Win32/nuqel.E / bankerfox.a / Antivirus system pro. problem
Post by jcs829 on 23rd October 2009, 3:23 pm
I have a laptop that is running on vista and 2 days ago, I downloaded a file which I presume was the one that infected my laptop. Ever since I get the pop-ups from antivirus system pro, and it wont let me run almost anything because it says "it's infected" . As well as getting warnings and threats from bankerfox.a and win32/nuqel.e
I read on this forums and tried downloading the "malwarebytes' anti-malware" software but then again after several tries it won't let me run it because it says the file is "infected".
I've read on and then the next step (i think) is to either download the hijack this, or the combofix software and post the log in here. So unless told otherwise my next post my combofix log as soon as I get to my laptop.
Thanks in advance for your help!
jcs829
Posts Posts : 20
Joined Joined : 2009-10-23
OS OS : vista
Points Points : 26114
Re: Win32/nuqel.E / bankerfox.a / Antivirus system pro. problem
Post by Dr Jay on 23rd October 2009, 7:21 pm
  • Click Scan now.
  • Read and put a Check next to Yes I accept the terms of use.
  • Click the Launching HouseCall>> button.
  • If confirmed that HouseCall can run on your system, under Using Java-based HouseCall kernel click the Starting HouseCall>> button.
  • You may receive a Security Warning about the TrendMicro Java applet, click YES.
  • Under Scan complete computer for malware, grayware, and vulnerabilities click the Next>> button.
  • Please be patient while it installs, updates, and scans your system.
  • Once the scan is complete, it will take you to the summary page.
  • Under Cleanup options, choose clean all detected infections automatically.
  • Click the Clean now>> button.
  • If anything was found you may be prompted to run the scan again, you can just close the browser window.
Posts Posts : 13743
Points Points : 302211
Post by jcs829 on 23rd October 2009, 7:50 pm
I got to the Trend micro webpage and I got to launch Housecall, and it started housecall and supposedly started scanning.
So when scanning it shows 3 steps that it has to go through
1) Preparing to scan the computer
2) scanning local computer
3)listing and removing detected malware
the problem is that on step2 a pop-up window shows up that says
"Message from the webpage
An error ocurred while trying to transfer data from the internet! Do you want Tren Micro Housecall to try resending the required files?
OK Cancel"
I keep pressing OK but the window keeps popping up after like 10 seconds. So waht now? DO i keep pressing ok? or something is wrong?
thanks in advance
jcs829
Posts Posts : 20
OS OS : vista
Post by Dr Jay on 23rd October 2009, 7:59 pm
Please do a scan with [You must be registered and logged in to see this link.]
Click on the Accept button and install any components it needs.
  • The program will install and then begin downloading the latest definition files.
  • After the files have been downloaded on the left side of the page in the Scan section select My Computer.
  • This will start the program and scan your system.
  • The scan will take a while, so be patient and let it run.
  • Once the scan is complete, click on View scan report
  • Now, click on the Save Report as button.
  • Save the file to your desktop.
  • Copy and paste that information in your next post.
Posts Posts : 13743
Post by jcs829 on 23rd October 2009, 8:39 pm
Something weird happened, once I told the Trend micro Housecall program to stay idle, the pop-ups telling me that my computer was threathened by Win32/nuqel.e and bankerfox.a stopped appearing as well as the internet explorer windows telling me to buy the antivirus system pro.
I'm still running the Kaspersky online scanner and I'm going to still post the report when its done, though just to make sure.
jcs829
Posts Posts : 20
OS OS : vista
Post by Dr Jay on 24th October 2009, 12:19 am
Ok Post when Ready
Posts Posts : 13743
Post by jcs829 on 24th October 2009, 1:39 am
hi,
I tried several times running the kaspersky scan but it would either get stuck or my laptop would crash. It never got pass 40%completion, like I said the pop-ups of the antivirus system pro are gone, but the laptop is still slow and I still can't run the Malwarebytes anti-malware. What should I do?
thanks
jcs829
Posts Posts : 20
OS OS : vista
Post by Dr Jay on 24th October 2009, 2:20 am
Try this:
Please use Internet Explorer and run a [You must be registered and logged in to see this link.]
  • Please check I agree with the Terms and Conditions and click Start Here
  • You will need to allow an Active X install for the scan to run.
  • Leave the scanning options at default and click Start Scan
Please post the results in your next reply.
Posts Posts : 13743
Post by jcs829 on 24th October 2009, 3:31 am
hi,
When i try to run the bitdefender a windows shows up telling me that Internet explorer is not running with administrative privileges so bitdefender wont work properly, and if I tell it to go on anyways the scan fails.
jcs829
Posts Posts : 20
OS OS : vista
Post by Dr Jay on 24th October 2009, 5:29 am
Right-click on Internet Explorer icon and click Run as Administrator, then try again, please.
Posts Posts : 13743
Post by jcs829 on 24th October 2009, 7:28 pm
BitDefender Online Scanner
Scan report generated at: Sat, Oct 24, 2009 - 14:20:57
Scan path: C:\;D:\;
Statistics
Time
02:59:27
Files
362338
Folders
26624
Boot Sectors
0
Archives
5036
Packed Files
19105
Results
Identified Viruses
22
Infected Files
138
Suspect Files
1
Warnings
0
Disinfected
0
Deleted Files
238
Engines Info
Virus Definitions
4452409
Engine build
AVCORE v2.1 Windows/i386 11.0.0.26 (Aug 27 2009)
Scan plugins
17
Archive plugins
44
Unpack plugins
8
E-mail plugins
6
System plugins
4
Scan Settings
First Action
Disinfect
Second Action
Delete
Heuristics
Yes
Enable Warnings
Yes
Scanned Extensions
Exclude Extensions
Scan Emails
Yes
Scan Archives
Yes
Scan Packed
Yes
Scan Files
Yes
Scan Boot
Yes
Scanned File
Status
C:\ProgramData\safevayi\safevayi.dll
Infected with: Trojan.Generic.2591710
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0D4C0000\4FCCCA35.VBN=>(Quarantine-PE)
Infected with: Trojan.Dropper.Peerad.A
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0D900000\4FDDEB55.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0DA40000.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0E980000.VBN=>(Quarantine-PE)
Infected with: Trojan.Generic.1745884
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300000\4FF18DAA.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0000
Detected with: Adware.XpAntivirus.AJ
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300000\4FF18DAA.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0005
Infected with: Trojan.FakeAV.AM
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300000\4FF18DAA.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0008
Infected with: Trojan.Generic.764000
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300000\4FF18DAA.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0014
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300000\4FF18DAA.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0019=>(NSIS g)=>lzma_solid_nsis0000
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E1A.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0000
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E1A.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0005
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E1A.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0008
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E1A.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0014
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E1A.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0019=>(NSIS g)=>lzma_solid_nsis0000
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E1D.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0000
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E1D.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0005
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E1D.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0008
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E1D.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0014
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E1D.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0019=>(NSIS g)=>lzma_solid_nsis0000
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E20.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0000
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E20.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0005
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E20.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0008
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E20.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0014
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E20.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0019=>(NSIS g)=>lzma_solid_nsis0000
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E24.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0000
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E24.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0005
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E24.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0008
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E24.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0014
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E24.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0019=>(NSIS g)=>lzma_solid_nsis0000
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E27.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0000
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E27.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0005
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E27.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0008
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E27.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0014
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E27.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0019=>(NSIS g)=>lzma_solid_nsis0000
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E2A.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0000
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E2A.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0005
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E2A.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0008
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E2A.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0014
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F300001\4FF18E2A.VBN=>(Quarantine-PE)=>(NSIS o)=>lzma_solid_nsis0019=>(NSIS g)=>lzma_solid_nsis0000
Deleted
Update failed
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F440008\4FC5903A.VBN=>(Quarantine-PE)
Infected with: Trojan.Peed.JRX
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F440009\4FC59055.VBN=>(Quarantine-PE)
Infected with: Trojan.Peed.JSB
Disinfection failed
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F500000.VBN=>(Quarantine-PE)
Infected with: Gen:Trojan.Heur.VB.mm0@daWRGCoi
Disinfection failed
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F540000.VBN=>(Quarantine-PE)
Infected with: Trojan.FakeAlert.ACU
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0F840002.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0FA00000.VBN=>(Quarantine-PE)
Infected with: Trojan.Generic.2525630
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0FA00001.VBN=>(Quarantine-PE)
Infected with: Trojan.Generic.IS.612488
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0FA00002.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0FA00004.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0FD00000.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0FD00001.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0FD00002.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0FD00003.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0FD00004.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0FD00005.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0FD00006.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0FE00000.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\0FE40000.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\10100000.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\10100001.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\10100002.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\10100003.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\11940000.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\11940001.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\11B00000.VBN=>(Quarantine-PE)
Infected with: Gen:Trojan.Heur.bu8@ySVBDZic
Disinfection failed
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\11B00001.VBN=>(Quarantine-PE)
Disinfection failed
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\11B00002.VBN=>(Quarantine-PE)
Infected with: Worm.Generic.95233
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\12140000.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\12140001.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\12140002.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\12140003.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0000.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0001.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0002.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0003.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0004.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0005.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0006.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0007.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0008.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0009.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C000A.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C000B.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C000C.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C000D.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C000E.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C000F.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0010.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0011.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0012.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0013.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0014.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0015.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0016.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0017.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0018.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0019.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C001A.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C001B.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C001C.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C001D.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C001E.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C001F.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0020.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0021.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0022.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0023.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\121C0024.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\13E40000.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\13E40001.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\13E40002.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\13E40003.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\14840000.VBN=>(Quarantine-PE)
Infected with: Trojan.Generic.1370981
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\14B40000.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\14B40001.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\14B40002.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\158C0000.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\158C0001.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\15940000.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\17A40000.VBN=>(Quarantine-PE)
Infected with: Backdoor.Generic.220839
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\17AC0000.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\17AC0001.VBN=>(Quarantine-PE)
Disinfection failed
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\17AC0002.VBN=>(Quarantine-PE)
Infected with: Gen:Trojan.Heur.bu1@zGoSS1pi
Disinfection failed
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\17AC0003.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\17AC0004.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\17AC0005.VBN=>(Quarantine-PE)
Detected with: Application.Generic.248984
Disinfection failed
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\17AC0006.VBN=>(Quarantine-PE)
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\17B80000.VBN=>(Quarantine-PE)
Detected with: Application.Tool.3394
Disinfection failed
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\1E400000\5EE25721.VBN=>(Quarantine-PE)
Disinfection failed
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\1E400000\5EE259F2.VBN=>(Quarantine-PE)
Disinfection failed
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\1E400000\5EE259F3.VBN=>(Quarantine-PE)
Disinfection failed
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\1E400001\5EE25AF7.VBN=>(Quarantine-PE)
Disinfection failed
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\1E400002\5EE25E16.VBN=>(Quarantine-PE)
Disinfection failed
Deleted
Deleted
C:\ProgramData\Symantec\Symantec AntiVirus Corporate Edition\7.5\Quarantine\1E400002\5EE25F7E.VBN=>(Quarantine-PE)
Disinfection failed
Deleted
Deleted
C:\Users\Chris\AppData\Local\Temp\Acr9F0C.tmp=>(JAVASCRIPT)
Suspected of: Exploit.PDF-JS.Gen
Disinfection failed
Deleted
Update failed
C:\Users\Chris\AppData\Local\Temp\MPSampleSubmit\umspnsau.dll.xor=>(Quarantine-PE)
Infected with: Trojan.Generic.2590460
Deleted
Deleted
C:\Users\Chris\AppData\Local\Temp\uacf2f6.tmp
Infected with: Gen:Trojan.Heur.wvW@vj8oOPdkx
Disinfection failed
Deleted
C:\Users\Chris\AppData\Local\Temp\wscsvc32.exe
Infected with: Gen:Trojan.Heur.1u0@vDtMG!jkx
Disinfection failed
Deleted
C:\Windows\Temp\TMP0000007A69BCAC340E084202
Deleted
jcs829
Posts Posts : 20
OS OS : vista
Post by Dr Jay on 24th October 2009, 9:33 pm
Posts Posts : 13743
Post by jcs829 on 24th October 2009, 9:52 pm
Database version: 3027
Windows 6.0.6002 Service Pack 2
10/24/2009 4:17:10 PM
mbam-log-2009-10-24 (16-17-01).txt
Objects scanned: 102860
Time elapsed: 10 minute(s), 41 second(s)
Registry Keys Infected: 8
Registry Values Infected: 7
Files Infected: 24
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{a2234b15-23f2-42ad-f4e4-00aac39c0004} (Trojan.Ertfor) -> No action taken.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{b64f4a7c-97c9-11da-8bde-f66bad1e3f3a} (Rogue.WinAntiVirus) -> No action taken.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{1a26f07f-0d60-4835-91cf-1e1766a0ec56} (Trojan.Agent) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Active Security (Rogue.ActiveSecurity) -> No action taken.
HKEY_CURRENT_USER\SOFTWARE\CoreGuard (Rogue.CoreguardAV) -> No action taken.
HKEY_CURRENT_USER\SOFTWARE\NordBull (Malware.Trace) -> No action taken.
HKEY_CURRENT_USER\SOFTWARE\XML (Trojan.FakeAlert) -> No action taken.
HKEY_CURRENT_USER\SOFTWARE\poprock (Trojan.Downloader) -> No action taken.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\SharedTaskScheduler\{a2234b15-23f2-42ad-f4e4-00aac39c0004} (Trojan.Ertfor) -> No action taken.
HKEY_CURRENT_USER\Control Panel\Desktop\convertedwallpaper (Hijack.Wallpaper) -> No action taken.
HKEY_CURRENT_USER\Control Panel\Desktop\originalwallpaper (Hijack.Wallpaper) -> No action taken.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\idstrf (Malware.Trace) -> No action taken.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\WINID (Malware.Trace) -> No action taken.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\poprock (Trojan.Downloader) -> No action taken.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\Yjafosi8kdf98winmdkmnkmfnwe (Trojan.Agent) -> No action taken.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\NoFolderOptions (Hijack.FolderOptions) -> Bad: (1) Good: (0) -> No action taken.
C:\Windows\System32\bitanazo.dll (Trojan.Vundo) -> No action taken.
C:\Windows\System32\fadonovi.dll (Trojan.Vundo) -> No action taken.
C:\Windows\System32\gedekuye.dll (Trojan.Vundo) -> No action taken.
C:\Windows\System32\jokilake.dll (Trojan.Vundo) -> No action taken.
C:\Windows\System32\kezehide.dll (Trojan.Vundo) -> No action taken.
C:\Windows\System32\kusudewi.dll (Trojan.Vundo) -> No action taken.
C:\Windows\System32\madujeri.exe (Rogue.SecurityTool) -> No action taken.
C:\Windows\System32\melidawa.dll (Trojan.Vundo) -> No action taken.
C:\Windows\System32\nelonezi.dll (Trojan.Vundo) -> No action taken.
C:\Windows\System32\nudegoya.dll (Trojan.Vundo) -> No action taken.
C:\Windows\System32\rivesogo.dll (Trojan.Vundo) -> No action taken.
C:\Windows\System32\pewofesa.dll (Trojan.Vundo) -> No action taken.
C:\Windows\System32\vipuliji.dll (Trojan.Vundo) -> No action taken.
C:\Windows\System32\vohetufa.dll (Trojan.Vundo) -> No action taken.
C:\Windows\System32\wizunipo.dll (Trojan.Vundo) -> No action taken.
C:\Windows\System32\zisilore.dll (Trojan.Vundo) -> No action taken.
C:\Users\Chris\AppData\Local\Temp\uacbe01.tmp (Trojan.FakeAlert) -> No action taken.
C:\Users\Chris\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\scandisk.lnk (Trojan.Downloader) -> No action taken.
C:\Windows\System32\ruyutego.dll (Trojan.Vundo) -> No action taken.
C:\Users\Chris\AppData\Local\Temp\nsrbgxod.bak (Trojan.Agent) -> No action taken.
C:\Windows\Tasks\{7B02EF0B-A410-4938-8480-9BA26420A627}.job (Trojan.Downloader) -> No action taken.
C:\Windows\Tasks\{BB65B0FB-5712-401b-B616-E69AC55E2757}.job (Trojan.Downloader) -> No action taken.
C:\Users\Chris\AppData\Local\Temp\c.exe (Trojan.Downloader) -> No action taken.
C:\Users\Chris\AppData\Local\Temp\jisfije9fjoiee.tmp (Trojan.Downloader) -> No action taken.
jcs829
Posts Posts : 20
OS OS : vista
Post by Dr Jay on 24th October 2009, 9:56 pm
Hi
Please take action on those items by clicking Remove Selected.
Posts Posts : 13743
Post by jcs829 on 24th October 2009, 11:05 pm
I was able to install Combofix as commy.exe on my desktop. However when i did the start->Run "%userprofile%\desktop\commy.exe" /stepdel
It showed combofix being loaded but then once it finished loading I got several pop-up warnings saying
"C:\ProgramData\ladowozi.dll is either not designed to run on windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support."
and then i press ok but the same window pop-up again for several times until it stops poppin up but combofix never runs.
NVM I got combofix to run, i'll post the txt files in a moment
Last edited by jcs829 on 24th October 2009, 11:40 pm; edited 1 time in total (Reason for editing : got the program to run)
jcs829
Posts Posts : 20
OS OS : vista
Post by jcs829 on 24th October 2009, 11:52 pm
ComboFix 09-10-24.01 - Chris 10/24/2009 18:10.1.2 - NTFSx86
Microsoft® Windows Vista™ Home Premium 6.0.6002.2.1252.1.1033.18.2037.797 [GMT -5:00]
Running from: c:\users\Chris\Desktop\commy.exe
AV: Symantec AntiVirus *On-access scanning enabled* (Updated) {FB06448E-52B8-493A-90F3-E43226D3305C}
SP: Symantec AntiVirus *enabled* (Updated) {6C85A515-B91D-4D2B-AF18-40984A4A8493}
* Resident AV is active
c:\$recycle.bin\S-1-5-21-3325274441-2933238227-355094248-500
c:\$recycle.bin\S-1-5-21-3325274441-2933238227-355094248-500\desktop.ini
c:\programdata\ntuser.dat{e5811f88-c762-11db-a035-00a0d1df235d}.TMContainer00000000000000000001.regtrans-ms
c:\programdata\ntuser.dat{e5811f98-c762-11db-a035-00a0d1df235d}.TMContainer00000000000000000001.regtrans-ms
((((((((((((((((((((((((( Files Created from 2009-09-24 to 2009-10-24 )))))))))))))))))))))))))))))))
2009-10-24 23:23 . 2009-10-24 23:29 -------- d-----w- c:\users\Chris\AppData\Local\temp
2009-10-24 23:23 . 2009-10-24 23:23 -------- d-----w- c:\users\Default\AppData\Local\temp
2009-10-24 22:31 . 2009-10-24 22:33 -------- d-----w- C:\commy
2009-10-24 03:09 . 2009-10-24 19:21 -------- d-----w- c:\windows\BDOSCAN8
2009-10-24 01:18 . 2009-10-24 01:18 -------- d-----w- c:\programdata\WindowsSearch
2009-10-23 22:36 . 2009-10-23 22:36 -------- d-----w- c:\windows\Sun
2009-10-23 19:36 . 2009-09-16 15:22 214664 ----a-w- c:\windows\system32\drivers\mfehidk.sys
2009-10-23 05:06 . 2009-10-23 05:06 -------- d-----w- c:\program files\Windows Live Safety Center
2009-10-23 04:31 . 2009-10-23 04:31 -------- d-----w- c:\users\Chris\AppData\Roaming\Malwarebytes
2009-10-23 04:15 . 2009-09-10 19:54 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-10-23 04:15 . 2009-10-24 21:04 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-10-23 04:15 . 2009-10-23 04:15 -------- d-----w- c:\programdata\Malwarebytes
2009-10-23 04:15 . 2009-09-10 19:53 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-10-22 23:16 . 2009-10-22 23:16 -------- d-sh--w- c:\windows\system32\%APPDATA%
2009-10-22 03:58 . 2009-10-22 03:58 -------- d-----w- c:\windows\system32\config\systemprofile\Tracing
2009-10-22 01:27 . 2009-10-23 03:45 -------- d-----w- c:\programdata\puleluro
2009-10-22 01:27 . 2009-10-24 17:26 -------- d-----w- c:\programdata\safevayi
2009-10-22 01:27 . 2009-10-23 19:17 -------- d-----w- c:\programdata\simipari
2009-10-22 01:27 . 2009-10-23 03:45 -------- d-----w- c:\programdata\sufohuwe
2009-10-22 01:20 . 2009-10-24 04:32 -------- d-----w- c:\programdata\somotiye
2009-10-22 01:20 . 2009-10-24 02:58 -------- d-----w- c:\programdata\miriniwi
2009-10-22 01:20 . 2009-10-22 01:20 -------- d-----w- c:\programdata\ladowozi
2009-10-19 23:38 . 2009-08-07 02:24 44768 ----a-w- c:\windows\system32\wups2.dll
2009-10-19 23:37 . 2009-08-07 02:24 53472 ----a-w- c:\windows\system32\wuauclt.exe
2009-10-19 23:37 . 2009-08-07 02:23 1929952 ----a-w- c:\windows\system32\wuaueng.dll
2009-10-19 23:37 . 2009-08-07 01:45 2421760 ----a-w- c:\windows\system32\wucltux.dll
2009-10-19 23:36 . 2009-08-07 02:24 35552 ----a-w- c:\windows\system32\wups.dll
2009-10-19 23:36 . 2009-08-07 02:23 575704 ----a-w- c:\windows\system32\wuapi.dll
2009-10-19 23:36 . 2009-08-07 01:44 87552 ----a-w- c:\windows\system32\wudriver.dll
2009-10-19 23:35 . 2009-08-07 00:23 171608 ----a-w- c:\windows\system32\wuwebv.dll
2009-10-19 23:35 . 2009-08-06 23:44 33792 ----a-w- c:\windows\system32\wuapp.exe
2009-10-16 20:17 . 2009-08-04 12:34 3600456 ----a-w- c:\windows\system32\ntkrnlpa.exe
2009-10-16 20:17 . 2009-08-04 12:34 3548216 ----a-w- c:\windows\system32\ntoskrnl.exe
2009-10-16 20:17 . 2009-09-10 16:48 218624 ----a-w- c:\windows\system32\msv1_0.dll
2009-10-16 20:17 . 2009-08-27 05:22 916480 ----a-w- c:\windows\system32\wininet.dll
2009-10-16 20:15 . 2009-09-04 11:41 60928 ----a-w- c:\windows\system32\msasn1.dll
2009-10-16 20:15 . 2009-09-14 09:29 144896 ----a-w- c:\windows\system32\drivers\srv2.sys
2009-10-16 20:15 . 2009-05-08 12:53 604672 ----a-w- c:\windows\system32\WMSPDMOD.DLL
2009-10-04 16:15 . 2009-10-04 16:15 127872 ----a-w- c:\users\Chris\AppData\Roaming\Move Networks\uninstall.exe
2009-10-04 16:15 . 2009-10-04 16:15 -------- d-----w- c:\users\Chris\AppData\Roaming\Move Networks
2009-10-02 19:22 . 2009-10-01 15:29 195440 ------w- c:\windows\system32\MpSigStub.exe
2009-09-29 21:14 . 2009-09-29 21:14 -------- d-----w- c:\programdata\SiteAdvisor
2009-09-27 21:47 . 2006-03-03 13:07 143360 ----a-w- c:\windows\system32\dunzip32.dll
2009-10-23 19:35 . 2007-02-28 20:29 -------- d-----w- c:\program files\McAfee
2009-10-22 03:58 . 2009-07-15 02:08 -------- d-----w- c:\users\Chris\AppData\Roaming\uTorrent
2009-10-19 03:43 . 2009-07-27 03:05 -------- d-----w- c:\users\Chris\AppData\Roaming\Skype
2009-10-19 03:27 . 2009-07-27 03:12 -------- d-----w- c:\users\Chris\AppData\Roaming\skypePM
2009-10-17 06:12 . 2007-03-20 21:14 -------- d-----w- c:\programdata\Microsoft Help
2009-10-17 06:08 . 2007-03-20 21:09 -------- d-----w- c:\program files\Microsoft Works
2009-10-05 20:11 . 2007-02-28 20:29 -------- d-----w- c:\programdata\McAfee
2009-10-04 16:15 . 2009-06-16 06:35 4183416 ----a-w- c:\users\Chris\AppData\Roaming\Move Networks\plugins\npqmp071503000010.dll
2009-10-02 01:35 . 2009-06-24 01:52 -------- d-----w- c:\program files\Microsoft
2009-09-28 01:09 . 2007-02-28 20:29 -------- d-----w- c:\program files\Common Files\McAfee
2009-09-22 00:22 . 2006-11-02 12:37 -------- d-----w- c:\program files\Windows Calendar
2009-09-22 00:21 . 2006-11-02 11:18 -------- d-----w- c:\program files\Windows Mail
2009-09-22 00:21 . 2006-11-02 12:37 -------- d-----w- c:\program files\Windows Sidebar
2009-09-22 00:21 . 2006-11-02 12:37 -------- d-----w- c:\program files\Windows Collaboration
2009-09-22 00:21 . 2006-11-02 12:37 -------- d-----w- c:\program files\Windows Journal
2009-09-22 00:21 . 2006-11-02 12:37 -------- d-----w- c:\program files\Windows Photo Gallery
2009-09-22 00:21 . 2006-11-02 12:37 -------- d-----w- c:\program files\Windows Defender
2009-09-16 15:22 . 2007-02-28 20:29 40552 ----a-w- c:\windows\system32\drivers\mfesmfk.sys
2009-09-16 15:22 . 2007-02-28 20:29 35272 ----a-w- c:\windows\system32\drivers\mfebopk.sys
2009-09-16 15:22 . 2007-02-28 20:29 79816 ----a-w- c:\windows\system32\drivers\mfeavfk.sys
2009-09-16 15:22 . 2007-02-28 20:29 34248 ----a-w- c:\windows\system32\drivers\mferkdk.sys
2009-09-16 01:32 . 2009-09-16 01:32 -------- d-----w- c:\program files\MATLAB
2009-09-10 04:44 . 2009-06-25 04:20 -------- d-----w- c:\program files\Microsoft Silverlight
2009-08-27 05:17 . 2009-10-16 20:16 109056 ----a-w- c:\windows\system32\iesysprep.dll
2009-08-27 05:17 . 2009-10-16 20:16 71680 ----a-w- c:\windows\system32\iesetup.dll
2009-08-27 03:42 . 2009-10-16 20:16 133632 ----a-w- c:\windows\system32\ieUnatt.exe
2009-08-18 04:33 . 2009-08-18 04:33 1193832 ----a-w- c:\windows\system32\FM20.DLL
2009-08-14 16:27 . 2009-09-10 02:25 904776 ----a-w- c:\windows\system32\drivers\tcpip.sys
2009-08-14 15:53 . 2009-09-10 02:25 17920 ----a-w- c:\windows\system32\netevent.dll
2009-08-14 13:49 . 2009-09-10 02:25 9728 ----a-w- c:\windows\system32\TCPSVCS.EXE
2009-08-14 13:49 . 2009-09-10 02:25 11264 ----a-w- c:\windows\system32\MRINFO.EXE
2009-08-14 13:49 . 2009-09-10 02:25 17920 ----a-w- c:\windows\system32\ROUTE.EXE
2009-08-14 13:49 . 2009-09-10 02:25 27136 ----a-w- c:\windows\system32\NETSTAT.EXE
2009-08-14 13:49 . 2009-09-10 02:25 19968 ----a-w- c:\windows\system32\ARP.EXE
2009-08-14 13:49 . 2009-09-10 02:25 8704 ----a-w- c:\windows\system32\HOSTNAME.EXE
2009-08-14 13:49 . 2009-09-10 02:25 10240 ----a-w- c:\windows\system32\finger.exe
2009-08-14 13:48 . 2009-09-10 02:25 30720 ----a-w- c:\windows\system32\drivers\tcpipreg.sys
2009-08-14 13:48 . 2009-09-10 02:25 105984 ----a-w- c:\windows\system32\netiohlp.dll
2009-07-30 14:38 . 2009-08-16 01:25 5173960 ----a-w- c:\windows\BAA Screensaver.scr
2009-07-27 03:12 . 2009-07-27 03:12 56 ---ha-w- c:\programdata\ezsidmv.dat
2004-03-15 23:51 . 2004-03-15 23:51 114688 ----a-w- c:\program files\internet explorer\plugins\LV71ActiveXControl.dll
2006-01-23 16:32 . 2006-01-23 16:32 131072 ----a-w- c:\program files\internet explorer\plugins\LV80ActiveXControl.dll
2007-02-08 16:48 . 2007-02-08 16:48 133920 ----a-w- c:\program files\internet explorer\plugins\LV82ActiveXControl.dll
2007-07-25 01:03 . 2007-07-25 01:03 118784 ----a-w- c:\program files\internet explorer\plugins\LV85ActiveXControl.dll
2009-07-23 19:18 . 2009-07-23 19:18 16384 --sha-w- c:\windows\System32\buhedina.exe
2009-07-22 23:10 . 2009-07-22 23:10 16384 --sha-w- c:\windows\System32\davozido.exe
2009-07-24 00:19 . 2009-07-24 00:19 69632 --sha-w- c:\windows\System32\vukolosu.exe
2009-07-23 20:18 . 2009-07-23 20:18 75776 --sha-w- c:\windows\System32\wimoroka.exe
2009-07-23 23:18 . 2009-07-23 23:18 81920 --sha-w- c:\windows\System32\wogutopa.exe
2009-07-23 20:18 . 2009-07-23 20:18 32768 --sha-w- c:\windows\System32\zarajubo.dll
"MsnMsgr"="c:\program files\Windows Live\Messenger\MsnMsgr.Exe" [2009-07-26 3883856]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2009-01-15 39408]
"WindowsWelcomeCenter"="oobefldr.dll" - c:\windows\System32\oobefldr.dll [2009-04-11 2153472]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2007-01-31 131072]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2007-01-31 151552]
"Persistence"="c:\windows\system32\igfxpers.exe" [2007-01-31 126976]
"Camera Assistant Software"="c:\program files\Camera Assistant Software for Toshiba\traybar.exe" [2007-02-13 405504]
"Windows Defender"="c:\program files\Windows Defender\MSASCui.exe" [2008-01-19 1008184]
"SynTPEnh"="c:\program files\Synaptics\SynTP\SynTPEnh.exe" [2007-02-02 835584]
"Google Desktop Search"="c:\program files\Google\Google Desktop Search\GoogleDesktop.exe" [2007-02-28 220160]
"TPwrMain"="c:\program files\TOSHIBA\Power Saver\TPwrMain.EXE" [2006-12-20 411768]
"HSON"="c:\program files\TOSHIBA\TBS\HSON.exe" [2006-12-08 55416]
"SmoothView"="c:\program files\Toshiba\SmoothView\SmoothView.exe" [2007-01-19 448632]
"00TCrdMain"="c:\program files\TOSHIBA\FlashCards\TCrdMain.exe" [2007-01-17 534648]
"ccApp"="c:\program files\Common Files\Symantec Shared\ccApp.exe" [2006-11-22 107112]
"vptray"="c:\progra~1\SYMANT~1\VPTray.exe" [2006-11-28 134808]
"GrooveMonitor"="c:\program files\Microsoft Office\Office12\GrooveMonitor.exe" [2008-10-25 31072]
"mcagent_exe"="c:\program files\McAfee.com\Agent\mcagent.exe" [2009-09-17 645328]
"TkBellExe"="c:\program files\Common Files\Real\Update_OB\realsched.exe" [2008-04-05 185896]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2009-01-05 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2009-04-02 342312]
"Citi Virtual Account Numbers"="c:\progra~1\VIRTUA~1\CitiVAN.exe" [2007-12-07 270336]
"Windows Mobile-based device management"="c:\windows\WindowsMobile\wmdSync.exe" [2006-11-02 215552]
"RtHDVCpl"="RtHDVCpl.exe" - c:\windows\RtHDVCpl.exe [2007-02-07 4374528]
"NDSTray.exe"="NDSTray.exe" [BU]
c:\users\Chris\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\
SolidWorks Task Scheduler Engine.lnk - c:\program files\SolidWorks\swScheduler\swBOEngine.exe [2007-9-9 488728]
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Svc]
"VistaSp2"=hex(b):13,16,9e,46,1c,3b,ca,01
R0 nipbcfk;National Instruments Class Upper Filter Driver;c:\windows\System32\drivers\nipbcfk.sys [7/10/2007 9:08 PM 15448]
R2 McAfee SiteAdvisor Service;McAfee SiteAdvisor Service;c:\program files\McAfee\SiteAdvisor\McSACore.exe [9/28/2009 3:17 PM 210216]
R2 NiViPxiK;NI-VISA PXI Driver;c:\windows\System32\drivers\NiViPxiKl.sys [7/19/2007 12:56 PM 11360]
R3 EraserUtilRebootDrv;EraserUtilRebootDrv;c:\program files\Common Files\Symantec Shared\EENGINE\EraserUtilRebootDrv.sys [10/16/2009 8:04 PM 102448]
R3 FwLnk;FwLnk Driver;c:\windows\System32\drivers\FwLnk.sys [2/28/2007 3:00 PM 7168]
S3 nidimk;nidimk;c:\windows\System32\drivers\nidimkl.sys [7/12/2007 7:18 PM 11360]
S3 nipalfwedl;nipalfwedl;c:\windows\System32\drivers\nipalfwedl.sys [7/18/2007 10:11 PM 11904]
S3 nipalusbedl;nipalusbedl;c:\windows\System32\drivers\nipalusbedl.sys [7/18/2007 10:12 PM 11896]
S3 NiViFWK;NI-VISA FireWire Driver;c:\windows\System32\drivers\NiViFWKl.sys [7/19/2007 12:48 PM 11384]
S3 NiViPciK;NI-VISA PCI Driver;c:\windows\System32\drivers\NiViPciKl.sys [7/19/2007 12:56 PM 11360]
S3 SavRoam;SAVRoam;c:\program files\Symantec AntiVirus\SavRoam.exe [11/28/2006 6:34 AM 122008]
WindowsMobile REG_MULTI_SZ wcescomm rapimgr
LocalServiceRestricted REG_MULTI_SZ WcesComm RapiMgr
2009-10-15 c:\windows\Tasks\McDefragTask.job
- c:\progra~1\mcafee\mqc\QcConsol.exe [2009-10-22 17:22]
2009-05-01 c:\windows\Tasks\McQcTask.job
2009-10-24 c:\windows\Tasks\User_Feed_Synchronization-{D7724767-7F5C-499C-B4D0-65A7A70C97B9}.job
- c:\windows\system32\msfeedssync.exe [2009-10-16 03:41]
uStart Page = about:blank
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~4\Office12\EXCEL.EXE/3000
HKCU-Run-lphcj4jj0e92o - c:\windows\system32\lphcj4jj0e92o.exe
HKCU-Run-dukogutel - c:\progra~2\simipari\simipari.dll
HKCU-Run-TOSCDSPD - TOSCDSPD.EXE
SharedTaskScheduler-{beeee39e-a28e-43b5-9408-ebb8ee69cf2c} - (no file)
Rootkit scan 2009-10-24 18:29
Windows 6.0.6002 Service Pack 2 NTFS
scanning hȋdden processes ...
scanning hȋdden files ...
hȋdden files: 0
@Denied: (A) (Users)
@Denied: (A) (Everyone)
"BlindDial"=dword:00000000
"MSCurrentCountry"=dword:000000b5
- - - - - - - > 'Explorer.exe'(172)
c:\program files\McAfee\SiteAdvisor\saHook.dll
c:\windows\Microsoft.Net\Framework\v3.0\WPF\PresentationFontCache.exe
c:\program files\Common Files\Symantec Shared\ccSvcHst.exe
c:\windows\system32\agrsmsvc.exe
c:\program files\TOSHIBA\ConfigFree\CFSvcs.exe
c:\program files\Symantec AntiVirus\DefWatch.exe
c:\windows\system32\lkcitdl.exe
c:\windows\system32\lkads.exe
c:\windows\system32\lktsrv.exe
c:\progra~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
c:\progra~1\McAfee\VIRUSS~1\mcshield.exe
c:\program files\McAfee\MPF\MPFSrv.exe
c:\program files\McAfee\MSK\MskSrver.exe
c:\program files\National Instruments\MAX\nimxs.exe
c:\program files\National Instruments\Shared\Security\nidmsrv.exe
c:\windows\system32\nisvcloc.exe
c:\program files\National Instruments\Shared\Tagger\tagsrv.exe
c:\toshiba\IVP\ISM\pinger.exe
c:\toshiba\IVP\swupdate\swupdtmr.exe
c:\program files\Symantec AntiVirus\Rtvscan.exe
c:\windows\system32\TODDSrv.exe
c:\program files\Toshiba\Power Saver\TosCoSrv.exe
c:\program files\Toshiba\Bluetooth Toshiba Stack\TosBtSrv.exe
c:\program files\Common Files\Ulead Systems\DVD\ULCDRSvr.exe
c:\progra~1\McAfee\MSC\mcmscsvc.exe
c:\progra~1\mcafee.com\agent\mcagent.exe
c:\commy29219c\CF30835.exe
c:\windows\system32\wbem\unsecapp.exe
c:\program files\common files\mcafee\mna\mcnasvc.exe
c:\commy29219c\PEV.cfxxe
Completion time: 2009-10-24 18:40 - machine was rebooted
ComboFix-quarantined-files.txt 2009-10-24 23:39
Pre-Run: 63,233,265,664 bytes free
Post-Run: 65,183,571,968 bytes free
- - End Of File - - 9AC10F27839C2D82B6F44000C6CDC8F7
jcs829
Posts Posts : 20
OS OS : vista
Post by jcs829 on 24th October 2009, 11:53 pm
µTorrent
Acrobat.com
Activation Assistant for the 2007 Microsoft Office suites
Adobe AIR
Adobe Flash Player 10 ActiveX
Adobe Reader 7.0
Adobe Shockwave Player
Apple Mobile Device Support
Apple Software Update
AutoUpdate
BAA Screensaver
Bejeweled 2 Deluxe
Blackhawk Striker 2
Blasterball 3
Bluetooth Stack for Windows by Toshiba
Bonjour
CD/DVD Drive Acoustic Silencer
Chuzzle Deluxe
Desktop Dialer
DivX Codec
DivX Player
DivX Web Player
DVD MovieFactory for TOSHIBA
GOM Player
Google Desktop
GRE POWERPREP
HI-TECH C51-lite V9.60PL0
HI-TECH PICC lite V9.60PL0
InfraRecorder
Internet Offers
iPod for Windows 2005-11-17
iTunes
IVI Shared Component
IVI Shared Components
Java(TM) SE Runtime Environment 6
JEOPARDY
JMP 6
Junk Mail filter update
LiveUpdate 3.2 (Symantec Corporation)
Marvell Miniport Driver
Mathcad 8 Explorer
McAfee SecurityCenter
Microsoft Choice Guard
Microsoft Office 2003 Web Components
Microsoft Office 2007 Service Pack 2 (SP2)
Microsoft Office Access MUI (English) 2007
Microsoft Office Access Setup Metadata MUI (English) 2007
Microsoft Office Enterprise 2007
Microsoft Office Groove MUI (English) 2007
Microsoft Office Groove Setup Metadata MUI (English) 2007
Microsoft Office Home and Student 2007
Microsoft Office InfoPath MUI (English) 2007
Microsoft Office Live Add-in 1.3
Microsoft Office OneNote MUI (English) 2007
Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
Microsoft Office Publisher MUI (English) 2007
Microsoft Works
Microsoft XML Parser
Move Media Player
MSVCRT
MSXML 4.0 SP2 (KB927978)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
National Instruments Software
NI-DAQmx - LabVIEW shared documentation
NI-DIM 1.7.0f0
NI-IVI Provider for MAX
NI-ORB 1.7.0f0
NI-PAL 2.1.0f1
NI-RPC 3.4.0f1
NI-RPC 3.4.0f1 for Phar Lap ETS
NI-VISA Runtime 4.2
NI AFW Channel Configuration Tool
NI Assistant Framework
NI Assistant Framework LabVIEW Code Generator 6.1
NI Assistant Framework LabVIEW Code Generator 7.0
NI Assistant Framework LabVIEW Code Generator 7.1
NI Assistant Framework LabVIEW Code Generator 8.0
NI Assistant Framework LabVIEW Code Generator 8.2
NI Assistant Framework LabVIEW Code Generator 8.5
NI Certificates Deployment Support
NI Circuit Design Suite 10 Core
NI Circuit Design Suite 10 Educational
NI Circuit Design Suite Support and Upgrade Utility
NI Control Design Mathscript VIs
NI Control Design Shared VIs
NI DataSocket 4.5.0
NI DN 2.0 installer
NI EULA Depot
NI Example Finder 8.5
NI Help Assistant
NI Instrument IO Assistant for LabVIEW 8.5
NI IVI Class Driver LabVIEW 8.5 Support
NI IVI Class Drivers
NI IVI Class Simulation Drivers
NI IVI Compliance Package 3.1
NI IVI Engine
NI IVI Online Help
NI LabVIEW 8.5
NI LabVIEW 8.5 Applibs
NI LabVIEW 8.5 CINtools
NI LabVIEW 8.5 Control Design and Simulation Module - Control Design Support
NI LabVIEW 8.5 Control Design and Simulation Module - Simulation Support
NI LabVIEW 8.5 Device Detection and Deployment Support
NI LabVIEW 8.5 Examples
NI LabVIEW 8.5 gMath
NI LabVIEW 8.5 Help
NI LabVIEW 8.5 Help File
NI LabVIEW 8.5 iMath
NI LabVIEW 8.5 Instr.lib
NI LabVIEW 8.5 License
NI LabVIEW 8.5 Manuals
NI LabVIEW 8.5 MeasAppChm File
NI LabVIEW 8.5 Menus
NI LabVIEW 8.5 Project
NI LabVIEW 8.5 Resource
NI LabVIEW 8.5 Simulation
NI LabVIEW 8.5 Templates
NI LabVIEW 8.5 User.lib
NI LabVIEW 8.5 VI.lib
NI LabVIEW 8.5 WWW
NI LabVIEW Analog Modulation Toolkit 4.0
NI LabVIEW Broker
NI LabVIEW C Interface
NI LabVIEW Deployable License 8.5.0
NI LabVIEW Digital Filter Design Toolkit 8.2.1
NI LabVIEW MAX XML
NI LabVIEW Merge Utility 8.5.0
NI LabVIEW Modulation Toolkit 4.0
NI LabVIEW Real-Time Error Dialog
NI LabVIEW Real-Time FIFO for Runtime
NI LabVIEW Run-Time Engine 7.1.1
NI LabVIEW Run-Time Engine 8.0.1
NI LabVIEW Run-Time Engine 8.2.1
NI LabVIEW Run-Time Engine 8.5
NI LabVIEW SignalExpress 2.5
NI LabVIEW SignalExpress 2.5 Core
NI LabVIEW SignalExpress 2.5 Core LabVIEW Support
NI LabVIEW SignalExpress 2.5 Datatypes
NI LabVIEW SignalExpress 2.5 LabVIEW Support
NI LabVIEW SignalExpress 2.5 Licenses
NI LabVIEW SignalExpress 2.5 Steps
NI LabVIEW SignalExpress 2.5 Tools
NI LabVIEW SimControl Shared Help Files
NI LabVIEW Simulation Module Converter
NI LabVIEW Simulation Module Optimization
NI LabVIEW Simulation Module Shared Files
NI LabVIEW System Identification 3.0 Assistant
NI LabVIEW System Identification 3.0 Toolkit VIs
NI LabVIEW System Identification Toolkit 3.0.1
NI LabWindows/CVI 8.1.1 Run-Time Engine
NI LabWindows/CVI Code Generator
NI License Manager
NI Logos 4.9
NI Logos LabVIEW 8.5 Support
NI Logos XT Support
NI LVBrokerAux 8.2.1
NI LVBrokerAux 8.5.0
NI LVBrokerAux71
NI LVBrokerAux8.0
NI Math Kernel Libraries
NI MAX LabVIEW Support
NI MDF Support
NI Measurement & Automation Explorer 4.3
NI Measurement Studio 8.1 Enterprise RunTime for VS2005
NI Measurement Studio Common .NET Language Assemblies for the .NET Framework 2.0
NI Measurement Studio Recipe Processor
NI MXS
NI OPC Support
NI Portable Configuration
NI Registration Wizard
NI Remote Provider for MAX
NI Remote PXI Provider for MAX
NI Service Locator
NI Session Manager 3.5
NI Software Provider for MAX
NI Sound and Vibration Frequency Analysis 5.0
NI System Identification Assistant LabVIEW Support
NI TDMS
NI Uninstaller
NI USI 1.5.0
NI Variable Engine
NI Variable Engine LabVIEW 8.5 Support
NI Variable Manager
NI VC2005MSMs x86
NI Web Pipeline
Penguins!
Polar Bowler
Polar Golfer
QuickTime
RealPlayer
Rhapsody Player Engine
RoboWorks Demo 3.0
SCRABBLE
Security Update for 2007 Microsoft Office System (KB969559)
Security Update for 2007 Microsoft Office System (KB969679)
Security Update for Microsoft Office Excel 2007 (KB969682)
Security Update for Microsoft Office Outlook 2007 (KB972363)
Security Update for Microsoft Office PowerPoint 2007 (KB957789)
Security Update for Microsoft Office Publisher 2007 (KB969693)
Security Update for Microsoft Office system 2007 (972581)
Security Update for Microsoft Office system 2007 (KB969613)
Security Update for Microsoft Office system 2007 (KB974234)
Security Update for Microsoft Office Visio Viewer 2007 (KB973709)
Security Update for Microsoft Office Word 2007 (KB969604)
Security Update for Windows Media Encoder (KB954156)
Skype web features
Skype™ 4.1
SolidWorks 2008 SP0
Symantec AntiVirus
Synaptics Pointing Device Driver
Texas Instruments PCIxx21/x515/xx12 drivers.
TIPCI
TOSHIBA Assist
TOSHIBA ConfigFree
TOSHIBA Disc Creator
TOSHIBA Extended Tiles for Windows Mobility Center
TOSHIBA Game Console
TOSHIBA Hardware Setup
TOSHIBA Media Center Game Console
Toshiba Registration
TOSHIBA SD Memory Utilities
TOSHIBA Software Modem
TOSHIBA Software Upgrades
TOSHIBA Speech System Applications
TOSHIBA Speech System SR Engine(U.S.) Version1.0
TOSHIBA Speech System TTS Engine(U.S.) Version1.0
TOSHIBA Supervisor Password
TOSHIBA Value Added Package
Update for Outlook 2007 Junk Email Filter (KB974810)
Windows Live Call
Windows Live Essentials
Windows Live Mail
Windows Live Messenger
Windows Live OneCare safety scanner
Windows Live Upload Tool
Windows Media Encoder 9 Series
WinDVD for TOSHIBA
WinRAR archiver
World of Warcraft
jcs829
Posts Posts : 20
OS OS : vista
Post by Belahzur on 26th October 2009, 12:24 am
  • Click Start >> Control Panel.
  • Under the Programs click Uninstall a Program
  • Highlight µTorrent and Java(TM) SE Runtime Environment 6
  • Click on the Uninstall/Change button at the top.
  1. Close any open browsers.
    Folder::
    File::
    DDS::
    RegLock::
Points Points : 245079
Post by jcs829 on 26th October 2009, 2:17 am
ComboFix 09-10-25.02 - Chris 10/25/2009 20:47.3.2 - NTFSx86
Microsoft® Windows Vista™ Home Premium 6.0.6002.2.1252.1.1033.18.2037.795 [GMT -5:00]
Command switches used :: c:\users\Chris\Desktop\CFScript.txt
AV: Symantec AntiVirus *On-access scanning disabled* (Updated) {FB06448E-52B8-493A-90F3-E43226D3305C}
SP: Symantec AntiVirus *disabled* (Updated) {6C85A515-B91D-4D2B-AF18-40984A4A8493}
FILE ::
"c:\windows\System32\buhedina.exe"
"c:\windows\System32\davozido.exe"
"c:\windows\System32\vukolosu.exe"
"c:\windows\System32\wimoroka.exe"
"c:\windows\System32\wogutopa.exe"
"c:\windows\System32\zarajubo.dll"
c:\programdata\ladowozi\ladowozi.dll
((((((((((((((((((((((((( Files Created from 2009-09-26 to 2009-10-26 )))))))))))))))))))))))))))))))
2009-10-26 02:03 . 2009-10-26 02:05 -------- d-----w- c:\users\Chris\AppData\Local\temp
2009-10-26 02:03 . 2009-10-26 02:03 -------- d-----w- c:\users\Public\AppData\Local\temp
2009-10-26 02:03 . 2009-10-26 02:03 -------- d-----w- c:\users\Default\AppData\Local\temp
2009-10-26 01:30 . 2009-07-15 02:08 -------- d-----w- c:\users\Chris\AppData\Roaming\uTorrent
- 2007-02-28 20:52 . 2009-10-24 22:44 85102 c:\windows\System32\WDI\ShutdownPerformanceDiagnostics_SystemData.bin
+ 2007-02-28 20:52 . 2009-10-25 16:27 85102 c:\windows\System32\WDI\ShutdownPerformanceDiagnostics_SystemData.bin
- 2006-11-02 13:05 . 2009-10-24 23:30 70052 c:\windows\System32\WDI\BootPerformanceDiagnostics_SystemData.bin
+ 2006-11-02 13:05 . 2009-10-26 01:36 70052 c:\windows\System32\WDI\BootPerformanceDiagnostics_SystemData.bin
- 2007-06-25 05:08 . 2009-10-24 23:30 20054 c:\windows\System32\WDI\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-3325274441-2933238227-355094248-1000_UserData.bin
+ 2007-06-25 05:08 . 2009-10-26 01:36 20054 c:\windows\System32\WDI\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-3325274441-2933238227-355094248-1000_UserData.bin
- 2007-03-20 20:42 . 2009-10-24 23:29 32768 c:\windows\System32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2007-03-20 20:42 . 2009-10-26 02:05 32768 c:\windows\System32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
- 2007-03-20 20:42 . 2009-10-24 23:29 65536 c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2007-03-20 20:42 . 2009-10-26 02:05 65536 c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2009-10-26 01:37 . 2009-10-26 01:37 6130 c:\windows\System32\config\systemprofile\AppData\Roaming\SACore\Cache\DA39A3EE5E6B4B0D3255BFEF95601890AFD80709\EB5AF50E0B263C13B3D628ADA3AC42B02C51003D\EB5AF50E0B263C13B3D628ADA3AC42B02C51003D\Data.dat
- 2009-10-24 22:25 . 2009-10-24 22:25 4962 c:\windows\System32\config\systemprofile\AppData\Roaming\SACore\Cache\DA39A3EE5E6B4B0D3255BFEF95601890AFD80709\B7B77EFB009E907FCA5AED9F5CD78AF3EC2558D6\B7B77EFB009E907FCA5AED9F5CD78AF3EC2558D6\Data.dat
+ 2009-10-26 01:05 . 2009-10-26 01:05 4962 c:\windows\System32\config\systemprofile\AppData\Roaming\SACore\Cache\DA39A3EE5E6B4B0D3255BFEF95601890AFD80709\B7B77EFB009E907FCA5AED9F5CD78AF3EC2558D6\B7B77EFB009E907FCA5AED9F5CD78AF3EC2558D6\Data.dat
+ 2009-10-26 01:12 . 2009-10-26 01:12 5756 c:\windows\System32\config\systemprofile\AppData\Roaming\SACore\Cache\DA39A3EE5E6B4B0D3255BFEF95601890AFD80709\41F1CD21CD05A267CEDD8C0E1104AD4C595D6FA2\41F1CD21CD05A267CEDD8C0E1104AD4C595D6FA2\Data.dat
- 2009-10-24 21:50 . 2009-10-24 21:50 5756 c:\windows\System32\config\systemprofile\AppData\Roaming\SACore\Cache\DA39A3EE5E6B4B0D3255BFEF95601890AFD80709\41F1CD21CD05A267CEDD8C0E1104AD4C595D6FA2\41F1CD21CD05A267CEDD8C0E1104AD4C595D6FA2\Data.dat
- 2009-10-24 22:00 . 2009-10-24 22:00 5988 c:\windows\System32\config\systemprofile\AppData\Roaming\SACore\Cache\DA39A3EE5E6B4B0D3255BFEF95601890AFD80709\3A3C5F7CC9415160B34912634CB95978E99A7DDE\3A3C5F7CC9415160B34912634CB95978E99A7DDE\Data.dat
+ 2009-10-26 01:39 . 2009-10-26 01:39 5988 c:\windows\System32\config\systemprofile\AppData\Roaming\SACore\Cache\DA39A3EE5E6B4B0D3255BFEF95601890AFD80709\3A3C5F7CC9415160B34912634CB95978E99A7DDE\3A3C5F7CC9415160B34912634CB95978E99A7DDE\Data.dat
+ 2009-10-26 01:05 . 2009-10-26 01:05 6158 c:\windows\System32\config\systemprofile\AppData\Roaming\SACore\Cache\DA39A3EE5E6B4B0D3255BFEF95601890AFD80709\217C5A9988F137C191AB2A26D7B4807D49DFC2EC\217C5A9988F137C191AB2A26D7B4807D49DFC2EC\Data.dat
+ 2009-10-26 01:37 . 2009-10-26 01:37 5866 c:\windows\System32\config\systemprofile\AppData\Roaming\SACore\Cache\DA39A3EE5E6B4B0D3255BFEF95601890AFD80709\0FAD3B8C5C374914520A72A77FB0B694C13391B5\0FAD3B8C5C374914520A72A77FB0B694C13391B5\Data.dat
+ 2009-10-25 16:25 . 2009-10-26 01:33 2048 c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
- 2009-10-24 23:28 . 2009-10-24 23:28 2048 c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
- 2009-10-24 23:28 . 2009-10-24 23:28 2048 c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
+ 2009-10-25 16:25 . 2009-10-26 01:33 2048 c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
- 2007-03-20 20:42 . 2009-10-24 23:29 311296 c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2007-03-20 20:42 . 2009-10-26 02:05 311296 c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2008-03-30 06:04 . 2009-10-25 06:04 2268008 c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache3.0.0.0.dat
- 2008-03-30 06:04 . 2009-10-24 23:26 2268008 c:\windows\ServiceProfiles\LocalService\AppData\Local\FontCache3.0.0.0.dat
*NewlyCreated* - MBR
*Deregistered* - mbr
2009-10-25 c:\windows\Tasks\User_Feed_Synchronization-{D7724767-7F5C-499C-B4D0-65A7A70C97B9}.job
Rootkit scan 2009-10-25 21:05
hȋdden files: 0
Completion time: 2009-10-26 21:09
ComboFix-quarantined-files.txt 2009-10-26 02:08
ComboFix2.txt 2009-10-24 23:40
Pre-Run: 63,628,644,352 bytes free
Post-Run: 63,607,091,200 bytes free
- - End Of File - - 4A429E1F218831BA2FA08E6FC6DB4D68
jcs829
Posts Posts : 20
Joined Joined : 2009-10-23
OS OS : vista
Points Points : 26114
Re: Win32/nuqel.E / bankerfox.a / Antivirus system pro. problem
Post by jcs829 on 27th October 2009, 5:39 pm
Bump...
or does that mean my computer is clean now?
jcs829
Posts Posts : 20
OS OS : vista
Post by jcs829 on 29th October 2009, 3:34 pm
hello?
jcs829
Posts Posts : 20
OS OS : vista
Post by Belahzur on 29th October 2009, 5:44 pm
ComboFix /u
Post by jcs829 on 30th October 2009, 1:05 am
It's running good and haven't had any sign of viruses. DO you think it's good now? Any more suggestions/comments?
jcs829
Posts Posts : 20
OS OS : vista
Post by Belahzur on 30th October 2009, 1:27 am
Yes, this looks fine now.
