Antivirus System PRO
Post by bmak35 on Mon Sep 28, 2009 5:10 pm
This showed up om my computer this morning. I ran my webroot Antivirus and Spyware and got rid of the popups. How do I totally remove this from my system?
bmak35
Joined Joined : 2009-09-28
OS OS : vista
Points Points : 26263
Re: Antivirus System PRO
Post by Belahzur on Mon Sep 28, 2009 6:14 pm
Points Points : 245069
