URGENT need help on Trojan virus removal
Post by kevin the bird on Tue Oct 20, 2009 2:38 pm
my computer recently got infected with the virus 'TrojanDownloader:Win32/Renos.JS'. It has stopped my Kaspersky antivirus software from working, and has stopped IE and firefox, so I can't get on the internet (I'm using a friend's computer now). Windows defender has detected it, but it doesn't delete it. Please can you tell me how to get rid of this virus?
kevin the bird
OS : vista
Re: URGENT need help on Trojan virus removal
Post by Dr Jay on Tue Oct 20, 2009 11:31 pm
Please transfer this download from a clean computer to the infected one:
OS : Windows 10 Home & Pro
Post by kevin the bird on Wed Oct 21, 2009 12:00 pm
Here's the ComboFix log:
ComboFix 09-10-20.03 - Ammar 21/10/2009 12:38.1.2 - NTFSx86
Microsoft® Windows Vista™ Home Premium 6.0.6001.1.1252.44.1033.18.2046.1347 [GMT 1]
Running from: c:\users\Ammar\Desktop\commy.exe
c:\$recycle.bin\S-1-5-21-1400113804-1914402855-3429530994-500
c:\$recycle.bin\S-1-5-21-2152478756-3922319563-605102323-500
c:\$recycle.bin\S-1-5-21-2761920510-736693625-3431824637-500
c:\windows\Installer\d15c.msi
c:\$recycle.bin\S-1-5-21-1400113804-1914402855-3429530994-500\desktop.ini
c:\$recycle.bin\S-1-5-21-2152478756-3922319563-605102323-500\desktop.ini
c:\$recycle.bin\S-1-5-21-2761920510-736693625-3431824637-500\desktop.ini
c:\program files\Applications\myp.ico
c:\users\Ammar\Documents\My Documents.url
Infected copy of c:\windows\system32\cngaudit.dll was found and disinfected
Restored copy from - c:\windows\winsxs\x86_microsoft-windows-cngaudit-dll_31bf3856ad364e35_6.0.6000.16386_none_e62d292932a96ce6\cngaudit.dll
-------\Legacy_{79007602-0CDB-4405-9DBF-1257BB3226EE}
((((((((((((((((((((((((( Files Created from 2009-09-21 to 2009-10-21 )))))))))))))))))))))))))))))))
2009-10-21 11:45 . 2009-10-21 11:48 -------- d-----w- c:\users\Ammar\AppData\Local\temp
2009-10-21 11:45 . 2009-10-21 11:45 -------- d-----w- c:\users\Default\AppData\Local\temp
2009-10-20 16:18 . 2009-10-20 16:18 -------- d-----w- C:\Kontiki
2009-10-20 15:09 . 2009-10-20 15:09 -------- d-----w- c:\windows\system32\EventProviders
2009-10-20 11:38 . 2009-10-20 18:23 0 ----a-r- c:\windows\win32k.sys
2009-10-15 20:11 . 2009-09-04 12:24 61440 ----a-w- c:\windows\system32\msasn1.dll
2009-10-15 20:11 . 2009-09-14 09:44 144896 ----a-w- c:\windows\system32\drivers\srv2.sys
2009-10-15 20:11 . 2009-04-02 12:37 604672 ----a-w- c:\windows\system32\WMSPDMOD.DLL
2009-10-12 11:33 . 2009-10-12 11:33 -------- d-----w- c:\programdata\Office Genuine Advantage
2009-10-02 19:04 . 2009-10-01 09:29 195440 ------w- c:\windows\system32\MpSigStub.exe
2009-09-24 11:23 . 2009-09-24 11:23 -------- d-----w- c:\users\Ammar\AppData\Roaming\TomTom
2009-09-24 11:23 . 2009-09-24 11:23 -------- d-----w- c:\users\Ammar\AppData\Local\TomTom
2009-09-24 11:23 . 2009-09-24 11:23 -------- d-----w- c:\program files\TomTom International B.V
2009-09-24 11:23 . 2009-09-24 11:23 -------- d-----w- c:\program files\TomTom HOME 2
2009-10-21 11:50 . 2008-04-04 14:23 -------- d-----w- c:\programdata\Kontiki
2009-10-21 11:49 . 2007-09-26 18:44 -------- d-----w- c:\program files\Dl_cats
2009-10-21 11:38 . 2008-08-22 10:35 -------- d-----w- c:\program files\Applications
2009-10-20 16:08 . 2008-08-24 15:06 -------- d-----w- c:\programdata\Kaspersky Lab
2009-10-20 10:51 . 2007-10-06 11:08 -------- d-----w- c:\programdata\Google Updater
2009-10-17 09:47 . 2009-06-06 11:17 -------- d-----w- c:\users\Ammar\AppData\Roaming\Spotify
2009-10-16 02:14 . 2006-11-02 11:18 -------- d-----w- c:\program files\Windows Mail
2009-10-16 02:04 . 2007-09-11 10:02 -------- d-----w- c:\programdata\Microsoft Help
2009-10-14 13:11 . 2009-08-19 12:09 108059 ----a-w- c:\windows\system32\drivers\klin.dat
2009-10-14 13:11 . 2009-08-19 12:09 95259 ----a-w- c:\windows\system32\drivers\klick.dat
2009-10-12 11:33 . 2007-09-19 18:20 88456 ----a-w- c:\users\Ammar\AppData\Local\GDIPFONTCACHEV1.DAT
2009-10-11 21:24 . 2007-09-11 10:04 -------- d-----w- c:\program files\Microsoft Works
2009-09-25 07:38 . 2007-09-11 09:57 -------- d--h--w- c:\program files\InstallShield Installation Information
2009-09-24 16:20 . 2007-09-11 10:10 -------- d-----w- c:\program files\Common Files\Adobe
2009-09-24 11:20 . 2008-02-10 12:01 -------- d-----w- c:\program files\TomTom HOME
2009-09-14 17:26 . 2009-09-14 17:26 -------- d-----w- c:\program files\iLike
2009-09-14 17:26 . 2008-09-28 20:06 -------- d-----w- c:\program files\iTunes
2009-09-14 12:31 . 2009-09-14 12:31 1775094 ----a-w- c:\programdata\SPL8842.tmp
2009-09-10 17:30 . 2009-10-15 20:12 213504 ----a-w- c:\windows\system32\msv1_0.dll
2009-09-09 23:11 . 2009-06-28 18:46 -------- d-----w- c:\program files\Microsoft Silverlight
2009-09-06 15:28 . 2007-09-11 09:57 -------- d-----w- c:\program files\Java
2009-08-31 13:55 . 2009-10-15 20:12 293376 ----a-w- c:\windows\system32\psisdecd.dll
2009-08-31 13:55 . 2009-10-15 20:12 428544 ----a-w- c:\windows\system32\EncDec.dll
2009-08-28 12:39 . 2009-09-03 18:01 28672 ----a-w- c:\windows\system32\Apphlpdm.dll
2009-08-28 10:15 . 2009-09-03 18:01 4240384 ----a-w- c:\windows\system32\GameUXLegacyGDFs.dll
2009-08-27 05:22 . 2009-10-15 20:12 916480 ----a-w- c:\windows\system32\wininet.dll
2009-08-27 05:17 . 2009-10-15 20:12 71680 ----a-w- c:\windows\system32\iesetup.dll
2009-08-27 05:17 . 2009-10-15 20:12 109056 ----a-w- c:\windows\system32\iesysprep.dll
2009-08-27 03:42 . 2009-10-15 20:12 133632 ----a-w- c:\windows\system32\ieUnatt.exe
2009-08-22 15:12 . 2009-06-06 15:41 -------- d-----w- c:\program files\Common Files\Adobe AIR
2009-08-22 15:11 . 2009-06-06 15:42 38208 ----a-w- c:\users\Ammar\AppData\Roaming\Macromedia\Flash Player\[You must be registered and logged in to see this link.]
2009-08-19 12:20 . 2009-05-24 14:30 128016 ----a-w- c:\windows\system32\drivers\kl1.sys
2009-08-19 12:10 . 2009-08-19 12:10 604140 --sha-w- c:\windows\system32\drivers\ISwift3.dat
2009-08-17 22:33 . 2009-08-17 22:33 1193832 ----a-w- c:\windows\system32\FM20.DLL
2009-08-14 17:07 . 2009-09-09 18:29 897608 ----a-w- c:\windows\system32\drivers\tcpip.sys
2009-08-14 16:29 . 2009-09-09 18:29 104960 ----a-w- c:\windows\system32\netiohlp.dll
2009-08-14 16:29 . 2009-09-09 18:29 17920 ----a-w- c:\windows\system32\netevent.dll
2009-08-14 14:16 . 2009-09-09 18:29 9728 ----a-w- c:\windows\system32\TCPSVCS.EXE
2009-08-14 14:16 . 2009-09-09 18:29 17920 ----a-w- c:\windows\system32\ROUTE.EXE
2009-08-14 14:16 . 2009-09-09 18:29 11264 ----a-w- c:\windows\system32\MRINFO.EXE
2009-08-14 14:16 . 2009-09-09 18:29 27136 ----a-w- c:\windows\system32\NETSTAT.EXE
2009-08-14 14:16 . 2009-09-09 18:29 19968 ----a-w- c:\windows\system32\ARP.EXE
2009-08-14 14:16 . 2009-09-09 18:29 8704 ----a-w- c:\windows\system32\HOSTNAME.EXE
2009-08-14 14:16 . 2009-09-09 18:29 10240 ----a-w- c:\windows\system32\finger.exe
2009-08-05 14:22 . 2009-10-15 20:12 3597896 ----a-w- c:\windows\system32\ntkrnlpa.exe
2009-08-05 14:22 . 2009-10-15 20:12 3546184 ----a-w- c:\windows\system32\ntoskrnl.exe
2009-08-03 14:07 . 2009-08-03 14:07 403816 ----a-w- c:\windows\system32\OGACheckControl.dll
2009-08-03 14:07 . 2009-08-03 14:07 322928 ----a-w- c:\windows\system32\OGAAddin.dll
2009-08-03 14:07 . 2009-08-03 14:07 230768 ----a-w- c:\windows\system32\OGAEXEC.exe
2009-07-25 04:23 . 2009-04-18 13:44 411368 ----a-w- c:\windows\system32\deploytk.dll
2008-02-08 22:15 . 2008-02-08 22:15 135680 ----a-w- c:\program files\mozilla firefox\components\GoogleDesktopMozilla.dll
2007-09-11 17:40 . 2007-09-11 17:35 8192 --sha-w- c:\windows\Users\Default\NTUSER.DAT
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2007-10-06 68856]
"kdx"="c:\program files\Kontiki\KHost.exe" [2007-04-23 1032640]
"iLike"="c:\program files\iLike\1.2.16\ilikesidebar.exe" [2008-09-10 63024]
"TomTomHOME.exe"="c:\program files\TomTom HOME 2\TomTomHOMERunner.exe" [2009-08-27 247144]
"Windows Defender"="c:\program files\Windows Defender\MSASCui.exe" [2008-01-19 1008184]
"ISUSScheduler"="c:\program files\Common Files\InstallShield\UpdateService\issch.exe" [2006-10-03 81920]
"RoxWatchTray"="c:\program files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatchTray9.exe" [2006-11-05 221184]
"dscactivate"="c:\program files\Dell Support Center\gs_agent\custom\dsca.exe" [2007-11-15 16384]
"Google Desktop Search"="c:\program files\Google\Google Desktop Search\GoogleDesktop.exe" [2008-02-08 1836544]
"Dell Photo AIO Printer 922"="c:\program files\Dell Photo AIO Printer 922\dlbtbmgr.exe" [2004-03-29 290816]
"ISUSPM Startup"="c:\progra~1\COMMON~1\INSTAL~1\UPDATE~1\ISUSPM.exe" [2006-10-03 221184]
"FaxCenterServer"="c:\program files\Dell PC Fax\fm3032.exe" [2006-11-03 312200]
"dlcxmon.exe"="c:\program files\Dell Photo AIO Printer 926\dlcxmon.exe" [2007-01-12 292336]
"MemoryCardManager"="c:\program files\Dell Photo AIO Printer 926\memcard.exe" [2006-11-03 304008]
"DLCXCATS"="c:\windows\system32\spool\DRIVERS\W32X86\3\DLCXtime.dll" [2006-10-16 106496]
"TkBellExe"="c:\program files\Common Files\Real\Update_OB\realsched.exe" [2007-11-24 185896]
"DellSupportCenter"="c:\program files\Dell Support Center\bin\sprtcmd.exe" [2009-05-21 206064]
"QuickTime Task"="c:\program files\QuickTime\QTTask.exe" [2008-09-06 413696]
"iTunesHelper"="c:\program files\iTunes\iTunesHelper.exe" [2008-09-10 289576]
"NvSvc"="c:\windows\system32\nvsvc.dll" [2007-05-24 86016]
"NvCplDaemon"="c:\windows\system32\NvCpl.dll" [2007-05-24 8429568]
"NvMediaCenter"="c:\windows\system32\NvMcTray.dll" [2007-05-24 81920]
"4oD"="c:\program files\Kontiki\KHost.exe" [2007-04-23 1032640]
"SunJavaUpdateSched"="c:\program files\Java\jre6\bin\jusched.exe" [2009-07-25 149280]
"Adobe Reader Speed Launcher"="c:\program files\Adobe\Reader 8.0\Reader\Reader_sl.exe" [2008-10-15 39792]
"RtHDVCpl"="RtHDVCpl.exe" - c:\windows\RtHDVCpl.exe [2007-03-15 4390912]
c:\users\Ammar\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\
BBC iPlayer Desktop.lnk - c:\program files\BBC iPlayer Desktop\BBC iPlayer Desktop.exe [2009-6-6 95744]
Cyber-shot Viewer Media Check Tool.lnk - c:\program files\Sony\Sony Picture Utility\VolumeWatcher\SPUVolumeWatcher.exe [2007-11-4 155648]
OneNote 2007 Screen Clipper and Launcher.lnk - c:\program files\Microsoft Office\Office12\ONENOTEM.EXE [2008-10-25 98696]
"AppInit_DLLs"=c:\progra~1\Google\GOOGLE~2\GoogleDesktopNetwork3.dll c:\progra~1\KASPER~1\KASPER~2\mzvkbd3.dll
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\KasperskyAntiVirus]
R0 klbg;Kaspersky Lab Boot Guard Driver;c:\windows\System32\drivers\klbg.sys [15/12/2008 20:41 33808]
R2 dlcx_device;dlcx_device;c:\windows\system32\dlcxcoms.exe -service --> c:\windows\system32\dlcxcoms.exe -service [?]
R2 TomTomHOMEService;TomTomHOMEService;c:\program files\TomTom HOME 2\TomTomHOMEService.exe [27/08/2009 16:05 92008]
R3 klmouflt;Kaspersky Lab KLMOUFLT;c:\windows\System32\drivers\klmouflt.sys [16/05/2009 20:59 19472]
S3 netr73;Belkin Wireless 54G USB Network Adapter Driver for Vista;c:\windows\System32\drivers\netr73.sys [20/08/2009 11:16 464384]
2009-10-21 c:\windows\Tasks\Google Software Updater.job
- c:\program files\Google\Common\Google Updater\GoogleUpdaterService.exe [2007-10-06 19:52]
mSearchURL = [You must be registered and logged in to see this link.]
IE: Download all links with IDM - c:\users\Ammar\AppData\Local\Temp\Rar$EX01.178\IEGetAll.htm
IE: Download FLV video content with IDM - c:\users\Ammar\AppData\Local\Temp\Rar$EX01.178\IEGetVL.htm
IE: Download with IDM - c:\users\Ammar\AppData\Local\Temp\Rar$EX01.178\IEExt.htm
IE: {{08E730A4-FB02-45BD-A900-01E4AD8016F6} - [You must be registered and logged in to see this link.]
FF - ProfilePath - c:\users\Ammar\AppData\Roaming\Mozilla\Firefox\Profiles\2w33kq8l.default\
FF - component: c:\program files\Mozilla Firefox\components\GoogleDesktopMozilla.dll
FF - component: c:\program files\Mozilla Firefox\extensions\linkfilter@kaspersky.ru\components\KavLinkFilter.dll
FF - plugin: c:\program files\Google\Google Updater\2.4.1536.6592\npCIDetect13.dll
---- FIREFOX POLICIES ----
HKLM-Run-DVDtoiPodConverter_upgrade - c:\program files\E-Zsoft\DVDtoiPodConverter\DVDtoiPodConverter.exe
HKU-Default-RunOnce-DelayShred - c:\program files\mcafee\mshr\ShrCL.EXE
AddRemove-Warning Center - c:\program files\Applications\wcu.exe
scanning hȋdden processes ...
DLCXCATS = rundll32 c:\windows\system32\spool\DRIVERS\W32X86\3\DLCXtime.dll,_RunDLLEntry@16???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
scanning hȋdden files ...
hȋdden files:
[HKEY_USERS\S-1-5-21-2761920510-736693625-3431824637-1000_Classes\CLSID\{5ED60779-4DE2-4E07-B862-974CA4FF2E9C}]
@Denied: (Full) (Everyone)
"scansk"=hex(0):d6,ea,e3,bf,6c,f6,46,9d,47,a4,15,bf,02,5c,17,e1,2d,09,05,57,c3,
73,54,1e,75,2d,68,df,d5,83,09,14,3a,e7,02,b6,62,2f,a8,b8,00,00,00,00,00,00,\
[HKEY_USERS\S-1-5-21-2761920510-736693625-3431824637-1000_Classes\CLSID\{d6cc81fb-0fe6-4f11-b1b6-75abc2f31ace}]
"Model"=dword:0000000c
"Therad"=dword:00000015
- - - - - - - > 'Explorer.exe'(5508)
c:\program files\Roxio\Drag-to-Disc\Shellex.dll
c:\windows\system32\DLAAPI_W.DLL
c:\program files\Roxio\Drag-to-Disc\ShellRes.dll
c:\program files\Kontiki\KService.exe
c:\program files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatch9.exe
c:\program files\Dell Support Center\bin\sprtsvc.exe
c:\windows\system32\WUDFHost.exe
c:\program files\Common Files\Roxio Shared\9.0\SharedCOM\RoxMediaDB9.exe
c:\commy\CF20872.exe
c:\windows\System32\rundll32.exe
c:\windows\ehome\ehmsas.exe
c:\program files\Dell Photo AIO Printer 922\dlbtbmon.exe
c:\windows\System32\wscript.exe
c:\program files\Common Files\Roxio Shared\9.0\SharedCOM\CPSHelpRunner.exe
c:\commy\PEV.cfxxe
Completion time: 2009-10-21 12:53 - machine was rebooted
ComboFix-quarantined-files.txt 2009-10-21 11:53
Pre-Run: 210,580,164,608 bytes free
Post-Run: 211,239,079,936 bytes free
- - End Of File - - 24C3A70D64126281A0BB01EB7758DE8C
This is the list of installed programs:
4oD
ABBYY FineReader 6.0 Sprint
Adobe AIR
Adobe Flash Player 10 ActiveX
Adobe Flash Player 10 Plugin
Adobe Reader 8.1.4
Adobe Shockwave Player
Apple Mobile Device Support
Apple Software Update
BBC iPlayer Desktop
Bonjour
Browser Address Error Redirector
Chinese Simplified Fonts Support For Adobe Reader 8
Dell PC Fax
Dell Support Center (Support Software)
Dell System Customization Wizard
DellSupport
Google Desktop
Google Earth
Google Updater
iLike Sidebar
Internet From BT
iTunes
Java(TM) 6 Update 15
Java(TM) SE Runtime Environment 6
Kaspersky Anti-Virus 2010
Microsoft Office 2007 Service Pack 2 (SP2)
Microsoft Office Home and Student 2007
Microsoft Office OneNote MUI (English) 2007
Microsoft Office Proofing Tools 2007 Service Pack 2 (SP2)
Mozilla Firefox (3.0.14)
MSXML 4.0 SP2 (KB927978)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB941833)
MSXML 4.0 SP2 (KB954430)
NVIDIA Drivers
NVIDIANetworkDiagnostic
OGA Notifier 2.0.0048.0
Orange Preload
QuickTime
RealPlayer
Roxio Creator Audio
Roxio Creator BDAV Plugin
Roxio Creator Copy
Roxio Creator Data
Roxio Creator DE
Roxio Creator Tools
Roxio Drag-to-Disc
Roxio Express Labeler
Roxio MyDVD DE
Roxio Update Manager
Security Update for 2007 Microsoft Office System (KB969559)
Security Update for 2007 Microsoft Office System (KB969679)
Security Update for Microsoft Office Excel 2007 (KB969682)
Security Update for Microsoft Office PowerPoint 2007 (KB957789)
Security Update for Microsoft Office system 2007 (972581)
Security Update for Microsoft Office system 2007 (KB969613)
Security Update for Microsoft Office system 2007 (KB974234)
Security Update for Microsoft Office Visio Viewer 2007 (KB973709)
Security Update for Microsoft Office Word 2007 (KB969604)
Sibelius Scorch (ActiveX Only)
Sky Broadband
Sky Broadband Browser Branding
Sonic Activation Module
Spelling Dictionaries Support For Adobe Reader 8
Spotify
StatsDirect
Tiscali Internet
TomTom HOME 2.7.2.1825
TomTom HOME Visual Studio Merge Modules
Update for Microsoft Office 2007 Help for Common Features (KB963673)
Update for Microsoft Office Excel 2007 Help (KB963678)
Update for Microsoft Office OneNote 2007 Help (KB963670)
Update for Microsoft Office Powerpoint 2007 Help (KB963669)
Update for Microsoft Office Script Editor Help (KB963671)
Update for Microsoft Office Word 2007 Help (KB963665)
VideoLAN VLC media player 0.8.6d
Warning Center
Windows Media Player Firefox Plugin
By the way, the ComboFix managed to restore my internet, so I can use links and downloads now.
kevin the bird
OS : vista
Post by Dr Jay on Wed Oct 21, 2009 8:47 pm
  1. Close any open browsers.
    DDS::
Post by kevin the bird on Thu Oct 22, 2009 10:07 am
ComboFix 09-10-20.03 - Ammar 22/10/2009 9:56.2.2 - NTFSx86
Microsoft® Windows Vista™ Home Premium 6.0.6001.1.1252.44.1033.18.2046.1237 [GMT 1:00]
Running from: c:\users\Ammar\Desktop\ComboFix.exe
Command switches used :: c:\users\Ammar\Desktop\CFScript.txt
((((((((((((((((((((((((( Files Created from 2009-09-22 to 2009-10-22 )))))))))))))))))))))))))))))))
2009-10-22 09:01 . 2009-10-22 09:01 -------- d-----w- c:\users\TEMP\AppData\Local\temp
2009-10-22 09:01 . 2009-10-22 09:01 -------- d-----w- c:\users\Public\AppData\Local\temp
2009-10-22 09:01 . 2009-10-22 09:01 -------- d-----w- c:\users\Default\AppData\Local\temp
2009-10-21 12:13 . 2009-10-21 12:16 -------- d-----w- c:\program files\Windows Live Safety Center
2009-10-21 11:45 . 2009-10-22 09:01 -------- d-----w- c:\users\Ammar\AppData\Local\temp
2009-10-22 09:02 . 2008-04-04 14:23 -------- d-----w- c:\programdata\Kontiki
2009-10-22 08:46 . 2007-09-26 18:44 -------- d-----w- c:\program files\Dl_cats
2009-10-21 22:13 . 2009-10-21 22:13 972636 ----a-w- c:\programdata\SPLF2E3.tmp
2009-10-21 22:10 . 2009-10-21 22:10 972636 ----a-w- c:\programdata\SPLF514.tmp
2009-10-21 12:08 . 2009-06-06 11:17 -------- d-----w- c:\users\Ammar\AppData\Roaming\Spotify
2009-10-21 11:52 . 2007-10-06 11:08 -------- d-----w- c:\programdata\Google Updater
+ 2006-11-02 13:05 . 2009-10-22 08:46 66190 c:\windows\System32\WDI\BootPerformanceDiagnostics_SystemData.bin
+ 2007-09-19 18:20 . 2009-10-22 08:46 19888 c:\windows\System32\WDI\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-2761920510-736693625-3431824637-1000_UserData.bin
- 2007-09-19 18:13 . 2009-10-21 11:47 32768 c:\windows\System32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2007-09-19 18:13 . 2009-10-22 08:49 32768 c:\windows\System32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2007-09-19 18:13 . 2009-10-22 08:49 32768 c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
- 2007-09-19 18:13 . 2009-10-21 11:47 32768 c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
- 2007-09-19 18:13 . 2009-10-21 11:47 16384 c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2007-09-19 18:13 . 2009-10-22 08:49 16384 c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2009-10-21 12:13 . 2009-10-21 12:13 39424 c:\windows\Installer\18aeda.msi
+ 2007-11-28 19:43 . 2009-10-21 22:47 5992 c:\windows\System32\WDI\ERCQueuedResolutions.dat
- 2007-11-28 19:43 . 2009-10-21 11:32 5992 c:\windows\System32\WDI\ERCQueuedResolutions.dat
- 2009-10-21 11:47 . 2009-10-21 11:47 2048 c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
+ 2009-10-22 08:44 . 2009-10-22 08:44 2048 c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
+ 2009-10-22 08:44 . 2009-10-22 08:44 2048 c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
- 2009-10-21 11:47 . 2009-10-21 11:47 2048 c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
+ 2008-10-13 20:35 . 2009-10-21 21:03 253546 c:\windows\System32\WDI\SuspendPerformanceDiagnostics_SystemData_FastS4.bin
+ 2009-10-21 12:16 . 2009-10-21 12:16 850944 c:\windows\Installer\18af16.msp
+ 2009-10-21 12:13 . 2009-10-21 12:13 170496 c:\windows\Installer\18aef8.msp
+ 2009-10-21 12:13 . 2009-10-21 12:13 162304 c:\windows\Installer\18aef2.msp
+ 2009-10-21 12:13 . 2009-10-21 12:13 189440 c:\windows\Installer\18aeec.msp
+ 2009-10-21 12:13 . 2009-10-21 12:13 217088 c:\windows\Installer\18aee6.msp
+ 2009-10-21 12:13 . 2009-10-21 12:13 375296 c:\windows\Installer\18aee0.msp
+ 2009-10-21 12:16 . 2009-10-21 12:16 9443328 c:\windows\Installer\18af10.msp
+ 2009-10-21 12:15 . 2009-10-21 12:15 2446336 c:\windows\Installer\18af0a.msp
+ 2009-10-21 12:14 . 2009-10-21 12:14 2001920 c:\windows\Installer\18aefe.msp
+ 2009-10-21 12:15 . 2009-10-21 12:15 30402560 c:\windows\Installer\18af04.msp
2009-10-22 c:\windows\Tasks\Google Software Updater.job
Rootkit scan 2009-10-22 10:01
Windows 6.0.6001 Service Pack 1 NTFS
c:\windows\TEMP\TMP0000006E89A27C184F2944CD
hȋdden files: 1
Completion time: 2009-10-22 10:03
ComboFix-quarantined-files.txt 2009-10-22 09:03
ComboFix2.txt 2009-10-21 11:53
Pre-Run: 212,215,189,504 bytes free
Post-Run: 212,242,374,656 bytes free
- - End Of File - - 8AA1F85F21AE6C4135DC9785BFF6C3A6
Here's the SecurityCheck log:
Results of screen317's Security Check version 0.99.0
Windows Vista Service Pack 1 (UAC is enabled)
Out of date service pack!!
Antivirus/Firewall Check:
Windows Firewall Enabled!
WMIC entry does not exist for antivirus; attempting automatic update.
Adobe Reader 8.1.4
Process Check:
objlist.exe by Laurent
Windows Defender MSASCui.exe
DNS Vulnerability Check:
Request Timed Out (Wireless Internet connection/Disconnected Internet/Proxy?)
kevin the bird
OS : vista
Post by Dr Jay on Fri Oct 23, 2009 3:58 am
    Rootkit::
    File::
Post by kevin the bird on Fri Oct 23, 2009 5:36 pm
ComboFix 09-10-20.03 - Ammar 23/10/2009 18:05.3.2 - NTFSx86
Microsoft® Windows Vista™ Home Premium 6.0.6001.1.1252.44.1033.18.2046.1213 [GMT 1:00]
Running from: c:\users\Ammar\Desktop\commy.exe.exe
Command switches used :: c:\users\Ammar\Desktop\CFScript.txt.txt
FILE ::
"c:\programdata\SPL8842.tmp"
((((((((((((((((((((((((( Files Created from 2009-09-23 to 2009-10-23 )))))))))))))))))))))))))))))))
2009-10-23 17:11 . 2009-10-23 17:11 -------- d-----w- c:\users\TEMP\AppData\Local\temp
2009-10-23 17:11 . 2009-10-23 17:11 -------- d-----w- c:\users\Public\AppData\Local\temp
2009-10-23 17:11 . 2009-10-23 17:11 -------- d-----w- c:\users\Default\AppData\Local\temp
2009-10-21 11:45 . 2009-10-23 17:24 -------- d-----w- c:\users\Ammar\AppData\Local\temp
2009-10-23 17:25 . 2008-04-04 14:23 -------- d-----w- c:\programdata\Kontiki
2009-10-23 17:24 . 2007-09-26 18:44 -------- d-----w- c:\program files\Dl_cats
2009-10-22 17:29 . 2007-10-06 11:08 -------- d-----w- c:\programdata\Google Updater
+ 2007-09-11 10:17 . 2009-10-23 16:58 62122 c:\windows\System32\WDI\ShutdownPerformanceDiagnostics_SystemData.bin
+ 2006-11-02 13:05 . 2009-10-23 16:58 66206 c:\windows\System32\WDI\BootPerformanceDiagnostics_SystemData.bin
+ 2007-09-19 18:20 . 2009-10-23 16:58 19888 c:\windows\System32\WDI\{86432a0b-3c7d-4ddf-a89c-172faa90485d}\S-1-5-21-2761920510-736693625-3431824637-1000_UserData.bin
+ 2007-09-19 18:13 . 2009-10-23 17:13 32768 c:\windows\System32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2007-09-19 18:13 . 2009-10-23 17:13 32768 c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2007-09-19 18:13 . 2009-10-23 17:13 16384 c:\windows\System32\config\systemprofile\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
- 2007-09-21 17:41 . 2009-09-27 18:40 16384 c:\windows\ServiceProfiles\LocalService\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
+ 2007-09-21 17:41 . 2009-10-23 00:36 16384 c:\windows\ServiceProfiles\LocalService\AppData\Roaming\Microsoft\Windows\Cookies\index.dat
- 2007-09-21 17:41 . 2009-09-27 18:40 32768 c:\windows\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
+ 2007-09-21 17:41 . 2009-10-23 00:36 32768 c:\windows\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\index.dat
- 2007-09-21 17:41 . 2009-09-27 18:40 16384 c:\windows\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2007-09-21 17:41 . 2009-10-23 00:36 16384 c:\windows\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\History\History.IE5\index.dat
+ 2009-10-23 17:12 . 2009-10-23 17:12 2048 c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive1.dat
+ 2009-10-23 17:12 . 2009-10-23 17:12 2048 c:\windows\ServiceProfiles\LocalService\AppData\Local\lastalive0.dat
+ 2008-10-13 20:35 . 2009-10-22 23:31 253800 c:\windows\System32\WDI\SuspendPerformanceDiagnostics_SystemData_FastS4.bin
+ 2006-11-02 10:33 . 2009-10-23 17:01 599942 c:\windows\System32\perfh009.dat
- 2006-11-02 10:33 . 2009-10-13 18:05 599942 c:\windows\System32\perfh009.dat
- 2006-11-02 10:33 . 2009-10-13 18:05 105448 c:\windows\System32\perfc009.dat
+ 2006-11-02 10:33 . 2009-10-23 17:01 105448 c:\windows\System32\perfc009.dat
2009-10-23 c:\windows\Tasks\Google Software Updater.job
Rootkit scan 2009-10-23 18:24
hȋdden files: 0
- - - - - - - > 'Explorer.exe'(3404)
c:\windows\servicing\TrustedInstaller.exe
c:\commy.exe\CF1210.exe
c:\commy.exe\PEV.cfxxe
Completion time: 2009-10-23 18:27 - machine was rebooted
ComboFix-quarantined-files.txt 2009-10-23 17:27
ComboFix2.txt 2009-10-22 09:03
ComboFix3.txt 2009-10-21 11:53
Pre-Run: 212,165,545,984 bytes free
Post-Run: 212,112,547,840 bytes free
- - End Of File - - 54E14A6BAF425147FDB4285870676AA3
kevin the bird
OS : vista
Post by Dr Jay on Fri Oct 23, 2009 7:23 pm
  1. Double click it to start the tool.
  2. A Notepad file containing the report will open, also found at C:\Rooter.txt. Post that log in your next reply.
Post by kevin the bird on Fri Oct 23, 2009 8:39 pm
Here's the Rooter log:
Rooter.exe (v1.0.2) by Eric_71
SeDebugPrivilege granted successfully ...
Windows Vista Home Edition (6.0.6001) Service Pack 1
[32_bits] - x86 Family 15 Model 107 Stepping 1, AuthenticAMD
[wscsvc] (Security Center) RUNNING (state:4)
[MpsSvc] RUNNING (state:4)
Windows Firewall -> Enabled
Windows Defender -> Enabled
User Account Control (UAC) -> Enabled
Internet Explorer 8.0.6001.18828
Mozilla Firefox 3.0.14 (en-GB)
C:\ [fȋxed-NTFS] .. ( Total:288 Go - Free:196 Go )
D:\ [fȋxed-NTFS] .. ( Total:9 Go - Free:5 Go )
E:\ [CD_Rom]
G:\ [Removable]
H:\ [Removable]
I:\ [Removable]
J:\ [Removable]
K:\ [Removable]
Scan : 21:38.41
Path : C:\Users\Ammar\Desktop\Rooter.exe
User : Ammar ( Administrator -> YES )
----------------------\\ Processes
Locked [System Process] (0)
Locked System (4)
______ \SystemRoot\System32\smss.exe (536)
______ C:\Windows\system32\csrss.exe (612)
______ C:\Windows\system32\wininit.exe (664)
______ C:\Windows\system32\csrss.exe (672)
______ C:\Windows\system32\services.exe (708)
______ C:\Windows\system32\lsass.exe (724)
______ C:\Windows\system32\lsm.exe (732)
______ C:\Windows\system32\winlogon.exe (776)
______ C:\Windows\system32\svchost.exe (924)
______ C:\Windows\system32\svchost.exe (1012)
______ C:\Windows\System32\svchost.exe (1052)
______ C:\Windows\System32\svchost.exe (1140)
______ C:\Windows\System32\svchost.exe (1184)
______ C:\Windows\system32\svchost.exe (1200)
Locked audiodg.exe (1276)
______ C:\Windows\system32\svchost.exe (1320)
______ C:\Windows\system32\SLsvc.exe (1336)
______ C:\Windows\system32\svchost.exe (1372)
______ C:\Windows\system32\svchost.exe (1588)
______ C:\Windows\System32\spoolsv.exe (1844)
______ C:\Windows\system32\svchost.exe (1868)
______ C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe (936)
______ C:\Program Files\Bonjour\mDNSResponder.exe (1264)
______ C:\Windows\system32\dlcxcoms.exe (1432)
______ C:\Program Files\Kontiki\KService.exe (1596)
______ C:\Windows\system32\svchost.exe (932)
______ C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatch9.exe (840)
______ C:\Program Files\Dell Support Center\bin\sprtsvc.exe (2188)
______ C:\Windows\system32\svchost.exe (2208)
______ C:\Program Files\TomTom HOME 2\TomTomHOMEService.exe (2232)
______ C:\Windows\System32\svchost.exe (2272)
______ C:\Windows\system32\SearchIndexer.exe (2304)
______ C:\Windows\system32\WUDFHost.exe (2820)
______ C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxMediaDB9.exe (2972)
______ C:\Windows\system32\taskeng.exe (3320)
______ C:\Windows\system32\Dwm.exe (3676)
______ C:\Windows\system32\taskeng.exe (2856)
______ C:\Program Files\Windows Defender\MSASCui.exe (3568)
______ C:\Windows\RtHDVCpl.exe (3552)
______ C:\Program Files\Common Files\InstallShield\UpdateService\issch.exe (3480)
______ C:\Program Files\Common Files\Roxio Shared\9.0\SharedCOM\RoxWatchTray9.exe (3528)
______ C:\Program Files\Dell Photo AIO Printer 922\dlbtbmgr.exe (2808)
______ C:\Program Files\Dell Photo AIO Printer 926\dlcxmon.exe (256)
______ C:\Program Files\Dell Photo AIO Printer 926\memcard.exe (248)
______ C:\Program Files\Common Files\Real\Update_OB\realsched.exe (268)
______ C:\Program Files\Dell Support Center\bin\sprtcmd.exe (252)
______ C:\Program Files\iTunes\iTunesHelper.exe (3812)
______ C:\Windows\System32\rundll32.exe (3056)
______ C:\Program Files\Kontiki\KHost.exe (3420)
______ C:\Program Files\Java\jre6\bin\jusched.exe (2472)
______ C:\Windows\System32\rundll32.exe (156)
______ C:\Program Files\Dell Photo AIO Printer 922\dlbtbmon.exe (2796)
______ C:\Program Files\DellSupport\DSAgnt.exe (904)
______ C:\Windows\ehome\ehtray.exe (2920)
______ C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe (3172)
______ C:\Program Files\TomTom HOME 2\TomTomHOMERunner.exe (3440)
______ C:\Program Files\Sony\Sony Picture Utility\VolumeWatcher\SPUVolumeWatcher.exe (3496)
______ C:\Program Files\Microsoft Office\Office12\ONENOTEM.EXE (3288)
______ C:\Windows\ehome\ehmsas.exe (1520)
______ C:\Windows\system32\wuauclt.exe (3820)
______ C:\Program Files\iPod\bin\iPodService.exe (4420)
______ C:\Windows\Explorer.exe (3404)
______ C:\Windows\System32\mobsync.exe (4900)
______ C:\Windows\system32\SearchProtocolHost.exe (5084)
______ C:\Windows\system32\SearchFilterHost.exe (5268)
______ C:\Windows\system32\SearchProtocolHost.exe (1680)
______ C:\Windows\system32\DllHost.exe (1084)
______ C:\Windows\system32\DllHost.exe (6032)
______ C:\Users\Ammar\Desktop\Rooter.exe (5440)
----------------------\\ Device\Harddisk0\
\Device\Harddisk0 [Sectors : 63 x 512 Bytes]
\Device\Harddisk0\Partition1 (Start_Offset:32256 | Length:57544704)
\Device\Harddisk0\Partition2 (Start_Offset:57671680 | Length:10737418240)
\Device\Harddisk0\Partition3 --[ MBR ]-- (Start_Offset:10795089920 | Length:309276442624)
----------------------\\ Scheduled Tasks
C:\Windows\Tasks\Google Software Updater.job
C:\Windows\Tasks\SA.DAT
C:\Windows\Tasks\SCHEDLGU.TXT
----------------------\\ Registry
----------------------\\ Files & Folders
----------------------\\ Scan completed at 21:38.44
C:\Rooter$\Rooter_2.txt - (23/10/2009 | 21:38.44)
kevin the bird
OS : vista
Post by Dr Jay on Sat Oct 24, 2009 12:18 am
Please download F-Secure's Blacklight from [You must be registered and logged in to see this link.]
  • Double-click blbeta.exe then accept the agreement.
  • click > scan then > next,
  • You'll see a list of all items found.
  • Don't choose for rename yet! I want to see the log first, because legit items can also be present there...
  • There must be also a log on your desktop with the name fsbl.xxxxxxx.log (the xxxxxxx stand for numbers)
  • Post the contents of the log in your next reply.
Post by kevin the bird on Sat Oct 24, 2009 6:04 pm
Here's the Blacklight log:
10/24/09 18:47:21 [Info]: BlackLight Engine 2.2.1092 initialized
10/24/09 18:47:21 [Info]: OS: 6.0 build 6001 (Service Pack 1)
10/24/09 18:47:21 [Note]: 7019 4
10/24/09 18:47:21 [Note]: 7005 0
10/24/09 18:47:24 [Note]: 7006 0
10/24/09 18:47:24 [Note]: 7027 0
10/24/09 18:47:24 [Note]: 7035 0
10/24/09 18:47:24 [Note]: 7026 0
10/24/09 18:47:26 [Note]: FSRAW library version 1.7.1024
10/24/09 18:48:30 [Note]: 4015 1438
10/24/09 18:48:30 [Note]: 4027 1438 65536
10/24/09 18:48:30 [Note]: 4020 1389 65536
10/24/09 18:48:30 [Note]: 4018 1389 65536
10/24/09 19:03:06 [Note]: 7007 0
It did, however say at the end that no hȋdden items were found
kevin the bird
OS : vista
Post by Dr Jay on Sat Oct 24, 2009 9:07 pm
Post by kevin the bird on Sun Oct 25, 2009 2:13 pm
Here's the Malwarebytes log:
Database version: 3029
25/10/2009 14:08:22
mbam-log-2009-10-25 (14-08-22).txt
Objects scanned: 251380
Time elapsed: 53 minute(s), 15 second(s)
Registry Keys Infected: 2
Registry Values Infected: 5
Folders Infected: 1
Files Infected: 5
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{9034a523-d068-4be8-a284-9df278be776e} (Trojan.Zlob) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Antivirus (Rogue.AntiVirus) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\New Windows\Allow\*.safetyincludes.com (Trojan.Zlob) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\New Windows\Allow\*.securemanaging.com (Trojan.Zlob) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\New Windows\Allow\*.securewebinfo.com (Trojan.Zlob) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\searchurl (Trojan.Zlob) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\SearchUrl\w\(default) (Trojan.Zlob) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Internet Explorer\SearchURL (Hijack.SearchPage) -> Bad: (http://internetsearchservice.com) Good: (http://www.Google.com/) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\SearchUrl\w\(default) (Hijack.SearchPage) -> Bad: (http://internetsearchservice.com/search?q=%s) Good: (http://www.Google.com/) -> Quarantined and deleted successfully.
C:\Windows\System32\377186 (Trojan.BHO) -> Quarantined and deleted successfully.
C:\Qoobox\Quarantine\C\Windows\System32\cngaudit.dll.vir (Trojan.Sirefef) -> Quarantined and deleted successfully.
C:\Users\Ammar\Documents\My Music\My Music.url (Trojan.Zlob) -> Quarantined and deleted successfully.
C:\Users\Ammar\Documents\My Pictures\My Pictures.url (Trojan.Zlob) -> Quarantined and deleted successfully.
C:\Users\Ammar\Documents\My Videos\My Video.url (Trojan.Zlob) -> Quarantined and deleted successfully.
C:\Windows\win32k.sys (Trojan.Dropper) -> Quarantined and deleted successfully.
kevin the bird
OS : vista
Post by Belahzur on Sun Oct 25, 2009 6:44 pm
ComboFix /u
Post by kevin the bird on Sun Oct 25, 2009 10:29 pm
When I try and enter the text, it says Windows can't find 'ComboFix' eventhough it's saved to my desktop
kevin the bird
OS : vista
Post by kevin the bird on Sun Oct 25, 2009 10:33 pm
Oops dw, managed to work it ;)
Everything seems to be running fine now, I think the virus has been deleted.
Thx so much for your help Smile
kevin the bird
OS : vista
