Police Pro and AntiVirus Pro
Post by jess9979 on Sun Sep 27, 2009 9:35 pm
Hello. My computer has contracted at least these two malware programs. I went to the removal guide but when I try to download malwarebytes, it just asks me what program I want it to run with and recommends adobe. I tried the download button and the "if you are having problems". Can you help please?
jess9979
Posts Posts : 13
Joined Joined : 2009-09-27
Points Points : 26285
Re: Police Pro and AntiVirus Pro
Post by Belahzur on Sun Sep 27, 2009 9:37 pm
Points Points : 245069
Post by jess9979 on Sun Sep 27, 2009 9:52 pm
Same thing - when I try to download Hijack This, and click "RUN" a window opens to ask me what program I want to use.
jess9979
Posts Posts : 13
Post by Belahzur on Sun Sep 27, 2009 11:43 pm
Please download [You must be registered and logged in to see this link.]
  • Before running it, right click it, and remove the ".com" extension and change it to ".scr"
  • Double-click on exeHelper.scr to run the fix.
Post by jess9979 on Sun Sep 27, 2009 11:54 pm
When I tried to right click (I wasn't exactly sure when or where) it ran, the black window popped up and I got this:
xeHelper by Raktor - 09
Build 20090925
Run at 19:50:58 on 09/27/09
Now searching...
Deleting file C:\Documents and Settings\All Users\Application Data\11818124\11818124.exe
Deleting file C:\Documents and Settings\All Users\Application Data\11818124\pc11818124ins
Removing HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\11818124
Checking for bad processes...
Killed process psystem.exe
Killed process wscsvc32.exe
Checking for bad files...
Deleting file C:\WINDOWS\system32\wscsvc32.exe
Error deleting C:\WINDOWS\system32\wscsvc32.exe
Deleting file C:\WINDOWS\system32\41.exe
Deleting file C:\Program Files\Windows Police Pro\Windows Police Pro.exe
Deleting file C:\Program Files\protection system\psystem.exe
Deleting file C:\Program Files\AntivirusPro_2010\AntivirusPro_2010.exe
Deleting file C:\Documents and Settings\Jessica\Desktop\Windows Police Pro.lnk
Deleting file C:\Documents and Settings\Jessica\Desktop\AntivirusPro_2010.lnk
Removing HKU\.DEFAULT\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\Advanced Virus Remover
Resetting policies...
--Finished--
Is that o.k.?
jess9979
Posts Posts : 13
Post by Belahzur on Sun Sep 27, 2009 11:56 pm
Yep.
Can you run Hijack This now? exeHelper has restored the damaged registry value for exe files.
Post by jess9979 on Mon Sep 28, 2009 12:06 am
Yes, it ran. Thank you. Here is the log:
Scan saved at 8:03:59 PM, on 9/27/2009
C:\WINDOWS\Explorer.exe
C:\Program Files\Webroot\Spy Sweeper\WRSSSDK.exe
C:\WINDOWS\system32\net.exe
C:\WINDOWS\system32\net1.exe
C:\DOCUME~1\Jessica\LOCALS~1\Temp\csrss.exe
C:\DOCUME~1\Jessica\LOCALS~1\Temp\taskmgr.exe
C:\DOCUME~1\Jessica\LOCALS~1\Temp\debug.exe
C:\Program Files\Internet Explorer\Iexplore.exe
R3 - URLSearchHook: AOLTBSearch Class - {EA756889-2338-43DB-8F07-D1CA6FB9C90D} - C:\Program Files\AOL\AIM Toolbar 5.0\aoltb.dll
O2 - BHO: C:\WINDOWS\system32\nzfiu3h78di.dll - {BA603215-23F2-42AD-F4E4-00AAC39CAA53} - C:\WINDOWS\system32\nzfiu3h78di.dll
O3 - Toolbar: McAfee SiteAdvisor - {0BF43445-2F28-4351-9252-17FE6E806AA0} - C:\Program Files\SiteAdvisor\6261\SiteAdv.dll
O3 - Toolbar: AIM Toolbar - {DE9C389F-3316-41A7-809B-AA305ED9D922} - C:\Program Files\AOL\AIM Toolbar 5.0\aoltb.dll
O3 - Toolbar: Ask Toolbar - {3041d03e-fd4b-44e0-b742-2d9b88305f98} - C:\Program Files\AskBarDis\bar\bin\askBar.dll
O3 - Toolbar: Google Toolbar - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files\Google\Google Toolbar\GoogleToolbar.dll
O4 - HKLM\..\Run: [SpySweeper] "C:\Program Files\Webroot\Spy Sweeper\SpySweeper.exe" /startintray
O4 - HKLM\..\Run: [calc] rundll32.exe C:\WINDOWS\system32\calc.dll,_IWMPEvents@0
O4 - HKLM\..\Run: [Antivirus Pro 2010] "C:\Program Files\AntivirusPro_2010\AntivirusPro_2010.exe" /hide
O4 - HKLM\..\Run: [UserFaultCheck] %systemroot%\system32\dumprep 0 -u
O4 - HKLM\..\Run: [sabukivuw] Rundll32.exe "c:\windows\system32\norefose.dll",a
O4 - HKCU\..\Run: [mserv] C:\Documents and Settings\Jessica\Application Data\svcst.exe
O4 - HKCU\..\Run: [calc] rundll32.exe C:\DOCUME~1\Jessica\protect.dll,_IWMPEvents@0
O4 - HKCU\..\Run: [Login Software 2009] C:\DOCUME~1\Jessica\LOCALS~1\Temp\nj42n0.exe
O4 - HKCU\..\Run: [WIndows Rescue Disk] C:\DOCUME~1\Jessica\LOCALS~1\Temp\drweb.exe
O4 - HKCU\..\Run: [Protection System] "C:\Program Files\Protection System\psystem.exe" -noscan
O4 - HKCU\..\Run: [Yjafosi8kdf98winmdkmnkmfnwe] C:\DOCUME~1\Jessica\LOCALS~1\Temp\taskmgr.exe
O4 - Startup: scandisk.dll
O4 - Startup: scandisk.lnk = ?
O8 - Extra context menu item: &AOL Toolbar Search - c:\program files\aol\aim toolbar 5.0\resources\en-US\local\search.html
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_02\bin\npjpi150_02.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_02\bin\npjpi150_02.dll
O9 - Extra button: AIM Toolbar - {3369AF0D-62E9-4bda-8103-B4C75499B578} - C:\Program Files\AOL\AIM Toolbar 5.0\aoltb.dll
O16 - DPF: {DF780F87-FF2B-4DF8-92D0-73DB16A1543A} (PopCapLoader Object) - [You must be registered and logged in to see this link.]
O16 - DPF: {E2883E8F-472F-4FB0-9522-AC9BF37916A7} - [You must be registered and logged in to see this link.]
O18 - Filter: x-sdch - {B1759355-3EEC-4C1E-B0F1-B719FE26E377} - C:\Program Files\Google\Google Toolbar\Component\fastsearch_A8904FB862BD9564.dll
O20 - AppInit_DLLs: muzobapu.dll c:\windows\system32\hilozepi.dll c:\windows\system32\norefose.dll
O21 - SSODL: koronepof - {7f19e1c4-6f20-464c-87a4-82d195bd7175} - c:\windows\system32\hilozepi.dll (file missing)
O21 - SSODL: mozitudab - {1236452b-611f-4720-ab75-9e12c7906992} - c:\windows\system32\norefose.dll (file missing)
O22 - SharedTaskScheduler: ksfe98wjkodsngiwiojndg873hundggdd - {BA603215-23F2-42AD-F4E4-00AAC39CAA53} - C:\WINDOWS\system32\nzfiu3h78di.dll
O22 - SharedTaskScheduler: jugezatag - {7f19e1c4-6f20-464c-87a4-82d195bd7175} - c:\windows\system32\hilozepi.dll (file missing)
O22 - SharedTaskScheduler: jugezatag - {1236452b-611f-4720-ab75-9e12c7906992} - c:\windows\system32\norefose.dll (file missing)
O23 - Service: AntiPol (antippolice_) - Unknown owner - C:\WINDOWS\svchast.exe (file missing)
O23 - Service: Background Intelligent Transfer Service (BITS) - Unknown owner - C:\WINDOWS\
O23 - Service: Webroot Spy Sweeper Engine (svcWRSSSDK) - Webroot Software, Inc. - C:\Program Files\Webroot\Spy Sweeper\WRSSSDK.exe
End of file - 7411 bytes
jess9979
Posts Posts : 13
Post by Belahzur on Mon Sep 28, 2009 12:09 am
Post by jess9979 on Mon Sep 28, 2009 1:02 am
Hi. I am having a problem downloading Malwarebytes. I can get all the way to where it is installing, abd it says EXTRACTING FILES, gets about two thirds of the way done, and then just freezes. I don't know if it has something to do with the fact that I tried to download it earlier, before you had me run Hijack This, when I was having problems downloading.
jess9979
Posts Posts : 13
Post by jess9979 on Mon Sep 28, 2009 2:09 am
Hi - I have tried it again and it actually finished but then nothing. It is on my desktop but when I try to launch oropen it, nothing happens.
jess9979
Posts Posts : 13
Post by Belahzur on Mon Sep 28, 2009 6:21 pm
Your system is severly infected. Problem with these infections nowadays is, it causes a lot of damage. Even if we clean the malware off your system, I can't guarantee that your system will be clean afterwards, because these infections/bundles leave a lot of leftovers behind that most scanners won't even recognise and logs won't show.
Also, I can't promise you we can repair all the damage it caused... Even after cleaning the malware, you can still get errors afterwards because of the damage. Solving these is not always possible since it will be searching for a needle in a haystack to find the right cause and solution.
So, we can try to clean this up and do what we can, but keep in mind that we can't solve ALL problems this malware already caused.
In light of this it would be wise for you to back up any files and folders that you don't want to lose before we start. Reason I am telling this is because when a system is so terribly infected and we try to clean this up manually, the damage that is already present may interfere with our removal attempts.
Please download [You must be registered and logged in to see this link.] by Rorschach112 to your desktop.
  • Please disable all of your antivirus/firewall before doing this step. [You must be registered and logged in to see this link.] if you don't know how..
  • Double click the program to run it. It will only take around
    several minutes
    to run.
  • It will do a series of tasks and tell you when each one is finished.
  • You will be prompted to press any key after each step
  • When it is done it will close and exit itself automatically.
  • You can delete The_Comedian.exe once it is finished
STOP! if you can't complete this step.. Tell me more about it..
  • Download combofix from here
Post by jess9979 on Mon Sep 28, 2009 7:09 pm
OK- I can't disable my antivirus (McAfee). When I try to run ComboFix it informs me that "McAfee VirusScan" is active. I went to the website provided. It instructs me to go to the icon in the system tray, but I don't have an icon for McAfee there. When I try to open McAfee from the start menu, a McAfee intro screen appears as if the system is starting to open, but then that screen disappears and nothing happens. How do I go about turning off McAfee?
-Thanks
jess9979
Posts Posts : 13
Post by Belahzur on Mon Sep 28, 2009 11:58 pm
You can temporarily uninstall Mcafee, or boot to safe mode and run Combofix in Safe Mode.
I would recommend Safe Mode option if your not comfy with the idea of removing Mcafee, but it's upto you.
Post by jess9979 on Tue Sep 29, 2009 1:45 am
I was able to successfully run ComboFix. Here is the log:
ComboFix 09-09-28.01 - Jessica 09/28/2009 21:25.1.1 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.382.210 [GMT -4:00]
Running from: c:\documents and settings\Jessica\Desktop\Combo-Fix.exe
AV: McAfee VirusScan *On-access scanning enabled* (Updated) {84B5EE75-6421-4CDE-A33A-DD43BA9FAD83}
FW: McAfee Personal Firewall *enabled* {94894B63-8C7F-4050-BDA4-813CA00DA3E8}
C:\aoqwlrag.exe
C:\cqfuy.exe
C:\ddqud.exe
c:\docume~1\Jessica\LOCALS~1\Temp\lsass.exe
c:\documents and settings\All Users\Application Data\alohuf.vbs
c:\documents and settings\All Users\Desktop\nudetube.com.lnk
c:\documents and settings\All Users\Desktop\pornotube.com.lnk
c:\documents and settings\All Users\Desktop\youporn.com.lnk
c:\documents and settings\All Users\Documents\ewifebury.inf
c:\documents and settings\All Users\Documents\ytemibi.exe
c:\documents and settings\Jessica\Application Data\exyhazux.vbs
c:\documents and settings\Jessica\Application Data\lizkavd.exe
c:\documents and settings\Jessica\Application Data\Microsoft\Internet Explorer\Quick Launch\Advanced Virus Remover.lnk
c:\documents and settings\Jessica\Application Data\Microsoft\Internet Explorer\Quick Launch\AntivirusPro_2010.lnk
c:\documents and settings\Jessica\Application Data\seres.exe
c:\documents and settings\Jessica\Application Data\svcst.exe
c:\documents and settings\Jessica\Cookies\guqagokid.scr
c:\documents and settings\Jessica\Local Settings\Application Data\nigama.vbs
c:\documents and settings\Jessica\Local Settings\Application Data\unataxype.vbs
c:\documents and settings\Jessica\Local Settings\Application Data\xofoh.inf
c:\documents and settings\Jessica\Local Settings\Temporary Internet Files\osif.db
c:\documents and settings\Jessica\Start Menu\Programs\AntivirusPro_2010
c:\documents and settings\Jessica\Start Menu\Programs\AntivirusPro_2010\AntivirusPro_2010.lnk
c:\documents and settings\Jessica\Start Menu\Programs\AntivirusPro_2010\Uninstall.lnk
C:\hxlqib.exe
C:\p2hhr.bat
C:\pkusq.exe
c:\program files\AntivirusPro_2010
c:\program files\AntivirusPro_2010\AntivirusPro_2010.cfg
c:\program files\AntivirusPro_2010\AVEngn.dll
c:\program files\AntivirusPro_2010\data\daily.cvd
c:\program files\AntivirusPro_2010\htmlayout.dll
c:\program files\AntivirusPro_2010\Microsoft.VC80.CRT\Microsoft.VC80.CRT.manifest
c:\program files\AntivirusPro_2010\Microsoft.VC80.CRT\msvcm80.dll
c:\program files\AntivirusPro_2010\Microsoft.VC80.CRT\msvcp80.dll
c:\program files\AntivirusPro_2010\Microsoft.VC80.CRT\msvcr80.dll
c:\program files\AntivirusPro_2010\pthreadVC2.dll
c:\program files\AntivirusPro_2010\Uninstall.exe
c:\program files\AntivirusPro_2010\wscui.cpl
c:\program files\Common Files\bapulikal.bat
c:\program files\Protection System
c:\program files\Protection System\core.cga
c:\program files\Protection System\coreext.dll
c:\program files\Protection System\firewall.dll
c:\program files\Protection System\help.ico
c:\program files\Protection System\psystem.exe
c:\program files\Protection System\uninstall.exe
c:\program files\Windows Police Pro
c:\program files\Windows Police Pro\msvcm80.dll
c:\program files\Windows Police Pro\msvcp80.dll
c:\program files\Windows Police Pro\msvcr80.dll
c:\program files\Windows Police Pro\tmp\dbsinit.exe
c:\windows\Downloaded Program Files\popcaploader.dll
c:\windows\Downloaded Program Files\popcaploader.inf
c:\windows\emusu._dl
c:\windows\Installer\128efd.msi
c:\windows\jymicyh.vbs
c:\windows\system32\config\systemprofile\protect.dll
c:\windows\system32\dahihiwi.exe
c:\windows\system32\doby.scr
c:\windows\system32\drivers\UACotowylvrgi.sys
c:\windows\system32\hafedeku.dll
c:\windows\system32\hopawiki.exe
c:\windows\system32\images
c:\windows\system32\kofipulo.dll
c:\windows\system32\lipemeye.exe
c:\windows\system32\muzobapu.dll.tmp
c:\windows\system32\nahilifo.dll
c:\windows\system32\nqpibfqp.dll
c:\windows\system32\nzFIu3h78di.dll
c:\windows\system32\regoyivu.dll
c:\windows\system32\UACafulkrjgxi.dll
c:\windows\system32\UAChbahmplvbb.dll
c:\windows\system32\UACidljljlppf.db
c:\windows\system32\uacinit.dll
c:\windows\system32\UACkioettftiv.dll
c:\windows\system32\UAClrxubfwqpl.dll
c:\windows\system32\UACmsqrrbjteh.dat
c:\windows\system32\UACtbafbwkqpp.dll
c:\windows\system32\uactmp.db
c:\windows\system32\vafiyene.exe
c:\windows\system32\vasidifu.exe
c:\windows\system32\verazubo.dll.tmp
c:\windows\system32\wbem\proquota.exe
c:\windows\system32\wowidezo.dll.tmp
c:\windows\system32\zakisohi.exe
c:\windows\Temp\1654329584.exe
c:\windows\tetybano.pif
C:\yhjj.exe
c:\windows\system32\proquota.exe . . . is missing!!
-------\Service_UACd.sys
-------\Legacy_UACd.sys
-------\Legacy_usbdriver
-------\Service_usbdriver
((((((((((((((((((((((((( Files Created from 2009-08-28 to 2009-09-29 )))))))))))))))))))))))))))))))
2009-09-28 22:36 . 2009-09-28 22:36 -------- d-----w- c:\documents and settings\Jessica\Application Data\McAfee
2009-09-28 18:36 . 2009-09-28 18:36 -------- d-----w- c:\program files\ERUNT
2009-09-28 00:27 . 2009-09-10 18:54 38224 ----a-w- c:\windows\system32\drivers\mbamswissarmy.sys
2009-09-28 00:27 . 2009-09-28 02:53 -------- d-----w- c:\program files\Malwarebytes' Anti-Malware
2009-09-28 00:27 . 2009-09-28 00:27 -------- d-----w- c:\documents and settings\All Users\Application Data\Malwarebytes
2009-09-28 00:27 . 2009-09-10 18:53 19160 ----a-w- c:\windows\system32\drivers\mbam.sys
2009-09-28 00:03 . 2009-09-28 00:03 -------- d-----w- c:\program files\Trend Micro
2009-09-23 21:25 . 2009-09-28 20:42 1570 ----a-w- c:\windows\system32\nqpibfqp.dat
2009-09-23 21:19 . 2009-09-27 23:51 -------- d-----w- c:\documents and settings\All Users\Application Data\11818124
2009-09-23 21:19 . 2009-09-23 21:19 -------- d-----w- c:\documents and settings\All Users\Application Data\11818284
2009-09-23 21:19 . 2009-09-23 21:19 155267 ----a-w- c:\windows\system32\vgcdtasa.dll
2009-09-23 20:25 . 2009-09-27 20:42 0 ----a-w- c:\windows\system32\drivers\a0367ed0.sys
2009-09-23 20:23 . 2009-09-23 20:26 22528 --sha-w- c:\windows\system32\calc.dll
2009-09-23 20:22 . 2009-09-23 20:22 143368 ------w- C:\mlhlsvq.exe
2009-09-17 19:18 . 2009-09-17 19:18 -------- d-----w- C:\Webroot
2009-09-13 03:21 . 2005-05-19 18:06 102912 ----a-w- c:\windows\system32\islzma.dll
2009-09-13 03:21 . 2009-09-13 03:21 -------- d-----w- c:\program files\Webroot
2009-09-13 03:21 . 2009-09-13 03:21 -------- d-----w- c:\documents and settings\Jessica\Application Data\Webroot
2009-09-13 03:21 . 2005-07-06 20:16 428032 ----a-w- c:\windows\WRServices.dll
2009-09-04 07:10 . 2009-09-04 07:12 -------- d-----w- C:\18bed3b494b7996a92
2009-09-04 07:09 . 2009-09-04 07:43 -------- d-----w- c:\windows\SxsCaPendDel
2009-09-01 07:04 . 2009-09-01 07:04 -------- d-----w- c:\windows\ServicePackFiles
2009-09-29 01:02 . 2007-08-08 21:21 -------- d-----w- c:\program files\Common Files\McAfee
2009-09-29 01:02 . 2007-08-08 21:15 -------- d-----w- c:\documents and settings\All Users\Application Data\McAfee
2009-09-29 01:02 . 2007-08-08 21:20 -------- d-----w- c:\program files\McAfee
2009-09-28 21:38 . 2007-08-08 21:28 -------- d-----w- c:\documents and settings\All Users\Application Data\Google Updater
2009-09-27 20:38 . 2009-06-27 20:38 50176 --sha-w- c:\windows\system32\gazizisa.dll
2009-09-23 21:20 . 2009-09-23 21:20 17314 ----a-w- c:\program files\Common Files\ekogep._sy
2009-09-16 20:03 . 2008-08-06 18:46 -------- d-----w- c:\program files\Microsoft Silverlight
2009-09-13 03:26 . 2007-08-08 21:43 -------- d-----w- c:\program files\IrfanView
2009-09-12 02:57 . 2007-10-19 02:18 -------- d-----w- c:\documents and settings\Jessica\Application Data\Move Networks
2009-08-05 09:11 . 2004-08-04 12:00 204800 ----a-w- c:\windows\system32\mswebdvd.dll
2009-07-29 04:53 . 2004-08-04 12:00 82432 ----a-w- c:\windows\system32\fontsub.dll
2009-07-29 04:53 . 2004-08-04 12:00 119808 ----a-w- c:\windows\system32\t2embed.dll
2009-07-17 18:55 . 2004-08-04 12:00 58880 ----a-w- c:\windows\system32\atl.dll
2009-07-14 03:43 . 2004-08-04 12:00 286208 ----a-w- c:\windows\system32\wmpdxm.dll
"{3041d03e-fd4b-44e0-b742-2d9b88305f98}"= "c:\program files\AskBarDis\bar\bin\askBar.dll" [2008-07-17 279944]
[HKEY_CLASSES_ROOT\clsid\{3041d03e-fd4b-44e0-b742-2d9b88305f98}]
[HKEY_CLASSES_ROOT\TypeLib\{4b1c1e16-6b34-430e-b074-5928eca4c150}]
"{3041D03E-FD4B-44E0-B742-2D9B88305F98}"= "c:\program files\AskBarDis\bar\bin\askBar.dll" [2008-07-17 279944]
"swg"="c:\program files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe" [2007-08-08 68856]
"QuickTime Task"="c:\program files\QuickTime\qttask.exe" [2008-05-27 413696]
"SpySweeper"="c:\program files\Webroot\Spy Sweeper\SpySweeper.exe" [2005-07-06 2972672]
c:\documents and settings\Jessica\Start Menu\Programs\Startup\
ERUNT AutoBackup.lnk - c:\program files\ERUNT\AUTOBACK.EXE [2005-10-20 38912]
[HKEY_USERS\.default\software\microsoft\windows\currentversion\policies\explorer]
"NoSetActiveDesktop"= 1 (0x1)
"NoActiveDesktopChanges"= 1 (0x1)
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Microsoft Find Fast.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Microsoft Find Fast.lnk
backup=c:\windows\pss\Microsoft Find Fast.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^All Users^Start Menu^Programs^Startup^Office Startup.lnk]
path=c:\documents and settings\All Users\Start Menu\Programs\Startup\Office Startup.lnk
backup=c:\windows\pss\Office Startup.lnkCommon Startup
[HKLM\~\startupfolder\C:^Documents and Settings^Jessica^Start Menu^Programs^Startup^Webshots.lnk]
path=c:\documents and settings\Jessica\Start Menu\Programs\Startup\Webshots.lnk
backup=c:\windows\pss\Webshots.lnkStartup
"WMPNetworkSvc"=3 (0x3)
"Viewpoint Manager Service"=2 (0x2)
"MpfService"=2 (0x2)
"McSysmon"=3 (0x3)
"McShield"=2 (0x2)
"McProxy"=2 (0x2)
"McODS"=3 (0x3)
"McNASvc"=2 (0x2)
"mcmscsvc"=2 (0x2)
"LVSrvLauncher"=2 (0x2)
"LVPrcSrv"=2 (0x2)
"iPod Service"=3 (0x3)
"idsvc"=3 (0x3)
"hpqwmi"=3 (0x3)
"gusvc"=2 (0x2)
"Bonjour Service"=2 (0x2)
"Ati HotKey Poller"=2 (0x2)
"Apple Mobile Device"=2 (0x2)
"UpdatesDisableNotify"=dword:00000001
"c:\\Program Files\\Common Files\\McAfee\\MNA\\McNASvc.exe"=
"c:\\Program Files\\Java\\jre1.5.0_02\\bin\\javaw.exe"=
R2 Viewpoint Manager Service;Viewpoint Manager Service;c:\program files\Viewpoint\Common\ViewpointService.exe [6/20/2009 7:38 AM 24652]
R3 HSFHWATI;HSFHWATI;c:\windows\system32\drivers\HSFHWATI.sys [8/6/2007 9:18 PM 231424]
S1 a0367ed0;a0367ed0;c:\windows\system32\drivers\a0367ed0.sys [9/23/2009 4:25 PM 0]
S2 antippolice_;AntiPol;c:\windows\svchast.exe --> c:\windows\svchast.exe [?]
*Deregistered* - mchInjDrv
2009-09-17 c:\windows\Tasks\AppleSoftwareUpdate.job
- c:\program files\Apple Software Update\SoftwareUpdate.exe [2007-08-29 16:34]
2009-09-29 c:\windows\Tasks\Google Software Updater.job
- c:\program files\Google\Common\Google Updater\GoogleUpdaterService.exe [2007-08-08 00:39]
2009-09-15 c:\windows\Tasks\McDefragTask.job
- c:\program files\mcafee\mqc\QcConsol.exe [2007-08-08 17:32]
2009-09-01 c:\windows\Tasks\McQcTask.job
IE: &AOL Toolbar Search - c:\program files\aol\aim toolbar 5.0\resources\en-US\local\search.html
Trusted Zone: internet
Trusted Zone: mcafee.com
BHO-{142bbaa6-82a0-4375-a9c3-e02096bdff2f} - vujigami.dll
HKCU-Run-Protection System - c:\program files\Protection System\psystem.exe
HKCU-Run-Aim6 - (no file)
HKLM-Run-sabukivuw - c:\windows\system32\hutijezu.dll
HKLM-Run-tefehunefu - hafedeku.dll
SharedTaskScheduler-{1236452b-611f-4720-ab75-9e12c7906992} - c:\windows\system32\norefose.dll
SharedTaskScheduler-{931e46ed-0ae0-44cc-be27-173f9d4f4708} - c:\windows\system32\hutijezu.dll
SSODL-mozitudab-{1236452b-611f-4720-ab75-9e12c7906992} - c:\windows\system32\norefose.dll
SSODL-mowigabom-{931e46ed-0ae0-44cc-be27-173f9d4f4708} - c:\windows\system32\hutijezu.dll
AddRemove-protection system - c:\program files\Protection System\Uninstall.exe
Rootkit scan 2009-09-28 21:37
scanning hȋdden processes ...
scanning hȋdden files ...
hȋdden files: 0
[HKEY_LOCAL_MACHINE\System\ControlSet001\Services\mchInjDrv]
"ImagePath"="\??\c:\windows\TEMP\mc22.tmp"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{19114156-8E9A-4D4E-9EE9-17A0E48D3BBB}]
@Denied: (A 2) (Everyone)
@="FlashBroker"
"LocalizedString"="@c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10c.exe,-101"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{19114156-8E9A-4D4E-9EE9-17A0E48D3BBB}\Elevation]
"Enabled"=dword:00000001
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{19114156-8E9A-4D4E-9EE9-17A0E48D3BBB}\LocalServer32]
@="c:\\WINDOWS\\system32\\Macromed\\Flash\\FlashUtil10c.exe"
[HKEY_LOCAL_MACHINE\software\Classes\CLSID\{19114156-8E9A-4D4E-9EE9-17A0E48D3BBB}\TypeLib]
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{1D4C8A81-B7AC-460A-8C23-98713C41D6B3}]
@="IFlashBroker3"
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{1D4C8A81-B7AC-460A-8C23-98713C41D6B3}\ProxyStubClsid32]
[HKEY_LOCAL_MACHINE\software\Classes\Interface\{1D4C8A81-B7AC-460A-8C23-98713C41D6B3}\TypeLib]
"Version"="1.0"
- - - - - - - > 'winlogon.exe'(660)
- - - - - - - > 'explorer.exe'(3828)
c:\program files\Webroot\Spy Sweeper\WRSSSDK.exe
c:\program files\Viewpoint\Viewpoint Manager\ViewMgr.exe
Completion time: 2009-09-29 21:42 - machine was rebooted
ComboFix-quarantined-files.txt 2009-09-29 01:41
Pre-Run: 45,570,519,040 bytes free
Post-Run: 46,642,593,792 bytes free
337 --- E O F --- 2009-09-09 07:02
jess9979
Posts Posts : 13
Post by Belahzur on Tue Sep 29, 2009 10:36 pm
  1. Close any open browsers.
    File::
    C:\mlhlsvq.exe
    Folder::
    Registry::
    "UpdatesDisableNotify"=-
    [-HKEY_LOCAL_MACHINE\System\ControlSet001\Services\mchInjDrv]
    Driver::
    a0367ed0
    antippolice_
    RegLock::
Post by jess9979 on Tue Sep 29, 2009 11:43 pm
Hello. Here's the log:
ComboFix 09-09-28.01 - Jessica 09/29/2009 19:20.2.1 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.382.110 [GMT -4:00]
Command switches used :: c:\documents and settings\Jessica\Desktop\CFScript.txt
* Resident AV is active
FILE ::
"C:\mlhlsvq.exe"
"c:\program files\Common Files\ekogep._sy"
"c:\windows\system32\calc.dll"
"c:\windows\system32\drivers\a0367ed0.sys"
"c:\windows\system32\gazizisa.dll"
"c:\windows\system32\nqpibfqp.dat"
"c:\windows\system32\vgcdtasa.dll"
C:\mlhlsvq.exe
-------\Legacy_antippolice_
-------\Service_a0367ed0
-------\Service_antippolice_
2009-09-29 15:30 . 2009-09-29 15:30 -------- d-----w- c:\documents and settings\LocalService\Application Data\SACore
2009-09-29 15:22 . 2009-07-08 17:44 79816 ----a-w- c:\windows\system32\drivers\mfeavfk.sys
2009-09-29 15:22 . 2009-07-08 17:44 40552 ----a-w- c:\windows\system32\drivers\mfesmfk.sys
2009-09-29 15:22 . 2009-07-08 17:44 35272 ----a-w- c:\windows\system32\drivers\mfebopk.sys
2009-09-29 15:22 . 2009-07-16 16:32 120136 ----a-w- c:\windows\system32\drivers\Mpfp.sys
2009-09-29 15:21 . 2009-09-29 15:22 -------- d-----w- c:\program files\Common Files\McAfee
2009-09-29 15:21 . 2009-09-29 15:22 -------- d-----w- c:\program files\McAfee.com
2009-09-29 15:17 . 2009-07-08 17:43 34248 ----a-w- c:\windows\system32\drivers\mferkdk.sys
2009-09-29 22:41 . 2007-08-08 21:28 -------- d-----w- c:\documents and settings\All Users\Application Data\Google Updater
2009-09-29 18:23 . 2007-08-08 21:15 -------- d-----w- c:\documents and settings\All Users\Application Data\McAfee
2009-09-29 17:37 . 2007-08-08 21:20 -------- d-----w- c:\program files\McAfee
2009-09-29 15:13 . 2007-08-08 21:24 -------- d-----w- c:\documents and settings\All Users\Application Data\SiteAdvisor
2009-07-08 17:44 . 2009-07-08 17:44 214024 ----a-w- c:\windows\system32\drivers\mfehidk.sys
- 2004-08-04 12:00 . 2009-09-29 01:29 71462 c:\windows\system32\perfc009.dat
+ 2004-08-04 12:00 . 2009-09-29 23:13 71462 c:\windows\system32\perfc009.dat
+ 2007-08-07 01:11 . 2009-09-29 20:10 32768 c:\windows\system32\config\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\index.dat
- 2007-08-07 01:11 . 2009-09-29 01:01 32768 c:\windows\system32\config\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\index.dat
+ 2007-08-07 01:11 . 2009-09-29 20:10 32768 c:\windows\system32\config\systemprofile\Local Settings\History\History.IE5\index.dat
- 2007-08-07 01:11 . 2009-09-29 01:01 32768 c:\windows\system32\config\systemprofile\Local Settings\History\History.IE5\index.dat
+ 2009-09-29 20:04 . 2009-09-29 20:10 32768 c:\windows\system32\config\systemprofile\Cookies\index.dat
- 2007-08-07 01:11 . 2009-09-29 01:01 32768 c:\windows\system32\config\systemprofile\Cookies\index.dat
+ 2009-09-29 14:58 . 2009-09-29 14:58 53248 c:\windows\ERDNT\AutoBackup\9-29-2009\Users\00000002\UsrClass.dat
- 2004-08-04 12:00 . 2009-09-29 01:29 441692 c:\windows\system32\perfh009.dat
+ 2004-08-04 12:00 . 2009-09-29 23:13 441692 c:\windows\system32\perfh009.dat
+ 2009-09-29 14:58 . 2005-10-20 16:02 163328 c:\windows\ERDNT\AutoBackup\9-29-2009\ERDNT.EXE
+ 2009-09-29 14:58 . 2009-09-29 14:58 3624960 c:\windows\ERDNT\AutoBackup\9-29-2009\Users\00000001\NTUSER.DAT
"mcagent_exe"="c:\program files\McAfee.com\Agent\mcagent.exe" [2009-07-10 645328]
"McSysmon"=3 (0x3)
"McShield"=2 (0x2)
"McProxy"=2 (0x2)
"McODS"=3 (0x3)
"McNASvc"=2 (0x2)
"mcmscsvc"=2 (0x2)
"LVPrcSrv"=2 (0x2)
"idsvc"=3 (0x3)
"hpqwmi"=3 (0x3)
"gusvc"=2 (0x2)
"EnableFirewall"= 0 (0x0)
R2 McAfee SiteAdvisor Service;McAfee SiteAdvisor Service;c:\program files\McAfee\SiteAdvisor\McSACore.exe [9/29/2009 11:26 AM 203280]
2009-09-29 c:\windows\Tasks\McDefragTask.job
- c:\progra~1\mcafee\mqc\QcConsol.exe [2009-09-29 01:26]
2009-09-29 c:\windows\Tasks\McQcTask.job
Rootkit scan 2009-09-29 19:33
hȋdden files: 0
- - - - - - - > 'winlogon.exe'(664)
- - - - - - - > 'explorer.exe'(3696)
c:\program files\McAfee\SiteAdvisor\saHook.dll
c:\progra~1\McAfee\MSC\mcmscsvc.exe
c:\progra~1\COMMON~1\McAfee\MNA\McNASvc.exe
c:\progra~1\COMMON~1\McAfee\McProxy\McProxy.exe
c:\progra~1\McAfee\VIRUSS~1\Mcshield.exe
c:\program files\McAfee\MPF\MpfSrv.exe
c:\progra~1\McAfee.com\Agent\mcagent.exe
Completion time: 2009-09-29 19:39 - machine was rebooted
ComboFix-quarantined-files.txt 2009-09-29 23:39
ComboFix2.txt 2009-09-29 01:42
Pre-Run: 46,489,882,624 bytes free
Post-Run: 46,496,727,040 bytes free
221 --- E O F --- 2009-09-09 07:02
jess9979
Posts Posts : 13
Post by Belahzur on Wed Sep 30, 2009 10:15 pm
    :filefind
    proquota.exe
Post by jess9979 on Wed Sep 30, 2009 11:07 pm
SystemLook v1.0 by jpshortstuff (29.08.09)
Log created at 19:00 on 30/09/2009 by Jessica (Administrator - Elevation successful)
Searching for "proquota.exe"
C:\WINDOWS\SoftwareDistribution\Download\dd9ab5193501484cf5e6884fa1d22f9e\proquota.exe --a--- 50176 bytes [20:34 30/08/2008] [00:12 14/04/2008] F6465A2EEF75468988A4FCF124148FA8
-=End Of File=-
jess9979
Posts Posts : 13
Post by Belahzur on Thu Oct 01, 2009 12:18 am
Thanks for that, nearly done now. Next, an uninstall log.
  • Open HijackThis.
Post by jess9979 on Thu Oct 01, 2009 12:27 am
Hello again. Here's the results:
Adobe Flash Player 10 ActiveX
Adobe Reader 6.0.1
AIM 6
AIM Toolbar 5.0
Apple Mobile Device Support
Ask Toolbar
Athlon 64 Processor Driver
ATI - Software Uninstall Utility
ATI Control Panel
ATI Display Driver
Bonjour
Broadcom 802.11 reƖ LAN Adapter
Conexant AC-Link Audio
Data Fax SoftModem with SmartCP
ERUNT 1.1j
Garmin Trip and Waypoint Manager v4
Google Updater
GRE POWERPREP
HijackThis 2.0.2
Hotfix for Windows XP (KB896344)
Hotfix for Windows XP (KB914440)
Hotfix for Windows XP (KB915865)
Hotfix for Windows XP (KB926239)
HP Help and Support
HP Software Update
HP User Guides 0001
HP reƖ Assistant 1.01 A2
ImageJ 1.41o
InterActual Player
InterVideo WinDVD
iTunes
J2SE Runtime Environment 5.0 Update 2
LimeWire 4.14.10
Logitech Audio Echo Cancellation Component
Logitech QuickCam
Logitech Video Enumerator
Logitech® Camera Driver
McAfee SecurityCenter
Microsoft .NET Framework 1.1
Microsoft Base Smart Card Cryptographic Service Provider Package
Microsoft Office 97, Professional Edition
Microsoft VC9 runtime libraries
MSXML 4.0 SP2 (KB927978)
MSXML 4.0 SP2 (KB936181)
MSXML 4.0 SP2 (KB954430)
MSXML 6 Service Pack 2 (KB954459)
muvee autoProducer 4.0 - SE
MVision
Quick Launch Buttons 5.10 B2
QuickTime
REALTEK Gigabit and Fast Ethernet NIC Driver
RollerCoaster Tycoon 2 Triple Thrill Pack
Security Update for Windows XP (KB890046)
Security Update for Windows XP (KB893756)
Security Update for Windows XP (KB896358)
Security Update for Windows XP (KB896423)
Security Update for Windows XP (KB896428)
Security Update for Windows XP (KB899587)
Security Update for Windows XP (KB899591)
Security Update for Windows XP (KB900725)
Security Update for Windows XP (KB901017)
Security Update for Windows XP (KB901190)
Security Update for Windows XP (KB901214)
Security Update for Windows XP (KB902400)
Security Update for Windows XP (KB904706)
Security Update for Windows XP (KB905414)
Security Update for Windows XP (KB905749)
Security Update for Windows XP (KB908519)
Security Update for Windows XP (KB911562)
Security Update for Windows XP (KB911927)
Security Update for Windows XP (KB913580)
Security Update for Windows XP (KB914388)
Security Update for Windows XP (KB914389)
Security Update for Windows XP (KB917344)
Security Update for Windows XP (KB917953)
Security Update for Windows XP (KB918118)
Security Update for Windows XP (KB918439)
Security Update for Windows XP (KB919007)
Security Update for Windows XP (KB920213)
Security Update for Windows XP (KB920670)
Security Update for Windows XP (KB920683)
Security Update for Windows XP (KB920685)
Security Update for Windows XP (KB921503)
Security Update for Windows XP (KB922819)
Security Update for Windows XP (KB923191)
Security Update for Windows XP (KB923414)
Security Update for Windows XP (KB923980)
Security Update for Windows XP (KB924191)
Security Update for Windows XP (KB924270)
Security Update for Windows XP (KB924496)
Security Update for Windows XP (KB924667)
Security Update for Windows XP (KB925902)
Security Update for Windows XP (KB926255)
Security Update for Windows XP (KB926436)
Security Update for Windows XP (KB927779)
Security Update for Windows XP (KB927802)
Security Update for Windows XP (KB928255)
Security Update for Windows XP (KB928843)
Security Update for Windows XP (KB929123)
Security Update for Windows XP (KB930178)
Security Update for Windows XP (KB931261)
Security Update for Windows XP (KB931784)
Security Update for Windows XP (KB932168)
Security Update for Windows XP (KB933566)
Security Update for Windows XP (KB933729)
Security Update for Windows XP (KB935839)
Security Update for Windows XP (KB935840)
Security Update for Windows XP (KB936021)
Security Update for Windows XP (KB938829)
Security Update for Windows XP (KB941202)
Security Update for Windows XP (KB941568)
Security Update for Windows XP (KB941644)
Security Update for Windows XP (KB941693)
Security Update for Windows XP (KB943055)
Security Update for Windows XP (KB943460)
Security Update for Windows XP (KB943485)
Security Update for Windows XP (KB944653)
Security Update for Windows XP (KB945553)
Security Update for Windows XP (KB946026)
Security Update for Windows XP (KB948590)
Security Update for Windows XP (KB948881)
Security Update for Windows XP (KB950749)
Security Update for Windows XP (KB961371-v2)
Sonic Audio Module
Sonic Copy Module
Sonic Data Module
Sonic Express Labeler
Sonic MyDVD Plus
Sonic Update Manager
Synaptics Pointing Device Driver
Texas Instruments PCIxx21/x515 drivers.
Update for Windows XP (KB894391)
Update for Windows XP (KB900485)
Update for Windows XP (KB904942)
Update for Windows XP (KB908531)
Update for Windows XP (KB910437)
Update for Windows XP (KB911280)
Update for Windows XP (KB916595)
Update for Windows XP (KB920342)
Update for Windows XP (KB920872)
Update for Windows XP (KB922582)
Update for Windows XP (KB925720)
Update for Windows XP (KB925876)
Update for Windows XP (KB927891)
Update for Windows XP (KB930916)
Update for Windows XP (KB931836)
Update for Windows XP (KB932823-v3)
Update for Windows XP (KB933360)
Update for Windows XP (KB938828)
Update for Windows XP (KB942763)
Viewpoint Manager (Remove Only)
Viewpoint Media Player
Webshots Desktop
Windows Imaging Component
Windows Media Format SDK Hotfix - KB891122
Windows Presentation Foundation
Windows XP Hotfix - KB873333
Windows XP Hotfix - KB873339
Windows XP Hotfix - KB883667
Windows XP Hotfix - KB884575
Windows XP Hotfix - KB885250
Windows XP Hotfix - KB885835
Windows XP Hotfix - KB885836
Windows XP Hotfix - KB885855
Windows XP Hotfix - KB885884
Windows XP Hotfix - KB886185
Windows XP Hotfix - KB887472
Windows XP Hotfix - KB888113
Windows XP Hotfix - KB888239
Windows XP Hotfix - KB888302
Windows XP Hotfix - KB890047
Windows XP Hotfix - KB890175
Windows XP Hotfix - KB890859
Windows XP Hotfix - KB891781
Windows XP Hotfix - KB892559
Zone Deluxe Games
jess9979
Posts Posts : 13
Post by Belahzur on Thu Oct 01, 2009 10:25 am
I see that you are running Limewire.
If Limewire is not removed, then I won't help you.
    LimeWire 4.14.10
Next,
    FCopy::
    C:\WINDOWS\SoftwareDistribution\Download\dd9ab5193501484cf5e6884fa1d22f9e\proquota.exe | c:\windows\system32\proquota.exe
Post by jess9979 on Thu Oct 01, 2009 10:44 pm
Hello. I removed the above programs and ran combofix. Here's the log:
ComboFix 09-09-28.01 - Jessica 10/01/2009 18:32.3.1 - NTFSx86
Microsoft Windows XP Home Edition 5.1.2600.2.1252.1.1033.18.382.154 [GMT -4:00]
c:\windows\SoftwareDistribution\Download\dd9ab5193501484cf5e6884fa1d22f9e\proquota.exe --> c:\windows\system32\proquota.exe
((((((((((((((((((((((((( Files Created from 2009-09-01 to 2009-10-01 )))))))))))))))))))))))))))))))
2009-10-01 22:32 . 2008-04-14 00:12 50176 ----a-w- c:\windows\system32\proquota.exe
2009-10-01 21:43 . 2009-10-01 21:43 -------- d-----w- c:\windows\system32\config\systemprofile\Application Data\SACore
2009-10-01 21:59 . 2007-08-09 00:54 -------- d-----w- c:\program files\Webshots
2009-10-01 21:41 . 2007-08-08 21:20 -------- d-----w- c:\program files\McAfee
2009-09-30 23:42 . 2007-08-08 21:28 -------- d-----w- c:\documents and settings\All Users\Application Data\Google Updater
+ 2004-08-04 12:00 . 2009-10-01 22:06 71462 c:\windows\system32\perfc009.dat
+ 2007-08-07 01:11 . 2009-10-01 21:53 32768 c:\windows\system32\config\systemprofile\Local Settings\Temporary Internet Files\Content.IE5\index.dat
+ 2007-08-07 01:11 . 2009-10-01 21:53 32768 c:\windows\system32\config\systemprofile\Local Settings\History\History.IE5\index.dat
+ 2009-09-30 00:54 . 2009-10-01 21:53 32768 c:\windows\system32\config\systemprofile\Cookies\index.dat
+ 2009-10-01 21:43 . 2009-10-01 21:43 53248 c:\windows\ERDNT\AutoBackup\10-1-2009\Users\00000002\UsrClass.dat
+ 2004-08-04 12:00 . 2009-10-01 22:06 441692 c:\windows\system32\perfh009.dat
+ 2009-10-01 21:43 . 2005-10-20 16:02 163328 c:\windows\ERDNT\AutoBackup\10-1-2009\ERDNT.EXE
+ 2009-10-01 21:43 . 2009-10-01 21:43 3624960 c:\windows\ERDNT\AutoBackup\10-1-2009\Users\00000001\NTUSER.DAT
"McSysmon"=3 (0x3)
"McShield"=2 (0x2)
"McProxy"=2 (0x2)
"McODS"=3 (0x3)
"McNASvc"=2 (0x2)
"mcmscsvc"=2 (0x2)
"LVPrcSrv"=2 (0x2)
"idsvc"=3 (0x3)
"hpqwmi"=3 (0x3)
"gusvc"=2 (0x2)
R2 McAfee SiteAdvisor Service;McAfee SiteAdvisor Service;c:\program files\McAfee\SiteAdvisor\McSACore.exe [9/29/2009 11:26 AM 210216]
2009-10-01 c:\windows\Tasks\AppleSoftwareUpdate.job
2009-10-01 c:\windows\Tasks\Google Software Updater.job
2009-10-01 c:\windows\Tasks\McQcTask.job
Rootkit scan 2009-10-01 18:38
hȋdden files: 0
- - - - - - - > 'explorer.exe'(1960)
Completion time: 2009-10-01 18:41
ComboFix-quarantined-files.txt 2009-10-01 22:41
ComboFix2.txt 2009-09-29 23:39
ComboFix3.txt 2009-09-29 01:42
Pre-Run: 46,365,315,072 bytes free
Post-Run: 46,337,490,944 bytes free
193 --- E O F --- 2009-09-09 07:02
jess9979
Posts Posts : 13
Post by Belahzur on Thu Oct 01, 2009 11:52 pm
    Ask Toolbar
ComboFix /u
Post by jess9979 on Fri Oct 02, 2009 12:07 am
Everything appears to be running normally again. I really appreciate your help.
jess9979
Posts Posts : 13
