I have BankerFox & Nuqel on my PC and need your help
Post by bballjunky on 30th October 2009, 3:39 pm
I've read a number of past logs on this site and it seems that this BankerFox / Nuqel virus is rather common. I would like your help to remove it from my PC. I'm currently at work but will follow any instructions you give once I get home later today. It appears that the first thing I need to do is to download and execute Hijackthis. Please confirm. Thanks!
bballjunky
Posts Posts : 10
Joined Joined : 2009-10-30
Points Points : 26118
Re: I have BankerFox & Nuqel on my PC and need your help
Post by Belahzur on 31st October 2009, 12:13 am
Yes, Hijack This logs always come first.
Points Points : 245111
BankerFox & Nuqel virus
Post by bballjunky on 29th November 2009, 1:09 am
Last month I first contacted you about the BankerFox and Nuqel virus. You mentioned that I should execute Hijackthis but there wasn't a link and I couldn't find it in any of the other notes I was reading. Can you send me a link to Hijackthis?
By the way, last month I found the .exe in my program files that the virus was attached to and I renamed the .exe. That made the virus stop executing. Now it's back and I want to get rid of it completely. I've checked my program files again for a recent .exe that had been loaded to my PC but I don't see anything. Is it possible that it's attached to some other file extention?
bballjunky
Posts Posts : 10
Post by Belahzur on 29th November 2009, 1:54 am
Post by bballjunky on 29th November 2009, 2:00 am
I just downloaded hijackthis. I double clicked and the virus immediately closes the program. What can I try now?
bballjunky
Posts Posts : 10
Post by bballjunky on 29th November 2009, 6:32 pm
I was able to run hijackthis. Here is the log.
Scan saved at 12:18:23 PM, on 11/29/2009
C:\Program Files\CyberLink\PowerDVD\DVDLauncher.exe
C:\Program Files\Intel\Modem Event Monitor\IntelMEM.exe
C:\Program Files\Creative\SBAudigy2\Surround Mixer\CTSysVol.exe
C:\Program Files\Creative\SBAudigy2\DVDAudio\CTDVDDet.EXE
C:\WINDOWS\system32\CTHELPER.EXE
C:\Program Files\Dell\Media Experience\PCMService.exe
C:\Program Files\Common Files\Sonic\Update Manager\sgtray.exe
C:\Program Files\Real\RealPlayer\RealPlay.exe
C:\Program Files\MusicMatch\MusicMatch Jukebox\mmtask.exe
C:\Program Files\MUSICMATCH\Musicmatch Jukebox\mm_tray.exe
C:\WINDOWS\System32\spool\drivers\w32x86\3\hpztsb11.exe
C:\Program Files\HP\hpcoretech\hpcmpmgr.exe
C:\WINDOWS\System32\hphmon06.exe
C:\Program Files\Common Files\AOL\1107989059\ee\AOLSoftware.exe
C:\Program Files\Common Files\AOL\ACS\AOLDial.exe
C:\Program Files\Scansoft\PaperPort\pptd40nt.exe
C:\Program Files\Visioneer OneTouch\OneTouchMon.exe
C:\Program Files\Dell Support Center\bin\sprtcmd.exe
C:\Program Files\QuickTime\QTTask.exe
C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe
C:\Documents and Settings\Lauren Jeffords\Local Settings\Application Data\jqonsj\amwxsysguard.exe
C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe
C:\Program Files\Microsoft Money\System\mnyexpr.exe
C:\Program Files\DellSupport\DSAgnt.exe
C:\WINDOWS\System32\CTsvcCDA.exe
C:\Program Files\Dell Support Center\gs_agent\dsc.exe
C:\Program Files\HP\Digital Imaging\bin\hpqgalry.exe
C:\WINDOWS\System32\nvsvc32.exe
C:\Program Files\Dell Support Center\bin\sprtsvc.exe
C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
C:\Program Files\Viewpoint\Common\ViewpointService.exe
C:\WINDOWS\wanmpsvc.exe
C:\WINDOWS\System32\MsPMSPSv.exe
C:\WINDOWS\System32\HPZipm12.exe
c:\program files\common files\aol\1107989059\ee\services\antiSpywareApp\ver2_0_7\AOLSP Scheduler.exe
c:\program files\common files\aol\1107989059\ee\aolsoftware.exe
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = "C:\Program Files\MSN Gaming Zone\Windows\CHKRZM.EXE"
R3 - URLSearchHook: (no name) - {00A6FAF6-072E-44cf-8957-5838F569A31D} - C:\Program Files\MyWebSearch\SrchAstt\1.bin\MWSSRCAS.DLL
R3 - URLSearchHook: (no name) - {0579B4B6-0293-4d73-B02D-5EBB0BA0F0A2} - C:\Program Files\AskSBar\SrchAstt\1.bin\A2SRCHAS.DLL
O1 - Hosts: ::1 localhost
O1 - Hosts: 91.212.127.226 ossecure2009.microsoft.com
O1 - Hosts: 91.212.127.226 os-secure2009.com
O1 - Hosts: 91.212.127.226 [You must be registered and logged in to see this link.]
O2 - BHO: Ask Search Assistant BHO - {0579B4B1-0293-4d73-B02D-5EBB0BA0F0A2} - C:\Program Files\AskSBar\SrchAstt\1.bin\A2SRCHAS.DLL
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0\Reader\ActiveX\AcroIEHelper.dll
O2 - BHO: UrlHelper Class - {6D023EBF-70B8-45A6-9ED5-556515FA0FE4} - C:\Program Files\BearShare Applications\BearShare MediaBar\BearShareIEHelper.dll
O2 - BHO: AOL Toolbar Launcher - {7C554162-8CB7-45A4-B8F4-8EA1C75885F9} - C:\Program Files\AOL\AIM Toolbar 5.0\aoltb.dll
O2 - BHO: BearSharePersonalization - {DD1849EA-8403-4441-8DFF-7575AAE1DC16} - C:\Program Files\BearShare Applications\Personalization\BearSharePersonalizationIE_v1047.dll
O2 - BHO: Ask Toolbar BHO - {F0D4B231-DA4B-4daf-81E4-DFEE4931A4AA} - C:\Program Files\AskSBar\bar\1.bin\ASKSBAR.DLL
O3 - Toolbar: Yahoo! Companion - {EF99BD32-C1FB-11D2-892F-0090271D4F88} - C:\Program Files\Yahoo!\Companion\Installs\cpn\ycomp5_5_5_0.dll
O3 - Toolbar: Ask Toolbar - {F0D4B239-DA4B-4daf-81E4-DFEE4931A4AA} - C:\Program Files\AskSBar\bar\1.bin\ASKSBAR.DLL
O3 - Toolbar: AIM Toolbar - {DE9C389F-3316-41A7-809B-AA305ED9D922} - C:\Program Files\AOL\AIM Toolbar 5.0\aoltb.dll
O3 - Toolbar: BearShare MediaBar - {D3DEE18F-DB64-4BEB-9FF1-E1F0A5033E4A} - C:\Program Files\BearShare Applications\BearShare MediaBar\BSMediaBar.dll
O3 - Toolbar: Viewpoint Toolbar - {F8AD5AA5-D966-4667-9DAF-2561D68B2012} - C:\Program Files\Common Files\Viewpoint\Toolbar Runtime\3.9.0\IEViewBar.dll
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\System32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [DVDLauncher] "C:\Program Files\CyberLink\PowerDVD\DVDLauncher.exe"
O4 - HKLM\..\Run: [IntelMeM] C:\Program Files\Intel\Modem Event Monitor\IntelMEM.exe
O4 - HKLM\..\Run: [CTSysVol] C:\Program Files\Creative\SBAudigy2\Surround Mixer\CTSysVol.exe
O4 - HKLM\..\Run: [CTDVDDet] C:\Program Files\Creative\SBAudigy2\DVDAudio\CTDVDDet.EXE
O4 - HKLM\..\Run: [CTHelper] CTHELPER.EXE
O4 - HKLM\..\Run: [AsioReg] REGSVR32.EXE /S CTASIO.DLL
O4 - HKLM\..\Run: [UpdReg] C:\WINDOWS\UpdReg.EXE
O4 - HKLM\..\Run: [PCMService] "C:\Program Files\Dell\Media Experience\PCMService.exe"
O4 - HKLM\..\Run: [UpdateManager] "C:\Program Files\Common Files\Sonic\Update Manager\sgtray.exe" /r
O4 - HKLM\..\Run: [RealTray] C:\Program Files\Real\RealPlayer\RealPlay.exe SYSTEMBOOTHIDEPLAYER
O4 - HKLM\..\Run: [mmtask] c:\Program Files\MusicMatch\MusicMatch Jukebox\mmtask.exe
O4 - HKLM\..\Run: [MMTray] C:\Program Files\MUSICMATCH\Musicmatch Jukebox\mm_tray.exe
O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINDOWS\System32\spool\drivers\w32x86\3\hpztsb11.exe
O4 - HKLM\..\Run: [HPHUPD06] C:\Program Files\HP\{AAC4FC36-8F89-4587-8DD3-EBC57C83374D}\hphupd06.exe
O4 - HKLM\..\Run: [HP Software Update] "C:\Program Files\HP\HP Software Update\HPWuSchd2.exe"
O4 - HKLM\..\Run: [HP Component Manager] "C:\Program Files\HP\hpcoretech\hpcmpmgr.exe"
O4 - HKLM\..\Run: [HPHmon06] C:\WINDOWS\System32\hphmon06.exe
O4 - HKLM\..\Run: [HostManager] C:\Program Files\Common Files\AOL\1107989059\ee\AOLSoftware.exe
O4 - HKLM\..\Run: [AOLDialer] C:\Program Files\Common Files\AOL\ACS\AOLDial.exe
O4 - HKLM\..\Run: [Pure Networks Port Magic] "C:\PROGRA~1\PURENE~1\PORTMA~1\PortAOL.exe" -Run
O4 - HKLM\..\Run: [PaperPort PTD] C:\Program Files\Scansoft\PaperPort\pptd40nt.exe
O4 - HKLM\..\Run: [IndexSearch] C:\Program Files\Scansoft\PaperPort\IndexSearch.exe
O4 - HKLM\..\Run: [OneTouch Monitor] C:\Program Files\Visioneer OneTouch\OneTouchMon.exe
O4 - HKLM\..\Run: [My Web Search Bar] rundll32 C:\PROGRA~1\MYWEBS~1\bar\1.bin\MWSBAR.DLL,S
O4 - HKLM\..\Run: [dscactivate] "C:\Program Files\Dell Support Center\gs_agent\custom\dsca.exe"
O4 - HKLM\..\Run: [DellSupportCenter] "C:\Program Files\Dell Support Center\bin\sprtcmd.exe" /P DellSupportCenter
O4 - HKLM\..\Run: [system tool] C:\Program Files\qhaqan\rbxosysguard.exe
O4 - HKLM\..\Run: [kqguxqfl] C:\Documents and Settings\Lauren Jeffords\Local Settings\Application Data\jqonsj\amwxsysguard.exe
O4 - HKCU\..\Run: [MoneyAgent] "C:\Program Files\Microsoft Money\System\mnyexpr.exe"
O4 - HKCU\..\Run: [DellSupport] "C:\Program Files\DellSupport\DSAgnt.exe" /startup
O4 - HKCU\..\Run: [DellSupportCenter] "C:\Program Files\Dell Support Center\bin\sprtcmd.exe" /P DellSupportCenter
O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\digital imaging\bin\hpqtra08.exe
O4 - Global Startup: HP Image Zone Fast Start.lnk = C:\Program Files\HP\digital imaging\bin\hpqthb08.exe
O8 - Extra context menu item: &AOL Toolbar Search - c:\program files\aol\aim toolbar 5.0\resources\en-US\local\search.html
O8 - Extra context menu item: &Search - [You must be registered and logged in to see this link.]
O9 - Extra button: AIM Toolbar - {3369AF0D-62E9-4bda-8103-B4C75499B578} - C:\Program Files\AOL\AIM Toolbar 5.0\aoltb.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\OFFICE11\REFIEBAR.DLL
O9 - Extra button: AIM - {AC9E2541-2814-11d5-BC6D-00B0D0A1DE45} - C:\PROGRA~1\AIM\aim.exe
O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\System32\Shdocvw.dll
O9 - Extra button: MUSICMATCH MX Web Player - {d81ca86b-ef63-42af-bee3-4502d9a03c2d} - [You must be registered and logged in to see this link.] (file missing)
O9 - Extra button: Go PlaySushi! - {EBD24BD3-E272-4FA3-A8BA-C5D709757CAB} - C:\Program Files\PlaySushi\PSText.dll
O16 - DPF: {1D4DB7D2-6EC9-47A3-BD87-1E41684E07BB} - [You must be registered and logged in to see this link.]
O16 - DPF: {56336BCB-3D8A-11D6-A00B-0050DA18DE71} (RdxIE Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {5ED80217-570B-4DA9-BF44-BE107C0EC166} (Windows Live Safety Center Base Module) - [You must be registered and logged in to see this link.]
O16 - DPF: {6632A7E9-FE1F-43D2-A04A-A15951ED63E0} - [You must be registered and logged in to see this link.]
O16 - DPF: {C02226EB-A5D7-4B1F-BD7E-635E46C2288D} (Toontown Installer ActiveX Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {E7DBFB6C-113A-47CF-B278-F5C6AF4DE1BD} - [You must be registered and logged in to see this link.]
O16 - DPF: {F91AB7B8-EE67-42AF-A5AA-8E232C396A04} (HTMLPRint Control) - [You must be registered and logged in to see this link.]
O23 - Service: AOL Connectivity Service (AOL ACS) - AOL LLC - C:\Program Files\Common Files\AOL\ACS\AOLAcsd.exe
O23 - Service: AOL TopSpeed Monitor (AOL TopSpeedMonitor) - America Online, Inc - C:\Program Files\Common Files\AOL\TopSpeed\2.0\aoltsmon.exe
O23 - Service: Creative Service for CDROM Access - Creative Technology Ltd - C:\WINDOWS\System32\CTsvcCDA.exe
O23 - Service: DSBrokerService - Unknown owner - C:\Program Files\DellSupport\brkrsvc.exe
O23 - Service: HP Port Resolver - Hewlett-Packard Company - C:\WINDOWS\System32\hpbpro.exe
O23 - Service: HP Status Server - Hewlett-Packard Company - C:\WINDOWS\System32\hpboid.exe
O23 - Service: Intel NCS NetService (NetSvc) - Intel(R) Corporation - C:\Program Files\Intel\NCS\Sync\NetSvc.exe
O23 - Service: NVIDIA Driver Helper Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\System32\nvsvc32.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\System32\HPZipm12.exe
O23 - Service: SupportSoft Sprocket Service (dellsupportcenter) (sprtsvc_dellsupportcenter) - SupportSoft, Inc. - C:\Program Files\Dell Support Center\bin\sprtsvc.exe
O23 - Service: Symantec Core LC - Unknown owner - C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
O23 - Service: WAN Miniport (ATW) Service (WANMiniportService) - America Online, Inc. - C:\WINDOWS\wanmpsvc.exe
End of file - 14148 bytes
bballjunky
Posts Posts : 10
Post by bballjunky on 29th November 2009, 8:12 pm
In addition to the Hijackthis log, I also ran exehelper. See log below. Thanks!
exeHelper by Raktor
Build 20091122
Run at 20:25:19exeHelper by Raktor
Build 20091122
Run at exeHelper by Raktor
Build 20091122
Run at 15:07:26 on 11/29/09
Now searching...
Checking for sysguard processes...
Removing HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\system tool
Checking for bad processes...
Checking for bad files...
Resetting policies...
--Finished--
bballjunky
Posts Posts : 10
Post by Belahzur on 29th November 2009, 11:50 pm
Post by bballjunky on 30th November 2009, 3:09 am
Okay - I ran hijackthis and Malwarebytes' as instructed. Everything went well, although I did get an error while running Malwarebytes'. The error code was 732 (0,0). When I clicked OK the Malwarebytes' software continued running. Once it finished I clicked Show Results, verifed that all listed items were checked and then I clicked Remove Selected. Everything seemed to go well.
So, does that mean my PC is cleared from this virus???
bballjunky
Posts Posts : 10
Post by bballjunky on 30th November 2009, 3:10 am
By the way, here is the MBAM log. Thanks!!
Database version: 2775
11/29/2009 9:53:25 PM
mbam-log-2009-11-29 (21-53-25).txt
Objects scanned: 149685
Time elapsed: 11 minute(s), 29 second(s)
Registry Keys Infected: 146
Registry Values Infected: 3
Folders Infected: 18
Files Infected: 91
HKEY_CLASSES_ROOT\Interface\{07b18eaa-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{07b18eac-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{1093995a-ba37-41d2-836e-091067c4ad17} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{120927bf-1700-43bc-810f-fab92549b390} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{17de5e5e-bfe3-4e83-8e1f-8755795359ec} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{1f52a5fa-a705-4415-b975-88503b291728} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{247a115f-06c2-4fb3-967d-2d62d3cf4f0a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{2763e333-b168-41a0-a112-d35f96f410c0} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{2e3537fc-cf2f-4f56-af54-5a6a3dd375cc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{2e9937fc-cf2f-4f56-af54-5a6a3dd375cc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{38a7c9da-8db7-4d0f-a7b1-c4b1a305bddb} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e1656ed-f60e-4597-b6aa-b6a58e171495} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e53e2cb-86db-4a4a-8bd9-ffeb7a64df82} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e720451-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{3e720453-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{63d0ed2b-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{63d0ed2d-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{6e74766c-4d93-4cc0-96d1-47b8e07ff9ca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{72ee7f04-15bd-4845-a005-d6711144d86a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{741de825-a6f0-4497-9aa6-8023cf9b0fff} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d291-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d293-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d295-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{7473d297-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{8d292ec0-6792-4a38-82ed-73a087e41ba6} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{90449521-d834-4703-bb4e-d3aa44042ff8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{991aac62-b100-47ce-8b75-253965244f69} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{a626cdbd-3d13-4f78-b819-440a28d7e8fc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{bbabdc90-f3d5-4801-863a-ee6ae529862d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{d6ff3684-ad3b-48eb-bbb4-b9e6c5a355c1} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{de38c398-b328-4f4c-a3ad-1b5e4ed93477} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e342af55-b78a-4cd0-a2bb-da7f52d9d25e} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e342af55-b78a-4cd0-a2bb-da7f52d9d25f} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e79dfbc9-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{e79dfbcb-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{eb9e5c1c-b1f9-4c2b-be8a-27d6446fdaf8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Interface\{f87d7fb5-9dc5-4c8c-b998-d8dfe02e2978} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{00a6faf1-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{00a6faf6-072e-44cf-8957-5838f569a31d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{07b18ea1-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{07b18ea0-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{07b18ea1-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{07b18ea9-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{07b18eab-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{07b18eab-a523-4961-b6bb-170de4475cca} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{53ced2d0-5e9a-4761-9005-648404e6f7e5} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{0f8ecf4f-3646-4c3a-8881-8e138ffcaf70} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{8ca01f0e-987c-49c3-b852-2f1ac4a7094c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{b813095c-81c0-4e40-aa14-67520372b987} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{c9d7be3e-141a-4c85-8cd6-32461f3df2c7} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{cff4ce82-3aa2-451f-9b77-7165605fb835} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{147a976f-eee1-4377-8ea7-4716e4cdd239} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{1e0de227-5ce4-4ea3-ab0c-8b03e1aa76bc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{25560540-9571-4d7b-9389-0f166788785a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{c8cecde3-1ae1-4c4a-ad82-6d5b00212144} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{25560540-9571-4d7b-9389-0f166788785a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{2eff3cf7-99c1-4c29-bc2b-68e057e22340} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{621feacd-8857-43a6-ae26-451d670d5370} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{2eff3cf7-99c1-4c29-bc2b-68e057e22340} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{3dc201fb-e9c9-499c-a11f-23c360d7c3f8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{e47caee0-deea-464a-9326-3f2801535a4d} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{3dc201fb-e9c9-499c-a11f-23c360d7c3f8} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{98d9753d-d73b-42d5-8c85-4469cda897ab} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{98d9753d-d73b-42d5-8c85-4469cda897ab} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{3e720452-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{3e720450-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{3e720452-b472-4954-b7aa-33069eb53906} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{63d0ed2c-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{8e6f1830-9607-4440-8530-13be7c4b1d14} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{63d0ed2c-b45b-4458-8b3b-60c69bbbd83c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{8e6f1832-9607-4440-8530-13be7c4b1d14} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{a9571378-68a1-443d-b082-284f960c6d17} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{7473d292-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{7473d290-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{7473d294-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{7473d294-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{7473d296-b7bb-4f24-ae82-7e2ce94bb6a9} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{84da4fdf-a1cf-4195-8688-3e961f505983} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{938aa51a-996c-4884-98ce-80dd16a5c9da} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{29d67d3c-509a-4544-903f-c8c1b8236554} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{9ff05104-b030-46fc-94b8-81276e4e27df} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{9ff05104-b030-46fc-94b8-81276e4e27df} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{a4730ebe-43a6-443e-9776-36915d323ad3} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{a6573479-9075-4a65-98a6-19fd29cf7374} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{98635087-3f5d-418f-990c-b1efe0797a3b} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{a6573479-9075-4a65-98a6-19fd29cf7374} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{d778513b-1c40-4819-b0c5-49e40b39afd0} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{adb01e81-3c79-4272-a0f1-7b2be7a782dc} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{d9fffb27-d62a-4d64-8cec-1ff006528805} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{0d26bc71-a633-4e71-ad31-eadc3a1b6a3a} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\CLSID\{e79dfbca-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\TypeLib\{e79dfbc0-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{e79dfbca-5697-4fbd-94e5-5b2a9c7c1612} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\Typelib\{f42228fb-e84e-479e-b922-fbbd096e792c} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{549b5ca7-4a86-11d7-a4df-000874180bb3} (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{1d4db7d2-6ec9-47a3-bd87-1e41684e07bb} (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.browseroverlaybarbutton (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.browseroverlaybarbutton.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.browseroverlayembed (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.browseroverlayembed.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.datacontrol (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.datacontrol.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historykillerscheduler (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historykillerscheduler.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historyswattercontrolbar (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.historyswattercontrolbar.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.htmlmenu (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.htmlmenu.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.htmlmenu.2 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.iecookiesmanager (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.iecookiesmanager.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.killerobjmanager (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.killerobjmanager.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswatterbarbutton (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswatterbarbutton.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswattersettingscontrol (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.popswattersettingscontrol.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.shellviewcontrol (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\funwebproducts.shellviewcontrol.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\MIME\Database\Content Type\application/x-f3embed (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.chatsessionplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.chatsessionplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.htmlpanel (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.htmlpanel.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.outlookaddin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.outlookaddin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.pseudotransparentplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearch.pseudotransparentplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.settingsplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.settingsplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.toolbarplugin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\mywebsearchtoolbar.toolbarplugin.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\screensavercontrol.screensaverinstaller (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CLASSES_ROOT\screensavercontrol.screensaverinstaller.1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\MyWebSearch (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\FocusInteractive (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Fun Web Products (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\FunWebProducts (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Outlook\Addins\MyWebSearch.OutlookAddin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Word\Addins\MyWebSearch.OutlookAddin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MyWebSearch bar Uninstall (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\MyWebSearch (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\MenuExt\&Search\(default) (Adware.Hotbar) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Media\WMSDK\Sources\f3PopularScreensavers (Adware.MyWebSearch) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\User Agent\Post Platform\FunWebProducts (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\ScreenSaver (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\ScreenSaver\Images (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\Shared (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\Shared\Cache (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Avatar (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Game (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\History (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Message (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\SrchAstt (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\SrchAstt\1.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\SrchAstt\1.bin\MWSSRCAS.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\MWSBAR.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3HISTSW.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3DTACTL.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3SHLLVW.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3HTMLMU.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3HTML.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3POPSWT.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3SKIN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3CJPEG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3SCRCTR.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3BROVLY.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3OUTLCN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3HTTPCT.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3MSG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\MWSOEPLG.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Documents and Settings\Alisa Jeffords\Local Settings\Temp\dogpile_sub_installer.exe (Trojan.Dropper) -> Quarantined and deleted successfully.
C:\Documents and Settings\Alisa Jeffords\Local Settings\Temporary Internet Files\Content.IE5\0BKF6H0X\Dogpile_Toolbar[1].exe (Trojan.Dropper) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\ScreenSaver\Images\001AE2C0.urr (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\ScreenSaver\Images\002B91CF.urr (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\Shared\Cache\CursorManiaBtn-new.html (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\Shared\Cache\CursorManiaBtn.html (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\Shared\Cache\SmileyCentralBtn-new.html (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\FunWebProducts\Shared\Cache\SmileyCentralBtn.html (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3BKGERR.JPG (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3IMSTUB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3PSSAVR.SCR (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3REPROX.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3RESTUB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3SCHMON.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3SPACER.WMV (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3WALLPP.DAT (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\F3WPHOOK.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3FFXTBR.JAR (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3FFXTBR.MANIFEST (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3IDLE.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3IMPIPE.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3NTSTBR.JAR (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3NTSTBR.MANIFEST (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3PLUGIN.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3SKPLAY.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\M3SLSRCH.EXE (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\MWSOESTB.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\1.bin\NPMYWEBS.DLL (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Avatar\COMMON.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\00014C75 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\00017BF1 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\00025644 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\0002ABE6 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\0002DD75 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\0002DE31.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\0002DF79.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\0002E034.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\0002EBCD.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\00047338 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\00084D2E (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\001F2A74.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\001F2C29.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\00339D9F.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\00339F16.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\0033AAED.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\0033AB99.bin (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\00424B9E (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\0053319B (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Cache\files.ini (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Game\CHECKERS.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Game\CHESS.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Game\REVERSI.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\History\search2 (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\CM.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\MFC.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\PSS.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\SMILEY.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\WB.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\icons\ZWINKY.ICO (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Message\COMMON.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\COMMON.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\DOG.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\FISH.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\KUNGFU.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\LIFEGARD.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\MAID.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\MAILBOX.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\OPERA.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\ROBOT.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\SEDUCT.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Notifier\SURFER.F3S (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings\prevcfg2.htm (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\Program Files\MyWebSearch\bar\Settings\s_pid.dat (Adware.MyWebSearch) -> Quarantined and deleted successfully.
C:\WINDOWS\SYSTEM32\f3PSSavr.scr (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Documents and Settings\Mark Jeffords\Desktop\winlogon.scr (Heuristics.Reserved.Word.Exploit) -> Quarantined and deleted successfully.
bballjunky
Posts Posts : 10
Post by Belahzur on 30th November 2009, 8:42 pm
Lets keep going.
Post by bballjunky on 1st December 2009, 12:33 am
I ran DDS. Below is the DDS log. I will post the Attach log to a separate reply.
Thanks for all your help!!!
++++++++++++++ DDS LOG +++++++++++++++++++++++++++++
DDS (Ver_09-11-29.01) - NTFSx86
Run by Mark Jeffords at 19:26:28.51 on Mon 11/30/2009
Internet Explorer: 6.0.2900.2180
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.511.112 [GMT -5:00]
svchost.exe
C:\WINDOWS\system32\svchost.exe -k WudfServiceGroup
svchost.exe
svchost.exe
svchost.exe
C:\WINDOWS\System32\svchost.exe -k imgsvc
C:\Program Files\Viewpoint\Viewpoint Manager\ViewMgr.exe
C:\Documents and Settings\Mark Jeffords\Desktop\dds.scr
mDefault_Page_URL = [You must be registered and logged in to see this link.]
uInternet Connection Wizard,ShellNext = "c:\program files\msn gaming zone\windows\CHKRZM.EXE"
mURLSearchHooks: AOLTBSearch Class: {ea756889-2338-43db-8f07-d1ca6fb9c90d} - c:\program files\aol\aim toolbar 5.0\aoltb.dll
mURLSearchHooks: H - No File
BHO: AcroIEHlprObj Class: {06849e9f-c8d7-4d59-b87d-784b7d6be0b3} - c:\program files\adobe\acrobat 6.0\reader\activex\AcroIEHelper.dll
BHO: AOL Toolbar Launcher: {7c554162-8cb7-45a4-b8f4-8ea1c75885f9} - c:\program files\aol\aim toolbar 5.0\aoltb.dll
TB: Yahoo! Companion: {ef99bd32-c1fb-11d2-892f-0090271d4f88} - c:\program files\yahoo!\companion\installs\cpn\ycomp5_5_5_0.dll
TB: AIM Toolbar: {de9c389f-3316-41a7-809b-aa305ed9d922} - c:\program files\aol\aim toolbar 5.0\aoltb.dll
TB: {4982D40A-C53B-4615-B15B-B5B5E98D167C} - No File
TB: BearShare MediaBar: {d3dee18f-db64-4beb-9ff1-e1f0a5033e4a} - c:\program files\bearshare applications\bearshare mediabar\BSMediaBar.dll
TB: {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - No File
TB: Ask Toolbar: {f0d4b239-da4b-4daf-81e4-dfee4931a4aa} - c:\program files\asksbar\bar\1.bin\ASKSBAR.DLL
EB: Real.com: {fe54fa40-d68c-11d2-98fa-00c0f0318afe} - c:\windows\system32\Shdocvw.dll
EB: {32683183-48a0-441b-a342-7c2a440a9478} - No File
uRun: [MoneyAgent] "c:\program files\microsoft money\system\mnyexpr.exe"
uRun: [DellSupport] "c:\program files\dellsupport\DSAgnt.exe" /startup
uRun: [DellSupportCenter] "c:\program files\dell support center\bin\sprtcmd.exe" /P DellSupportCenter
mRun: [NvCplDaemon] RUNDLL32.EXE c:\windows\system32\NvCpl.dll,NvStartup
mRun: [DVDLauncher] "c:\program files\cyberlink\powerdvd\DVDLauncher.exe"
mRun: [IntelMeM] c:\program files\intel\modem event monitor\IntelMEM.exe
mRun: [CTSysVol] c:\program files\creative\sbaudigy2\surround mixer\CTSysVol.exe
mRun: [CTDVDDet] c:\program files\creative\sbaudigy2\dvdaudio\CTDVDDet.EXE
mRun: [CTHelper] CTHELPER.EXE
mRun: [AsioReg] REGSVR32.EXE /S CTASIO.DLL
mRun: [UpdReg] c:\windows\UpdReg.EXE
mRun: [PCMService] "c:\program files\dell\media experience\PCMService.exe"
mRun: [dla] c:\windows\system32\dla\tfswctrl.exe
mRun: [UpdateManager] "c:\program files\common files\sonic\update manager\sgtray.exe" /r
mRun: [RealTray] c:\program files\real\realplayer\RealPlay.exe SYSTEMBOOTHIDEPLAYER
mRun: [mmtask] c:\program files\musicmatch\musicmatch jukebox\mmtask.exe
mRun: [MMTray] c:\program files\musicmatch\musicmatch jukebox\mm_tray.exe
mRun: [HPDJ Taskbar Utility] c:\windows\system32\spool\drivers\w32x86\3\hpztsb11.exe
mRun: [HPHUPD06] c:\program files\hp\{aac4fc36-8f89-4587-8dd3-ebc57c83374d}\hphupd06.exe
mRun: [HP Software Update] "c:\program files\hp\hp software update\HPWuSchd2.exe"
mRun: [HP Component Manager] "c:\program files\hp\hpcoretech\hpcmpmgr.exe"
mRun: [HPHmon06] c:\windows\system32\hphmon06.exe
mRun: [HostManager] c:\program files\common files\aol\1107989059\ee\AOLSoftware.exe
mRun: [AOLDialer] c:\program files\common files\aol\acs\AOLDial.exe
mRun: [Pure Networks Port Magic] "c:\progra~1\purene~1\portma~1\PortAOL.exe" -Run
mRun: [PaperPort PTD] c:\program files\scansoft\paperport\pptd40nt.exe
mRun: [IndexSearch] c:\program files\scansoft\paperport\IndexSearch.exe
mRun: [OneTouch Monitor] c:\program files\visioneer onetouch\OneTouchMon.exe
mRun: [dscactivate] "c:\program files\dell support center\gs_agent\custom\dsca.exe"
mRun: [DellSupportCenter] "c:\program files\dell support center\bin\sprtcmd.exe" /P DellSupportCenter
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\hpdigi~1.lnk - c:\program files\hp\digital imaging\bin\hpqtra08.exe
StartupFolder: c:\docume~1\alluse~1\startm~1\programs\startup\hpimag~1.lnk - c:\program files\hp\digital imaging\bin\hpqthb08.exe
IE: &AOL Toolbar Search - c:\program files\aol\aim toolbar 5.0\resources\en-us\local\search.html
IE: &Search
IE: E&xport to Microsoft Excel - c:\progra~1\micros~3\office11\EXCEL.EXE/3000
IE: {AC9E2541-2814-11d5-BC6D-00B0D0A1DE45} - c:\progra~1\aim\aim.exe
IE: {d81ca86b-ef63-42af-bee3-4502d9a03c2d} - [You must be registered and logged in to see this link.]
IE: {3369AF0D-62E9-4bda-8103-B4C75499B578} - {DE9C389F-3316-41A7-809B-AA305ED9D922} - c:\program files\aol\aim toolbar 5.0\aoltb.dll
IE: {92780B25-18CC-41C8-B9BE-3C9C571A8263} - {FF059E31-CC5A-4E2E-BF3B-96E929D65503} - c:\progra~1\micros~3\office11\REFIEBAR.DLL
IE: {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - {FE54FA40-D68C-11d2-98FA-00C0F0318AFE} - c:\windows\system32\Shdocvw.dll
IE: {EBD24BD3-E272-4FA3-A8BA-C5D709757CAB} - {EBD24BD3-E272-4FA3-A8BA-C5D709757CAB} - c:\program files\playsushi\PSText.dll
DPF: {0CCA191D-13A6-4E29-B746-314DEE697D83} - [You must be registered and logged in to see this link.]
DPF: {56336BCB-3D8A-11D6-A00B-0050DA18DE71} - [You must be registered and logged in to see this link.]
DPF: {5ED80217-570B-4DA9-BF44-BE107C0EC166} - [You must be registered and logged in to see this link.]
DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} - [You must be registered and logged in to see this link.]
DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} - [You must be registered and logged in to see this link.]
DPF: {C02226EB-A5D7-4B1F-BD7E-635E46C2288D} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0014-0002-0003-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0014-0002-0013-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0015-0000-0010-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0003-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {CAFEEFAC-0016-0000-0013-ABCDEFFEDCBA} - [You must be registered and logged in to see this link.]
DPF: {F91AB7B8-EE67-42AF-A5AA-8E232C396A04} - [You must be registered and logged in to see this link.]
Handler: cetihpz - {CF184AD3-CDCB-4168-A3F7-8E447D129300} - c:\program files\hp\hpcoretech\comp\hpuiprot.dll
FF - ProfilePath - c:\docume~1\markje~1\applic~1\mozilla\firefox\profiles\q3idopo5.default\
FF - component: c:\program files\bearshare applications\personalization\ff_v1047\components\BearSharePersonalizationFF_v1047.dll
FF - plugin: c:\program files\viewpoint\viewpoint experience technology\npViewpoint.dll
R2 Symantec Core LC;Symantec Core LC;c:\program files\common files\symantec shared\ccpd-lc\symlcsvc.exe [2004-9-7 1245064]
R2 Viewpoint Manager Service;Viewpoint Manager Service;c:\program files\viewpoint\common\ViewpointService.exe [2007-2-22 24652]
S3 lsscdbhk;lsscdbhk;\??\c:\docume~1\ashley~1\locals~1\temp\lsscdbhk.sys --> c:\docume~1\ashley~1\locals~1\temp\lsscdbhk.sys [?]
S3 MMCD;MMCD;\??\c:\docume~1\alisaj~1\locals~1\temp\mmcd.sys --> c:\docume~1\alisaj~1\locals~1\temp\MMCD.SYS [?]
S3 NwudfRd;NwudfRd;\??\c:\docume~1\hannah~1\locals~1\temp\nwudfrd.sys --> c:\docume~1\hannah~1\locals~1\temp\NwudfRd.sys [?]
2009-11-30 02:32:41 0 d-----w- c:\docume~1\markje~1\applic~1\Malwarebytes
2009-11-30 02:32:36 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-11-30 02:32:35 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-11-30 02:32:35 0 d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-11-30 02:32:35 0 d-----w- c:\docume~1\alluse~1\applic~1\Malwarebytes
2009-11-29 17:18:05 0 d-----w- c:\program files\Trend Micro
2009-11-13 01:25:03 107368 ----a-w- c:\windows\system32\GEARAspi.dll
2009-11-13 01:24:00 0 d-----w- c:\program files\iPod
2009-11-13 01:23:24 0 d-----w- c:\program files\iTunes
2009-11-12 12:11:21 118 ----a-w- c:\windows\system32\MRT.INI
2009-11-29 18:26:43 10344 ----a-w- c:\windows\system32\drivers\symlcbrd.sys
2009-10-29 23:31:47 46640 ----a-w- c:\windows\system32\msln.exe
2009-10-29 01:46:50 178432 ----a-w- c:\windows\system32\lsp.dll
2009-10-27 23:45:40 43824 ---ha-w- c:\windows\system32\mlfcache.dat
2009-10-20 00:00:35 3070976 ----a-w- c:\windows\system32\dllcache\mshtml.dll
2009-09-25 05:49:02 668672 ----a-w- c:\windows\system32\wininet.dll
2009-09-25 05:49:02 668672 ----a-w- c:\windows\system32\dllcache\wininet.dll
2009-09-25 05:49:02 628224 ----a-w- c:\windows\system32\dllcache\urlmon.dll
2009-09-25 05:49:02 474112 ------w- c:\windows\system32\dllcache\shlwapi.dll
2009-09-25 05:49:02 1509888 ------w- c:\windows\system32\dllcache\shdocvw.dll
2009-09-25 05:49:01 532480 ----a-w- c:\windows\system32\dllcache\mstime.dll
2009-09-25 05:49:01 449024 ----a-w- c:\windows\system32\dllcache\mshtmled.dll
2009-09-25 05:49:01 39424 ----a-w- c:\windows\system32\dllcache\pngfilt.dll
2009-09-25 05:49:01 146432 ----a-w- c:\windows\system32\dllcache\msrating.dll
2009-09-25 05:48:59 96256 ----a-w- c:\windows\system32\dllcache\inseng.dll
2009-09-25 05:48:59 81920 ----a-w- c:\windows\system32\ieencode.dll
2009-09-25 05:48:59 81920 ------w- c:\windows\system32\dllcache\ieencode.dll
2009-09-25 05:48:59 55808 ----a-w- c:\windows\system32\dllcache\extmgr.dll
2009-09-25 05:48:59 251904 ----a-w- c:\windows\system32\dllcache\iepeers.dll
2009-09-25 05:48:59 16384 ----a-w- c:\windows\system32\dllcache\jsproxy.dll
2009-09-25 05:48:58 357888 ----a-w- c:\windows\system32\dllcache\dxtmsft.dll
2009-09-25 05:48:58 205312 ----a-w- c:\windows\system32\dllcache\dxtrans.dll
2009-09-25 05:48:58 151040 ------w- c:\windows\system32\dllcache\cdfview.dll
2009-09-25 05:48:57 1024000 ------w- c:\windows\system32\dllcache\browseui.dll
2009-09-18 09:46:06 18432 ----a-w- c:\windows\system32\dllcache\iedw.exe
2009-09-11 14:33:52 133632 ----a-w- c:\windows\system32\msv1_0.dll
2009-09-11 14:33:52 133632 ------w- c:\windows\system32\dllcache\msv1_0.dll
2009-09-04 20:45:26 58880 ----a-w- c:\windows\system32\msasn1.dll
2009-09-04 20:45:26 58880 ------w- c:\windows\system32\dllcache\msasn1.dll
2003-07-28 10:16:52 36864 ----a-w- c:\windows\inf\i386\Vizmicro.dll
2003-07-28 10:16:26 172032 ----a-w- c:\windows\inf\i386\viceo.dll
2003-07-28 10:01:10 36207 ----a-w- c:\windows\inf\i386\9320FW.bin
2003-07-28 10:01:10 274432 ----a-w- c:\windows\inf\i386\9320LLD.dll
2003-07-28 10:01:10 155648 ----a-w- c:\windows\inf\i386\rtscan.dll
2001-08-03 22:29:18 13824 ----a-w- c:\windows\inf\i386\Usbscan.sys
============= FINISH: 19:26:59.68 ===============
bballjunky
Posts Posts : 10
Joined Joined : 2009-10-30
Points Points : 26118
Re: I have BankerFox & Nuqel on my PC and need your help
Post by bballjunky on 1st December 2009, 12:36 am
Here is the Attach log. See the prior reply for the DDS log.
Thanks!
Install Date: 9/11/2004 9:45:50 AM
System Uptime: 11/30/2009 7:22:10 PM (0 hours ago)
Motherboard: Dell Computer Corp. | | 0F4491
Processor: Intel(R) Pentium(R) 4 CPU 3.40GHz | Microprocessor | 3391/800mhz
A: is Removable
C: is FIXED (NTFS) - 146 GiB total, 99.207 GiB free.
D: is CDROM ()
E: is CDROM ()
F: is Removable
G: is Removable
H: is Removable
I: is Removable
J: is Removable
L: is FIXED (FAT32) - 57 GiB total, 18.172 GiB free.
RP693: 9/1/2009 9:20:43 PM - System Checkpoint
RP694: 9/8/2009 3:31:19 PM - System Checkpoint
RP695: 9/8/2009 9:02:00 PM - Software Distribution Service 3.0
RP696: 9/12/2009 9:35:58 AM - System Checkpoint
RP697: 10/1/2009 3:02:14 PM - System Checkpoint
RP698: 10/2/2009 6:06:42 PM - System Checkpoint
RP699: 10/3/2009 7:53:08 PM - System Checkpoint
RP700: 10/3/2009 11:08:56 PM - Software Distribution Service 3.0
RP701: 10/5/2009 4:55:09 PM - System Checkpoint
RP702: 10/8/2009 3:37:27 PM - System Checkpoint
RP703: 10/11/2009 8:00:39 PM - System Checkpoint
RP704: 10/13/2009 8:14:07 PM - Software Distribution Service 3.0
RP705: 10/17/2009 5:22:45 PM - System Checkpoint
RP706: 10/25/2009 1:05:53 PM - System Checkpoint
RP707: 10/26/2009 3:00:37 PM - System Checkpoint
RP708: 10/29/2009 9:17:43 PM - Software Distribution Service 3.0
RP709: 11/6/2009 4:30:54 PM - Software Distribution Service 3.0
RP710: 11/10/2009 6:09:39 PM - System Checkpoint
RP711: 11/12/2009 7:04:34 AM - Software Distribution Service 3.0
RP712: 11/21/2009 8:39:00 PM - System Checkpoint
RP713: 11/24/2009 5:50:47 PM - Software Distribution Service 3.0
RP714: 11/27/2009 1:56:02 PM - System Checkpoint
Abacast Client
Adobe Acrobat - Reader 6.0.2 Update
Adobe Flash Player 10 Plugin
Adobe Reader 6.0.1
Adobe Shockwave Player 11.5
AIM 6
AIM Toolbar 5.0
Alchemist Special Edition
Animals of Africa
AOL Instant Messenger
AOL Uninstaller (Choose which Products to Remove)
AOL You've Got Pictures Screensaver
Apple Application Support
Apple Mobile Device Support
Apple Software Update
ArcSoft PhotoImpression
Arthur's Thinking Games
Ask Toolbar
Avanquest update
Balloon Kaboom
Balloon Pop Special Edition
Banctec Service Agreement
Barbie(TM) Horse Adventures(TM)
Basketball
BearShare
Bingo Master Special Edition
Black Jack Fever Special Edition
Blast Thru Special Edition
Block Rox
Bonjour
Bowling Mania Special Edition
BufferChm
Build in Time
Burlington's Greeting Card Creator 32
Castle Slots
Chess Swappers
Chinese Checkers
Chinese Chess
Clifford Learning Activities
ClueFinders 3rd Grade Adventures
ClueFinders 5th Grade Adventures
ClueFinders(R) 4th Grade Adventures
Collector's Edition 251
Colors of War Special Edition
Consumer Complete Care Services Agreement
Creative MediaSource
CreativeProjects
CreativeProjectsTemplates
CueTour
Dell Digital Jukebox Driver
Dell Media Experience
Dell Networking Guide
Dell Solution Center
Dell Support Center (Support Software)
DellSupport
Destinations
Director
Disney's Winnie the Pooh Toddler
Diva Starz(TM) CD-ROM
EarthLink Setup Files
Extreme Dinosaurs Special Edition
Fisher~Price® Ready For School
Four Orbs
FrostWire 4.17.0
Get High Speed Internet!
Glowing Bugs Special Edition
Hallmark Holiday Card Studio
Hearts
HelloKitty (remove only)
Help and Support Customization
HijackThis 2.0.2
Hotfix for Windows XP (KB914440)
Hotfix for Windows XP (KB915865)
Hotfix for Windows XP (KB926239)
HP Diagnostic Assistant
HP Image Zone 4.0
HP Software Update
HPSystemDiagnostics
InstantShare
Intel(R) 537EP V9x DF PCI Modem
Intel(R) PRO Network Adapters and Drivers
Intel(R) PROSet
Internet Explorer Default Page
iTunes
J2SE Runtime Environment 5.0 Update 10
Jasc Paint Shop Photo Album
Jasc Paint Shop Pro 8 Dell Edition
Java 2 Runtime Environment, SE v1.4.2_03
Java 2 Runtime Environment, SE v1.4.2_13
Java(TM) 6 Update 13
Java(TM) 6 Update 3
Jigsaw USA Special Edition
Jumpstart First Grade v1.4
JumpStart Kindergarten v2.4b
Jumpstart Preschool v2.3b
Kid Pix Deluxe 3
Learn2 Player (Uninstall Only)
Lernout & Hauspie TruVoice American English TTS Engine
LG USB Drivers
Maze Cube
MediaBar 2.0 (BearShare)
Microsoft .NET Framework 1.1
Microsoft Money 2004
Microsoft Money 2004 System Pack
Microsoft Office Basic Edition 2003
Microsoft Silverlight
Microsoft Text-to-Speech Engine 4.0 (English)
Mini Go
Mini Golf Master 2 Special Edition
Mini Golf Special Edition
Modem Event Monitor
Modem Helper
Modem On Hold
Mozilla Firefox (3.0.15)
MSN Music Assistant
MSXML 4.0 SP2 (KB927978)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
MSXML 4.0 SP2 (KB973688)
MUSICMATCH® Jukebox
My Little Pony
NetZeroInstallers
Norton Security Scan
NVIDIA Windows 2000/XP Display Drivers
Overland
Owl and Mouse U.S. Map Puzzle
PaperPort 8.0 SE
Pet Vet (remove only)
Photo Story 3 for Windows
PhotoGallery
Photosmart 320,370,7400,8100,8400 Series
Pinball Master Special Edition
Playsushi
PowerDVD 5.1
PrintScreen
PS8400
PSPrinters06
QFolder
QuickProjects
QuickTime
Reader Rabbit 1st Grade
RealPlayer Basic
Rifle Range
Ringtone Media Studio
Rockett's Camp Adventures(TM)
SeaWorld Adventure Park Tycoon
Security Update for Windows XP (KB890046)
Security Update for Windows XP (KB893756)
Security Update for Windows XP (KB896358)
Security Update for Windows XP (KB896423)
Security Update for Windows XP (KB896424)
Security Update for Windows XP (KB896428)
Security Update for Windows XP (KB899587)
Security Update for Windows XP (KB899591)
Security Update for Windows XP (KB900725)
Security Update for Windows XP (KB901017)
Security Update for Windows XP (KB901214)
Security Update for Windows XP (KB902400)
Security Update for Windows XP (KB904706)
Security Update for Windows XP (KB905414)
Security Update for Windows XP (KB905749)
Security Update for Windows XP (KB908519)
Security Update for Windows XP (KB911562)
Security Update for Windows XP (KB911927)
Security Update for Windows XP (KB912919)
Security Update for Windows XP (KB913580)
Security Update for Windows XP (KB914388)
Security Update for Windows XP (KB914389)
Security Update for Windows XP (KB917344)
Security Update for Windows XP (KB917422)
Security Update for Windows XP (KB917953)
Security Update for Windows XP (KB918118)
Security Update for Windows XP (KB919007)
Security Update for Windows XP (KB920213)
Security Update for Windows XP (KB920670)
Security Update for Windows XP (KB920683)
Security Update for Windows XP (KB920685)
Security Update for Windows XP (KB921398)
Security Update for Windows XP (KB921503)
Security Update for Windows XP (KB921883)
Security Update for Windows XP (KB922616)
Security Update for Windows XP (KB922819)
Security Update for Windows XP (KB923191)
Security Update for Windows XP (KB923414)
Security Update for Windows XP (KB923694)
Security Update for Windows XP (KB923980)
Security Update for Windows XP (KB924191)
Security Update for Windows XP (KB924270)
Security Update for Windows XP (KB924496)
Security Update for Windows XP (KB924667)
Security Update for Windows XP (KB925454)
Security Update for Windows XP (KB925486)
Security Update for Windows XP (KB925902)
Security Update for Windows XP (KB926255)
Security Update for Windows XP (KB926436)
Security Update for Windows XP (KB927779)
Security Update for Windows XP (KB927802)
Security Update for Windows XP (KB928090)
Security Update for Windows XP (KB928255)
Security Update for Windows XP (KB928843)
Security Update for Windows XP (KB929123)
Security Update for Windows XP (KB929969)
Security Update for Windows XP (KB930178)
Security Update for Windows XP (KB931261)
Security Update for Windows XP (KB931768)
Security Update for Windows XP (KB931784)
Security Update for Windows XP (KB932168)
Security Update for Windows XP (KB933566)
Security Update for Windows XP (KB933729)
Security Update for Windows XP (KB935839)
Security Update for Windows XP (KB935840)
Security Update for Windows XP (KB936021)
Security Update for Windows XP (KB937143)
Security Update for Windows XP (KB938127)
Security Update for Windows XP (KB938829)
Security Update for Windows XP (KB939653)
Security Update for Windows XP (KB941202)
Security Update for Windows XP (KB941568)
Security Update for Windows XP (KB941644)
Security Update for Windows XP (KB941693)
Security Update for Windows XP (KB942615)
Security Update for Windows XP (KB943055)
Security Update for Windows XP (KB943460)
Security Update for Windows XP (KB943485)
Security Update for Windows XP (KB944338)
Security Update for Windows XP (KB944533)
Security Update for Windows XP (KB944653)
Security Update for Windows XP (KB945553)
Security Update for Windows XP (KB946026)
Security Update for Windows XP (KB947864)
Security Update for Windows XP (KB948590)
Security Update for Windows XP (KB948881)
Security Update for Windows XP (KB950749)
Security Update for Windows XP (KB950759)
Security Update for Windows XP (KB956390)
Security Update for Windows XP (KB958215)
Security Update for Windows XP (KB958470)
Security Update for Windows XP (KB960714)
Security Update for Windows XP (KB963027)
Security Update for Windows XP (KB969897)
Security Update for Windows XP (KB974455)
SkinsHP1
Small Chess
Smilies
Snake Arena Special Edition
Sonic DLA
Sonic MyDVD
Sonic RecordNow!
Sonic Update Manager
Sound Blaster Audigy 2
TaxCut 2004
TaxCut Deluxe 2005
TrayApp
Unload
Update for Windows XP (KB900485)
Update for Windows XP (KB904942)
Update for Windows XP (KB908531)
Update for Windows XP (KB910437)
Update for Windows XP (KB911280)
Update for Windows XP (KB916595)
Update for Windows XP (KB920872)
Update for Windows XP (KB922582)
Update for Windows XP (KB927891)
Update for Windows XP (KB929338)
Update for Windows XP (KB930916)
Update for Windows XP (KB931836)
Update for Windows XP (KB933360)
Update for Windows XP (KB936357)
Update for Windows XP (KB938828)
Update for Windows XP (KB942763)
Update for Windows XP (KB942840)
Update for Windows XP (KB946627)
Update for Windows XP (KB976749)
Viewpoint Manager (Remove Only)
Viewpoint Media Player
Viewpoint Toolbar
Visioneer OneTouch 9320
Wal-Mart Music Downloads Store
WebFldrs XP
WebReg
Wild Wheels Special Edition
Windows Live OneCare safety scanner
Windows XP Hotfix - KB873339
Windows XP Hotfix - KB885835
Windows XP Hotfix - KB885836
Windows XP Hotfix - KB886185
Windows XP Hotfix - KB887472
Windows XP Hotfix - KB888302
Windows XP Hotfix - KB890859
Windows XP Hotfix - KB891781
Windows XP Service Pack 2
Winferno Registry Power Cleaner
Yahoo! Toolbar
Yahtzee
11/29/2009 7:59:22 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service iPod Service with arguments "" in order to run the server: {063D34A4-BF84-4B8D-B699-E8CA06504DDE}
11/29/2009 12:49:25 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service StiSvc with arguments "" in order to run the server: {A1F4E726-8CF1-11D1-BF92-0060081ED811}
11/29/2009 12:48:55 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service netman with arguments "" in order to run the server: {BA126AE5-2166-11D1-B1D0-00805FC1270E}
11/29/2009 12:48:30 PM, error: Service Control Manager [7026] - The following boot-start or system-start driver(s) failed to load: AFD Fips intelppm IPSec MRxSmb NetBIOS NetBT RasAcd Rdbss Tcpip
11/29/2009 12:48:30 PM, error: Service Control Manager [7001] - The TCP/IP NetBIOS Helper service depends on the AFD Networking Support Environment service which failed to start because of the following error: A device attached to the system is not functioning.
11/29/2009 12:48:30 PM, error: Service Control Manager [7001] - The IPSEC Services service depends on the IPSEC driver service which failed to start because of the following error: A device attached to the system is not functioning.
11/29/2009 12:48:30 PM, error: Service Control Manager [7001] - The DNS Client service depends on the TCP/IP Protocol Driver service which failed to start because of the following error: A device attached to the system is not functioning.
11/29/2009 12:48:30 PM, error: Service Control Manager [7001] - The DHCP Client service depends on the NetBios over Tcpip service which failed to start because of the following error: A device attached to the system is not functioning.
11/29/2009 12:48:30 PM, error: Service Control Manager [7001] - The Bonjour Service service depends on the TCP/IP Protocol Driver service which failed to start because of the following error: A device attached to the system is not functioning.
11/29/2009 12:48:30 PM, error: Service Control Manager [7001] - The Apple Mobile Device service depends on the TCP/IP Protocol Driver service which failed to start because of the following error: A device attached to the system is not functioning.
11/29/2009 12:48:25 PM, error: DCOM [10005] - DCOM got error "%1084" attempting to start the service EventSystem with arguments "" in order to run the server: {1BE1F766-5536-11D1-B726-00C04FB926AF}
11/29/2009 12:42:29 PM, error: W32Time [46] - The time service encountered an error and was forced to shut down. The error was: 0x8007045B
11/29/2009 1:29:36 PM, error: Service Control Manager [7026] - The following boot-start or system-start driver(s) failed to load: Fips intelppm
bballjunky
Posts Posts : 10
Post by Belahzur on 1st December 2009, 1:45 am
  • Download combofix from here
Points Points : 245111
Post by Belahzur on 1st December 2009, 9:46 pm
Can you post the Combofix log please? should be located at C:\Combofix.txt
Post by bballjunky on 4th December 2009, 12:02 am
Here's the Combofix log. Thanks
ComboFix 09-12-02.05 - Mark Jeffords 12/02/2009 22:50.1.2 - x86
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.511.148 [GMT -5:00]
Running from: c:\documents and settings\Mark Jeffords\Desktop\Combo-Fix.exe
c:\documents and settings\Lauren Jeffords\Local Settings\Application Data\jqonsj
c:\documents and settings\Lauren Jeffords\Local Settings\Application Data\jqonsj\amwxsysguard.exe
c:\program files\Internet Explorer\msimg32.dll
c:\program files\PlaySushi\PSTExt.dll
c:\windows\desktop
c:\windows\desktop\Diva Starz(TM) CD-ROM.lnk
c:\windows\Downloaded Program Files\RdxIE.dll
c:\windows\system32\mydll.dll
((((((((((((((((((((((((( Files Created from 2009-11-03 to 2009-12-03 )))))))))))))))))))))))))))))))
2009-12-01 00:41 . 2009-12-01 00:41 -------- d-----w- c:\documents and settings\Alisa Jeffords\Application Data\Malwarebytes
2009-11-30 21:13 . 2009-11-30 21:13 -------- d-----w- c:\documents and settings\Lauren Jeffords\Application Data\Leadertech
2009-11-30 21:06 . 2009-11-30 21:06 -------- d-----w- c:\documents and settings\Lauren Jeffords\Application Data\Malwarebytes
2009-11-30 20:28 . 2009-11-30 20:28 -------- d-----w- c:\documents and settings\Hannah Jeffords\Application Data\Malwarebytes
2009-11-30 11:56 . 2009-11-30 11:56 -------- d-----w- c:\documents and settings\Ashley Jeffords\Application Data\Malwarebytes
2009-11-30 02:32 . 2009-11-30 02:32 -------- d-----w- c:\documents and settings\Mark Jeffords\Application Data\Malwarebytes
2009-11-30 02:32 . 2009-09-10 19:54 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-11-30 02:32 . 2009-11-30 02:32 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-11-30 02:32 . 2009-11-30 02:32 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2009-11-30 02:32 . 2009-09-10 19:53 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-11-29 18:40 . 2004-09-08 03:13 24520 ----a-w- c:\documents and settings\Administrator.JEFFORDS1\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-11-29 17:18 . 2009-11-29 17:18 -------- d-----w- c:\program files\Trend Micro
2009-11-13 01:25 . 2008-04-17 18:12 107368 ----a-w- c:\windows\system32\GEARAspi.dll
2009-11-13 01:24 . 2009-11-13 01:24 -------- d-----w- c:\program files\iPod
2009-11-13 01:23 . 2009-11-13 01:25 -------- d-----w- c:\program files\iTunes
2009-11-13 01:13 . 2009-11-13 01:13 79144 ----a-w- c:\documents and settings\All Users\Application Data\Apple Computer\Installer Cache\iTunes 9.0.2.25\SetupAdmin.exe
2009-12-03 04:22 . 2009-10-29 01:42 -------- d-----w- c:\program files\PlaySushi
2009-12-03 01:53 . 2004-09-08 03:02 288 ----a-w- c:\windows\system32\DVCStateBkp-{00000002-00000000-00000002-00001102-00000004-10031102}.dat
2009-12-03 01:53 . 2004-09-08 03:02 288 ----a-w- c:\windows\system32\DVCState-{00000002-00000000-00000002-00001102-00000004-10031102}.dat
2009-11-29 18:26 . 2004-09-08 03:06 10344 ----a-w- c:\windows\system32\drivers\symlcbrd.sys
2009-11-29 00:51 . 2009-10-29 01:44 -------- d-----w- c:\program files\qhaqan
2009-11-13 01:23 . 2008-12-25 16:57 -------- d-----w- c:\program files\Common Files\Apple
2009-11-04 21:45 . 2005-02-22 20:54 -------- d-----w- c:\documents and settings\Ashley Jeffords\Application Data\AdobeUM
2009-11-03 12:25 . 2008-05-01 01:47 -------- d-----w- c:\documents and settings\Lauren Jeffords\Application Data\U3
2009-11-01 02:02 . 2009-10-29 22:43 -------- d-----w- c:\documents and settings\Mark Jeffords\Application Data\U3
2009-10-30 00:04 . 2004-09-08 03:06 -------- d-----w- c:\program files\Common Files\Symantec Shared
2009-10-29 23:31 . 2009-10-29 23:31 46640 ----a-w- c:\windows\system32\msln.exe
2009-10-29 19:49 . 2009-10-29 19:49 -------- d-----w- c:\program files\MSN Toolbar Installer
2009-10-28 00:16 . 2008-01-19 14:32 -------- d-----w- c:\documents and settings\Lauren Jeffords\Application Data\FrostWire
2009-10-27 23:45 . 2009-10-27 23:45 43824 ---ha-w- c:\windows\system32\mlfcache.dat
2009-10-27 21:54 . 2009-10-27 21:54 -------- d-----w- c:\documents and settings\Hannah Jeffords\Application Data\AdobeUM
2009-10-27 15:42 . 2009-10-27 15:42 188928 ----a-w- c:\documents and settings\Alisa Jeffords\Application Data\Mozilla\Extensions\{ec8030f7-c20a-464f-9b0e-13a3a9e97384}\textlinks@playsushi.com\components\PlaySushiFF.dll
2009-10-27 02:50 . 2004-10-24 19:39 -------- d-----w- c:\documents and settings\Mark Jeffords\Application Data\AdobeUM
2009-10-24 13:36 . 2009-06-02 14:35 -------- d-----w- c:\documents and settings\Ashley Jeffords\Application Data\Apple Computer
2009-10-19 21:39 . 2005-03-05 22:36 -------- d-----w- c:\documents and settings\Alisa Jeffords\Application Data\AdobeUM
2009-10-15 18:40 . 2008-12-25 17:01 -------- d-----w- c:\documents and settings\Lauren Jeffords\Application Data\Apple Computer
2009-10-15 18:32 . 2009-10-15 18:31 -------- d-----w- c:\documents and settings\All Users\Application Data\{755AC846-7372-4AC8-8550-C52491DAA8BD}
2009-10-15 18:29 . 2009-10-15 18:29 -------- d-----w- c:\program files\QuickTime
2009-10-14 20:49 . 2005-01-20 00:07 -------- d-----w- c:\documents and settings\Lauren Jeffords\Application Data\AdobeUM
2009-09-25 05:49 . 2006-06-23 16:33 668672 ----a-w- c:\windows\system32\wininet.dll
2009-09-25 05:48 . 2004-08-04 07:56 81920 ----a-w- c:\windows\system32\ieencode.dll
2009-09-11 14:33 . 2002-08-29 10:00 133632 ----a-w- c:\windows\system32\msv1_0.dll
2009-09-04 20:45 . 2004-03-30 01:48 58880 ----a-w- c:\windows\system32\msasn1.dll
"MSMSGS"="c:\program files\Messenger\msmsgs.exe" [2004-10-13 1694208]
"MoneyAgent"="c:\program files\Microsoft Money\System\mnyexpr.exe" [2003-06-18 200704]
"DellSupportCenter"="c:\program files\Dell Support Center\bin\sprtcmd.exe" [2008-08-13 206064]
"RealTray"="c:\program files\Real\RealPlayer\RealPlay.exe SYSTEMBOOTHIDEPLAYER" [X]
"NvCplDaemon"="c:\windows\System32\NvCpl.dll" [2003-11-03 4800512]
"DVDLauncher"="c:\program files\CyberLink\PowerDVD\DVDLauncher.exe" [2004-04-11 53248]
"IntelMeM"="c:\program files\Intel\Modem Event Monitor\IntelMEM.exe" [2003-09-04 221184]
"CTSysVol"="c:\program files\Creative\SBAudigy2\Surround Mixer\CTSysVol.exe" [2002-10-29 49152]
"CTDVDDet"="c:\program files\Creative\SBAudigy2\DVDAudio\CTDVDDet.EXE" [2002-09-30 45056]
"UpdReg"="c:\windows\UpdReg.EXE" [2000-05-11 90112]
"PCMService"="c:\program files\Dell\Media Experience\PCMService.exe" [2004-04-12 290816]
"dla"="c:\windows\system32\dla\tfswctrl.exe" [2004-03-15 122933]
"UpdateManager"="c:\program files\Common Files\Sonic\Update Manager\sgtray.exe" [2003-08-19 110592]
"mmtask"="c:\program files\MusicMatch\MusicMatch Jukebox\mmtask.exe" [2004-04-19 53248]
"MMTray"="c:\program files\MUSICMATCH\Musicmatch Jukebox\mm_tray.exe" [2004-04-19 131072]
"HPDJ Taskbar Utility"="c:\windows\System32\spool\drivers\w32x86\3\hpztsb11.exe" [2004-04-06 172032]
"HPHUPD06"="c:\program files\HP\{AAC4FC36-8F89-4587-8DD3-EBC57C83374D}\hphupd06.exe" [2004-06-07 49152]
"HP Software Update"="c:\program files\HP\HP Software Update\HPWuSchd2.exe" [2004-02-12 49152]
"HP Component Manager"="c:\program files\HP\hpcoretech\hpcmpmgr.exe" [2004-05-12 241664]
"HPHmon06"="c:\windows\System32\hphmon06.exe" [2004-06-07 659456]
"HostManager"="c:\program files\Common Files\AOL\1107989059\ee\AOLSoftware.exe" [2006-09-26 50736]
"AOLDialer"="c:\program files\Common Files\AOL\ACS\AOLDial.exe" [2006-10-23 71216]
"Pure Networks Port Magic"="c:\progra~1\PURENE~1\PORTMA~1\PortAOL.exe" [2004-04-05 99480]
"PaperPort PTD"="c:\program files\Scansoft\PaperPort\pptd40nt.exe" [2002-09-23 45108]
"IndexSearch"="c:\program files\Scansoft\PaperPort\IndexSearch.exe" [2002-09-23 36864]
"OneTouch Monitor"="c:\program files\Visioneer OneTouch\OneTouchMon.exe" [2003-08-18 98304]
"dscactivate"="c:\program files\Dell Support Center\gs_agent\custom\dsca.exe" [2007-11-15 16384]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2009-09-05 417792]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2009-10-29 141600]
"CTHelper"="CTHELPER.EXE" - c:\windows\SYSTEM32\CTHELPER.EXE [2003-02-20 28672]
"AsioReg"="CTASIO.DLL" - c:\windows\SYSTEM32\CTASIO.DLL [2003-02-20 110592]
"c:\\Program Files\\America Online 9.0\\waol.exe"=
"c:\\Program Files\\Common Files\\AOL\\1107989059\\EE\\aolsoftware.exe"=
"c:\\StubInstaller.exe"=
"c:\\Program Files\\America Online 9.0a\\waol.exe"=
"c:\\Program Files\\AIM\\aim.exe"=
"c:\\Program Files\\BearShare Applications\\BearShare\\BearShare.exe"=
"c:\\Program Files\\FrostWire\\FrostWire.exe"=
R2 Viewpoint Manager Service;Viewpoint Manager Service;c:\program files\Viewpoint\Common\ViewpointService.exe [2/22/2007 5:11 PM 24652]
S3 lsscdbhk;lsscdbhk;\??\c:\docume~1\ASHLEY~1\LOCALS~1\Temp\lsscdbhk.sys --> c:\docume~1\ASHLEY~1\LOCALS~1\Temp\lsscdbhk.sys [?]
S3 MMCD;MMCD;\??\c:\docume~1\ALISAJ~1\LOCALS~1\Temp\MMCD.SYS --> c:\docume~1\ALISAJ~1\LOCALS~1\Temp\MMCD.SYS [?]
S3 NwudfRd;NwudfRd;\??\c:\docume~1\HANNAH~1\LOCALS~1\Temp\NwudfRd.sys --> c:\docume~1\HANNAH~1\LOCALS~1\Temp\NwudfRd.sys [?]
2009-12-02 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2008-07-30 17:34]
2009-12-02 c:\windows\Tasks\HP Usg Daily FY04.job
- c:\program files\HP\{AAC4FC36-8F89-4587-8DD3-EBC57C83374D}\pexpress\hphped06.exe [2004-06-07 04:53]
2009-09-18 c:\windows\Tasks\Norton Security Scan.job
- c:\program files\Norton Security Scan\Nss.exe [2007-04-20 03:42]
uInternet Connection Wizard,ShellNext = "c:\program files\MSN Gaming Zone\Windows\CHKRZM.EXE"
IE: &AOL Toolbar Search - c:\program files\aol\aim toolbar 5.0\resources\en-US\local\search.html
IE: &Search
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~3\OFFICE11\EXCEL.EXE/3000
IE: {{EBD24BD3-E272-4FA3-A8BA-C5D709757CAB} - {EBD24BD3-E272-4FA3-A8BA-C5D709757CAB} - c:\program files\PlaySushi\PSText.dll
DPF: {6632A7E9-FE1F-43D2-A04A-A15951ED63E0} - [You must be registered and logged in to see this link.]
FF - ProfilePath - c:\documents and settings\Mark Jeffords\Application Data\Mozilla\Firefox\Profiles\q3idopo5.default\
FF - component: c:\program files\BearShare Applications\Personalization\FF_v1047\components\BearSharePersonalizationFF_v1047.dll
AddRemove-BearShare - c:\program files\BearShare Applications\BearShare\UninstallSurvey.exe c:\progra~1\BEARSH~1\BEARSH~1\UNWISE.EXE
AddRemove-Playsushi - c:\program files\PlaySushi\psuninst.exe
AddRemove-RealPlayer 6.0 - c:\program files\Common Files\Real\Update\\rnuninst.exe RealNetworks|RealPlayer|6.0
AddRemove-RegPowerClean2007_is1 - c:\program files\Winferno\RegistryPowerCleaner\unins000.exe
Rootkit scan 2009-12-02 23:25
scanning hȋdden processes ...
scanning hȋdden files ...
hȋdden files: 0
[HKEY_LOCAL_MACHINE\software\Classes\.mfp]
@DACL=(02 0000)
@="MacromediaFlashPaper.MacromediaFlashPaper"
"Content Type"="application/x-shockwave-flash"
[HKEY_LOCAL_MACHINE\software\Classes\.sol]
@DACL=(02 0000)
"Content Type"="text/plain"
[HKEY_LOCAL_MACHINE\software\Classes\.sor]
@DACL=(02 0000)
Completion time: 2009-12-02 23:43
ComboFix-quarantined-files.txt 2009-12-03 04:42
Pre-Run: 106,350,702,592 bytes free
Post-Run: 108,277,817,344 bytes free
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Home Edition" /fastdetect /NoExecute=OptIn
- - End Of File - - A1C1E8F05A049126A4E5096921A0AC67
bballjunky
Posts Posts : 10
Post by Belahzur on 4th December 2009, 1:19 am
I see that you are running Frostwire.
    Ask Toolbar
    FrostWire 4.17.0
    Java(TM) 6 Update 3MediaBar 2.0 (BearShare)
    Viewpoint Toolbar
  • Save it to your desktop.
    :services
    lsscdbhk
    MMCD
    NwudfRd
    :files
    c:\documents and settings\Lauren Jeffords\Application Data\Viewpoint
    c:\program files\FrostWire
  • Close OTMoveIt
Please post the OTMoveIt log.
