Mcafee Error Starting on demand scanner - help!
Post by BarryD on 30th October 2009, 10:34 pm
Looks like i've picked up some nasty visru from somewhere I get redirected to some odd looking sites in google and if I try to do a scan with Mcafee i get this error:
I've tried spybot but that just closes automatically and Malwarebytes' Anti-Malware does the same so I'm a bit stuck!
I tried running the hijackthis program and got this:
'An unexpected error has occured at procedure: modRegistry_Inigetstring(sFile=win.ini, sSection=windows, sValue=load)
Error #5 - invalid procedure call or argument
Please help, I've no idea what to try next
BarryD
Posts Posts : 13
Joined Joined : 2009-10-30
Points Points : 25975
Re: Mcafee Error Starting on demand scanner - help!
Post by BarryD on 30th October 2009, 10:40 pm
update: i got hijackthis to run a couple of times but it closed itself before i had time to copy and paste the text, now it wont run at all
BarryD
Posts Posts : 13
Post by BarryD on 30th October 2009, 10:58 pm
another update: Systemlook gave me this:
Searching for "scecli.dll"
C:\WINDOWS\$NtServicePackUninstall$\scecli.dll -----c 180224 bytes [17:41 02/08/2008] [19:00 10/08/2004] 0F78E27F563F2AAF74B91A49E2ABF19A
C:\WINDOWS\ServicePackFiles\i386\scecli.dll ------ 181248 bytes [17:35 02/08/2008] [00:12 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
C:\WINDOWS\system32\scecli.dll --a--- 181248 bytes [17:56 07/03/2019] [00:12 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
Searching for "netlogon.dll"
C:\WINDOWS\$NtServicePackUninstall$\netlogon.dll -----c 407040 bytes [17:41 02/08/2008] [19:00 10/08/2004] 96353FCECBA774BB8DA74A1C6507015A
C:\WINDOWS\ServicePackFiles\i386\netlogon.dll ------ 407040 bytes [17:35 02/08/2008] [00:12 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
C:\WINDOWS\system32\netlogon.dll --a--- 407040 bytes [17:56 07/03/2019] [00:12 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
Searching for "eventlog.dll"
C:\WINDOWS\$NtServicePackUninstall$\eventlog.dll -----c 55808 bytes [17:41 02/08/2008] [19:00 10/08/2004] 82B24CB70E5944E6E34662205A2A5B78
C:\WINDOWS\ServicePackFiles\i386\eventlog.dll ------ 56320 bytes [17:33 02/08/2008] [00:11 14/04/2008] 6D4FEB43EE538FC5428CC7F0565AA656
C:\WINDOWS\system32\eventlog.dll --a--- 61952 bytes [17:56 07/03/2019] [00:11 14/04/2008] (Unable to calculate MD5)
Searching for "cngaudit.dll"
No files found.
BarryD
Posts Posts : 13
Post by Belahzur on 31st October 2009, 12:09 am
Files to delete:
Points Points : 245091
Post by BarryD on 31st October 2009, 12:21 am
when i try to extract the avenger.zip mcafee tells me its blocked 'backdoor-EFN' trojan so wont let me run it
do i need to disable mcafee?
BarryD
Posts Posts : 13
Post by BarryD on 31st October 2009, 12:29 am
Platform: Windows XP
Rootkit scan active.
No rootkits found!
File "C:\WINDOWS\system32\eventlog.dll" deleted successfully.
Completed script processing.
Finished! Terminate.
BarryD
Posts Posts : 13
Post by Belahzur on 31st October 2009, 8:14 pm
Post by BarryD on 31st October 2009, 9:05 pm
Database version: 3071
31/10/2009 21:01:20
mbam-log-2009-10-31 (21-01-20).txt
Objects scanned: 120980
Time elapsed: 9 minute(s), 46 second(s)
Registry Keys Infected: 12
Registry Values Infected: 2
Folders Infected: 2
Files Infected: 10
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{2d2bee6e-3c9a-4d58-b9ec-458edb28d0f6} (Rogue.DriveCleaner) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{1a26f07f-0d60-4835-91cf-1e1766a0ec56} (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_USERS\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\{19127ad2-394b-70f5-c650-b97867baa1f7} (Backdoor.Bot) -> Quarantined and deleted successfully.
HKEY_USERS\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\{43bf8cd1-c5d5-2230-7bb2-98f22c2b7dc6} (Backdoor.Bot) -> Quarantined and deleted successfully.
HKEY_USERS\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\{494e6cec-7483-a4ee-0938-895519a84bc7} (Backdoor.Bot) -> Quarantined and deleted successfully.
HKEY_USERS\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\{19127ad2-394b-70f5-c650-b97867baa1f7} (Backdoor.Bot) -> Quarantined and deleted successfully.
HKEY_USERS\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\{43bf8cd1-c5d5-2230-7bb2-98f22c2b7dc6} (Backdoor.Bot) -> Quarantined and deleted successfully.
HKEY_USERS\S-1-5-18\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\{494e6cec-7483-a4ee-0938-895519a84bc7} (Backdoor.Bot) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\NordBull (Malware.Trace) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\XML (Trojan.FakeAlert) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Software Notifier (Rogue.Multiple) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\poprock (Trojan.Downloader) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Network\UID (Malware.Trace) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\rhceg1j0enae (Rogue.AntiVirusXP) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Start_ShowSearch (Hijack.StartMenu) -> Bad: (0) Good: (1) -> Quarantined and deleted successfully.
C:\Documents and Settings\All Users\Application Data\CrucialSoft Ltd (Rogue.Multiple) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\lowsec (Stolen.data) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\xa.tmp (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\lowsec\local.ds (Stolen.data) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\lowsec\user.ds (Stolen.data) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\sdra64.exe (Spyware.Zbot) -> Quarantined and deleted successfully.
C:\WINDOWS\Fonts\acrsecB.fon (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\Fonts\acrsecI.fon (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\Tasks\{7B02EF0B-A410-4938-8480-9BA26420A627}.job (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\Tasks\{BB65B0FB-5712-401b-B616-E69AC55E2757}.job (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\win32k.sys (Trojan.Dropper) -> Quarantined and deleted successfully.
C:\Documents and Settings\BarryD\Desktop\winlogon.scr (Heuristics.Reserved.Word.Exploit) -> Quarantined and deleted successfully.
BarryD
Posts Posts : 13
Post by BarryD on 1st November 2009, 12:10 am
I'm still getting the same mcafee error and spybot wont run at all so I guess i'm not out of the woods yet?
currently running a full scan with malwarebytes, nearly 2 hours in and 1 infected object found so far.....
BarryD
Posts Posts : 13
Post by Belahzur on 1st November 2009, 10:46 pm
  • Download combofix from here
Post by BarryD on 1st November 2009, 11:32 pm
ComboFix 09-10-30.01 - BarryD 01/11/2009 23:08.1.2 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.3.1252.44.1033.18.1023.572 [GMT 0]
Running from: c:\documents and settings\BarryD\Desktop\Combo-Fix.exe
* Created a new restore point
* Resident AV is active
C:\cleanup.exe
c:\recycler\S-1-5-21-1786715176-3111723283-1950669573-500
c:\windows\desktop
c:\windows\desktop\Virtual Pool 3.lnk
c:\windows\emMON.exe
c:\windows\Fonts\acrsec.fon
c:\windows\kb913800.exe
c:\windows\run.log
c:\windows\system32\Cache
c:\windows\system32\clrviddc.dll
c:\windows\system32\images
c:\windows\system32\images\Thumbs.db
c:\windows\system32\tmp40.tmp
F:\Autorun.inf
Infected copy of c:\windows\system32\DRIVERS\atapi.sys was found and disinfected
Restored copy from - Kitty ate it :p
-------\Legacy_{79007602-0CDB-4405-9DBF-1257BB3226EE}
((((((((((((((((((((((((( Files Created from 2009-10-01 to 2009-11-01 )))))))))))))))))))))))))))))))
2019-03-07 17:56 . 2009-08-29 07:36 832512 -c--a-w- c:\windows\system32\dllcache\wininet.dll
2019-03-07 17:53 . 2019-03-07 17:53 -------- d-----w- C:\cmpnents
2009-11-01 20:42 . 2009-11-01 20:43 -------- d-----w- c:\program files\Spybot - Search and Destroy
2009-11-01 20:33 . 2009-11-01 20:33 -------- d--h--w- c:\windows\PIF
2009-10-30 22:44 . 2009-10-30 22:45 -------- d-----w- c:\program files\Common Files\Adobe
2009-10-30 22:23 . 2009-10-30 22:28 -------- d-----w- c:\documents and settings\BarryD\.SunDownloadManager
2009-10-30 19:48 . 2009-10-30 19:48 -------- d-----w- c:\documents and settings\BarryD\Application Data\Malwarebytes
2009-10-30 19:48 . 2009-09-10 14:54 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-10-30 19:48 . 2009-10-30 19:48 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2009-10-30 19:48 . 2009-09-10 14:53 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-10-30 19:48 . 2009-10-31 20:44 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-10-16 17:16 . 2009-09-06 07:09 126976 -c----w- c:\windows\system32\dllcache\ftpsvc2.dll
2009-10-13 20:49 . 2009-10-13 20:49 120 ----a-w- C:\drmHeader.bin
2009-11-01 22:51 . 2007-01-07 23:59 -------- d-----w- c:\documents and settings\BarryD\Application Data\BitTorrent
2009-11-01 21:42 . 2009-04-01 21:48 -------- d-----w- c:\documents and settings\BarryD\Application Data\HPAppData
2009-11-01 21:08 . 2007-01-08 18:02 -------- d-----w- c:\documents and settings\All Users\Application Data\Spybot - Search & Destroy
2009-11-01 20:39 . 2007-01-08 18:01 -------- d-----w- c:\program files\Spybot - Search & Destroy
2009-11-01 19:15 . 2007-01-02 20:29 -------- d-----w- c:\program files\McAfee
2009-10-30 00:25 . 2006-09-23 06:50 88776 ----a-w- c:\documents and settings\BarryD\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-10-29 23:59 . 2008-10-25 14:06 -------- d-----w- c:\documents and settings\All Users\Application Data\Microsoft Help
2009-10-29 23:56 . 2008-10-25 14:15 -------- d-----w- c:\program files\Microsoft Works
2009-10-21 22:20 . 2007-04-25 19:36 -------- d-----w- c:\program files\Winamp
2009-09-27 22:35 . 2009-09-27 22:35 71960 ---ha-w- c:\windows\system32\mlfcache.dat
2009-09-27 22:33 . 2007-04-14 15:08 -------- d-----w- c:\documents and settings\BarryD\Application Data\Apple Computer
2009-09-27 22:01 . 2009-09-27 21:59 -------- d-----w- c:\program files\iTunes
2009-09-27 22:01 . 2009-09-27 21:59 -------- d-----w- c:\documents and settings\All Users\Application Data\{755AC846-7372-4AC8-8550-C52491DAA8BD}
2009-09-27 21:59 . 2009-09-27 21:59 -------- d-----w- c:\program files\iPod
2009-09-27 21:59 . 2007-12-26 22:47 -------- d-----w- c:\program files\Common Files\Apple
2009-09-27 21:56 . 2009-09-27 21:55 -------- d-----w- c:\program files\QuickTime
2009-09-27 21:45 . 2009-09-27 21:45 -------- d-----w- c:\program files\iPhone Configuration Utility
2009-09-25 22:01 . 2008-09-29 20:40 -------- d-----w- c:\documents and settings\LocalService\Application Data\SACore
2009-09-16 09:22 . 2007-04-22 09:55 40552 ----a-w- c:\windows\system32\drivers\mfesmfk.sys
2009-09-16 09:22 . 2007-04-22 09:55 35272 ----a-w- c:\windows\system32\drivers\mfebopk.sys
2009-09-16 09:22 . 2007-04-22 09:55 214664 ----a-w- c:\windows\system32\drivers\mfehidk.sys
2009-09-16 09:22 . 2007-04-22 09:55 79816 ----a-w- c:\windows\system32\drivers\mfeavfk.sys
2009-09-16 09:22 . 2007-04-22 09:55 34248 ----a-w- c:\windows\system32\drivers\mferkdk.sys
2009-09-11 14:18 . 2019-03-07 17:56 136192 ----a-w- c:\windows\system32\msv1_0.dll
2009-09-10 17:05 . 2009-06-30 17:28 -------- d-----w- c:\program files\Microsoft Silverlight
2009-09-08 18:21 . 2009-08-31 20:42 -------- d-----w- c:\documents and settings\BarryD\Application Data\HpUpdate
2009-09-04 21:03 . 2019-03-07 17:56 58880 ----a-w- c:\windows\system32\msasn1.dll
2009-09-01 21:46 . 2009-09-01 21:21 116839 ----a-w- c:\windows\hpqins00.dat
2009-08-29 07:36 . 2019-03-07 17:56 832512 ----a-w- c:\windows\system32\wininet.dll
2009-08-29 07:36 . 2019-03-07 17:56 78336 ----a-w- c:\windows\system32\ieencode.dll
2009-08-29 07:36 . 2019-03-07 17:56 17408 ----a-w- c:\windows\system32\corpol.dll
2009-08-28 18:42 . 2009-03-26 21:04 2065696 ----a-w- c:\windows\system32\usbaaplrc.dll
2009-08-28 18:42 . 2007-12-26 22:48 40448 ----a-w- c:\windows\system32\drivers\usbaapl.sys
2009-08-26 08:00 . 2019-03-07 17:57 247326 ----a-w- c:\windows\system32\strmdll.dll
2009-08-17 22:33 . 2009-08-17 22:33 1193832 ----a-w- c:\windows\system32\FM20.DLL
2009-08-06 19:24 . 2005-12-02 08:45 327896 ----a-w- c:\windows\system32\wucltui.dll
2009-08-06 19:24 . 2005-12-02 08:45 209632 ----a-w- c:\windows\system32\wuweb.dll
2009-08-06 19:24 . 2005-12-02 08:45 35552 ----a-w- c:\windows\system32\wups.dll
2009-08-06 19:24 . 2005-05-26 03:16 44768 ----a-w- c:\windows\system32\wups2.dll
2009-08-06 19:24 . 2005-12-02 08:45 53472 ----a-w- c:\windows\system32\wuauclt.exe
2009-08-06 19:24 . 2019-03-07 17:56 96480 ----a-w- c:\windows\system32\cdm.dll
2009-08-06 19:23 . 2005-12-02 08:45 575704 ----a-w- c:\windows\system32\wuapi.dll
2009-08-06 19:23 . 2008-10-25 14:21 274288 ----a-w- c:\windows\system32\mucltui.dll
2009-08-06 19:23 . 2008-10-25 14:21 215920 ----a-w- c:\windows\system32\muweb.dll
2009-08-06 19:23 . 2005-12-02 08:45 1929952 ----a-w- c:\windows\system32\wuaueng.dll
2009-08-05 09:01 . 2019-03-07 17:56 204800 ----a-w- c:\windows\system32\mswebdvd.dll
2009-08-04 15:13 . 2004-08-03 23:18 2145280 ----a-w- c:\windows\system32\ntoskrnl.exe
2009-08-04 14:20 . 2004-08-03 22:59 2023936 ----a-w- c:\windows\system32\ntkrnlpa.exe
2007-01-08 15:30 . 2007-01-08 15:30 37152 ----a-w- c:\program files\MC
------- Sigcheck -------
[7] 2008-04-14 . 6D4FEB43EE538FC5428CC7F0565AA656 . 56320 . . [5.1.2600.5512] . . c:\windows\ServicePackFiles\i386\eventlog.dll
[-] 2004-08-10 . 82B24CB70E5944E6E34662205A2A5B78 . 55808 . . [5.1.2600.2180] . . c:\windows\$NtServicePackUninstall$\eventlog.dll
c:\windows\system32\eventlog.dll ... is missing !!
"WMPNSCFG"="c:\program files\Windows Media Player\WMPNSCFG.exe" [2006-10-18 204288]
"SpybotSD TeaTimer"="c:\program files\Spybot - Search and Destroy\TeaTimer.exe" [2009-03-05 2260480]
"ehTray"="c:\windows\ehome\ehtray.exe" [2005-08-05 64512]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2006-08-11 7630848]
"NvMediaCenter"="c:\windows\system32\NvMcTray.dll" [2006-08-11 86016]
"McENUI"="c:\progra~1\McAfee\MHN\McENUI.exe" [2009-07-07 1176808]
"mcagent_exe"="c:\program files\McAfee.com\Agent\mcagent.exe" [2009-09-17 645328]
"GrooveMonitor"="c:\program files\Microsoft Office\Office12\GrooveMonitor.exe" [2008-10-25 31072]
"TkBellExe"="c:\program files\Common Files\Real\Update_OB\realsched.exe" [2007-04-03 185896]
"HP Software Update"="c:\program files\HP\HP Software Update\HPWuSchd2.exe" [2007-10-14 49152]
"hpqSRMon"="c:\program files\HP\Digital Imaging\bin\hpqSRMon.exe" [2007-08-22 80896]
"AppleSyncNotifier"="c:\program files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe" [2009-08-13 177440]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2009-07-25 149280]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2009-09-05 417792]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2009-09-21 305440]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 9.0\Reader\Reader_sl.exe" [2009-10-03 35696]
"Adobe ARM"="c:\program files\Common Files\Adobe\ARM\1.0\AdobeARM.exe" [2009-09-04 935288]
"Ptipbmf"="ptipbmf.dll" - c:\windows\system32\ptipbmf.dll [2003-06-20 118784]
"High Definition Audio Property Page Shortcut"="HDAShCut.exe" - c:\windows\system32\HdAShCut.exe [2004-10-27 61952]
"nwiz"="nwiz.exe" - c:\windows\system32\nwiz.exe [2006-08-11 1519616]
"CTHelper"="CTHELPER.EXE" - c:\windows\CTHELPER.EXE [2005-06-18 16384]
"CTFMON.EXE"="c:\windows\system32\CTFMON.EXE" [2008-04-14 15360]
c:\documents and settings\BarryD\Start Menu\Programs\Startup\
OneNote 2007 Screen Clipper and Launcher.lnk - c:\program files\Microsoft Office\Office12\ONENOTEM.EXE [2008-10-25 98696]
HP Digital Imaging Monitor.lnk - c:\program files\HP\Digital Imaging\bin\hpqtra08.exe [2008-3-25 214360]
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Adobe Reader Speed Launch.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Adobe Reader Speed Launch.lnk
backup=c:\windows\pss\Adobe Reader Speed Launch.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Microsoft Office.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Microsoft Office.lnk
backup=c:\windows\pss\Microsoft Office.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Picture Package Menu.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Picture Package Menu.lnk
backup=c:\windows\pss\Picture Package Menu.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Picture Package VCD Maker.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Picture Package VCD Maker.lnk
backup=c:\windows\pss\Picture Package VCD Maker.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Service Manager.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Service Manager.lnk
backup=c:\windows\pss\Service Manager.lnkCommon Startup
"Autodesk Licensing Service"=3 (0x3)
"iPod Service"=3 (0x3)
"Bonjour Service"=2 (0x2)
"EnableFirewall"= 0 (0x0)
"c:\\Program Files\\CyberLink\\PowerCinema\\PowerCinema.exe"=
"c:\\Program Files\\BitTorrent\\bittorrent.exe"=
"c:\\Program Files\\Valve\\Steam\\SteamApps\\barryD\\half-life deathmatch source\\hl2.exe"=
"c:\\Program Files\\Valve\\Steam\\SteamApps\\barryD\\counter-strike source\\hl2.exe"=
"c:\\Program Files\\Valve\\Steam\\SteamApps\\barryD\\half-life 2 deathmatch\\hl2.exe"=
"c:\\Program Files\\Real\\RealOne Player\\trueplay.exe"=
"c:\\Program Files\\McAfee\\MBK\\McAfeeDataBackup.exe"=
"c:\\Program Files\\DC++\\DCPlusPlus.exe"=
"c:\\Program Files\\Valve\\Steam\\SteamApps\\barryD\\source dedicated server\\srcds.exe"=
"c:\\Program Files\\Microsoft Office\\Office12\\GROOVE.EXE"=
"c:\\Program Files\\Valve\\Steam\\Steam.exe"=
"c:\\Program Files\\Sports Interactive\\Football Manager 2007\\fm.exe"=
"c:\\Program Files\\Valve\\Steam\\SteamApps\\common\\left 4 dead demo\\left4dead.exe"=
"c:\\Program Files\\HP\\Digital Imaging\\bin\\hpiscnapp.exe"=
"c:\\Program Files\\KONAMI\\Pro Evolution Soccer 2009\\pes2009.exe"=
"%windir%\\system32\\drivers\\svchost.exe"=
"c:\\Program Files\\Common Files\\McAfee\\MNA\\McNASvc.exe"=
R2 McAfee SiteAdvisor Service;McAfee SiteAdvisor Service;c:\program files\McAfee\SiteAdvisor\McSACore.exe [29/09/2008 19:03 206096]
R2 MSSQL$INVENTORCONTENT;MSSQL$INVENTORCONTENT;c:\program files\Microsoft SQL Server\MSSQL$INVENTORCONTENT\Binn\sqlservr.exe -sINVENTORCONTENT --> c:\program files\Microsoft SQL Server\MSSQL$INVENTORCONTENT\Binn\sqlservr.exe -sINVENTORCONTENT [?]
R3 AtcL001;NDIS Miniport Driver for Attansic L1 Gigabit Ethernet Adapter;c:\windows\system32\drivers\atl01_xp.sys [13/09/2006 23:15 34944]
S3 ASPI;Advanced SCSI Programming Interface Driver;c:\windows\system32\drivers\ASPI32.SYS [15/07/2007 21:54 16877]
S3 bfastfao;bfastfao;\??\c:\docume~1\BARRYD~1\LOCALS~1\Temp\bfastfao.sys --> c:\docume~1\BARRYD~1\LOCALS~1\Temp\bfastfao.sys [?]
S3 SQLAgent$INVENTORCONTENT;SQLAgent$INVENTORCONTENT;c:\program files\Microsoft SQL Server\MSSQL$INVENTORCONTENT\Binn\sqlagent.EXE -i INVENTORCONTENT --> c:\program files\Microsoft SQL Server\MSSQL$INVENTORCONTENT\Binn\sqlagent.EXE -i INVENTORCONTENT [?]
S3 xlink;XLink Driver (xlink.sys);c:\windows\system32\drivers\xlink.sys [26/09/2007 21:44 19677]
S4 m5287;m5287;c:\windows\system32\drivers\m5287.sys [02/12/2005 17:08 85888]
S4 m5289;m5289;c:\windows\system32\drivers\m5289.sys [02/12/2005 17:08 51840]
*NewlyCreated* - CLASSPNP_2
*NewlyCreated* - MBR
*Deregistered* - CLASSPNP_2
*Deregistered* - mbr
HPZ12 REG_MULTI_SZ Pml Driver HPZ12 Net Driver HPZ12
hpdevmgmt REG_MULTI_SZ hpqcxs08 hpqddsvc
2008-08-09 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 11:34]
2007-04-22 c:\windows\Tasks\McDefragTask.job
- c:\program files\mcafee\mqc\QcConsol.exe [2007-04-22 11:22]
2007-07-01 c:\windows\Tasks\McQcTask.job
IE: Sothink SWF Catcher - c:\program files\Common Files\SourceTec\SWF Catcher\InternetExplorer.htm
IE: {{08E730A4-FB02-45BD-A900-01E4AD8016F6} - [You must be registered and logged in to see this link.]
Trusted Zone: peeron.com\www
HKCU-Run-PowerBar - (no file)
AddRemove-HijackThis - c:\documents and settings\BarryD\Local Settings\Temporary Internet Files\Content.IE5\6FTV44CO\HijackThis.exe
Rootkit scan 2009-11-01 23:21
scanning hȋdden processes ...
CTHelper = CTHELPER.EXE?
scanning hȋdden files ...
hȋdden files: 0
- - - - - - - > 'explorer.exe'(556)
c:\program files\McAfee\SiteAdvisor\saHook.dll
c:\program files\CyberLink\PowerCinema\Kernel\TV\CLCapSvc.exe
c:\program files\CyberLink\PowerCinema\Kernel\TV\CLSched.exe
c:\program files\CyberLink\Shared Files\CLML_NTService\CLMLServer.exe
c:\windows\eHome\ehRecvr.exe
c:\program files\CyberLink\Shared Files\CLML_NTService\CLMLService.exe
c:\windows\eHome\ehSched.exe
c:\windows\system32\inetsrv\inetinfo.exe
c:\progra~1\McAfee\MSC\mcmscsvc.exe
c:\program files\common files\mcafee\mna\mcnasvc.exe
c:\progra~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
c:\progra~1\McAfee\VIRUSS~1\mcshield.exe
c:\program files\McAfee\MSK\MskSrver.exe
c:\program files\CyberLink\Shared Files\RichVideo.exe
c:\progra~1\mcafee.com\agent\mcagent.exe
c:\program files\Windows Media Player\WMPNetwk.exe
c:\windows\eHome\ehmsas.exe
c:\program files\HP\Digital Imaging\bin\hpqSTE08.exe
c:\program files\HP\Digital Imaging\bin\hpqbam08.exe
c:\program files\HP\Digital Imaging\bin\hpqgpc01.exe
c:\windows\system32\dllhost.exe
c:\program files\McAfee\MPF\MPFSrv.exe
Completion time: 2009-11-01 23:28 - machine was rebooted
ComboFix-quarantined-files.txt 2009-11-01 23:28
Pre-Run: 170,484,805,632 bytes free
Post-Run: 170,323,681,280 bytes free
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Windows XP Media Center Edition" /noexecute=optin /fastdetect
- - End Of File - - 698EB89EC021D950587CF025D67B2CF0
BarryD
Posts Posts : 13
Post by BarryD on 1st November 2009, 11:44 pm
Mcafee still gives me the same message when i try and scan
I uninstalled spybot and re-installed it (had to put it in a different folder as i cant delete 'SpybotSD.exe' but it works fine now.
BarryD
Posts Posts : 13
Post by Belahzur on 2nd November 2009, 1:04 am
This malware has the ability to change file permissions which cause this problem, we can fix it, but not just yet, there are still other issues.
  1. Close any open browsers.
    FCopy::
    c:\windows\$NtServicePackUninstall$\eventlog.dll | c:\windows\system32\eventlog.dll
    Driver::
    bfastfao
Post by BarryD on 2nd November 2009, 6:38 pm
ComboFix 09-11-01.04 - BarryD 02/11/2009 18:16.2.2 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.3.1252.44.1033.18.1023.532 [GMT 0:00]
Command switches used :: c:\documents and settings\BarryD\Desktop\CFScript.txt
c:\windows\$NtServicePackUninstall$\eventlog.dll --> c:\windows\system32\eventlog.dll
-------\Legacy_BFASTFAO
-------\Service_bfastfao
((((((((((((((((((((((((( Files Created from 2009-10-02 to 2009-11-02 )))))))))))))))))))))))))))))))
2009-11-02 18:16 . 2008-04-14 00:11 56320 -c--a-w- c:\windows\system32\dllcache\eventlog.dll
2009-11-02 18:16 . 2008-04-14 00:11 56320 ----a-w- c:\windows\system32\eventlog.dll
2009-11-02 18:02 . 2009-11-02 18:16 -------- d-----w- c:\windows\LastGood.Tmp
2009-11-02 18:12 . 2009-04-01 21:48 -------- d-----w- c:\documents and settings\BarryD\Application Data\HPAppData
2009-11-02 18:02 . 2007-01-02 20:29 -------- d-----w- c:\program files\McAfee
2009-11-01 23:57 . 2007-01-07 23:59 -------- d-----w- c:\documents and settings\BarryD\Application Data\BitTorrent
2009-08-29 07:36 . 2019-03-07 17:56 832512 ------w- c:\windows\system32\wininet.dll
2009-08-06 19:24 . 2005-12-02 08:45 53472 ------w- c:\windows\system32\wuauclt.exe
+ 2009-11-02 18:27 . 2009-11-02 18:27 16384 c:\windows\Temp\Perflib_Perfdata_bc.dat
+ 2009-11-02 18:27 . 2009-11-02 18:27 16384 c:\windows\Temp\Perflib_Perfdata_56c.dat
+ 2005-12-02 08:49 . 2009-11-02 18:02 32768 c:\windows\system32\config\systemprofile\Local Settings\History\History.IE5\index.dat
- 2005-12-02 08:49 . 2009-11-01 21:25 32768 c:\windows\system32\config\systemprofile\Local Settings\History\History.IE5\index.dat
+ 2009-11-01 23:41 . 2009-11-02 18:02 32768 c:\windows\system32\config\systemprofile\Cookies\index.dat
- 2005-12-02 08:49 . 2009-11-01 21:25 32768 c:\windows\system32\config\systemprofile\Cookies\index.dat
+ 2009-11-02 18:16 . 2004-08-10 19:00 55808 c:\windows\LastGood.Tmp\system32\eventlog.dll
+ 2008-12-05 23:55 . 2009-11-02 18:27 222436 c:\windows\system32\inetsrv\MetaBase.bin
S2 0327601257184976mcinstcleanup;McAfee Application Installer Cleanup (0327601257184976);c:\windows\TEMP\032760~1.EXE c:\progra~1\COMMON~1\McAfee\INSTAL~1\cleanup.ini -cleanup -nolog -service --> c:\windows\TEMP\032760~1.EXE c:\progra~1\COMMON~1\McAfee\INSTAL~1\cleanup.ini -cleanup -nolog -service [?]
*NewlyCreated* - 0327601257184976MCINSTCLEANUP
Rootkit scan 2009-11-02 18:28
hȋdden files: 0
- - - - - - - > 'explorer.exe'(3512)
c:\windows\system32\ctagent.dll
c:\windows\ehome\mcrdsvc.exe
c:\progra~1\McAfee\VIRUSS~1\mcsysmon.exe
Completion time: 2009-11-02 18:35 - machine was rebooted
ComboFix-quarantined-files.txt 2009-11-02 18:35
ComboFix2.txt 2009-11-01 23:28
Pre-Run: 170,165,895,168 bytes free
Post-Run: 170,125,606,912 bytes free
- - End Of File - - B09C7CF1BE2926992E82CA683C3F608E
BarryD
Posts Posts : 13
Post by Belahzur on 2nd November 2009, 6:42 pm
ComboFix /u
Post by BarryD on 2nd November 2009, 7:02 pm
Computer seems to be running ok (and has seemed ok since the successful malwarebytes scan)
mcafee still gives the 'error starting on demand scanner' when i try to scan
BarryD
Posts Posts : 13
Post by Belahzur on 2nd November 2009, 9:21 pm
Please download [You must be registered and logged in to see this link.] file.
  • Please download Junction.zip and save it.
  • Unzip it and put junction.exe in the Windows directory (C:\Windows).
  • Go to Start => Run... => Copy and paste the following command in the run box and click OK:
    cmd /c junction -s c:\ >log.txt&log.txt& del log.txt
  • A command window opens starting to scan the system. Wait until a log file opens. Copy and paste or attach the content of it.
Post by BarryD on 2nd November 2009, 9:40 pm
Junction v1.05 - Windows junction creator and reparse point viewer
Copyright (C) 2000-2007 Mark Russinovich
Systems Internals - [You must be registered and logged in to see this link.]
Failed to open \\?\c:\\pagefile.sys: The process cannot access the file because it is being used by another process.
Failed to open \\?\c:\\Program Files\McAfee\VirusScan\mcods.exe: Access is denied.
Failed to open \\?\c:\\Program Files\Spybot - Search & Destroy\SpybotSD.exe: Access is denied.
..\\?\c:\\WINDOWS\$hf_mig$\KB904706\KB904706: MOUNT POINT
Substitute Name: \Device\__max++>\^
\\?\c:\\WINDOWS\$hf_mig$\KB917159\KB917159: MOUNT POINT
\\?\c:\\WINDOWS\$hf_mig$\KB918899\KB918899: MOUNT POINT
.\\?\c:\\WINDOWS\$hf_mig$\KB920213\KB920213: MOUNT POINT
\\?\c:\\WINDOWS\$hf_mig$\KB924496\KB924496: MOUNT POINT
\\?\c:\\WINDOWS\$hf_mig$\KB925454\KB925454: MOUNT POINT
\\?\c:\\WINDOWS\$hf_mig$\KB932168\KB932168: MOUNT POINT
\\?\c:\\WINDOWS\$hf_mig$\KB933729\KB933729: MOUNT POINT
\\?\c:\\WINDOWS\$hf_mig$\KB941568\KB941568: MOUNT POINT
\\?\c:\\WINDOWS\$hf_mig$\KB943460\KB943460: MOUNT POINT
...\\?\c:\\WINDOWS\assembly\GAC_32\System.EnterpriseServices\2.0.0.0__b03f5f7f11d50a3a: JUNCTION
Print Name : C:\WINDOWS\WinSxS\x86_System.EnterpriseServices_b03f5f7f11d50a3a_2.0.0.0_x-ww_7d5f3790
Substitute Name: C:\WINDOWS\WinSxS\x86_System.EnterpriseServices_b03f5f7f11d50a3a_2.0.0.0_x-ww_7d5f3790
\\?\c:\\WINDOWS\assembly\GAC_MSIL\IEExecRemote\2.0.0.0__b03f5f7f11d50a3a: JUNCTION
Print Name : C:\WINDOWS\WinSxS\MSIL_IEExecRemote_b03f5f7f11d50a3a_2.0.0.0_x-ww_6e57c34e
Substitute Name: C:\WINDOWS\WinSxS\MSIL_IEExecRemote_b03f5f7f11d50a3a_2.0.0.0_x-ww_6e57c34e
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\BDATunePIA\BDATunePIA: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\ehCIR\ehCIR: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\EhCM\EhCM: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\ehcommon\ehcommon: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\ehepg\ehepg: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\ehepgdat\ehepgdat: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\ehExtCOM\ehExtCOM: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\ehExtHost\ehExtHost: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\ehiExtCOM\ehiExtCOM: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\ehiExtens\ehiExtens: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\ehiMsgr\ehiMsgr: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\ehiPlay\ehiPlay: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\ehiProxy\ehiProxy: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\ehiUserXp\ehiUserXp: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\ehiVidCtl\ehiVidCtl: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\ehiwmp\ehiwmp: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\ehiWUapi\ehiWUapi: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\ehRecObj\ehRecObj: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\ehshell\ehshell: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages1_v1.1.4322\Microsoft.MediaCenter\Microsoft.MediaCenter: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAP115.tmp\ZAP115.tmp: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAP133.tmp\ZAP133.tmp: MOUNT POINT
\\?\c:\\WINDOWS\assembly\NativeImages_v2.0.50727_32\Temp\ZAP400.tmp\ZAP400.tmp: MOUNT POINT
\\?\c:\\WINDOWS\assembly\temp\temp: MOUNT POINT
\\?\c:\\WINDOWS\assembly\tmp\tmp: MOUNT POINT
\\?\c:\\WINDOWS\Config\Config: MOUNT POINT
\\?\c:\\WINDOWS\Connection Wizard\Connection Wizard: MOUNT POINT
.\\?\c:\\WINDOWS\ehome\CreateDisc\SonicResources\SonicResources: MOUNT POINT
\\?\c:\\WINDOWS\ehome\CreateDisc\Styles\NTSC\Symphony\Cache\CacheDataFiles\CacheDataFiles: MOUNT POINT
\\?\c:\\WINDOWS\ehome\CreateDisc\Styles\NTSC\Symphony\Symphony\Symphony: MOUNT POINT
\\?\c:\\WINDOWS\ehome\CreateDisc\Styles\PAL\Symphony\Cache\CacheDataFiles\CacheDataFiles: MOUNT POINT
\\?\c:\\WINDOWS\ehome\CreateDisc\Styles\PAL\Symphony\Symphony\Symphony: MOUNT POINT
...\\?\c:\\WINDOWS\IIS Temporary Compressed Files\IIS Temporary Compressed Files: MOUNT POINT
\\?\c:\\WINDOWS\ime\chsime\applets\applets: MOUNT POINT
\\?\c:\\WINDOWS\ime\CHTIME\Applets\Applets: MOUNT POINT
\\?\c:\\WINDOWS\ime\imejp\applets\applets: MOUNT POINT
\\?\c:\\WINDOWS\ime\imejp98\imejp98: MOUNT POINT
\\?\c:\\WINDOWS\ime\imjp8_1\applets\applets: MOUNT POINT
\\?\c:\\WINDOWS\ime\imkr6_1\applets\applets: MOUNT POINT
\\?\c:\\WINDOWS\ime\imkr6_1\dicts\dicts: MOUNT POINT
\\?\c:\\WINDOWS\ime\shared\res\res: MOUNT POINT
..\\?\c:\\WINDOWS\inf\Other\Other: MOUNT POINT
.\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\00002109411090400000000000F01FEC\12.0.4518\12.0.4518: MOUNT POINT
\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\00002109440090400000000000F01FEC\12.0.4518\12.0.4518: MOUNT POINT
\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\00002109511090400000000000F01FEC\12.0.4518\12.0.4518: MOUNT POINT
\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\00002109711090400000000000F01FEC\12.0.4518\12.0.4518: MOUNT POINT
\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\00002109910090400000000000F01FEC\12.0.4518\12.0.4518: MOUNT POINT
\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\00002109B10090400000000000F01FEC\12.0.4518\12.0.4518: MOUNT POINT
\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\00002109F100A0C00000000000F01FEC\12.0.4518\12.0.4518: MOUNT POINT
\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\00002109F100C0400000000000F01FEC\12.0.4518\12.0.4518: MOUNT POINT
\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\0DC1503A46F231838AD88BCDDC8E8F7C\3.2.30729\3.2.30729: MOUNT POINT
\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\D7314F9862C648A4DB8BE2A5B47BE100\1.0.0\1.0.0: MOUNT POINT
\\?\c:\\WINDOWS\Installer\$PatchCache$\Managed\DC3BF90CC0D3D2F398A9A6D1762F70F3\2.2.30729\2.2.30729: MOUNT POINT
\\?\c:\\WINDOWS\java\classes\classes: MOUNT POINT
\\?\c:\\WINDOWS\java\trustlib\trustlib: MOUNT POINT
.\\?\c:\\WINDOWS\Microsoft.NET\Framework\v1.0.3705\Temporary ASP.NET Files\Bind Logs\Bind Logs: MOUNT POINT
.\\?\c:\\WINDOWS\Microsoft.NET\Framework\v1.1.4322\Temporary ASP.NET Files\Bind Logs\Bind Logs: MOUNT POINT
.\\?\c:\\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET Files\Temporary ASP.NET Files: MOUNT POINT
\\?\c:\\WINDOWS\msapps\msinfo\msinfo: MOUNT POINT
.\\?\c:\\WINDOWS\pchealth\ERRORREP\QHEADLES\QHEADLES: MOUNT POINT
\\?\c:\\WINDOWS\pchealth\ERRORREP\QSIGNOFF\QSIGNOFF: MOUNT POINT
\\?\c:\\WINDOWS\pchealth\helpctr\batch\batch: MOUNT POINT
Failed to open \\?\c:\\WINDOWS\pchealth\helpctr\binaries\helpsvc.exe: Access is denied.
\\?\c:\\WINDOWS\pchealth\helpctr\Config\CheckPoint\CheckPoint: MOUNT POINT
\\?\c:\\WINDOWS\pchealth\helpctr\Config\News\News: MOUNT POINT
\\?\c:\\WINDOWS\pchealth\helpctr\HelpFiles\HelpFiles: MOUNT POINT
\\?\c:\\WINDOWS\pchealth\helpctr\InstalledSKUs\InstalledSKUs: MOUNT POINT
.\\?\c:\\WINDOWS\pchealth\helpctr\System\DFS\DFS: MOUNT POINT
.\\?\c:\\WINDOWS\pchealth\helpctr\System_OEM\System_OEM: MOUNT POINT
\\?\c:\\WINDOWS\pchealth\helpctr\Temp\Temp: MOUNT POINT
\\?\c:\\WINDOWS\Registration\CRMLog\CRMLog: MOUNT POINT
..\\?\c:\\WINDOWS\SoftwareDistribution\AuthCabs\Downloaded\Downloaded: MOUNT POINT
\\?\c:\\WINDOWS\SoftwareDistribution\Download\355f788b6de8a3ec79e9aa172e6317f1\backup\backup: MOUNT POINT
\\?\c:\\WINDOWS\SoftwareDistribution\Download\b7becdf0812b9161bfddc415c4486bad\backup\backup: MOUNT POINT
.\\?\c:\\WINDOWS\SoftwareDistribution\SelfUpdate\Default\Default: MOUNT POINT
\\?\c:\\WINDOWS\SoftwareDistribution\SelfUpdate\Registered\Registered: MOUNT POINT
\\?\c:\\WINDOWS\Sun\Java\Deployment\Deployment: MOUNT POINT
\\?\c:\\WINDOWS\SxsCaPendDel\SxsCaPendDel: MOUNT POINT
\\?\c:\\WINDOWS\WinSxS\InstallTemp\InstallTemp: MOUNT POINT
.\\?\c:\\WINDOWS\WinSxS\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1433_x-ww_5cf844d2\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1433_x-ww_5cf844d2: MOUNT POINT
BarryD
Posts Posts : 13
Post by Belahzur on 3rd November 2009, 12:25 am
Like you did with juntion.exe, place inherit.exe into the Windows folder.
Now open a new notepad file.
@echo off
"inherit.exe" "c:\Program Files\McAfee\VirusScan\mcods.exe"
"inherit.exe" "c:\\Program Files\Spybot - Search & Destroy\SpybotSD.exe"
exit
Save this as fix.bat, save it to your desktop.
Let it run until it says OK on each one.
Spybot/Mcafee on-demand scanner will work now.
Post by BarryD on 3rd November 2009, 11:40 pm
Wow.
I've no idea what you did or how you did it but it seems to have worked perfectly.
Huge thanks, very much appreciated!
BarryD
Posts Posts : 13
Post by Belahzur on 4th November 2009, 1:40 am
Not a problem! Smile
You can delete everything we used.
