How to remove Antivirus System Pro
Post by celluvisc on Tue 20 Oct 2009, 11:24 am
Help!!! Somehow my computer has been infected by Antivirus System Pro. I need to remove it somehow. It is constantly blocking my programs and popping up millions of alerts. I need to remove it I have tried the pc doctor, but it blocks the program. Can anyone help me?
Operating System : Vista
Re: How to remove Antivirus System Pro
Post by DragonMaster Jay on Tue 20 Oct 2009, 12:41 pm
Welcome to GeekPolice. We are here to save you money. Our expertise here can help you get rid of threats.
From this point on, please do not make any more changes to your computer; such as install/uninstall programs, use special fix tools, delete files, edit the registry, etc. - unless advised by a Tech Staff member, administrator, or moderator. Please do not ask for help elsewhere (in this site or other sites). Doing so can result in system changes, which may not show up in the logs you post.
As this topic is for you only, I just need to issue a warning to outside readers:
Warning: Instructions issued in this topic are for this user only. We are not responsible for damages, so if you need help; please register for this site, and start a new topic requesting help.
Please download ComboFix from
GeekPolice Academy Manager
DragonMaster Jay
Manager | Tech Officer
