laptop cannot detect battery, help!
Post by megatails5 on 22nd October 2009, 9:31 am
for some reason, last night my laptop came up with the little symbol in the bottom right of the screen, saying that it is plugged in, then i noticed that the battery symbol (which is normallly full because it is plugged in most of the time) has a big red cross through it. Upon hovering over it, it says no battery is detected, help please! Can't Believe It
megatails5
Posts Posts : 228
Joined Joined : 2009-03-16
OS OS : Windows Vista 64bit
Protection Protection : Malwarebytes, Windows Security Essentials
Points Points : 28890
Re: laptop cannot detect battery, help!
Post by Doctor Inferno on 22nd October 2009, 11:05 am
Remove the battery and try cleaning the contacts, see if it works.
Points Points : 104630
Post by megatails5 on 22nd October 2009, 12:01 pm
how to remove a battery from a laptop?
megatails5
Posts Posts : 228
Post by Doctor Inferno on 22nd October 2009, 4:01 pm
There's usually a slider somewhere around the battery underneath the laptop for you to remove it.
Post by megatails5 on 23rd October 2009, 7:52 pm
still nothing, if my laptop is not plugged in, its off....
megatails5
Posts Posts : 228
