No sound
Solved No sound
Post by FaithCassita on Sat Oct 24, 2009 1:54 am
Hi, please help. I had to restore my pc, had to reinstall windows and now my system is not playing any sound whatsoever. Can you help me figure out what kind of audio driver I have and how to fix it?
FaithCassita
OS : Windows XP
Solved Re: No sound
Post by Dr Jay on Sat Oct 24, 2009 2:35 am
Please download the latest version of Kaspersky GetSystemInfo (GSI) from Kaspersky and save it to your Desktop.
Click the Settings button.
Set it to Maximum
It will create a zip folder called GetSystemInfo_XXXXXXXXXXXXXX.zip on your Desktop. Please upload the folder to Kaspersky GSI Parser and click the Submit button.
OS : Windows 10 Home & Pro
Solved Re: No sound
Post by FaithCassita on Sat Oct 24, 2009 2:49 am
Here's the url
http://www.getsysteminfo.com/read.php?file=88639d8291a276d8e2b4e96c063c87b6
Thanks for the help. I need to have sound on my comp!
Hopefully you can help me fix it.
FaithCassita
OS : Windows XP
Solved Re: No sound
Post by Dr Jay on Sat Oct 24, 2009 5:25 am
Do you have a drivers disk for Dell? I am guessing that is your system.
If not, you can find drivers on their website. support.dell.com
Solved Re: No sound
Post by FaithCassita on Sat Oct 24, 2009 1:21 pm
yeah it's a dell, but it's refurbished. I'll look around at that site though and see what I find. Thanks.
FaithCassita
OS : Windows XP
Solved Re: No sound
Post by FaithCassita on Sat Oct 24, 2009 1:34 pm
AHH, you're amazing! It was too simple. Before I posted here I looked everywhere to find out what kind of driver download I needed. I never thought :Well my computer is a Dell, let's see what the Dell Website has to offer". Thank you DragonMaster!! It worked!
FaithCassita
OS : Windows XP
Solved Re: No sound
Post by Dr Jay on Sat Oct 24, 2009 8:57 pm
Good!
Solved Re: No sound
Post by cincymom513 on Mon Jan 18, 2010 10:21 pm
I have the same problem and tried your suggestion, but when I click on the settings button, it won't let me change them. It says I don't have administrator rights to edit settings. I'm under administrator on my computer.
cincymom513
OS : Windows Vista
Solved Re: No sound
Post by cincymom513 on Mon Jan 18, 2010 10:31 pm
I went ahead and followed your procedure, though. Here is the URL
http://www.getsysteminfo.com/read.php?file=d62fa8999c0d92acf89b88a02e7f2f1f
Can you help?
cincymom513
OS : Windows Vista
