Antivirus System Pro alert
Post by moneydr1 on Tue Oct 20, 2009 3:24 am
On a computer I'm not typing on, I have multiple windows open indicating a virus.
Windows titled:
Windows Security alert
Security Warning
Spywaare Alert!
Windows are opening up with porn site URLs but IE says it cannot display the webpage.
How do I get rid of this stuff??? Thanks!
moneydr1
Joined Joined : 2009-10-20
Points Points : 26023
Re: Antivirus System Pro alert
Post by Dr Jay on Tue Oct 20, 2009 5:20 am
Welcome to GeekPolice. We are here to save you money. Our expertise here can help you get rid of threats.
From this point on, please do not make any more changes to your computer; such as install/uninstall programs, use special fix tools, delete files, edit the registry, etc. - unless advised by a Tech Staff member, administrator, or moderator. Please do not ask for help elsewhere (in this site or other sites). Doing so can result in system changes, which may not show up in the logs you post.
As this topic is for you only, I just need to issue a warning to outside readers:
Roger that Warning: Instructions issued in this topic are for this user only. We are not responsible for damages, so if you need help; please register for this site, and start a new topic requesting help.
Posts Posts : 13713
Points Points : 302059
