Antivirus System Pro Removal problems
Post by DrSquishie on 15th October 2009, 1:36 am
I have read the forum for the removal of this Virus, I am having the problem when i download the removal program "Application cannot be executed. The file mbam.exe is Infected. Do you want to activate Antivirul Software now?" I cannot get passed that i also cannot get into SafeMode to load it either it starts to load then resets my comp. I dont know what to do.
DrSquishie
DrSquishie
Posts Posts : 8
Joined Joined : 2009-10-15
Points Points : 26152
Re: Antivirus System Pro Removal problems
Post by Belahzur on 15th October 2009, 4:52 pm
Points Points : 245101
