LAMP Problem
LAMP Problem
Post by Windows.7.Tester on Sun 04 Oct 2009, 6:04 am
Hello, I have successfully installed LAMP, which for you that don't know is Linux Apache PHP & MySQL, and I have the /var/www folder but in that folder is the index.html file that has the It Works! text just to let you know if you installed it right, which I did, but I can not edit, delete or rename and file that I put in the /var/www directory, can someone please tell me how to fix this and let me edit and rename and delete the files in that directory?
Windows.7.Tester
Operating System : Windows XP Professional Corporate Key - Ubuntu 9.04
