Thermal cooling for Athlon 64
Solved Thermal cooling for Athlon 64
Post by pcuser on 4th March 2008, 11:11 am
I recently bought a new mobo with a boxed AMD 64 3500 CPU. When I enquired about thermal paste the shop I purchased them from said I didnít require any - just use the thermal pad. However, all the articles Iíve read recommend the use of paste. Therefore, do I scratch the thermal pad off and use paste, use the paste in addition to the pad or can I get by with just the thermal pad? I donít intend to overclock it.
pcuser
Posts Posts : 119
Joined Joined : 2008-01-12
OS OS : XP and others
Points Points : 32720
Solved Re: Thermal cooling for Athlon 64
Post by Doctor Inferno on 4th March 2008, 11:11 am
AMD is specific about which thermal compounds it recommends. While thermal pads are recommended for lidless CPUs like Athlon, Athlon XP and Duron chips, lidded processors like the Athlon 64 should have a thin layer of paste applied to the lid prior to fitting the heatsink to it.
If you purchased the boxed version of the Athlon 64, and it came with the cooling system supplied, the thermal compound provided will be perfectly adequate, especially as you donít intend to make excessive demands of your CPU.
If you ever did want to increase the demands of your CPU, familiarise yourself with heatsink removal and cleaning. You should never mix different thermal compounds, so you would also need to clean both CPU and heatsink before applying new thermal paste. AMD provides detailed videos for both processes at www.amd.com/uk/HPBodySystemComponent/.
Points Points : 104610
Post by TeReX on 5th March 2008, 9:57 am
nice info doctor.
Points Points : 32491
