antivirus system pro
Post by asxyouxwish on 21st October 2009, 10:02 pm
Came home this afternoon to several pop ups and a strange program that I didn't recognize asking me to run a scan. I of course didn't, but now can't access My Computer, run the task manager, or even download the Java Update listed in the first step to running Hijack This.
I'm using Firefox on an ancient Dell desktop running Windows XP.
Please send help!
asxyouxwish
Posts Posts : 5
Joined Joined : 2009-10-21
Points Points : 26077
Re: antivirus system pro
Post by Dr Jay on 21st October 2009, 11:09 pm
Posts Posts : 14310
Points Points : 302971
Post by asxyouxwish on 22nd October 2009, 10:08 pm
When I try to run combofix, I get various messages along the lines of
"application cannot be executed. The file pev.exe (this filename has differed) is infected. Do you want to activate your antivirus software now?"
and nothing loads.
asxyouxwish
Posts Posts : 5
Post by Dr Jay on 23rd October 2009, 4:21 am
  • Click Start
  • Click Start
Posts Posts : 14310
Post by asxyouxwish on 23rd October 2009, 9:54 pm
When I attempt to access that page from Internet Explorer, I am redirected to this website - [You must be registered and logged in to see this link.] and can't seem to get past it.
I don't know if there is any way to tell based on the total lack of information I've been able to provide, but truth be told I was a couple weeks away from replacing this computer altogether anyway. My only concern is that my external hard drive might somehow also be affected If there is a safe easy way to determine that, I'm totally ok with going office space on my machine and simply buying a new one.
Thanks for all your efforts thus far. Sorry I haven't been much help.
asxyouxwish
Posts Posts : 5
Post by Dr Jay on 24th October 2009, 12:31 am
If you suspect the hard drive is infected, then you must use a rescue disk, with the type of infection that you have. It is a dangerous infection called Virut: Read more: [You must be registered and logged in to see this link.]
We have hit a dead end. It is recommended to do a reformat and reinstall of your computer.
For the external hard drive, do the following:
Avira AntiVir Rescue System is a Linux-based application that allows accessing computers that cleaning systems cannot be booted anymore or disinfecting external drives that are infected by malware.
  • Download The Avira AntiVir Rescue System from [You must be registered and logged in to see this link.].
  • Just double-click on the rescue system package to burn it to a CD/DVD.
  • Then please use that CD/DVD with Avira Rescue System to boot your computer.
You'll get a boot option to either boot from hard drive or AntiVir Rescue System.
Press the number 2 on your keyboard to boot into AntiVir Rescue System.
Please wait until drivers are loaded and Main menu shows. Then please select the second option “Scan your system with AntiVir” and hit Enter.
Under Configuration, please select Scan all files, Try to repair infected files and Rename files if they cannot be removed?.
Then please start the scan.
The Avira AntiVir Rescue System wil now
  • repair a damaged system,
  • rescue data,
  • scan the system for virus infections.
I am sorry for the bad news. I do not understand why these mean people make such harsh viruses, and I wish there was a way to clean your system without everything being damaged. But, the problem is, cleaning the system, most files will be damaged. It is like trying to clean up a city that just had a tornado or hurricane run through it. Takes rebuilding, and time to set back up.
Posts Posts : 14310
Post by asxyouxwish on 28th October 2009, 1:23 am
Been away for a bit, thanks so much for your efforts. Luckily I will soon be replacing this computer and was planning on that anyway.
In terms of the external hard drive, is it safe to perform the avira rescue on a different computer or should I run it on the one experiencing problems?
asxyouxwish
Posts Posts : 5
Post by asxyouxwish on 31st October 2009, 9:17 pm
bump.
asxyouxwish
Posts Posts : 5
Post by Dr Jay on 2nd November 2009, 3:05 am
Sorry for delay. On the one experiencing problems. It will not hurt running it on others, though.
Posts Posts : 14310
