Antivirus System Pro
Post by kmoskowski on 20th October 2009, 8:11 pm
I've been getting several pop-ups that say the following:
Antivirus System Pro Alert
Spyware Alert!
Security Warning
Windows Security Alert
I know this is some kind of bug. How can I get rid of it??
kmoskowski
Joined Joined : 2009-10-20
OS OS : Visa
Points Points : 26073
Re: Antivirus System Pro
Post by Dr Jay on 20th October 2009, 11:34 pm
Posts Posts : 14309
Points Points : 302960
