Need help! Antivirus system pro - can't run downloads
Post by MDGuyy on 31st October 2009, 4:59 am
Hey,
My gf lovingly infected her laptop with the Antivirus System Pro (Win32/Nuqel.E as well as the BankerFox.A one as well) Where it launches the websites repeatedly, and most inconveniently, BLOCKS all .exe and other files that you recommend to use to clean it off. I tried locating some of the files (mixed sucess) and deleted those but really didn't seem to affect anything.
How do I go about conquering this thing? I can download everything, but when I go to run it it fails and throws up a (trojan produced) box that says it cannot be completed and holts the process.
Any help would be appreciated, I've already wasted 3+ hours on this and have pretty much gone no where.
SC
MDGuyy
Joined Joined : 2009-10-31
OS OS : XP?
Points Points : 25964
Re: Need help! Antivirus system pro - can't run downloads
Post by Dr Jay on 31st October 2009, 5:17 am
Please download this file: [You must be registered and logged in to see this link.] and save it to your desktop
Double click on exe_fix.com to run it
Type the number 1 at the prompt and allow the tool to run
Posts Posts : 14308
Points Points : 302959
Thanks but.......
Post by MDGuyy on 31st October 2009, 5:31 am
Thanks for the quick reply, however every time I try to do anything, whether its download something and open it, or simply try to open solitaire, I get this message "Application cannot be executed. the file (name).exe/etc (or in this case, the exe_....com) is infected. Do you want to activate your antivirus software now?"
I can't get around this, any application be it exe or otherwise is jammed by this trojan - so nothing I download will work - any thoughts on getting around it?
MDGuyy
OS OS : XP?
Post by Dr Jay on 31st October 2009, 5:44 am
Please reboot to Safe Mode with Networking (tap the F8 key just before Windows starts to load and select the Safe Mode with Networking option from the menu).
Then, please repeat the steps above.
Posts Posts : 14308
