HELP Antivirus PRO
HELP Antivirus PRO
Post by CraigK on Sun Oct 25, 2009 3:46 am
Hi, I have rad alot about this vrirus and am urrently trying to get it off my computer but I having a little trouble..
I romoved the PRO process from the computer and was able to delete the pogram file on it, and then I was able to install "Malwre-Bytes" Anti-Malware and have run several scans to try and delete the files.. After 2-3 scans and re-boots Im still having trouble with my internet and the scan says it cannot delete a few of the remaining files.. Can someone help me to completely remove this threat?? thx, Ck.
CraigK
Posts Posts : 4
Joined Joined : 2009-10-25
Points Points : 25986
Re: HELP Antivirus PRO
Post by Belahzur on Sun Oct 25, 2009 6:18 pm
Points Points : 245059
Post by CraigK on Sun Oct 25, 2009 6:24 pm
thanks for the help!! Gotta go to work for this afternoon, but will DL and scan once I get home.. Ill leave the information and post sometime in the early hours of tomorrow morning.
CraigK
Posts Posts : 4
Post by CraigK on Mon Oct 26, 2009 3:22 am
Ok, just did the scan.. heres the notepad info..
Scan saved at 11:21:16 PM, on 10/25/2009
C:\WINDOWS\system32\drivers\CDAC11BA.EXE
C:\WINDOWS\System32\cisvc.exe
C:\Program Files\McAfee\SiteAdvisor\McSACore.exe
c:\program files\common files\mcafee\mna\mcnasvc.exe
C:\Program Files\Common Files\Microsoft Shared\Works Shared\WkUFind.exe
C:\Program Files\Common Files\Totem Shared\Uninstall0001\upd.exe
C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
C:\Program Files\Microsoft IntelliType Pro\itype.exe
C:\Program Files\Microsoft IntelliPoint\ipoint.exe
C:\Program Files\Windows Live\Messenger\MsnMsgr.Exe
C:\Program Files\Microsoft IntelliPoint\dpupdchk.exe
C:\Program Files\Windows Live\Contacts\wlcomm.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\SearchURL,(Default) = [You must be registered and logged in to see this link.]
O1 - Hosts: ::1 localhost
O1 - Hosts: 91.212.127.226 osguard-pro.microsoft.com
O1 - Hosts: 91.212.127.226 osguard-pro.com
O1 - Hosts: 91.212.127.226 [You must be registered and logged in to see this link.]
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: (no name) - {243B17DE-77C7-46BF-B94B-0B5F309A0E64} - C:\Program Files\Microsoft Money\System\mnyside.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - c:\PROGRA~1\mcafee\VIRUSS~1\scriptsn.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - c:\program files\google\googletoolbar2.dll (file missing)
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\4.1.509.6972\swg.dll
O2 - BHO: McAfee SiteAdvisor BHO - {B164E929-A1B6-4A06-B104-2CD0E90A88FF} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O3 - Toolbar: (no name) - {ACB1E670-3217-45C4-A021-6B829A8A27CB} - (no file)
O3 - Toolbar: (no name) - {BA52B914-B692-46c4-B683-905236F6F655} - (no file)
O3 - Toolbar: &Google - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - c:\program files\google\googletoolbar2.dll (file missing)
O3 - Toolbar: McAfee SiteAdvisor Toolbar - {0EBBBE48-BAD4-4B4C-8E5A-516ABECAE064} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O4 - HKLM\..\Run: [Microsoft Works Update Detection] C:\Program Files\Common Files\Microsoft Shared\Works Shared\WkUFind.exe
O4 - HKLM\..\Run: [Uninstall0001] "C:\Program Files\Common Files\Totem Shared\Uninstall0001\upd.exe" LASTCALL!adverts.virtuagirl.com!StatsVirtuaGirl
O4 - HKLM\..\Run: [ATIPTA] C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
O4 - HKLM\..\Run: [itype] "C:\Program Files\Microsoft IntelliType Pro\itype.exe"
O4 - HKLM\..\Run: [IntelliPoint] "C:\Program Files\Microsoft IntelliPoint\ipoint.exe"
O4 - HKLM\..\Run: [Cviwemilekihibaz] rundll32.exe "C:\WINDOWS\ixajuciv.dll",Startup
O4 - HKLM\..\Run: [calc] rundll32.exe C:\WINDOWS\system32\calc.dll,_IWMPEvents@0
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\Windows Live\Messenger\MsnMsgr.Exe" /background
O4 - HKCU\..\Run: [ares] "C:\Program Files\Ares\Ares.exe" -h
O4 - HKCU\..\Run: [updateMgr] "C:\Program Files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe" AcRdB7_0_9 -reboot 1
O4 - HKCU\..\Run: [calc] rundll32.exe C:\DOCUME~1\Admin\ntuser.dll,_IWMPEvents@0
O4 - Startup: scandisk.dll
O4 - Startup: scandisk.lnk = ?
O4 - Global Startup: Adobe Gamma Loader.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
O8 - Extra context menu item: &Search - [You must be registered and logged in to see this link.]
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~4\Office12\REFIEBAR.DLL
O9 - Extra button: MoneySide - {E023F504-0C5A-4750-A1E7-A9046DEA8A21} - C:\Program Files\Microsoft Money\System\mnyside.dll
O16 - DPF: {00B71CFB-6864-4346-A978-C0A14556272C} (Checkers Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {0CCA191D-13A6-4E29-B746-314DEE697D83} (Facebook Photo Uploader 5) - [You must be registered and logged in to see this link.]
O16 - DPF: {3B02AAA2-327C-40ED-A849-4BE819AE5385} (ImgSizer Control) - [You must be registered and logged in to see this link.] and Settings\Admin\Local Settings\Temp\~DlfnTmp0\imgSizer.ocx
O16 - DPF: {4ED9DDF0-7479-4BBE-9335-5A1EDB1D8A21} - [You must be registered and logged in to see this link.]
O16 - DPF: {5F8469B4-B055-49DD-83F7-62B522420ECC} (Facebook Photo Uploader Control) - [You must be registered and logged in to see this link.]
O16 - DPF: {86EEF11E-FF16-48CE-B1A2-474B663041A9} - [You must be registered and logged in to see this link.]
O16 - DPF: {8E0D4DE5-3180-4024-A327-4DFAD1796A8D} (MessengerStatsClient Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {91433D86-9F27-402C-B5E3-DEBDD122C339} - [You must be registered and logged in to see this link.]
O16 - DPF: {B38870E4-7ECB-40DA-8C6A-595F0A5519FF} (MsnMessengerSetupDownloadControl Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {B8BE5E93-A60C-4D26-A2DC-220313175592} (ZoneIntro Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {BCC0FF27-31D9-4614-A68E-C18E1ADA4389} - [You must be registered and logged in to see this link.]
O16 - DPF: {E5D419D6-A846-4514-9FAD-97E826C84822} (HeartbeatCtl Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {FF0C042C-98E9-4C36-B2EC-E21FDFDCEF75} - [You must be registered and logged in to see this link.]
O17 - HKLM\System\CCS\Services\Tcpip\..\{344815CC-6D53-49EE-9C15-A260C48F4BA2}: NameServer = 192.168.2.1
O18 - Protocol: dssrequest - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O18 - Protocol: sacore - {5513F07E-936B-4E52-9B00-067394E91CC5} - c:\PROGRA~1\mcafee\SITEAD~1\mcieplg.dll
O23 - Service: Adobe LM Service - Unknown owner - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: ATI Smart - Unknown owner - C:\WINDOWS\system32\ati2sgag.exe
O23 - Service: C-DillaCdaC11BA - Macrovision - C:\WINDOWS\system32\drivers\CDAC11BA.EXE
O23 - Service: Google Updater Service (gusvc) - Google - C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: lxce_device - Lexmark International, Inc. - C:\WINDOWS\system32\lxcecoms.exe
O23 - Service: McAfee SiteAdvisor Service - McAfee, Inc. - C:\Program Files\McAfee\SiteAdvisor\McSACore.exe
O23 - Service: McAfee Network Agent (McNASvc) - McAfee, Inc. - c:\program files\common files\mcafee\mna\mcnasvc.exe
End of file - 11596 bytes
CraigK
Posts Posts : 4
Post by Belahzur on Mon Oct 26, 2009 6:18 pm
Post by CraigK on Mon Oct 26, 2009 9:51 pm
Ok so I did another scan and here are the results... I ended up deleting some of the processes the other day and I havent had any Adware pop ups today while being online so I thnk thats a good sign..
This time it prompted me to restart but said everything could be deleted!!
Database version: 3037
10/26/2009 5:48:08 PM
mbam-log-2009-10-26 (17-48-08).txt
Objects scanned: 144038
Time elapsed: 24 minute(s), 30 second(s)
Registry Values Infected: 2
Files Infected: 3
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\calc (Trojan.Downloader) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\calc (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Documents and Settings\Admin\Start Menu\Programs\Startup\scandisk.lnk (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\Documents and Settings\Ian Kelly\Start Menu\Programs\Startup\scandisk.lnk (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\Documents and Settings\Ian Kelly\Local Settings\Temp\nsrbgxod.bak (Trojan.Agent) -> Quarantined and deleted successfully.
CraigK
Posts Posts : 4
Post by Belahzur on Tue Oct 27, 2009 12:06 am
