Help with virus disabling malware and virus scan
Post by JohnKramer on Sun Nov 01, 2009 8:07 pm
"I have problems with my personal computer, My computer started getting slow, then I tried to run a scan with my McAffe but I could not do it, I just have the message: ERROR-Starting on Demand Scanner. Then I tried to run the Malwarebytes AntiMalware and I then start and then disappear from my screen. I follow your instructions about updating Java and run the HijackThis and it just disappear from my screen too. Could you please help me out, I do not know what else to do?"
I have the exact same problem as this guy. I should also point out I usually use firefox and was using it when i got the virus, but it seems to have disabled that as well. So right now I am using Google Chrome.
Thanks for any help.
Sorry, here's a link to the thread I was quoting, in case it is any help.
Last edited by JohnKramer on Sun Nov 01, 2009 8:09 pm; edited 1 time in total (Reason for editing : add a link)
JohnKramer
Posts Posts : 14
Joined Joined : 2009-11-01
Points Points : 25926
Re: Help with virus disabling malware and virus scan
Post by Belahzur on Sun Nov 01, 2009 10:39 pm
    :filefind
    scecli.dll
    netlogon.dll
    eventlog.dll
    cngaudit.dll
Points Points : 245059
Post by JohnKramer on Tue Nov 03, 2009 11:54 am
Log created at 11:49 on 03/11/2009 by Ayyub Maadani (Administrator - Elevation successful)
Searching for "scecli.dll"
C:\I386\SCECLI.DLL --a--- 174592 bytes [15:08 14/10/2004] [04:00 29/08/2002] 97418A5C642A5C748A28BD7CF6860B57
C:\WINDOWS\$NtServicePackUninstall$\scecli.dll -----c 180224 bytes [11:11 23/08/2008] [23:56 03/08/2004] 0F78E27F563F2AAF74B91A49E2ABF19A
C:\WINDOWS\ServicePackFiles\i386\scecli.dll ------ 181248 bytes [13:19 22/10/2004] [00:12 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
C:\WINDOWS\SYSTEM32\scecli.dll --a--- 181248 bytes [04:00 29/08/2002] [00:12 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
Searching for "netlogon.dll"
C:\I386\NETLOGON.DLL --a--- 399360 bytes [15:07 14/10/2004] [04:00 29/08/2002] 3ADD563ED7A1C66E6F5E0F7A661AA96D
C:\WINDOWS\$NtServicePackUninstall$\netlogon.dll -----c 407040 bytes [11:11 23/08/2008] [23:56 03/08/2004] 96353FCECBA774BB8DA74A1C6507015A
C:\WINDOWS\ServicePackFiles\i386\netlogon.dll ------ 407040 bytes [13:18 22/10/2004] [00:12 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
C:\WINDOWS\SYSTEM32\netlogon.dll --a--- 407040 bytes [04:00 29/08/2002] [00:12 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
Searching for "eventlog.dll"
C:\I386\EVENTLOG.DLL --a--- 49152 bytes [15:04 14/10/2004] [04:00 29/08/2002] BF3C8CF53C77B48206B39910B6D6CBCC
C:\WINDOWS\$NtServicePackUninstall$\eventlog.dll -----c 55808 bytes [11:11 23/08/2008] [23:56 03/08/2004] 82B24CB70E5944E6E34662205A2A5B78
C:\WINDOWS\ServicePackFiles\i386\eventlog.dll ------ 56320 bytes [13:18 22/10/2004] [00:11 14/04/2008] 6D4FEB43EE538FC5428CC7F0565AA656
C:\WINDOWS\SYSTEM32\eventlog.dll --a--- 61952 bytes [04:00 29/08/2002] [00:11 14/04/2008] (Unable to calculate MD5)
Searching for "cngaudit.dll"
No files found.
-=End Of File=-
JohnKramer
Posts Posts : 14
Post by Belahzur on Tue Nov 03, 2009 8:41 pm
Files to delete:
C:\WINDOWS\system32\eventlog.dll
Post by JohnKramer on Tue Nov 03, 2009 9:49 pm
I downloaded avenger but when I tried to extract it an alert from mcafee popped up and blocked it as a trojan?
Heres what it says :
"McAfee has automatically blocked and removed a Trojan.
About this Trojan
Detected: BackDoor-EFN (Trojan), BackDoor-EFN (Trojan)
Location: C:\Documents and Settings\Ayyub Maadani\My Documents\Downloads\avenger\avenger.exe
Trojans appear as legitimate programs but can damage valuable files, disrupt performance, and allow unauthorized access to your computer."
JohnKramer
Posts Posts : 14
Post by Belahzur on Wed Nov 04, 2009 1:36 am
Ignore the warning, disable/uninstall Mcafee, it's wrong about that, false positive.
Post by JohnKramer on Wed Nov 04, 2009 2:19 pm
I did everything but a black command window didn't open on the desktop instead mcafee blocked it as a trojan again. Which is weird because I turned it off before...
However, the log file did show up:
Platform: Windows XP
Rootkit scan active.
No rootkits found!
File "C:\WINDOWS\system32\eventlog.dll" deleted successfully.
Completed script processing.
Finished! Terminate.
JohnKramer
Posts Posts : 14
Post by Belahzur on Thu Nov 05, 2009 12:41 am
Post by JohnKramer on Thu Nov 05, 2009 10:07 pm
Database version: 3107
05/11/2009 22:05:14
mbam-log-2009-11-05 (22-05-14).txt
Objects scanned: 191842
Time elapsed: 29 minute(s), 1 second(s)
Registry Keys Infected: 4
Registry Values Infected: 1
Files Infected: 11
HKEY_CURRENT_USER\SOFTWARE\NordBull (Malware.Trace) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\XML (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\TDSSserv (Rootkit.Agent) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\poprock (Trojan.Downloader) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\poprock (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\Documents and Settings\Ayyub Maadani\Local Settings\Temp\b.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\RECYCLER\S-1-5-21-3333968868-2200709785-3983559585-1008\Dc230.exe (Adware.Agent.N) -> Quarantined and deleted successfully.
C:\RECYCLER\S-1-5-21-3333968868-2200709785-3983559585-1008\Dc241.exe (Adware.Agent.N) -> Quarantined and deleted successfully.
C:\RECYCLER\S-1-5-21-3333968868-2200709785-3983559585-1008\Dc253.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\Documents and Settings\Ayyub Maadani\Local Settings\Temp\c.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\Documents and Settings\Ayyub Maadani\Local Settings\Temp\a.exe (Rootkit.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\MarioParty4-Boo.dat (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\Tasks\{7B02EF0B-A410-4938-8480-9BA26420A627}.job (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\Tasks\{BB65B0FB-5712-401b-B616-E69AC55E2757}.job (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\win32k.sys (Trojan.Dropper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Ayyub Maadani\My Documents\downloads\winlogon.scr (Heuristics.Reserved.Word.Exploit) -> Quarantined and deleted successfully.
JohnKramer
Posts Posts : 14
Post by Belahzur on Thu Nov 05, 2009 10:12 pm
Post by JohnKramer on Thu Nov 05, 2009 11:46 pm
Run by Ayyub Maadani at 23:44:13.87 on 05/11/2009
Internet Explorer: 7.0.5730.13 BrowserJavaVersion: 1.6.0_10
FW: McAfee Personal Firewall *enabled* {94894B63-8C7F-4050-BDA4-813CA00DA3E8}
uStart Page =
uInternet Settings,ProxyOverride = ;*.local
uURLSearchHooks: McAfee SiteAdvisor Toolbar: {0ebbbe48-bad4-4b4c-8e5a-516abecae064} - c:\progra~1\mcafee\sitead~1\mcieplg.dll
BHO: McAfee Phishing Filter: {27b4851a-3207-45a2-b947-be8afe6163ab} - c:\progra~1\mcafee\msk\mskapbho.dll
BHO: UberButton Class: {5bab4b5b-68bc-4b02-94d6-2fc0de4a7897} - c:\program files\yahoo!\common\yiesrvc.dll
BHO: DriveLetterAccess: {5ca3d70e-1895-11cf-8e15-001234567890} - c:\windows\system32\dla\tfswshx.dll
BHO: YahooTaggedBM Class: {65d886a2-7ca7-479b-bb95-14d1efb7946a} - c:\program files\yahoo!\common\YIeTagBm.dll
BHO: Java(tm) Plug-In SSV Helper: {761497bb-d6f0-462c-b6eb-d4daf1d92d43} - c:\program files\java\jre6\bin\ssv.dll
BHO: scriptproxy: {7db2d5a0-7241-4e79-b68d-6309f01c5231} - c:\program files\mcafee\virusscan\scriptsn.dll
BHO: {7E853D72-626A-48EC-A868-BA8D5E23E045} - No File
BHO: Google Toolbar Helper: {aa58ed58-01dd-4d91-8333-cf10577473f7} - c:\program files\google\googletoolbar1.dll
BHO: McAfee SiteAdvisor BHO: {b164e929-a1b6-4a06-b104-2cd0e90a88ff} - c:\progra~1\mcafee\sitead~1\mcieplg.dll
TB: Wanadoo: {8b68564d-53fd-4293-b80c-993a9f3988ee} - c:\progra~1\wanadoo\wsbar\WSBar.dll
TB: &Google: {2318c2b1-4965-11d4-9b18-009027a5cd4f} - c:\program files\google\googletoolbar1.dll
TB: McAfee SiteAdvisor Toolbar: {0ebbbe48-bad4-4b4c-8e5a-516abecae064} - c:\progra~1\mcafee\sitead~1\mcieplg.dll
TB: Veoh Web Player Video Finder: {0fbb9689-d3d7-4f7a-a2e2-585b10099bfc} - c:\program files\veoh networks\veohwebplayer\VeohIEToolbar.dll
TB: Yahoo! Toolbar: {ef99bd32-c1fb-11d2-892f-0090271d4f88} -
EB: &Yahoo! Messenger: {4528bbe0-4e08-11d5-ad55-00010333d0ad} - c:\progra~1\yahoo!\common\yhexbmesus.dll
EB: {32683183-48a0-441b-a342-7c2a440a9478} - No File
uRun: [kdx] c:\program files\kontiki\KHost.exe -all
uRun: [Aim6]
uRun: [WinDNN] "c:\documents and settings\ayyub maadani\application data\google\klnxv19819115.exe" 2
uRun: [SB Audigy 2 Startup Menu] /L:ENG
uRun: [Google Update] "c:\documents and settings\ayyub maadani\local settings\application data\google\update\GoogleUpdate.exe" /c
uRun: [ares destiny] "c:\program files\ares destiny\Ares.exe" -h
uRun: [WMPNSCFG] c:\program files\windows media player\WMPNSCFG.exe
mRun: [SunJavaUpdateSched] "c:\program files\java\jre6\bin\jusched.exe"
mRun: [IAAnotif] c:\program files\intel\intel application accelerator\iaanotif.exe
mRun: [PCMService] "c:\program files\dell\media experience\PCMService.exe"
mRun: [IntelMeM] c:\program files\intel\modem event monitor\IntelMEM.exe
mRun: [CTSysVol] c:\program files\creative\sbaudigy2\surround mixer\CTSysVol.exe
mRun: [CTDVDDet] c:\program files\creative\sbaudigy2\dvdaudio\CTDVDDet.EXE
mRun: [CTHelper] CTHELPER.EXE
mRun: [AsioReg] REGSVR32.EXE /S CTASIO.DLL
mRun: [UpdReg] c:\windows\UpdReg.EXE
mRun: [VirusScan] c:\progra~1\mcafee.com\vso\mcvsshld.exe
mRun: [Dell Photo AIO Printer 922] "c:\program files\dell photo aio printer 922\dlbtbmgr.exe"
mRun: [BluetoothAuthenticationAgent] rundll32.exe bthprops.cpl,,BluetoothAuthenticationAgent
mRun: [LGODDFU] "c:\program files\lg_fwupdate\fwupdate.exe" blrun
mRun: [mcagent_exe] "c:\program files\mcafee.com\agent\mcagent.exe" /runkey
mRun: [McENUI] c:\progra~1\mcafee\mhn\McENUI.exe /hide
mRun: [4oD] "c:\program files\kontiki\KHost.exe" -all
mRun: [Adobe Reader Speed Launcher] "c:\program files\adobe\reader 9.0\reader\Reader_sl.exe"
mRun: [MSConfig] c:\windows\pchealth\helpctr\binaries\MSConfig.exe /auto
StartupFolder: c:\docume~1\ayyubm~1\startm~1\programs\startup\sdktra~1.lnk - c:\sun\sdk\jdk\bin\javaw.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\micros~1.lnk - c:\program files\microsoft office\office10\OSA.EXE
IE: &Google Search - c:\program files\google\GoogleToolbar1.dll/cmsearch.html
IE: &Translate English Word - c:\program files\google\GoogleToolbar1.dll/cmwordtrans.html
IE: &Yahoo! Search - [You must be registered and logged in to see this link.] files\yahoo!\Common/ycsrch.htm
IE: Backward Links - c:\program files\google\GoogleToolbar1.dll/cmbacklinks.html
IE: Cached Snapshot of Page - c:\program files\google\GoogleToolbar1.dll/cmcache.html
IE: E&xport to Microsoft Excel - c:\progra~1\micros~3\office10\EXCEL.EXE/3000
IE: Search with Wanadoo - c:\progra~1\wanadoo\wsbar\WSBar.dll/VSearch.htm
IE: Similar Pages - c:\program files\google\GoogleToolbar1.dll/cmsimilar.html
IE: Translate Page into English - c:\program files\google\GoogleToolbar1.dll/cmtrans.html
IE: Yahoo! &Dictionary - [You must be registered and logged in to see this link.] files\yahoo!\Common/ycdict.htm
IE: Yahoo! &Maps - [You must be registered and logged in to see this link.] files\yahoo!\Common/ycmap.htm
IE: {CCA281CA-C863-46ef-9331-5C8D4460577F} - c:\program files\bluetooth\bluetooth software\btsendto_ie.htm
IE: {CD67F990-D8E9-11d2-98FE-00C0F0318AFE}
IE: {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - {5BAB4B5B-68BC-4B02-94D6-2FC0DE4A7897} - c:\program files\yahoo!\common\yiesrvc.dll
DPF: {20A60F0D-9AFA-4515-A0FD-83BD84642501} - [You must be registered and logged in to see this link.]
DPF: {5D6F45B3-9043-443D-A792-115447494D24} - [You must be registered and logged in to see this link.]
DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} - [You must be registered and logged in to see this link.]
DPF: {C3F79A2B-B9B4-4A66-B012-3EE46475B072} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0010-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
Handler: cdo - {CD00020A-8B95-11D1-82DB-00C04FB1625D} - c:\program files\common files\microsoft shared\web folders\PKMCDO.DLL
Handler: dssrequest - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\progra~1\mcafee\sitead~1\McIEPlg.dll
Handler: sacore - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\progra~1\mcafee\sitead~1\McIEPlg.dll
Handler: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - c:\progra~1\common~1\skype\SKYPE4~1.DLL
Notify: LMIinit - LMIinit.dll
FF - ProfilePath - c:\docume~1\ayyubm~1\applic~1\mozilla\firefox\profiles\q4beip64.default\
FF - prefs.js: browser.search.selectedEngine - Wikipedia (en)
FF - component: c:\documents and settings\ayyub maadani\application data\mozilla\firefox\profiles\q4beip64.default\extensions\{19627815-20a6-46e6-be34-a0b6967c022a}\components\Engine.dll
FF - component: c:\program files\mcafee\siteadvisor\components\McFFPlg.dll
FF - plugin: c:\documents and settings\ayyub maadani\application data\mozilla\firefox\profiles\q4beip64.default\extensions\battlefieldheroespatcher@ea.com\platform\winnt_x86-msvc\plugins\npBFHUpdater.dll
FF - plugin: c:\documents and settings\ayyub maadani\local settings\application data\google\update\1.2.183.7\npGoogleOneClick8.dll
FF - plugin: c:\program files\mozilla firefox\plugins\NPMGWRAP.DLL
FF - plugin: c:\program files\mozilla firefox\plugins\npViewpoint.dll
FF - plugin: c:\program files\veoh networks\veohwebplayer\NPVeohTVPlugin.dll
FF - plugin: c:\program files\veoh networks\veohwebplayer\npWebPlayerVideoPluginATL.dll
FF - plugin: c:\program files\viewpoint\viewpoint experience technology\npViewpoint.dll
FF - hȋdden: Microsoft .NET Framework Assistant: {20a82645-c095-46ed-80e3-08825760534b} - c:\windows\microsoft.net\framework\v3.5\windows presentation foundation\dotnetassistantextension\
FF - hȋdden: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0001-ABCDEFFEDCBA}
FF - hȋdden: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0002-ABCDEFFEDCBA}
FF - hȋdden: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA}
FF - hȋdden: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0007-ABCDEFFEDCBA}
FF - hȋdden: Java Console: No Registry Reference - c:\program files\mozilla firefox\extensions\{CAFEEFAC-0016-0000-0010-ABCDEFFEDCBA}
---- FIREFOX POLICIES ----
FF - user.js: dom.disable_open_during_load - true // Popupblocker control handled by McAfee Privacy Service
2009-11-01 18:13:09 3 ----a-w- c:\documents and settings\ayyub maadani\tray.pid
2009-11-01 17:43:20 116 ----a-w- c:\documents and settings\ayyub maadani\.asadminpass
2009-11-01 17:43:09 789 ----a-w- c:\documents and settings\ayyub maadani\.asadmintruststore
2009-11-01 17:38:11 23108 ----a-w- c:\windows\system32\productregistry
2009-11-01 17:12:03 0 dc----w- C:\Sun
2009-11-01 16:46:19 0 d-----w- c:\documents and settings\ayyub maadani\.SunDownloadManager
2009-10-30 11:15:56 102664 ----a-w- c:\windows\system32\drivers\tmcomm.sys
2009-10-30 11:13:08 0 d-----w- c:\documents and settings\ayyub maadani\.housecall6.6
2009-09-16 09:22:48 79816 ----a-w- c:\windows\system32\drivers\mfeavfk.sys
2009-09-16 09:22:48 40552 ----a-w- c:\windows\system32\drivers\mfesmfk.sys
2009-09-16 09:22:48 35272 ----a-w- c:\windows\system32\drivers\mfebopk.sys
2009-09-16 09:22:48 214664 ----a-w- c:\windows\system32\drivers\mfehidk.sys
2009-09-16 09:22:14 34248 ----a-w- c:\windows\system32\drivers\mferkdk.sys
2009-09-10 14:54:06 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-09-10 14:53:50 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-08-13 15:16:05 512000 ------w- c:\windows\system32\dllcache\jscript.dll
2008-09-19 18:26:46 32768 --sha-w- c:\windows\system32\config\systemprofile\local settings\history\history.ie5\mshist012008091920080920\index.dat
============= FINISH: 23:45:09.51 ===============
JohnKramer
Posts Posts : 14
Post by JohnKramer on Thu Nov 05, 2009 11:47 pm
No restore point in system.
µTorrent
05
4Media PS3 Video Converter
4oD
ABBYY FineReader 5.0 Sprint Plus
Ad-Aware SE Personal
Adobe Acrobat Reader 3.01
Adobe AIR
Adobe Flash Player 10 ActiveX
Adobe Flash Player 10 Plugin
Adobe Flash Player 9 ActiveX
Adobe Reader 9.2
Adobe Reader Japanese Fonts
Adobe® Photoshop® Album Starter Edition 3.0
AIM 6
Apple Mobile Device Support
Apple Software Update
ArcSoft Camera Suite 1.3
ArcSoft Collage Creator
ArcSoft Multimedia Email
ArcSoft PhotoImpression 5
ArcSoft VideoImpression 2
Ares Destiny 3.0
ATI Display Driver
AviSynth 2.5
Battlefield Heroes
BBC iPlayer Desktop
BBC iPlayer Download Manager
Bluetooth Software
Bonjour
Broadcom Advanced Control Suite 2
Camera Window
Canon Camera Window for ZoomBrowser EX
Canon Internet Library for ZoomBrowser EX
Canon PhotoRecord
Canon ScanGear Toolbox CS 2.2
Canon Utilities File Viewer Utility 1.2
Canon Utilities PhotoStitch 3.1
Canon Utilities RemoteCapture 2.7
Canon Utilities ZoomBrowser EX
CIG
Combined Community Codec Pack 2007-07-22
Corel Applications
Creative MediaSource
Creative WebCam Center
Creative WebCam Live! Pro Driver (1.00.06.0811)
Creative WebCam Live! Pro User's Guide (English)
Dell Media Experience
Dell Solution Center
Dell System Restore
DiscIndisK Vitual CD-ROM
DivX Web Player
DVD Decrypter (Remove Only)
DVD Suite
File Viewer Utility 1.2.1
First Step Guide
G4a922EN
Get Yahoo! Messenger
GOM Player
Google Chrome
Google Earth
Help and Support Customization
HijackThis 2.0.2
Hotspot Shield 1.04
ImageMixer VCD2
Intel Application Accelerator
Intel(R) 537EP V9x DF PCI Modem
InterActual Player
Internet Explorer Default Page
iTunes
Jasc Paint Shop Photo Album
Jasc Paint Shop Pro 8 Dell Edition
Java Platform, Enterprise Edition 5 SDK
Java(TM) 6 Update 10
Learn2 Player (Uninstall Only)
Lernout & Hauspie TruVoice American English TTS Engine
LG ODD Auto Firmware Update
LogMeIn
Macromedia Flash MX
Macromedia Shockwave Player
McAfee SecurityCenter
Microsoft .NET Framework 1.1
Microsoft Office PowerPoint Viewer 2003
Microsoft Office XP Professional with FrontPage
Microsoft Windows Journal Viewer
Microsoft Works 7.0
Modem Event Monitor
Modem Helper
Modem On Hold
Monopoly Star Wars
Mozilla Firefox (3.0.15)
MSN Winks Plus
MSXML 4.0 SP2 (KB954430)
MyEmoticons
NinjaVideo Helper
Nintendo Desktop Manager
Nintendo Wi-Fi USB Connector Registration Tool
Nokia Connectivity Cable DKU-2 Drivers
osu!
PhotoStitch
Picture Package
PowerDVD
PowerProducer
PSP Video 9 5.01
PunkBuster Services
QuickTime
Rapport
Real Alternative 1.9.0
RemoteCapture 2.7.1
Rugrats Print Shop
scr_Metroidprime Screen Saver
Skype™ 3.8
Sonic DLA
Sonic MyDVD
Sonic RecordNow!
Sonic Update Manager
Sony Ericsson PC Suite
Sony USB Driver
Sound Blaster Audigy 2
SpeedTouch USB Software
SuperMarioSunshine Screen Saver
The Battle for Middle-earth (tm)
The Legend of Zelda Screensaver
tunnel Screen Saver
Veoh Web Player
Videora Nokia 5800 XpressMusic Converter 4.08
Videora Xbox 360 Converter 4.08
Viewpoint Media Player
Wanadoo Search Toolbar
WebFldrs XP
Windows Genuine Advantage v1.3.0254.0
Windows Live installer
Windows Live Messenger
Windows Media Player Firefox Plugin
Windows XP Service Pack 3
WinRAR archiver
XviD MPEG-4 Video Codec
Yahoo! extras
Yahoo! Internet Mail
Yahoo! Messenger
YouTube Downloader App 2.01
JohnKramer
Posts Posts : 14
Post by Origin on Fri Nov 06, 2009 1:45 am
2. During the download, rename Combofix to svchost as follows:
  • Double click on svchost.exe.
    Do not mouse click combofix's window whilst it's running. That may cause it to stall.
Posts Posts : 2685
Joined Joined : 2009-05-05
OS OS : Windows Xp Sp3
Points Points : 31473
Post by JohnKramer on Fri Nov 06, 2009 5:15 pm
ComboFix 09-11-05.05 - Ayyub Maadani 06/11/2009 16:05.1.2 - NTFSx86
Running from: c:\documents and settings\Ayyub Maadani\Desktop\ComboFix.exe
* Resident AV is active
c:\documents and settings\Ayyub Maadani\Desktop\[Torrentsworld.net] - No More Heroes Original Sound Tracks (vgmTorrents net).torrent
c:\windows\run.log
c:\windows\system32\install.exe
c:\windows\system32\logs
-------\Legacy_TDSSSERV
-------\Legacy_{79007602-0CDB-4405-9DBF-1257BB3226EE}
((((((((((((((((((((((((( Files Created from 2009-10-06 to 2009-11-06 )))))))))))))))))))))))))))))))
2009-11-01 17:12 . 2009-11-01 17:12 -------- dc----w- C:\Sun
2009-11-01 16:46 . 2009-11-01 17:40 -------- d-----w- c:\documents and settings\Ayyub Maadani\.SunDownloadManager
2009-10-30 11:15 . 2009-10-30 11:13 102664 ----a-w- c:\windows\system32\drivers\tmcomm.sys
2009-10-30 11:13 . 2009-10-30 11:16 -------- d-----w- c:\documents and settings\Ayyub Maadani\.housecall6.6
2009-10-17 18:26 . 2009-10-17 18:26 -------- d-----w- c:\documents and settings\Ibrahim Maadani\Application Data\Trusteer
2009-11-06 16:46 . 2008-01-26 22:04 -------- d-----w- c:\documents and settings\All Users\Application Data\Kontiki
2009-11-06 16:33 . 2007-11-07 18:30 -------- d-----w- c:\program files\lg_fwupdate
2009-11-06 16:30 . 2004-09-30 19:49 288 ----a-w- c:\windows\system32\DVCStateBkp-{00000004-00000000-00000000-00001102-00000004-10031102}.dat
2009-11-06 16:30 . 2004-09-30 19:49 288 ----a-w- c:\windows\system32\DVCState-{00000004-00000000-00000000-00001102-00000004-10031102}.dat
2009-11-06 15:43 . 2007-01-13 11:52 -------- d-----w- c:\program files\McAfee
2009-11-05 21:32 . 2008-09-19 18:26 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-11-01 19:42 . 2004-11-07 08:33 -------- d-----w- c:\program files\Common Files\Adobe
2009-11-01 17:53 . 2004-09-30 19:36 -------- d-----w- c:\program files\Java
2009-10-17 18:55 . 2004-10-14 19:29 86352 ----a-w- c:\documents and settings\Ibrahim Maadani\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-09-29 19:03 . 2009-09-29 16:03 -------- d-----w- c:\program files\HandBrake
2009-09-29 16:12 . 2009-09-29 16:12 -------- d-----w- c:\documents and settings\Ayyub Maadani\Application Data\HandBrake
2009-09-29 15:45 . 2009-07-06 18:49 -------- d-----w- c:\documents and settings\Ayyub Maadani\Application Data\Red Kawa
2009-09-29 09:58 . 2009-09-29 09:58 -------- d-----w- c:\program files\Regensoft
2009-09-16 09:22 . 2007-01-13 11:53 40552 ----a-w- c:\windows\system32\drivers\mfesmfk.sys
2009-09-16 09:22 . 2007-01-13 11:53 35272 ----a-w- c:\windows\system32\drivers\mfebopk.sys
2009-09-16 09:22 . 2007-01-13 11:53 79816 ----a-w- c:\windows\system32\drivers\mfeavfk.sys
2009-09-16 09:22 . 2007-01-13 11:53 214664 ----a-w- c:\windows\system32\drivers\mfehidk.sys
2009-09-16 09:22 . 2007-01-13 11:53 34248 ----a-w- c:\windows\system32\drivers\mferkdk.sys
2009-09-15 08:54 . 2004-11-05 09:51 86352 ----a-w- c:\documents and settings\Sandra Maadani\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-09-15 08:53 . 2009-09-15 08:53 -------- d-----w- c:\documents and settings\Sandra Maadani\Application Data\Trusteer
2009-09-15 08:19 . 2009-09-15 08:19 -------- d-----w- c:\documents and settings\NetworkService\Application Data\McAfee
2009-09-14 19:33 . 2007-01-13 11:46 -------- d-----w- c:\documents and settings\All Users\Application Data\McAfee
2009-09-14 12:05 . 2008-07-22 11:39 -------- d-----w- c:\documents and settings\Ayyub Maadani\Application Data\Skype
2009-09-14 11:52 . 2006-12-25 11:40 -------- d-----w- c:\program files\Windows Media Connect 2
2009-09-14 10:06 . 2008-07-22 11:42 -------- d-----w- c:\documents and settings\Ayyub Maadani\Application Data\skypePM
2009-09-10 14:54 . 2008-09-19 18:26 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-09-10 14:53 . 2008-09-19 18:26 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-09-01 20:21 . 2009-09-01 20:20 1925024 ----a-w- c:\documents and settings\All Users\Application Data\NOS\Adobe_Downloads\install_flash_player.exe
2009-08-18 21:40 . 2004-10-18 19:35 86352 ----a-w- c:\documents and settings\Ayyub Maadani\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
------- Sigcheck -------
[7] 2008-04-14 . 6D4FEB43EE538FC5428CC7F0565AA656 . 56320 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\eventlog.dll
[7] 2004-08-03 . 82B24CB70E5944E6E34662205A2A5B78 . 55808 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\eventlog.dll
c:\windows\system32\eventlog.dll ... is missing !!
"SB Audigy 2 Startup Menu"="/L:ENG" [X]
"kdx"="c:\program files\Kontiki\KHost.exe" [2007-11-27 1032376]
"Google Update"="c:\documents and settings\Ayyub Maadani\Local Settings\Application Data\Google\Update\GoogleUpdate.exe" [2009-09-14 133104]
"ares destiny"="c:\program files\Ares Destiny\Ares.exe" [2007-08-07 2970112]
"WMPNSCFG"="c:\program files\Windows Media Player\WMPNSCFG.exe" [2006-10-18 204288]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2008-12-26 136600]
"IAAnotif"="c:\program files\Intel\Intel Application Accelerator\iaanotif.exe" [2004-06-29 135168]
"PCMService"="c:\program files\Dell\Media Experience\PCMService.exe" [2004-04-11 290816]
"IntelMeM"="c:\program files\Intel\Modem Event Monitor\IntelMEM.exe" [2003-09-03 221184]
"CTSysVol"="c:\program files\Creative\SBAudigy2\Surround Mixer\CTSysVol.exe" [2002-10-29 49152]
"CTDVDDet"="c:\program files\Creative\SBAudigy2\DVDAudio\CTDVDDet.EXE" [2002-09-30 45056]
"UpdReg"="c:\windows\UpdReg.EXE" [2000-05-11 90112]
"Dell Photo AIO Printer 922"="c:\program files\Dell Photo AIO Printer 922\dlbtbmgr.exe" [2004-03-29 290816]
"LGODDFU"="c:\program files\lg_fwupdate\fwupdate.exe" [2007-11-07 249856]
"mcagent_exe"="c:\program files\McAfee.com\Agent\mcagent.exe" [2009-09-17 645328]
"McENUI"="c:\progra~1\McAfee\MHN\McENUI.exe" [2009-07-07 1176808]
"4oD"="c:\program files\Kontiki\KHost.exe" [2007-11-27 1032376]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2009-01-05 413696]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2009-10-03 35696]
"Adobe ARM"="c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2009-09-04 935288]
"combofix"="c:\combofix\CF14212.exe" [2009-11-06 389120]
"CTHelper"="CTHELPER.EXE" - c:\windows\SYSTEM32\CTHELPER.EXE [2003-02-20 28672]
"AsioReg"="CTASIO.DLL" - c:\windows\SYSTEM32\CTASIO.DLL [2003-02-20 110592]
"BluetoothAuthenticationAgent"="bthprops.cpl" - c:\windows\SYSTEM32\bthprops.cpl [2008-04-14 110592]
c:\documents and settings\Ayyub Maadani\Start Menu\Programs\Startup\
SDK Tray Menu.lnk - c:\sun\SDK\jdk\bin\javaw.exe [2009-11-1 139264]
Microsoft Office.lnk - c:\program files\Microsoft Office\Office10\OSA.EXE [2001-2-13 83360]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon\notify\LMIinit]
2007-05-25 14:22 63040 ----a-w- c:\windows\SYSTEM32\LMIinit.dll
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Adobe Reader Speed Launch.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Adobe Reader Speed Launch.lnk
backup=c:\windows\pss\Adobe Reader Speed Launch.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Bluetooth.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Bluetooth.lnk
backup=c:\windows\pss\Bluetooth.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Picture Package Menu.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Picture Package Menu.lnk
backup=c:\windows\pss\Picture Package Menu.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Picture Package VCD Maker.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Picture Package VCD Maker.lnk
backup=c:\windows\pss\Picture Package VCD Maker.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Run Nintendo Wi-Fi USB Connector Registration Tool.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Run Nintendo Wi-Fi USB Connector Registration Tool.lnk
backup=c:\windows\pss\Run Nintendo Wi-Fi USB Connector Registration Tool.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Run Registration Tool.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Run Registration Tool.lnk
backup=c:\windows\pss\Run Registration Tool.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^Ayyub Maadani^Start Menu^Programs^Startup^BBC iPlayer Desktop.lnk]
path=c:\documents and settings\Ayyub Maadani\Start Menu\Programs\Startup\BBC iPlayer Desktop.lnk
backup=c:\windows\pss\BBC iPlayer Desktop.lnkStartup
[HKLM\~\startupfolder\C:^Documents and Settings^Ayyub Maadani^Start Menu^Programs^Startup^DiscinDisK.lnk]
path=c:\documents and settings\Ayyub Maadani\Start Menu\Programs\Startup\DiscinDisK.lnk
backup=c:\windows\pss\DiscinDisK.lnkStartup
[HKLM\~\startupfolder\C:^Documents and Settings^Ayyub Maadani^Start Menu^Programs^Startup^Wallpaper Changer.lnk]
path=c:\documents and settings\Ayyub Maadani\Start Menu\Programs\Startup\Wallpaper Changer.lnk
backup=c:\windows\pss\Wallpaper Changer.lnkStartup
[HKLM\~\startupfolder\C:^Documents and Settings^Ayyub Maadani^Start Menu^Programs^Startup^wpc.lnk]
path=c:\documents and settings\Ayyub Maadani\Start Menu\Programs\Startup\wpc.lnk
backup=c:\windows\pss\wpc.lnkStartup
"EnableFirewall"= 0 (0x0)
"c:\\Program Files\\Internet Explorer\\iexplore.exe"=
"c:\\Program Files\\Yahoo!\\Messenger\\YPager.exe"=
"c:\\Program Files\\Yahoo!\\Messenger\\YServer.exe"=
"c:\\Program Files\\EA GAMES\\The Battle for Middle-earth (tm)\\game.dat"=
"c:\\Program Files\\uTorrent\\uTorrent.exe"=
"c:\\Program Files\\Kontiki\\KService.exe"=
"c:\\Program Files\\McAfee\\MBK\\McAfeeDataBackup.exe"=
"c:\\Program Files\\Ares Destiny\\Ares.exe"=
"c:\\Program Files\\NetMeeting\\conf.exe"=
"c:\\WINDOWS\\SYSTEM32\\rtcshare.exe"=
"%windir%\\system32\\drivers\\svchost.exe"=
"c:\\Program Files\\Veoh Networks\\VeohWebPlayer\\veohwebplayer.exe"=
"c:\\WINDOWS\\SYSTEM32\\PnkBstrA.exe"=
"c:\\WINDOWS\\SYSTEM32\\PnkBstrB.exe"=
"c:\\Program Files\\WiFiConnector\\NintendoWFCReg.exe"=
"c:\\Program Files\\Common Files\\McAfee\\MNA\\McNASvc.exe"=
R2 0160741257500966mcinstcleanup;McAfee Application Installer Cleanup (0160741257500966);c:\windows\TEMP\016074~1.EXE [x]
R3 EMSLink;EMS Inter-Link driver V3.0;c:\windows\system32\Drivers\EM3Link.sys [2006-12-02 9744]
R4 LMIRfsClientNP;LMIRfsClientNP; [x]
S1 RapportKELL;RapportKELL;c:\program files\Trusteer\Rapport\bin\RapportKELL.sys [2009-08-18 58728]
S1 RapportPG;RapportPG;c:\program files\Trusteer\Rapport\bin\RapportPG.sys [2009-08-18 333928]
S2 LMIInfo;LogMeIn Kernel Information Provider;c:\program files\LogMeIn\x86\RaInfo.sys [2007-04-17 12992]
S2 LMIRfsDriver;LogMeIn Remote File System Driver;c:\windows\system32\drivers\LMIRfsDriver.sys [2007-04-05 46112]
S2 McAfee SiteAdvisor Service;McAfee SiteAdvisor Service;c:\program files\McAfee\SiteAdvisor\McSACore.exe [2009-09-16 92296]
S2 NinjaVideo Helper.exe;NinjaVideo Helper;c:\program files\NinjaVideo\NinjaVideo Helper\NinjaVideo Helper.exe [2008-04-10 110592]
S2 RapportMgmtService;Rapport Management Service;c:\program files\Trusteer\Rapport\bin\RapportMgmtService.exe [2009-08-18 955624]
S2 Viewpoint Manager Service;Viewpoint Manager Service;c:\program files\Viewpoint\Common\ViewpointService.exe [2007-01-04 24652]
S3 CDCCG;Machoman V-CD 0.53!machoman China;c:\windows\system32\Drivers\cdg.sys [2002-01-08 26640]
*NewlyCreated* - 0160741257500966MCINSTCLEANUP
*NewlyCreated* - MBR
*Deregistered* - mbr
2009-10-26 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 12:34]
2009-11-02 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-3333968868-2200709785-3983559585-1008Core.job
- c:\documents and settings\Ayyub Maadani\Local Settings\Application Data\Google\Update\GoogleUpdate.exe [2009-09-14 10:22]
2009-11-04 c:\windows\Tasks\GoogleUpdateTaskUserS-1-5-21-3333968868-2200709785-3983559585-1008UA.job
2004-10-14 c:\windows\Tasks\ISP signup reminder 1.job
- c:\windows\System32\OOBE\OOBEBALN.EXE [2002-08-29 00:12]
2008-07-15 c:\windows\Tasks\McDefragTask.job
- c:\program files\mcafee\mqc\QcConsol.exe [2007-01-13 11:22]
2009-09-01 c:\windows\Tasks\McQcTask.job
uStart Page =
IE: &Google Search - c:\program files\Google\GoogleToolbar1.dll/cmsearch.html
IE: &Translate English Word - c:\program files\Google\GoogleToolbar1.dll/cmwordtrans.html
IE: &Yahoo! Search - [You must be registered and logged in to see this link.] files\Yahoo!\Common/ycsrch.htm
IE: Backward Links - c:\program files\Google\GoogleToolbar1.dll/cmbacklinks.html
IE: Cached Snapshot of Page - c:\program files\Google\GoogleToolbar1.dll/cmcache.html
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~3\Office10\EXCEL.EXE/3000
IE: Search with Wanadoo - c:\progra~1\Wanadoo\WSBar\WSBar.dll/VSearch.htm
IE: Similar Pages - c:\program files\Google\GoogleToolbar1.dll/cmsimilar.html
IE: Translate Page into English - c:\program files\Google\GoogleToolbar1.dll/cmtrans.html
IE: Yahoo! &Dictionary - [You must be registered and logged in to see this link.] files\Yahoo!\Common/ycdict.htm
IE: Yahoo! &Maps - [You must be registered and logged in to see this link.] files\Yahoo!\Common/ycmap.htm
FF - ProfilePath - c:\documents and settings\Ayyub Maadani\Application Data\Mozilla\Firefox\Profiles\q4beip64.default\
FF - component: c:\documents and settings\Ayyub Maadani\Application Data\Mozilla\Firefox\Profiles\q4beip64.default\extensions\{19627815-20a6-46e6-be34-a0b6967c022a}\components\Engine.dll
FF - component: c:\program files\McAfee\SiteAdvisor\components\McFFPlg.dll
FF - plugin: c:\documents and settings\Ayyub Maadani\Application Data\Mozilla\Firefox\Profiles\q4beip64.default\extensions\battlefieldheroespatcher@ea.com\platform\WINNT_x86-msvc\plugins\npBFHUpdater.dll
FF - plugin: c:\documents and settings\Ayyub Maadani\Local Settings\Application Data\Google\Update\1.2.183.13\npGoogleOneClick8.dll
FF - plugin: c:\program files\Mozilla Firefox\plugins\NPMGWRAP.DLL
FF - plugin: c:\program files\Mozilla Firefox\plugins\npViewpoint.dll
FF - plugin: c:\program files\Veoh Networks\VeohWebPlayer\NPVeohTVPlugin.dll
FF - plugin: c:\program files\Veoh Networks\VeohWebPlayer\npWebPlayerVideoPluginATL.dll
HKCU-Run-WinDNN - c:\documents and settings\Ayyub Maadani\Application Data\Google\klnxv19819115.exe
HKCU-Run-Aim6 - (no file)
HKLM-Run-VirusScan - c:\progra~1\mcafee.com\vso\mcvsshld.exe
AddRemove-HijackThis - c:\documents and settings\Ayyub Maadani\My Documents\Downloads\HijackThis.exe
AddRemove-MyEmo - c:\program files\MyEmoticons\uninstall.exe
AddRemove-ShockwaveFlash - c:\windows\system32\Macromed\Flash\FlashUtil9b.exe
Rootkit scan 2009-11-06 16:33
scanning hȋdden processes ...
scanning hȋdden files ...
hȋdden files: 0
Stealth MBR rootkit/Mebroot/Sinowal detector 0.3.7 by Gmer, [You must be registered and logged in to see this link.]
device: opened successfully
user: MBR read successfully
called modules: ntoskrnl.exe CLASSPNP.SYS disk.sys iaStor.sys spyo.sys hal.dll >>UNKNOWN [0x87386938]<<
kernel: MBR read successfully
user & kernel MBR OK
iaStor.sys @ 0x0 0x0 bytes
\Driver\iaStor [ IRP_MJ_CREATE ] 0xF094 != 0xF74A9240 iaStor.sys
\Driver\iaStor [ IRP_MJ_CLOSE ] 0xF094 != 0xF74A9240 iaStor.sys
\Driver\iaStor [ IRP_MJ_DEVICE_CONTROL ] 0x127E8 != 0xF74A9240 iaStor.sys
\Driver\iaStor [ IRP_MJ_INTERNAL_DEVICE_CONTROL ] 0x12AA8 != 0xF74A9240 iaStor.sys
\Driver\iaStor [ IRP_MJ_POWER ] 0x17118 != 0xF74A9240 iaStor.sys
\Driver\iaStor [ IRP_MJ_SYSTEM_CONTROL ] 0x171A4 != 0xF74A9240 iaStor.sys
\Driver\iaStor IRP hooks detected !
- - - - - - - > 'winlogon.exe'(892)
c:\windows\system32\LMIinit.dll
c:\windows\system32\LMIRfsClientNP.dll
c:\windows\System32\Ati2evxx.exe
c:\program files\Bluetooth\Bluetooth Software\bin\btwdins.exe
c:\windows\System32\CTsvcCDA.exe
c:\program files\Intel\Intel Application Accelerator\iaantmon.exe
c:\program files\Kontiki\KService.exe
c:\progra~1\McAfee\MSC\mcmscsvc.exe
c:\program files\common files\mcafee\mna\mcnasvc.exe
c:\progra~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
c:\progra~1\McAfee\VIRUSS~1\mcshield.exe
c:\program files\McAfee\MSK\MskSrver.exe
c:\windows\system32\PnkBstrA.exe
c:\program files\CyberLink\Shared Files\RichVideo.exe
c:\windows\System32\MsPMSPSv.exe
c:\program files\Windows Media Player\WMPNetwk.exe
c:\progra~1\mcafee.com\agent\mcagent.exe
c:\program files\Dell Photo AIO Printer 922\dlbtbmon.exe
c:\documents and settings\Ayyub Maadani\Local Settings\Application Data\Google\Update\1.2.183.13\GoogleCrashHandler.exe
c:\program files\McAfee\MPF\MPFSrv.exe
Completion time: 2009-11-06 16:52 - machine was rebooted
ComboFix-quarantined-files.txt 2009-11-06 16:52
Pre-Run: 121,475,334,144 bytes free
Post-Run: 122,307,010,560 bytes free
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Home Edition" /fastdetect /NoExecute=OptIn
- - End Of File - - 9FE84045755CA4464A1E8BF935FD54FB
JohnKramer
Posts Posts : 14
Post by Origin on Sat Nov 07, 2009 7:39 pm
    :filefind
    scecli.dll
    netlogon.dll
    eventlog.dll
    cngaudit.dll
Posts Posts : 2685
Post by JohnKramer on Sat Nov 07, 2009 9:40 pm
SystemLook v1.0 by jpshortstuff (29.08.09)
Log created at 21:32 on 07/11/2009 by Ayyub Maadani (Administrator - Elevation successful)
C:\WINDOWS\ERDNT\cache\scecli.dll --a--- 181248 bytes [16:49 06/11/2009] [00:12 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
C:\WINDOWS\SYSTEM32\scecli.dll ------ 181248 bytes [04:00 29/08/2002] [00:12 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
C:\WINDOWS\ERDNT\cache\netlogon.dll --a--- 407040 bytes [16:49 06/11/2009] [00:12 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
C:\WINDOWS\SYSTEM32\netlogon.dll ------ 407040 bytes [04:00 29/08/2002] [00:12 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
No files found.
-=End Of File=-
JohnKramer
Posts Posts : 14
Post by Belahzur on Sun Nov 08, 2009 8:53 pm
  1. Close any open browsers.
    FCopy::
    c:\windows\$NtServicePackUninstall$\eventlog.dll | c:\windows\system32\eventlog.dll
Post by JohnKramer on Mon Nov 09, 2009 12:38 pm
ComboFix 09-11-08.03 - Ayyub Maadani 09/11/2009 10:35.2.2 - NTFSx86
Command switches used :: c:\documents and settings\Ayyub Maadani\Desktop\CFscript.txt
* Created a new restore point
c:\windows\$NtServicePackUninstall$\eventlog.dll --> c:\windows\system32\eventlog.dll
((((((((((((((((((((((((( Files Created from 2009-10-09 to 2009-11-09 )))))))))))))))))))))))))))))))
2009-11-09 10:35 . 2004-08-03 23:56 55808 ----a-w- c:\windows\system32\eventlog.dll
2009-11-09 10:35 . 2004-08-03 23:56 55808 ----a-w- c:\windows\system32\dllcache\eventlog.dll
2009-11-09 11:17 . 2008-01-26 22:04 -------- d-----w- c:\documents and settings\All Users\Application Data\Kontiki
2009-11-09 11:04 . 2007-11-07 18:30 -------- d-----w- c:\program files\lg_fwupdate
2009-11-09 10:57 . 2004-09-30 19:49 288 ----a-w- c:\windows\system32\DVCStateBkp-{00000004-00000000-00000000-00001102-00000004-10031102}.dat
2009-11-09 10:57 . 2004-09-30 19:49 288 ----a-w- c:\windows\system32\DVCState-{00000004-00000000-00000000-00001102-00000004-10031102}.dat
2009-11-09 10:04 . 2007-01-13 11:52 -------- d-----w- c:\program files\McAfee
+ 2009-11-09 10:58 . 2009-11-09 10:58 16384 c:\windows\Temp\Perflib_Perfdata_5f4.dat
+ 2009-11-09 10:58 . 2009-11-09 10:58 16384 c:\windows\Temp\Perflib_Perfdata_5e4.dat
+ 2002-09-03 01:08 . 2009-11-09 10:08 32768 c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\History\History.IE5\INDEX.DAT
- 2002-09-03 01:08 . 2009-11-06 15:42 32768 c:\windows\SYSTEM32\CONFIG\systemprofile\Local Settings\History\History.IE5\INDEX.DAT
+ 2009-11-06 19:57 . 2009-11-09 10:08 32768 c:\windows\SYSTEM32\CONFIG\systemprofile\Cookies\index.dat
- 2002-09-03 01:08 . 2009-11-06 15:42 32768 c:\windows\SYSTEM32\CONFIG\systemprofile\Cookies\INDEX.DAT
R2 0134541257761057mcinstcleanup;McAfee Application Installer Cleanup (0134541257761057);c:\windows\TEMP\013454~1.EXE [x]
*NewlyCreated* - 0134541257761057MCINSTCLEANUP
uStart Page =
Rootkit scan 2009-11-09 11:04
hȋdden files: 0
called modules: ntoskrnl.exe CLASSPNP.SYS disk.sys iaStor.sys spbm.sys hal.dll >>UNKNOWN [0x87386938]<<
- - - - - - - > 'winlogon.exe'(888)
- - - - - - - > 'explorer.exe'(5052)
c:\progra~1\mcafee\SITEAD~1\saHook.dll
c:\program files\Trusteer\Rapport\bin\rooksbas.dll
c:\progra~1\WINDOW~2\wmpband.dll
c:\windows\system32\btncopy.dll
c:\program files\ArcSoft\PhotoImpression 5\share\pihook.dll
Completion time: 2009-11-09 11:22 - machine was rebooted
ComboFix-quarantined-files.txt 2009-11-09 11:22
ComboFix2.txt 2009-11-06 16:52
Pre-Run: 122,053,271,552 bytes free
Post-Run: 122,030,059,520 bytes free
- - End Of File - - 330A92F90E02732F3822F3C17F8B6120
JohnKramer
Posts Posts : 14
Post by Belahzur on Mon Nov 09, 2009 8:35 pm
ComboFix /u
Post by JohnKramer on Mon Nov 09, 2009 11:33 pm
My computer has sped up and so is Firefox and Anti-Malware. However McAfee still comes up with the same error message and still won't scan.
"Scanning has encountered a problem from which it cannot recover. here are the problems details: - Error starting on demand scanner"
JohnKramer
Posts Posts : 14
Post by Belahzur on Tue Nov 10, 2009 5:28 pm
God this infection is annoying, it likes to leave it marks, guess we need to shift that too.
Please download [You must be registered and logged in to see this link.] file.
  • Please download Junction.zip and save it.
  • Unzip it and put junction.exe in the Windows directory (C:\Windows).
  • Go to Start => Run... => Copy and paste the following command in the run box and click OK:
    cmd /c junction -s c:\ >log.txt&log.txt& del log.txt
  • A command window opens starting to scan the system. Wait until a log file opens. Copy and paste or attach the content of it.
Post by JohnKramer on Tue Nov 10, 2009 7:21 pm
Gah, I meant to say both Firefox and Anti-Malware are working last time. I suck at typing see.
Junction v1.05 - Windows junction creator and reparse point viewer
Copyright (C) 2000-2007 Mark Russinovich
Systems Internals - [You must be registered and logged in to see this link.]
Failed to open \\?\c:\\hiberfil.sys: The process cannot access the file because it is being used by another process.
Failed to open \\?\c:\\pagefile.sys: The process cannot access the file because it is being used by another process.
Failed to open \\?\c:\\Documents and Settings\All Users\Application Data\Microsoft\Dr Watson\user.dmp: Access is denied.
Failed to open \\?\c:\\Program Files\Java\jre6\bin\java.exe: Access is denied.
Failed to open \\?\c:\\Program Files\McAfee\VirusScan\mcods.exe: Access is denied.
..\\?\c:\\WINDOWS\$hf_mig$\KB943460\KB943460: MOUNT POINT
Substitute Name: \Device\__max++>\^
\\?\c:\\WINDOWS\$hf_mig$\KB969059\KB969059: MOUNT POINT
.\\?\c:\\WINDOWS\$hf_mig$\KB971486\KB971486: MOUNT POINT
\\?\c:\\WINDOWS\$hf_mig$\KB973525\KB973525: MOUNT POINT
\\?\c:\\WINDOWS\$hf_mig$\KB974112\KB974112: MOUNT POINT
\\?\c:\\WINDOWS\$hf_mig$\KB974455-IE7\KB974455-IE7: MOUNT POINT
\\?\c:\\WINDOWS\$hf_mig$\KB974571\KB974571: MOUNT POINT
\\?\c:\\WINDOWS\$hf_mig$\KB975025\KB975025: MOUNT POINT
\\?\c:\\WINDOWS\$hf_mig$\KB975467\KB975467: MOUNT POINT
.\\?\c:\\WINDOWS\A4W_DATA\A4W_DATA: MOUNT POINT
\\?\c:\\WINDOWS\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a: JUNCTION
Print Name : C:\WINDOWS\WinSxS\x86_System.EnterpriseServices_b03f5f7f11d50a3a_2.0.0.0_x-ww_7d5f3790
Substitute Name: C:\WINDOWS\WinSxS\x86_System.EnterpriseServices_b03f5f7f11d50a3a_2.0.0.0_x-ww_7d5f3790
\\?\c:\\WINDOWS\assembly\GAC_MSIL\IEExecRemote\2.0.0.0__b03f5f7f11d50a3a: JUNCTION
Print Name : C:\WINDOWS\WinSxS\MSIL_IEExecRemote_b03f5f7f11d50a3a_2.0.0.0_x-ww_6e57c34e
Substitute Name: C:\WINDOWS\WinSxS\MSIL_IEExecRemote_b03f5f7f11d50a3a_2.0.0.0_x-ww_6e57c34e
.\\?\c:\\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAP1F9.tmp\ZAP1F9.tmp: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAP3A4.tmp\ZAP3A4.tmp: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAP48C.tmp\ZAP48C.tmp: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAP4AC.tmp\ZAP4AC.tmp: MOUNT POINT
\\?\c:\\WINDOWS\assembly\temp\temp: MOUNT POINT
\\?\c:\\WINDOWS\assembly\tmp\tmp: MOUNT POINT
\\?\c:\\WINDOWS\Cache\Adobe Reader 6.0\Adobe Reader 6.0: MOUNT POINT
\\?\c:\\WINDOWS\Config\Config: MOUNT POINT
\\?\c:\\WINDOWS\Connection Wizard\Connection Wizard: MOUNT POINT
.\\?\c:\\WINDOWS\Debug\UserMode\UserMode: MOUNT POINT
\\?\c:\\WINDOWS\ftpcache\ftpcache: MOUNT POINT
.\\?\c:\\WINDOWS\Help\SBSI\Training\WXPPer\Cbz\Cbz: MOUNT POINT
.\\?\c:\\WINDOWS\Help\SBSI\Training\WXPPer\Lib\Lib: MOUNT POINT
\\?\c:\\WINDOWS\Help\SBSI\Training\WXPPer\Wave\Wave: MOUNT POINT
.\\?\c:\\WINDOWS\IME\IMEJP\APPLETS\APPLETS: MOUNT POINT
\\?\c:\\WINDOWS\IME\IMEJP98\IMEJP98: MOUNT POINT
\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\0DC1503A46F231838AD88BCDDC8E8F7C\3.2.30729\3.2.30729: MOUNT POINT
\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\DC3BF90CC0D3D2F398A9A6D1762F70F3\2.2.30729\2.2.30729: MOUNT POINT
.\\?\c:\\WINDOWS\Microsoft.NET\Framework\v1.1.4322\Temporary ASP.NET Files\Bind Logs\Bind Logs: MOUNT POINT
.\\?\c:\\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET Files\Temporary ASP.NET Files: MOUNT POINT
\\?\c:\\WINDOWS\MSAPPS\MSINFO\MSINFO: MOUNT POINT
\\?\c:\\WINDOWS\msdownld.tmp\msdownld.tmp: MOUNT POINT
\\?\c:\\WINDOWS\MUI\MUI: MOUNT POINT
\\?\c:\\WINDOWS\New Folder\New Folder: MOUNT POINT
\\?\c:\\WINDOWS\PCHealth\HelpCtr\BATCH\BATCH: MOUNT POINT
\\?\c:\\WINDOWS\PCHealth\HelpCtr\Config\CheckPoint\CheckPoint: MOUNT POINT
.\\?\c:\\WINDOWS\PCHealth\HelpCtr\HelpFiles\HelpFiles: MOUNT POINT
\\?\c:\\WINDOWS\PCHealth\HelpCtr\InstalledSKUs\InstalledSKUs: MOUNT POINT
\\?\c:\\WINDOWS\PCHealth\HelpCtr\System\DFS\DFS: MOUNT POINT
.\\?\c:\\WINDOWS\PCHealth\HelpCtr\Temp\Temp: MOUNT POINT
.\\?\c:\\WINDOWS\Registration\CRMLog\CRMLog: MOUNT POINT
\\?\c:\\WINDOWS\SoftwareDistribution\AuthCabs\Downloaded\Downloaded: MOUNT POINT
\\?\c:\\WINDOWS\SoftwareDistribution\Download\37f6297b42610206c3fdeaf1ae71345e\backup\backup: MOUNT POINT
Failed to open \\?\c:\\WINDOWS\SoftwareDistribution\Download\37f6297b42610206c3fdeaf1ae71345e\update\update.exe: Access is denied.
Failed to open \\?\c:\\WINDOWS\SoftwareDistribution\Download\51401b498f4675531d9efb941ee01ef3\update\update.exe: Access is denied.
\\?\c:\\WINDOWS\SoftwareDistribution\Download\5cfa09586faf6d9470f0c817d855bb6b\backup\backup: MOUNT POINT
Failed to open \\?\c:\\WINDOWS\SoftwareDistribution\Download\5cfa09586faf6d9470f0c817d855bb6b\update\update.exe: Access is denied.
Failed to open \\?\c:\\WINDOWS\SoftwareDistribution\Download\71668abe67b6d77ebac6750f25908a6e\update\update.exe: Access is denied.
\\?\c:\\WINDOWS\SoftwareDistribution\Download\85947e1a809663c7f480717673587a59\backup\backup: MOUNT POINT
Failed to open \\?\c:\\WINDOWS\SoftwareDistribution\Download\85947e1a809663c7f480717673587a59\update\update.exe: Access is denied.
Failed to open \\?\c:\\WINDOWS\SoftwareDistribution\Download\8fa1ad7968e63408057364ad07aa482c\update\update.exe: Access is denied.
\\?\c:\\WINDOWS\SoftwareDistribution\Download\9868363812bbe4a0a4d814b7943ba906\backup\backup: MOUNT POINT
Failed to open \\?\c:\\WINDOWS\SoftwareDistribution\Download\9868363812bbe4a0a4d814b7943ba906\update\update.exe: Access is denied.
\\?\c:\\WINDOWS\SoftwareDistribution\Download\d3767eab8f4479a8d252b47e8ec225c8\backup\backup: MOUNT POINT
Failed to open \\?\c:\\WINDOWS\SoftwareDistribution\Download\d3767eab8f4479a8d252b47e8ec225c8\update\update.exe: Access is denied.
Failed to open \\?\c:\\WINDOWS\SoftwareDistribution\Download\e15760431e46367ca5a3dfd40a9d03e3\update\update.exe: Access is denied.
Failed to open \\?\c:\\WINDOWS\SoftwareDistribution\Download\fbdd9f75315c1cf9ff63f37aaca267d3\update\update.exe: Access is denied.
.\\?\c:\\WINDOWS\STPV temp\STPV temp: MOUNT POINT
\\?\c:\\WINDOWS\Sun\Java\Deployment\Deployment: MOUNT POINT
Failed to open \\?\c:\\WINDOWS\SYSTEM32\MRT.exe: Access is denied.
Failed to open \\?\c:\\WINDOWS\SYSTEM32\WBEM\wmiprvse.exe: Access is denied.
\\?\c:\\WINDOWS\WinSxS\InstallTemp\InstallTemp: MOUNT POINT
JohnKramer
Posts Posts : 14
Joined Joined : 2009-11-01
Points Points : 25926
Re: Help with virus disabling malware and virus scan
Post by Belahzur on Tue Nov 10, 2009 7:59 pm
Like you did with juntion.exe, place inherit.exe into the Windows folder.
Now open a new notepad file.
@echo off
"inherit.exe" "c:\Program Files\McAfee\VirusScan\mcods.exe"
"inherit.exe" "c:\Program Files\Java\jre6\bin\java.exe"
"inherit.exe" "c:\WINDOWS\SYSTEM32\MRT.exe"
exit
Save this as fix.bat, save it to your desktop.
Let it run until it says OK on each one.
Points Points : 245059
Post by JohnKramer on Wed Nov 11, 2009 2:04 pm
Ok, I've done that. Is there anything else?
JohnKramer
Posts Posts : 14
Post by Belahzur on Wed Nov 11, 2009 8:18 pm
Nope, that should be it. Does Mcafee work now?
Post by JohnKramer on Wed Nov 11, 2009 10:17 pm
Yes, it seems to be working fine. Smile
Thanks so much. I've already recommended you guys to my friends
Thank You!
JohnKramer
Posts Posts : 14
Post by Belahzur on Wed Nov 11, 2009 11:01 pm
