DVD-RW Drive E will not Eject
Post by VixisX on 17th October 2009, 3:11 pm
I was wondering if I have a conflict with another program. My DVD-RW Drive E will not open by pressing the button on the computer for a long time mow, and will not open if i go to "my computer" and click on eject. I'm not sure what's going on with this. My other drive ejects fine. The only way I can open the drive is to use Nero and ejecting the disk using this program. But even this doesn't work 100% all the time. I was wondering if you can check for a conflict with my programs, or How I can reslove this issue.
Thanks in advance...
VixisX
Posts Posts : 50
Joined Joined : 2009-06-03
Points Points : 27644
Re: DVD-RW Drive E will not Eject
Post by Dr Jay on 17th October 2009, 8:51 pm
You may have a faulty button on your DVD drive. That is nothing big, as a local computer repair shop can fix that.
However, the reason why only Nero can eject the drive, is because it does not press the button, it just activates the file necessary to open the drive.
Posts Posts : 14309
Points Points : 302960
Post by VixisX on 17th October 2009, 9:12 pm
Is there a way to verify i do not have a software conflict with my driver. When i go to "my COmputer" and hit the eject icon, the drive will not open; and it only opens sometimes with Nero... is this a driver problem than?
VixisX
Posts Posts : 50
Post by Dr Jay on 17th October 2009, 9:59 pm
I will take a closer look.
Please download the latest version of Kaspersky GetSystemInfo (GSI) from Kaspersky.fr and save it to your Desktop.
  • Please close all other applications running on your system.
  • Please double click GetSystemInfo.exe to open it.
  • Click the Settings button.
  • Set it to Maximum
  • IMPORTANT! Then please click Customize - choose Driver / Ports tab and
  • Uncheck Scan Ports.
  • Click Create Report to run it.
  • It will create a zip folder called GetSystemInfo_XXXXXXXXXXXXXX.zip on your Desktop. Please upload the folder to Kaspersky GSI Parser and click the Submit button.
Posts Posts : 14309
Post by VixisX on 18th October 2009, 4:22 am
VixisX
Posts Posts : 50
Post by Dr Jay on 18th October 2009, 9:47 pm
Please read this over and click here to open a new topic in the malware forum. As I was looking at the Kaspersky GSI, I noticed a rootkit. Which may be the reason why your DVD drive button is not functioning.
Once you open the new topic, please copy (select all of the URL and right-click and select Copy) the URL that is in the address bar of this topic, and paste (right-click and select paste) it in the new topic in the malware forum.
Posts Posts : 14309
Post by VixisX on 1st November 2009, 3:55 pm
Done...
VixisX
Posts Posts : 50
