Help mcafee - "error starting on demand SCANNER" FUBAR PC
Post by timbalish on 30th October 2009, 12:39 am
I am new and need some help!
You guys are the men when it comes to this, hopefully someone can help me.
I tried to get a log file, but it quits before I can save.
I tried to use winlogon.scr it runs once, but the log flys by and I am unable to copy/save it. then it will not run again. An now access is denied to delete that file. I tried again saving under another file name with no luck.
Can you help Smile) THANKS SO MUCH!!!!!
Tim Christenson
timbalish
Posts Posts : 3
Joined Joined : 2009-10-29
Points Points : 25995
Re: Help mcafee - "error starting on demand SCANNER" FUBAR PC
Post by timbalish on 30th October 2009, 12:54 am
I used systemlook as you instructed another user with the same problem and this is the log it returned:
SystemLook v1.0 by jpshortstuff (29.08.09)
Log created at 19:48 on 29/10/2009 by Tim Christenson (Administrator - Elevation successful)
Searching for "scecli.dll"
C:\i386\scecli.dll --a--c 180224 bytes [02:24 09/10/2006] [09:00 04/08/2004] 0F78E27F563F2AAF74B91A49E2ABF19A
C:\WINDOWS\$NtServicePackUninstall$\scecli.dll -----c 180224 bytes [22:20 03/10/2008] [09:00 04/08/2004] 0F78E27F563F2AAF74B91A49E2ABF19A
C:\WINDOWS\ServicePackFiles\i386\scecli.dll -----c 181248 bytes [00:14 22/08/2008] [00:12 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
C:\WINDOWS\system32\scecli.dll --a--- 181248 bytes [16:51 10/08/2004] [00:12 14/04/2008] A86BB5E61BF3E39B62AB4C7E7085A084
Searching for "netlogon.dll"
C:\i386\netlogon.dll --a--c 407040 bytes [02:23 09/10/2006] [09:00 04/08/2004] 96353FCECBA774BB8DA74A1C6507015A
C:\WINDOWS\$NtServicePackUninstall$\netlogon.dll -----c 407040 bytes [22:20 03/10/2008] [09:00 04/08/2004] 96353FCECBA774BB8DA74A1C6507015A
C:\WINDOWS\ServicePackFiles\i386\netlogon.dll -----c 407040 bytes [00:13 22/08/2008] [00:12 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
C:\WINDOWS\system32\netlogon.dll --a--- 407040 bytes [16:51 10/08/2004] [00:12 14/04/2008] 1B7F071C51B77C272875C3A23E1E4550
Searching for "eventlog.dll"
C:\i386\eventlog.dll --a--c 55808 bytes [02:21 09/10/2006] [09:00 04/08/2004] 82B24CB70E5944E6E34662205A2A5B78
C:\WINDOWS\$NtServicePackUninstall$\eventlog.dll -----c 55808 bytes [22:21 03/10/2008] [09:00 04/08/2004] 82B24CB70E5944E6E34662205A2A5B78
C:\WINDOWS\ServicePackFiles\i386\eventlog.dll -----c 56320 bytes [00:11 22/08/2008] [00:11 14/04/2008] 6D4FEB43EE538FC5428CC7F0565AA656
C:\WINDOWS\system32\eventlog.dll --a--- 61952 bytes [16:51 10/08/2004] [00:11 14/04/2008] (Unable to calculate MD5)
Searching for "cngaudit.dll"
No files found.
-=End Of File=-
I hope that helps start the process.
THANKS !! u the man!
timbalish
Posts Posts : 3
Post by Belahzur on 30th October 2009, 1:21 am
Files to delete:
Points Points : 245111
Post by timbalish on 30th October 2009, 1:35 am
my mcafee says avanger.exe is has a trojan horse and will not let it run.
that makes me scared.
timbalish
Posts Posts : 3
Post by Belahzur on 31st October 2009, 12:16 am
Uninstall Mcafee, it just interferes too much. The warning isn't right, avenger is NOT malicious in any way.
