alpha antivirus removal problem
Post by richard rice on Sat 24 Oct 2009, 5:58 am
im having a problem with alpha antivirus on my system and cant remove it from my system. not sure how it got there but it's a virus in it's self.every time i go to and and remove program it asks me to buy the program b 4 i can remove it, please someone help
richard rice
Operating System : vista home primium
Re: alpha antivirus removal problem
Post by DragonMaster Jay on Sat 24 Oct 2009, 6:26 am
Please download ComboFix from
GeekPolice Academy Manager
DragonMaster Jay
Manager | Tech Officer
