Assist with Antivirus System Pro
Post by Capntreee on Fri Oct 23, 2009 3:21 am
Discovered Antivirus System Pro this afternoon as it hijacked my browser and started playing ads and displaying random websites. Read through a bunch of other forum logs to learn what I could. Downloaded Malwarebytes as I'd seen it recommended by many others. This program will not run because it can not locate mbam.exe despite being pointed to the correct folder. Extracted zip files a 2nd time to be sure. I could try HijackThis but I'm not certain that is what you'd request. Thanks in advance for your assistance.
Capntreee
OS : XP Pro SP2
Re: Assist with Antivirus System Pro
Post by Dr Jay on Sat Oct 24, 2009 1:05 am
OS : Windows 10 Home & Pro
Post by Capntreee on Mon Oct 26, 2009 4:25 pm
ComboFix 09-10-25.02 - Terry Hanrahan 10/26/2009 8:56.1.1 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.2.1252.1.1033.18.1014.621 [GMT -7:00]
Running from: c:\documents and settings\Terry Hanrahan\desktop\commy.exe
FW: Norton Internet Worm Protection *disabled* {990F9400-4CEE-43EA-A83A-D013ADD8EA6E}
c:\documents and settings\All Users\Application Data\16440520
c:\windows\system32\bopetuza.exe
c:\windows\system32\figorana.exe
c:\windows\system32\kajoreji.exe
c:\windows\system32\losiyolu.exe
c:\windows\system32\rirozobi.exe
c:\windows\system32\sunemudu.exe
c:\windows\system32\vikatemo.exe
c:\docume~1\TERRYH~1\LOCALS~1\Temp\csrss.exe
c:\docume~1\TERRYH~1\LOCALS~1\Temp\lsass.exe
c:\docume~1\TERRYH~1\LOCALS~1\Temp\services.exe
c:\docume~1\TERRYH~1\LOCALS~1\Temp\svchost.exe
c:\docume~1\TERRYH~1\LOCALS~1\Temp\taskmgr.exe
c:\docume~1\TERRYH~1\LOCALS~1\Temp\winlogon.exe
c:\documents and settings\All Users\Application Data\16440520\16440520.exe
c:\documents and settings\Terry Hanrahan\ntuser.dll
c:\documents and settings\Terry Hanrahan\Start Menu\Programs\Startup\scandisk.dll
c:\documents and settings\Terry Hanrahan\Start Menu\Programs\Startup\scandisk.lnk
C:\LOG1.tmp
c:\windows\alorazohit.dll
c:\windows\syssvc.exe
c:\windows\system32\_000006_.tmp.dll
c:\windows\system32\_000007_.tmp.dll
c:\windows\system32\_000008_.tmp.dll
c:\windows\system32\_000009_.tmp.dll
c:\windows\system32\_000011_.tmp.dll
c:\windows\system32\~.exe
c:\windows\system32\6to4v32.dll
c:\windows\system32\calc.dll
c:\windows\system32\certstore.dat
c:\windows\system32\cz52cp7.dll
c:\windows\system32\FInstall.sys
c:\windows\system32\havomuzo.dll.tmp
c:\windows\system32\iehelper.dll
c:\windows\system32\Install.txt
c:\windows\system32\isapeep.sys
c:\windows\system32\midinuro.dll.tmp
c:\windows\system32\mulipiza.dll
c:\windows\system32\nutuhunu.dll.tmp
c:\windows\system32\sebimike.dll
c:\windows\system32\volosejo.dll
c:\windows\system32\yiwuyipa.dll
E:\Autorun.inf
Infected copy of c:\windows\system32\eventlog.dll was found and disinfected
Restored copy from - c:\i386\eventlog.dll
-------\Legacy_6TO4
-------\Service_6to4
-------\Legacy_isapeep
-------\Service_isapeep
((((((((((((((((((((((((( Files Created from 2009-09-26 to 2009-10-26 )))))))))))))))))))))))))))))))
2009-10-23 02:35 . 2009-10-23 02:35 -------- d-----w- c:\documents and settings\Terry Hanrahan\Application Data\Malwarebytes
2009-10-23 02:35 . 2009-09-10 21:54 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-10-23 02:35 . 2009-10-23 02:41 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-10-23 02:35 . 2009-10-23 02:35 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2009-10-23 02:35 . 2009-09-10 21:53 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-10-22 23:06 . 2009-10-26 14:24 0 ----a-r- c:\windows\Dlujuqole.bin
2009-10-22 23:06 . 2009-10-26 15:21 120 ----a-w- c:\windows\Eceqoboxebo.dat
2009-10-22 23:06 . 2009-10-22 23:06 -------- d-----w- c:\documents and settings\Terry Hanrahan\Local Settings\Application Data\{9168E96F-B4D7-47A2-B989-D8D5557CDCCC}
2009-10-22 23:00 . 2009-10-26 14:29 0 ----a-r- c:\windows\win32k.sys
2009-10-22 23:00 . 2009-10-22 23:00 52224 ----a-w- C:\ldvx.exe
2009-10-22 23:00 . 2009-10-22 23:00 50176 ----a-w- C:\qsdhs.exe
2009-10-22 23:00 . 2009-10-22 23:00 250368 ----a-w- C:\dtacmawh.exe
2009-10-22 18:34 . 2009-10-22 18:34 -------- d-----w- c:\documents and settings\Terry Hanrahan\Local Settings\Application Data\Temp
2009-09-28 15:56 . 2009-08-29 07:36 6067200 ------w- c:\windows\system32\dllcache\ieframe.dll
2009-09-28 15:56 . 2009-08-29 07:36 52224 ------w- c:\windows\system32\dllcache\msfeedsbs.dll
2009-09-28 15:56 . 2009-08-29 07:36 459264 ------w- c:\windows\system32\dllcache\msfeeds.dll
2009-09-28 15:56 . 2009-08-29 07:36 268288 ------w- c:\windows\system32\dllcache\iertutil.dll
2009-09-28 15:56 . 2009-08-29 07:36 63488 ------w- c:\windows\system32\dllcache\icardie.dll
2009-09-28 15:56 . 2009-08-29 07:36 380928 ------w- c:\windows\system32\dllcache\ieapfltr.dll
2009-09-28 15:56 . 2009-08-28 10:28 13824 ------w- c:\windows\system32\dllcache\ieudinit.exe
2009-09-28 15:56 . 2009-06-29 08:33 2452872 ------w- c:\windows\system32\dllcache\ieapfltr.dat
2009-10-26 16:05 . 2007-10-09 15:47 -------- d-----w- c:\program files\Dl_cats
2009-10-23 21:35 . 2007-10-12 16:00 848 --sha-w- c:\documents and settings\All Users\Application Data\KGyGaAvL.sys
2009-09-28 21:26 . 2007-05-18 18:12 -------- d-----w- c:\documents and settings\All Users\Application Data\Microsoft Help
2009-09-11 14:03 . 2004-08-11 22:00 136192 ----a-w- c:\windows\system32\msv1_0.dll
2009-09-10 16:39 . 2008-09-17 22:13 58472 ----a-w- c:\documents and settings\Guest\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-09-08 14:08 . 2007-05-18 18:24 58472 ----a-w- c:\documents and settings\Administrator\Local Settings\Application Data\GDIPFONTCACHEV1.DAT
2009-09-04 20:45 . 2004-08-11 22:00 58880 ----a-w- c:\windows\system32\msasn1.dll
2009-08-29 07:36 . 2004-08-11 22:00 832512 ----a-w- c:\windows\system32\wininet.dll
2009-08-29 07:36 . 2004-08-11 22:00 78336 ----a-w- c:\windows\system32\ieencode.dll
2009-08-29 07:36 . 2004-08-11 22:00 17408 ------w- c:\windows\system32\corpol.dll
2009-08-26 08:16 . 2004-08-11 22:00 247326 ----a-w- c:\windows\system32\strmdll.dll
2009-08-07 02:24 . 2004-08-11 22:12 327896 ----a-w- c:\windows\system32\wucltui.dll
2009-08-07 02:24 . 2004-08-11 22:12 209632 ----a-w- c:\windows\system32\wuweb.dll
2009-08-07 02:24 . 2007-04-17 05:45 44768 ----a-w- c:\windows\system32\wups2.dll
2009-08-07 02:24 . 2004-08-11 22:12 35552 ----a-w- c:\windows\system32\wups.dll
2009-08-07 02:24 . 2004-08-11 22:12 53472 ----a-w- c:\windows\system32\wuauclt.exe
2009-08-07 02:24 . 2004-08-11 22:00 96480 ----a-w- c:\windows\system32\cdm.dll
2009-08-07 02:23 . 2004-08-11 22:12 575704 ----a-w- c:\windows\system32\wuapi.dll
2009-08-07 02:23 . 2004-08-11 22:12 1929952 ----a-w- c:\windows\system32\wuaueng.dll
2009-08-05 09:11 . 2004-08-11 22:00 204800 ----a-w- c:\windows\system32\mswebdvd.dll
2009-08-04 12:51 . 2004-08-11 22:00 2185984 ----a-w- c:\windows\system32\ntoskrnl.exe
2009-08-04 12:02 . 2004-08-04 03:59 2062976 ----a-w- c:\windows\system32\ntkrnlpa.exe
2007-10-23 19:31 . 2007-10-09 22:27 88 --sh--r- c:\windows\system32\D9F34FE0B0.sys
2009-07-23 23:07 . 2009-07-23 23:07 91648 --sha-w- c:\windows\system32\hesonida.dll
2009-07-22 23:06 . 2009-07-22 23:06 39424 --sha-w- c:\windows\system32\hofonike.dll
2009-07-23 11:07 . 2009-07-23 11:07 39424 --sha-w- c:\windows\system32\husiwolo.dll
2009-07-24 23:08 . 2009-07-24 23:08 39424 --sha-w- c:\windows\system32\jakokoba.dll
2009-07-26 15:09 . 2009-07-26 15:09 39424 --sha-w- c:\windows\system32\kufubabe.dll
2009-07-26 15:10 . 2009-07-26 15:10 53248 --sha-w- c:\windows\system32\lanimaye.dll
2009-07-23 11:07 . 2009-07-23 11:07 53760 --sha-w- c:\windows\system32\liroteyu.dll
2009-07-25 11:08 . 2009-07-25 11:08 39424 --sha-w- c:\windows\system32\mekerozu.dll
2009-07-25 23:08 . 2009-07-25 23:08 39424 --sha-w- c:\windows\system32\mimedefa.dll
2009-07-24 23:08 . 2009-07-24 23:08 91648 --sha-w- c:\windows\system32\ruwodote.dll
2009-07-24 11:07 . 2009-07-24 11:07 39424 --sha-w- c:\windows\system32\siyasago.dll
2009-07-23 23:07 . 2009-07-23 23:07 53760 --sha-w- c:\windows\system32\tofiraji.dll
2009-07-22 23:06 . 2009-07-22 23:06 1051170 --sha-w- c:\windows\system32\tolujuwi.exe
2009-07-24 11:07 . 2009-07-24 11:07 91648 --sha-w- c:\windows\system32\wuhetoso.dll
2009-07-26 15:09 . 2009-07-26 15:09 53248 --sha-w- c:\windows\system32\wutivoba.dll
2009-07-22 23:06 . 2009-07-22 23:06 91648 --sha-w- c:\windows\system32\yivivaso.dll
2009-07-23 23:07 . 2009-07-23 23:07 39424 --sha-w- c:\windows\system32\zewufodo.dll
[HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{9da0b9bf-558b-4255-941b-aebc45e8d263}]
"DellSupport"="c:\program files\Dell Support\DSAgnt.exe" [2006-08-29 395776]
"MSMSGS"="c:\program files\Messenger\msmsgs.exe" [2004-10-13 1694208]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2007-08-19 68856]
"IgfxTray"="c:\windows\system32\igfxtray.exe" [2006-07-21 98304]
"HotKeysCmds"="c:\windows\system32\hkcmd.exe" [2006-07-21 86016]
"Persistence"="c:\windows\system32\igfxpers.exe" [2006-07-21 81920]
"IAAnotif"="c:\program files\Intel\Intel Matrix Storage Manager\Iaanotif.exe" [2006-07-06 151552]
"DMXLauncher"="c:\program files\Dell\Media Experience\DMXLauncher.exe" [2005-10-05 94208]
"Google Desktop Search"="c:\program files\Google\Google Desktop Search\GoogleDesktop.exe" [2007-05-18 169984]
"Symantec PIF AlertEng"="c:\program files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe" [2007-03-13 517768]
"dlcxmon.exe"="c:\program files\Dell Photo AIO Printer 926\dlcxmon.exe" [2007-01-12 292336]
"MemoryCardManager"="c:\program files\Dell Photo AIO Printer 926\memcard.exe" [2006-11-04 304008]
"DLCXCATS"="c:\windows\System32\spool\DRIVERS\W32X86\3\DLCXtime.dll" [2006-10-16 106496]
"Act.Outlook.Service"="c:\program files\ACT\Act for Windows\Act.Outlook.Service.exe" [2007-08-13 9728]
"Act! Preloader"="c:\program files\ACT\Act for Windows\ActSage.exe" [2007-08-14 1351680]
"PinnacleDriverCheck"="c:\windows\system32\PSDrvCheck.exe" [2004-03-11 406016]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2007-10-26 98304]
"Acrobat Assistant 8.0"="c:\program files\Adobe\Acrobat 8.0\Acrobat\Acrotray.exe" [2007-05-11 624248]
"SigmatelSysTrayApp"="stsystra.exe" - c:\windows\stsystra.exe [2006-07-24 282624]
Notification Packages REG_MULTI_SZ scecli lerpripn.dll
"c:\\Program Files\\ACT\\Act for Windows\\ActSage.exe"=
"c:\\WINDOWS\\system32\\dlcxcoms.exe"=
"c:\\Program Files\\Google\\Google Desktop Search\\GoogleDesktop.exe"=
"135:TCP"= 135:TCP:TCP Port 135
"5000:TCP"= 5000:TCP:TCP Port 5000
"5001:TCP"= 5001:TCP:TCP Port 5001
"5002:TCP"= 5002:TCP:TCP Port 5002
"5003:TCP"= 5003:TCP:TCP Port 5003
"5004:TCP"= 5004:TCP:TCP Port 5004
"5005:TCP"= 5005:TCP:TCP Port 5005
"5006:TCP"= 5006:TCP:TCP Port 5006
"5007:TCP"= 5007:TCP:TCP Port 5007
"5008:TCP"= 5008:TCP:TCP Port 5008
"5009:TCP"= 5009:TCP:TCP Port 5009
"5010:TCP"= 5010:TCP:TCP Port 5010
"5011:TCP"= 5011:TCP:TCP Port 5011
"5012:TCP"= 5012:TCP:TCP Port 5012
"5013:TCP"= 5013:TCP:TCP Port 5013
"5014:TCP"= 5014:TCP:TCP Port 5014
"5015:TCP"= 5015:TCP:TCP Port 5015
"5016:TCP"= 5016:TCP:TCP Port 5016
"5017:TCP"= 5017:TCP:TCP Port 5017
"5018:TCP"= 5018:TCP:TCP Port 5018
"5019:TCP"= 5019:TCP:TCP Port 5019
"5020:TCP"= 5020:TCP:TCP Port 5020
R2 BtwSrv;BtwSrv;c:\windows\system32\svchost.exe -k netsvcs [8/11/2004 3:00 PM 14336]
R2 dlcx_device;dlcx_device;c:\windows\system32\dlcxcoms.exe -service --> c:\windows\system32\dlcxcoms.exe -service [?]
R2 fastnetsrv;fastnetsrv Service;c:\windows\system32\FastNetSrv.exe [8/4/2004 3:00 AM 47616]
R2 MSSQL$ACT7;SQL Server (ACT7);c:\program files\Microsoft SQL Server\MSSQL.1\MSSQL\Binn\sqlservr.exe [2/10/2007 5:29 AM 29178224]
S2 ACT! Scheduler;ACT! Scheduler;c:\program files\ACT\Act for Windows\Act.Scheduler.exe [10/12/2007 8:58 AM 65536]
*NewlyCreated* - BTWSRV
*Deregistered* - mbr
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Svchost - NetSvcs
BtwSrv
IE: Append to existing PDF - c:\program files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
IE: Convert link target to Adobe PDF - c:\program files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
IE: Convert link target to existing PDF - c:\program files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
IE: Convert selected links to Adobe PDF - c:\program files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
IE: Convert selected links to existing PDF - c:\program files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
IE: Convert selection to Adobe PDF - c:\program files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
IE: Convert selection to existing PDF - c:\program files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
IE: Convert to Adobe PDF - c:\program files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
BHO-{A2234B15-23F2-42AD-F4E4-00AAC39C0004} - c:\windows\system32\cz52cp7.dll
BHO-{bdb69a0a-605f-2a61-34fe-0879f029086c} - c:\windows\alorazohit.dll
HKCU-Run-updateMgr - c:\program files\Adobe\Acrobat 7.0\Reader\AdobeUpdateManager.exe
HKLM-Run-Jwawikoqatu - c:\windows\alorazohit.dll
HKLM-Run-16440520 - c:\docume~1\ALLUSE~1\APPLIC~1\16440520\16440520.exe
HKLM-Run-hofisonuz - c:\windows\system32\mulipiza.dll
HKLM-Run-zamuvayube - volosejo.dll
SharedTaskScheduler-{A2234B15-23F2-42AD-F4E4-00AAC39C0004} - c:\windows\system32\cz52cp7.dll
SharedTaskScheduler-{360bcfc7-1d3d-41f9-9b64-af527f962c6c} - c:\windows\system32\mulipiza.dll
SSODL-damasozun-{360bcfc7-1d3d-41f9-9b64-af527f962c6c} - c:\windows\system32\mulipiza.dll
Rootkit scan 2009-10-26 09:05
scanning hȋdden processes ...
DLCXCATS = rundll32 c:\windows\System32\spool\DRIVERS\W32X86\3\DLCXtime.dll,_RunDLLEntry@16???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
scanning hȋdden files ...
c:\windows\irc.txt 6 bytes
hȋdden files: 1
- - - - - - - > 'lsass.exe'(776)
c:\windows\lerpripn.dll
- - - - - - - > 'explorer.exe'(3588)
c:\progra~1\WINDOW~2\wmpband.dll
c:\program files\Symantec\LiveUpdate\ALUSchedulerSvc.exe
c:\program files\Intel\Intel Matrix Storage Manager\Iaantmon.exe
c:\program files\common files\protexis\license service\psiservice_2.exe
c:\program files\Microsoft SQL Server\90\Shared\sqlbrowser.exe
c:\program files\Microsoft SQL Server\90\Shared\sqlwriter.exe
c:\program files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
c:\windows\system32\wdfmgr.exe
c:\windows\system32\wmdtc.exe
c:\commy\CF32395.exe
c:\program files\Google\Google Desktop Search\GoogleDesktopIndex.exe
c:\program files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
c:\windows\system32\lsm32.sys
c:\program files\Symantec\LiveUpdate\AUpdate.exe
c:\progra~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
c:\commy\PEV.cfxxe
Completion time: 2009-10-26 9:08 - machine was rebooted
ComboFix-quarantined-files.txt 2009-10-26 16:08
Pre-Run: 39,674,515,456 bytes free
Post-Run: 40,190,828,544 bytes free
multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect
- - End Of File - - 176D1987F6466B7193A65970D879F715
ACT! by Sage Premium 2008 (10.0)
Adobe Acrobat 8 Standard
Adobe Acrobat 8.1.1 Standard
Adobe Flash Player 10 ActiveX
Adobe Reader 8.1.1
AutoUpdate
Corel Paint Shop Pro Photo XI
Dell CinePlayer
Dell Driver Reset Tool
Dell Support 3.2.1
Dell System Restore
DiscAPI (Studio 10)
DivX
Google Desktop
Hotfix for Windows XP (KB896256)
Hotfix for Windows XP (KB906569)
Hotfix for Windows XP (KB908673)
Hotfix for Windows XP (KB909095)
Hotfix for Windows XP (KB914440)
Hotfix for Windows XP (KB915865)
Hotfix for Windows XP (KB921411)
Intel(R) Matrix Storage Manager
Intel(R) PRO Network Connections
Java(TM) 6 Update 13
Java(TM) 6 Update 3
LiveUpdate 3.0 (Symantec Corporation)
LiveUpdate Notice (Symantec Corporation)
Microsoft .NET Framework 1.1
Microsoft Office Basic 2007
Microsoft Office Live Meeting 2005
Microsoft Office Professional Edition 2003
Microsoft Plus! Digital Media Edition Installer
Microsoft Plus! Photo Story 2 LE
Microsoft Software Update for Web Folders (English) 12
Microsoft SQL Server 2005
Microsoft SQL Server 2005 Express Edition (ACT7)
Microsoft SQL Server Native Client
Microsoft SQL Server Setup Support Files (English)
Microsoft SQL Server VSS Writer
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
MSXML 6 Service Pack 2 (KB954459)
Pinnacle Instant DVD Recorder
QuickTime
RAPID (Studio 10)
SearchAssist
Security Update for Windows XP (KB893756)
Security Update for Windows XP (KB896358)
Security Update for Windows XP (KB896423)
Security Update for Windows XP (KB896424)
Security Update for Windows XP (KB896428)
Security Update for Windows XP (KB899587)
Security Update for Windows XP (KB899588)
Security Update for Windows XP (KB899591)
Security Update for Windows XP (KB900725)
Security Update for Windows XP (KB901017)
Security Update for Windows XP (KB901214)
Security Update for Windows XP (KB902400)
Security Update for Windows XP (KB904706)
Security Update for Windows XP (KB905414)
Security Update for Windows XP (KB905749)
Security Update for Windows XP (KB908519)
Security Update for Windows XP (KB908531)
Security Update for Windows XP (KB911562)
Security Update for Windows XP (KB911927)
Security Update for Windows XP (KB912919)
Security Update for Windows XP (KB913580)
Security Update for Windows XP (KB914388)
Security Update for Windows XP (KB914389)
Security Update for Windows XP (KB917344)
Security Update for Windows XP (KB917422)
Security Update for Windows XP (KB917953)
Security Update for Windows XP (KB918118)
Security Update for Windows XP (KB918439)
Security Update for Windows XP (KB919007)
Security Update for Windows XP (KB920213)
Security Update for Windows XP (KB920670)
Security Update for Windows XP (KB920683)
Security Update for Windows XP (KB920685)
Security Update for Windows XP (KB921503)
Security Update for Windows XP (KB922819)
Security Update for Windows XP (KB923191)
Security Update for Windows XP (KB923414)
Security Update for Windows XP (KB923694)
Security Update for Windows XP (KB923789)
Security Update for Windows XP (KB923980)
Security Update for Windows XP (KB924191)
Security Update for Windows XP (KB924270)
Security Update for Windows XP (KB924496)
Security Update for Windows XP (KB924667)
Security Update for Windows XP (KB925902)
Security Update for Windows XP (KB926255)
Security Update for Windows XP (KB926436)
Security Update for Windows XP (KB927779)
Security Update for Windows XP (KB927802)
Security Update for Windows XP (KB928090)
Security Update for Windows XP (KB928255)
Security Update for Windows XP (KB928843)
Security Update for Windows XP (KB929123)
Security Update for Windows XP (KB929969)
Security Update for Windows XP (KB930178)
Security Update for Windows XP (KB931261)
Security Update for Windows XP (KB931784)
Security Update for Windows XP (KB932168)
Security Update for Windows XP (KB933729)
Security Update for Windows XP (KB935839)
Security Update for Windows XP (KB935840)
Security Update for Windows XP (KB936021)
Security Update for Windows XP (KB937143)
Security Update for Windows XP (KB937894)
Security Update for Windows XP (KB938127)
Security Update for Windows XP (KB938829)
Security Update for Windows XP (KB939653)
Security Update for Windows XP (KB941202)
Security Update for Windows XP (KB941568)
Security Update for Windows XP (KB941644)
Security Update for Windows XP (KB941693)
Security Update for Windows XP (KB942615)
Security Update for Windows XP (KB943055)
Security Update for Windows XP (KB943460)
Security Update for Windows XP (KB943485)
Security Update for Windows XP (KB944338)
Security Update for Windows XP (KB944533)
Security Update for Windows XP (KB944653)
Security Update for Windows XP (KB945553)
Security Update for Windows XP (KB946026)
Security Update for Windows XP (KB947864)
Security Update for Windows XP (KB948590)
Security Update for Windows XP (KB948881)
Security Update for Windows XP (KB950749)
Security Update for Windows XP (KB950759)
Security Update for Windows XP (KB958215)
Security Update for Windows XP (KB958470)
Security Update for Windows XP (KB960714)
Security Update for Windows XP (KB963027)
Security Update for Windows XP (KB969897)
Security Update for Windows XP (KB971032)
SmartSound Quicktracks Plugin
Sonic Activation Module
Symantec KB-DocID:2003093015493306
Update for Windows XP (KB894391)
Update for Windows XP (KB900485)
Update for Windows XP (KB904942)
Update for Windows XP (KB910437)
Update for Windows XP (KB911280)
Update for Windows XP (KB912945)
Update for Windows XP (KB916595)
Update for Windows XP (KB920872)
Update for Windows XP (KB922582)
Update for Windows XP (KB925720)
Update for Windows XP (KB927891)
Update for Windows XP (KB930916)
Update for Windows XP (KB931836)
Update for Windows XP (KB932823-v3)
Update for Windows XP (KB933360)
Update for Windows XP (KB936357)
Update for Windows XP (KB938828)
Update for Windows XP (KB942763)
Update for Windows XP (KB942840)
Update for Windows XP (KB946627)
WebFldrs XP
Windows Imaging Component
Windows Media Format Runtime
Windows XP Hotfix - KB873339
Windows XP Hotfix - KB885250
Windows XP Hotfix - KB885835
Windows XP Hotfix - KB885836
Windows XP Hotfix - KB886185
Windows XP Hotfix - KB887472
Windows XP Hotfix - KB888302
Windows XP Hotfix - KB889673
Windows XP Hotfix - KB890859
Windows XP Hotfix - KB891781
Capntreee
OS : XP Pro SP2
Post by Capntreee on Mon Oct 26, 2009 4:27 pm
Perhaps I'm wrong but Combofix didn't seem to work completely. I now see the 'folder option' under the Tools drop down menu but I still got some random audio track start playing even as I'm typing this reply
Capntreee
OS : XP Pro SP2
Post by Capntreee on Mon Oct 26, 2009 4:29 pm
"How to invest in a bull market" advert started playing but no window opened ?!? Then it stopped. This is not making sense.
Capntreee
OS : XP Pro SP2
Post by Belahzur on Mon Oct 26, 2009 6:04 pm
  1. Close any open browsers.
    File::
    C:\ldvx.exe
    C:\qsdhs.exe
    C:\dtacmawh.exe
    Registry::
    [-HKEY_LOCAL_MACHINE\~\Browser Helper Objects\{9da0b9bf-558b-4255-941b-aebc45e8d263}]
    "Notification Packages"=hex(7):73,63,65,63,6c,69,00,00
    Driver::
    BtwSrv
    fastnetsrv
    NetSvc::
    BtwSrv
    File::
    C:\ldvx.exe
    C:\qsdhs.exe
    C:\dtacmawh.exe
    Registry::
    Driver::
    BtwSrv
    fastnetsrv
    NetSvc::
    BtwSrv
Post by Capntreee on Wed Oct 28, 2009 4:25 pm
This program will not permit Notepad to open. In a system tray dialog box it claims "Security Tool Warning" notepad.exe is infacted with worm lsas.blaster.keyloger ; this worm is trying to send your credit card details using notepad.exe to a remote host"
This in nonsense as this PC does not contain ANY credit card details. The Antivirus System Pro program has simply takenover Notepad so that I cannot follow your removal instructions. Help!
Capntreee
OS : XP Pro SP2
Post by Capntreee on Wed Oct 28, 2009 5:16 pm
Additionally the program has now also disabled System Restore; disabled the Command window; disabled Add/Remove Programs; disabled the Security center and removed all icons from the Desktop.
It provides a similar warning dialog box for each program claiming, in the 3rd person, that the program "lsas.blaster.keyloger" has infected all of them and now they cannot bne opened. Great...
Capntreee
OS : XP Pro SP2
Post by Belahzur on Wed Oct 28, 2009 9:25 pm
