Antivirus System Pro
Post by JPswanson on Sat 24 Oct 2009, 3:56 am
I have read through all the threads here, and have tried that Combofix.exe and other various methods. But this program is blocking everything from running, task master, Combofix, malwarebytes, spybot, AVG. I need help and quickly... Thank you
Operating System : XP
Re: Antivirus System Pro
Post by DragonMaster Jay on Sat 24 Oct 2009, 12:02 pm
Please run Trend Micro Housecall online scan.
  • Click Scan now.
  • Read and put a Check next to Yes I accept the terms of use.
  • Click the Launching HouseCall>> button.
  • If confirmed that HouseCall can run on your system, under Using Java-based HouseCall kernel click the Starting HouseCall>> button.
  • You may receive a Security Warning about the TrendMicro Java applet, click YES.
  • Under Scan complete computer for malware, grayware, and vulnerabilities click the Next>> button.
  • Please be patient while it installs, updates, and scans your system.
  • Once the scan is complete, it will take you to the summary page.
  • Under Cleanup options, choose clean all detected infections automatically.
  • Click the Clean now>> button.
  • If anything was found you may be prompted to run the scan again, you can just close the browser window.
GeekPolice Academy Manager
DragonMaster Jay
Manager | Tech Officer
