my explorer doesnt work and having problem with malware
Post by HoldR4D on 3rd October 2009, 6:42 am
im new to the webpage...
i am sure i have acouple of trojans and spyware, my explorer doesnt work and when i try to put it in task manager file its not found in order for me to used my internet browser i have to punch it in task manager. i try to run the malware program and it doesnt work , just comes up in the task manager but doesnt pop up please help
HoldR4D
Posts Posts : 53
Joined Joined : 2009-10-03
OS OS : windows XP
Points Points : 26317
Re: my explorer doesnt work and having problem with malware
Post by Dr Jay on 3rd October 2009, 8:47 am
Hi
Restore Permissions for explorer.exe
Please download [You must be registered and logged in to see this link.] by sUBs
  1. Drag and drop explorer.exe onto Inherit
  2. This shall restore permissions to the application
  3. The application should now run normally
Please indicate in your next post if this was successful.
Please download ComboFix by sUBs
[You must be registered and logged in to see this link.] or [You must be registered and logged in to see this link.]
Please save the file to your Desktop, but rename it first:
Important information about ComboFix
Before the download:
  • Please copy and paste these instructions to Notepad and save to your Desktop, or print them - for easier access.
  • It is important to rename ComboFix before the download.
  • Please do not rename ComboFix to other names, but only the one indicated.
After the download:
  • Close any open browsers.
  • Very Important: Temporarily disable your anti-virus, script blocking and any anti-malware real-time protection before performing a scan. They can interfere with ComboFix or remove some of its embedded files which may cause "unpredictable results". [You must be registered and logged in to see this link.] if you don't know how.
  • WARNING: Combofix will disconnect your machine from the Internet as soon as it starts
  • Please do not attempt to re-connect your machine back to the Internet until ComboFix has completely finished.
  • If there is no Internet connection after running ComboFix, then restart your computer to restore back your connection.
Running ComboFix:
  • Double click on svchost.exe & follow the prompts.
  • It will attempt to install the Recovery Console:
  • When ComboFix finishes, it will produce a report for you.
  • Please post the "C:\Combo-Fix.txt" in your next reply.
Troubleshooting ComboFix
Safe Mode:
If you still cannot get ComboFix to run, try booting into Safe Mode, and run it there.
(To boot into Safe Mode, tap F8 after BIOS, and just before the Windows
logo appears. A list of options will appear, select "Safe Mode.")
Re-downloading:
If this doesn't work either, try the same method (above method), but try to download it again, except name
ComboFix.exe to iexplore.exe, explorer.exe, or winlogon.exe.
Malware is known for blocking all "user" processes, except for its whitelist of system important processes such as iexplore.exe, explorer.exe, winlogon.exe.
Posts Posts : 14309
Points Points : 302960
Post by HoldR4D on 10th October 2009, 12:14 am
i am trying to do it but i cant seem to shut down cyberdefender because i dont have no icons or task bar im workin everything directly thru task manager, how can i shut down cyberdefender thru task manager
HoldR4D
Posts Posts : 53
OS OS : windows XP
Post by Dr Jay on 10th October 2009, 6:07 am
Hi
ComboFix can do it for you. Go ahead and run ComboFix.
Posts Posts : 14309
Post by HoldR4D on 12th October 2009, 6:10 am
i appreciate you helping me but combofix deleted alot of stuff but the inherit doesnt work and everything its still the same
HoldR4D
Posts Posts : 53
OS OS : windows XP
Post by Dr Jay on 12th October 2009, 6:22 am
Hi
Ok. Please post the ComboFix log and we will go from there.
Posts Posts : 14309
Post by HoldR4D on 12th October 2009, 11:50 pm
hi
sorry im trying to look for the combofix txt and it doesnt appear in the c drive or no other place
HoldR4D
Posts Posts : 53
OS OS : windows XP
Post by Dr Jay on 13th October 2009, 2:45 am
Kitty ate it. No way!
Please re-run ComboFix and post a log.
Posts Posts : 14309
Post by HoldR4D on 13th October 2009, 3:58 am
lmao good one
ComboFix 09-10-12.03 - Administrator 10/12/2009 23:43.5.2 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.1022.742 [GMT -4:00]
Running from: c:\documents and settings\Administrator\My Documents\ComboFix.exe
AV: CyberDefender Internet Security *On-access scanning enabled* (Updated) {925FF895-595E-4ED4-BB84-E12C72FBA43A}
c:\windows\system32\config\systemprofile\Application Data\3781678402
c:\windows\system32\config\systemprofile\Application Data\3781678402\3781678402.bat
c:\windows\system32\config\systemprofile\Application Data\3781678402\3781678402.cfg
c:\windows\system32\config\systemprofile\Application Data\3781678402\3781678402.exe
c:\windows\system32\config\systemprofile\Application Data\4317503905
c:\windows\system32\config\systemprofile\Application Data\4317503905\4317503905.bat
c:\windows\system32\config\systemprofile\Application Data\4317503905\4317503905.cfg
c:\windows\system32\config\systemprofile\Application Data\4317503905\4317503905.exe
-- Previous Run --
-- Previous Run --
-- Previous Run --
c:\windows\system32\drivers\beep.sys . . . is infected!!
c:\windows\system32\proquota.exe . . . is missing!!
c:\windows\system32\proquota.exe was missing
Restored copy from - c:\windows\ServicePackFiles\i386\proquota.exe
-------\Legacy_NWCWORKSTATION
-------\Legacy_UACd.sys
-------\Legacy_VUEFFLHEPIZ
-------\Service_NWCWorkstation
-------\Service_UACd.sys
-------\Service_vuefflhepiz
((((((((((((((((((((((((( Files Created from 2009-09-13 to 2009-10-13 )))))))))))))))))))))))))))))))
2009-10-13 02:48 . 2009-10-13 02:48 -------- d-sh--w- c:\documents and settings\Administrator\IECompatCache
2009-10-13 02:16 . 2009-10-13 02:16 -------- d-----w- c:\documents and settings\Administrator\Application Data\Malwarebytes
2009-10-12 23:31 . 2008-04-14 00:12 50176 ----a-w- c:\windows\system32\proquota.exe
2009-10-12 23:31 . 2008-04-14 00:12 50176 ----a-w- c:\windows\system32\dllcache\proquota.exe
2009-10-12 04:47 . 2009-10-12 04:47 -------- d-----w- c:\documents and settings\Administrator\Application Data\AdobeUM
2009-10-10 05:33 . 2009-10-10 05:34 -------- d-----w- c:\documents and settings\Administrator\Local Settings\Application Data\Adobe
2009-10-10 00:53 . 2009-10-10 00:56 -------- d-----w- c:\documents and settings\Administrator\Tracing
2009-10-09 14:07 . 2009-10-09 14:07 -------- d-sh--w- c:\documents and settings\Administrator\PrivacIE
2009-10-09 14:07 . 2009-10-09 14:07 -------- d-sh--w- c:\documents and settings\Administrator\IETldCache
2009-10-02 18:40 . 2009-10-03 01:37 131731 ----a-w- c:\windows\system32\dbsinit.exe
2009-09-29 23:05 . 2009-10-03 04:27 -------- d-----w- c:\documents and settings\All Users\Application Data\14708904
2009-09-23 00:58 . 2009-10-03 06:54 664 ----a-w- c:\windows\system32\d3d9caps.dat
2009-09-23 00:14 . 2009-09-23 00:14 -------- d-----r- C:\MSOCache
2009-09-22 22:18 . 2009-10-01 22:59 0 ----a-w- c:\windows\system32\drivers\8ff0f6eb.sys
2009-09-22 17:03 . 2009-09-22 17:03 137248 ----a-w- c:\windows\system32\drivers\ethpqnon.sys
2009-09-22 16:49 . 2009-09-23 01:16 -------- d-----w- c:\program files\a-squared Free
2009-09-22 16:48 . 2000-07-15 04:00 101888 ----a-w- c:\windows\system32\VB6STKIT.DLL
2009-09-22 16:48 . 1998-06-18 04:00 89360 ----a-w- c:\windows\system32\VB5DB.DLL
2009-09-22 16:48 . 2009-09-22 16:48 -------- d-----w- c:\program files\MCS Studios
2009-09-22 15:57 . 2009-09-10 18:54 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-09-22 15:57 . 2009-10-03 04:29 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-09-22 15:57 . 2009-09-22 15:57 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2009-09-22 15:57 . 2009-09-10 18:53 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-09-22 15:22 . 2009-09-22 15:22 -------- d-sh--w- c:\windows\system32\config\systemprofile\PrivacIE
2009-09-22 15:21 . 2009-09-22 15:24 -------- d-----w- c:\program files\Sagasoft
2009-09-22 03:17 . 2009-09-22 03:17 -------- d-sh--w- c:\windows\system32\config\systemprofile\IETldCache
2009-09-17 04:45 . 2009-09-17 04:47 -------- d-----w- c:\windows\SxsCaPendDel
2009-09-17 04:45 . 2009-09-17 04:45 -------- d-----w- c:\program files\Microsoft
2009-09-17 04:44 . 2009-09-17 04:44 -------- d-----w- c:\program files\Windows Live SkyDrive
2009-09-17 04:44 . 2009-09-17 04:45 -------- d-----w- c:\program files\Windows Live
2009-09-17 04:42 . 2009-09-17 04:42 -------- d-----w- c:\program files\Common Files\Windows Live
2009-10-13 03:02 . 2005-07-27 23:06 384 ----a-w- c:\windows\system32\DVCStateBkp-{00000005-00000000-00000004-00001102-00000004-20061102}.dat
2009-10-13 03:02 . 2005-07-27 23:06 384 ----a-w- c:\windows\system32\DVCState-{00000005-00000000-00000004-00001102-00000004-20061102}.dat
2009-10-11 21:19 . 2009-07-11 21:19 1011451 --sha-w- c:\windows\system32\rimuwuka.exe
2009-10-10 05:30 . 2009-07-10 05:30 1011570 --sha-w- c:\windows\system32\sedutodo.exe
2009-10-01 22:49 . 2009-07-01 22:49 50176 --sha-w- c:\windows\system32\tojowebo.dll
2009-09-30 21:19 . 2009-06-30 21:19 50688 --sha-w- c:\windows\system32\yinazeku.dll
2009-09-22 15:01 . 2008-10-14 02:52 -------- d---a-w- c:\documents and settings\All Users\Application Data\TEMP
2009-09-22 03:22 . 2009-06-22 03:22 180224 --sha-w- c:\windows\system32\wimesabi.exe
2009-09-22 03:22 . 2009-06-22 03:22 44970 --sha-w- c:\windows\system32\pidokobo.exe
2009-09-09 10:50 . 2008-10-16 19:47 -------- d-----w- c:\program files\Microsoft Silverlight
2009-08-29 01:41 . 2005-12-13 16:56 -------- d-----w- c:\program files\DL_cats
2009-08-25 03:05 . 2009-08-07 00:09 -------- d-----w- c:\program files\CyberDefender
2009-08-07 00:08 . 2009-08-07 00:09 67424 ----a-w- c:\windows\system32\drivers\CDAVFS.sys
2009-08-05 09:01 . 2004-08-19 20:49 204800 ----a-w- c:\windows\system32\mswebdvd.dll
2009-07-26 20:44 . 2009-07-26 20:44 48448 ----a-w- c:\windows\system32\sirenacm.dll
2009-07-17 19:01 . 2004-08-19 20:49 58880 ----a-w- c:\windows\system32\atl.dll
2009-06-22 03:16 . 2009-06-22 03:16 49152 --sha-w- c:\windows\system32\zabufaki.dll
------- Sigcheck -------
[7] 2004-08-10 . DA1F27D85E0D1525F6621372E7B685E9 . 4224 . . [5.1.2600.0] . . c:\windows\system32\dllcache\beep.sys
[7] 2008-04-14 . 12896823FB95BFB3DC9B46BCAEDC9923 . 1033728 . . [6.00.2900.5512] . . c:\windows\ServicePackFiles\i386\explorer.exe
[-] 2007-06-13 . 7712DF0CDDE3A5AC89843E61CD5B3658 . 1033216 . . [6.00.2900.3156] . . c:\windows\$hf_mig$\KB938828\SP2QFE\explorer.exe
[-] 2007-06-13 . 97BD6515465659FF8F3B7BE375B2EA87 . 1033216 . . [6.00.2900.3156] . . c:\windows\$NtServicePackUninstall$\explorer.exe
[-] 2004-08-10 . A0732187050030AE399B241436565E64 . 1032192 . . [6.00.2900.2180] . . c:\windows\$NtUninstallKB938828$\explorer.exe
c:\windows\system32\drivers\beep.sys ... is missing !!
c:\windows\explorer.exe ... is missing !!
"DellSupport"="c:\program files\Dell Support\DSAgnt.exe" [2005-05-15 332800]
"CyberDefender Early Detection Center"="c:\program files\CyberDefender\AntiSpyware\cdas4.exe" [2009-08-25 738632]
"msnmsgr"="c:\program files\Windows Live\Messenger\msnmsgr.exe" [2009-07-26 3883856]
"ehTray"="c:\windows\ehome\ehtray.exe" [2004-08-10 59392]
"IAAnotif"="c:\program files\Intel\Intel Matrix Storage Manager\iaanotif.exe" [2005-04-25 139264]
"ATIPTA"="c:\program files\ATI Technologies\ATI Control Panel\atiptaxx.exe" [2005-04-15 344064]
"CTDVDDET"="c:\program files\Creative\SBAudigy2ZS\DVDAudio\CTDVDDET.EXE" [2003-06-18 45056]
"DLBXCATS"="c:\windows\System32\spool\DRIVERS\W32X86\3\DLBXtime.dll" [2004-12-07 69632]
"dlbxmon.exe"="c:\program files\Dell Photo AIO Printer 962\dlbxmon.exe" [2005-01-18 425984]
"HostManager"="c:\program files\Common Files\AOL\1134621263\ee\AOLSoftware.exe" [2007-10-08 41824]
"LogitechCommunicationsManager"="c:\program files\Common Files\Logitech\LComMgr\Communications_Helper.exe" [2006-10-31 284184]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2007-12-11 286720]
"SigmatelSysTrayApp"="stsystra.exe" - c:\windows\stsystra.exe [2005-03-23 339968]
Digital Line Detect.lnk - c:\program files\Digital Line Detect\DLG.exe [2005-7-27 24576]
QuickBooks Update Agent.lnk - c:\program files\Common Files\Intuit\QuickBooks\QBUpdate\qbupdate.exe [2004-11-11 806912]
[HKEY_USERS\.default\software\microsoft\windows\currentversion\policies\explorer]
"NoSetActiveDesktop"= 1 (0x1)
"NoActiveDesktopChanges"= 1 (0x1)
Authentication Packages REG_MULTI_SZ msv1_0 nwprovau
"UpdatesDisableNotify"=dword:00000001
"EnableFirewall"= 0 (0x0)
"DisableNotifications"= 1 (0x1)
"c:\\Program Files\\Common Files\\AOL\\ACS\\AOLDial.exe"=
"c:\\Program Files\\Common Files\\AOL\\ACS\\AOLacsd.exe"=
"c:\\Program Files\\America Online 9.0\\waol.exe"=
"c:\\Program Files\\Common Files\\AOL\\TopSpeed\\3.0\\aoltpsd3.exe"=
"c:\\Program Files\\Common Files\\AOL\\1134621263\\ee\\aolsoftware.exe"=
"c:\\Program Files\\Common Files\\AOL\\1134621263\\ee\\aim6.exe"=
"c:\\Program Files\\Logitech\\Desktop Messenger\\8876480\\Program\\LogitechDesktopMessenger.exe"=
"c:\\Program Files\\Common Files\\AOL\\System Information\\sinf.exe"=
"c:\\Program Files\\CyberDefender\\AntiSpyware\\cdas4.exe"=
"c:\\WINDOWS\\system32\\taskmgr.exe"=
S1 8ff0f6eb;8ff0f6eb;c:\windows\system32\drivers\8ff0f6eb.sys [9/22/2009 6:18 PM 0]
S1 ethpqnon;ethpqnon;c:\windows\system32\drivers\ethpqnon.sys [9/22/2009 1:03 PM 137248]
S3 CDAVFS;CDAVFS;c:\windows\system32\drivers\CDAVFS.sys [8/6/2009 8:09 PM 67424]
S3 MBAMSwissArmy;MBAMSwissArmy;c:\windows\system32\drivers\mbamswissarmy.sys [9/22/2009 11:57 AM 38224]
[HKEY_LOCAL_MACHINE\software\microsoft\active setup\installed components\>{60B49E34-C7CC-11D0-8953-00A0C90347FF}]
"c:\windows\system32\rundll32.exe" "c:\windows\system32\iedkcs32.dll",BrandIEActiveSetup SIGNUP
2009-09-30 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2007-08-29 19:57]
IE: E&xport to Microsoft Excel - c:\progra~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
Handler: bwfile-8876480 - {9462A756-7B47-47BC-8C80-C34B9B80B32B} - c:\program files\Logitech\Desktop Messenger\8876480\Program\GAPlugProtocol-8876480.dll
BHO-{3a62e784-ae46-41b1-8d0f-9ed0c997a7a7} - jozoyona.dll
Toolbar-{A26503FE-B3B8-4910-A9DC-9CBD25C6B8D6} - (no file)
SharedTaskScheduler-{4898af56-8acc-4ba4-910b-7036670def8f} - (no file)
SharedTaskScheduler-{ea95e221-9dc1-4ff2-bcde-1e6ff2686414} - (no file)
SharedTaskScheduler-{3808b5ad-e46c-4723-a7ee-0e204d926ba0} - (no file)
SharedTaskScheduler-{6e89ab01-e1e6-40c6-bb66-e3ee4a72790f} - (no file)
SharedTaskScheduler-{8b7e0aca-a276-4f12-84e4-15b6c99bfb42} - (no file)
SharedTaskScheduler-{bb5265d6-0d0a-47a3-a583-c2839a981f48} - (no file)
SharedTaskScheduler-{89ebf313-1187-4329-bb28-a0ef91863bbb} - (no file)
SharedTaskScheduler-{c714a17e-3abf-4b06-bf7e-fa0ead49ed5e} - (no file)
SharedTaskScheduler-{2ece87bc-8976-4db2-b183-1c60718368c7} - (no file)
SharedTaskScheduler-{0a3d1923-efb6-4c84-9740-5758e5ce34ba} - (no file)
SSODL-loliteton-{4898af56-8acc-4ba4-910b-7036670def8f} - (no file)
SSODL-fezakuhuy-{ea95e221-9dc1-4ff2-bcde-1e6ff2686414} - (no file)
SSODL-vadeyamov-{3808b5ad-e46c-4723-a7ee-0e204d926ba0} - (no file)
SSODL-wikowosiy-{6e89ab01-e1e6-40c6-bb66-e3ee4a72790f} - (no file)
SSODL-fehubiwah-{8b7e0aca-a276-4f12-84e4-15b6c99bfb42} - (no file)
SSODL-binutikug-{bb5265d6-0d0a-47a3-a583-c2839a981f48} - (no file)
SSODL-hukoyifiz-{89ebf313-1187-4329-bb28-a0ef91863bbb} - (no file)
SSODL-zuwedumas-{c714a17e-3abf-4b06-bf7e-fa0ead49ed5e} - (no file)
SSODL-kujidahok-{2ece87bc-8976-4db2-b183-1c60718368c7} - (no file)
SSODL-wenuyalud-{0a3d1923-efb6-4c84-9740-5758e5ce34ba} - (no file)
Notify-__c004D466 - c:\windows\system32\__c004D466.dat
Rootkit scan 2009-10-12 23:49
scanning hȋdden processes ...
DLBXCATS = rundll32 c:\windows\System32\spool\DRIVERS\W32X86\3\DLBXtime.dll,_RunDLLEntry@16???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
scanning hȋdden files ...
hȋdden files: 0
[HKEY_USERS\.Default\Software\Microsoft\Internet Explorer\User Preferences]
@Denied: (2) (LocalSystem)
"88D7D0879DAB32E14DE5B3A805A34F98AFF34F5977"=hex:01,00,00,00,d0,8c,9d,df,01,15,
d1,11,8c,7a,00,c0,4f,c2,97,eb,01,00,00,00,44,5c,8d,03,37,4c,d2,4d,aa,20,0e,\
"2D53CFFC5C1A3DD2E97B7979AC2A92BD59BC839E81"=hex:01,00,00,00,d0,8c,9d,df,01,15,
[HKEY_USERS\S-1-5-21-3835334267-1934715317-2934981272-500\Software\Microsoft\Internet Explorer\User Preferences]
@Denied: (2) (Administrator)
d1,11,8c,7a,00,c0,4f,c2,97,eb,01,00,00,00,a9,9c,5d,7b,36,8f,3b,41,b2,20,90,\
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{1D4C8A81-B7AC-460A-8C23-98713C41D6B3}]
@Denied: (A 2) (Everyone)
@="IFlashBroker3"
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{1D4C8A81-B7AC-460A-8C23-98713C41D6B3}\ProxyStubClsid32]
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{1D4C8A81-B7AC-460A-8C23-98713C41D6B3}\TypeLib]
"Version"="1.0"
Completion time: 2009-10-13 23:51
ComboFix-quarantined-files.txt 2009-10-13 03:51
Pre-Run: 217,697,234,944 bytes free
Post-Run: 217,673,945,088 bytes free
235 --- E O F --- 2009-09-18 16:14
HoldR4D
Posts Posts : 53
OS OS : windows XP
Post by Dr Jay on 13th October 2009, 8:00 am
Hi
  1. Close any open browsers.
    KILLALL::
    Folder::
    File::
    Rootkit::
    DDS::
    FCopy::
    c:\windows\system32\dllcache\beep.sys | C:\Windows\System32\drivers\beep.sys
    c:\windows\ServicePackFiles\i386\explorer.exe | C:\Windows\Explorer.exe
    DirLook::
Please download avast! ANTIROOTKIT from [You must be registered and logged in to see this link.] and save it to your Desktop.
Note: to prevent false positives, please quit all running programs before starting the scan!
  • Double-click on aswar.exe to start the program.
  • Click Show Scan Options.
  • Make sure the following checkboxes have checkmarks in them: hȋdden Files and Directories, hȋdden Services and Drivers, hȋdden Registry Keys and Values, hȋdden Processes, Log all scanned items.
  • Click the big Scan Now! button.
  • Click View scan log. Please post the contents of that log in your next reply. If the scan log will not launch, please tell me.
Please post the ComboFix and Avast Anti-rootkit logs in your next reply.
Posts Posts : 14309
Post by HoldR4D on 13th October 2009, 8:07 pm
avast! Antirootkit, version 0.9.6
Scan started: Tuesday, October 13, 2009 3:55:59 PM
Scan finished: Tuesday, October 13, 2009 4:03:47 PM
hȋdden files found: 0
hȋdden registry items found: 0
hȋdden processes found: 0
hȋdden services found: 0
hȋdden boot sectors found: 0
HoldR4D
Posts Posts : 53
OS OS : windows XP
Post by HoldR4D on 13th October 2009, 8:09 pm
c:\windows\system32\dllcache\beep.sys --> c:\windows\System32\drivers\beep.sys
c:\windows\ServicePackFiles\i386\explorer.exe --> c:\windows\Explorer.exe
-------\Service_8ff0f6eb
-------\Service_ethpqnon
2009-10-13 19:33 . 2008-04-14 00:12 1033728 ----a-w- c:\windows\system32\dllcache\explorer.exe
2009-10-13 19:33 . 2008-04-14 00:12 1033728 ----a-w- c:\windows\Explorer.exe
2009-10-13 19:33 . 2004-08-10 10:00 4224 ----a-w- c:\windows\system32\drivers\beep.sys
2009-10-13 19:33 . 2004-08-10 10:00 4224 ----a-w- c:\windows\system32\dllcache\beep.sys
2009-10-13 19:40 . 2005-07-27 23:06 384 ----a-w- c:\windows\system32\DVCStateBkp-{00000005-00000000-00000004-00001102-00000004-20061102}.dat
2009-10-13 19:40 . 2005-07-27 23:06 384 ----a-w- c:\windows\system32\DVCState-{00000005-00000000-00000004-00001102-00000004-20061102}.dat
(((((((((((((((((((((((((((((((((((((((((((( Look )))))))))))))))))))))))))))))))))))))))))))))))))))))))))
---- Directory of c:\windows\System32\spool\DRIVERS\W32X86\3 ----
2005-12-21 04:17 . 2007-09-28 01:08 50908 -c-ha-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxma.GID
2005-12-13 16:59 . 2008-10-14 04:05 15856 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\lxWF2000.BUD
2005-12-13 16:59 . 2003-02-06 17:09 3460 ----a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\lxWF2000.GPD
2005-12-13 16:59 . 2002-03-11 23:32 2560 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\LXWF2000.DLL
2005-12-13 16:57 . 2004-06-01 17:50 2038 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxsccp.cnT
2005-12-13 16:57 . 2004-11-01 20:03 248294 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxsccp.hlP
2005-12-13 16:56 . 2005-01-07 18:14 2041158 -c--a-r- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxuser.chm
2005-12-13 16:56 . 2005-01-04 16:25 4243 -c--a-r- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxtele.ini
2005-12-13 16:56 . 2004-11-09 19:27 65536 ----a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxcfg.dll
2005-12-13 16:56 . 2005-01-10 14:56 180224 ----a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxunst.exe
2005-12-13 16:56 . 2005-01-13 10:29 27 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxprod.ver
2005-12-13 16:56 . 2004-08-27 19:35 1748 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxprod.ini
2005-12-13 16:56 . 2005-01-20 14:46 1442 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbx.loc
2005-12-13 16:55 . 2004-12-07 21:45 53248 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxupld.exe
2005-12-13 16:55 . 2004-12-07 21:44 53248 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxtime.exe
2005-12-13 16:55 . 2004-12-07 21:43 69632 ----a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxtime.dll
2005-12-13 16:55 . 2004-12-07 21:44 57344 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxserv.exe
2005-12-13 16:55 . 2004-12-07 21:44 53248 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxview.exe
2005-12-13 16:55 . 2004-12-07 21:44 294912 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxuldr.dll
2005-12-13 16:55 . 2004-12-07 21:43 278528 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxretv.dll
2005-12-13 16:55 . 2004-12-02 19:55 176128 ----a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxtsfw.dll
2005-12-13 16:55 . 2004-12-03 14:16 110592 ----a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxdrec.dll
2005-12-13 16:55 . 2004-12-07 18:51 83852 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxdpp.hlp
2005-12-13 16:55 . 2004-09-29 20:37 22444 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxceip.hlp
2005-12-13 16:55 . 2004-07-01 20:16 1643218 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxphcl.out
2005-12-13 16:55 . 2004-08-10 19:12 1959746 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxphau.out
2005-12-13 16:55 . 2004-08-06 17:16 57344 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxppx.dll
2005-12-13 16:55 . 2004-12-16 15:36 630784 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxpmui.dll
2005-12-13 16:55 . 2004-08-21 16:15 368640 ----a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxcomx.dll
2005-12-13 16:55 . 2005-01-20 09:56 98304 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxinsr.dll
2005-12-13 16:55 . 2005-01-20 09:54 139264 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxins.dll
2005-12-13 16:55 . 2004-03-30 21:45 40960 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxvs.dll
2005-12-13 16:55 . 2004-12-16 15:29 356352 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxih.exe
2005-12-13 16:55 . 2004-12-16 15:33 368640 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxcfg.exe
2005-12-13 16:55 . 2004-12-16 15:27 114688 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxpplc.dll
2005-12-13 16:55 . 2004-12-16 15:33 401408 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxcomm.dll
2005-12-13 16:55 . 2004-12-16 15:33 483328 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxlmpm.dll
2005-12-13 16:55 . 2004-12-16 15:32 1085440 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxusb1.dll
2005-12-13 16:55 . 2004-12-16 15:33 741376 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxhbn3.dll
2005-12-13 16:55 . 2004-12-16 15:27 507904 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxhbn1.dll
2005-12-13 16:55 . 2004-12-16 15:26 462848 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxcoms.exe
2005-12-13 16:55 . 2004-12-16 15:26 139264 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxprox.dll
2005-12-13 16:55 . 2004-12-16 15:33 663552 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxcomc.dll
2005-12-13 16:55 . 2004-12-16 15:36 1146880 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxserv.dll
2005-12-13 16:55 . 2003-10-01 18:34 245760 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxsk2.dll
2005-12-13 16:55 . 2003-10-01 18:34 204800 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxsk1.dll
2005-12-13 16:55 . 2004-05-13 16:14 229376 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxsk0.dll
2005-12-13 16:55 . 2004-03-24 21:45 983101 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxGF.DLL
2005-12-13 16:55 . 2002-12-19 14:19 6841 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxeula.txt
2005-12-13 16:55 . 2004-08-10 19:12 1578218 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxaual.out
2005-12-13 16:55 . 2004-07-01 20:16 1896052 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxCLN.OUT
2005-12-13 16:55 . 2004-12-16 15:15 4096 ----a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxPCFG.DLL
2005-12-13 16:55 . 2004-12-16 15:15 73728 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxPP5C.DLL
2005-12-13 16:55 . 2005-01-20 09:55 32768 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxCUR.DLL
2005-12-13 16:55 . 2005-01-20 09:53 69632 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxCU.DLL
2005-12-13 16:55 . 2005-01-20 09:56 90112 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxUPDR.DLL
2005-12-13 16:55 . 2005-01-20 09:53 73728 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxUPD.DLL
2005-12-13 16:55 . 2005-01-20 09:46 397312 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxUTIL.DLL
2005-12-13 16:55 . 2005-01-20 09:55 86016 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxPSWR.DLL
2005-12-13 16:55 . 2005-01-20 09:51 368640 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxPSW.DLL
2005-12-13 16:55 . 2005-01-20 09:55 122880 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxUPDB.DLL
2005-12-13 16:55 . 2005-01-20 09:55 757760 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxPSWB.DLL
2005-12-13 16:55 . 2005-01-20 09:55 1990656 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxPRPB.DLL
2005-12-13 16:55 . 2005-01-20 09:54 5480448 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxLPAB.DLL
2005-12-13 16:55 . 2005-01-20 09:54 471040 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxJSWB.DLL
2005-12-13 16:55 . 2005-01-20 09:54 176128 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxINSB.DLL
2005-12-13 16:55 . 2005-01-20 09:54 77824 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxCUB.DLL
2005-12-13 16:55 . 2005-01-20 09:55 90112 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxPRPR.DLL
2005-12-13 16:55 . 2005-01-20 09:53 561152 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxPRP.DLL
2005-12-13 16:55 . 2005-01-20 09:55 204800 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxLPAR.DLL
2005-12-13 16:55 . 2005-01-20 09:50 995328 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxLPA.DLL
2005-12-13 16:55 . 2005-01-20 09:55 135168 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxJSWR.DLL
2005-12-13 16:55 . 2005-01-20 09:47 139264 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxJSW.DLL
2005-12-13 16:55 . 2004-12-15 18:46 188416 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxPSWX.EXE
2005-12-13 16:55 . 2004-06-09 21:15 77824 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxJSWX.EXE
2005-12-13 16:55 . 2004-06-16 20:59 300 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxMA.CNT
2005-12-13 16:55 . 2004-05-28 18:48 5871 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxLPA.CNT
2005-12-13 16:55 . 2004-06-01 22:20 1593 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxDRV.CNT
2005-12-13 16:55 . 2004-05-18 20:57 7434 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxNOTE.HLP
2005-12-13 16:55 . 2005-01-07 22:05 986320 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxLPA.HLP
2005-12-13 16:55 . 2004-11-01 20:11 496313 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxDRV.HLP
2005-12-13 16:55 . 2004-12-16 15:24 295936 ----a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxSTRN.DLL
2005-12-13 16:55 . 2004-12-16 15:14 56832 ----a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxUI5C.DLL
2005-12-13 16:55 . 2004-10-20 13:37 114688 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxFLIB.DLL
2005-12-13 16:55 . 2004-10-20 13:37 704512 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxHPEH.DLL
2005-12-13 16:55 . 2004-10-20 13:37 147456 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxHPEP.DLL
2005-12-13 16:55 . 2004-10-20 13:37 413696 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxHPEC.DLL
2005-12-13 16:55 . 2004-12-16 18:55 539843 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxCLR4.LUT
2005-12-13 16:55 . 2004-12-22 14:20 1005912 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxCLR3.LUT
2005-12-13 16:55 . 2004-12-22 14:20 987923 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxCLR2.LUT
2005-12-13 16:55 . 2004-12-22 14:20 987923 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxCLR1.LUT
2005-12-13 16:55 . 2004-03-30 21:45 152576 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\ptzipw32.dll
2005-12-13 16:55 . 2004-03-30 21:45 73856 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\hlp256.dll
2005-12-13 16:55 . 2004-03-30 21:45 24576 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\lexgo.EXE
2005-12-13 16:55 . 2003-08-19 15:01 430080 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\LEXEDF.DLL
2005-12-13 16:55 . 2004-12-16 15:14 116736 ----a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\dlbxDR5C.DLL
2005-07-27 23:09 . 2007-04-09 17:24 758664 ----a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\mdigraph.dll
2005-07-27 23:09 . 2007-04-09 17:23 46472 ----a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\mdiui.dll
2004-08-04 06:56 . 2008-04-14 00:12 373248 ----a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\unidrv.dll
2004-08-04 06:56 . 2008-04-14 00:12 744448 ----a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\unidrvui.dll
2004-08-04 06:56 . 2007-05-15 08:08 761344 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\unires.dll
2001-07-22 01:41 . 2001-07-22 01:41 14362 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\STDNAMES.GPD
2001-07-22 00:39 . 2001-07-22 00:39 21225 -c--a-w- c:\windows\System32\spool\DRIVERS\W32X86\3\UNIDRV.HLP
HKCU-Run-CyberDefender Early Detection Center - c:\program files\CyberDefender\AntiSpyware\cdas4.exe
AddRemove-{AA63780B-DDB7-417b-8A13-E5AFBE08E807} - c:\program files\CyberDefender\cdinstx.exe
AddRemove-{AC5352DA-F4F2-4A59-A1BF-41546342746B} - c:\program files\CyberDefender\cdinstx.exe
Rootkit scan 2009-10-13 15:41
c:\docume~1\ADMINI~1\LOCALS~1\Temp\~DF5E9A.tmp 16384 bytes
c:\docume~1\ADMINI~1\LOCALS~1\Temp\~DF5EB6.tmp 512 bytes
hȋdden files: 2
@="IFlashBroker3"
"Version"="1.0"
- - - - - - - > 'explorer.exe'(4004)
c:\windows\system32\ati2evxx.exe
c:\program files\a-squared Free\a2service.exe
c:\progra~1\COMMON~1\AOL\ACS\AOLacsd.exe
c:\windows\system32\CTSVCCDA.EXE
c:\windows\ehome\ehRecvr.exe
c:\windows\ehome\ehSched.exe
c:\program files\Intel\Intel Matrix Storage Manager\IAANTMon.exe
c:\windows\wanmpsvc.exe
c:\windows\system32\msiexec.exe
c:\windows\system32\dllhost.exe
c:\windows\ehome\ehmsas.exe
c:\windows\system32\dlbxcoms.exe
Completion time: 2009-10-13 15:48 - machine was rebooted
ComboFix-quarantined-files.txt 2009-10-13 19:48
ComboFix2.txt 2009-10-13 19:00
ComboFix3.txt 2009-10-13 03:51
Pre-Run: 217,656,991,744 bytes free
Post-Run: 217,556,037,632 bytes free
1546 --- E O F --- 2009-09-18 16:14
HoldR4D
Posts Posts : 53
OS OS : windows XP
Post by HoldR4D on 13th October 2009, 8:10 pm
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Network1.Popups.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\NetworkEssentials.SCBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\NetworkEssentials.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\New.net.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\NewDotNet.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\NewsUpdate.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\NJStar Asian Explorer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\NN_Bar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\NoCreditCard Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\NowBox.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\NV-Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\NVDialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Oemji Bar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Oemji Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\OfferAgent.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\OffshoreClicks.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\One2one Viewer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\OnFlow.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\OnlDial.MaConnect.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\OnlDial.Ole.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\OnWebMedia.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Oodlz.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\OpenSite.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\OpinionBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\OrbitExplorer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\OutLaster.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Overpro.com.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\OverPro.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\P2P Networking.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ParisVoyeur Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\PeopleOnPage.Apropos.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\PeopleOnPage.AproposMedia.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\PeopleOnPage.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\PeoplePC Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Peper Trojan.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Peper.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Perfect Keylogger Lite.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Perfect Keylogger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Phony search redirector.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Piratos.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\PKings-IEHelper.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Pops-Stop.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Pops Stop.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\PopUpDefence.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Popuper.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Popuppers Advertising.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Porn Dialer 5-2-46-112.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Porn Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\pornbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\PowerReg Scheduler.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\PowerSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Powerstrip.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\PrecisionPop.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\PrecisionTime.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Preview AdService.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ProDyne Webinstall.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\PromulGate.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Prutect.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\PSGuard Desktop Hijacker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\PSGuard.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Puper.UpdateSearches.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\PurityScan.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\QaBar-Adult Links Toolband.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\QaBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Qcbar.AdultLinks.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\QHosts.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Qidion Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Quicknavigate Hijacker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\QuickPage.SwitchDialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\QuickSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Radlight 3 PRO.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Radlight Divx Player.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\RadLight Media Player.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Radlight.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\RapidBlaster.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\RasDial.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\RCPrograms.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Redhotnetworks.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\RedV.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Regsync.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\RelatedLinks BHO.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\RelatedLinks.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Remote Keylogger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ReplaceSearch.BHO.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Rex Services.Adtrojan.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\RichFind.Q.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\RightFinder.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\RiverSoftware.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Roings.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Rsync.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Ruboskizo.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\RVP.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\RXToolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Rydial.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Safecast.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Safeguard Protect.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SafeSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SafeSurfing.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SahAgent.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SandBoxer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SaveNow - WhenUSave.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SaveNow.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Scam.Trackzapper.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SCBAR.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SDBot.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Search-Pounder.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Search Assistant.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Search Miracle.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Search Relevancy.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Search Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Searchalot.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SearchAndClick.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SearchbarCash.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SearchCentrix.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SearchEnhancement hijacker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SearchEnhancement.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SearchExe.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SearchFast.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SearchForIt Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Searchforit.com.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SearchForIt.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Searchit.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SearchMaid.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SearchMiracle.EliteBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Searchmiracle.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SearchPounders Hijacker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SearchRelevancy.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SearchSquire.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SearchV.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\searchwww.hijacker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SearchWWW.IEToolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SecondThought.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Secret-Crush.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SecretCrush.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Security iGuard.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\seekseek hijacker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Seeq Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Sesso.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SexCounter.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Sexfiles Dialers.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SexFiles.nu.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SexList.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SexTracker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ShareDocs.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ShopAtHome.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ShopAtHomeSelect.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ShopForGood.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ShopNav Hijacker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ShopNav.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ShopNavSearch.Srng.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ShowBehind.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\sICRO Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SideFind.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SideSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SinSource.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Slagent.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SlimFTP.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SlotchBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SmartBrowser.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SmartPops - Network Essentials.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SmitFraud.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Softomate Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Specific911 Hijack.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Spector Pro Keylogger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SpediaBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Speedblaster.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SpeedDelivery.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Spy Recon Keylogger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SpyArsenal HomeKeylogger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SpyBlast.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SpyBuddy Keylogger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SpyDeleter.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SpyKeylogger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SpyKiller 2005.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SpyPC Keylogger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SpySheriff.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Spyware.Perezzz.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SpywareNo.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SpywareNuker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SquireSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Srng.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\StarInstall(MainPean).txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Startnow.Hyperbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Startpage.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Starware Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Starware.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Statblaster.MemoryWatcher.b.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Statblaster.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\StoolBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\StopPop.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Strip Player.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SubSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SunInfoConnect.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SupaSeek.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Super-gals.com.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Super-spider Hijacker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SuperBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Superlogy.com.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Supersmileys.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SupremeSpy.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SureBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Surf Accuracy.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Surfairy.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SurfAssistant.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Surfbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SurfSideKick.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SwimSuitNetwork.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SwitchDialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SyncroAd.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SySsfitb.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\System Soap Pro.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\System Soap.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\System Spy.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\System1060.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SysWeb-Telecom Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SysWebTelecom.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\SyvumClickTM.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TafBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Target Saver.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TargetNet.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Targetsaver.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Targetsoft.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TeenXXX (TinyBar).txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Teknum Updater.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TestTimer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TheSearchMall.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TIB Browser.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TIBS Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TIBS dialers.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TIBS Premium Rate Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TIBS Premium Rate Dialler.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TightVNC.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Timbuktu Pro.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Timesink.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TinTel dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TinTel.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TinyBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Tinyo.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ToolbarCC.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TopConverting Crazywinnings.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TopConverting Downloader.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Topconverting.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TOPicks.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TopMoxie.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TopPicks.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TopRebates.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TopSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TrafficHog.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Transponder.Ahexe.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Transponder.Alchemy.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Transponder.BI.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Transponder.Bolger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Transponder.Ceres.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Transponder.LocalNRD.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Transponder.Multimpp.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Transponder.MXTarget.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Transponder.Pynix.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Transponder.Speer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Transponder.Twain-tech.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Transponder.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Troj.Dloader.FQ.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan-Downloader-hȋdden.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan-Downloader-Stubby.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan-Fake Warning.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan Common Components.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan Downloader Apher.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan drsnsrch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Banker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.CallingHome.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Delf.IT.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Dialer.FU.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.DNS Changer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Downloader.BHOmod.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Downloader.CT.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Downloader.Domcom.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Downloader.FH.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Downloader.FQ.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Downloader.Pacimedia.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Downloader.Small.BDZ.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Dropper.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Drsnsrch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Dumaru.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.FakeAlert.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.FakeSpy.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.FavAdd.ae.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Favadd.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Hacktool.Rootkit.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Pakes.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Popuper.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Proxy.BK.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Proxy.Webber.O.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Sheldor.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Spywad.A.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.StartPage.BN.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.startpage.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Stubby.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Win32.Revop.c.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Win32.Sdbot-QG.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Trojan.Wuviewer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TSCash.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Tubby Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TubbyBHO.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TurboDownload.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TV Media Display.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TvMedia.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Twain-tech.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TwainTech.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Twister.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\TX4.BrowserAd.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\UCmore.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\UKVideo2 Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Unknown Trojan.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ValueAd.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\VBouncer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Virtual Bouncer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\VirtualBouncer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Virtumonde.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\VLoading.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\vx2 (Transponder).txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\VX2 Transponder variant.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\VX2.aBetterInternet.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\VX2.BTGrab.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\VX2.DealsOnline.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\VX2.Host.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\VX2.LocalNRD.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\VX2.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\W32.Bagle.I.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\W32.HLLW.Xolox.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WareOut.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Web3000.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WebDialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WebHancer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WebInstall.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WebRebates.TopRebates.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WebRebates.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WebSearch Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WebSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WebTrends live.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WhenU.ClockSync.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WhenU.Control.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WhenU.DesktopToolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WhenU.SaveNow.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WhenU.Search.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WhenU.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WhenU.WeatherCast.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WhenUSave.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WhenUSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WildMedia.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WildTangent.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Win-Spy.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Win32.Backdoor.Jeem.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\win32.blaster.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Win32.Downloader.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Win32.LolaWeb.Trojan.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\win32.mydoom.p@mm.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Win32.Netsky.B.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Win32.Perfiler.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Win32.Sasser.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Win32.Welchia.B.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Win32.winshow.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WinAD.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WindowEnhancer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Windows AdControl.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WindUpdate.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WindUpdates.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WinFavorites.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Wink.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Winpage Blocker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Winpup.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Winpup32.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WinTools.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Wishbone.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Wowvirgins.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\WurldMedia.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Xrenoder.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Xupiter.OrbitExplorer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Xupiter.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\XXXDIAL.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\XXXtoolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\YourSiteBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ZANGO Search Assistant.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Zango.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Zestyfind.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ZipClix.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Zoombar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ZSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Loading Index.htm
c:\program files\CyberDefender\AntiSpyware\Includes\NoItems Index.htm
c:\program files\CyberDefender\AntiSpyware\Includes\Notify.wav
c:\program files\CyberDefender\AntiSpyware\Includes\Report Spyware.htm
c:\program files\CyberDefender\AntiSpyware\Includes\Report.htm
c:\program files\CyberDefender\AntiSpyware\Includes\Restore Spyware.htm
c:\program files\CyberDefender\AntiSpyware\Includes\Restore.htm
c:\program files\CyberDefender\AntiSpyware\Includes\Settings Browser Helper Objects.htm
c:\program files\CyberDefender\AntiSpyware\Includes\Settings Internet Explorer.htm
c:\program files\CyberDefender\AntiSpyware\Includes\Settings Startup Program.htm
c:\program files\CyberDefender\AntiSpyware\InstallResource.dll
c:\program files\CyberDefender\AntiSpyware\iss_sm.ico
c:\program files\CyberDefender\AntiSpyware\ISSIntro.exe
c:\program files\CyberDefender\AntiSpyware\sum.htm
c:\program files\CyberDefender\AntiSpyware\support.ico
c:\program files\CyberDefender\AntiSpyware\support_sm.ico
c:\program files\CyberDefender\AntiSpyware\UserGuide\cdaschk.ini
c:\program files\CyberDefender\AntiSpyware\UserGuide\cybdefantispy.set
c:\program files\CyberDefender\AntiSpyware\uwfile.dat
c:\program files\CyberDefender\AntiSpyware\WsLiveUpdateHost.ini
c:\program files\CyberDefender\AntiSpyware\WsLiveUpFiles\cdaspat1.dat.03
c:\program files\CyberDefender\AntiSpyware\WsLiveUpFiles\cdaspat11.dat.03
c:\program files\CyberDefender\AntiSpyware\WsLiveUpFiles\cdaspat12.dat.03
c:\program files\CyberDefender\AntiSpyware\WsLiveUpFiles\cdaspat13.dat.03
c:\program files\CyberDefender\AntiSpyware\WsLiveUpFiles\cdaspat14.dat.03
c:\program files\CyberDefender\AntiSpyware\WsLiveUpFiles\cdaspat2.dat.03
c:\program files\CyberDefender\AntiSpyware\WsLiveUpFiles\cdaspat3.dat.03
c:\program files\CyberDefender\AntiSpyware\WsLiveUpFiles\cdaspat4.dat.03
c:\program files\CyberDefender\AntiSpyware\WsLiveUpFiles\cdavpat.dat.03
c:\program files\CyberDefender\AntiSpyware\WsLiveUpFiles\cdavpat.dat.04
c:\program files\CyberDefender\AntiSpyware\WsLiveUpFiles\cdavpat.dat.05
c:\program files\CyberDefender\AntiSpyware\WsLiveUpFiles\stbar03.exe
c:\program files\CyberDefender\AntiSpyware\WsLiveUpFiles\stbarpat.dat.03
c:\program files\CyberDefender\AntiSpyware\WsLiveUpFiles\tmp\cdavpat.dat.06
c:\program files\CyberDefender\AntiSpyware\WsLiveUpFiles\tmp\cdiss03.exe
c:\program files\CyberDefender\AntiSpyware\WsLiveUpFiles\tmp\stbarpat.dat.03
c:\program files\CyberDefender\AntiSpyware\WsLiveUpFiles\wsliveup.dat.03
c:\program files\CyberDefender\AntiSpyware\wslvucfg.ini
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\History\2009-09-22.ini
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\DelayLoad.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\Explorer Bars.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\Explorer Plugins.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\Hosts.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\IE Extensions.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\IE Main.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\IE Menubar.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\IE Plugins.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\IE Searchbar.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\IE Toolbar.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\NT Run.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\Run.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\RunOnce.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\RunOnceEx.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\RunServices.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\Service.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\Shell.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\Startup.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\URLSearchHooks.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\WinLogon.dat
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Status.ini
c:\program files\CyberDefender\AntiVirus\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Upload\Alert\Run.dat
c:\program files\CyberDefender\AntiVirus\CapiCom.Dll
c:\program files\CyberDefender\AntiVirus\cdav6.exe
c:\program files\CyberDefender\AntiVirus\CDAVcfg.ini
c:\program files\CyberDefender\AntiVirus\CDAVFS.dll
c:\program files\CyberDefender\AntiVirus\CDAVFS.inf
c:\program files\CyberDefender\AntiVirus\CDAVFS.INF.OLD
c:\program files\CyberDefender\AntiVirus\CDAVFS.sys
c:\program files\CyberDefender\AntiVirus\cdavpat.dat.03
c:\program files\CyberDefender\AntiVirus\cdavpat.dat.04
c:\program files\CyberDefender\AntiVirus\cdavpat.dat.05
c:\program files\CyberDefender\AntiVirus\cdavpat.dat.06
c:\program files\CyberDefender\AntiVirus\CDAVSettings.ini
c:\program files\CyberDefender\AntiVirus\CDAVUpdateHost.ini
c:\program files\CyberDefender\AntiVirus\cdiss03.exe
c:\program files\CyberDefender\AntiVirus\cdissversion.ini
c:\program files\CyberDefender\AntiVirus\cdspnsrv.dll
c:\program files\CyberDefender\AntiVirus\CybDefAV.dll
c:\program files\CyberDefender\AntiVirus\CybDefAVUI.dll
c:\program files\CyberDefender\AntiVirus\CybDefExt.dll
c:\program files\CyberDefender\AntiVirus\CyberDefenderEDC.exe
c:\program files\CyberDefender\AntiVirus\DisableWindowsFirewall.exe
c:\program files\CyberDefender\AntiVirus\Download\cdavpat.dat.03
c:\program files\CyberDefender\AntiVirus\Download\cdavpat.dat.04
c:\program files\CyberDefender\AntiVirus\Download\cdavpat.dat.06
c:\program files\CyberDefender\AntiVirus\Download\cdiss03.exe
c:\program files\CyberDefender\AntiVirus\EnableWindowsFirewall.exe
c:\program files\CyberDefender\AntiVirus\Html\History eMail.htm
c:\program files\CyberDefender\AntiVirus\Html\History File.htm
c:\program files\CyberDefender\AntiVirus\Html\Loading Index.htm
c:\program files\CyberDefender\AntiVirus\Html\NoItems Index.htm
c:\program files\CyberDefender\AntiVirus\Html\Notify.wav
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-08-08.ini
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-08-22.ini
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-08-24.ini
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-08-26.ini
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-08-27.ini
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-08-28.ini
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-08-29.ini
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-08-30.ini
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-09-01.ini
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-09-04.ini
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-09-06.ini
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-09-09.ini
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-09-11.ini
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-09-13.ini
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-09-16.ini
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-09-19.ini
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-09-20.ini
c:\program files\CyberDefender\AntiVirus\UpdateHistory\2009-09-21.ini
c:\program files\CyberDefender\AntiVirus\UserGuide\CybDefAV.set
c:\program files\CyberDefender\AntiVirus\UserGuide\CybDefAVchk.ini
c:\program files\CyberDefender\AntiVirus\uwcdsoe.dll
c:\program files\CyberDefender\AntiVirus\uwcdsolk.dl_
c:\program files\CyberDefender\AntiVirus\uwcdsolk.dll
c:\program files\CyberDefender\AntiVirus\uwhook32.dll
c:\program files\CyberDefender\AntiVirus\wslvucfg.ini
c:\program files\CyberDefender\cdinstx.log
c:\program files\CyberDefender\earlySpam\cdaspm.dll
c:\program files\CyberDefender\earlySpam\cdinstx.log
c:\program files\CyberDefender\earlySpam\images\block_normal.bmp
c:\program files\CyberDefender\earlySpam\images\block_over.bmp
c:\program files\CyberDefender\earlySpam\images\earlySPAMBtn.bmp
c:\program files\CyberDefender\earlySpam\images\grant_normal.bmp
c:\program files\CyberDefender\earlySpam\images\grant_over.bmp
c:\program files\CyberDefender\earlySpam\images\options_normal.bmp
c:\program files\CyberDefender\earlySpam\images\options_over.bmp
c:\program files\CyberDefender\earlySpam\images\spy_normal.bmp
c:\program files\CyberDefender\earlySpam\images\spy_over.bmp
c:\program files\CyberDefender\earlySpam\oeapiinitcom.dll
c:\program files\CyberDefender\earlySpam\oecom.dll
c:\program files\CyberDefender\earlySpam\oestore.dll
c:\program files\CyberDefender\earlySpam\uwmyjunk.ini
c:\program files\CyberDefender\eula.rtf
c:\program files\CyberDefender\HomePage\CDWebVw.dll
c:\program files\CyberDefender\InstallModule\AdPresenter\CSIDL_PROGRAM_FILES\AdPresenter\cdNetAd.dll
c:\program files\CyberDefender\InstallModule\AntiSpam\CSIDL_PROGRAM_FILES\earlySpam\cdaspm.dll
c:\program files\CyberDefender\InstallModule\AntiSpam\CSIDL_PROGRAM_FILES\earlySpam\images\block_normal.bmp
c:\program files\CyberDefender\InstallModule\AntiSpam\CSIDL_PROGRAM_FILES\earlySpam\images\block_over.bmp
c:\program files\CyberDefender\InstallModule\AntiSpam\CSIDL_PROGRAM_FILES\earlySpam\images\earlySPAMBtn.bmp
c:\program files\CyberDefender\InstallModule\AntiSpam\CSIDL_PROGRAM_FILES\earlySpam\images\grant_normal.bmp
c:\program files\CyberDefender\InstallModule\AntiSpam\CSIDL_PROGRAM_FILES\earlySpam\images\grant_over.bmp
c:\program files\CyberDefender\InstallModule\AntiSpam\CSIDL_PROGRAM_FILES\earlySpam\images\options_normal.bmp
c:\program files\CyberDefender\InstallModule\AntiSpam\CSIDL_PROGRAM_FILES\earlySpam\images\options_over.bmp
c:\program files\CyberDefender\InstallModule\AntiSpam\CSIDL_PROGRAM_FILES\earlySpam\images\spy_normal.bmp
c:\program files\CyberDefender\InstallModule\AntiSpam\CSIDL_PROGRAM_FILES\earlySpam\images\spy_over.bmp
c:\program files\CyberDefender\InstallModule\AntiSpam\CSIDL_PROGRAM_FILES\earlySpam\oeapiinitcom.dll
c:\program files\CyberDefender\InstallModule\AntiSpam\CSIDL_PROGRAM_FILES\earlySpam\oecom.dll
c:\program files\CyberDefender\InstallModule\AntiSpam\CSIDL_PROGRAM_FILES\earlySpam\oestore.dll
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\AWSDLL.DLL
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\cdinstx.exe
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\cdmyidd.dll
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\database.db
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\gacutil.exe
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Includes\Loading.htm
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Includes\NoItems Index.htm
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Includes\Password Cookie.htm
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Includes\Passwords Index.htm
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Includes\Privacy Index.htm
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\charset.html
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\cookie.html
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\defaultCharset.html
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\form.html
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\frame.html
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\gray.htm
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\green.htm
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\host.html
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\bg.jpg
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\bg_button.jpg
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\bg_top.jpg
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\bt_go.gif
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\bt_go_down.gif
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\bt_go_over.gif
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\bt_grey.gif
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\bt_red - Copy.gif
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\bt_red.gif
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\bt_red_down.gif
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\bt_red_over.gif
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\caution.gif
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\frame.gif
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\logo.gif
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\logo.jpg
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\logo_orange.gif
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\topbar.gif
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\topbar_orange.gif
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\images\warning.gif
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\popup.html
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\port.html
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\protocol.html
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\red.htm
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\referrer.html
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\scamalert.htm
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\scamalert.htm1
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\script.html
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\security.html
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\style.css
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\Scam Alert\yellow.htm
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\st.ico
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\stbarpat.dat.03
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\UserGuide\cybdefstbar.set
c:\program files\CyberDefender\InstallModule\SecurityToolbar\CSIDL_LOCAL_APPDATA\CyberDefender\UserGuide\stbarchk.ini
c:\program files\CyberDefender\SecurityStatus.ini
c:\program files\CyberDefender\UserGuide\CybDefISS.set
c:\program files\CyberDefender\UserGuide\CybDefISSchk.ini
c:\program files\CyberDefender\VistaAdmin.exe
c:\windows\system32\dbsinit.exe
HoldR4D
Posts Posts : 53
Joined Joined : 2009-10-03
OS OS : windows XP
Points Points : 26317
Re: my explorer doesnt work and having problem with malware
Post by HoldR4D on 13th October 2009, 8:11 pm
ComboFix 09-10-13.01 - Administrator 10/13/2009 15:33.7.2 - NTFSx86
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.1022.520 [GMT -4:00]
Running from: c:\documents and settings\Administrator\My Documents\ComboFix.exe
Command switches used :: c:\documents and settings\Administrator\My Documents\CFScript.txt
AV: CyberDefender Internet Security *On-access scanning enabled* (Updated) {925FF895-595E-4ED4-BB84-E12C72FBA43A}
FILE ::
"c:\windows\system32\dbsinit.exe"
c:\documents and settings\All Users\Application Data\14708904
c:\program files\CyberDefender\AdPresenter\cdNetAd.dll
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Alert\Run.dat
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Html\Alert Index.html
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Html\Alert.html
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Html\Cookie Index.html
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Html\Firewall Index.html
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Html\OnLoadMSUpdate.html
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Html\Report Index.html
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Html\Restore Index.html
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Html\Restore.html
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Html\Settings Index.html
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\procrun.log
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\DelayLoad.dat
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\Explorer Bars.dat
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\Explorer Plugins.dat
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\Hosts.dat
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\IE Extensions.dat
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\IE Main.dat
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\IE Menubar.dat
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\IE Searchbar.dat
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\IE Toolbar.dat
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\Run.dat
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\Service.dat
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\Startup.dat
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\URLSearchHooks.dat
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Shield\WinLogon.dat
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Status.ini
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Upload\Alert\DelayLoad.dat
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Upload\Alert\Explorer Plugins.dat
c:\program files\CyberDefender\AntiSpyware\{2D93B178-6A72-4CBD-8EF0-938CB655E5F8}\Upload\Alert\Run.dat
c:\program files\CyberDefender\AntiSpyware\AWSDLL.dll
c:\program files\CyberDefender\AntiSpyware\CDAScfg.ini
c:\program files\CyberDefender\AntiSpyware\cdaspat.dat.03
c:\program files\CyberDefender\AntiSpyware\cdaspat1.dat.03
c:\program files\CyberDefender\AntiSpyware\cdaspat11.dat.03
c:\program files\CyberDefender\AntiSpyware\cdaspat12.dat.03
c:\program files\CyberDefender\AntiSpyware\cdaspat13.dat.03
c:\program files\CyberDefender\AntiSpyware\cdaspat14.dat.03
c:\program files\CyberDefender\AntiSpyware\cdaspat2.dat.03
c:\program files\CyberDefender\AntiSpyware\cdaspat3.dat.03
c:\program files\CyberDefender\AntiSpyware\cdaspat4.dat.03
c:\program files\CyberDefender\AntiSpyware\CDASSettings.ini
c:\program files\CyberDefender\AntiSpyware\CDASUpdateHost.ini
c:\program files\CyberDefender\AntiSpyware\CDAVFS.dll
c:\program files\CyberDefender\AntiSpyware\cdDownloadList.ini
c:\program files\CyberDefender\AntiSpyware\cdissversion.ini
c:\program files\CyberDefender\AntiSpyware\cdspnsrv.dll
c:\program files\CyberDefender\AntiSpyware\config.ini
c:\program files\CyberDefender\AntiSpyware\ConsolidatedResources.dll
c:\program files\CyberDefender\AntiSpyware\CybDefSB.dll
c:\program files\CyberDefender\AntiSpyware\CybDefSBUI.dll
c:\program files\CyberDefender\AntiSpyware\CybDefSysUI.dll
c:\program files\CyberDefender\AntiSpyware\CyberDefenderEDC.exe
c:\program files\CyberDefender\AntiSpyware\Download\cdaspat.dat.03
c:\program files\CyberDefender\AntiSpyware\Download\cdaspat1.dat.03
c:\program files\CyberDefender\AntiSpyware\Download\cdaspat11.dat.03
c:\program files\CyberDefender\AntiSpyware\Download\cdaspat12.dat.03
c:\program files\CyberDefender\AntiSpyware\Download\cdaspat13.dat.03
c:\program files\CyberDefender\AntiSpyware\Download\cdaspat14.dat.03
c:\program files\CyberDefender\AntiSpyware\Download\cdaspat2.dat.03
c:\program files\CyberDefender\AntiSpyware\Download\cdaspat3.dat.03
c:\program files\CyberDefender\AntiSpyware\Download\cdaspat4.dat.03
c:\program files\CyberDefender\AntiSpyware\EDCConfig.exe
c:\program files\CyberDefender\AntiSpyware\gacutil.exe
c:\program files\CyberDefender\AntiSpyware\Includes\Alert.htm
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Adware.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Alert Internet Explorer.htm
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Alert Startup Program.htm
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Browser Changer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Browser Plugin.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\BrowserChanger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\BrowserPlugin.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Bundler.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\categories.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Commercial Key Logger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\CommercialKeyLogger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Cookie.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Data Miner.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\DataMiner.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Key Logger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\KeyLogger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Low Risk Adware.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\LowRiskAdware.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Malware.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\P2P.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\RAT.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Report Tracking Cookie.htm
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Restore tracking cookie.htm
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Search Hijacker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\SearchHijacker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Spyware.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Stealth.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Trojan Downloader.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Trojan.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\TrojanDownloader.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Category\Worm.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\007 Keylogger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\007 Spy.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\123mania.com.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\180ad Solution.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\180search Assistant.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\180SearchAssistant.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\180Solutions.com SurfAssistant.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\2020Search.com.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\2020Search.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\2nd-thought.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\2nd thought.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\404search.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\7AdPower.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\7FaSSt.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\7search-BrowserAccelerator.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\911-search.info.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ABC Keylogger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ABetterInternet.Aurora.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ABetterInternet.Ceres.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ABetterInternet.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\About Blank.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Abox.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Absolute Key Logger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\abxtoolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Ace Club Casino.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AceNotes Free.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Aconti-Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Aconti.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ActiveSearch (411 Ferret).txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ActiveSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ActMon Keylogger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Acx Install.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Ad-Flow.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Ad-Popper.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AdBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AdBars.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AdBreak.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AdBureau.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AdDestroyer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Adintelligence.AproposToolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Adlogix Browser Hijacker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Adlogix.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Admanager Controller.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Admess.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Admilli Service.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AdPlus-SurferBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AdRoar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Adrotator.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AdShooter.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Adtomi.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Adultlinks Quickbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Adultlinks.Quickbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Adultlinks.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Advanced Searchbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Advertbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Advertising.com.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Adviva.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AdvSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Advware.BetterInternet.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ADWARE.BINET.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Adware.FOne.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Adware.HotSearchBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AFA Internet Enhancement.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Ahead Nero Burning Rom.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Alexa Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Alexa.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\All-In-One Telcom.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AllCyberSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Altnet Software.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Altnet.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AltnetBDE.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AlwaysUpdatedNews.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Alyon.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Andlotsmore.com dialler.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AntiLamer Light.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AntivirusGold.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Aornum.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Apropos.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Ares.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AsianRaw Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Atwola Cookie.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Aureate-Radiate.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Aureate Group Mail.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Aureate or Radiate.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Aureate.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AutoSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\AutoUpdate.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Avenue Media.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Azesearch Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BackDoor-BDI.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Backdoor.Agent.EN.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Backdoor.Delf.is.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Backdoor.Hackdoor.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Backdoor.Jeem.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Backdoor.Prorat.16.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Backdoor.Rbot.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Backdoor.Thunk.E.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Backdoor.win32.bifrose.d.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BackWeb Lite.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BackWeb.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BargainBuddy.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BDE Projector.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BDHelper.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BDPlugin.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BDSearch Plugin.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BearShare.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Begin2search.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Belcaro GoldenRetriever.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Berbew Trojan.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BFast.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BHO_DealHelper.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Bho_SEP.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Bho_SideFind.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BigTrafficNetwork.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Bikinidesk.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BingoFun Games.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BlazeFind.Bridge.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BlazeFind.Browserhelper2.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BlazeFind.SearchEnhancer.ISTbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BlazeFind.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BlazingTools Perfect Keylogger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Blondes.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Bluemountain.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Bokja NetInfo.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BonziBuddy.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BookedSpace.Remanent.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BookedSpace.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BPS Spyware Remover.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Bridge.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Brilliant Digital.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BroadCastPC.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BrowserAid.Featured-Results.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BrowserAid.INetP.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BrowserAid.RunDLL16.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BrowserAid.SearchandClick.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BrowserAid.Startium.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BrowserAid.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BrowserPal.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BrowserToolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BuddyLinks.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BuddyMediaBHO.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Bulla.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Bullguard Popup Ad.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BullsEye Network.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BullsEye.CashBack.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BullsEye.eXact Advertising.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BullsEye.eXact.ISEXEng.Trojan.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\BullsEye.NaviSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\C-Dilla.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\C2.lop.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\CallingHome.biz.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Carpe Diem.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Carpediem.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\CAS.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Cashback.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\CasinoClient.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\CasinoOnNet.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\CasinoPalazzo.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Central-24 Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\CES webmail.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Claria.Dashbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Claria.Precision Time.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Claria.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Claria.Weatherscope.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ClearSearch.Net.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\CleverIEHooker.Jeired.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ClickAgents.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ClickAlchemy.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ClickSpring.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ClickSpring_MediaTickets.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ClickSpring_PurityScan.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Clickyes2enter.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ClimaxBucks.InternetOptimizer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ClipGenie.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Clkoptimizer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Clocksync.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Comedy-Planet.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Comet Cursor.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Comet Systems.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Comload.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Commander Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Common Components for About Blank.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Common Components for BC Computing spy software.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Common Components for IGetNet.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Common Components for Keyloggers.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Common Components for MBP dialers.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Common Components for SBSoft.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Common Components For Spectorsoft.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Common Components for Transponders.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\CommonName.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Comsoft.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Conducent FlexPak.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Conducent TimeSink.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ConfuSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Connector Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\CoolSavings.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\CoolWebSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\CoreMetrics.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Coulomb Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Coulomb Ltd.Content Access Plugin.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\CouponAge.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\CouponsAndOffers.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\CrackSpider.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\CrazyWinnings.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Crush.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\CustomToolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Cydoor.TOPicks.a.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Cydoor.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Daily Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DailyWinner.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DailyWinnerBHO.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Daosearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DAP.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Dapsol Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Dapsol.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DashBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Date Regon.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DateMaker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DCON.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DealHelper.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DelfinProject.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Derbiz.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Desktop Hijacker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Dialer.Axload.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Dialer.IEDisco.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Dialer.Scom.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Dialer.UDconnect.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Dialer2004.com.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DialerData Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DialerMaker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DialerOffline.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Dialerplatform.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DialXS.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Diamond Deal Casino.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Divago.Surfairy.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DivX Pro 5.1.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Dluca-M.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Domain Sponsor Cookie.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DoubleClick.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Download Accelerator Plus ads.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Download Accelerator.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Downloader.Lunii.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DownloadPlus.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DownloadReceiver.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DownloadWare.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DSO Exploit.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DSSAgent.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DyFuCA.InternetOptimizer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\DyFuCA.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\E2G.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\E2Give.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\EasyBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\EasySearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\EasyWebSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\eBates MoneyMaker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\eBates.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\eBayToolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\eBlaster.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\eGroup.InstantAccess.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\eGroupDialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Elite toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\EliteBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Elitum.EliteBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Emesx.dll.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\emusic.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\EnConfidence.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ePlugin.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ErrorGuard.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ESP Keylogger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\eSyndicate BHO.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\eUniverse.IncrediFind.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\eUniverse.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\eUniverse.UpdMgr.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\EverAd.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\eXact Advertising.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\eXact ISEXEng.Trojan.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ExactSearchBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Excite.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ExDialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ezCyberSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\EzSearchbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\eZula HotText.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\EzuLa.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\F__kSite.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FactoryNetwork Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Fairtale Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Farmmext.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Farsighter.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Fast Video Player Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FastClick.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Fastfind.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FastSeeker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Fastvideoplayer dialler.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FastVideoPlayer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FavoriteMan.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FCI.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FileFreedom.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FindSpy.A.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FindWhateverNow.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FizzleWizzle Search Bar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FlashEnhancer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FlashenhancerBHO.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FlashGet.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FlashTrack.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Flingstone Infamous Downloader.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Flyswat.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Forbes.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Free Scratch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FreeConnectLtd.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FreeScratchAndWin.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FreeScratchCards.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Fresh Bar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Funny Trojan.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FunWeb.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\FunWebProducts.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GAIN-eWallet.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GAIN-Supported Software.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GAIN.DashBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GAIN.Date Manager.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GAIN.Precision Time.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GAIN.Screen Scenes.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GAIN.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GAIN.Weatherscope.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GameSpy Arcade.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Gator.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GetMirar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GigaTech SuperBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GigexAgent-SpeedDelivery.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Global Netcom Inc.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GlobalCS Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GlobalDialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GloboSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Gloggle.Shing.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Gloogle Downloader.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GMSoft Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GogoTools.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GoHip.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GoIndirect.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Golden Eye.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Golden Palace Casino.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GoZilla.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Grip Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Grokster.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\GSIM.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\H@tKeysH@@k.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Hacker.ag.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Haczyk.Ulubione.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\HalfLemon.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\HangUpTeam.TechnicRat.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Haxdoor-H.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Hellz Little Spy.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Hi-Wire.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Hijacker.IEHost.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\HitBox.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\HitHopper.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\HitsLink.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Holystic-Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Holystic.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\HomepageProtector.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Hot_Pleasure.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Hotsearchbar Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\HotSearchBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Hungry Hands porn hijacker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\HungryHands BHO.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\HuntBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\HuntToolBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Huysuzseks.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Hyperlinker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Ibero Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IberoDialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IBIS Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\icannnews.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ICOO Loader.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IE Access.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IE Driver.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IE Plugin.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ie2bar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IEAccess.IEDial.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IEFeats.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IEHijacker.Find4u.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IEHijacker.HereToFind.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IEHijacker.Hotoffers.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IEHijacker.richfind.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IEHIjacker.SearchExe.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IEHijacker.ZestyFind.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IELoader.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IEMenuExtension Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IEPageHelper.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IEPlugin.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IESearchToolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\iGetNet.Natural Language Navigation.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IGetNet.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ILookup.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ILookup.Vroomsearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ImIServer IEPlugin.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IncrediFindBHO.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\InetSpeak.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Instafinder.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Instant Access.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IntermixMedia.KeenValue.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Internet Washer Pro.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\InternetDelivery.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\InternetOptimizer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\InternetWasher.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IntexusDial.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IPinsight.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\iSearch desktop search.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\iSearch Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\iSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ISearchTech.ISTactiveX.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ISearchTech.ISTbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ISearchTech.ISTsvc.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ISearchTech.ISTsvc_Updater.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ISearchTech.PowerScan.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ISearchTech.SideFind.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ISearchTech.Slotch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ISearchTech.YSB.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\istbar.dotcomToolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ISTbar.Slotch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\istbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\ISTbar.XXXToolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\IwantSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\iWon.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Jeem.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Jeired.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Jraun.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\KazaaLite.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Kazoom.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\KeenValue PerfectNav.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\KeenValue.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\KEXplorer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\KeyCaptor.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Keyhost Hijacker - JRaun.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Klez.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\LimeShop.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Limewire.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\LinkGrabber 99.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\LinkMaker Hijacker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\LinkMaker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\LinkSynergy.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Locators.com Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Look2Me.Topconverting.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Look2Me.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Lop.com.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Lop.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\LoudMarketing.WinFavorites.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Lovefreegames Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Lycos Sidesearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Lycos.SideSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\LZIO.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MagicControl.Agent.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MagicControl.Av.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MagicControl.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MagicControl.WinMgts.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MainPean Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Mainpean Stardialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MainPean.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MakeThemCry.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Malware.Psguard.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Malware.TopAntiSpyware.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MarketDart.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Marketscore Internet Accelerator.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Marketscore Netsetter.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Marketscore(Netsetter).txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Masta Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Mastacash.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MatrixDialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Maxifiles.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Media Pass.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Media Tickets.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MediaBuddy (FileFreedom).txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MediaCharger.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MediaGateway.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MediaLoads Enhanced.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MediaMotor.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MediaPass.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MediaPlex.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MediaTicket.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MediaTickets.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MediaUpdate.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MegaSearch Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Megasearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Memory Watcher.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MemoryMeter.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MemoryWatcher.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Metadirect hijacker.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Metadirect.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\metareward.com Cookie.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MicroGaming.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\midADdle.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Mindset Interactive - Favoriteman.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MiniBug.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Mirar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MoeMoney.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MOM.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MoneyTree.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Morpheus.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MPGCom Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MSConnect.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MSView.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MX-Targeting.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\My Daily Horoscope.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\My Search.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\My Way.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\myDoom.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MyNetProtector.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MyPointsPointAlert.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\MySearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\n-CASE.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\NaughtyPops.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\NavExcel.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\NavHelper.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\NaviSearch.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Navpmc.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\nCASE.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\NeededWare.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Neo Toolbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Netpal.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\NetRatings Premeter.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\NetRatings.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Netservices BV.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Netsonic.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Netster Searchbar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Netvenda.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Netvision Dialer.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Netword Agent.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Network Essentials.Hopper.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Network Essentials.ScBar.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Network Essentials.Search-Exe.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Network Essentials.SmartpopOops.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Network Essentials.SmartPops.txt
c:\program files\CyberDefender\AntiSpyware\Includes\Description\Network Essentials.WindowEnhancer.txt
HoldR4D
Posts Posts : 53
OS OS : windows XP
sorry dude but its way too big so i had to post it like this
HoldR4D
Posts Posts : 53
OS OS : windows XP
Post by Dr Jay on 14th October 2009, 12:35 am
Hi
Do you have a Desktop now? If not, reboot your computer.
  1. Close any open browsers.
    KillAll::
    File::
    c:\windows\system32\rimuwuka.exe
    c:\windows\system32\sedutodo.exe
    c:\windows\system32\tojowebo.dll
    c:\windows\system32\yinazeku.dll
    c:\windows\system32\wimesabi.exe
    c:\windows\system32\pidokobo.exe
    c:\windows\system32\zabufaki.dll
    c:\docume~1\ADMINI~1\LOCALS~1\Temp\~DF5E9A.tmp
    c:\docume~1\ADMINI~1\LOCALS~1\Temp\~DF5EB6.tmp
Please post the ComboFix log and the Malwarebytes log. Also, please tell me how your computer is running and if you have a Desktop now.
Posts Posts : 14309
Points Points : 302960
Post by HoldR4D on 15th October 2009, 12:33 am
yeap it worked great ty very much i have 1 last problem at the beggining of the computer reset i get an option and it only last 3 seconds how can i elemenate that ?
HoldR4D
Posts Posts : 53
OS OS : windows XP
Post by Dr Jay on 15th October 2009, 1:12 am
Would that be something like this:
It is normal. It is installed by ComboFix, to help recover if malware has damaged your computer badly.
Please post the logs in your next reply.
Posts Posts : 14309
Post by HoldR4D on 15th October 2009, 1:53 am
yea and 3 option microsoft windows proffesional something , so theres no way i can put it to logg in direcly to the windows screen ?
HoldR4D
Posts Posts : 53
OS OS : windows XP
Post by Dr Jay on 16th October 2009, 12:42 am
Hi
Please do the following:
Right-click on My Computer.
You should be in System Properties, then click the Advanced tab.
Under the Startup and Recovery section, click Settings.
You might see one or two checkboxes at the top:
Please make sure both are unchecked.
Then, click OK. When your system starts up, it should immediately boot to Windows XP. Please confirm this, by restarting your computer.
Posts Posts : 14309
Post by HoldR4D on 29th October 2009, 3:32 am
its workin very fine ty , i try downloading avast and install it but i had to delete.
HoldR4D
Posts Posts : 53
OS OS : windows XP
Post by HoldR4D on 1st November 2009, 10:45 pm
Help With removing cyber defender antivirus please?
i can not find it on add programs and removal. and its not on start up ?
HoldR4D
Posts Posts : 53
OS OS : windows XP
Post by Dr Jay on 2nd November 2009, 3:03 am
Please start a new topic, as it has been a while since you last posted, malware may have changed or multiplied. Also, it will avoid confusion.
=> LOCKED
Posts Posts : 14309
