Antivirus System Pro help
Page 3 of 3
Page 3 of 3 • 1, 2, 3
- squidboyNovice
OS : XP Home
Rubies : 3111
Here's the CKScanner log:
CKScanner - Additional Security Risks - These are not necessarily bad
scanner sequence 3.RP.11
----- EOF -----
And here's the Security Check log:
Results of screen317's Security Check version 0.99.0
Windows XP Service Pack 2
Out of date service pack!!
Antivirus/Firewall Check:
Windows Firewall Enabled!
Java(TM) 6 Update 11
Out of date Java installed!
Adobe Flash Player 10
Adobe Reader 7.0.9
Process Check:
objlist.exe by Laurent
DNS Vulnerability Check:
Actually, the computer seems to be running pretty well. I haven't been flooded with pop-ups, able to browse various known-safe sites, able to open whatever programs I choose without being blocked. If I didn't know better, I'd say it's back to normal. And maybe it is?! I will await your opinion and reply - thanks again for your support!!!
----- EOF -----
Adobe Reader 7.0.9
Process Check:
- Dr JayHead Admin
Power of Youth!
OS : Windows 10 Home & Pro, Android, Linux
Arch. : x64 (64-bit)
Anti-Malware : Bitdefender Total Security
Rubies : 289571
Please upgrade to Windows XP SP3, because it includes all previously released updates. It also includes a small number of new functionalities. Some of the updates that Service Pack 3 provides, you may not have. It is now available via Windows Update.
Please download the newest version of Adobe Acrobat Reader from Adobe.com
Please download the newest version of Java from Java.com.
Software recommendations
Antivirus/Antispyware
Firewall
Note: Please keep ALL of these programs up-to-date and run them whenever you suspect a problem to prevent malware problems.
Resident Protection help
Rogue programs help
http://www.spywarewarrior.com/rogue_anti-spyware.htm
Securing your computer
If you are interested:
Thank you for choosing GeekPolice. Please see this page if you would like to leave feedback or contribute to our site. Do you have any more questions?
- Microsoft Security Essentials: this is Microsoft's free antivirus/antispyware program. It equips you with protection against viruses, spyware, trojans, rootkits, and worms. It is also light on the computer's performance. Note: when installing this, you have both an antivirus and antispyware. Make sure you also get a firewall.
- AVG Free: this is one of the most powerful, and easiest to use security software. The free version equips you with protection against viruses, spyware, trojans, rootkits, worms, and rogue software. Note: when installing this, you have both an antivirus and antispyware. Make sure you also get a firewall.
Firewall
- Tallemu Online Armor: the free version is just as good as the premium. I have linked you to the free version.
- Comodo Firewall: the free version is just as good as the premium. I have linked you to the free version. The optional security suite enhances the firewall by 40% increase. If you would like to install the suite that includes antivirus, then remove your old antivirus first.
- PC Tools Firewall Plus: free and excellent firewall.
Rogue programs help
- Windows Updates - It is very important to make sure that both Internet Explorer and Windows are kept current with the latest critical security patches from Microsoft. To do this just start Internet Explorer and select Tools > Windows Update, and follow the online instructions from there.
- hpHosts file replaces your current HOSTS file with one containing well known ad sites and other bad sites. This prevents your computer from connecting to those sites by redirecting them to 127.0.0.1, which is your local computer's loopback address, meaning it will be difficult to infect your computer in the future.
- Firefox may be downloaded from here: http://www.getfirefox.com
- Opera is available here: http://www.opera.com/download/
- squidboyNovice
OS : XP Home
Rubies : 3111
DragonMaster Jay, you are awesome! Thank you so much for your help getting me through this - I definitely couldn't have done it without you. And thanks for the final tips; I'll make sure I do everything you recommended.....and I will certainly be making a donation as a "thank you".
Thanks!
Steve
Thanks!
Steve
Similar topics
Page 3 of 3
