Antivirus System Pro and antivirus 2009 major issues
Post by cpagator on Sat Oct 24, 2009 3:38 am
I seem to have both of these, but i think they are the same virus. THey have now disabled my ability to get to the internet, so I can not download new software. It has also disabled my ability to start in an safe mode. Lastly, I had already installed Malwarebytes' antimalware and it will not allow me to access this file. What can I do? Please help.
cpagator
Posts Posts : 3
Joined Joined : 2009-10-24
Points Points : 25995
Re: Antivirus System Pro and antivirus 2009 major issues
Post by Belahzur on Sat Oct 24, 2009 3:50 pm
Points Points : 245059
Post by cpagator on Sat Oct 24, 2009 4:50 pm
The issue I am having before even doing this is that the virus is not allowing me to get to the internet on taht computer. I am posting to this site with my other computer. I also tried saving the program to a disc and running it that way, and again, the virus will not allow it to be read.
How can I proceed?
cpagator
Posts Posts : 3
Post by Belahzur on Sat Oct 24, 2009 7:44 pm
Lets try this program instead.
Post by cpagator on Sat Oct 24, 2009 8:24 pm
Again, I greatly appreciate your help, but the virus will not allow me to launch internet explorer or firefox to be able to get to any of these programs. Is there a way to get to the internet to download these programs without going through IE or firefox?
cpagator
Posts Posts : 3
Post by Belahzur on Sat Oct 24, 2009 8:47 pm
Can you download them on another machine and transfer them via USB?
