Antivirus System Pro
Re: Antivirus System Pro
Post by artpassion on 24th October 2009, 12:59 am
SUCCESS!!!!
I disabled the Winpk Filter Miniport in my ethernet card's Property settings by unchecking the box and i was able to acquire an IP address, etc. I strongly suspect based on the description here: [You must be registered and logged in to see this link.] that whomever created Antivirus System Pro used this as part of the attack on my computer, at least that is how I read the implications in the language. I have not uninstalled this until getting your OK, but I think this is the at the core of my internet problem.
I finally then got into Jotti and acquired the URL you requested
JOTTI URL
What is my next course of action?
artpassion
Posts Posts : 26
Joined Joined : 2009-10-20
Points Points : 26142
Post by Dr Jay on 24th October 2009, 1:00 am
GREAT!
Click the Settings button.
Set it to Maximum
Posts Posts : 14309
Points Points : 302960
Post by artpassion on 24th October 2009, 1:31 am
GSI PARSER REPORT URL
artpassion
Posts Posts : 26
Post by Dr Jay on 24th October 2009, 2:30 am
Please delete the following file:
C:\WINDOWS\meta4.exe
  • Click the Start
Please let me know how your computer is running. Also, are you having problems with Windows Updates?
Posts Posts : 14309
Post by artpassion on 24th October 2009, 5:28 am
My computer seems to be running a lot better since I was infected by Antivirus System Pro. I haven't experienced any particular problems with Windows Update in the past, if there is something I should be aware of let me know. Thanks.
Here is the Malware log
MBAM LOG
Database version: 3022
10/24/2009 1:12:58 AM
mbam-log-2009-10-24 (01-12-58).txt
Scan type: Full Scan (C:\|)
Objects scanned: 275517
Time elapsed: 2 hour(s), 15 minute(s), 3 second(s)
Registry Keys Infected: 2
Files Infected: 7
HKEY_CLASSES_ROOT\Interface\{04a38f6b-006f-4247-ba4c-02a139d5531c} (Adware.Minibug) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{6fd31ed6-7c94-4bbc-8e95-f927f4d3a949} (Adware.180Solutions) -> Quarantined and deleted successfully.
C:\Program Files\Maketorrent 2\uninstall.exe (Password.Stealer) -> Quarantined and deleted successfully.
C:\Qoobox\Quarantine\C\Documents and Settings\Max Slobodin_2\Application Data\Desktopicon\eBayShortcuts.exe.vir (Adware.ADON) -> Quarantined and deleted successfully.
C:\Qoobox\Quarantine\C\Program Files\jccfry\vfvesysguard.exe.vir (Rogue.Installer) -> Quarantined and deleted successfully.
C:\Qoobox\Quarantine\C\WINDOWS\syssvc.exe.vir (Trojan.FakeAlert) -> Quarantined and deleted successfully.
C:\Qoobox\Quarantine\C\WINDOWS\system32\iehelper.dll.vir (Trojan.BHO) -> Quarantined and deleted successfully.
C:\Qoobox\Quarantine\C\WINDOWS\system32\lsp.dll.vir (Search.Hijacker) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\tftp.nfo (Trojan.Downloader) -> Quarantined and deleted successfully.
Also, should I get rid of this Winpk Filter Miniport nonsense? Its in both my device manager under Network Adapters and in the Properties of both my ethernet card and my wireless card. As I've said, I've never seen this stuff before the infection that brought me here. Let me know.
Thank you so much for your time.
artpassion
Posts Posts : 26
Post by Dr Jay on 24th October 2009, 8:54 pm
Don't delete those yet. That may not be safe.
Please run the [You must be registered and logged in to see this link.]
Note: This Scanner is for Internet Explorer Only!
  • Follow the Instruction [You must be registered and logged in to see this link.] for installation.
  • Accept the License Agreement.
  • Once the ActiveX installs,Click Full System Scan
  • Once the download completes,the scan will begin automatically.
  • The scan will take some time to finish,so please be patient.
  • When the scan completes, click the Automatic cleaning (recommended) button.
  • Click the Show Report button and Copy&Paste the entire report in your next reply.
Posts Posts : 14309
Post by artpassion on 25th October 2009, 3:36 am
F-SECURE REPORT
Scanning Report
Saturday, October 24, 2009 17:34:46 - 23:34:01
Computer name: THEARTCHIVE
Scanning type: Scan system for malware, spyware and rootkits
Target: C:\ F:\
18 malware found
TrackingCookie.Questionmarket (spyware)
* System (Disinfected)
TrackingCookie.Adinterax (spyware)
TrackingCookie.2o7 (spyware)
TrackingCookie.Advertising (spyware)
TrackingCookie.Atdmt (spyware)
TrackingCookie.Adtech (spyware)
TrackingCookie.Doubleclick (spyware)
TrackingCookie.Revsci (spyware)
TrackingCookie.Zanox (spyware)
TrackingCookie.Adrevolver (spyware)
TrackingCookie.Webtrends (spyware)
TrackingCookie.Mediaplex (spyware)
TrackingCookie.Tradedoubler (spyware)
TrackingCookie.Statcounter (spyware)
TrackingCookie.Atwola (spyware)
TrackingCookie.Yieldmanager (spyware)
TrackingCookie.Imrworldwide (spyware)
Trojan.Generic.2300830 (virus)
* C:\PROGRAM FILES\CDTREE\CDTREE.3.1.3.PRO-REGPATCH.EXE (Renamed & Submitted)
Statistics
Scanned:
* Files: 128567
* System: 3691
* Not scanned: 8
Actions:
* Disinfected: 17
* Renamed: 1
* Deleted: 0
* Not cleaned: 0
* Submitted: 1
Files not scanned:
* C:\PAGEFILE.SYS
* C:\HIBERFIL.SYS
* C:\WINDOWS\SYSTEM32\CONFIG\SOFTWARE
* C:\WINDOWS\SYSTEM32\CONFIG\SAM
* C:\WINDOWS\SYSTEM32\CONFIG\SYSTEM
* C:\WINDOWS\SYSTEM32\CONFIG\DEFAULT
* C:\WINDOWS\SYSTEM32\CONFIG\SECURITY
* C:\DOCUMENTS AND SETTINGS\ALL USERS\APPLICATION DATA\MICROSOFT\CRYPTO\RSA\MACHINEKEYS\B73E0FC8D5BD7727E5AF3BCE1229DDDB_09618EAC-CEE0-4CA5-8DDA-2D51F6C50A7C
Options
Scanning engines:
Scanning options:
* Scan defined files: COM EXE SYS OV? BIN SCR DLL SHS HTM HTML HTT VBS JS INF VXD DO? XL? RTF CPL WIZ HTA PP? PWZ P?T MSO PIF . ACM ASP AX CNV CSC DRV INI MDB MPD MPP MPT OBD OBT OCX PCI TLB TSP WBK WBT WPC WSH VWP WML BOO HLP TD0 TT6 MSG ASD JSE VBE WSC CHM EML PRC SHB LNK WSF {* PDF ZL? XML XXX ANI AVB BAT CMD JOB LSP MAP MHT MIF PHP POT SWF WMF NWS TAR
* Use advanced heuristics
artpassion
Posts Posts : 26
Post by Belahzur on 26th October 2009, 12:25 am
Points Points : 245101
Post by artpassion on 26th October 2009, 12:37 am
The machine seems to be running much better than it was when it was infected. I also took the steps to uninstalling the old and outdated antivirus program I got through my university years ago and replaced it with AVG9 and made sure it was up to date and did a scan and came up clean.
I also removed the Winpk Filter Miniport from my system and have had good internet service since.
Are there any further steps you or Jay would like me to do? I seem to have shaken a lot of garbage from my system, and this has seemed to save my laptop.
If there isn't anything in particular I need to do past what I have already done, I would like to thank you, and especially Jay, for helping me with this problem. You guys are patient and really care about working through people's computer problems. I am strapped for cash at the moment, but hopefully one day soon I can throw this site a small donation. You guys deserve it.
Also, can I remove all the programs I was told to download to the desktop? I plan on keeping the logs either way just in case.
Last edited by artpassion on 26th October 2009, 12:42 am; edited 1 time in total (Reason for editing : additional information)
artpassion
Posts Posts : 26
Post by Belahzur on 26th October 2009, 6:05 pm
You can remove everything we used now. Smile That should do it.
Post by artpassion on 27th October 2009, 12:17 am
Thank you so much again. I guess this closes my case. Thank you.
artpassion
Posts Posts : 26
