System infected - spyware removal tool
Post by NickSpil on Sun Oct 18, 2009 4:42 am
Hello, please help me!
I'm posting from another laptop because I cannot get through mine. Task manager does not operate and it cannot start on a safe mode. I use Windows XP. When I turn on my laptop, it is showing not the usual desktop but in the center a small black box with red letters stating the following: YOUR SYSTEM IS INFECTED! System has been stopped due to a serious malfunction. Spyware activity has been detected. It is recommended to use spyware removal tool to prevent data loss. Do not use the computer before all spyware removed. What can I do to heel it? Sad tearing
NickSpil
Joined Joined : 2009-10-17
Points Points : 26064
Re: System infected - spyware removal tool
Post by Belahzur on Sun Oct 18, 2009 2:57 pm
Points Points : 245059
Post by NickSpil on Sun Oct 18, 2009 7:46 pm
Sorry! I downloaded hijackThis, but when I click in Install, it does nothing (doesn't install it). What else do you recommend?
NickSpil
Post by Belahzur on Sun Oct 18, 2009 9:44 pm
  • Copy and paste DDS.txt back here, I don't need to see attach.txt just yet.
