Antivirus Pro 2010 HELP!!!!
Page 1 of 1
- Mele422Beginner
OS : XP
Rubies : 3107
This nasty thing Antivirus Pro 2010 has wormed its way onto my PC. I have tried Malwarebytes, Spyware Doctor and doing some manual digging to try and get it off. Nothing works and everytime I run the spyware and reboot the system is comes back. Where is this thing hiding and how do I get it off?? Any little bit of advice is much appreciated!! Thanks
- Dr JayHead Admin
Power of Youth!
OS : Windows 10 Home & Pro, Android, Linux
Arch. : x64 (64-bit)
Anti-Malware : Bitdefender Total Security
Rubies : 289567
Welcome to GeekPolice. We are here to save you money. Our expertise here can help you get rid of threats.
From this point on, please do not make any more changes to your computer; such as install/uninstall programs, use special fix tools, delete files, edit the registry, etc. - unless advised by a Tech Staff member, administrator, or moderator. Please do not ask for help elsewhere (in this site or other sites). Doing so can result in system changes, which may not show up in the logs you post.
As this topic is for you only, I just need to issue a warning to outside readers:
Warning: Instructions issued in this topic are for this user only. We are not responsible for damages, so if you need help; please register for this site, and start a new topic requesting help.
Please download ComboFix
from BleepingComputer.com
- Disable your AntiVirus and AntiSpyware applications, usually via a right click on the System Tray icon. They may otherwise interfere with our tools A guide to do this can be found here
- Click Start>Run then copy paste the following command into the Run box & click OK "%userprofile%\desktop\commy.exe" /stepdel
- As part of it's process, ComboFix will check to see if the Microsoft Windows Recovery Console is installed. With malware infections being as they are today, it's strongly recommended to have this pre-installed on your machine before doing any malware removal. It will allow you to boot up into a special recovery/repair mode that will allow us to more easily help you should your computer have a problem after an attempted removal of malware.
- Follow the prompts to allow ComboFix to download and install the Microsoft Windows Recovery Console, and when prompted, agree to the End-User License Agreement to install the Microsoft Windows Recovery Console
- Click on Yes, to continue scanning for malware.
- When finished, it shall produce a log for you. Please include the contents of C:\ComboFix.txt in your next reply.
Similar topics
Page 1 of 1
