Unwanted Hewlett and Packard problem
Solved Unwanted Hewlett and Packard problem
Post by pb1947 on 6th October 2009, 4:33 am
can any one help me to remove two very annoying HP popups. I have tried to get around this on the HP site, and guess what, my Query was deleted from their forum.
when my system starts up I get an extremely annoying blue HP balloon popup in the lower right corner of my display stating my HP photosmart C4200 printer is ready. Sounds harmless enough, but this popup compromises my security and has created big problems on my startup, ie my security is held closed until the HP file executes, so I then get a systray balloon that tells me that my firewall is closed, this is only a lag of 500 milliseconds before the firewall then opens does its job, It also prevents me from opening internet explorer and running some other programs until the hp popup appears and the same is closed, this HP rubbish happens well into startup and I have to sit there and wait before I can fully use my OS.
For the trouble this has caused (Thank you HP for destroying the integrety of my system) I am prepared to throw my Photosmart printer into the round filing cabinet (rubbish bin) and buy an Epsom like I should have done in the first place
My advice to other people who get sucked in to a HP Printer is to be aware that HP will write heaps of crap programs to run their annoying advertising popups with out any regards to your private property (computer), this will happen when you do current driver upgrades and totally without your permission.
the other problem is every time I print I get the other annoying HP ink cartridge popup.
If anyone can help me remove the HP software for these popups I would greatly appreciate it.
Cheers PB
ps, thumbs up to Belzahur for the time and devotion in helping people, thanks mate for solving extreme virus problems for me
pb1947
Posts Posts : 44
Joined Joined : 2009-06-22
OS OS : Windows 10
Protection Protection : Vipre + MalwareBytes Pro
Points Points : 27793
Solved Re: Unwanted Hewlett and Packard problem
Post by Doctor Inferno on 6th October 2009, 11:26 am
We can try removing a startup item. Please post your HijackThis log here.
Points Points : 104640
Solved HP popups :- log file hijack this
Post by pb1947 on 6th October 2009, 11:46 am
@Doctor Inferno wrote:Hello,
Scan saved at 10:34:26 PM, on 6/10/2009
Hi Doc, thanking you for your assistance, cheers PB (pete)
C:\windows\System32\smss.exe
C:\windows\system32\winlogon.exe
C:\windows\system32\services.exe
C:\windows\system32\lsass.exe
C:\windows\system32\nvsvc32.exe
C:\windows\system32\svchost.exe
C:\windows\System32\svchost.exe
C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe
C:\windows\system32\spoolsv.exe
C:\Program Files\Creative\Shared Files\CTAudSvc.exe
C:\windows\Explorer.EXE
C:\windows\RTHDCPL.EXE
C:\windows\system32\RUNDLL32.EXE
C:\Program Files\Eset\nod32kui.exe
C:\Program Files\Common Files\ACD Systems\EN\DevDetect.exe
C:\windows\system32\CTHELPER.EXE
C:\Program Files\Lavasoft\Ad-Aware\AAWTray.exe
C:\windows\system32\ctfmon.exe
C:\windows\system32\CTsvcCDA.exe
C:\Program Files\isposure\IsposureAgent.exe
C:\Program Files\Nero\Nero8\Nero BackItUp\NBService.exe
C:\Program Files\Eset\nod32krn.exe
C:\WINDOWS\system32\IoctlSvc.exe
C:\Program Files\TomTom HOME 2\TomTomHOMEService.exe
C:\Program Files\HP\Digital Imaging\bin\hpqbam08.exe
C:\windows\system32\wuauclt.exe
C:\utils\hijackThis\hijackgpthis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.bigpond.com/homepage/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
O2 - BHO: HP Smart Web Printing 1.0 - {AE84A6AA-A333-4B92-B276-C11E2212E4FE} - C:\Program Files\HP\Smart Web Printing\SmartWebPrinting.dll
O2 - BHO: Google Toolbar Notifier BHO - {AF69DE43-7D58-4638-B6FA-CE66B5AD205D} - C:\Program Files\Google\GoogleToolbarNotifier\5.3.4501.1418\swg.dll
O3 - Toolbar: FreshDownload Bar - {ED0E8CA5-42FB-4B18-997B-769E0408E79D} - (no file)
O4 - HKLM\..\Run: [nwiz] C:\Program Files\NVIDIA Corporation\nView\nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\windows\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\windows\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nod32kui] "C:\Program Files\Eset\nod32kui.exe" /WAITSERVICE
O4 - HKLM\..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Nero\Lib\NeroCheck.exe
O4 - HKLM\..\Run: [NBKeyScan] "C:\Program Files\Nero\Nero8\Nero BackItUp\NBKeyScan.exe"
O4 - HKLM\..\Run: [Device Detector] DevDetect.exe -autorun
O4 - HKLM\..\Run: [CTHelper] CTHELPER.EXE
O4 - HKLM\..\Run: [Adobe Reader Speed Launcher] "C:\Program Files\Adobe\Reader 9.0\Reader\Reader_sl.exe"
O4 - HKLM\..\Run: [Ad-Watch] C:\Program Files\Lavasoft\Ad-Aware\AAWTray.exe
O4 - HKCU\..\Run: [ctfmon.exe] C:\windows\system32\ctfmon.exe
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\system32\CTFMON.EXE (User 'Default user')
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: FreshDownload - {87989A8E-F587-43A4-9315-34A4E4F4B3F9} - C:\windows\system32\shdocvw.dll
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\windows\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\windows\Network Diagnostic\xpnetdiag.exe
O16 - DPF: {0742B9EF-8C83-41CA-BFBA-830A59E23533} (Microsoft Data Collection Control) - https://support.microsoft.com/OAS/ActiveX/MSDcode.cab
O16 - DPF: {1E54D648-B804-468d-BC78-4AFFED8E262F} (System Requirements Lab) - http://www.nvidia.com/content/DriverDownload/srl/3.0.0.4/srl_bin/sysreqlab_nvd.cab
O16 - DPF: {5727FF4C-EF4E-4d96-A96C-03AD91910448} (System Requirements Lab) - http://www.srtest.com/srl_bin/sysreqlab_ind.cab
O16 - DPF: {6E32070A-766D-4EE6-879C-DC1FA91D2FC3} (MUWebControl Class) - http://update.microsoft.com/microsoftupdate/v6/V5Controls/en/x86/client/muweb_site.cab?1243504952390
O16 - DPF: {74DBCB52-F298-4110-951D-AD2FF67BC8AB} (NVIDIA Smart Scan) - http://www.nvidia.com/content/DriverDownload/nforce/NvidiaSmartScan.cab
O16 - DPF: {935F9B04-0C7B-4454-A391-348C54AD7ADD} (Jolly Bear Games Player) - http://games.bigfishgames.com/en_big-city-adventure-sydney-australia/online/JBGamePlayer.cab
O16 - DPF: {CF40ACC5-E1BB-4AFF-AC72-04C2F616BCA7} -
O16 - DPF: {DF780F87-FF2B-4DF8-92D0-73DB16A1543A} (PopCapLoader Object) - http://aolsvc.aol.com/onlinegames/bejeweled2/popcaploader_v10.cab
O16 - DPF: {F6ACF75C-C32C-447B-9BEF-46B766368D29} (Creative Software AutoUpdate Support Package) - http://ccfiles.creative.com/Web/softwareupdate/su2/ocx/15108/CTPID.cab
O23 - Service: Creative Audio Engine Licensing Service - Creative Labs - C:\Program Files\Common Files\Creative Labs Shared\Service\CTAELicensing.exe
O23 - Service: Creative Service for CDROM Access - Creative Technology Ltd - C:\windows\system32\CTsvcCDA.exe
O23 - Service: Creative Audio Service (CTAudSvcService) - Creative Technology Ltd - C:\Program Files\Creative\Shared Files\CTAudSvc.exe
O23 - Service: IsposureAgent (isposure_svc) - Epitiro Ltd. - C:\Program Files\isposure\IsposureAgent.exe
O23 - Service: Lavasoft Ad-Aware Service - Lavasoft - C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe
O23 - Service: Nero BackItUp Scheduler 3 - Nero AG - C:\Program Files\Nero\Nero8\Nero BackItUp\NBService.exe
O23 - Service: NMIndexingService - Nero AG - C:\Program Files\Common Files\Nero\Lib\NMIndexingService.exe
O23 - Service: NOD32 Kernel Service (NOD32krn) - Eset - C:\Program Files\Eset\nod32krn.exe
O23 - Service: nProtect GameGuard Service (npggsvc) - Unknown owner - C:\windows\system32\GameMon.des.exe (file missing)
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\windows\system32\nvsvc32.exe
O23 - Service: PLFlash DeviceIoControl Service - Prolific Technology Inc. - C:\WINDOWS\system32\IoctlSvc.exe
O23 - Service: TomTomHOMEService - TomTom - C:\Program Files\TomTom HOME 2\TomTomHOMEService.exe
End of file - 10643 bytes
pb1947
Posts Posts : 44
OS OS : Windows 10
Post by Doctor Inferno on 7th October 2009, 9:30 am
Please fix these lines:
If you want fast startup, you can fix these lines:
Post by pb1947 on 7th October 2009, 1:42 pm
Thanks very much Doc. I asked for help with a fix, not only did you do that you also gave me the bonus of speeding up my startup. It goes like greased lightning now and no more rotten HP Popups. you will definitely be hearing from me on the donation page. I would have in the end taken this to the computer shop and would have paid through the nose for the fix.
cheers to yourself and once again thanks, you people are legends
PB (pete)
ps hehe I made a typo on Belahzur's name on the first post, hope he doesn't mind, lol, a thumbs down to me for that one
pb1947
Posts Posts : 44
OS OS : Windows 10
Post by Doctor Inferno on 8th October 2009, 1:37 am
I've seen typos for his name many times, I think he doesn't mind. Goofy
Glad i could help. Smile
