Alpha Antivirus problem
Post by sharon starnes on Sun Oct 18, 2009 9:30 pm
Alpha has inserted itself into our system and we are unable to get it out. HP told us we could contact this site for removal help. What do I need to do? Thank you
sharon starnes
OS : vista
Re: Alpha Antivirus problem
Post by Belahzur on Sun Oct 18, 2009 9:53 pm
Post by maxandtheborrowers on Mon Oct 19, 2009 4:01 pm
Moderated Message: Hello, your comment has been removed. Please do not post in another member's topic. If you need help, please read [You must be registered and logged in to see this link.] over and [You must be registered and logged in to see this link.] to open a new topic. ~DragonMaster Jay
maxandtheborrowers
OS : vista
Post by solocanoejake on Mon Oct 19, 2009 10:00 pm
solocanoejake
OS : Vista
alpha antivirus...now what?
Post by chris1 on Tue Oct 20, 2009 12:26 am
chris1
OS : vista
Post by Dr Jay on Tue Oct 20, 2009 1:50 am
Hi Sharon
OS : Windows 10 Home & Pro
