Antivirus system pro
Post by ballzy4 on 24th October 2009, 4:14 pm
having some trouble with this virus. i've followed all the instructions, tried trendmicro house call, and a few other suggestions. the problem is when i download any of these files, i get an error message saying "application cannot be executed. the file "xxxxx.xxx" is infected. do you want to activate your antivirus software now?" i'm in need of a little assistance with this one!
ballzy4
Posts Posts : 6
Joined Joined : 2009-10-24
Points Points : 26058
Re: Antivirus system pro
Post by Belahzur on 24th October 2009, 7:41 pm
Points Points : 245121
Post by ballzy4 on 24th October 2009, 7:53 pm
exeHelper by Raktor
exeHelper by Raktor
Build 20091021
Run at 15:50:24 on 10/24/09
Now searching...
Checking for bad processes...
Killed process winupdate.exe
Checking for bad files...
Deleting file C:\WINDOWS\system32\AVR09.exe
Deleting file C:\WINDOWS\system32\~.exe
Deleting file C:\WINDOWS\system32\winupdate.exe
Deleting file C:\WINDOWS\system32\winhelper.dll
Deleting file C:\WINDOWS\system32\critical_warning.html
Removing HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\winupdate.exe
Removing HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\system tool
Removing HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\system tool
Resetting policies...
--Finished--
ballzy4
Posts Posts : 6
Post by Belahzur on 24th October 2009, 8:01 pm
Post by ballzy4 on 24th October 2009, 8:08 pm
it gives me an error message, that the program is not compatible with my OS
ballzy4
Posts Posts : 6
Post by Belahzur on 24th October 2009, 8:46 pm
Post by ballzy4 on 24th October 2009, 8:55 pm
Scan saved at 4:52:50 PM, on 24/10/2009
C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
C:\Program Files\Alwil Software\Avast4\ashServ.exe
C:\WINDOWS\ehome\ehtray.exe
C:\WINDOWS\RTHDCPL.EXE
C:\Program Files\DISC\DISCover.exe
C:\Program Files\DISC\DiscUpdMgr.exe
C:\Program Files\HP DigitalMedia Archive\DMAScheduler.exe
C:\Program Files\Microsoft IntelliType Pro\itype.exe
C:\Program Files\Microsoft IntelliPoint\ipoint.exe
C:\HP\KBD\KBD.EXE
C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
C:\Program Files\MSN Messenger\msnmsgr.exe
C:\Program Files\irenjm\tgxwsysguard.exe
C:\WINDOWS\ehome\RMSysTry.exe
C:\WINDOWS\arservice.exe
C:\WINDOWS\eHome\ehRecvr.exe
C:\WINDOWS\eHome\ehSched.exe
C:\WINDOWS\ehome\RMSvc.exe
c:\Program Files\HP\Digital Imaging\bin\hpqSTE08.exe
C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
C:\WINDOWS\eHome\ehmsas.exe
C:\WINDOWS\system32\dllhost.exe
C:\Program Files\DISC\DiscStreamHub.exe
c:\windows\system\hpsysdrv.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = [You must be registered and logged in to see this link.]
O1 - Hosts: ::1 localhost
O1 - Hosts: 91.212.127.226 osguard-pro.microsoft.com
O1 - Hosts: 91.212.127.226 osguard-pro.com
O1 - Hosts: 91.212.127.226 [You must be registered and logged in to see this link.]
O2 - BHO: RealPlayer Download and Record Plugin for Internet Explorer - {3049C3E9-B461-4BC5-8870-4C09146192CA} - c:\program files\real\realplayer\rpbrowserrecordplugin.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.3.4501.1418\swg.dll
O4 - HKLM\..\Run: [ehTray] C:\WINDOWS\ehome\ehtray.exe
O4 - HKLM\..\Run: [AlwaysReady Power Message APP] ARPWRMSG.EXE
O4 - HKLM\..\Run: [HPHUPD08] c:\Program Files\HP\Digital Imaging\{33D6CC28-9F75-4d1b-A11D-98895B3A3729}\hphupd08.exe
O4 - HKLM\..\Run: [DISCover] C:\Program Files\DISC\DISCover.exe
O4 - HKLM\..\Run: [DiscUpdateManager] C:\Program Files\DISC\DiscUpdMgr.exe
O4 - HKLM\..\Run: [DMAScheduler] "c:\Program Files\HP DigitalMedia Archive\DMAScheduler.exe"
O4 - HKLM\..\Run: [Recguard] C:\WINDOWS\SMINST\RECGUARD.EXE
O4 - HKLM\..\Run: [HPBootOp] "C:\Program Files\Hewlett-Packard\HP Boot Optimizer\HPBootOp.exe" /run
O4 - HKLM\..\Run: [itype] "C:\Program Files\Microsoft IntelliType Pro\itype.exe"
O4 - HKLM\..\Run: [IntelliPoint] "C:\Program Files\Microsoft IntelliPoint\ipoint.exe"
O4 - HKLM\..\Run: [KBD] C:\HP\KBD\KBD.EXE
O4 - HKLM\..\Run: [RoxWatchTray] "C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatchTray9.exe"
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [avast!] C:\PROGRA~1\ALWILS~1\Avast4\ashDisp.exe
O4 - HKLM\..\Run: [Wrasolovol] rundll32.exe "C:\WINDOWS\ebefovavoxosok.dll",Startup
O4 - HKCU\..\Run: [MsnMsgr] "C:\Program Files\MSN Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [AdobeUpdater] C:\Program Files\Common Files\Adobe\Updater5\AdobeUpdater.exe
O4 - S-1-5-18 Startup: Pin.lnk = C:\hp\bin\CLOAKER.EXE (User 'SYSTEM')
O4 - .DEFAULT Startup: Pin.lnk = C:\hp\bin\CLOAKER.EXE (User 'Default user')
O4 - .DEFAULT User Startup: Pin.lnk = C:\hp\bin\CLOAKER.EXE (User 'Default user')
O4 - Global Startup: Extender Resource Monitor.lnk = C:\WINDOWS\ehome\RMSysTry.exe
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office10\OSA.EXE
O9 - Extra button: Internet Connection Help - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\PCHEALTH\HELPCTR\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm
O9 - Extra 'Tools' menuitem: Internet Connection Help - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\PCHEALTH\HELPCTR\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm
O16 - DPF: {7063B95A-70DB-4BAC-AF83-2E07A14B5D90} (RootDevice Class) - [You must be registered and logged in to see this link.]
O16 - DPF: {F04A8AE2-A59D-11D2-8792-00C04F8EF29D} (Hotmail Attachments Control) - [You must be registered and logged in to see this link.]
O18 - Filter hijack: text/html - (no CLSID) - (no file)
O23 - Service: avast! iAVS4 Control Service (aswUpdSv) - ALWIL Software - C:\Program Files\Alwil Software\Avast4\aswUpdSv.exe
O23 - Service: avast! Antivirus - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashServ.exe
O23 - Service: avast! Mail Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashMaiSv.exe
O23 - Service: avast! Web Scanner - ALWIL Software - C:\Program Files\Alwil Software\Avast4\ashWebSv.exe
O23 - Service: Google Update Service (gupdate1ca2e3dd5feccae) (gupdate1ca2e3dd5feccae) - Google Inc. - C:\Program Files\Google\Update\GoogleUpdate.exe
O23 - Service: Roxio UPnP Renderer 9 - Sonic Solutions - C:\Program Files\Roxio\Digital Home 9\RoxioUPnPRenderer9.exe
O23 - Service: Roxio Upnp Server 9 - Sonic Solutions - C:\Program Files\Roxio\Digital Home 9\RoxioUpnpService9.exe
O23 - Service: LiveShare P2P Server 9 (RoxLiveShare9) - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxLiveShare9.exe
O23 - Service: RoxMediaDB9 - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxMediaDB9.exe
O23 - Service: Roxio Hard Drive Watcher 9 (RoxWatch9) - Sonic Solutions - C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatch9.exe
O23 - Service: Symantec Core LC - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
End of file - 11374 bytes
ballzy4
Posts Posts : 6
Post by Belahzur on 24th October 2009, 9:10 pm
  • Open HijackThis.
Post by ballzy4 on 24th October 2009, 9:27 pm
Database version: 2775
24/10/2009 5:21:30 PM
mbam-log-2009-10-24 (17-21-30).txt
Objects scanned: 111841
Time elapsed: 4 minute(s), 44 second(s)
Registry Keys Infected: 1
Registry Values Infected: 1
Registry Data Items Infected: 5
Folders Infected: 3
Files Infected: 9
HKEY_CURRENT_USER\SOFTWARE\ErrorSmart (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\Desktop\General\wallpaper (Hijack.Wallpaper) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\LSA\Notification Packages (Trojan.Vundo.H) -> Data: fc7130.dll -> Delete on reboot.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\ActiveDesktop\NoChangingWallpaper (Hijack.DisplayProperties) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\activedesktop\NoChangingWallpaper (Hijack.DisplayProperties) -> Bad: (1) Good: (0) -> Quarantined and deleted successfully.
C:\Documents and Settings\HP_Administrator\Application Data\ErrorSmart (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Documents and Settings\HP_Administrator\Application Data\ErrorSmart\Log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Documents and Settings\HP_Administrator\Application Data\ErrorSmart\Registry Backups (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\WINDOWS\FC7130.dll (Trojan.Vundo.H) -> Delete on reboot.
C:\Documents and Settings\HP_Administrator\Application Data\ErrorSmart\Log\2008 Jun 10 - 09_28_29 PM_578.log (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\Documents and Settings\HP_Administrator\Application Data\ErrorSmart\Registry Backups\2008-06-10_21-29-11.reg (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\WINDOWS\Fonts\acrsecB.fon (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\Fonts\acrsecI.fon (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\syssvc.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\WINDOWS\Tasks\ErrorSmart Scheduled Scan.job (Rogue.ErrorSmart) -> Quarantined and deleted successfully.
C:\WINDOWS\smdat32a.sys (Rootkit.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\smdat32m.sys (Rootkit.Agent) -> Quarantined and deleted successfully.
ballzy4
Posts Posts : 6
Post by Belahzur on 24th October 2009, 10:36 pm
Please re-open Malwarebytes, click the Update tab, and click Check for Updates. Then, click the Scanner tab, select Perform Quick Scan, and press Scan.
Post by ballzy4 on 24th October 2009, 11:26 pm
Database version: 3027
24/10/2009 7:06:04 PM
mbam-log-2009-10-24 (19-06-04).txt
Objects scanned: 117691
Time elapsed: 5 minute(s), 45 second(s)
Memory Modules Infected: 1
Files Infected: 5
C:\WINDOWS\system32\lsp.dll (Search.Hijacker) -> Delete on reboot.
C:\ldvx.exe (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\wbem\proquota.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Documents and Settings\HP_Administrator\Local Settings\Temp\~TM5E0.tmp (Trojan.Agent) -> Quarantined and deleted successfully.
C:\Documents and Settings\HP_Administrator\Local Settings\Temp\~.exe (Trojan.Agent) -> Quarantined and deleted successfully.
ballzy4
Posts Posts : 6
