
O1 - Hosts: 91.212.127.226 winguard2009.microsoft.com
O1 - Hosts: 91.212.127.226 winguard-2009.com
O1 - Hosts: 91.212.127.226 [You must be registered and logged in to see this link.]
O2 - BHO: Pop-Up Blocker BHO - {3C060EA2-E6A9-4E49-A530-D4657B8C449A} - C:\Program Files\TELUS\TELUS security services\pkR.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.3.4501.1418\swg.dll
O2 - BHO: MSN Toolbar Helper - {d2ce3e00-f94a-4740-988e-03dc2f38c34f} - C:\Program Files\MSN\Toolbar\3.0.1203.0\msneshellx.dll
O3 - Toolbar: MSN Toolbar - {1E61ED7C-7CB8-49d6-B9E9-AB4C880C8414} - C:\Program Files\MSN\Toolbar\3.0.1203.0\msneshellx.dll
O4 - HKLM\..\Run: [IMJPMIG8.1] "C:\WINDOWS\IME\imjp8_1\IMJPMIG.EXE" /Spoil /RemAdvDef /Migration32
O4 - HKLM\..\Run: [MSPY2002] C:\WINDOWS\system32\IME\PINTLGNT\ImScInst.exe /SYNC
O4 - HKLM\..\Run: [PHIME2002ASync] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /SYNC
O4 - HKLM\..\Run: [PHIME2002A] C:\WINDOWS\system32\IME\TINTLGNT\TINTSETP.EXE /IMEName
O4 - HKLM\..\Run: [RemoteControl] "C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe"
O4 - HKLM\..\Run: [LanguageShortcut] "C:\Program Files\CyberLink\PowerDVD\Language\Language.exe"
O4 - HKLM\..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Ahead\Lib\NeroCheck.exe
O4 - HKLM\..\Run: [SecurDisc] C:\Program Files\Nero\Nero 7\InCD\NBHGui.exe
O4 - HKLM\..\Run: [InCD] C:\Program Files\Nero\Nero 7\InCD\InCD.exe
O4 - HKLM\..\Run: [Persistence] C:\WINDOWS\system32\igfxpers.exe
O4 - HKLM\..\Run: [ooquickpdfv7] "C:\WINDOWS\system32\oopmagent.exe"
O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb05.exe
O4 - HKLM\..\Run: [TELUS] D:\Install\TELUS.exe
O4 - HKLM\..\Run: [Motive SmartBridge] C:\PROGRA~1\TELUSE~1\SMARTB~1\MotiveSB.exe
O4 - HKLM\..\Run: [Tsa.exe] "C:\Program Files\TELUS\TELUS security advisor\Tsa.exe" /AUTORUN
O4 - HKLM\..\Run: [cmyhtabn] C:\Documents and Settings\Default\Local Settings\Application Data\jjsnac\opgxsysguard.exe
O4 - HKLM\..\RunOnce: [IndexCleaner] "C:\Program Files\TELUS\TELUS security services\IdxClnR.exe"
O4 - HKLM\..\RunOnce: [Malwarebytes' Anti-Malware] C:\Program Files\Malwarebytes' Anti-Malware\mbamgui.exe /install /silent
O4 - HKCU\..\Run: [LightScribe Control Panel] C:\Program Files\Common Files\LightScribe\LightScribeControlPanel.exe -hȋdden
O4 - HKCU\..\Run: [cmyhtabn] C:\Documents and Settings\Default\Local Settings\Application Data\jjsnac\opgxsysguard.exe
O4 - HKCU\..\RunOnce: [IndexCleaner] "C:\Program Files\TELUS\TELUS security services\IdxClnR.exe"
O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Reader 8.0\Reader\reader_sl.exe
O4 - Global Startup: Adobe Reader Synchronizer.lnk = C:\Program Files\Adobe\Reader 8.0\Reader\AdobeCollabSync.exe
O4 - Global Startup: NkbMonitor.exe.lnk = C:\Program Files\Nikon\PictureProject\NkbMonitor.exe
O4 - Global Startup: OFFICE One Startup v7.lnk = C:\Program Files\OFFICE One v7\OFFICE One Startup v7\oostartupv7.exe
O4 - Global Startup: TELUS eCare.lnk = C:\Program Files\TELUS eCare\bin\matcli.exe
O23 - Service: Agere Modem Call Progress Audio (AgereModemAudio) - Agere Systems - C:\WINDOWS\system32\agrsmsvc.exe
O23 - Service: Google Update Service (gupdate1c9b7fb7edccd26) (gupdate1c9b7fb7edccd26) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: Google Software Updater (gusvc) - Unknown owner - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe (file missing)
O23 - Service: InCD Helper (InCDsrv) - Nero AG - C:\Program Files\Nero\Nero 7\InCD\InCDsrv.exe
O23 - Service: NBService - Nero AG - C:\Program Files\Nero\Nero 7\Nero BackItUp\NBService.exe
O23 - Service: NMIndexingService - Nero AG - C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe
O23 - Service: O2Micro Flash Memory Card Service (o2flash) - O2Micro International - C:\Program Files\O2Micro Oz128 Driver\o2flash.exe
O23 - Service: PDAgent - Raxco Software, Inc. - C:\Program Files\Raxco\PerfectDisk\PDAgent.exe
O23 - Service: PDEngine - Raxco Software, Inc. - C:\Program Files\Raxco\PerfectDisk\PDEngine.exe
O23 - Service: TELUS security services (Radialpoint Security Services) - TELUS - C:\Program Files\TELUS\TELUS security services\RpsSecurityAwareR.exe
O23 - Service: Cyberlink RichVideo Service(CRVS) (RichVideo) - Unknown owner - C:\Program Files\CyberLink\Shared Files\RichVideo.exe
O23 - Service: TELUS security services Firewall (RP_FWS) - TELUS - C:\Program Files\TELUS\TELUS security services\Fws.exe
End of file - 9173 bytes
jbluemink
OS : Vist home premium
Re: Antivirus System Pro
Post by Belahzur on Thu Nov 05, 2009 1:04 am
Post by jbluemink on Fri Nov 06, 2009 2:56 am
Hi, here's the Malwarebytes log. It seems to have worked, thanks a lot!
Database version: 2775
11/5/2009 6:50:02 PM
mbam-log-2009-11-05 (18-50-02).txt
Objects scanned: 87404
Time elapsed: 3 minute(s), 13 second(s)
Registry Keys Infected: 3
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{b6d223f6-c185-49a2-ba7e-a03e84744702} (Trojan.Vundo.H) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{b6d223f6-c185-49a2-ba7e-a03e84744702} (Trojan.Vundo.H) -> Quarantined and deleted successfully.
jbluemink
Post by Dr Jay on Fri Nov 06, 2009 3:08 pm
Please use Internet Explorer and run a [You must be registered and logged in to see this link.]
  • Please check I agree with the Terms and Conditions and click Start Here
  • You will need to allow an Active X install for the scan to run.
  • Leave the scanning options at default and click Start Scan
Please post the results in your next reply.
OS : Windows 10 Home & Pro
