Antivirus System Pro help
Post by squidboy on Mon Nov 02, 2009 3:22 am
I've been infected with this fun little virus. I have downloaded the malwarebyte software (from another pc, as it redirects me to it's special page on the infected pc) and installed it. It seemed like it was going to scan, then was disrupted by the Antivirus Pro. I have tried the "hijack this" utility to create a log file, but when I run it, it has a splash screen for 1-2 seconds & disappears. Not sure what to try next. ANy help would be much appreciated.
Thanks!
squidboy
OS : XP Home
Re: Antivirus System Pro help
Post by Dr Jay on Mon Nov 02, 2009 3:26 am
Please download [You must be registered and logged in to see this link.] (by S!Ri)
Extract the content (a folder named SmitfraudFix) to your Desktop.
Double-click smitfraudfix.exe
Select option #1 - Search by typing 1 and press "Enter"; a text file will appear, which lists infected files (if present).
Please copy/paste the content of that report into your next reply.
OS : Windows 10 Home & Pro
Post by squidboy on Mon Nov 02, 2009 3:33 am
I just tried that and when I click on smitfraudfix, I get a small "DOS-type" splash screen that comes up with "c:windows\system32\cmd.exe" as the header, but it goes away immediately.
squidboy
OS : XP Home
Post by Dr Jay on Mon Nov 02, 2009 3:39 am
Post by squidboy on Mon Nov 02, 2009 3:49 am
OK, I got combofix started & everything looked to be going well, but it stopped me and told me to close my Kaspersky anti-virus. I would, but it is not active on the task-bar & it is nowhere to be seen in the task manager. Is there another (hȋdden?) place to disable it so I can continue with the combofix? Thanks!
squidboy
OS : XP Home
Post by Dr Jay on Mon Nov 02, 2009 4:17 am
ComboFix will probably disable it for you. Go ahead.
Post by squidboy on Mon Nov 02, 2009 4:59 am
It keeps telling me "the posted message is too big" when I try to inser the contents of the log file, so I'll put them in a few different posts, beginning here:
ComboFix 09-10-30.01 - Steve 11/01/2009 23:29.1.1 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.1023.717 [GMT -5:00]
Running from: c:\documents and settings\Steve\desktop\commy.exe
AV: Kaspersky Internet Security *On-access scanning enabled* (Updated) {2C4D4BC6-0793-4956-A9F9-E252435469C0}
FW: Kaspersky Internet Security *enabled* {2C4D4BC6-0793-4956-A9F9-E252435469C0}
C:\Images
c:\program files\gihogn
c:\program files\gihogn\fhicsysguard.exe
c:\program files\wxwrmo
c:\program files\wxwrmo\eefdsysguard.exe
c:\recycler\NPROTECT
c:\windows\system32\lowsec
c:\docume~1\Steve\LOCALS~1\Temp\svchost.exe
c:\docume~1\Steve\LOCALS~1\Temp\winlogon.exe
c:\documents and settings\All Users\Application Data\Microsoft\Media\WPTEct.dll
c:\documents and settings\Steve\Application Data\inst.exe
c:\documents and settings\Steve\ntuser.dll
c:\documents and settings\Steve\Start Menu\Programs\Startup\scandisk.dll
c:\documents and settings\Steve\Start Menu\Programs\Startup\scandisk.lnk
C:\ntldrs
c:\recycler\NPROTECT\00000132.rbf
c:\recycler\NPROTECT\00000133.rbf
c:\recycler\NPROTECT\00000134.rbf
c:\recycler\NPROTECT\00000135.rbf
c:\recycler\NPROTECT\00000136.rbf
c:\recycler\NPROTECT\00000137.rbf
c:\recycler\NPROTECT\00000138.rbf
c:\recycler\NPROTECT\00000139.rbf
c:\recycler\NPROTECT\00000140.rbf
c:\recycler\NPROTECT\00000141.rbf
c:\recycler\NPROTECT\00000142.rbf
c:\recycler\NPROTECT\00000143.rbf
c:\recycler\NPROTECT\00000144.rbf
c:\recycler\NPROTECT\00000145.rbf
c:\recycler\NPROTECT\00000146.rbf
c:\recycler\NPROTECT\00000147.rbf
c:\recycler\NPROTECT\00000148.rbf
c:\recycler\NPROTECT\00000149.rbf
c:\recycler\NPROTECT\00000150.rbf
c:\recycler\NPROTECT\00000151.rbf
c:\recycler\NPROTECT\00000152.rbf
c:\recycler\NPROTECT\00000153.rbf
c:\recycler\NPROTECT\00000154.rbf
c:\recycler\NPROTECT\00000155.rbf
c:\recycler\NPROTECT\00000156.rbf
c:\recycler\NPROTECT\00000157.rbf
c:\recycler\NPROTECT\00000158.rbf
c:\recycler\NPROTECT\00000159.rbf
c:\recycler\NPROTECT\00000160.rbf
c:\recycler\NPROTECT\00000161.rbf
c:\recycler\NPROTECT\00000162.rbf
c:\recycler\NPROTECT\00000163.rbs
c:\recycler\NPROTECT\00000164.ipi
c:\recycler\NPROTECT\00000165.msi
c:\recycler\NPROTECT\00000171.rbs
c:\recycler\NPROTECT\00000172.ipi
c:\recycler\NPROTECT\00000173.msi
c:\recycler\NPROTECT\00000186.DLL
c:\recycler\NPROTECT\00000187.SYS
c:\recycler\NPROTECT\00000188.SPM
c:\recycler\NPROTECT\00000189.GRD
c:\recycler\NPROTECT\00000190.SIG
c:\recycler\NPROTECT\00000191.INF
c:\recycler\NPROTECT\00000192.CAT
c:\recycler\NPROTECT\00000196.rbs
c:\recycler\NPROTECT\00000197.ipi
c:\recycler\NPROTECT\00000198.msi
c:\recycler\NPROTECT\00000205.rbs
c:\recycler\NPROTECT\00000206.ipi
c:\recycler\NPROTECT\00000207.msi
c:\recycler\NPROTECT\00000210.rbf
c:\recycler\NPROTECT\00000211.rbf
c:\recycler\NPROTECT\00000212.rbf
c:\recycler\NPROTECT\00000213.rbf
c:\recycler\NPROTECT\00000214.rbf
c:\recycler\NPROTECT\00000215.rbf
c:\recycler\NPROTECT\00000216.rbs
c:\recycler\NPROTECT\00000217.ipi
c:\recycler\NPROTECT\00000218.msi
c:\recycler\NPROTECT\00000221.rbf
c:\recycler\NPROTECT\00000222.rbf
c:\recycler\NPROTECT\00000223.rbs
c:\recycler\NPROTECT\00000224.ipi
c:\recycler\NPROTECT\00000225.msi
c:\recycler\NPROTECT\00000227.dat
c:\recycler\NPROTECT\00000229.EXE
c:\recycler\NPROTECT\00000230.LOC
c:\recycler\NPROTECT\00000231.dll
c:\recycler\NPROTECT\00000232.dll
c:\recycler\NPROTECT\00000233.loc
c:\recycler\NPROTECT\00000234.exe
c:\recycler\NPROTECT\00000235.dll
c:\recycler\NPROTECT\00000236.dll
c:\recycler\NPROTECT\00000237.dll
c:\recycler\NPROTECT\00000238.dll
c:\recycler\NPROTECT\00000351.ecf
c:\recycler\NPROTECT\00000434.RPT
c:\recycler\NPROTECT\00000435.RPT
c:\recycler\NPROTECT\00000437.KLZ
c:\recycler\NPROTECT\00000438.xml
c:\recycler\NPROTECT\00000440.XML
c:\recycler\NPROTECT\00000441.XML
c:\recycler\NPROTECT\00000442.XML
c:\recycler\NPROTECT\00000446.dat
c:\recycler\NPROTECT\00000450.avc
c:\recycler\NPROTECT\00000453.avc
c:\recycler\NPROTECT\00000457.BES
c:\recycler\NPROTECT\00000458.DIF
c:\recycler\NPROTECT\00000459.2V8
c:\recycler\NPROTECT\00000460.AZI
c:\recycler\NPROTECT\00000461.DIF
c:\recycler\NPROTECT\00000462.DIF
c:\recycler\NPROTECT\00000463.370
c:\recycler\NPROTECT\00000464.ODR
c:\recycler\NPROTECT\00000465.T6K
c:\recycler\NPROTECT\00000466.Y2E
c:\recycler\NPROTECT\00000467.DIF
c:\recycler\NPROTECT\00000468.gsg
c:\recycler\NPROTECT\00000469.KRG
c:\recycler\NPROTECT\00000470.XML
c:\recycler\NPROTECT\00000471.KRG
c:\recycler\NPROTECT\00000472.stt
c:\recycler\NPROTECT\00000473.krg
c:\recycler\NPROTECT\00000474.stt
c:\recycler\NPROTECT\00000475.dat
c:\recycler\NPROTECT\00000476.XML
c:\recycler\NPROTECT\00000477.KRG
c:\recycler\NPROTECT\00000478.XML
c:\recycler\NPROTECT\00000479.avc
c:\recycler\NPROTECT\00000480.avc
c:\recycler\NPROTECT\00000481.avc
c:\recycler\NPROTECT\00000482.avc
c:\recycler\NPROTECT\00000483.avc
c:\recycler\NPROTECT\00000484.xml
c:\recycler\NPROTECT\00000485.xml
c:\recycler\NPROTECT\00000486.XML
c:\recycler\NPROTECT\00000487.stt
c:\recycler\NPROTECT\00000489.XML
c:\recycler\NPROTECT\00000490.stt
c:\recycler\NPROTECT\00000491.dat
c:\recycler\NPROTECT\00000492.XML
c:\recycler\NPROTECT\00000493.gsg
c:\recycler\NPROTECT\00000494.XML
c:\recycler\NPROTECT\00000495.avc
c:\recycler\NPROTECT\00000496.avc
c:\recycler\NPROTECT\00000500.krg
c:\recycler\NPROTECT\00000501.KRG
c:\recycler\NPROTECT\00000502.KRG
c:\recycler\NPROTECT\00000503.KRG
c:\recycler\NPROTECT\00000505.XML
c:\recycler\NPROTECT\00000673.ecf
c:\recycler\NPROTECT\00000798.RPT
c:\recycler\NPROTECT\00000799.RPT
c:\recycler\NPROTECT\00000800.KLZ
c:\recycler\NPROTECT\00000801.xml
c:\recycler\NPROTECT\00000804.XML
c:\recycler\NPROTECT\00000806.XML
c:\recycler\NPROTECT\00000807.XML
c:\recycler\NPROTECT\00000816.dat
c:\recycler\NPROTECT\00000818.Z4R
c:\recycler\NPROTECT\00000819.DIF
c:\recycler\NPROTECT\00000820.DIF
c:\recycler\NPROTECT\00000821.USO
c:\recycler\NPROTECT\00000822.PBZ
c:\recycler\NPROTECT\00000823.P9O
c:\recycler\NPROTECT\00000824.M6U
c:\recycler\NPROTECT\00000825.DIF
c:\recycler\NPROTECT\00000826.DIF
c:\recycler\NPROTECT\00000827.gsg
c:\recycler\NPROTECT\00000828.KRG
c:\recycler\NPROTECT\00000829.XML
c:\recycler\NPROTECT\00000830.KRG
c:\recycler\NPROTECT\00000831.stt
c:\recycler\NPROTECT\00000832.krg
c:\recycler\NPROTECT\00000833.stt
c:\recycler\NPROTECT\00000834.dat
c:\recycler\NPROTECT\00000835.XML
c:\recycler\NPROTECT\00000836.KRG
c:\recycler\NPROTECT\00000837.XML
c:\recycler\NPROTECT\00000838.avc
c:\recycler\NPROTECT\00000839.avc
c:\recycler\NPROTECT\00000840.xml
c:\recycler\NPROTECT\00000841.xml
c:\recycler\NPROTECT\00000842.XML
c:\recycler\NPROTECT\00000843.gsg
c:\recycler\NPROTECT\00000844.XML
c:\recycler\NPROTECT\00000845.avc
c:\recycler\NPROTECT\00000846.avc
c:\recycler\NPROTECT\00000847.avc
c:\recycler\NPROTECT\00000848.avc
c:\recycler\NPROTECT\00000852.XML
c:\recycler\NPROTECT\00000853.dat
c:\recycler\NPROTECT\00000856.XML
c:\recycler\NPROTECT\00000857.dat
c:\recycler\NPROTECT\00000858.PBV
c:\recycler\NPROTECT\00000859.KRG
c:\recycler\NPROTECT\00000860.KRG
c:\recycler\NPROTECT\00000861.krg
c:\recycler\NPROTECT\00000863.XML
c:\recycler\NPROTECT\00000865.XML
c:\recycler\NPROTECT\00000991.ecf
c:\recycler\NPROTECT\00001125.CAB
c:\recycler\NPROTECT\00001128.chk
c:\recycler\NPROTECT\00001134.cab
c:\recycler\NPROTECT\00001140.cab
c:\recycler\NPROTECT\00001163.edb
c:\recycler\NPROTECT\00001164.log
c:\recycler\NPROTECT\00001191.RPT
c:\recycler\NPROTECT\00001192.RPT
c:\recycler\NPROTECT\00001194.KLZ
c:\recycler\NPROTECT\00001195.xml
c:\recycler\NPROTECT\00001198.KLZ
c:\recycler\NPROTECT\00001199.XML
c:\recycler\NPROTECT\00001200.XML
c:\recycler\NPROTECT\00001201.XML
c:\recycler\NPROTECT\00001202.XML
c:\recycler\NPROTECT\00001207.dat
c:\recycler\NPROTECT\00001216.U5N
c:\recycler\NPROTECT\00001217.DIF
c:\recycler\NPROTECT\00001218.WXW
c:\recycler\NPROTECT\00001219.ZFL
c:\recycler\NPROTECT\00001220.DIF
c:\recycler\NPROTECT\00001221.DIF
c:\recycler\NPROTECT\00001222.YY1
c:\recycler\NPROTECT\00001223.DIF
c:\recycler\NPROTECT\00001224.DIF
c:\recycler\NPROTECT\00001225.gsg
c:\recycler\NPROTECT\00001226.KRG
c:\recycler\NPROTECT\00001227.XML
c:\recycler\NPROTECT\00001228.KRG
c:\recycler\NPROTECT\00001229.XML
c:\recycler\NPROTECT\00001230.avc
c:\recycler\NPROTECT\00001231.avc
c:\recycler\NPROTECT\00001232.avc
c:\recycler\NPROTECT\00001233.avc
c:\recycler\NPROTECT\00001234.krg
c:\recycler\NPROTECT\00001235.XML
c:\recycler\NPROTECT\00001236.dat
c:\recycler\NPROTECT\00001237.xml
c:\recycler\NPROTECT\00001238.PBV
c:\recycler\NPROTECT\00001239.xml
c:\recycler\NPROTECT\00001240.XML
c:\recycler\NPROTECT\00001241.stt
c:\recycler\NPROTECT\00001243.XML
c:\recycler\NPROTECT\00001244.stt
c:\recycler\NPROTECT\00001245.dat
c:\recycler\NPROTECT\00001246.XML
c:\recycler\NPROTECT\00001247.gsg
c:\recycler\NPROTECT\00001248.XML
c:\recycler\NPROTECT\00001249.avc
c:\recycler\NPROTECT\00001253.PBV
c:\recycler\NPROTECT\00001254.krg
c:\recycler\NPROTECT\00001255.KRG
c:\recycler\NPROTECT\00001256.KRG
c:\recycler\NPROTECT\00001257.KRG
c:\recycler\NPROTECT\00001259.XML
c:\recycler\NPROTECT\00001260.XML
c:\recycler\NPROTECT\00001261.KRG
c:\recycler\NPROTECT\00001262.dat
c:\recycler\NPROTECT\00001263.dat
c:\recycler\NPROTECT\00001264.dat
c:\recycler\NPROTECT\00001266.ecf
c:\recycler\NPROTECT\00001267.DB-
c:\recycler\NPROTECT\00001268.DB-
c:\recycler\NPROTECT\00001272.DB-
c:\recycler\NPROTECT\00001287.ecf
c:\recycler\NPROTECT\00001289.RPT
c:\recycler\NPROTECT\00001304.edb
c:\recycler\NPROTECT\00001335.DLL
c:\recycler\NPROTECT\00001336.SYS
c:\recycler\NPROTECT\00001337.SPM
c:\recycler\NPROTECT\00001338.GRD
c:\recycler\NPROTECT\00001339.SIG
c:\recycler\NPROTECT\00001340.INF
c:\recycler\NPROTECT\00001341.CAT
c:\recycler\NPROTECT\00001342.dl^
c:\recycler\NPROTECT\00001343.dl^
c:\recycler\NPROTECT\00001344.dl^
c:\recycler\NPROTECT\00001345.dl^
c:\recycler\NPROTECT\00001346.DL^
c:\recycler\NPROTECT\00001347.DL^
c:\recycler\NPROTECT\00001348.dl^
c:\recycler\NPROTECT\00001349.ex^
c:\recycler\NPROTECT\00001350.ex^
c:\recycler\NPROTECT\00001351.dl^
c:\recycler\NPROTECT\00001352.dl^
c:\recycler\NPROTECT\00001353.dl^
c:\recycler\NPROTECT\00001354.dl^
c:\recycler\NPROTECT\00001355.dl^
c:\recycler\NPROTECT\00001356.gr^
c:\recycler\NPROTECT\00001357.si^
c:\recycler\NPROTECT\00001358.sp^
c:\recycler\NPROTECT\00001360.dll
c:\recycler\NPROTECT\00001361.dat
c:\recycler\NPROTECT\00001362.scr
c:\recycler\NPROTECT\00001363.txt
c:\recycler\NPROTECT\00001364.DIS
c:\recycler\NPROTECT\00001365.grd
c:\recycler\NPROTECT\00001366.sig
c:\recycler\NPROTECT\00001367.dat
c:\recycler\NPROTECT\00001368.grd
c:\recycler\NPROTECT\00001369.sig
c:\recycler\NPROTECT\00001370.wlt
c:\recycler\NPROTECT\00001371.scr
c:\recycler\NPROTECT\00001372.txt
c:\recycler\NPROTECT\00001374.DIS
c:\recycler\NPROTECT\00001375.dis
c:\recycler\NPROTECT\00001376.grd
c:\recycler\NPROTECT\00001377.sig
c:\recycler\NPROTECT\00001393.DLL
c:\recycler\NPROTECT\00001394.SYS
c:\recycler\NPROTECT\00001395.SPM
c:\recycler\NPROTECT\00001396.GRD
c:\recycler\NPROTECT\00001397.SIG
c:\recycler\NPROTECT\00001398.INF
c:\recycler\NPROTECT\00001399.CAT
c:\recycler\NPROTECT\00001401.rbf
c:\recycler\NPROTECT\00001402.rbf
c:\recycler\NPROTECT\00001403.rbf
c:\recycler\NPROTECT\00001404.rbf
c:\recycler\NPROTECT\00001405.rbf
c:\recycler\NPROTECT\00001406.rbf
c:\recycler\NPROTECT\00001407.rbf
c:\recycler\NPROTECT\00001408.rbf
c:\recycler\NPROTECT\00001409.rbf
c:\recycler\NPROTECT\00001410.rbf
c:\recycler\NPROTECT\00001411.rbf
c:\recycler\NPROTECT\00001412.rbf
c:\recycler\NPROTECT\00001413.rbs
c:\recycler\NPROTECT\00001414.ipi
c:\recycler\NPROTECT\00001415.msi
c:\recycler\NPROTECT\00001418.rbs
c:\recycler\NPROTECT\00001419.ipi
c:\recycler\NPROTECT\00001420.msi
c:\recycler\NPROTECT\00001421.dl^
c:\recycler\NPROTECT\00001422.dl^
c:\recycler\NPROTECT\00001423.ex^
c:\recycler\NPROTECT\00001424.dl^
c:\recycler\NPROTECT\00001425.dl^
c:\recycler\NPROTECT\00001426.dl^
c:\recycler\NPROTECT\00001427.dl^
c:\recycler\NPROTECT\00001428.dl^
c:\recycler\NPROTECT\00001429.dl^
c:\recycler\NPROTECT\00001430.dl^
c:\recycler\NPROTECT\00001512.ini
c:\recycler\NPROTECT\00001513.ini
c:\recycler\NPROTECT\00001514.dat
c:\recycler\NPROTECT\00001515.dat
c:\recycler\NPROTECT\00001518.LOG
c:\recycler\NPROTECT\00001519.log
c:\recycler\NPROTECT\00001520.log
c:\recycler\NPROTECT\00001521.log
c:\recycler\NPROTECT\00001522.dat
c:\recycler\NPROTECT\00001523.dat
c:\recycler\NPROTECT\00001524.dat
c:\recycler\NPROTECT\00001539.ecf
c:\recycler\NPROTECT\00001545.RPT
c:\recycler\NPROTECT\00001554.REG
c:\recycler\NPROTECT\00001555.REG
c:\recycler\NPROTECT\00001556.REG
c:\recycler\NPROTECT\00001557.REG
c:\recycler\NPROTECT\00001558.REG
c:\recycler\NPROTECT\00001559.REG
c:\recycler\NPROTECT\00001560.REG
c:\recycler\NPROTECT\00001561.REG
c:\recycler\NPROTECT\00001562.REG
c:\recycler\NPROTECT\00001563.REG
c:\recycler\NPROTECT\00001564.REG
c:\recycler\NPROTECT\00001565.REG
c:\recycler\NPROTECT\00001566.REG
c:\recycler\NPROTECT\00001567.REG
c:\recycler\NPROTECT\00001568.REG
c:\recycler\NPROTECT\00001569.REG
c:\recycler\NPROTECT\00001570.REG
c:\recycler\NPROTECT\00001571.REG
c:\recycler\NPROTECT\00001572.REG
c:\recycler\NPROTECT\00001573.REG
c:\recycler\NPROTECT\00001574.REG
c:\recycler\NPROTECT\00001575.REG
c:\recycler\NPROTECT\00001576.REG
c:\recycler\NPROTECT\00001577.REG
c:\recycler\NPROTECT\00001578.REG
c:\recycler\NPROTECT\00001579.REG
c:\recycler\NPROTECT\00001580.REG
c:\recycler\NPROTECT\00001581.REG
c:\recycler\NPROTECT\00001582.REG
c:\recycler\NPROTECT\00001583.REG
c:\recycler\NPROTECT\00001584.REG
c:\recycler\NPROTECT\00001585.edb
c:\recycler\NPROTECT\00001586.REG
c:\recycler\NPROTECT\00001587.REG
c:\recycler\NPROTECT\00001588.REG
c:\recycler\NPROTECT\00001589.REG
c:\recycler\NPROTECT\00001590.REG
c:\recycler\NPROTECT\00001591.REG
c:\recycler\NPROTECT\00001592.REG
c:\recycler\NPROTECT\00001593.REG
c:\recycler\NPROTECT\00001594.REG
c:\recycler\NPROTECT\00001595.REG
c:\recycler\NPROTECT\00001596.REG
c:\recycler\NPROTECT\00001597.REG
c:\recycler\NPROTECT\00001598.REG
c:\recycler\NPROTECT\00001599.REG
c:\recycler\NPROTECT\00001600.REG
c:\recycler\NPROTECT\00001601.REG
c:\recycler\NPROTECT\00001602.REG
c:\recycler\NPROTECT\00001603.REG
c:\recycler\NPROTECT\00001604.REG
c:\recycler\NPROTECT\00001605.REG
c:\recycler\NPROTECT\00001606.REG
c:\recycler\NPROTECT\00001607.REG
c:\recycler\NPROTECT\00001608.REG
c:\recycler\NPROTECT\00001609.REG
c:\recycler\NPROTECT\00001610.REG
c:\recycler\NPROTECT\00001611.REG
c:\recycler\NPROTECT\00001612.REG
c:\recycler\NPROTECT\00001613.REG
c:\recycler\NPROTECT\00001614.REG
c:\recycler\NPROTECT\00001615.REG
c:\recycler\NPROTECT\00001616.REG
c:\recycler\NPROTECT\00001617.REG
c:\recycler\NPROTECT\00001618.REG
c:\recycler\NPROTECT\00001619.REG
c:\recycler\NPROTECT\00001620.REG
c:\recycler\NPROTECT\00001621.REG
c:\recycler\NPROTECT\00001622.REG
c:\recycler\NPROTECT\00001623.REG
c:\recycler\NPROTECT\00001624.REG
c:\recycler\NPROTECT\00001625.REG
c:\recycler\NPROTECT\00001626.REG
c:\recycler\NPROTECT\00001627.REG
c:\recycler\NPROTECT\00001628.REG
c:\recycler\NPROTECT\00001629.REG
c:\recycler\NPROTECT\00001630.REG
c:\recycler\NPROTECT\00001631.REG
c:\recycler\NPROTECT\00001632.REG
c:\recycler\NPROTECT\00001633.REG
c:\recycler\NPROTECT\00001634.REG
c:\recycler\NPROTECT\00001635.REG
c:\recycler\NPROTECT\00001636.REG
c:\recycler\NPROTECT\00001637.REG
c:\recycler\NPROTECT\00001638.REG
c:\recycler\NPROTECT\00001639.REG
c:\recycler\NPROTECT\00001640.REG
c:\recycler\NPROTECT\00001641.REG
c:\recycler\NPROTECT\00001642.REG
c:\recycler\NPROTECT\00001643.REG
c:\recycler\NPROTECT\00001644.REG
c:\recycler\NPROTECT\00001645.REG
c:\recycler\NPROTECT\00001646.REG
c:\recycler\NPROTECT\00001647.REG
c:\recycler\NPROTECT\00001648.REG
c:\recycler\NPROTECT\00001649.REG
c:\recycler\NPROTECT\00001650.REG
c:\recycler\NPROTECT\00001651.REG
c:\recycler\NPROTECT\00001652.REG
c:\recycler\NPROTECT\00001653.REG
c:\recycler\NPROTECT\00001654.REG
c:\recycler\NPROTECT\00001655.REG
c:\recycler\NPROTECT\00001656.REG
c:\recycler\NPROTECT\00001657.REG
c:\recycler\NPROTECT\00001658.REG
c:\recycler\NPROTECT\00001659.REG
c:\recycler\NPROTECT\00001660.REG
c:\recycler\NPROTECT\00001661.REG
c:\recycler\NPROTECT\00001662.REG
c:\recycler\NPROTECT\00001663.REG
c:\recycler\NPROTECT\00001664.REG
c:\recycler\NPROTECT\00001665.REG
c:\recycler\NPROTECT\00001666.REG
c:\recycler\NPROTECT\00001667.REG
c:\recycler\NPROTECT\00001668.REG
c:\recycler\NPROTECT\00001669.REG
c:\recycler\NPROTECT\00001670.REG
c:\recycler\NPROTECT\00001671.REG
c:\recycler\NPROTECT\00001672.REG
c:\recycler\NPROTECT\00001673.REG
c:\recycler\NPROTECT\00001674.REG
c:\recycler\NPROTECT\00001675.REG
c:\recycler\NPROTECT\00001676.REG
c:\recycler\NPROTECT\00001677.REG
c:\recycler\NPROTECT\00001678.REG
c:\recycler\NPROTECT\00001679.REG
c:\recycler\NPROTECT\00001680.REG
c:\recycler\NPROTECT\00001681.REG
c:\recycler\NPROTECT\00001682.REG
c:\recycler\NPROTECT\00001683.REG
c:\recycler\NPROTECT\00001684.REG
c:\recycler\NPROTECT\00001685.REG
c:\recycler\NPROTECT\00001686.REG
c:\recycler\NPROTECT\00001687.REG
c:\recycler\NPROTECT\00001688.REG
c:\recycler\NPROTECT\00001689.REG
c:\recycler\NPROTECT\00001690.REG
c:\recycler\NPROTECT\00001691.REG
c:\recycler\NPROTECT\00001692.REG
c:\recycler\NPROTECT\00001693.REG
c:\recycler\NPROTECT\00001694.REG
c:\recycler\NPROTECT\00001695.REG
c:\recycler\NPROTECT\00001696.REG
c:\recycler\NPROTECT\00001697.REG
c:\recycler\NPROTECT\00001698.REG
c:\recycler\NPROTECT\00001699.REG
c:\recycler\NPROTECT\00001700.REG
c:\recycler\NPROTECT\00001701.REG
c:\recycler\NPROTECT\00001702.REG
c:\recycler\NPROTECT\00001703.REG
c:\recycler\NPROTECT\00001704.REG
c:\recycler\NPROTECT\00001705.REG
c:\recycler\NPROTECT\00001706.REG
c:\recycler\NPROTECT\00001707.REG
c:\recycler\NPROTECT\00001708.REG
c:\recycler\NPROTECT\00001709.REG
c:\recycler\NPROTECT\00001710.REG
c:\recycler\NPROTECT\00001711.REG
c:\recycler\NPROTECT\00001712.REG
c:\recycler\NPROTECT\00001713.REG
c:\recycler\NPROTECT\00001714.REG
c:\recycler\NPROTECT\00001715.REG
c:\recycler\NPROTECT\00001716.REG
c:\recycler\NPROTECT\00001717.REG
c:\recycler\NPROTECT\00001719.und
c:\recycler\NPROTECT\00001721.und
c:\recycler\NPROTECT\00001723.und
c:\recycler\NPROTECT\00001725.und
c:\recycler\NPROTECT\00001727.und
c:\recycler\NPROTECT\00001729.und
c:\recycler\NPROTECT\00001731.und
c:\recycler\NPROTECT\00001733.und
c:\recycler\NPROTECT\00001735.und
c:\recycler\NPROTECT\00001737.und
c:\recycler\NPROTECT\00001739.und
c:\recycler\NPROTECT\00001741.und
c:\recycler\NPROTECT\00001743.und
c:\recycler\NPROTECT\00001745.und
c:\recycler\NPROTECT\00001747.und
c:\recycler\NPROTECT\00001749.und
c:\recycler\NPROTECT\00001751.und
c:\recycler\NPROTECT\00001753.und
c:\recycler\NPROTECT\00001755.und
c:\recycler\NPROTECT\00001757.und
c:\recycler\NPROTECT\00001759.und
c:\recycler\NPROTECT\00001761.und
c:\recycler\NPROTECT\00001763.und
c:\recycler\NPROTECT\00001765.und
c:\recycler\NPROTECT\00001767.und
c:\recycler\NPROTECT\00001769.und
c:\recycler\NPROTECT\00001771.und
c:\recycler\NPROTECT\00001773.und
c:\recycler\NPROTECT\00001775.und
c:\recycler\NPROTECT\00001777.und
c:\recycler\NPROTECT\00001779.und
c:\recycler\NPROTECT\00001781.und
c:\recycler\NPROTECT\00001783.und
c:\recycler\NPROTECT\00001785.und
c:\recycler\NPROTECT\00001787.und
c:\recycler\NPROTECT\00001789.und
c:\recycler\NPROTECT\00001791.und
c:\recycler\NPROTECT\00001793.und
c:\recycler\NPROTECT\00001795.und
c:\recycler\NPROTECT\00001797.und
c:\recycler\NPROTECT\00001799.und
c:\recycler\NPROTECT\00001801.und
c:\recycler\NPROTECT\00001803.und
c:\recycler\NPROTECT\00001805.und
c:\recycler\NPROTECT\00001807.und
c:\recycler\NPROTECT\00001809.und
c:\recycler\NPROTECT\00001811.und
c:\recycler\NPROTECT\00001813.und
c:\recycler\NPROTECT\00001815.und
c:\recycler\NPROTECT\00001817.und
c:\recycler\NPROTECT\00001819.und
c:\recycler\NPROTECT\00001821.und
c:\recycler\NPROTECT\00001823.und
c:\recycler\NPROTECT\00001825.und
c:\recycler\NPROTECT\00001827.und
c:\recycler\NPROTECT\00001829.und
c:\recycler\NPROTECT\00001831.und
c:\recycler\NPROTECT\00001833.und
c:\recycler\NPROTECT\00001835.und
c:\recycler\NPROTECT\00001837.und
c:\recycler\NPROTECT\00001839.und
c:\recycler\NPROTECT\00001841.und
c:\recycler\NPROTECT\00001843.und
c:\recycler\NPROTECT\00001845.und
c:\recycler\NPROTECT\00001847.und
c:\recycler\NPROTECT\00001849.und
c:\recycler\NPROTECT\00001851.und
c:\recycler\NPROTECT\00001853.und
c:\recycler\NPROTECT\00001855.und
c:\recycler\NPROTECT\00001857.und
c:\recycler\NPROTECT\00001859.und
c:\recycler\NPROTECT\00001861.und
c:\recycler\NPROTECT\00001863.und
c:\recycler\NPROTECT\00001865.und
c:\recycler\NPROTECT\00001867.und
c:\recycler\NPROTECT\00001869.und
c:\recycler\NPROTECT\00001870.dll
c:\recycler\NPROTECT\00001872.und
c:\recycler\NPROTECT\00001874.und
c:\recycler\NPROTECT\00001876.dll
c:\recycler\NPROTECT\00001877.und
c:\recycler\NPROTECT\00001881.und
c:\recycler\NPROTECT\00001884.und
c:\recycler\NPROTECT\00001886.und
c:\recycler\NPROTECT\00001888.und
c:\recycler\NPROTECT\00001890.und
c:\recycler\NPROTECT\00001892.und
c:\recycler\NPROTECT\00001894.und
c:\recycler\NPROTECT\00001895.dat
c:\recycler\NPROTECT\00001896.scr
c:\recycler\NPROTECT\00001897.txt
c:\recycler\NPROTECT\00001898.DIS
c:\recycler\NPROTECT\00001899.grd
c:\recycler\NPROTECT\00001900.sig
c:\recycler\NPROTECT\00001901.spm
c:\recycler\NPROTECT\00001902.DIS
c:\recycler\NPROTECT\00001903.grd
c:\recycler\NPROTECT\00001904.sig
c:\recycler\NPROTECT\00002050.RPT
c:\recycler\NPROTECT\00002051.RPT
c:\recycler\NPROTECT\00002054.xml
c:\recycler\NPROTECT\00002056.XML
c:\recycler\NPROTECT\00002057.XML
c:\recycler\NPROTECT\00002058.XML
c:\recycler\NPROTECT\00002060.XML
c:\recycler\NPROTECT\00002074.8DW
c:\recycler\NPROTECT\00002075.DIF
c:\recycler\NPROTECT\00002076.H08
c:\recycler\NPROTECT\00002077.DIF
c:\recycler\NPROTECT\00002078.DIF
c:\recycler\NPROTECT\00002079.EEE
c:\recycler\NPROTECT\00002080.XER
c:\recycler\NPROTECT\00002081.HUW
c:\recycler\NPROTECT\00002082.-QO
c:\recycler\NPROTECT\00002083.131
c:\recycler\NPROTECT\00002084.DIF
c:\recycler\NPROTECT\00002085.DIF
c:\recycler\NPROTECT\00002086.gsg
c:\recycler\NPROTECT\00002087.KRG
c:\recycler\NPROTECT\00002088.XML
c:\recycler\NPROTECT\00002089.KRG
c:\recycler\NPROTECT\00002090.stt
c:\recycler\NPROTECT\00002091.krg
c:\recycler\NPROTECT\00002092.stt
c:\recycler\NPROTECT\00002093.dat
c:\recycler\NPROTECT\00002094.XML
c:\recycler\NPROTECT\00002095.KRG
c:\recycler\NPROTECT\00002096.XML
c:\recycler\NPROTECT\00002097.avc
c:\recycler\NPROTECT\00002098.KRG
c:\recycler\NPROTECT\00002099.XML
c:\recycler\NPROTECT\00002100.xml
c:\recycler\NPROTECT\00002101.PBV
c:\recycler\NPROTECT\00002102.xml
c:\recycler\NPROTECT\00002103.XML
c:\recycler\NPROTECT\00002104.stt
c:\recycler\NPROTECT\00002106.XML
c:\recycler\NPROTECT\00002107.stt
c:\recycler\NPROTECT\00002108.dat
c:\recycler\NPROTECT\00002109.XML
c:\recycler\NPROTECT\00002110.gsg
c:\recycler\NPROTECT\00002111.XML
c:\recycler\NPROTECT\00002112.avc
c:\recycler\NPROTECT\00002113.avc
c:\recycler\NPROTECT\00002114.avc
c:\recycler\NPROTECT\00002115.avc
c:\recycler\NPROTECT\00002120.lst
c:\recycler\NPROTECT\00002121.krg
c:\recycler\NPROTECT\00002122.KRG
c:\recycler\NPROTECT\00002123.KRG
c:\recycler\NPROTECT\00002124.KRG
c:\recycler\NPROTECT\00002126.XML
c:\recycler\NPROTECT\00002211.ecf
c:\recycler\NPROTECT\00002421.RPT
c:\recycler\NPROTECT\00002422.RPT
c:\recycler\NPROTECT\00002424.KLZ
c:\recycler\NPROTECT\00002425.xml
c:\recycler\NPROTECT\00002428.bin
c:\recycler\NPROTECT\00002430.XML
c:\recycler\NPROTECT\00002431.XML
c:\recycler\NPROTECT\00002432.XML
c:\recycler\NPROTECT\00002433.KLZ
c:\recycler\NPROTECT\00002434.XML
c:\recycler\NPROTECT\00002436.XML
c:\recycler\NPROTECT\00002451.12H
c:\recycler\NPROTECT\00002452.DIF
c:\recycler\NPROTECT\00002453.VJM
c:\recycler\NPROTECT\00002454.DIF
c:\recycler\NPROTECT\00002455.DIF
c:\recycler\NPROTECT\00002456.6E8
c:\recycler\NPROTECT\00002457.VZF
c:\recycler\NPROTECT\00002458.DIF
c:\recycler\NPROTECT\00002459.VXN
c:\recycler\NPROTECT\00002460.DIF
c:\recycler\NPROTECT\00002461.3KY
c:\recycler\NPROTECT\00002462.DIF
c:\recycler\NPROTECT\00002463.gsg
c:\recycler\NPROTECT\00002464.KRG
c:\recycler\NPROTECT\00002465.XML
c:\recycler\NPROTECT\00002466.KRG
c:\recycler\NPROTECT\00002467.stt
c:\recycler\NPROTECT\00002468.krg
c:\recycler\NPROTECT\00002469.stt
c:\recycler\NPROTECT\00002470.dat
c:\recycler\NPROTECT\00002471.XML
c:\recycler\NPROTECT\00002472.KRG
c:\recycler\NPROTECT\00002473.XML
c:\recycler\NPROTECT\00002474.lst
c:\recycler\NPROTECT\00002475.avc
c:\recycler\NPROTECT\00002476.avc
c:\recycler\NPROTECT\00002477.avc
c:\recycler\NPROTECT\00002478.avc
c:\recycler\NPROTECT\00002479.xml
c:\recycler\NPROTECT\00002480.xml
c:\recycler\NPROTECT\00002481.XML
c:\recycler\NPROTECT\00002482.stt
c:\recycler\NPROTECT\00002483.XML
c:\recycler\NPROTECT\00002484.kdz
c:\recycler\NPROTECT\00002485.KRG
c:\recycler\NPROTECT\00002487.dat
c:\recycler\NPROTECT\00002489.XML
c:\recycler\NPROTECT\00002490.stt
c:\recycler\NPROTECT\00002491.dat
c:\recycler\NPROTECT\00002492.XML
c:\recycler\NPROTECT\00002493.gsg
c:\recycler\NPROTECT\00002494.XML
c:\recycler\NPROTECT\00002495.avc
c:\recycler\NPROTECT\00002496.avc
c:\recycler\NPROTECT\00002500.krg
c:\recycler\NPROTECT\00002501.KRG
c:\recycler\NPROTECT\00002502.KRG
c:\recycler\NPROTECT\00002503.KRG
c:\recycler\NPROTECT\00002504.KRG
c:\recycler\NPROTECT\00002506.XML
c:\recycler\NPROTECT\00002507.XML
c:\recycler\NPROTECT\00002510.kfb
c:\recycler\NPROTECT\00002552.ecf
c:\recycler\NPROTECT\00002802.RPT
c:\recycler\NPROTECT\00002803.RPT
c:\recycler\NPROTECT\00002805.xml
c:\recycler\NPROTECT\00002806.XML
c:\recycler\NPROTECT\00002808.ecf
c:\recycler\NPROTECT\00002809.XML
c:\recycler\NPROTECT\00002817.DVA
c:\recycler\NPROTECT\00002818.DIF
c:\recycler\NPROTECT\00002819.4O9
c:\recycler\NPROTECT\00002820.DIF
c:\recycler\NPROTECT\00002821.DIF
c:\recycler\NPROTECT\00002822.gsg
c:\recycler\NPROTECT\00002823.KRG
c:\recycler\NPROTECT\00002824.XML
c:\recycler\NPROTECT\00002825.KRG
c:\recycler\NPROTECT\00002826.stt
c:\recycler\NPROTECT\00002827.krg
c:\recycler\NPROTECT\00002828.stt
c:\recycler\NPROTECT\00002829.dat
c:\recycler\NPROTECT\00002830.XML
c:\recycler\NPROTECT\00002831.KRG
c:\recycler\NPROTECT\00002832.XML
c:\recycler\NPROTECT\00002833.avc
c:\recycler\NPROTECT\00002834.avc
c:\recycler\NPROTECT\00002835.KRG
c:\recycler\NPROTECT\00002836.XML
c:\recycler\NPROTECT\00002837.kfb
c:\recycler\NPROTECT\00002838.KRG
c:\recycler\NPROTECT\00002839.XML
c:\recycler\NPROTECT\00002840.kdz
c:\recycler\NPROTECT\00002841.xml
c:\recycler\NPROTECT\00002842.xml
c:\recycler\NPROTECT\00002843.XML
c:\recycler\NPROTECT\00002844.stt
c:\recycler\NPROTECT\00002846.XML
c:\recycler\NPROTECT\00002847.stt
c:\recycler\NPROTECT\00002848.dat
c:\recycler\NPROTECT\00002849.XML
c:\recycler\NPROTECT\00002850.gsg
c:\recycler\NPROTECT\00002851.krg
c:\recycler\NPROTECT\00002852.KRG
c:\recycler\NPROTECT\00002853.KRG
c:\recycler\NPROTECT\00002855.XML
c:\recycler\NPROTECT\00003100.DAT
c:\recycler\NPROTECT\00003101.dat
c:\recycler\NPROTECT\00003102.dat
c:\recycler\NPROTECT\00003103.sys
c:\recycler\NPROTECT\00003104.vxd
c:\recycler\NPROTECT\00003105.dll
c:\recycler\NPROTECT\00003106.grd
c:\recycler\NPROTECT\00003107.sig
c:\recycler\NPROTECT\00003108.DAT
c:\recycler\NPROTECT\00003109.dat
c:\recycler\NPROTECT\00003140.ecf
c:\recycler\NPROTECT\00003181.RPT
c:\recycler\NPROTECT\00003182.RPT
c:\recycler\NPROTECT\00003184.xml
c:\recycler\NPROTECT\00003185.XML
c:\recycler\NPROTECT\00003187.XML
c:\recycler\NPROTECT\00003195.Z1A
c:\recycler\NPROTECT\00003196.DIF
c:\recycler\NPROTECT\00003197.KM-
c:\recycler\NPROTECT\00003198.DIF
c:\recycler\NPROTECT\00003199.DIF
c:\recycler\NPROTECT\00003200.gsg
c:\recycler\NPROTECT\00003201.KRG
c:\recycler\NPROTECT\00003202.XML
c:\recycler\NPROTECT\00003203.KRG
c:\recycler\NPROTECT\00003204.stt
c:\recycler\NPROTECT\00003205.krg
c:\recycler\NPROTECT\00003206.stt
c:\recycler\NPROTECT\00003207.dat
c:\recycler\NPROTECT\00003208.XML
c:\recycler\NPROTECT\00003209.xml
c:\recycler\NPROTECT\00003210.xml
c:\recycler\NPROTECT\00003211.XML
c:\recycler\NPROTECT\00003212.stt
c:\recycler\NPROTECT\00003214.XML
c:\recycler\NPROTECT\00003215.stt
c:\recycler\NPROTECT\00003216.dat
c:\recycler\NPROTECT\00003217.XML
c:\recycler\NPROTECT\00003218.gsg
c:\recycler\NPROTECT\00003219.krg
c:\recycler\NPROTECT\00003220.KRG
c:\recycler\NPROTECT\00003221.KRG
c:\recycler\NPROTECT\00003223.XML
c:\recycler\NPROTECT\00003224.dat
c:\recycler\NPROTECT\00003225.dat
c:\recycler\NPROTECT\00003232.ecf
c:\recycler\NPROTECT\00003234.RPT
c:\recycler\NPROTECT\00003259.DB-
c:\recycler\NPROTECT\00003260.DB-
c:\recycler\NPROTECT\00003262.DB-
c:\recycler\NPROTECT\00003267.ecf
c:\recycler\NPROTECT\00003274.edb
c:\recycler\NPROTECT\00003336.DIC
c:\recycler\NPROTECT\00003342.XML
c:\recycler\NPROTECT\00003345.PLK
c:\recycler\NPROTECT\00003348.RPT
c:\recycler\NPROTECT\00003349.RPT
c:\recycler\NPROTECT\00003350.xml
c:\recycler\NPROTECT\00003351.RPT
c:\recycler\NPROTECT\00003352.RPT
c:\recycler\NPROTECT\00003353.RPT
c:\recycler\NPROTECT\00003355.LNK
c:\recycler\NPROTECT\00003356.LNK
c:\recycler\NPROTECT\00003357.LNK
c:\recycler\NPROTECT\00003358.LNK
c:\recycler\NPROTECT\00003359.XML
c:\recycler\NPROTECT\00003360.KLZ
c:\recycler\NPROTECT\00003361.XML
c:\recycler\NPROTECT\00003362.XML
c:\recycler\NPROTECT\00003363.LNK
c:\recycler\NPROTECT\00003364.LNK
c:\recycler\NPROTECT\00003365.LNK
c:\recycler\NPROTECT\00003366.LNK
c:\recycler\NPROTECT\00003383.LNK
c:\recycler\NPROTECT\00003384.LNK
c:\recycler\NPROTECT\00003389.DOC
c:\recycler\NPROTECT\00003391._PD
c:\recycler\NPROTECT\00003392.DIF
c:\recycler\NPROTECT\00003394.-DN
c:\recycler\NPROTECT\00003395.DIF
c:\recycler\NPROTECT\00003396.DIF
c:\recycler\NPROTECT\00003397.GWA
c:\recycler\NPROTECT\00003398.LKM
c:\recycler\NPROTECT\00003399.WW_
c:\recycler\NPROTECT\00003400.1PK
c:\recycler\NPROTECT\00003401.T1M
c:\recycler\NPROTECT\00003402.BYR
c:\recycler\NPROTECT\00003403.KT9
c:\recycler\NPROTECT\00003404.LF-
c:\recycler\NPROTECT\00003405.7MR
c:\recycler\NPROTECT\00003406.3LZ
c:\recycler\NPROTECT\00003407.DIF
c:\recycler\NPROTECT\00003408.ini
c:\recycler\NPROTECT\00003409.ini
c:\recycler\NPROTECT\00003410.gsg
c:\recycler\NPROTECT\00003411.KRG
c:\recycler\NPROTECT\00003412.XML
c:\recycler\NPROTECT\00003413.KRG
c:\recycler\NPROTECT\00003414.stt
c:\recycler\NPROTECT\00003415.krg
c:\recycler\NPROTECT\00003416.stt
c:\recycler\NPROTECT\00003417.dat
c:\recycler\NPROTECT\00003418.XML
c:\recycler\NPROTECT\00003420.xml
c:\recycler\NPROTECT\00003421.xml
c:\recycler\NPROTECT\00003422.XML
c:\recycler\NPROTECT\00003423.stt
c:\recycler\NPROTECT\00003425.XML
c:\recycler\NPROTECT\00003426.stt
c:\recycler\NPROTECT\00003427.dat
c:\recycler\NPROTECT\00003428.XML
c:\recycler\NPROTECT\00003429.gsg
c:\recycler\NPROTECT\00003430.XML
c:\recycler\NPROTECT\00003431.avc
c:\recycler\NPROTECT\00003432.avc
c:\recycler\NPROTECT\00003433.avc
c:\recycler\NPROTECT\00003434.avc
c:\recycler\NPROTECT\00003435.avc
c:\recycler\NPROTECT\00003436.avc
c:\recycler\NPROTECT\00003437.avc
c:\recycler\NPROTECT\00003438.avc
c:\recycler\NPROTECT\00003439.avc
c:\recycler\NPROTECT\00003440.set
c:\recycler\NPROTECT\00003442.krg
c:\recycler\NPROTECT\00003443.KRG
c:\recycler\NPROTECT\00003444.KRG
c:\recycler\NPROTECT\00003445.KRG
c:\recycler\NPROTECT\00003447.XML
c:\recycler\NPROTECT\00003450.LOG
c:\recycler\NPROTECT\00003451.log
c:\recycler\NPROTECT\00003452.log
c:\recycler\NPROTECT\00003453.log
c:\recycler\NPROTECT\00003459.LNK
c:\recycler\NPROTECT\00003460.dat
c:\recycler\NPROTECT\00003461.LNK
c:\recycler\NPROTECT\00003465.log
c:\recycler\NPROTECT\00003466.log
c:\recycler\NPROTECT\00003467.log
c:\recycler\NPROTECT\00003468.log
c:\recycler\NPROTECT\00003469.log
c:\recycler\NPROTECT\00003494.XML
c:\recycler\NPROTECT\00003495.XML
c:\recycler\NPROTECT\00003496.XML
c:\recycler\NPROTECT\00003497.rbf
c:\recycler\NPROTECT\00003498.rbf
c:\recycler\NPROTECT\00003499.rbf
c:\recycler\NPROTECT\00003500.rbf
c:\recycler\NPROTECT\00003501.rbf
c:\recycler\NPROTECT\00003502.rbf
c:\recycler\NPROTECT\00003503.rbs
c:\recycler\NPROTECT\00003504.ipi
c:\recycler\NPROTECT\00003524.dat
c:\recycler\NPROTECT\00003526.DIC
c:\recycler\NPROTECT\00003527.LNK
c:\recycler\NPROTECT\00003528.LNK
c:\recycler\NPROTECT\00003529.LNK
c:\recycler\NPROTECT\00003530.LNK
c:\recycler\NPROTECT\00003531.LNK
c:\recycler\NPROTECT\00003532.LNK
c:\recycler\NPROTECT\00003536.DOC
c:\recycler\NPROTECT\00003636.ini
c:\recycler\NPROTECT\00003637.ini
c:\recycler\NPROTECT\00003638.dat
c:\recycler\NPROTECT\00003641.log
c:\recycler\NPROTECT\00003644.XML
c:\recycler\NPROTECT\00003646.ini
c:\recycler\NPROTECT\00003647.ini
c:\recycler\NPROTECT\00003648.dat
c:\recycler\NPROTECT\00003649.dat
c:\recycler\NPROTECT\00003651.LNK
c:\recycler\NPROTECT\00003652.dat
c:\recycler\NPROTECT\00003653.LNK
c:\recycler\NPROTECT\00003675.XML
c:\recycler\NPROTECT\00003677.ini
c:\recycler\NPROTECT\00003678.ini
c:\recycler\NPROTECT\00003679.dat
c:\recycler\NPROTECT\00003680.dat
c:\recycler\NPROTECT\00003684.PLK
c:\recycler\NPROTECT\00003686.dat
c:\recycler\NPROTECT\00003687.dat
c:\recycler\NPROTECT\00003695.ecf
c:\recycler\NPROTECT\00003705.KLZ
c:\recycler\NPROTECT\00003706.xml
c:\recycler\NPROTECT\00003710.RPT
c:\recycler\NPROTECT\00003712.ini
c:\recycler\NPROTECT\00003713.ini
c:\recycler\NPROTECT\00003714.dat
c:\recycler\NPROTECT\00003716.LOG
c:\recycler\NPROTECT\00003717.log
c:\recycler\NPROTECT\00003718.log
c:\recycler\NPROTECT\00003719.XML
c:\recycler\NPROTECT\00003721.KLZ
c:\recycler\NPROTECT\00003722.XML
c:\recycler\NPROTECT\00003723.XML
c:\recycler\NPROTECT\00003730.avc
c:\recycler\NPROTECT\00003732.avc
c:\recycler\NPROTECT\00003737.DDT
c:\recycler\NPROTECT\00003738.DIF
c:\recycler\NPROTECT\00003739.LER
c:\recycler\NPROTECT\00003740.DIF
c:\recycler\NPROTECT\00003741.DIF
c:\recycler\NPROTECT\00003742.ANP
c:\recycler\NPROTECT\00003743.FTF
c:\recycler\NPROTECT\00003744.4X2
c:\recycler\NPROTECT\00003745.ZO0
c:\recycler\NPROTECT\00003746.DHW
c:\recycler\NPROTECT\00003747.DIF
c:\recycler\NPROTECT\00003748.gsg
c:\recycler\NPROTECT\00003749.KRG
c:\recycler\NPROTECT\00003750.XML
c:\recycler\NPROTECT\00003751.KRG
c:\recycler\NPROTECT\00003752.stt
c:\recycler\NPROTECT\00003753.krg
c:\recycler\NPROTECT\00003754.stt
c:\recycler\NPROTECT\00003755.dat
c:\recycler\NPROTECT\00003756.XML
c:\recycler\NPROTECT\00003757.KRG
c:\recycler\NPROTECT\00003758.XML
c:\recycler\NPROTECT\00003759.set
c:\recycler\NPROTECT\00003760.avc
c:\recycler\NPROTECT\00003761.avc
c:\recycler\NPROTECT\00003762.avc
c:\recycler\NPROTECT\00003763.avc
c:\recycler\NPROTECT\00003764.avc
c:\recycler\NPROTECT\00003765.avc
c:\recycler\NPROTECT\00003766.avc
c:\recycler\NPROTECT\00003767.avc
c:\recycler\NPROTECT\00003768.avc
c:\recycler\NPROTECT\00003769.xml
c:\recycler\NPROTECT\00003770.xml
c:\recycler\NPROTECT\00003771.XML
c:\recycler\NPROTECT\00003772.stt
c:\recycler\NPROTECT\00003774.XML
c:\recycler\NPROTECT\00003775.stt
c:\recycler\NPROTECT\00003776.dat
c:\recycler\NPROTECT\00003777.XML
c:\recycler\NPROTECT\00003778.gsg
c:\recycler\NPROTECT\00003779.XML
c:\recycler\NPROTECT\00003780.avc
c:\recycler\NPROTECT\00003781.avc
c:\recycler\NPROTECT\00003782.avc
c:\recycler\NPROTECT\00003786.krg
c:\recycler\NPROTECT\00003787.KRG
c:\recycler\NPROTECT\00003788.KRG
c:\recycler\NPROTECT\00003789.KRG
c:\recycler\NPROTECT\00003791.XML
c:\recycler\NPROTECT\00003793.LNK
c:\recycler\NPROTECT\00003794.LNK
c:\recycler\NPROTECT\00003795.LNK
c:\recycler\NPROTECT\00003796.exe
c:\recycler\NPROTECT\00003797.exe
c:\recycler\NPROTECT\00003798.exe
c:\recycler\NPROTECT\00003799.exe
c:\recycler\NPROTECT\00003800.dll
c:\recycler\NPROTECT\00003801.exe
c:\recycler\NPROTECT\00003802.exe
c:\recycler\NPROTECT\00003803.img
c:\recycler\NPROTECT\00003804.ICO
c:\recycler\NPROTECT\00003805.dll
c:\recycler\NPROTECT\00003806.mst
c:\recycler\NPROTECT\00003807.cfg
c:\recycler\NPROTECT\00003808.chm
c:\recycler\NPROTECT\00003809.txt
c:\recycler\NPROTECT\00003810.dll
c:\recycler\NPROTECT\00003811.DLL
c:\recycler\NPROTECT\00003814.exe
c:\recycler\NPROTECT\00003817.sys
c:\recycler\NPROTECT\00003820.ini
c:\recycler\NPROTECT\00003821.ini
c:\recycler\NPROTECT\00003822.dat
c:\recycler\NPROTECT\00003823.log
c:\recycler\NPROTECT\00003824.log
c:\recycler\NPROTECT\00003829.DB-
c:\recycler\NPROTECT\00003830.DB-
c:\recycler\NPROTECT\00003831.DB-
c:\recycler\NPROTECT\00003832.log
c:\recycler\NPROTECT\00003833.log
c:\recycler\NPROTECT\00003834.DB-
c:\recycler\NPROTECT\00003835.log
c:\recycler\NPROTECT\00003836.log
c:\recycler\NPROTECT\00003837.DB-
c:\recycler\NPROTECT\00003838
c:\recycler\NPROTECT\00003839.fnm
c:\recycler\NPROTECT\00003840.frq
c:\recycler\NPROTECT\00003841.prx
c:\recycler\NPROTECT\00003842.fdx
c:\recycler\NPROTECT\00003843.fdt
c:\recycler\NPROTECT\00003844.tii
c:\recycler\NPROTECT\00003845.tis
c:\recycler\NPROTECT\00003846.f0
c:\recycler\NPROTECT\00003847.f1
c:\recycler\NPROTECT\00003848.f2
c:\recycler\NPROTECT\00003849.f3
c:\recycler\NPROTECT\00003850.f4
c:\recycler\NPROTECT\00003851.f5
c:\recycler\NPROTECT\00003852.f6
c:\recycler\NPROTECT\00003853.f7
c:\recycler\NPROTECT\00003854.f8
c:\recycler\NPROTECT\00003855.f9
c:\recycler\NPROTECT\00003856.f10
c:\recycler\NPROTECT\00003857.f11
c:\recycler\NPROTECT\00003858.f12
c:\recycler\NPROTECT\00003859.f13
c:\recycler\NPROTECT\00003860.f14
c:\recycler\NPROTECT\00003861.f15
c:\recycler\NPROTECT\00003862.f16
c:\recycler\NPROTECT\00003863.f17
c:\recycler\NPROTECT\00003864.f18
c:\recycler\NPROTECT\00003865.f19
c:\recycler\NPROTECT\00003866.f20
c:\recycler\NPROTECT\00003867.f21
c:\recycler\NPROTECT\00003868.f22
c:\recycler\NPROTECT\00003869.f23
c:\recycler\NPROTECT\00003870.f24
c:\recycler\NPROTECT\00003871.f25
c:\recycler\NPROTECT\00003872.f26
c:\recycler\NPROTECT\00003873.f27
c:\recycler\NPROTECT\00003874.f28
c:\recycler\NPROTECT\00003875.f29
c:\recycler\NPROTECT\00003876.f30
c:\recycler\NPROTECT\00003877.f31
c:\recycler\NPROTECT\00003878.f32
c:\recycler\NPROTECT\00003879.f33
c:\recycler\NPROTECT\00003880.f34
c:\recycler\NPROTECT\00003881.f35
c:\recycler\NPROTECT\00003882.f36
c:\recycler\NPROTECT\00003883.f37
c:\recycler\NPROTECT\00003884.f38
c:\recycler\NPROTECT\00003885.f39
c:\recycler\NPROTECT\00003886.f40
c:\recycler\NPROTECT\00003887.f41
c:\recycler\NPROTECT\00003888.f42
c:\recycler\NPROTECT\00003889.f43
c:\recycler\NPROTECT\00003890.f44
c:\recycler\NPROTECT\00003891.f45
c:\recycler\NPROTECT\00003892.f46
c:\recycler\NPROTECT\00003893.f47
c:\recycler\NPROTECT\00003894.f48
c:\recycler\NPROTECT\00003895.f49
c:\recycler\NPROTECT\00003896.f50
c:\recycler\NPROTECT\00003897.f51
c:\recycler\NPROTECT\00003898.f52
c:\recycler\NPROTECT\00003899.f53
c:\recycler\NPROTECT\00003900.f54
c:\recycler\NPROTECT\00003901.f55
c:\recycler\NPROTECT\00003902.f56
c:\recycler\NPROTECT\00003903.f57
c:\recycler\NPROTECT\00003904.f58
c:\recycler\NPROTECT\00003905.f59
c:\recycler\NPROTECT\00003906.f60
c:\recycler\NPROTECT\00003907.f61
c:\recycler\NPROTECT\00003908.f62
c:\recycler\NPROTECT\00003909.f63
c:\recycler\NPROTECT\00003910.f64
c:\recycler\NPROTECT\00003911.f65
c:\recycler\NPROTECT\00003912.f66
c:\recycler\NPROTECT\00003913.f67
c:\recycler\NPROTECT\00003914.f68
c:\recycler\NPROTECT\00003915.f69
c:\recycler\NPROTECT\00003916.f70
c:\recycler\NPROTECT\00003917.f71
c:\recycler\NPROTECT\00003918.f72
c:\recycler\NPROTECT\00003919.f73
c:\recycler\NPROTECT\00003920.f74
c:\recycler\NPROTECT\00003921.f75
c:\recycler\NPROTECT\00003922.f76
c:\recycler\NPROTECT\00003923
c:\recycler\NPROTECT\00003924.cfs
c:\recycler\NPROTECT\00003925.del
c:\recycler\NPROTECT\00003926
c:\recycler\NPROTECT\00003927.DB-
c:\recycler\NPROTECT\00003928.DB-
c:\recycler\NPROTECT\00003929.DB-
c:\recycler\NPROTECT\00003930.DB-
c:\recycler\NPROTECT\00003931.DB-
c:\recycler\NPROTECT\00003932.DB-
c:\recycler\NPROTECT\00003933.DB-
c:\recycler\NPROTECT\00003934.DB-
c:\recycler\NPROTECT\00003935.DB-
c:\recycler\NPROTECT\00003936.DB-
c:\recycler\NPROTECT\00003937.DB-
c:\recycler\NPROTECT\00003938.DB-
c:\recycler\NPROTECT\00003939.DB-
c:\recycler\NPROTECT\00003940.DB-
c:\recycler\NPROTECT\00003941.DB-
c:\recycler\NPROTECT\00003942.DB-
c:\recycler\NPROTECT\00003943.DB-
c:\recycler\NPROTECT\00003944.DB-
c:\recycler\NPROTECT\00003945.DB-
c:\recycler\NPROTECT\00003946.DB-
c:\recycler\NPROTECT\00003947.DB-
c:\recycler\NPROTECT\00003948.DB-
c:\recycler\NPROTECT\00003949.DB-
c:\recycler\NPROTECT\00003950.DB-
c:\recycler\NPROTECT\00003951.DB-
c:\recycler\NPROTECT\00003952.DB-
c:\recycler\NPROTECT\00003953.DB-
c:\recycler\NPROTECT\00003954.DB-
c:\recycler\NPROTECT\00003955.DB-
c:\recycler\NPROTECT\00003956.DB-
c:\recycler\NPROTECT\00003957.DB-
c:\recycler\NPROTECT\00003958.DB-
c:\recycler\NPROTECT\00003959.DB-
c:\recycler\NPROTECT\00003960.DB-
c:\recycler\NPROTECT\00003961.DB-
c:\recycler\NPROTECT\00003962.DB-
c:\recycler\NPROTECT\00003963.DB-
c:\recycler\NPROTECT\00003964.DB-
c:\recycler\NPROTECT\00003965.DB-
c:\recycler\NPROTECT\00003966.DB-
c:\recycler\NPROTECT\00003967.DB-
c:\recycler\NPROTECT\00003968.DB-
c:\recycler\NPROTECT\00003969.DB-
c:\recycler\NPROTECT\00003970.DB-
c:\recycler\NPROTECT\00003971.DB-
c:\recycler\NPROTECT\00003972.DB-
c:\recycler\NPROTECT\00003973.DB-
c:\recycler\NPROTECT\00003974.DB-
c:\recycler\NPROTECT\00003975.DB-
c:\recycler\NPROTECT\00003976.DB-
c:\recycler\NPROTECT\00003977.DB-
c:\recycler\NPROTECT\00003978.DB-
c:\recycler\NPROTECT\00003979.DB-
c:\recycler\NPROTECT\00003980.DB-
c:\recycler\NPROTECT\00003981.DB-
c:\recycler\NPROTECT\00003982.DB-
c:\recycler\NPROTECT\00003983.DB-
c:\recycler\NPROTECT\00003984.DB-
c:\recycler\NPROTECT\00003985.DB-
c:\recycler\NPROTECT\00003986.DB-
c:\recycler\NPROTECT\00003987.DB-
c:\recycler\NPROTECT\00003988.DB-
c:\recycler\NPROTECT\00003989.DB-
c:\recycler\NPROTECT\00003990.DB-
c:\recycler\NPROTECT\00003991.DB-
c:\recycler\NPROTECT\00003992.DB-
c:\recycler\NPROTECT\00003993.DB-
c:\recycler\NPROTECT\00003994.DB-
c:\recycler\NPROTECT\00003995.DB-
c:\recycler\NPROTECT\00003996.DB-
c:\recycler\NPROTECT\00003997.DB-
c:\recycler\NPROTECT\00003998.DB-
c:\recycler\NPROTECT\00003999.DB-
c:\recycler\NPROTECT\00004000.DB-
c:\recycler\NPROTECT\00004001.DB-
c:\recycler\NPROTECT\00004002.DB-
c:\recycler\NPROTECT\00004003.DB-
c:\recycler\NPROTECT\00004004.DB-
c:\recycler\NPROTECT\00004005.DB-
c:\recycler\NPROTECT\00004006.DB-
c:\recycler\NPROTECT\00004007.DB-
c:\recycler\NPROTECT\00004008.DB-
c:\recycler\NPROTECT\00004009.DB-
c:\recycler\NPROTECT\00004010.DB-
c:\recycler\NPROTECT\00004011.DB-
c:\recycler\NPROTECT\00004012.DB-
c:\recycler\NPROTECT\00004013.DB-
c:\recycler\NPROTECT\00004014.DB-
c:\recycler\NPROTECT\00004015.DB-
c:\recycler\NPROTECT\00004016.DB-
c:\recycler\NPROTECT\00004017.DB-
c:\recycler\NPROTECT\00004018.DB-
c:\recycler\NPROTECT\00004019.DB-
c:\recycler\NPROTECT\00004020.DB-
c:\recycler\NPROTECT\00004021.DB-
c:\recycler\NPROTECT\00004022.DB-
c:\recycler\NPROTECT\00004023.DB-
c:\recycler\NPROTECT\00004024.DB-
c:\recycler\NPROTECT\00004025.DB-
c:\recycler\NPROTECT\00004026.DB-
c:\recycler\NPROTECT\00004027.DB-
c:\recycler\NPROTECT\00004028.DB-
c:\recycler\NPROTECT\00004029.DB-
c:\recycler\NPROTECT\00004030.DB-
c:\recycler\NPROTECT\00004031.DB-
c:\recycler\NPROTECT\00004032.DB-
c:\recycler\NPROTECT\00004033.DB-
c:\recycler\NPROTECT\00004034.DB-
c:\recycler\NPROTECT\00004035.DB-
c:\recycler\NPROTECT\00004036.DB-
c:\recycler\NPROTECT\00004037.DB-
c:\recycler\NPROTECT\00004039.DB-
c:\recycler\NPROTECT\00004040.DB-
c:\recycler\NPROTECT\00004041.DB-
c:\recycler\NPROTECT\00004042.DB-
c:\recycler\NPROTECT\00004043.DB-
c:\recycler\NPROTECT\00004044.DB-
c:\recycler\NPROTECT\00004045.DB-
c:\recycler\NPROTECT\00004046.DB-
c:\recycler\NPROTECT\00004047.DB-
c:\recycler\NPROTECT\00004048.DB-
c:\recycler\NPROTECT\00004049.DB-
c:\recycler\NPROTECT\00004050.DB-
c:\recycler\NPROTECT\00004051.DB-
c:\recycler\NPROTECT\00004052.DB-
c:\recycler\NPROTECT\00004053.DB-
c:\recycler\NPROTECT\00004054.DB-
c:\recycler\NPROTECT\00004055.DB-
c:\recycler\NPROTECT\00004056.DB-
c:\recycler\NPROTECT\00004057.DB-
c:\recycler\NPROTECT\00004058.DB-
c:\recycler\NPROTECT\00004059.DB-
c:\recycler\NPROTECT\00004060.DB-
c:\recycler\NPROTECT\00004061.DB-
c:\recycler\NPROTECT\00004062.DB-
c:\recycler\NPROTECT\00004063.DB-
c:\recycler\NPROTECT\00004064.DB-
c:\recycler\NPROTECT\00004065.DB-
c:\recycler\NPROTECT\00004066.DB-
c:\recycler\NPROTECT\00004067.DB-
c:\recycler\NPROTECT\00004068.DB-
c:\recycler\NPROTECT\00004069.DB-
c:\recycler\NPROTECT\00004070.DB-
c:\recycler\NPROTECT\00004071.DB-
c:\recycler\NPROTECT\00004072.DB-
c:\recycler\NPROTECT\00004073.DB-
c:\recycler\NPROTECT\00004074.DB-
c:\recycler\NPROTECT\00004075.DB-
c:\recycler\NPROTECT\00004076.DB-
c:\recycler\NPROTECT\00004077.DB-
c:\recycler\NPROTECT\00004078.DB-
c:\recycler\NPROTECT\00004079.DB-
c:\recycler\NPROTECT\00004080.DB-
c:\recycler\NPROTECT\00004081.DB-
c:\recycler\NPROTECT\00004082.DB-
c:\recycler\NPROTECT\00004083.DB-
c:\recycler\NPROTECT\00004084.DB-
c:\recycler\NPROTECT\00004085.DB-
c:\recycler\NPROTECT\00004086.DB-
c:\recycler\NPROTECT\00004087.DB-
c:\recycler\NPROTECT\00004088.DB-
c:\recycler\NPROTECT\00004089.DB-
c:\recycler\NPROTECT\00004090.DB-
c:\recycler\NPROTECT\00004091.DB-
c:\recycler\NPROTECT\00004092.DB-
c:\recycler\NPROTECT\00004093.DB-
c:\recycler\NPROTECT\00004094.DB-
c:\recycler\NPROTECT\00004095.DB-
c:\recycler\NPROTECT\00004096.DB-
c:\recycler\NPROTECT\00004097.DB-
c:\recycler\NPROTECT\00004098.DB-
c:\recycler\NPROTECT\00004099.DB-
c:\recycler\NPROTECT\00004100.DB-
c:\recycler\NPROTECT\00004101.DB-
c:\recycler\NPROTECT\00004102.DB-
c:\recycler\NPROTECT\00004103.DB-
c:\recycler\NPROTECT\00004104.DB-
c:\recycler\NPROTECT\00004105.DB-
c:\recycler\NPROTECT\00004106.DB-
c:\recycler\NPROTECT\00004107.DB-
c:\recycler\NPROTECT\00004108.DB-
c:\recycler\NPROTECT\00004109.DB-
c:\recycler\NPROTECT\00004110.DB-
c:\recycler\NPROTECT\00004111.DB-
c:\recycler\NPROTECT\00004112.DB-
c:\recycler\NPROTECT\00004113.DB-
c:\recycler\NPROTECT\00004114.DB-
c:\recycler\NPROTECT\00004115.DB-
c:\recycler\NPROTECT\00004116.DB-
c:\recycler\NPROTECT\00004117.DB-
c:\recycler\NPROTECT\00004118.DB-
c:\recycler\NPROTECT\00004119.DB-
c:\recycler\NPROTECT\00004120.DB-
c:\recycler\NPROTECT\00004121.DB-
c:\recycler\NPROTECT\00004122.DB-
c:\recycler\NPROTECT\00004123.DB-
c:\recycler\NPROTECT\00004124.DB-
c:\recycler\NPROTECT\00004125.DB-
c:\recycler\NPROTECT\00004126.DB-
c:\recycler\NPROTECT\00004127.DB-
c:\recycler\NPROTECT\00004128.DB-
c:\recycler\NPROTECT\00004129.DB-
c:\recycler\NPROTECT\00004130.DB-
c:\recycler\NPROTECT\00004131.DB-
c:\recycler\NPROTECT\00004132.DB-
c:\recycler\NPROTECT\00004133.DB-
c:\recycler\NPROTECT\00004134.DB-
c:\recycler\NPROTECT\00004135.DB-
c:\recycler\NPROTECT\00004136.DB-
c:\recycler\NPROTECT\00004137.DB-
c:\recycler\NPROTECT\00004138.DB-
c:\recycler\NPROTECT\00004139.DB-
c:\recycler\NPROTECT\00004140.DB-
c:\recycler\NPROTECT\00004141.DB-
c:\recycler\NPROTECT\00004142.edb
c:\recycler\NPROTECT\00004143.DB-
c:\recycler\NPROTECT\00004144.DB-
c:\recycler\NPROTECT\00004145.DB-
c:\recycler\NPROTECT\00004146.DB-
c:\recycler\NPROTECT\00004147.DB-
c:\recycler\NPROTECT\00004148.DB-
c:\recycler\NPROTECT\00004149.DB-
c:\recycler\NPROTECT\00004150.DB-
c:\recycler\NPROTECT\00004151.DB-
c:\recycler\NPROTECT\00004152.DB-
c:\recycler\NPROTECT\00004153.DB-
c:\recycler\NPROTECT\00004154.DB-
c:\recycler\NPROTECT\00004155.DB-
c:\recycler\NPROTECT\00004156.DB-
c:\recycler\NPROTECT\00004157.DB-
c:\recycler\NPROTECT\00004158.DB-
c:\recycler\NPROTECT\00004159.DB-
c:\recycler\NPROTECT\00004160.DB-
c:\recycler\NPROTECT\00004161.DB-
c:\recycler\NPROTECT\00004400.ecf
c:\recycler\NPROTECT\00004440.RPT
c:\recycler\NPROTECT\00004441.RPT
c:\recycler\NPROTECT\00004443.xml
c:\recycler\NPROTECT\00004445.XML
c:\recycler\NPROTECT\00004446.XML
c:\recycler\NPROTECT\00004448.XML
c:\recycler\NPROTECT\00004459.K0R
c:\recycler\NPROTECT\00004460.DIF
c:\recycler\NPROTECT\00004461.LSU
c:\recycler\NPROTECT\00004462.DIF
c:\recycler\NPROTECT\00004463.DIF
c:\recycler\NPROTECT\00004464.GWO
c:\recycler\NPROTECT\00004465.NNX
c:\recycler\NPROTECT\00004466.DIF
c:\recycler\NPROTECT\00004467.gsg
c:\recycler\NPROTECT\00004468.KRG
c:\recycler\NPROTECT\00004469.XML
c:\recycler\NPROTECT\00004470.KRG
c:\recycler\NPROTECT\00004471.stt
c:\recycler\NPROTECT\00004472.krg
c:\recycler\NPROTECT\00004473.stt
c:\recycler\NPROTECT\00004474.dat
c:\recycler\NPROTECT\00004475.XML
c:\recycler\NPROTECT\00004476.KRG
c:\recycler\NPROTECT\00004477.XML
c:\recycler\NPROTECT\00004478.avc
c:\recycler\NPROTECT\00004479.avc
c:\recycler\NPROTECT\00004480.avc
c:\recycler\NPROTECT\00004481.xml
c:\recycler\NPROTECT\00004482.xml
c:\recycler\NPROTECT\00004483.XML
c:\recycler\NPROTECT\00004484.stt
c:\recycler\NPROTECT\00004486.XML
c:\recycler\NPROTECT\00004487.stt
c:\recycler\NPROTECT\00004488.dat
c:\recycler\NPROTECT\00004489.XML
c:\recycler\NPROTECT\00004490.gsg
c:\recycler\NPROTECT\00004491.XML
c:\recycler\NPROTECT\00004492.avc
c:\recycler\NPROTECT\00004493.avc
c:\recycler\NPROTECT\00004497.krg
c:\recycler\NPROTECT\00004498.KRG
c:\recycler\NPROTECT\00004499.KRG
c:\recycler\NPROTECT\00004500.KRG
c:\recycler\NPROTECT\00004502.XML
c:\recycler\NPROTECT\00004509.txt
c:\recycler\NPROTECT\00004681.grd
c:\recycler\NPROTECT\00004682.sig
c:\recycler\NPROTECT\00004683.wlt
c:\recycler\NPROTECT\00004684.wlt
c:\recycler\NPROTECT\00004685.grd
c:\recycler\NPROTECT\00004686.sig
c:\recycler\NPROTECT\00004687.grd
c:\recycler\NPROTECT\00004688.sig
c:\recycler\NPROTECT\00004689.wlt
c:\recycler\NPROTECT\00004690.dat
c:\recycler\NPROTECT\00004691.grd
c:\recycler\NPROTECT\00004692.sig
c:\recycler\NPROTECT\00004693.wlt
c:\recycler\NPROTECT\00004694.txt
c:\recycler\NPROTECT\00004695.grd
c:\recycler\NPROTECT\00004696.sig
c:\recycler\NPROTECT\00004697.dat
c:\recycler\NPROTECT\00004698.997
c:\recycler\NPROTECT\00004699.998
c:\recycler\NPROTECT\00004700.999
c:\recycler\NPROTECT\00004701.scr
c:\recycler\NPROTECT\00004702.txt
c:\recycler\NPROTECT\00004703.dis
c:\recycler\NPROTECT\00004704.grd
c:\recycler\NPROTECT\00004705.sig
c:\recycler\NPROTECT\00004729.REG
c:\recycler\NPROTECT\00004730.und
c:\recycler\NPROTECT\00004731.und
c:\recycler\NPROTECT\00004732.und
c:\recycler\NPROTECT\00004733.und
c:\recycler\NPROTECT\00004734.und
c:\recycler\NPROTECT\00004735.und
c:\recycler\NPROTECT\00004736.und
c:\recycler\NPROTECT\00004737.und
c:\recycler\NPROTECT\00004738.und
c:\recycler\NPROTECT\00004740.und
c:\recycler\NPROTECT\00004742.und
c:\recycler\NPROTECT\00004745.nsi
c:\recycler\NPROTECT\00004746.nsi
c:\recycler\NPROTECT\00004747.LNK
c:\recycler\NPROTECT\00004748.LNK
c:\recycler\NPROTECT\00004749.LNK
c:\recycler\NPROTECT\00004750.LNK
c:\recycler\NPROTECT\00004751.LNK
c:\recycler\NPROTECT\00004752.LNK
c:\recycler\NPROTECT\00004753.LNK
c:\recycler\NPROTECT\00004754.LNK
c:\recycler\NPROTECT\00004755.LNK
c:\recycler\NPROTECT\00004756.LNK
c:\recycler\NPROTECT\00004757.LNK
c:\recycler\NPROTECT\00004758.LNK
c:\recycler\NPROTECT\00004759.LNK
c:\recycler\NPROTECT\00004760.LNK
c:\recycler\NPROTECT\00004761.rbf
c:\recycler\NPROTECT\00004762.rbf
c:\recycler\NPROTECT\00004763.rbf
c:\recycler\NPROTECT\00004764.rbf
c:\recycler\NPROTECT\00004765.rbf
c:\recycler\NPROTECT\00004766.rbf
c:\recycler\NPROTECT\00004767.rbf
c:\recycler\NPROTECT\00004768.rbf
c:\recycler\NPROTECT\00004769.rbf
c:\recycler\NPROTECT\00004770.rbf
c:\recycler\NPROTECT\00004771.rbf
c:\recycler\NPROTECT\00004772.rbf
c:\recycler\NPROTECT\00004773.rbf
c:\recycler\NPROTECT\00004774.rbf
c:\recycler\NPROTECT\00004775.rbf
c:\recycler\NPROTECT\00004776.rbf
c:\recycler\NPROTECT\00004777.rbf
c:\recycler\NPROTECT\00004778.rbf
c:\recycler\NPROTECT\00004779.rbf
c:\recycler\NPROTECT\00004780.rbf
c:\recycler\NPROTECT\00004781.rbf
c:\recycler\NPROTECT\00004782.rbf
c:\recycler\NPROTECT\00004783.rbf
c:\recycler\NPROTECT\00004784.rbf
c:\recycler\NPROTECT\00004785.rbf
c:\recycler\NPROTECT\00004786.rbf
c:\recycler\NPROTECT\00004787.rbf
c:\recycler\NPROTECT\00004788.rbf
c:\recycler\NPROTECT\00004789.rbs
c:\recycler\NPROTECT\00004790.ipi
c:\recycler\NPROTECT\00004792.msi
c:\recycler\NPROTECT\00004793.rbf
c:\recycler\NPROTECT\00004794.rbs
c:\recycler\NPROTECT\00004795.ipi
c:\recycler\NPROTECT\00004796.msi
c:\recycler\NPROTECT\NPROTECT.LOG
c:\safetycenter\ie.Dll
c:\windows\msa.exe
c:\windows\system32\~.exe
c:\windows\system32\calc.dll
c:\windows\system32\dezifamu.dll
c:\windows\system32\iehelper.dll
c:\windows\system32\ipYT7o1v.dll
c:\windows\system32\lowsec\local.ds
c:\windows\system32\lowsec\user.ds
c:\windows\system32\lsp.dll
c:\windows\system32\moyofilu.dll
c:\windows\system32\ntSVc.ocx
c:\windows\system32\petemowa.dll
c:\windows\system32\resevine.dll
c:\windows\system32\temp.exe
c:\windows\twain_16.dll
Infected copy of c:\windows\system32\eventlog.dll was found and disinfected
Restored copy from - c:\windows\ServicePackFiles\i386\eventlog.dll
squidboy
OS : XP Home
Post by squidboy on Mon Nov 02, 2009 5:00 am
.....And finishing with this:
((((((((((((((((((((((((( Files Created from 2009-10-02 to 2009-11-02 )))))))))))))))))))))))))))))))
2009-11-02 02:38 . 2009-11-02 03:02 -------- d-----w- c:\program files\centipede
2009-11-02 02:01 . 2009-11-02 04:35 -------- d-----w- C:\SafetyCenter
2009-11-02 01:59 . 2009-11-02 01:59 96256 ----a-w- C:\cobch.exe
2009-11-02 01:59 . 2009-11-02 01:59 52224 ----a-w- C:\nmswcnsf.exe
2009-11-02 01:54 . 2009-11-02 02:25 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-11-02 01:53 . 2009-11-02 01:53 -------- d-----w- C:\Malwarebytes_Anti-Malware_1.41
2009-11-02 01:53 . 2009-11-02 01:53 7171690 ----a-w- C:\Malwarebytes_Anti-Malware_1.41.zip
2009-11-02 01:42 . 2009-11-02 02:12 -------- d-----w- c:\documents and settings\All Users\Application Data\msca
2009-10-26 06:11 . 2009-10-26 06:11 -------- d-----w- c:\documents and settings\Steve\Application Data\Malwarebytes
2009-10-26 06:11 . 2009-09-10 19:54 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-10-26 06:11 . 2009-10-26 06:11 -------- d-----w- c:\program files\maw
2009-10-26 06:11 . 2009-10-26 06:11 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2009-10-26 06:11 . 2009-09-10 19:53 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-11-02 04:41 . 2007-11-26 00:10 925184 --sha-w- c:\windows\system32\drivers\fidbox.idx
2009-11-02 04:41 . 2007-11-26 00:10 66651680 --sha-w- c:\windows\system32\drivers\fidbox.dat
2009-11-02 04:41 . 2007-11-26 00:10 136700 --sha-w- c:\windows\system32\drivers\fidbox2.idx
2009-11-02 04:41 . 2007-11-26 00:10 1335584 --sha-w- c:\windows\system32\drivers\fidbox2.dat
2009-11-02 02:32 . 2009-08-25 00:07 0 ----a-r- c:\windows\win32k.sys
2009-10-26 06:21 . 2007-03-08 13:38 -------- d-----w- c:\documents and settings\All Users\Application Data\1Click DVD Copy Pro
2009-10-26 05:16 . 2007-01-03 23:14 -------- d-----w- c:\documents and settings\Steve\Application Data\1clickPro
2009-10-26 04:41 . 2008-05-16 01:30 -------- d-----w- c:\program files\Yahoo!
2009-10-26 04:40 . 2007-07-01 05:01 -------- d-----w- c:\program files\Real
2009-10-26 04:40 . 2006-06-23 10:03 -------- d--h--w- c:\program files\InstallShield Installation Information
2009-10-26 04:25 . 2007-11-26 00:11 -------- d-----w- c:\documents and settings\All Users\Application Data\Kaspersky Lab
2009-10-25 23:20 . 2007-11-29 02:49 18816 ----a-w- c:\windows\system32\drivers\dvd43llh.sys
2009-10-25 23:20 . 2007-11-29 02:49 -------- d-----w- c:\program files\dvd43
2009-10-25 23:18 . 2007-01-03 22:51 -------- d-----w- c:\documents and settings\Steve\Application Data\Vso
2009-10-20 13:04 . 2007-03-09 22:44 -------- d-----w- c:\program files\IrfanView
2009-10-19 11:35 . 2006-07-26 21:11 -------- d-----w- c:\program files\Thumbs7
2009-10-16 03:22 . 2006-06-23 02:13 28232 ----a-w- c:\documents and settings\Steve\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-10-14 15:08 . 2008-12-20 02:47 108059 ----a-w- c:\windows\system32\drivers\klin.dat
2009-10-14 15:08 . 2008-12-20 02:47 95259 ----a-w- c:\windows\system32\drivers\klick.dat
2009-09-18 18:58 . 2007-03-10 02:12 -------- d-----w- c:\program files\PasswordSafe
2009-09-11 14:33 . 2002-06-25 21:42 133632 ----a-w- c:\windows\system32\msv1_0.dll
2009-09-04 20:45 . 2002-06-25 21:41 58880 ----a-w- c:\windows\system32\msasn1.dll
2009-08-29 07:36 . 2004-01-08 19:23 832512 ----a-w- c:\windows\system32\wininet.dll
2009-08-29 07:36 . 2004-08-04 07:56 78336 ----a-w- c:\windows\system32\ieencode.dll
2009-08-29 07:36 . 2002-06-25 21:37 17408 ------w- c:\windows\system32\corpol.dll
2009-08-26 08:16 . 2002-06-25 21:47 247326 ----a-w- c:\windows\system32\strmdll.dll
2009-08-20 19:09 . 2009-08-20 19:09 1193832 ----a-w- c:\windows\system32\FM20.DLL
2009-08-05 09:11 . 2002-06-25 21:42 204800 ----a-w- c:\windows\system32\mswebdvd.dll
2009-08-04 14:00 . 2002-06-25 21:43 2180352 ----a-w- c:\windows\system32\ntoskrnl.exe
2009-08-04 13:13 . 2002-06-25 21:43 2057728 ----a-w- c:\windows\system32\ntkrnlpa.exe
2009-08-02 02:05 . 2009-08-02 02:05 39424 --sha-w- c:\windows\system32\maligoha.dll
"Tracks Eraser Pro"="c:\program files\Acesoft\Tracks Eraser Pro\te.exe" [2009-06-24 1437504]
"SsAAD.exe"="c:\progra~1\Sony\SONICS~1\SsAAD.exe" [2006-05-08 81920]
"BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}"="c:\program files\Common Files\Ahead\Lib\NMBgMonitor.exe" [2007-06-21 148776]
"BTCLiveUpdate"="c:\program files\LiveUpdate\LiveUpdate.exe" [2004-03-08 430080]
"Window Washer"="c:\program files\Webroot\Washer\wwDisp.exe" [2007-11-26 1206600]
"CTSyncU.exe"="c:\program files\Creative\Sync Manager Unicode\CTSyncU.exe" [2007-07-17 868352]
"updateMgr"="c:\program files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe" [2006-03-30 313472]
"LightScribe Control Panel"="c:\program files\Common Files\LightScribe\LightScribeControlPanel.exe" [2009-06-17 2363392]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2003-10-06 5058560]
"HPDJ Taskbar Utility"="c:\windows\system32\spool\drivers\w32x86\3\hpztsb07.exe" [2006-01-06 188416]
"Share-to-Web Namespace Daemon"="c:\program files\Hewlett-Packard\HP Share-to-Web\hpgs2wnd.exe" [2002-04-17 69632]
"NvMediaCenter"="c:\windows\system32\NvMcTray.dll" [2003-10-06 49152]
"AVFX Engine"="c:\program files\Creative\Creative Live! Cam\VideoFX\StartFX.exe" [2006-10-20 20480]
"iRiver Updater"="\Updater.exe" [2004-07-01 212992]
"TkBellExe"="c:\program files\Common Files\Real\Update_OB\realsched.exe" [2007-07-01 185632]
"TrueImageMonitor.exe"="c:\program files\Acronis\TrueImageHome\TrueImageMonitor.exe" [2007-02-16 1169776]
"AcronisTimounterMonitor"="c:\program files\Acronis\TrueImageHome\TimounterMonitor.exe" [2007-02-16 1945960]
"Acronis Scheduler2 Service"="c:\program files\Common Files\Acronis\Schedule2\schedhlp.exe" [2007-02-16 149024]
"NeroFilterCheck"="c:\program files\Common Files\Ahead\Lib\NeroCheck.exe" [2007-06-11 153136]
"dvd43"="c:\program files\dvd43\dvd43_tray.exe" [2009-10-23 827904]
"HPHmon04"="c:\windows\system32\hphmon04.exe" [2006-01-06 348160]
"AVP"="c:\program files\Kaspersky Lab\Kaspersky Internet Security 2009\avp.exe" [2009-07-21 208616]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2009-01-05 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2009-01-06 290088]
"BCMSMMSG"="BCMSMMSG.exe" - c:\windows\BCMSMMSG.exe [2003-08-29 122880]
"nwiz"="nwiz.exe" - c:\windows\system32\nwiz.exe [2003-10-06 741376]
PGPtray.exe [2004-6-9 339968]
Device Detector 2.lnk - c:\program files\Olympus\DeviceDetector\DevDtct2.exe [2009-1-1 114688]
ymetray.lnk - c:\program files\Yahoo!\Yahoo! Music Jukebox\ymetray.exe [2006-8-14 49152]
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\KasperskyAntiVirus]
"EnableFirewall"= 0 (0x0)
"c:\\Program Files\\Yahoo!\\Yahoo! Music Jukebox\\YahooMusicEngine.exe"=
R0 klbg;Kaspersky Lab Boot Guard Driver;c:\windows\system32\drivers\klbg.sys [1/29/2008 5:29 PM 33808]
R2 BT848;AVerMedia, AVerTV WDM Video Capture;c:\windows\system32\drivers\BT848.sys [6/23/2006 5:02 AM 260072]
R2 BTTUNER;AVerMedia, AVerTV WDM TvTuner;c:\windows\system32\drivers\bttuner.sys [6/23/2006 5:05 AM 22016]
R2 BTXBAR;AVerMedia, AVerTV WDM Crossbar;c:\windows\system32\drivers\btxbar.sys [6/23/2006 5:05 AM 13312]
R2 IntuitUpdateService;Intuit Update Service;c:\program files\Common Files\Intuit\Update Service\IntuitUpdateService.exe [10/10/2008 4:45 AM 13088]
R2 wwEngineSvc;Window Washer Engine;c:\program files\Webroot\Washer\WasherSvc.exe [4/1/2008 7:41 PM 598856]
R3 KLFLTDEV;Kaspersky Lab KLFltDev;c:\windows\system32\drivers\klfltdev.sys [3/13/2008 6:02 PM 26640]
R3 klim5;Kaspersky Anti-Virus NDIS Filter;c:\windows\system32\drivers\klim5.sys [4/30/2008 5:06 PM 24592]
S3 EraserUtilDrv10741;EraserUtilDrv10741;\??\c:\program files\Common Files\Symantec Shared\EENGINE\EraserUtilDrv10741.sys --> c:\program files\Common Files\Symantec Shared\EENGINE\EraserUtilDrv10741.sys [?]
S3 RTLWUSB;NETGEAR WG111v2 54Mbps Wireless USB 2.0 Adapter NT Driver;c:\windows\system32\drivers\wg111v2.sys [3/27/2006 5:53 PM 167808]
*NewlyCreated* - CLASSPNP_2
*NewlyCreated* - MBR
*Deregistered* - CLASSPNP_2
*Deregistered* - mbr
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\{10880D85-AAD9-4558-ABDC-2AB1552D831F}]
"c:\program files\Common Files\LightScribe\LSRunOnce.exe"
2009-10-23 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-04-11 17:34]
mWindow Title =
IE: Add to Banner Ad Blocker - c:\program files\Kaspersky Lab\Kaspersky Internet Security 2009\ie_banner_deny.htm
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~2\Office10\EXCEL.EXE/3000
Trusted Zone: turbotax.com
BHO-{baf9faef-fcef-4512-81bd-4eb65c087b13} - petemowa.dll
HKCU-Run-BitTorrent - c:\program files\BitTorrent\bittorrent.exe
HKLM-Run-HPHUPD04 - c:\program files\HP Photosmart 11\hphinstall\UniPatch\hphupd04.exe
HKLM-Run-mosowofuz - c:\windows\system32\dezifamu.dll
HKLM-Run-pagosakojo - moyofilu.dll
SharedTaskScheduler-{f53d86e0-9fd8-4448-a79a-8b0737204c4b} - c:\windows\system32\dezifamu.dll
SSODL-detiwemit-{f53d86e0-9fd8-4448-a79a-8b0737204c4b} - c:\windows\system32\dezifamu.dll
AddRemove-HijackThis - I:\HijackThis.exe
Rootkit scan 2009-11-01 23:44
scanning hȋdden processes ...
scanning hȋdden files ...
hȋdden files: 0
- - - - - - - > 'winlogon.exe'(1232)
c:\windows\system32\RtlGina2.dll
- - - - - - - > 'lsass.exe'(1288)
c:\windows\system32\relog_ap.dll
- - - - - - - > 'explorer.exe'(3584)
c:\windows\system32\PGPhk.dll
c:\windows\system32\nView.dll
c:\windows\system32\nvwddi.dll
c:\windows\system32\browselc.dll
c:\program files\Common Files\Acronis\Schedule2\schedul2.exe
c:\program files\Common Files\LightScribe\LSSrvc.exe
c:\program files\Common Files\Microsoft Shared\VS7Debug\mdm.exe
c:\windows\system32\PGPserv.exe
c:\program files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
c:\program files\Windows Media Player\WMPNetwk.exe
c:\windows\system32\devldr32.exe
c:\windows\system32\RUNDLL32.EXE
C:\Updater.exe
c:\program files\Hewlett-Packard\HP Share-to-Web\hpgs2wnf.exe
c:\windows\system32\Rundll32.exe
c:\program files\Common Files\Ahead\Lib\NMIndexStoreSvr.exe
c:\documents and settings\Steve\Start Menu\Programs\Startup\PGPtray.exe
c:\program files\Common Files\Ahead\Lib\NMIndexingService.exe
Completion time: 2009-11-02 23:51 - machine was rebooted
ComboFix-quarantined-files.txt 2009-11-02 04:51
Pre-Run: 25,704,128,512 bytes free
Post-Run: 25,972,224,000 bytes free
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Home Edition" /fastdetect /NoExecute=OptIn
- - End Of File - - 2D5E642E5B08DA8B9AC9890886A7BA94
squidboy
OS : XP Home
Re: Antivirus System Pro help
Post by Dr Jay on Mon Nov 02, 2009 10:28 am
  1. Close any open browsers.
    File::
    C:\cobch.exe
    C:\nmswcnsf.exe
    Folder::
    C:\SafetyCenter
OS : Windows 10 Home & Pro
Post by squidboy on Mon Nov 02, 2009 1:07 pm
OK, I couldn't get far on this one. I was greeted with the same message I had before - telling me I need to close my "real time scanner" Kaspersky Internet Security. Just as in my earlier post when I tried to run combofix, Kaspersky is not present in either the taskbar or Windows Task Manager. I am greeted with the same warning from combofix related to continuing without exiting Kaspersky.
squidboy
OS : XP Home
Post by Dr Jay on Mon Nov 02, 2009 7:17 pm
Can it continue anyway, if not - please do the following:
Open Kaspersky from the Start Menu. Then, disable it in there.
I think it will want you to Pause protection - by user request. Those might be options.
Post by squidboy on Mon Nov 02, 2009 8:48 pm
Well, I ended up just uninstalling the Kaspersky program from my PC, since it kept thinking it was running. I had tried to open it & change the settings to shut it down, but the virus has a hold on opening .exe files, so I was unable to do that.
I ran the combofix after uninstalling and rebooting my PC (even though combofix STILL told me to close my Kaspersky - after uninstalling it!) I have a much smaller log file this time, which I am pasting here. I tried to do what you requested regarding the CFScript.txt, but I don't have the exe file named "combofix" anymore, since I renamed it "commy". I tried to drag the CFScript onto "commy" on my desktop, but all that does is start the combofix utility again.
That being said, here is my latest log file. Thanks for the help with this! (By the way, the "centipede" folder that you saw was created by me. I was trying to outsmart the virus by saving the malwarebyte's program in another folder named "centipede". I just wanted you to know that, so you don't think the virus had created something new.
ComboFix 09-10-30.01 - Steve 11/02/2009 14:40.2.1 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.1023.577 [GMT -5:00]
Running from: c:\documents and settings\Steve\desktop\commy.exe
AV: Kaspersky Internet Security *On-access scanning enabled* (Updated) {2C4D4BC6-0793-4956-A9F9-E252435469C0}
FW: Kaspersky Internet Security *enabled* {2C4D4BC6-0793-4956-A9F9-E252435469C0}
2009-11-02 04:21 . 2009-11-02 04:51 -------- d-----w- C:\commy
2009-08-29 07:36 . 2004-01-08 19:23 832512 ------w- c:\windows\system32\wininet.dll
*NewlyCreated* - PCIIDEX_2
*Deregistered* - PCIIDEX_2
mWindow Title =
Rootkit scan 2009-11-02 14:48
hȋdden files: 0
Stealth MBR rootkit/Mebroot/Sinowal detector 0.3.7 by Gmer, [You must be registered and logged in to see this link.]
device: opened successfully
user: MBR read successfully
called modules: ntoskrnl.exe catchme.sys CLASSPNP.SYS disk.sys dvd43llh.sys atapi.sys hal.dll pciide.sys PCIIDEX.SYS
kernel: MBR read successfully
user & kernel MBR OK
atapi.sys @ 0xF74D8000 0x17480 bytes
\Driver\atapi [ IRP_MJ_INTERNAL_DEVICE_CONTROL ] 0xF74DE7B4 != 0xF78C8B20 dvd43llh.sys
\Driver\atapi IRP hooks detected !
- - - - - - - > 'winlogon.exe'(836)
- - - - - - - > 'lsass.exe'(892)
- - - - - - - > 'explorer.exe'(3372)
Completion time: 2009-11-02 14:50
ComboFix-quarantined-files.txt 2009-11-02 19:50
ComboFix2.txt 2009-11-02 04:51
Pre-Run: 26,716,626,944 bytes free
Post-Run: 26,703,163,392 bytes free
- - End Of File - - 7664005C920FCF4381B1D800500EEB84
squidboy
OS : XP Home
Post by Dr Jay on Mon Nov 02, 2009 9:33 pm
Please do this for Kaspersky:
1. Click on the Start menu.
2. Select Run...
3. Type wbemtest and click OK
4. Connect to root\SecurityCenter
5. Click on Query
6. Type in SELECT * FROM AntiVirusProduct and click on Apply
If there is more than one result, it means there is more than one Antivirus program installed. Double click on each result to view the properties for that Antivirus product. Identify the product(s) installed and DELETE any records for an Antivirus software that is no longer installed.
    File::
    C:\cobch.exe
    C:\nmswcnsf.exe
    Folder::
    C:\SafetyCenter
Post by squidboy on Mon Nov 02, 2009 9:51 pm
OK - I just went through the steps you outlined. When it got to image #4 (as above), the query box was blank in the box below "Enter Query". I'll reboot the PC again & try to run combofix again. I just don't understand why it thinks Kasperksy is still installed when I uninstalled it.
With the CFScript.txt file......should I be copying that to my flash drive, where "combofix.exe" is? I don't have combofix.exe anywhere else, since I followed the instructions to rename it to commy.exe when I placed it onto the dektop.
Thanks!
squidboy
OS : XP Home
Post by Dr Jay on Tue Nov 03, 2009 12:50 am
It should be in the same location as commy.exe, then drag the CFScript over top of Commy.exe.
Post by squidboy on Tue Nov 03, 2009 2:20 am
OK, it still thinks I have the Kasperky program installed, but here are the results from combofix being run after CFScript is placed over commy.exe. Again, thank you very much for the help with this!
ComboFix 09-11-01.04 - Steve 11/02/2009 20:35.3.1 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.1023.578 [GMT -5]
Running from: c:\documents and settings\Steve\Desktop\commy.exe
Command switches used :: c:\documents and settings\Steve\Desktop\CFScript.txt
* Created a new restore point
FILE ::
"C:\cobch.exe"
"C:\nmswcnsf.exe"
C:\cobch.exe
C:\nmswcnsf.exe
c:\program files\centipede\changes.rtf
c:\program files\centipede\Languages\albanian.lng
c:\program files\centipede\Languages\arabic.lng
c:\program files\centipede\Languages\bosnian.lng
c:\program files\centipede\Languages\bulgarian.lng
c:\program files\centipede\Languages\catalan.lng
c:\program files\centipede\Languages\chineseSI.lng
c:\program files\centipede\Languages\chineseTR.lng
c:\program files\centipede\Languages\croatian.lng
c:\program files\centipede\Languages\czech.lng
c:\program files\centipede\Languages\danish.lng
c:\program files\centipede\Languages\dutch.lng
c:\program files\centipede\Languages\english.lng
c:\program files\centipede\Languages\estonian.lng
c:\program files\centipede\Languages\finnish.lng
c:\program files\centipede\Languages\french.lng
c:\program files\centipede\Languages\german.lng
c:\program files\centipede\Languages\greek.lng
c:\program files\centipede\Languages\hebrew.lng
c:\program files\centipede\Languages\hungarian.lng
c:\program files\centipede\Languages\italian.lng
c:\program files\centipede\Languages\korean.lng
c:\program files\centipede\Languages\latvian.lng
c:\program files\centipede\Languages\macedonian.lng
c:\program files\centipede\Languages\norwegian.lng
c:\program files\centipede\Languages\polish.lng
c:\program files\centipede\Languages\portugueseBR.lng
c:\program files\centipede\Languages\portuguesePT.lng
c:\program files\centipede\Languages\romanian.lng
c:\program files\centipede\Languages\russian.lng
c:\program files\centipede\Languages\serbian.lng
c:\program files\centipede\Languages\slovak.lng
c:\program files\centipede\Languages\slovenian.lng
c:\program files\centipede\Languages\spanish.lng
c:\program files\centipede\Languages\swedish.lng
c:\program files\centipede\Languages\turkish.lng
c:\program files\centipede\Languages\ukrainian.lng
c:\program files\centipede\license.txt
c:\program files\centipede\mbam.chm
c:\program files\centipede\mbam.dll
c:\program files\centipede\mbamext.dll
c:\program files\centipede\mbamgui.exe
c:\program files\centipede\mbamservice.exe
c:\program files\centipede\ssubtmr6.dll
c:\program files\centipede\unins000.dat
c:\program files\centipede\unins000.exe
c:\program files\centipede\unins000.msg
c:\program files\centipede\vbalsgrid6.ocx
c:\program files\centipede\zlib.dll
C:\SafetyCenter
c:\safetycenter\main.ico
c:\safetycenter\new.exe
c:\safetycenter\protector.exe
c:\safetycenter\sound.wav
c:\safetycenter\start.exe
c:\safetycenter\tst.exe
c:\safetycenter\uninstall.exe
((((((((((((((((((((((((( Files Created from 2009-10-03 to 2009-11-03 )))))))))))))))))))))))))))))))
2009-11-02 19:38 . 2009-11-02 19:50 -------- d-----w- C:\commy17334c
*NewlyCreated* - PROCEXP113
*Deregistered* - PROCEXP113
mWindow Title =
AddRemove-Malwarebytes' Anti-Malware_is1 - c:\program files\centipede\unins000.exe
Rootkit scan 2009-11-02 20:42
hȋdden files: 0
- - - - - - - > 'winlogon.exe'(808)
- - - - - - - > 'lsass.exe'(864)
Completion time: 2009-11-03 20:44
ComboFix-quarantined-files.txt 2009-11-03 01:44
ComboFix2.txt 2009-11-02 19:50
ComboFix3.txt 2009-11-02 04:51
Pre-Run: 26,686,025,728 bytes free
Post-Run: 26,671,898,624 bytes free
- - End Of File - - 834F45C1618DEC258D25200A598EB451
EDITED TO ADD:
I just tried to reinstall the malwarebyte's anti-malware again. It allowed me to reinstall it over the existing installation & actually allowed me to update it and run it! (I did not take any action after it was done with the scan.) So far, I am able to get to my homepage, etc. It SEEMS to be OK now, but I'll leave that up to you to decide! Smile The following is the log file that the malwarebyte program created:
Database version: 3090
11/2/2009 9:51:24 PM
mbam-log-2009-11-02 (21-51-17).txt
Objects scanned: 126893
Time elapsed: 4 minute(s), 30 second(s)
Registry Keys Infected: 7
Files Infected: 2
HKEY_CLASSES_ROOT\Interface\{051c9a06-fb08-486f-b09b-8b33b261637d} (Rogue.AntiVirus1) -> No action taken.
HKEY_CLASSES_ROOT\AppID\{29256442-2c14-48ca-b756-3ee0f8bdc774} (Rogue.AntiVirus1) -> No action taken.
HKEY_CLASSES_ROOT\CLSID\{459b6bf8-5320-4c41-8833-85baedf31086} (Trojan.FakeAlert) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ControlPanel\NameSpace\{459b6bf8-5320-4c41-8833-85baedf31086} (Trojan.FakeAlert) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Desktop\NameSpace\{459b6bf8-5320-4c41-8833-85baedf31086} (Trojan.FakeAlert) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{459b6bf8-5320-4c41-8833-85baedf31086} (Trojan.FakeAlert) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\NetworkNeighborhood\NameSpace\{459b6bf8-5320-4c41-8833-85baedf31086} (Trojan.FakeAlert) -> No action taken.
C:\WINDOWS\system32\maligoha.dll (Trojan.Vundo) -> No action taken.
C:\WINDOWS\win32k.sys (Trojan.Dropper) -> No action taken.
Last edited by squidboy on Tue Nov 03, 2009 3:01 am; edited 2 times in total (Reason for editing : Able to run malwarebyte program & get to internet)
squidboy
OS : XP Home
Post by Dr Jay on Tue Nov 03, 2009 3:47 am
Please post the Malwarebytes log.
Post by squidboy on Tue Nov 03, 2009 4:17 am
That what I had already posted in the reply above. Is there something else you were looking for instead of that?
squidboy
OS : XP Home
Post by Dr Jay on Tue Nov 03, 2009 5:33 am
Oops, I meant to say, please remove the selected items, then post the Malwarebytes log.
Post by squidboy on Tue Nov 03, 2009 6:22 am
Alrighty, DragonMaster Jay....here's the new log:
11/3/2009 1:03:05 AM
mbam-log-2009-11-03 (01-03-05).txt
Files Infected: 2
HKEY_CLASSES_ROOT\Interface\{051c9a06-fb08-486f-b09b-8b33b261637d} (Rogue.AntiVirus1) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\AppID\{29256442-2c14-48ca-b756-3ee0f8bdc774} (Rogue.AntiVirus1) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{459b6bf8-5320-4c41-8833-85baedf31086} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\ControlPanel\NameSpace\{459b6bf8-5320-4c41-8833-85baedf31086} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Desktop\NameSpace\{459b6bf8-5320-4c41-8833-85baedf31086} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\{459b6bf8-5320-4c41-8833-85baedf31086} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\NetworkNeighborhood\NameSpace\{459b6bf8-5320-4c41-8833-85baedf31086} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\maligoha.dll (Trojan.Vundo) -> Quarantined and deleted successfully.
C:\WINDOWS\win32k.sys (Trojan.Dropper) -> Quarantined and deleted successfully.
*** After that, I rebooted the PC and ran the malwarebyte's program again from the start. Here is the log from that.....
11/3/2009 1:18:52 AM
mbam-log-2009-11-03 (01-18-52).txt
Objects scanned: 126846
Time elapsed: 4 minute(s), 25 second(s)
squidboy
OS : XP Home
Post by Dr Jay on Tue Nov 03, 2009 6:41 am
Please use Internet Explorer and run a [You must be registered and logged in to see this link.]
  • Please check I agree with the Terms and Conditions and click Start Here
  • You will need to allow an Active X install for the scan to run.
  • Leave the scanning options at default and click Start Scan
Please post the results in your next reply.
Post by squidboy on Tue Nov 03, 2009 12:29 pm
Good morning DragonMaster Jay!
Here are the results from the bitdefender scan:
BitDefender Online Scanner
Scan report generated at: Tue, Nov 03, 2009 - 06:18:14
Scan path: A:\;C:\;D:\;E:\;F:\;G:\;H:\;
Statistics
Time
02:42:59
Files
581549
Folders
14829
Boot Sectors
0
Archives
10797
Packed Files
46050
Results
Identified Viruses
17
Infected Files
23
Suspect Files
3
Warnings
0
Disinfected
0
Deleted Files
30
Engines Info
Virus Definitions
4480894
Engine build
AVCORE v2.1 Windows/i386 11.0.0.26 (Oct 20 2009)
Scan plugins
17
Archive plugins
44
Unpack plugins
8
E-mail plugins
6
System plugins
4
Scan Settings
First Action
Disinfect
Second Action
Delete
Heuristics
Yes
Enable Warnings
Yes
Scanned Extensions
Exclude Extensions
Scan Emails
Yes
Scan Archives
Yes
Scan Packed
Yes
Scan Files
Yes
Scan Boot
Yes
Scanned File
Status
C:\Qoobox\Quarantine\C\Documents and Settings\Steve\ntuser.dll.vir
Infected with: Gen:Trojan.Heur.bu8@yOgv9dac
Disinfection failed
Deleted
C:\Qoobox\Quarantine\C\Documents and Settings\Steve\Start Menu\Programs\Startup\scandisk.dll.vir
Disinfection failed
Deleted
C:\Qoobox\Quarantine\C\DOCUME~1\Steve\LOCALS~1\Temp\svchost.exe.vir
Infected with: Gen:Trojan.Heur.Krap.bmX@aaF0edl
Disinfection failed
Deleted
C:\Qoobox\Quarantine\C\DOCUME~1\Steve\LOCALS~1\Temp\winlogon.exe.vir
Disinfection failed
Deleted
C:\Qoobox\Quarantine\C\ntldrs.vir
Infected with: Gen:Trojan.Heur.GM.0040020902
Disinfection failed
Deleted
C:\Qoobox\Quarantine\C\Program Files\wxwrmo\eefdsysguard.exe.vir
Infected with: Trojan.Generic.2615597
Deleted
C:\Qoobox\Quarantine\C\WINDOWS\msa.exe.vir
Infected with: Gen:Trojan.Heur.Renos.juW@b8IZqCn
Disinfection failed
Deleted
C:\Qoobox\Quarantine\C\WINDOWS\system32\calc.dll.vir
Disinfection failed
Deleted
C:\Qoobox\Quarantine\C\WINDOWS\system32\eventlog.dll.vir
Infected with: Trojan.Generic.2525630
Deleted
C:\Qoobox\Quarantine\C\WINDOWS\system32\iehelper.dll.vir
Infected with: Trojan.Generic.2601447
Deleted
C:\Qoobox\Quarantine\C\WINDOWS\system32\ipyt7o1v.dll.vir
Infected with: Trojan.Generic.2554519
Deleted
C:\Qoobox\Quarantine\C\WINDOWS\system32\lsp.dll.vir
Detected with: Application.Generic.248984
Disinfection failed
Deleted
E:\backup.pst=>[Subject: ??Re: Thanks Smile][From: Hotrod]=>Joke.cpl
Infected with: Win32.Bagle.AY@mm
Deleted
E:\backup.pst
Updated
E:\backup.pst=>[Subject: ??Re: Thanks Smile][From: Hotrod]=>price.scr
Infected with: Worm.Generic.3187
Deleted
E:\backup.pst
Updated
E:\backup.pst=>[Subject: ??Regions Bank Reminder: PIease Update Your DetaiIs][From: Regions & Union Planters]=>(body)=>(Compressed Rtf)=>(Rtf2Html)
Infected with: Trojan.Spy.HTML.Bankfraud.DQ
Disinfection failed
Deleted
Update failed
E:\backup.pst=>[Subject: ??Undeliverable Message User unknown][From: Postmaster]=>(body)=>(Compressed Rtf)
Suspected of: Exploit.Iframe.Vulnerability
Disinfection failed
Deleted
Deleted
E:\backup.pst
Updated
E:\backup.pst=>[Subject: ??New Net Critical Update][From: Microsoft Program Security Center]=>Upgrade36.zl9
Infected with: Win32.Swen.A@mm
Deleted
E:\backup.pst
Updated
E:\backup.pst=>[Subject: ??Congratulations ! from Libby][From: [You must be registered and logged in to see this link.]]=>(body)=>(Compressed Rtf)
Infected with: Generic.Peed.Eml.6D944631
Disinfection failed
Deleted
Deleted
E:\backup.pst
Updated
E:\backup.pst=>[Subject: ??Mail Delivery (failure [You must be registered and logged in to see this link.])][From: [You must be registered and logged in to see this link.]]=>(body)=>(Compressed Rtf)
Suspected of: Trojan.Exploit.Html.Iframe.Filedownload.JF
Disinfection failed
Deleted
Deleted
E:\backup.pst
Updated
E:\backup.pst=>[Subject: ??Mail Delivery (failure [You must be registered and logged in to see this link.])][From: [You must be registered and logged in to see this link.]]=>message.zlq
Infected with: Win32.Netsky.P@mm
Deleted
E:\backup.pst
Updated
Disinfection failed
Deleted
Deleted
E:\backup.pst
Updated
E:\backup.pst=>[Subject: ??1][From: Djrobengel]=>(body)=>(Compressed Rtf)=>(Rtf2Html)
Infected with: Trojan.Script.86471
Disinfection failed
Deleted
Update failed
E:\backup.pst=>[Subject: ??Citizens Bank: security update][From: Citizens Bank]=>(body)=>(Compressed Rtf)=>(Rtf2Html)
Infected with: HTML.Phishing.B
Disinfection failed
Deleted
Update failed
E:\backup.pst=>[Subject: ??Citizens Bank: Urgent Security Notification For All Clients [Sat, 30 Oct 2004 01:55:15 -0600]][From: Citizens Bank]=>(body)=>(Compressed Rtf)=>(Rtf2Html)
Disinfection failed
Deleted
Update failed
E:\backup.pst=>[Subject: ??Re: Hi][From: Hotrod]=>price.zl6
Deleted
E:\backup.pst
Updated
E:\backup.pst=>[Subject: ??Urgent security notification][From: REGIONS BANK]=>(body)=>(Compressed Rtf)=>(Rtf2Html)
Disinfection failed
Deleted
Update failed
squidboy
OS : XP Home
Post by Dr Jay on Tue Nov 03, 2009 4:00 pm
Please download DDS by sUBs from [You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.] and save it to your Desktop.
Note: Before scanning, make sure all other running programs are closed. There shouldn't be any scheduled antivirus scans running while the scan is being performed. Do not use your computer for anything else during the scan.
  • A small box will open, with an explanation about the tool. No input is needed, the scan is running.
  • Notepad will open with the results, click Yes to the Optional_Scan
  • Please follow the instructions that pop up for posting the results.
  • Close the program window, and delete the program from your Desktop.
Post by squidboy on Tue Nov 03, 2009 7:25 pm
Have I said thank you recently?! You guys are great - I'll certainly have to donate online once this is all done!
OK, Sir, here are the results from the DDS.txt file after running DDS:
Run by Steve at 14:17:25.95 on Tue 11/03/2009
Internet Explorer: 7.0.5730.13
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.1023.479 [GMT -5:00]
svchost.exe
C:\WINDOWS\system32\svchost.exe -k WudfServiceGroup
svchost.exe
svchost.exe
svchost.exe
C:\Program Files\Common Files\Acronis\Schedule2\schedul2.exe
C:\WINDOWS\System32\svchost.exe -k HTTPFilter
C:\Program Files\Common Files\Intuit\Update Service\IntuitUpdateService.exe
C:\Program Files\Common Files\Microsoft Shared\VS7Debug\mdm.exe
C:\WINDOWS\system32\PGPserv.exe
C:\WINDOWS\System32\svchost.exe -k imgsvc
C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
C:\Program Files\Webroot\Washer\WasherSvc.exe
C:\WINDOWS\BCMSMMSG.exe
C:\WINDOWS\system32\rundll32.exe
C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb07.exe
C:\Program Files\Hewlett-Packard\HP Share-to-Web\hpgs2wnd.exe
C:\WINDOWS\system32\devldr32.exe
C:\Program Files\Creative\Creative Live! Cam\VideoFX\StartFX.exe
C:\Updater.exe
C:\Program Files\Acronis\TrueImageHome\TrueImageMonitor.exe
C:\Program Files\Hewlett-Packard\HP Share-to-Web\hpgs2wnf.exe
C:\Program Files\Acronis\TrueImageHome\TimounterMonitor.exe
C:\Program Files\Common Files\Acronis\Schedule2\schedhlp.exe
C:\WINDOWS\system32\hphmon04.exe
C:\PROGRA~1\Sony\SONICS~1\SsAAD.exe
C:\Program Files\Common Files\Ahead\Lib\NMBgMonitor.exe
C:\Program Files\Creative\Sync Manager Unicode\CTSyncU.exe
C:\Documents and Settings\Steve\Start Menu\Programs\Startup\PGPtray.exe
C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe
C:\Documents and Settings\Steve\Desktop\dds.scr
mWindow Title =
TB: MSN Toolbar: {1e61ed7c-7cb8-49d6-b9e9-ab4c880c8414} - c:\program files\msn\toolbar\3.0.0988.2\msneshellx.dll
TB: {C4069E3A-68F1-403E-B40E-20066696354B} - No File
TB: {47833539-D0C5-4125-9FA8-0819E2EAAC93} - No File
EB: {32683183-48a0-441b-a342-7c2a440a9478} - No File
uRun: [Tracks Eraser Pro] c:\program files\acesoft\tracks eraser pro\te.exe min
uRun: [SsAAD.exe] c:\progra~1\sony\sonics~1\SsAAD.exe
uRun: [BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] "c:\program files\common files\ahead\lib\NMBgMonitor.exe"
uRun: [BTCLiveUpdate] "c:\program files\liveupdate\LiveUpdate.exe" /autostart
uRun: [Window Washer] c:\program files\webroot\washer\wwDisp.exe
uRun: [CTSyncU.exe] "c:\program files\creative\sync manager unicode\CTSyncU.exe"
uRun: [updateMgr] "c:\program files\adobe\acrobat 7.0\reader\AdobeUpdateManager.exe" AcRdB7_0_9 -reboot 1
uRun: [LightScribe Control Panel] c:\program files\common files\lightscribe\LightScribeControlPanel.exe -hȋdden
uRunOnce: [Index Washer] c:\program files\webroot\washer\WashIdx.exe "Steve"
mRun: [BCMSMMSG] BCMSMMSG.exe
mRun: [NvCplDaemon] "RUNDLL32.EXE" c:\windows\system32\NvCpl.dll,NvStartup
mRun: [nwiz] "nwiz.exe" /install
mRun: [HPDJ Taskbar Utility] c:\windows\system32\spool\drivers\w32x86\3\hpztsb07.exe
mRun: [Share-to-Web Namespace Daemon] "c:\program files\hewlett-packard\hp share-to-web\hpgs2wnd.exe"
mRun: [NvMediaCenter] "RUNDLL32.EXE" c:\windows\system32\NvMcTray.dll,NvTaskbarInit
mRun: [AVFX Engine] "c:\program files\creative\creative live! cam\videofx\StartFX.exe"
mRun: [iRiver Updater] \Updater.exe
mRun: [TrueImageMonitor.exe] "c:\program files\acronis\trueimagehome\TrueImageMonitor.exe"
mRun: [AcronisTimounterMonitor] "c:\program files\acronis\trueimagehome\TimounterMonitor.exe"
mRun: [Acronis Scheduler2 Service] "c:\program files\common files\acronis\schedule2\schedhlp.exe"
mRun: [NeroFilterCheck] "c:\program files\common files\ahead\lib\NeroCheck.exe"
mRun: [dvd43] c:\program files\dvd43\dvd43_tray.exe
mRun: [HPHmon04] c:\windows\system32\hphmon04.exe
StartupFolder: c:\documents and settings\steve\start menu\programs\startup\PGPtray.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\device~1.lnk - c:\program files\olympus\devicedetector\DevDtct2.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\ymetray.lnk - c:\program files\yahoo!\yahoo! music jukebox\ymetray.exe
IE: Add to Banner Ad Blocker - c:\program files\kaspersky lab\kaspersky internet security 2009\ie_banner_deny.htm
IE: E&xport to Microsoft Excel - c:\progra~1\micros~2\office10\EXCEL.EXE/3000
IE: {85d1f590-48f4-11d9-9669-0800200c9a66} - %windir%\bdoscandel.exe
DPF: Yahoo! Pool 2 - [You must be registered and logged in to see this link.]
DPF: {05CA9FB0-3E3E-4B36-BF41-0E3A5CAA8CD8} - [You must be registered and logged in to see this link.]
DPF: {3BA3B159-7533-4F96-A2CE-EE5894BBD3D5} - [You must be registered and logged in to see this link.]
DPF: {406B5949-7190-4245-91A9-30A17DE16AD0} - [You must be registered and logged in to see this link.]
DPF: {5D86DDB5-BDF9-441B-9E9E-D4730F4EE499} - [You must be registered and logged in to see this link.]
DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} - [You must be registered and logged in to see this link.]
DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} - [You must be registered and logged in to see this link.]
DPF: {74C861A1-D548-4916-BC8A-FDE92EDFF62C} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0011-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {F137B9BA-89EA-4B04-9C67-2074A9DF61FD} - [You must be registered and logged in to see this link.]
DPF: {FFBB3F3B-0A5A-4106-BE53-DFE1E2340CB1} - [You must be registered and logged in to see this link.]
Handler: belarc - {6318E0AB-2E93-11D1-B8ED-00608CC9A71F} - c:\program files\belarc\advisor\system\BAVoilaX.dll
LSA: Authentication Packages = msv1_0 relog_ap
mASetup: {10880D85-AAD9-4558-ABDC-2AB1552D831F} - "c:\program files\common files\lightscribe\LSRunOnce.exe"
R2 BT848;AVerMedia, AVerTV WDM Video Capture;c:\windows\system32\drivers\BT848.sys [2006-6-23 260072]
R2 BTTUNER;AVerMedia, AVerTV WDM TvTuner;c:\windows\system32\drivers\bttuner.sys [2006-6-23 22016]
R2 BTXBAR;AVerMedia, AVerTV WDM Crossbar;c:\windows\system32\drivers\btxbar.sys [2006-6-23 13312]
R2 IntuitUpdateService;Intuit Update Service;c:\program files\common files\intuit\update service\IntuitUpdateService.exe [2008-10-10 13088]
R2 PGPdisk;PGPdisk;c:\windows\system32\drivers\PGPdisk.sys [2006-6-24 169120]
R2 PGPsdkDriver;PGPsdkDriver;c:\windows\system32\drivers\PGPsdk.sys [2006-6-24 26624]
R2 wwEngineSvc;Window Washer Engine;c:\program files\webroot\washer\WasherSvc.exe [2008-4-1 598856]
S3 EraserUtilDrv10741;EraserUtilDrv10741;\??\c:\program files\common files\symantec shared\eengine\eraserutildrv10741.sys --> c:\program files\common files\symantec shared\eengine\EraserUtilDrv10741.sys [?]
S3 RTLWUSB;NETGEAR WG111v2 54Mbps Wireless USB 2.0 Adapter NT Driver;c:\windows\system32\drivers\wg111v2.sys [2006-3-27 167808]
2009-11-03 01:33:34 0 d-----w- C:\commy21264c
2009-11-02 19:38:26 0 d-----w- C:\commy17334c
2009-11-02 04:27:52 0 d-sha-r- C:\cmdcons
2009-11-02 04:24:29 98816 ----a-w- c:\windows\sed.exe
2009-11-02 04:24:29 77312 ----a-w- c:\windows\MBR.exe
2009-11-02 04:24:29 236544 ----a-w- c:\windows\PEV.exe
2009-11-02 04:24:29 161792 ----a-w- c:\windows\SWREG.exe
2009-11-02 04:21:28 0 d-----w- C:\commy
2009-11-02 01:54:22 0 d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-11-02 01:53:44 0 d-----w- C:\Malwarebytes_Anti-Malware_1.41
2009-11-02 01:53:12 7171690 ----a-w- C:\Malwarebytes_Anti-Malware_1.41.zip
2009-11-02 01:42:50 0 d-----w- c:\docume~1\alluse~1\applic~1\msca
2009-10-26 06:11:52 0 d-----w- c:\docume~1\steve\applic~1\Malwarebytes
2009-10-26 06:11:46 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-10-26 06:11:44 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-10-26 06:11:44 0 d-----w- c:\program files\maw
2009-10-26 06:11:44 0 d-----w- c:\docume~1\alluse~1\applic~1\Malwarebytes
2009-10-25 23:20:20 18816 ----a-w- c:\windows\system32\drivers\dvd43llh.sys
2009-10-16 03:14:31 28232 ----a-w- c:\docume~1\steve\applic~1\GDIPFONTCACHEV1.DAT
2009-09-11 14:33:52 133632 ----a-w- c:\windows\system32\msv1_0.dll
2009-09-04 20:45:26 58880 ----a-w- c:\windows\system32\msasn1.dll
2009-08-29 07:36:27 832512 ------w- c:\windows\system32\wininet.dll
2009-08-29 07:36:24 78336 ----a-w- c:\windows\system32\ieencode.dll
2009-08-29 07:36:24 17408 ------w- c:\windows\system32\corpol.dll
2009-08-26 08:16:37 247326 ----a-w- c:\windows\system32\strmdll.dll
2009-08-20 19:09:06 1193832 ----a-w- c:\windows\system32\FM20.DLL
============= FINISH: 14:17:53.09 ===============
squidboy
OS : XP Home
Post by Dr Jay on Wed Nov 04, 2009 3:35 am
Please download CKScanner by askey127 from [You must be registered and logged in to see this link.]
Save it to your desktop.
  • Doubleclick CKScanner.exe and click Search For Files.
  • After a very short time, when the cursor hourglass disappears, click Save List To File.
  • A message box will verify that the file is saved.
  • Double-click the CKFiles.txt icon on your desktop and copy/paste the contents in your next reply.
Please include the CKScanner and Security Check logs in your next reply. Also, please tell me how your computer is running.
Post by squidboy on Wed Nov 04, 2009 3:57 am
Here's the CKScanner log:
CKScanner - Additional Security Risks - These are not necessarily bad
scanner sequence 3.RP.11
----- EOF -----
And here's the Security Check log:
Results of screen317's Security Check version 0.99.0
Windows XP Service Pack 2
Out of date service pack!!
Antivirus/Firewall Check:
Windows Firewall Enabled!
Java(TM) 6 Update 11
Out of date Java installed!
Adobe Flash Player 10
Adobe Reader 7.0.9
Process Check:
objlist.exe by Laurent
DNS Vulnerability Check:
Actually, the computer seems to be running pretty well. I haven't been flooded with pop-ups, able to browse various known-safe sites, able to open whatever programs I choose without being blocked. If I didn't know better, I'd say it's back to normal. And maybe it is?! I will await your opinion and reply - thanks again for your support!!!
squidboy
OS : XP Home
Post by Dr Jay on Wed Nov 04, 2009 6:07 am
Please upgrade to Windows XP SP3, because it includes all previously released updates. It also includes a small number of new functionalities. Some of the updates that Service Pack 3 provides, you may not have. It is now available via [You must be registered and logged in to see this link.].
Software recommendations
Antivirus/Antispyware
  • [You must be registered and logged in to see this link.]: this is Microsoft's free antivirus/antispyware program. It equips you with protection against viruses, spyware, trojans, rootkits, and worms. It is also light on the computer's performance. Note: when installing this, you have both an antivirus and antispyware. Make sure you also get a firewall.
  • [You must be registered and logged in to see this link.]: this is one of the most powerful, and easiest to use security software. The free version equips you with protection against viruses, spyware, trojans, rootkits, worms, and rogue software. Note: when installing this, you have both an antivirus and antispyware. Make sure you also get a firewall.
Firewall
Note: Please keep ALL of these programs up-to-date and run them whenever you suspect a problem to prevent malware problems.
Resident Protection help
Rogue programs help
Securing your computer
If you are interested:
Post by squidboy on Wed Nov 04, 2009 3:25 pm
DragonMaster Jay, you are awesome! Thank you so much for your help getting me through this - I definitely couldn't have done it without you. And thanks for the final tips; I'll make sure I do everything you recommended.....and I will certainly be making a donation as a "thank you".
Thanks!
Steve
squidboy
OS : XP Home
