Start Up problem - malware?
Post by pk2 on 22nd October 2009, 3:03 pm
Hi - not sure what the problem is but here are the symptoms. I thought I would ask here before trying something on my own and really messing things up! My apologies if this is the wrong forum for this post.
This is computer is running XP with SP2.
The computer would not shut down using the usual start/turn off computer/turn off method. I tried ctrl-alt-del to start the task manager. It would not start.
Since there was no way to shut the computer down, I turned power-off / on. I saw the bios boot/set up screen. It was displayed (for about 20 seconds) and then the screen went dark. Previously at this point I would see the windows start up screens and things would proceed normally. I tried rebooting in the safe mode. I got similar results but this time SAFE MODE is displayed in each corner of the screen. The HDD light blinks briefly while in this mode but nothing else happens.
I installed a 640GB HDD in this machine in May 2009 and have been using this as my primary drive. I left the old HDD in the machine as the secondary drive. The computer will run when booted from the old drive so we do have a have to look at the files on the new HDD.
As I mentioned I wanted to get some expert advice here before proceeding on my own.
pk
pk2
Posts Posts : 30
Joined Joined : 2009-04-14
Points Points : 28008
Re: Start Up problem - malware?
Post by Dr Jay on 24th October 2009, 1:08 am
Sorry for the delay, we are busy here on the boards. If you are still having issues, please do the following:
Posts Posts : 14314
Points Points : 302989
Post by pk2 on 25th October 2009, 4:17 pm
Thanks for the response. Since I can not boot from the 640GB HDD (the new one that is the primary drive), I assume I should boot from the secondary HDD and run MBAM and select all HDDs - correct?
pk2
Posts Posts : 30
Post by pk2 on 25th October 2009, 5:01 pm
Here is the MBAM log
Database version: 3029
10/25/2009 10:58:06 AM
mbam-log-2009-10-25 (10-58-06).txt
Scan type: Full Scan (H:\|)
Objects scanned: 578946
Time elapsed: 2 hour(s), 41 minute(s), 12 second(s)
Registry Keys Infected: 1
Files Infected: 2
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{abd45510-9b22-41cd-9acd-8182a2da
7c63} (Trojan.FakeAlert) -> Quarantined and deleted successfully.
H:\Documents and Settings\HP_Owner\Local Settings\Temporary Internet
Files\Content.IE5\GHIJ8RMT\MakeTheWebBetter[1].exe (Adware.MakeTheWebBetter) -> Quarantined and deleted
successfully.
H:\Gary Laptop\Program Files\CIDGenerator\sob19.exe (Trojan.VkHost) -> Quarantined and deleted successfully.
pk2
Posts Posts : 30
Post by pk2 on 25th October 2009, 5:15 pm
Computer still will not boot from 640 GB drive even in the safe mode.
pk2
Posts Posts : 30
Post by Belahzur on 26th October 2009, 12:13 am
Does is display an error why it wont boot from the other hardrive?
Points Points : 245111
Post by pk2 on 26th October 2009, 3:27 am
There is no error displayed. I do not know why it will not boot from the other drive. That is the problem I am trying to solve. When I try to boot in the safe mode, "SAFE MODE" is displayed in each corner of the black screen and the cursor is located in the center of the screen, I can move the cursor. Nothing else happens. I thought it might be a virus/malware.
pk2
Posts Posts : 30
Post by Belahzur on 26th October 2009, 5:38 pm
It could be that the XP partition is corrupt, since there is no error message.
Post by pk2 on 26th October 2009, 8:58 pm
I think the partition is okay. I did a chkdsk on the drive when I booted from the secondary drive. Could it be a Windows file is corrupt. Could I copy the c:\windows from the good drive to the one that does not boot?
pk2
Posts Posts : 30
Post by Belahzur on 27th October 2009, 12:04 am
I doubt copying the entire directory would work, Windows file protection would block overwriting half the files in there.
You could just boot using your Windows disc if you have one and removing the partition that doesn't boot? Do you have an XP disc?
Post by pk2 on 27th October 2009, 1:58 pm
Wouldn't I have to re-install my programs if I remove the partition that does not boot?
pk2
Posts Posts : 30
Post by Belahzur on 27th October 2009, 5:40 pm
Only the programs from that one partition, but yes.
