Need help with Antivirus System PRO.
Post by COOLSTATIC05 on 22nd October 2009, 10:02 pm
I had this Antivirus System PRO 1 day and got It removed with the help from you guys then after a few days It got back again 2 times. I believe that It should not come back again when its removed. Are there any ways to stop that thing from coming back again? And/or is there like a thing that I have in my computer that makes it go back?
Thanks for reading.
COOLSTATIC05
Posts Posts : 6
Joined Joined : 2009-10-22
Points Points : 26058
Re: Need help with Antivirus System PRO.
Post by Dr Jay on 24th October 2009, 1:04 am
Posts Posts : 14309
Points Points : 302960
Post by COOLSTATIC05 on 24th October 2009, 9:42 pm
ComboFix Log:
ComboFix 09-10-23.01 - Pajela` 10/24/2009 14:26.1.4 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.2.1252.1.1033.18.3327.2931 [GMT -7:00]
Running from: c:\documents and settings\Pajela`\desktop\commy.exe
AV: BitDefender Antivirus *On-access scanning disabled* (Updated) {6C4BB89C-B0ED-4F41-A29C-4373888923BB}
AV: ESET NOD32 Antivirus 4.0 *On-access scanning disabled* (Updated) {E5E70D32-0101-4F12-8FB0-D96ACA4F34C0}
FW: BitDefender Firewall *disabled* {4055920F-2E99-48A8-A270-4243D2B8F242}
* Resident AV is active
c:\docume~1\Pajela`\LOCALS~1\Temp\1.wmv
c:\windows\system32\2084596025.dat
c:\windows\system32\proquota.exe . . . is missing!!
-------\Legacy_PROTECTEDSTORAGEODSERV
-------\Service_ProtectedStorageodserv
((((((((((((((((((((((((( Files Created from 2009-09-24 to 2009-10-24 )))))))))))))))))))))))))))))))
2009-10-22 02:12 . 2009-10-22 02:37 -------- d-----w- c:\program files\tvsxua
2009-10-18 20:46 . 2009-10-18 21:06 -------- d-----w- c:\program files\jimpft
2009-10-18 20:31 . 2009-10-18 21:06 -------- d-----w- c:\documents and settings\All Users\Application Data\NOS
2009-10-17 19:55 . 2009-10-17 19:55 -------- d-----w- c:\documents and settings\LocalService\Local Settings\Application Data\ESET
2009-10-15 23:04 . 2009-09-10 21:54 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-10-15 23:04 . 2009-10-15 23:04 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2009-10-15 23:04 . 2009-09-10 21:53 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-10-15 23:04 . 2009-10-15 23:04 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-10-15 21:35 . 2009-10-15 23:18 -------- d-----w- c:\program files\fbeuko
2009-10-03 00:35 . 2009-10-03 00:35 159580 ----a-w- c:\windows\Marsu-Fix 2.5 Uninstaller.exe
2009-10-03 00:20 . 2009-10-03 00:20 -------- d-----w- c:\documents and settings\All Users\Application Data\ESET
2009-10-02 22:34 . 2009-10-02 23:14 -------- d-----w- c:\program files\ESET
2009-09-26 01:52 . 2009-09-26 01:52 -------- d-----w- c:\program files\Ventrilo
2009-10-02 23:13 . 2009-02-06 21:31 -------- d-----w- c:\program files\Common Files\Wise Installation Wizard
2009-10-02 23:13 . 2009-02-06 21:31 -------- d-----w- c:\program files\SUPERAntiSpyware
"StartCCC"="c:\program files\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" [2008-01-21 61440]
"Acrobat Assistant 8.0"="c:\program files\Adobe\Acrobat 8.0\Acrobat\Acrotray.exe" [2007-05-11 624248]
"SysTrayApp"="c:\program files\IDT\WDM\sttray.exe" [2007-12-14 413696]
"GrooveMonitor"="c:\program files\Microsoft Office\Office12\GrooveMonitor.exe" [2006-10-27 31016]
"egui"="c:\program files\ESET\ESET NOD32 Antivirus\egui.exe" [2009-02-06 2021400]
"RunNarrator"="Narrator.exe" - c:\windows\system32\narrator.exe [2004-08-04 53760]
"EnableFirewall"= 0 (0x0)
"c:\\Program Files\\Common Files\\Adobe\\Adobe Version Cue CS3\\Server\\bin\\VersionCueCS3.exe"=
"c:\\Program Files\\uTorrent\\uTorrent.exe"=
"c:\\Program Files\\Microsoft Office\\Office12\\GROOVE.EXE"=
"c:\\Program Files\\Intuit\\QuickBooks 2007\\QBDBMgrN.exe"=
"c:\\Program Files\\Garena\\Garena.exe"=
"c:\\Counter-Strike Source\\hl2.exe"=
"c:\\Program Files\\Ventrilo\\Ventrilo.exe"=
"3703:TCP"= 3703:TCP:Adobe Version Cue CS3 Server
"3704:TCP"= 3704:TCP:Adobe Version Cue CS3 Server
"50900:TCP"= 50900:TCP:Adobe Version Cue CS3 Server
"50901:TCP"= 50901:TCP:Adobe Version Cue CS3 Server
"53:TCP"= 53:TCP:websrvx
R1 ehdrv;ehdrv;c:\windows\system32\drivers\ehdrv.sys [2/6/2009 2:23 PM 106208]
R1 epfwtdir;epfwtdir;c:\windows\system32\drivers\epfwtdir.sys [2/6/2009 2:24 PM 93336]
R2 ekrn;ESET Service;c:\program files\ESET\ESET NOD32 Antivirus\ekrn.exe [2/6/2009 2:23 PM 727720]
R3 tap0801;TAP-Win32 Adapter V8;c:\windows\system32\drivers\tap0801.sys [9/30/2006 11:37 PM 26624]
R3 TNET1130;802.11 WLAN;c:\windows\system32\drivers\TNET1130.sys [5/17/2009 12:23 PM 386688]
S2 BDVEDISK;BDVEDISK;\??\c:\program files\BitDefender\BitDefender 2009\BDVEDISK.sys --> c:\program files\BitDefender\BitDefender 2009\BDVEDISK.sys [?]
S3 cpuz131;cpuz131;\??\c:\docume~1\ZOUND_~1\LOCALS~1\Temp\cpuz131\cpuz_x32.sys --> c:\docume~1\ZOUND_~1\LOCALS~1\Temp\cpuz131\cpuz_x32.sys [?]
S3 GarenaPEngine;GarenaPEngine;\??\c:\docume~1\Pajela`\LOCALS~1\Temp\KSU1E.tmp --> c:\docume~1\Pajela`\LOCALS~1\Temp\KSU1E.tmp [?]
IE: Append to existing PDF - c:\program files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
IE: Convert link target to Adobe PDF - c:\program files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
IE: Convert link target to existing PDF - c:\program files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
IE: Convert selected links to Adobe PDF - c:\program files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
IE: Convert selected links to existing PDF - c:\program files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
IE: Convert selection to Adobe PDF - c:\program files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
IE: Convert selection to existing PDF - c:\program files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
IE: Convert to Adobe PDF - c:\program files\Adobe\Acrobat 8.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
FF - ProfilePath -
Rootkit scan 2009-10-24 14:35
scanning hȋdden processes ...
scanning hȋdden files ...
hȋdden files: 0
[HKEY_LOCAL_MACHINE\System\ControlSet002\Services\GarenaPEngine]
"ImagePath"="\??\c:\docume~1\Pajela`\LOCALS~1\Temp\KSU1E.tmp"
[HKEY_USERS\S-1-5-21-343818398-573735546-839522115-1007\Software\Trolltech\OrganizationDefaults\Qt Factory Cache 4.3\com.trolltech.Qt.QImageIOHandlerFactoryInterface:\c:\Documents and Settings\Pajela`\My Documents\ * * \ *J*A*C*O*B* * \ *S*T*U*F*F* * \GSC\plugins\imageformats]
"qgif4.dll"=multi:"2007-12-04T14:47\00gif\00\00"
"qjpeg4.dll"=multi:"2007-12-04T14:47\00jpeg\00jpg\00\00"
"qmng4.dll"=multi:"2007-12-04T14:48\00mng\00\00"
"qsvg4.dll"=multi:"2007-12-04T14:48\00svg\00\00"
"qtiff4.dll"=multi:"2007-12-04T14:48\00tiff\00tif\00\00"
[HKEY_USERS\S-1-5-21-343818398-573735546-839522115-1007\Software\Trolltech\OrganizationDefaults\Qt Plugin Cache 4.3.false\c:\documents and settings\Pajela`\My Documents\ * * \ *J*A*C*O*B* * \ *S*T*U*F*F* * \GSC\plugins\imageformats]
"qgif4.dll"=multi:"40303\000\00Windows msvc release full-config\002007-12-04T14:47\00\00"
"qjpeg4.dll"=multi:"40303\000\00Windows msvc release full-config\002007-12-04T14:47\00\00"
"qmng4.dll"=multi:"40303\000\00Windows msvc release full-config\002007-12-04T14:48\00\00"
"qsvg4.dll"=multi:"40303\000\00Windows msvc release full-config\002007-12-04T14:48\00\00"
"qtiff4.dll"=multi:"40303\000\00Windows msvc release full-config\002007-12-04T14:48\00\00"
- - - - - - - > 'winlogon.exe'(1028)
- - - - - - - > 'explorer.exe'(5748)
c:\progra~1\WINDOW~2\wmpband.dll
c:\commy\CF22467.exe
c:\program files\ATI Technologies\ATI.ACE\Core-Static\MOM.exe
c:\program files\Common Files\Intuit\QuickBooks\QBCFMonitorService.exe
c:\program files\idt\ecsxpv_5762_010208\wdm\STacSV.exe
c:\program files\ATI Technologies\ATI.ACE\Core-Static\ccc.exe
c:\program files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
c:\commy\PEV.cfxxe
Completion time: 2009-10-24 14:38 - machine was rebooted
ComboFix-quarantined-files.txt 2009-10-24 21:38
Pre-Run: 373,195,481,088 bytes free
Post-Run: 379,015,020,544 bytes free
- - End Of File - - 1CC5EFAB84F08ABA55B4B7E70BD957FE
COOLSTATIC05
Posts Posts : 6
Add-Remove Programs:
Add or Remove Adobe Creative Suite 3 Master Collection
Adobe Acrobat 8 Professional
Adobe After Effects CS3
Adobe After Effects CS3 Presets
Adobe Anchor Service CS3
Adobe Asset Services CS3
Adobe Bridge CS3
Adobe Bridge Start Meeting
Adobe BridgeTalk Plugin CS3
Adobe Camera Raw 4.0
Adobe CMaps
Adobe Color - Photoshop Specific
Adobe Color Common Settings
Adobe Color EU Extra Settings
Adobe Color JA Extra Settings
Adobe Color NA Recommended Settings
Adobe Contribute CS3
Adobe Default Language CS3
Adobe Device Central CS3
Adobe Dreamweaver CS3
Adobe Encore CS3
Adobe Encore CS3 Codecs
Adobe ExtendScript Toolkit 2
Adobe Extension Manager CS3
Adobe Fireworks CS3
Adobe Flash CS3
Adobe Flash Player 10 ActiveX
Adobe Flash Player 10 Plugin
Adobe Flash Video Encoder
Adobe Fonts All
Adobe Help Viewer CS3
Adobe Illustrator CS3
Adobe InDesign CS3
Adobe InDesign CS3 Icon Handler
Adobe Linguistics CS3
Adobe MotionPicture Color Files
Adobe PDF Library Files
Adobe Photoshop CS3
Adobe Premiere Pro CS3
Adobe Premiere Pro CS3 Functional Content
Adobe Premiere Pro CS3 Third Party Content
Adobe Setup
Adobe SING CS3
Adobe Soundbooth CS3
Adobe Soundbooth CS3 Codecs
Adobe Stock Photos CS3
Adobe Type Support
Adobe Update Manager CS3
Adobe Version Cue CS3 Client
Adobe Video Profiles
Adobe WAS CS3
Adobe WinSoft Linguistics Plugin
Adobe XMP DVA Panels CS3
Adobe XMP Panels CS3
AHV content for Acrobat and Flash
ATI - Software Uninstall Utility
ATI AVIVO Codecs
ATI Catalyst Control Center
ATI Display Driver
ATI Parental Control & Encoder
Catalyst Control Center Core Implementation
Catalyst Control Center Graphics Full Existing
Catalyst Control Center Graphics Full New
Catalyst Control Center Graphics Light
Catalyst Control Center Graphics Previews Common
ccc-core-preinstall
ccc-core-static
ccc-utility
CCC Help English
Command & Conquer
Counter-Strike Source 1.19
EasyWorship
ESET Online Scanner v3
Garena
High Definition Audio Driver Package - KB888111
Hotfix for Windows XP (KB926239)
IDT Audio
Magic ISO Maker v5.4 (build 0255)
Marsu-Fix 2.5
Microsoft .NET Framework 1.1
Microsoft .NET Framework 2.0
Microsoft .NET Framework 3.0
Microsoft Office Access MUI (English) 2007
Microsoft Office Access Setup Metadata MUI (English) 2007
Microsoft Office Enterprise 2007
Microsoft Office Groove MUI (English) 2007
Microsoft Office Groove Setup Metadata MUI (English) 2007
Microsoft Office InfoPath MUI (English) 2007
Microsoft Office OneNote MUI (English) 2007
Microsoft Office Publisher MUI (English) 2007
Microsoft Software Update for Web Folders (English) 12
Microsoft SQL Server Native Client
Microsoft SQL Server Setup Support Files (English)
Mozilla Firefox (3.0.14)
MSXML 4.0 SP2 Parser and SDK
MSXML 6.0 Parser (KB925673)
OpenVPN 2.0.9
PDF Settings
QuickBooks Premier: Nonprofit Edition 2007
QuickBooks Product Listing Service
Skins
Sony Vegas Pro 8.0
SupportSoft Assisted Service
SWiSH Max2
Ventrilo Client
WebFldrs XP
Windows Communication Foundation
Windows Imaging Component
Windows Media Player 11
Windows Presentation Foundation
Windows Workflow Foundation
WinRAR archiver
XML Paper Specification Shared Components Pack 1.0
Yahoo! BrowserPlus
Yahoo! Messenger
COOLSTATIC05
Posts Posts : 6
Post by Dr Jay on 24th October 2009, 9:53 pm
  1. Close any open browsers.
    Folder::
    c:\Program Files\Garena
    Rootkit::
    Driver::
    GarenaPEngine
    File::
Posts Posts : 14309
Post by COOLSTATIC05 on 27th October 2009, 10:43 pm
ComboFix 09-10-26.06 - Pajela` 10/27/2009 15:29.2.4 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.2.1252.1.1033.18.3327.2934 [GMT -8:00]
Running from: c:\documents and settings\Pajela`\Desktop\commy.exe
Command switches used :: c:\documents and settings\Pajela`\Desktop\CFScript.txt
FILE ::
"c:\docume~1\Pajela`\LOCALS~1\Temp\KSU1E.tmp"
c:\program files\Garena
c:\program files\Garena\AESocket.dll
c:\program files\Garena\atl71.dll
c:\program files\Garena\Avatar\boy.swf
c:\program files\Garena\Avatar\boy_s.swf
c:\program files\Garena\Avatar\girl.swf
c:\program files\Garena\Avatar\girl_s.swf
c:\program files\Garena\Avatar\unknown.swf
c:\program files\Garena\Avatar\unknown_s.swf
c:\program files\Garena\clients.dat
c:\program files\Garena\CommonLib.dll
c:\program files\Garena\config\bs.br.xml
c:\program files\Garena\config\bs.cn.xml
c:\program files\Garena\config\bs.en.xml
c:\program files\Garena\config\bs.id.xml
c:\program files\Garena\config\bs.pp.xml
c:\program files\Garena\config\bs.ru.xml
c:\program files\Garena\config\bs.sd.xml
c:\program files\Garena\config\bs.sp.xml
c:\program files\Garena\config\bs.th.xml
c:\program files\Garena\config\bs.tw.xml
c:\program files\Garena\config\bs.vn.xml
c:\program files\Garena\config\loccn.xml
c:\program files\Garena\config\locen.xml
c:\program files\Garena\config\lockr.xml
c:\program files\Garena\config\loctw.xml
c:\program files\Garena\CS15Hook.dll
c:\program files\Garena\deps\vww.gzp
c:\program files\Garena\dlls\CTSys.dll
c:\program files\Garena\dlls\flags.dll
c:\program files\Garena\dlls\FPSHelper.dll
c:\program files\Garena\dlls\GFireMan.dll
c:\program files\Garena\dlls\IPvR.dll
c:\program files\Garena\dlls\PEngine.dll
c:\program files\Garena\dlls\PluginLanguage.dll
c:\program files\Garena\dlls\WC3J.dll
c:\program files\Garena\face\1.bmp
c:\program files\Garena\face\1_m.bmp
c:\program files\Garena\face\10.bmp
c:\program files\Garena\face\10_m.bmp
c:\program files\Garena\face\11.bmp
c:\program files\Garena\face\11_m.bmp
c:\program files\Garena\face\12.bmp
c:\program files\Garena\face\12_m.bmp
c:\program files\Garena\face\13.bmp
c:\program files\Garena\face\13_m.bmp
c:\program files\Garena\face\14.bmp
c:\program files\Garena\face\14_m.bmp
c:\program files\Garena\face\15.bmp
c:\program files\Garena\face\15_m.bmp
c:\program files\Garena\face\16.bmp
c:\program files\Garena\face\16_m.bmp
c:\program files\Garena\face\17.bmp
c:\program files\Garena\face\17_m.bmp
c:\program files\Garena\face\18.bmp
c:\program files\Garena\face\18_m.bmp
c:\program files\Garena\face\19.bmp
c:\program files\Garena\face\19_m.bmp
c:\program files\Garena\face\2.bmp
c:\program files\Garena\face\2_m.bmp
c:\program files\Garena\face\20.bmp
c:\program files\Garena\face\20_m.bmp
c:\program files\Garena\face\21.bmp
c:\program files\Garena\face\21_m.bmp
c:\program files\Garena\face\22.bmp
c:\program files\Garena\face\22_m.bmp
c:\program files\Garena\face\23.bmp
c:\program files\Garena\face\23_m.bmp
c:\program files\Garena\face\24.bmp
c:\program files\Garena\face\24_m.bmp
c:\program files\Garena\face\3.bmp
c:\program files\Garena\face\3_m.bmp
c:\program files\Garena\face\4.bmp
c:\program files\Garena\face\4_m.bmp
c:\program files\Garena\face\5.bmp
c:\program files\Garena\face\5_m.bmp
c:\program files\Garena\face\6.bmp
c:\program files\Garena\face\6_m.bmp
c:\program files\Garena\face\7.bmp
c:\program files\Garena\face\7_m.bmp
c:\program files\Garena\face\8.bmp
c:\program files\Garena\face\8_m.bmp
c:\program files\Garena\face\9.bmp
c:\program files\Garena\face\9_m.bmp
c:\program files\Garena\files\files.ggz
c:\program files\Garena\FPSHook.dll
c:\program files\Garena\Gamecn.dat
c:\program files\Garena\GameConfig.xml
c:\program files\Garena\Gameen.dat
c:\program files\Garena\Gametw.dat
c:\program files\Garena\Garena.exe
c:\program files\Garena\GarenaSkin.dll
c:\program files\Garena\GarenaSkin1.dll
c:\program files\Garena\GarenaTV.xml
c:\program files\Garena\GarenaTV\0.bmp
c:\program files\Garena\GarenaTV\1.bmp
c:\program files\Garena\GarenaTV\2.bmp
c:\program files\Garena\GarenaTV\3.bmp
c:\program files\Garena\GarenaTV\4.bmp
c:\program files\Garena\GarenaTV\5.bmp
c:\program files\Garena\GarenaTV\6.bmp
c:\program files\Garena\GarenaTV\cn.ggz
c:\program files\Garena\GarenaTV\cn_s.ggz
c:\program files\Garena\GarenaTV\en.ggz
c:\program files\Garena\GarenaTV\en_s.ggz
c:\program files\Garena\GarenaTV\id_s.ggz
c:\program files\Garena\GarenaTV\tw.ggz
c:\program files\Garena\GarenaTV\tw_s.ggz
c:\program files\Garena\GarenaTV_UI.dll
c:\program files\Garena\GarenaTVHook.dll
c:\program files\Garena\GGICON.ico
c:\program files\Garena\Gn.ggz
c:\program files\Garena\gs.dat
c:\program files\Garena\hc.xml
c:\program files\Garena\Inject.dll
c:\program files\Garena\L4DSocket.dll
c:\program files\Garena\langs.xml
c:\program files\Garena\Languages\FPSGame.dll.cn
c:\program files\Garena\Languages\FPSGame.dll.en
c:\program files\Garena\Languages\FPSGame.dll.tw
c:\program files\Garena\Languages\Garena.exe.br
c:\program files\Garena\Languages\Garena.exe.cn
c:\program files\Garena\Languages\Garena.exe.en
c:\program files\Garena\Languages\Garena.exe.id
c:\program files\Garena\Languages\Garena.exe.ru
c:\program files\Garena\Languages\Garena.exe.sp
c:\program files\Garena\Languages\Garena.exe.th
c:\program files\Garena\Languages\Garena.exe.tw
c:\program files\Garena\Languages\Garena.exe.vn
c:\program files\Garena\Languages\GarenaTV_UI.dll.cn
c:\program files\Garena\Languages\GarenaTV_UI.dll.en
c:\program files\Garena\Languages\GarenaTV_UI.dll.id
c:\program files\Garena\Languages\GarenaTV_UI.dll.tw
c:\program files\Garena\Languages\languages.glf
c:\program files\Garena\Languages\update.exe.cn
c:\program files\Garena\Languages\update.exe.tw
c:\program files\Garena\Languages\update2.exe.cn
c:\program files\Garena\Languages\update2.exe.tw
c:\program files\Garena\Languages\WC3Ass.dll.cn
c:\program files\Garena\Languages\WC3Ass.dll.en
c:\program files\Garena\Languages\WC3Ass.dll.tw
c:\program files\Garena\Languages\WC3Ass.dll.vn
c:\program files\Garena\Languages\WC3Ladder.dll.cn
c:\program files\Garena\Languages\WC3Ladder.dll.en
c:\program files\Garena\Languages\WC3Ladder.dll.tw
c:\program files\Garena\layout\BlackShotView.layout
c:\program files\Garena\layout\layout.ggz
c:\program files\Garena\lib\common\Language.dll
c:\program files\Garena\lib\GarenaRoomSystem.dll
c:\program files\Garena\lib\GarenaWebService.dll
c:\program files\Garena\lib\HttpLayer.dll
c:\program files\Garena\lib\Language.dll
c:\program files\Garena\lib\Layout.dll
c:\program files\Garena\lib\LibPlugin.ggz
c:\program files\Garena\lib\LoadSwf.dll
c:\program files\Garena\lib\MessagePumpLib.dll
c:\program files\Garena\lib\NetworkLayer.dll
c:\program files\Garena\lib\PKCS.dll
c:\program files\Garena\lib\WebCache.dll
c:\program files\Garena\mdata.ggz
c:\program files\Garena\PluginKernel.dll
c:\program files\Garena\plugins\Game\GarenaTVRecorder.dll
c:\program files\Garena\plugins\Game\WC3Ass.dll
c:\program files\Garena\plugins\Game\WC3Ladder.dll
c:\program files\Garena\plugins\Game\WC3VC.dll
c:\program files\Garena\plugins\Plugins.ggz
c:\program files\Garena\plugins\UI\AvoidCrackPlugin.dll
c:\program files\Garena\plugins\UI\BlackShotPlugin.dll
c:\program files\Garena\plugins\UI\CafeLogin.dll
c:\program files\Garena\plugins\UI\Chenyx.dll
c:\program files\Garena\plugins\UI\FavListUIPlugin.dll
c:\program files\Garena\plugins\UI\FPSGame.dll
c:\program files\Garena\plugins\UI\GarenaTV.dll
c:\program files\Garena\plugins\UI\GarenaTVRecUI.dll
c:\program files\Garena\plugins\UI\GEngine.dll
c:\program files\Garena\plugins\UI\ManagePlugin.dll
c:\program files\Garena\plugins\UI\StatPlugin.dll
c:\program files\Garena\plugins\UI\ViwawaPlugin.dll
c:\program files\Garena\plugins\UI\zDep.dll
c:\program files\Garena\plugins\UI\zzzPlugin.dll
c:\program files\Garena\RecConfig.xml
c:\program files\Garena\roomCN.dat
c:\program files\Garena\roomEN.dat
c:\program files\Garena\roomTW.dat
c:\program files\Garena\server.xml
c:\program files\Garena\shop\items\1.gif
c:\program files\Garena\shop\items\100.gif
c:\program files\Garena\shop\items\105.gif
c:\program files\Garena\shop\items\150.gif
c:\program files\Garena\shop\items\2.gif
c:\program files\Garena\shop\items\200.gif
c:\program files\Garena\shop\items\201.gif
c:\program files\Garena\shop\items\202.gif
c:\program files\Garena\shop\items\203.gif
c:\program files\Garena\shop\items\204.gif
c:\program files\Garena\shop\items\205.gif
c:\program files\Garena\shop\items\206.gif
c:\program files\Garena\shop\items\21.gif
c:\program files\Garena\shop\items\22.gif
c:\program files\Garena\shop\items\23.gif
c:\program files\Garena\shop\items\3.gif
c:\program files\Garena\shop\items\300.gif
c:\program files\Garena\shop\items\301.gif
c:\program files\Garena\shop\items\302.gif
c:\program files\Garena\shop\items\303.gif
c:\program files\Garena\shop\items\304.gif
c:\program files\Garena\shop\items\305.gif
c:\program files\Garena\shop\items\306.gif
c:\program files\Garena\shop\items\307.gif
c:\program files\Garena\shop\items\308.gif
c:\program files\Garena\shop\items\309.gif
c:\program files\Garena\shop\items\310.gif
c:\program files\Garena\shop\items\311.gif
c:\program files\Garena\shop\items\312.gif
c:\program files\Garena\shop\items\313.gif
c:\program files\Garena\shop\items\4.gif
c:\program files\Garena\shop\items\40.gif
c:\program files\Garena\shop\items\60.gif
c:\program files\Garena\shop\items\61.gif
c:\program files\Garena\shop\items\62.gif
c:\program files\Garena\shop\items\63.gif
c:\program files\Garena\shop\items\64.gif
c:\program files\Garena\shop\items\65.gif
c:\program files\Garena\shop\items\66.gif
c:\program files\Garena\Skin\Flags\-.gif
c:\program files\Garena\Skin\Flags\ad.gif
c:\program files\Garena\Skin\Flags\ae.gif
c:\program files\Garena\Skin\Flags\af.gif
c:\program files\Garena\Skin\Flags\ag.gif
c:\program files\Garena\Skin\Flags\ai.gif
c:\program files\Garena\Skin\Flags\al.gif
c:\program files\Garena\Skin\Flags\am.gif
c:\program files\Garena\Skin\Flags\an.gif
c:\program files\Garena\Skin\Flags\ao.gif
c:\program files\Garena\Skin\Flags\aq.gif
c:\program files\Garena\Skin\Flags\ar.gif
c:\program files\Garena\Skin\Flags\as.gif
c:\program files\Garena\Skin\Flags\at.gif
c:\program files\Garena\Skin\Flags\au.gif
c:\program files\Garena\Skin\Flags\aw.gif
c:\program files\Garena\Skin\Flags\az.gif
c:\program files\Garena\Skin\Flags\ba.gif
c:\program files\Garena\Skin\Flags\bb.gif
c:\program files\Garena\Skin\Flags\bd.gif
c:\program files\Garena\Skin\Flags\be.gif
c:\program files\Garena\Skin\Flags\bf.gif
c:\program files\Garena\Skin\Flags\bg.gif
c:\program files\Garena\Skin\Flags\bh.gif
c:\program files\Garena\Skin\Flags\bi.gif
c:\program files\Garena\Skin\Flags\bj.gif
c:\program files\Garena\Skin\Flags\bm.gif
c:\program files\Garena\Skin\Flags\bn.gif
c:\program files\Garena\Skin\Flags\bo.gif
c:\program files\Garena\Skin\Flags\br.gif
c:\program files\Garena\Skin\Flags\bs.gif
c:\program files\Garena\Skin\Flags\bt.gif
c:\program files\Garena\Skin\Flags\bv.gif
c:\program files\Garena\Skin\Flags\bw.gif
c:\program files\Garena\Skin\Flags\by.gif
c:\program files\Garena\Skin\Flags\bz.gif
c:\program files\Garena\Skin\Flags\ca.gif
c:\program files\Garena\Skin\Flags\cd.gif
c:\program files\Garena\Skin\Flags\cf.gif
c:\program files\Garena\Skin\Flags\cg.gif
c:\program files\Garena\Skin\Flags\ch.gif
c:\program files\Garena\Skin\Flags\ci.gif
c:\program files\Garena\Skin\Flags\ck.gif
c:\program files\Garena\Skin\Flags\cl.gif
c:\program files\Garena\Skin\Flags\cm.gif
c:\program files\Garena\Skin\Flags\cn.gif
c:\program files\Garena\Skin\Flags\co.gif
c:\program files\Garena\Skin\Flags\cr.gif
c:\program files\Garena\Skin\Flags\cu.gif
c:\program files\Garena\Skin\Flags\cv.gif
c:\program files\Garena\Skin\Flags\cy.gif
c:\program files\Garena\Skin\Flags\cz.gif
c:\program files\Garena\Skin\Flags\de.gif
c:\program files\Garena\Skin\Flags\dj.gif
c:\program files\Garena\Skin\Flags\dk.gif
c:\program files\Garena\Skin\Flags\dm.gif
c:\program files\Garena\Skin\Flags\do.gif
c:\program files\Garena\Skin\Flags\dz.gif
c:\program files\Garena\Skin\Flags\ec.gif
c:\program files\Garena\Skin\Flags\ee.gif
c:\program files\Garena\Skin\Flags\eg.gif
c:\program files\Garena\Skin\Flags\er.gif
c:\program files\Garena\Skin\Flags\es.gif
c:\program files\Garena\Skin\Flags\et.gif
c:\program files\Garena\Skin\Flags\eu.gif
c:\program files\Garena\Skin\Flags\fi.gif
c:\program files\Garena\Skin\Flags\fj.gif
c:\program files\Garena\Skin\Flags\fk.gif
c:\program files\Garena\Skin\Flags\fm.gif
c:\program files\Garena\Skin\Flags\fo.gif
c:\program files\Garena\Skin\Flags\fr.gif
c:\program files\Garena\Skin\Flags\fx.gif
c:\program files\Garena\Skin\Flags\ga.gif
c:\program files\Garena\Skin\Flags\gb.gif
c:\program files\Garena\Skin\Flags\gd.gif
c:\program files\Garena\Skin\Flags\ge.gif
c:\program files\Garena\Skin\Flags\gh.gif
c:\program files\Garena\Skin\Flags\gi.gif
c:\program files\Garena\Skin\Flags\gl.gif
c:\program files\Garena\Skin\Flags\gm.gif
c:\program files\Garena\Skin\Flags\gn.gif
c:\program files\Garena\Skin\Flags\gp.gif
c:\program files\Garena\Skin\Flags\gq.gif
c:\program files\Garena\Skin\Flags\gr.gif
c:\program files\Garena\Skin\Flags\gt.gif
c:\program files\Garena\Skin\Flags\gu.gif
c:\program files\Garena\Skin\Flags\gw.gif
c:\program files\Garena\Skin\Flags\gy.gif
c:\program files\Garena\Skin\Flags\hk.gif
c:\program files\Garena\Skin\Flags\hm.gif
c:\program files\Garena\Skin\Flags\hn.gif
c:\program files\Garena\Skin\Flags\hr.gif
c:\program files\Garena\Skin\Flags\ht.gif
c:\program files\Garena\Skin\Flags\hu.gif
c:\program files\Garena\Skin\Flags\id.gif
c:\program files\Garena\Skin\Flags\ie.gif
c:\program files\Garena\Skin\Flags\il.gif
c:\program files\Garena\Skin\Flags\im.gif
c:\program files\Garena\Skin\Flags\in.gif
c:\program files\Garena\Skin\Flags\io.gif
c:\program files\Garena\Skin\Flags\iq.gif
c:\program files\Garena\Skin\Flags\ir.gif
c:\program files\Garena\Skin\Flags\is.gif
c:\program files\Garena\Skin\Flags\it.gif
c:\program files\Garena\Skin\Flags\je.gif
c:\program files\Garena\Skin\Flags\jm.gif
c:\program files\Garena\Skin\Flags\jo.gif
c:\program files\Garena\Skin\Flags\jp.gif
c:\program files\Garena\Skin\Flags\ke.gif
c:\program files\Garena\Skin\Flags\kg.gif
c:\program files\Garena\Skin\Flags\kh.gif
c:\program files\Garena\Skin\Flags\ki.gif
c:\program files\Garena\Skin\Flags\km.gif
c:\program files\Garena\Skin\Flags\kn.gif
c:\program files\Garena\Skin\Flags\kp.gif
c:\program files\Garena\Skin\Flags\kr.gif
c:\program files\Garena\Skin\Flags\kw.gif
c:\program files\Garena\Skin\Flags\ky.gif
c:\program files\Garena\Skin\Flags\kz.gif
c:\program files\Garena\Skin\Flags\la.gif
c:\program files\Garena\Skin\Flags\lb.gif
c:\program files\Garena\Skin\Flags\lc.gif
c:\program files\Garena\Skin\Flags\li.gif
c:\program files\Garena\Skin\Flags\lk.gif
c:\program files\Garena\Skin\Flags\lr.gif
c:\program files\Garena\Skin\Flags\ls.gif
c:\program files\Garena\Skin\Flags\lt.gif
c:\program files\Garena\Skin\Flags\lu.gif
c:\program files\Garena\Skin\Flags\lv.gif
c:\program files\Garena\Skin\Flags\ly.gif
c:\program files\Garena\Skin\Flags\ma.gif
c:\program files\Garena\Skin\Flags\mc.gif
c:\program files\Garena\Skin\Flags\md.gif
c:\program files\Garena\Skin\Flags\me.gif
c:\program files\Garena\Skin\Flags\mg.gif
c:\program files\Garena\Skin\Flags\mh.gif
c:\program files\Garena\Skin\Flags\mk.gif
c:\program files\Garena\Skin\Flags\ml.gif
c:\program files\Garena\Skin\Flags\mm.gif
c:\program files\Garena\Skin\Flags\mn.gif
c:\program files\Garena\Skin\Flags\mo.gif
c:\program files\Garena\Skin\Flags\mp.gif
c:\program files\Garena\Skin\Flags\mq.gif
c:\program files\Garena\Skin\Flags\mr.gif
c:\program files\Garena\Skin\Flags\ms.gif
c:\program files\Garena\Skin\Flags\mt.gif
c:\program files\Garena\Skin\Flags\mu.gif
c:\program files\Garena\Skin\Flags\mv.gif
c:\program files\Garena\Skin\Flags\mw.gif
c:\program files\Garena\Skin\Flags\mx.gif
c:\program files\Garena\Skin\Flags\my.gif
c:\program files\Garena\Skin\Flags\mz.gif
c:\program files\Garena\Skin\Flags\na.gif
c:\program files\Garena\Skin\Flags\nc.gif
c:\program files\Garena\Skin\Flags\ne.gif
c:\program files\Garena\Skin\Flags\nf.gif
c:\program files\Garena\Skin\Flags\ng.gif
c:\program files\Garena\Skin\Flags\ni.gif
c:\program files\Garena\Skin\Flags\nl.gif
c:\program files\Garena\Skin\Flags\no.gif
c:\program files\Garena\Skin\Flags\np.gif
c:\program files\Garena\Skin\Flags\nr.gif
c:\program files\Garena\Skin\Flags\nz.gif
c:\program files\Garena\Skin\Flags\om.gif
c:\program files\Garena\Skin\Flags\pa.gif
c:\program files\Garena\Skin\Flags\pe.gif
c:\program files\Garena\Skin\Flags\pf.gif
c:\program files\Garena\Skin\Flags\pg.gif
c:\program files\Garena\Skin\Flags\ph.gif
c:\program files\Garena\Skin\Flags\pk.gif
c:\program files\Garena\Skin\Flags\pl.gif
c:\program files\Garena\Skin\Flags\pm.gif
c:\program files\Garena\Skin\Flags\pr.gif
c:\program files\Garena\Skin\Flags\ps.gif
c:\program files\Garena\Skin\Flags\pt.gif
c:\program files\Garena\Skin\Flags\pw.gif
c:\program files\Garena\Skin\Flags\py.gif
c:\program files\Garena\Skin\Flags\qa.gif
c:\program files\Garena\Skin\Flags\re.gif
c:\program files\Garena\Skin\Flags\ro.gif
c:\program files\Garena\Skin\Flags\rs.gif
c:\program files\Garena\Skin\Flags\ru.gif
c:\program files\Garena\Skin\Flags\rw.gif
c:\program files\Garena\Skin\Flags\sa.gif
c:\program files\Garena\Skin\Flags\sb.gif
c:\program files\Garena\Skin\Flags\sc.gif
c:\program files\Garena\Skin\Flags\sd.gif
c:\program files\Garena\Skin\Flags\se.gif
c:\program files\Garena\Skin\Flags\sg.gif
c:\program files\Garena\Skin\Flags\si.gif
c:\program files\Garena\Skin\Flags\sk.gif
c:\program files\Garena\Skin\Flags\sl.gif
c:\program files\Garena\Skin\Flags\sm.gif
c:\program files\Garena\Skin\Flags\sn.gif
c:\program files\Garena\Skin\Flags\so.gif
c:\program files\Garena\Skin\Flags\sr.gif
c:\program files\Garena\Skin\Flags\st.gif
c:\program files\Garena\Skin\Flags\sv.gif
c:\program files\Garena\Skin\Flags\sy.gif
c:\program files\Garena\Skin\Flags\sz.gif
c:\program files\Garena\Skin\Flags\tc.gif
c:\program files\Garena\Skin\Flags\td.gif
c:\program files\Garena\Skin\Flags\tf.gif
c:\program files\Garena\Skin\Flags\tg.gif
c:\program files\Garena\Skin\Flags\th.gif
c:\program files\Garena\Skin\Flags\tj.gif
c:\program files\Garena\Skin\Flags\tm.gif
c:\program files\Garena\Skin\Flags\tn.gif
c:\program files\Garena\Skin\Flags\to.gif
c:\program files\Garena\Skin\Flags\tp.gif
c:\program files\Garena\Skin\Flags\tr.gif
c:\program files\Garena\Skin\Flags\tt.gif
c:\program files\Garena\Skin\Flags\tv.gif
c:\program files\Garena\Skin\Flags\tw.gif
c:\program files\Garena\Skin\Flags\tz.gif
c:\program files\Garena\Skin\Flags\ua.gif
c:\program files\Garena\Skin\Flags\ug.gif
c:\program files\Garena\Skin\Flags\uk.gif
c:\program files\Garena\Skin\Flags\um.gif
c:\program files\Garena\Skin\Flags\us.gif
c:\program files\Garena\Skin\Flags\uy.gif
c:\program files\Garena\Skin\Flags\uz.gif
c:\program files\Garena\Skin\Flags\va.gif
c:\program files\Garena\Skin\Flags\vc.gif
c:\program files\Garena\Skin\Flags\ve.gif
c:\program files\Garena\Skin\Flags\vg.gif
c:\program files\Garena\Skin\Flags\vi.gif
c:\program files\Garena\Skin\Flags\vn.gif
c:\program files\Garena\Skin\Flags\vu.gif
c:\program files\Garena\Skin\Flags\ws.gif
c:\program files\Garena\Skin\Flags\ye.gif
c:\program files\Garena\Skin\Flags\yu.gif
c:\program files\Garena\Skin\Flags\za.gif
c:\program files\Garena\Skin\Flags\zm.gif
c:\program files\Garena\Skin\Flags\zr.gif
c:\program files\Garena\Skin\Flags\zw.gif
c:\program files\Garena\Skin\Skin.ggz
c:\program files\Garena\Skins.xml
c:\program files\Garena\SocketHook.dll
c:\program files\Garena\sound\folder.wav
c:\program files\Garena\sound\game.wav
c:\program files\Garena\sound\msg.wav
c:\program files\Garena\sound\nudge.wav
c:\program files\Garena\sound\quit.wav
c:\program files\Garena\sound\ring.wav
c:\program files\Garena\sound\sysmsg.wav
c:\program files\Garena\source.xml
c:\program files\Garena\sqlite3.dll
c:\program files\Garena\update.exe
c:\program files\Garena\update.xml
c:\program files\Garena\user.xml
c:\program files\Garena\user\12273436\ban.dat
c:\program files\Garena\user\12273436\data.dat
c:\program files\Garena\user\12273436\fps.dat
c:\program files\Garena\user\12273436\recent.txt
c:\program files\Garena\user\12273436\system.xml
c:\program files\Garena\user\12484328\ban.dat
c:\program files\Garena\user\12484328\data.dat
c:\program files\Garena\user\12484328\fps.dat
c:\program files\Garena\user\12484328\recent.txt
c:\program files\Garena\viwawa.cn.xml
c:\program files\Garena\viwawa.en.xml
c:\program files\Garena\viwawa.tw.xml
c:\program files\Garena\War3Hook.dll
c:\program files\Garena\web\1.cn.html
c:\program files\Garena\web\1.en.html
c:\program files\Garena\web\1.tw.html
c:\program files\Garena\web\2.cn.html
c:\program files\Garena\web\2.en.html
c:\program files\Garena\web\2.tw.html
c:\program files\Garena\web\3.cn.html
c:\program files\Garena\web\3.en.html
c:\program files\Garena\web\3.tw.html
c:\program files\Garena\web\6.cn.html
c:\program files\Garena\web\6.en.html
c:\program files\Garena\web\6.tw.html
c:\program files\Garena\web\embed_game.jpg
c:\program files\Garena\web\embed_game_cn.jpg
c:\program files\Garena\web\embed_game_tw.jpg
c:\program files\Garena\web\embed_garenafire_ZH.jpg
c:\program files\Garena\web\embed_gfire.jpg
c:\program files\Garena\web\gfire.cn.html
c:\program files\Garena\web\gfire.en.html
c:\program files\Garena\web\gfire.tw.html
c:\program files\Garena\web\ggbackground.jpg
c:\program files\Garena\YYFileSystem.dll
-------\Legacy_GARENAPENGINE
-------\Service_GarenaPEngine
-------\Legacy_ehdrv
-------\Service_ehdrv
((((((((((((((((((((((((( Files Created from 2009-09-27 to 2009-10-27 )))))))))))))))))))))))))))))))
- 2004-08-04 12:00 . 2009-04-08 15:28 70910 c:\windows\system32\perfc009.dat
+ 2004-08-04 12:00 . 2009-10-25 23:04 70910 c:\windows\system32\perfc009.dat
+ 2004-08-04 12:00 . 2009-10-25 23:04 438824 c:\windows\system32\perfh009.dat
- 2004-08-04 12:00 . 2009-04-08 15:28 438824 c:\windows\system32\perfh009.dat
R1 epfwtdir;epfwtdir;c:\windows\system32\drivers\epfwtdir.sys [2/6/2009 1:24 PM 93336]
R2 ekrn;ESET Service;c:\program files\ESET\ESET NOD32 Antivirus\ekrn.exe [2/6/2009 1:23 PM 727720]
R3 tap0801;TAP-Win32 Adapter V8;c:\windows\system32\drivers\tap0801.sys [9/30/2006 10:37 PM 26624]
R3 TNET1130;802.11 WLAN;c:\windows\system32\drivers\TNET1130.sys [5/17/2009 11:23 AM 386688]
*Deregistered* - mbr
FF - ProfilePath -
Rootkit scan 2009-10-27 15:37
hȋdden files: 0
- - - - - - - > 'winlogon.exe'(1020)
- - - - - - - > 'explorer.exe'(5488)
c:\program files\ESET\ESET NOD32 Antivirus\eplgHooks.dll
c:\commy\CF7925.exe
c:\commy\PEV.cfxxe
Completion time: 2009-10-27 15:40 - machine was rebooted
ComboFix-quarantined-files.txt 2009-10-27 23:40
ComboFix2.txt 2009-10-24 21:38
Pre-Run: 378,927,312,896 bytes free
Post-Run: 378,851,680,256 bytes free
- - End Of File - - 08E95140BCFBBF734BD8BD77D309C701
COOLSTATIC05
Posts Posts : 6
Post by Belahzur on 28th October 2009, 1:34 am
So you play Darkorbit too? noticed it was your homepage. Big Grin
    :filefind
    proquota.exe
Points Points : 245101
Post by COOLSTATIC05 on 8th November 2009, 6:23 pm
Well, I think i don't have the problem anymore. It didnt appear since the last time so i think its cool. And yeah I play Darkorbit. Thanks for the help anyways^^
COOLSTATIC05
Posts Posts : 6
