Bankerfox.A and Antivirus Pro is trying to run my machine!
Post by headram on 23rd October 2009, 1:22 am
I think your aware of both of these after reading some other posts. Trying to type this in before it acts up again.
headram
Joined Joined : 2009-10-23
Points Points : 26053
Re: Bankerfox.A and Antivirus Pro is trying to run my machine!
Post by Dr Jay on 24th October 2009, 1:04 am
Posts Posts : 14309
Points Points : 302970
