Need help with 3 issues please
Post by tafzal on Mon 28 Sep 2009, 2:37 am
1. During the start up process, it freezes (without any messages) on the blue screen (before the ctrl-alt-del window). I then turn it off and then on again. It takes 2-4 times before i can log on. (no messages it shows)
2. I keep on getting "just-in-time debugging" message window. Should I turn it on or off, is it good ?
3. When I do the Task Manager, it shows the running of something called 'sjiqg hajxg lwxo xmugnvnyjolie'. What is this, and when i cancel or kill it, it comes back after 5 seconds
4. Is there anything else below in te 'hijackthis' that i should get rid of ?
Scan saved at 11:22:10 AM, on 9/27/2009
C:\Program Files\Windows Defender\MsMpEng.exe
C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe
C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
C:\Program Files\McAfee\Common Framework\FrameworkService.exe
C:\Program Files\Network Associates\VirusScan\VsTskMgr.exe
C:\Program Files\ProtectTools\Embedded Security Software\PSDsrvc.EXE
C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
C:\Program Files\Network Associates\Remote Desktop 32\CONNSRV.EXE
C:\Program Files\ProtectTools\Embedded Security Software\PSDrt.exe
C:\Program Files\Lavasoft\Ad-Aware\AAWTray.exe
C:\Program Files\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe
C:\Program Files\Analog Devices\Core\smax4pnp.exe
C:\Program Files\Intel\Wireless\bin\ZCfgSvc.exe
C:\Program Files\Intel\Wireless\Bin\ifrmewrk.exe
C:\Program Files\Hewlett-Packard\HP ProtectTools Security Manager\PTHOSTTR.EXE
C:\Program Files\Java\jre1.6.0_01\bin\jusched.exe
C:\Program Files\Network Associates\VirusScan\SHSTAT.EXE
C:\Program Files\Intel\Wireless\Bin\Dot1XCfg.exe
C:\Program Files\Common Files\Network Associates\TalkBack\TBMon.exe
C:\Program Files\McAfee\Common Framework\udaterui.exe
C:\Program Files\Windows Defender\MSASCui.exe
C:\Program Files\McAfee\Common Framework\McTray.exe
C:\Program Files\Lavasoft\Ad-Aware\Ad-Aware.exe
C:\Program Files\Network Associates\VirusScan\Mcshield.exe
C:\Documents and Settings\plymtma\Desktop\Hijack This.exe
O2 - BHO: C:\WINDOWS\system32\tajf83ikdmf.dll - {BF56A325-23F2-42AD-F4E4-00AAC39CAA53} - C:\WINDOWS\system32\tajf83ikdmf.dll
O4 - HKLM\..\Run: [Client Access Service] "C:\Program Files\IBM\Client Access\cwbsvstr.exe"
O4 - HKLM\..\Run: [Client Access Help Update] "C:\Program Files\IBM\Client Access\cwbinhlp.exe"
O4 - HKLM\..\Run: [Client Access Check Version] "C:\Program Files\IBM\Client Access\cwbckver.exe" LOGIN
O4 - HKLM\..\Run: [Client Access Express Welcome] "C:\Program Files\IBM\Client Access\cwbwlwiz.exe"
O4 - HKLM\..\Run: [Client Access PC5250 Sound] "C:\Program Files\IBM\Client Access\Emulator\pcssnd.exe"
O4 - HKLM\..\Run: [QlbCtrl] %ProgramFiles%\Hewlett-Packard\HP Quick Launch Buttons\QlbCtrl.exe /Start
O4 - HKLM\..\Run: [IntelZeroConfig] "C:\Program Files\Intel\Wireless\bin\ZCfgSvc.exe"
O4 - HKLM\..\Run: [reƖ] "C:\Program Files\Intel\Wireless\Bin\ifrmewrk.exe" /tf Intel PROSet/Wireless
O4 - HKLM\..\Run: [PTHOSTTR] C:\Program Files\Hewlett-Packard\HP ProtectTools Security Manager\PTHOSTTR.EXE /Start
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_01\bin\jusched.exe"
O4 - HKLM\..\Run: [Synchronization Manager] %SystemRoot%\system32\mobsync.exe /logon
O4 - HKLM\..\Run: [ShStatEXE] "C:\Program Files\Network Associates\VirusScan\SHSTAT.EXE" /STANDALONE
O4 - HKLM\..\Run: [Network Associates Error Reporting Service] "C:\Program Files\Common Files\Network Associates\TalkBack\TBMon.exe"
O4 - HKLM\..\Run: [McAfeeUpdaterUI] "C:\Program Files\McAfee\Common Framework\udaterui.exe" /StartedFromRunKey
O4 - HKLM\..\Run: [Ad-Watch] C:\Program Files\Lavasoft\Ad-Aware\AAWTray.exe
O4 - HKLM\..\Run: [Windows Defender] "C:\Program Files\Windows Defender\MSASCui.exe" -hide
O4 - HKLM\..\Run: [MSConfig] C:\WINDOWS\PCHealth\HelpCtr\Binaries\MSConfig.exe /auto
O4 - HKLM\..\Run: [net] "C:\WINDOWS\system32\"
O4 - HKCU\..\Run: [RegistryMechanic] C:\Program Files\Registry Mechanic\RegMech.exe /H
O4 - HKCU\..\Run: [AdobeUpdater] C:\Program Files\Common Files\Adobe\Updater5\AdobeUpdater.exe
O4 - HKCU\..\Run: [DriverUpdaterPro] C:\Program Files\iXi Tools\Driver Updater Pro\DriverUpdaterPro.exe -t
O4 - HKCU\..\Run: [WIndows Rescue Disk] C:\DOCUME~1\plymtma\LOCALS~1\Temp\win16.exe
O4 - HKCU\..\Run: [Windows System Recover!] C:\DOCUME~1\plymtma\LOCALS~1\Temp\install.exe
O4 - HKCU\..\Run: [hivew] C:\WINDOWS\system32\rundll32.exe C:\DOCUME~1\plymtma\LOCALS~1\Temp\421477961231don.dll,Set1
O4 - HKCU\..\Run: [Protection System] "C:\Program Files\Protection System\psystem.exe" -noscan
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_01\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_01\bin\ssv.dll
O9 - Extra button: @btrez.dll,-4015 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra 'Tools' menuitem: @btrez.dll,-4017 - {CCA281CA-C863-46ef-9331-5C8D4460577F} - C:\Program Files\WIDCOMM\Bluetooth Software\btsendto_ie.htm
O9 - Extra button: (no name) - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O9 - Extra 'Tools' menuitem: Spybot - Search && Destroy Configuration - {DFB852A3-47F8-48C4-A200-58CAB36FD2A2} - C:\Program Files\Spybot - Search & Destroy\SDHelper.dll
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: Domain =
O17 - HKLM\Software\..\Telephony: DomainName =
O17 - HKLM\System\CS1\Services\Tcpip\Parameters: Domain =
O17 - HKLM\System\CS2\Services\Tcpip\Parameters: Domain =
O20 - AppInit_DLLs: ,C:\WINDOWS\TEMP\552742xxx.dll
O22 - SharedTaskScheduler: ghya673gidh87we9inkff - {BF56A325-23F2-42AD-F4E4-00AAC39CAA53} - C:\WINDOWS\system32\tajf83ikdmf.dll
O23 - Service: Bluetooth Service (btwdins) - Broadcom Corporation. - C:\Program Files\WIDCOMM\Bluetooth Software\bin\btwdins.exe
O23 - Service: Intel(R) PROSet/Wireless Event Log (EvtEng) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\EvtEng.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - c:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: Security Platform Management Service (IFXSpMgtSrv) - Infineon Technologies AG - C:\WINDOWS\system32\IFXSPMGT.exe
O23 - Service: Trusted Platform Core Service (IFXTCS) - Infineon Technologies AG - C:\WINDOWS\system32\IFXTCS.exe
O23 - Service: Lavasoft Ad-Aware Service - Lavasoft - C:\Program Files\Lavasoft\Ad-Aware\AAWService.exe
O23 - Service: McAfee Framework Service (McAfeeFramework) - McAfee, Inc. - C:\Program Files\McAfee\Common Framework\FrameworkService.exe
O23 - Service: Network Associates McShield (McShield) - McAfee, Inc. - C:\Program Files\Network Associates\VirusScan\Mcshield.exe
O23 - Service: Network Associates Task Manager (McTaskManager) - Network Associates, Inc. - C:\Program Files\Network Associates\VirusScan\VsTskMgr.exe
O23 - Service: Personal Secure Drive Service (PersonalSecureDriveService) - Infineon Technologies AG - C:\Program Files\ProtectTools\Embedded Security Software\PSDsrvc.EXE
O23 - Service: Intel(R) PROSet/Wireless Registry Service (RegSrvc) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\RegSrvc.exe
O23 - Service: RemoteDesktop Connection Manager (RemoteDesktopConnectionManager) - Magic Solutions, A Network Associates Company - C:\Program Files\Network Associates\Remote Desktop 32\CONNSRV.EXE
O23 - Service: Intel(R) PROSet/Wireless Service (S24EventMonitor) - Intel Corporation - C:\Program Files\Intel\Wireless\Bin\S24EvMon.exe
O23 - Service: sofatnet Service (sofatnet) - Sigma Designs In - C:\WINDOWS\system32\sofatnet.exe
End of file - 11422 bytes
Operating System : xp
Re: Need help with 3 issues please
Post by DragonMaster Jay on Mon 28 Sep 2009, 7:53 am
Please download ComboFix by sUBs
Link 1: or Link 2:
Please save the file to your Desktop, but rename it first:
Important information about ComboFix
Before the download:
  • Please copy and paste these instructions to Notepad and save to your Desktop, or print them - for easier access.
  • It is important to rename ComboFix before the download.
  • Please do not rename ComboFix to other names, but only the one indicated.
After the download:
  • Close any open browsers.
  • Very Important: Temporarily disable your anti-virus, script blocking and any anti-malware real-time protection before performing a scan. They can interfere with ComboFix or remove some of its embedded files which may cause "unpredictable results". Please visit here if you don't know how.
  • WARNING: Combofix will disconnect your machine from the Internet as soon as it starts
  • Please do not attempt to re-connect your machine back to the Internet until ComboFix has completely finished.
  • If there is no Internet connection after running ComboFix, then restart your computer to restore back your connection.
Running ComboFix:
  • Double click on svchost.exe & follow the prompts.
  • It will attempt to install the Recovery Console:
  • When ComboFix finishes, it will produce a report for you.
  • Please post the "C:\Combo-Fix.txt" in your next reply.
Troubleshooting ComboFix
Safe Mode:
If you still cannot get ComboFix to run, try booting into Safe Mode, and run it there.
(To boot into Safe Mode, tap F8 after BIOS, and just before the Windows
logo appears. A list of options will appear, select "Safe Mode.")
If this doesn't work either, try the same method (above method), but try to download it again, except name
ComboFix.exe to iexplore.exe, explorer.exe, or winlogon.exe.
Malware is known for blocking all "user" processes, except for its whitelist of system important processes such as iexplore.exe, explorer.exe, winlogon.exe.
GeekPolice Academy Manager
DragonMaster Jay
Manager | Tech Officer
