ANTIVIRUS SYSTEM PRO [IN NEED OF HELP]
Post by leahteal on Tue Oct 20, 2009 6:10 pm
In the removal guide it says to post your log, but heres the thing when the notepad pops up it pops up for like a split second and disappears leavin' me no time to copy its contents. I need to get rid of this darn virus some how! HELP! Afraid
Also, I downloaded the malwarebytes, but it wont let me open it.. Once I get passed the set up and hit finish it just goes away.. I tried to run the program, but it wont come up. ERR.
-Leah
leahteal
OS : Windows XP
# Likes : 0
Re: ANTIVIRUS SYSTEM PRO [IN NEED OF HELP]
Post by Dr Jay on Tue Oct 20, 2009 11:33 pm
OS : Windows 10 Home & Pro
# Likes : 10
