ANTIVIRUS SYSTEM PRO -HIJACKTHIS NOT WORKING???
Post by Marianna on Mon Oct 26, 2009 9:38 pm
I really need help removing AntiVrus System Pro from my laptop. I've read all the posts, tried MalwareBytes, Hijackthis...nothing helps because the pop ups all stop me from doing what I need to do to get the info you require. I can't get online with my laptop (using my pc), I get around 20 pop ups a minute and it's driving me crazy.
I'm completely lost and don't know what else to do. PLEASE HELP!
Marianna
OS : Vista
Re: ANTIVIRUS SYSTEM PRO -HIJACKTHIS NOT WORKING???
Post by Belahzur on Tue Oct 27, 2009 12:05 am
Will Hijack This actually run though?
Post by Marianna on Tue Oct 27, 2009 12:48 am
I tried to run Malwarebytes first, it wouldn't allow me to install it. The pop ups would immediately come up and everything else closes. Tried the same with Hijackthis...downloads fine but as soon as I try to open/run anything the pop ups appear and shuts down the prog I'm trying to run. I have somehow managed to reinstall the newest version of avg (which i was originally using), it's done a full scan and says it's got rid of some things but not everything. Antivirus is still there and giving me pop up messages by the dozen every minute.
Can you give me any idea's?
Marianna
OS : Vista
Post by Belahzur on Tue Oct 27, 2009 7:47 pm
Lets try this.
Post by Marianna on Tue Oct 27, 2009 11:19 pm
[You must be registered and logged in to see this link.] wrote:Lets try this.
Ok, just downloaded the file and tried to run the prog...the window appears only for a split second, didn't manage to do or read any of it before it immediately closed down again. Tried it a few times and the same happend.
Marianna
OS : Vista
Post by Belahzur on Wed Oct 28, 2009 1:35 am
    :filefind
    scecli.dll
    netlogon.dll
    eventlog.dll
    cngaudit.dll
Post by Marianna on Wed Oct 28, 2009 9:26 pm
Hi, Not sure if this has worked correctly but here is what came up in the txt file :
SystemLook v1.0 by jpshortstuff (29.08.09)
Log created at 20:54 on 28/10/2009 by Maz (Administrator - Elevation successful)
Searching for "scecli.dll"
Marianna
OS : Vista
Post by Belahzur on Thu Oct 29, 2009 12:28 am
It worked, but not fully, that's only half the log.
Can you manually check this for me.
Find this file:
C:\Windows\system32\eventlog.dll
Right click, select Properties. Can you tell me what it's filesize is please?
Post by Marianna on Fri Oct 30, 2009 12:42 am
Hmmm, tried to locate the file. I get a message telling me it doesn't exist, I've checked that I typed it in correctly and even tried to locate it the long way but it really doesn't seem to exist. Any suggestions?
Sorry to be such a pain, I don't know what else to try.
Marianna
OS : Vista
Post by Belahzur on Fri Oct 30, 2009 1:21 am
Hmm, perhaps one of the other files.
Check for this file and it's filesize if it exists.
C:\Windows\system32\cngaudit.dll
Post by Marianna on Fri Oct 30, 2009 8:42 am
Managed to find this file, it's saying 60.5Kb.
Marianna
OS : Vista
Post by Belahzur on Fri Oct 30, 2009 8:45 pm
Bingo.
Files to delete:
C:\WINDOWS\system32\cngaudit.dll
